[GRASS-SVN] r39558 - grass/trunk/lib/db/dbmi_base
svn_grass at osgeo.org
Sun Oct 18 07:47:44 EDT 2009
Author: martinl
Date: 2009-10-18 07:47:43 -0400 (Sun, 18 Oct 2009)
New Revision: 39558
grass/trunk/lib/db/dbmi_base/column.c
column.c: initial doxygen strings
Modified: grass/trunk/lib/db/dbmi_base/column.c
--- grass/trunk/lib/db/dbmi_base/column.c 2009-10-18 09:56:23 UTC (rev 39557)
+++ grass/trunk/lib/db/dbmi_base/column.c 2009-10-18 11:47:43 UTC (rev 39558)
@@ -1,3 +1,17 @@
+ \file db/dbmi_base/column.c
+ \brief DBMI Library (base) - columns management
+ (C) 1999-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Joel Jones (CERL/UIUC), Radim Blazek
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
@@ -4,10 +18,14 @@
#include <grass/dbmi.h>
- \brief returns column structure for given table and column number
- \return
- \param
+ \brief Returns column structure for given table and column number
+ \param table pointer to dbTable
+ \param n column index (starting with '0')
+ \return pointer to dbColumn
+ \return NULL on error
dbColumn *db_get_table_column(dbTable * table, int n)
if (n < 0 || n >= table->numColumns)
@@ -16,216 +34,271 @@
- \brief returns column value for given column structure
- \return
- \param
+ \brief Returns column value for given column structure
+ \param column pointer to dbColumn
+ \return pointer to dbValue
dbValue *db_get_column_value(dbColumn * column)
return &column->value;
- \brief returns column default value for given column structure
- \return
- \param
+ \brief Returns column default value for given column structure
dbValue *db_get_column_default_value(dbColumn * column)
return &column->defaultValue;
- \brief define column sqltype for column (the function db_sqltype_name()
- returns sqltype description)
- \return
- \param
+ \brief Define column sqltype for column (the function db_sqltype_name()
+ returns sqltype description)
+ \verbatim
+ #define DB_SQL_TYPE_UNKNOWN 0
+ #define DB_SQL_TYPE_CHARACTER 1
+ #define DB_SQL_TYPE_SMALLINT 2
+ #define DB_SQL_TYPE_INTEGER 3
+ #define DB_SQL_TYPE_REAL 4
+ #define DB_SQL_TYPE_DOUBLE_PRECISION 6
+ #define DB_SQL_TYPE_DECIMAL 7
+ #define DB_SQL_TYPE_NUMERIC 8
+ #define DB_SQL_TYPE_DATE 9
+ #define DB_SQL_TYPE_TIME 10
+ #define DB_SQL_TYPE_TIMESTAMP 11
+ #define DB_SQL_TYPE_INTERVAL 12
+ #define DB_SQL_TYPE_TEXT 13
+ #define DB_SQL_TYPE_SERIAL 21
+ \endverbatim
+ \param sqltype SQL data type (see list)
void db_set_column_sqltype(dbColumn * column, int sqltype)
column->sqlDataType = sqltype;
- \brief
- \return
- \param
+ \brief Set column host data type
+ \param type data type
void db_set_column_host_type(dbColumn * column, int type)
column->hostDataType = type;
- \brief
- \return
- \param
+ \brief Get column scale
+ \return scale
int db_get_column_scale(dbColumn * column)
return column->scale;
- \brief
- \return
- \param
+ \brief Set column scale
+ \param scale column scale value
void db_set_column_scale(dbColumn * column, int scale)
column->scale = scale;
- \brief
- \return
- \param
+ \brief Get column precision
+ \return precision
int db_get_column_precision(dbColumn * column)
return column->precision;
- \brief
- \return
- \param
+ \brief Set column precision
+ \param precision value
void db_set_column_precision(dbColumn * column, int precision)
column->precision = precision;
- \brief returns column sqltype for column (the function db_sqltype_name()
- \return
- \param
+ \brief Returns column sqltype for column (the function
+ db_sqltype_name() returns sqltype description) \return \param
+ \return sql data type (see include/dbmi.h)
int db_get_column_sqltype(dbColumn * column)
return column->sqlDataType;
+ \brief Get column host type
+ \return data type (see include/dbmi.h)
int db_get_column_host_type(dbColumn * column)
return column->hostDataType;
- \brief
- \return
- \param
+ \brief Set default value identificator
void db_set_column_has_defined_default_value(dbColumn * column)
column->hasDefaultValue = 1;
- \brief
- \return
- \param
+ \brief Unset default value identificator
void db_set_column_has_undefined_default_value(dbColumn * column)
column->hasDefaultValue = 0;
