[GRASS-SVN] r39557 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Oct 18 05:56:24 EDT 2009
Author: hamish
Date: 2009-10-18 05:56:23 -0400 (Sun, 18 Oct 2009)
New Revision: 39557
   grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
message wording, typo
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-10-18 09:30:43 UTC (rev 39556)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-10-18 09:56:23 UTC (rev 39557)
@@ -252,22 +252,21 @@
         # toggles
         self.radio1 = wx.RadioButton(parent=self, id=wx.ID_ANY,
-                                     label=_("Select coordinate system"),
+                                     label=_("Select coordinate system parameters from a list"),
                                      style = wx.RB_GROUP)
         self.radio2 = wx.RadioButton(parent=self, id=wx.ID_ANY,
-                                     label=_("Select EPSG code of coordinate system"))
+                                     label=_("Select EPSG code of spatial reference system"))
         self.radio3 = wx.RadioButton(parent=self, id=wx.ID_ANY,
-                                     label=_("Use coordinate system of selected "
-                                             "georeferenced file"))
+                                     label=_("Read projection and datum terms from a "
+                                             "georeferenced data file"))
         self.radio4 = wx.RadioButton(parent=self, id=wx.ID_ANY,
                                              "WKT or PRJ file"))
         self.radio5 = wx.RadioButton(parent=self, id=wx.ID_ANY,
-                                     label=_("Create custom PROJ.4 parameters "
-                                             "string for coordinate system"))
+                                     label=_("Specify projection and datum terms using custom "
+                                             "PROJ.4 parameters"))
         self.radio6 = wx.RadioButton(parent=self, id=wx.ID_ANY,
-                                     label=_("Use arbitrary non-earth "
-                                             "coordinate system (XY)"))
+                                     label=_("Create an arbitrary non-earth coordinate system (XY)"))
         # layout
         self.sizer.AddGrowableCol(1)
         self.sizer.SetVGap(10)
@@ -423,7 +422,9 @@
         if self.proj in self.parent.projections.keys():
             if self.proj == 'stp':
-                wx.MessageBox('State Plan Projection must be entered as an EPSG code or a custom PROJ4 string',
+                wx.MessageBox('Currently State Plane projections must be selected using the '
+                              'text-based setup (g.setproj), or entered by EPSG code or '
+                              'custom PROJ.4 terms.',
                               'Warning', wx.ICON_WARNING)
                 self.proj = ''
                 self.tproj.SetValue(self.proj)
