[GRASS-SVN] r39556 - grass/trunk/vector/v.db.select
svn_grass at osgeo.org
Sun Oct 18 05:30:44 EDT 2009
Author: martinl
Date: 2009-10-18 05:30:43 -0400 (Sun, 18 Oct 2009)
New Revision: 39556
grass/trunk/vector/v.db.select/main.c
v.db.select: initial OGR support
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2009-10-18 09:13:12 UTC (rev 39555)
+++ grass/trunk/vector/v.db.select/main.c 2009-10-18 09:30:43 UTC (rev 39556)
@@ -4,6 +4,7 @@
* MODULE: v.db.select
* AUTHOR(S): Radim Blazek
+ * OGR support by Martin Landa <landa.martin gmail.com>
* PURPOSE: Print vector attributes
@@ -40,7 +41,7 @@
dbColumn *column;
dbValue *value;
struct field_info *Fi;
- int field, ncols, col, more;
+ int ncols, col, more;
struct Map_info Map;
char query[1024];
struct ilist *list_lines;
@@ -105,8 +106,6 @@
exit(EXIT_FAILURE);
/* set input vector map name and mapset */
- field = atoi(field_opt->answer);
if (file_opt->answer && strcmp(file_opt->answer, "-") != 0) {
if (NULL == freopen(file_opt->answer, "w", stdout)) {
G_fatal_error(_("Unable to open file <%s> for writing"), file_opt->answer);
@@ -130,9 +129,9 @@
/* open input vector */
if (!r_flag->answer)
- Vect_open_old_head(&Map, map_opt->answer, "");
+ Vect_open_old_head2(&Map, map_opt->answer, "", field_opt->answer);
else {
- if (2 > Vect_open_old(&Map, map_opt->answer, "")) {
+ if (2 > Vect_open_old2(&Map, map_opt->answer, "", field_opt->answer)) {
Vect_close(&Map);
G_fatal_error(_("Unable to open vector map <%s> at topology level. "
"Flag '%c' requires topology level."),
@@ -140,9 +139,9 @@
- if ((Fi = Vect_get_field(&Map, field)) == NULL)
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
+ if ((Fi = Vect_get_field2(&Map, field_opt->answer)) == NULL)
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ field_opt->answer);
driver = db_start_driver_open_database(Fi->driver, Fi->database);
@@ -229,7 +228,7 @@
if (r_flag->answer) {
/* get minimal region extent */
- Vect_cidx_find_all(&Map, field, -1, cat, list_lines);
+ Vect_cidx_find_all(&Map, atoi(field_opt->answer), -1, cat, list_lines);
for (i = 0; i < list_lines->n_values; i++) {
line = list_lines->value[i];
area = Vect_get_centroid_area(&Map, line);