- \brief
- \return
- \param
void db_unset_column_has_default_value(dbColumn * column)
- \brief
- \return
- \param
+ \brief Check if column has defined default value
+ \return 1 if true
+ \return 0 if false
int db_test_column_has_default_value(dbColumn * column)
return (column->hasDefaultValue != 0);
- \brief
- \return
- \param
+ \return 1 if true
int db_test_column_has_defined_default_value(dbColumn * column)
return (column->hasDefaultValue);
- \brief
- \return
- \param
+ \return 1 if false
+ \return 0 if true
int db_test_column_has_undefined_default_value(dbColumn * column)
return (!column->hasDefaultValue);
- \brief
- \return
- \param
+ \brief Set default value to be used
void db_set_column_use_default_value(dbColumn * column)
column->useDefaultValue = 1;
- \brief
- \return
- \param
+ \brief Unset default value to be used
void db_unset_column_use_default_value(dbColumn * column)
column->useDefaultValue = 0;
- \brief
- \return
- \param
+ \brief Checks if default value is used
+ \return 1 if true
int db_test_column_use_default_value(dbColumn * column)
return (column->useDefaultValue != 0);
- \brief
- \return
- \param
+ \brief Set null value to be allowed
void db_set_column_null_allowed(dbColumn * column)
column->nullAllowed = 1;
- \brief
- \return
- \param
+ \brief Unset null value to be allowed
void db_unset_column_null_allowed(dbColumn * column)
column->nullAllowed = 0;
- \brief
- \return
- \param
+ \brief Checks if null value is allowed
+ \return 1 if true
int db_test_column_null_allowed(dbColumn * column)
@@ -233,90 +306,97 @@
- \brief
- \return
- \param
+ \brief Get column's length
+ \return length
int db_get_column_length(dbColumn * column)
return column->dataLen;
- \brief
- \return
- \param
+ \brief Set column's length
+ \param length value
void db_set_column_length(dbColumn * column, int length)
column->dataLen = length;
- \brief
- \return
- \param
+ \brief Set select privilages to be granted
void db_set_column_select_priv_granted(dbColumn * column)
column->select = DB_GRANTED;
- \brief
- \return
- \param
+ \brief Unset select privilages
void db_set_column_select_priv_not_granted(dbColumn * column)
column->select = DB_NOT_GRANTED;
- \brief
- \return
- \param
+ \brief Get select privilages
+ \return privilages
int db_get_column_select_priv(dbColumn * column)
return column->select;
- \brief
- \return
- \param
+ \brief Set update privilages to be granted
void db_set_column_update_priv_granted(dbColumn * column)
column->update = DB_GRANTED;
- \brief
- \return
- \param
+ \brief Unset update privilages
void db_set_column_update_priv_not_granted(dbColumn * column)
column->update = DB_NOT_GRANTED;
- \brief
- \return
- \param
+ \brief Get update privilages
int db_get_column_update_priv(dbColumn * column)
return column->update;
- \brief
- \return
- \param
+ \brief Initialize dbColumn
+ \param column pointer to dbColumn to be initialized
void db_init_column(dbColumn * column)
db_zero((void *)column, sizeof(dbColumn));
@@ -327,29 +407,39 @@
- \brief
- \return
- \param
+ \brief Set column name
+ \param name column name
+ \return DB_OK on success
+ \return error code on failure
int db_set_column_name(dbColumn * column, const char *name)
return db_set_string(&column->columnName, name);
- \brief returns column name for given column
- \return
- \param
+ \brief Returns column name for given column
+ \return pointer to string with column name
const char *db_get_column_name(dbColumn * column)
return db_get_string(&column->columnName);
- \brief
- \return
- \param
+ \brief Set column description
+ \param description column's description
int db_set_column_description(dbColumn * column, const char *description)
@@ -357,20 +447,22 @@
- \brief returns column description for given column
- \return
- \param
+ \brief Returns column description for given column
+ \return pointer to string with column's description
const char *db_get_column_description(dbColumn * column)
return db_get_string(&column->description);
- \brief frees column structure
- \return
- \param
+ \brief Frees column structure
void db_free_column(dbColumn * column)
db_free_string(&column->columnName);
