[GRASS-SVN] r38940 - grass/trunk/lib/vector
svn_grass at osgeo.org
Tue Sep 1 06:10:52 EDT 2009
Author: martinl
Date: 2009-09-01 06:10:51 -0400 (Tue, 01 Sep 2009)
New Revision: 38940
grass/trunk/lib/vector/vectorlib.dox
vectorlib.dox: some topo rules merged from GRASS 5 PA
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2009-09-01 09:00:36 UTC (rev 38939)
+++ grass/trunk/lib/vector/vectorlib.dox 2009-09-01 10:10:51 UTC (rev 38940)
@@ -744,6 +744,33 @@
Topology is written for native format while pseudo-topology is written
for OGR sources, SHAPE-link.
+The following rules apply to the vector data:
+- Lines should not cross each other (i.e., lines which would cross must
+ be split at their intersection to form distict lines).
+- Linear primitives which share nodes at exactly same points (i.e.,
+ must be snapped together). This is particulary important since nodes
+ are not exactly represented in the coor file, but only implicitly as
+ endpoints of lines.
+- Common area boundaries should appear only once (i.e., should not be
+ double digitized).
+- Areas must be explicitly closed. This means that it must be possible
+ to complete each area by following one or more boundaries that are
+ connected by common nodes, and that such tracings result is closed
+ areas.
+- It is recommended that area features and linear features be placed
+ in separate layers. However if area features and linear features
+ must appear in one layer, common boundaries should be digitized only
+ once. A boundary that is also a line (e.g., a road which is also a
+ field boundary), should be digitized as a boundary to complete the
+ area. The area feature should be labeled by a centroid as an
+ area. Additionally, the common boundary itself (i.e., the boundary
+ which is also a line) should be labeled as a line by a distict
+ category number.
+Vector map topology can be cleaned at user level by <tt>v.clean</tt>
+command.
\subsection topo_file_format Topo file format specification
Topo file is read by Vect_open_topo().
