[GRASS-SVN] r38939 - grass/branches/develbranch_6/lib/gmath
svn_grass at osgeo.org
Tue Sep 1 05:00:38 EDT 2009
Author: hamish
Date: 2009-09-01 05:00:36 -0400 (Tue, 01 Sep 2009)
New Revision: 38939
grass/branches/develbranch_6/lib/gmath/ccmath_grass_wrapper.c
G_math_solvps() should return something
Modified: grass/branches/develbranch_6/lib/gmath/ccmath_grass_wrapper.c
--- grass/branches/develbranch_6/lib/gmath/ccmath_grass_wrapper.c 2009-08-31 20:30:54 UTC (rev 38938)
+++ grass/branches/develbranch_6/lib/gmath/ccmath_grass_wrapper.c 2009-09-01 09:00:36 UTC (rev 38939)
@@ -164,18 +164,22 @@
return solv(a[0],b, n);
\brief Solve a symmetric positive definite linear system S*x = b.
\param a = array containing system matrix S (altered to Cholesky upper right factor by computation)
\param b = array containing system vector b as input and solution vector x as output
\param n = dimension of system
- \return: 0 -> normal exit 1 -> input matrix not positive definite
+ \return: 0 -> normal exit; -1 -> input matrix not positive definite
int G_math_solvps(double **a,double *b,int n)
- solvps(a[0], b,n);
+ return solvps(a[0], b,n);
\brief Solve a tridiagonal linear system M*x = y.
@@ -191,6 +195,8 @@
solvtd(a, b, c, x, m);
return;
\brief Solve an upper right triangular linear system T*x = b.
@@ -199,15 +205,15 @@
\param n = dimension (dim(a)=n*n,dim(b)=n)
\return value: f = status flag, with 0 -> normal exit, -1 -> system singular
int G_math_solvru(double **a,double *b,int n)
return solvru(a[0], b, n);
\brief Invert (in place) a general real matrix A -> Inv(A).
\param a = array containing the input matrix A. This is converted to the inverse matrix.
\param n = dimension of the system (i.e. A is n x n )
\return: 0 -> normal exit, 1 -> singular input matrix
@@ -216,6 +222,8 @@
return minv(a[0], n);
\brief Invert (in place) a symmetric real matrix, V -> Inv(V).
@@ -229,11 +237,10 @@
return psinv( a[0], n);
\brief Invert an upper right triangular matrix T -> Inv(T).
\param a = pointer to array of upper right triangular matrix, This is replaced by the inverse matrix.
\param n = dimension (dim(a)=n*n)
\return value: status flag, with 0 -> matrix inverted -1 -> matrix singular
@@ -242,6 +249,8 @@
return ruinv(a[0], n);
@@ -252,7 +261,6 @@
\brief Compute the eigenvalues of a real symmetric matrix A.
\param a = pointer to array of symmetric n by n input matrix A. The computation alters these values.
\param ev = pointer to array of the output eigenvalues
\param n = dimension parameter (dim(a)= n*n, dim(ev)= n)
@@ -262,6 +270,8 @@
eigval(a[0], ev, n);
return;
\brief Compute the eigenvalues and eigenvectors of a real symmetric matrix A.
@@ -281,6 +291,8 @@
eigen(a[0], ev, n);
return;
\brief Compute the maximum (absolute) eigenvalue and corresponding eigenvector of a real symmetric matrix A.
@@ -358,6 +370,8 @@
d[i] >= 0 for i = 0 to n-1.
\brief Compute the singular values of a real m by n matrix A.
@@ -373,11 +387,12 @@
return svdval(d, a[0], m, n);
\brief Compute singular values when m >> n.
\param d = pointer to double array of dimension n (output = singular values of A)
\param a = pointer to store of the m by n input matrix A (A is altered by the computation)
\param m = number of rows in A
@@ -388,9 +403,10 @@
return sv2val(d, a[0], m, n);
\brief Compute the singular value transformation S = U~*A*V.
@@ -405,9 +421,9 @@
return svduv(d, a[0], u[0], m, v[0], n);
\brief Compute the singular value transformation when m >> n.
@@ -421,10 +437,11 @@
return sv2uv(d, a[0], u[0], m, v[0], n);
\brief Compute the singular value transformation with A overloaded by the partial U-matrix.
