[GRASS-SVN] r38941 - grass/trunk/lib/vector
svn_grass at osgeo.org
Tue Sep 1 15:33:52 EDT 2009
Author: martinl
Date: 2009-09-01 15:33:51 -0400 (Tue, 01 Sep 2009)
New Revision: 38941
grass/trunk/lib/vector/vectorlib.dox
vectorlib.dox: some minor updates (merged from GRASS 5 PM)
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2009-09-01 10:10:51 UTC (rev 38940)
+++ grass/trunk/lib/vector/vectorlib.dox 2009-09-01 19:33:51 UTC (rev 38941)
@@ -344,17 +344,21 @@
For historical reasons, there are two internal libraries:
- diglib (with dig_*() functions), GRASS 3.x/4.x
-- Vlib (with V1_*(), V2_*() and Vect_*() functions), GRASS 4.x/5.x (except for the 5.7 interim version)
+- Vlib (with V1_*(), V2_*() and Vect_*() functions), GRASS 4.x/5.x
+ (except for the 5.7 interim version)
The vector library was introduced in GRASS 4.0 to hide internal vector
files' formats and structures. In GRASS 6/7, everything is accessed via
Vect_*() functions, for example:
Old 4.x code:
\code
xx = Map.Att[Map.Area[area_num].att].x;
\endcode
New 6.x/7.x functions:
\code
centroid = Vect_get_area_centroid(Map, area_num);
Vect_read_line(Map, line_p, NULL, centroid);
@@ -366,9 +370,19 @@
functions). All available Vect_*() functions are topological vector
functions.
-<i>Note: For details please read Blazek et al. 2002 (see below) as well as the
-references in this document.</i>
+The following include file contains definitions and structures
+required by some of the routines in this library. The programmer
+should therefore include this file in any code that uses the vector
+library:
+\code
+#include <grass/vector.h>
+\endcode
+<i>Note: For details please read Blazek et al. 2002 (see below) as
+well as the references in this document.</i>
\section vlib_structures Vector library structures
\subsection Map_info Map_info structure
@@ -1512,8 +1526,21 @@
\section vlibfunc List of vector library functions
+The vector library provides the GRASS programmer with routines to
+process vector data. The routines in the vector library are presented
+in functional groupings, rather than in alphabetical order. The order
+of presentation will, it is hoped, provide better understanding of how
+the library is to be used, as well as show the interrelationships
+among the various routines. Note that a good way to understand how to
+use these routines is to look at the source code for GRASS modules
+which use them.
+Note: All routines start with one of following prefixes Vect_, V1_,
+V2_ or dig_. To avoid name conficts, programmers should not create
+variables or routines in their own modules which use this prefix.
The Vect_*() functions are the programmer's API for GRASS vector
-programming.
+programming. The programmer should use only routines with this prefix.
- \subpage area
- \subpage array
