[GRASS-SVN] r38963 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Fri Sep 4 05:49:33 EDT 2009
Author: benducke
Date: 2009-09-04 05:49:32 -0400 (Fri, 04 Sep 2009)
New Revision: 38963
grass/trunk/vector/v.out.ogr/main.c
Synchronized with version in 6.5:
* added -u ("update") flag for writing layers to existing OGR datasources
* added -s ("skip cat") flag for dropping GRASS cat column from output
* made sure that OGR features are properly created and destroyed
each time through the main export loop
* fixed two nasty mem leaks in the attribute field generation code (mk_att)
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-09-04 08:57:05 UTC (rev 38962)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-09-04 09:49:32 UTC (rev 38963)
@@ -2,16 +2,16 @@
* MODULE: v.out.ogr
* AUTHOR(S): Radim Blazek
- * Some extensions: Markus Neteler
+ * Some extensions: Markus Neteler, Benjamin Ducke
* PURPOSE: Category manipulations
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
+ * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * This program is free software under the
+ * GNU General Public License (>=v2).
* Read the file COPYING that comes with GRASS
* for details.
@@ -31,7 +31,7 @@
int nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
int mk_att(int cat, struct field_info *Fi, dbDriver *Driver,
- int ncol, int doatt, OGRFeatureH Ogr_feature);
+ int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature);
char *OGR_list_write_drivers();
char OGRdrivers[2000];
@@ -43,7 +43,7 @@
struct GModule *module;
struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt,
*field_opt, *dsco, *lco;
- struct Flag *cat_flag, *esristyle, *poly_flag;
+ struct Flag *cat_flag, *esristyle, *poly_flag, *update_flag, *nocat_flag;
char buf[2000];
char key1[200], key2[200];
struct Key_Value *projinfo, *projunits;
@@ -147,6 +147,14 @@
_("OGR layer creation option (format specific, NAME=VALUE)");
lco->guisection = _("Creation");
+ update_flag = G_define_flag();
+ update_flag->key = 'u';
+ update_flag->description = _("Open an existing datasource for update");
+ nocat_flag = G_define_flag();
+ nocat_flag->key = 's';
+ nocat_flag->description = _("Skip export of GRASS category ID ('cat') attribute");
cat_flag->key = 'c';
cat_flag->description = _("Also export features without category (not labeled). "
@@ -173,7 +181,7 @@
if (!layer_opt->answer) {
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
if (G_name_is_fully_qualified(in_opt->answer, xname, xmapset))
layer_opt->answer = G_store(xname);
else
@@ -261,8 +269,14 @@
i++;
- G_debug(1, "Create OGR data source");
- Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
+ if ( update_flag->answer ) {
+ G_debug(1, "Update OGR data source");
+ Ogr_ds = OGR_Dr_Open(Ogr_driver, dsn_opt->answer, TRUE);
+ } else {
+ G_debug(1, "Create OGR data source");
+ Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
CSLDestroy(papszDSCO);
if (Ogr_ds == NULL)
G_fatal_error(_("Unable to open OGR data source '%s'"),
@@ -317,7 +331,12 @@
Fi = Vect_get_field(&In, field);
if (Fi == NULL) {
G_warning(_("No attribute table found -> using only category numbers as attributes"));
+ /* if we have no more than a 'cat' column, then that has to
+ be exported in any case */
+ if (nocat_flag->answer) {
+ G_warning(_("Exporting 'cat' anyway, as it is the only attribute table field"));
+ nocat_flag->answer=0;
Ogr_field = OGR_Fld_Create("cat", OFTInteger);
OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
OGR_Fld_Destroy(Ogr_field);
@@ -378,7 +397,21 @@
OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
+ if (!nocat_flag->answer) {
+ Ogr_field =
+ OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
+ OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
+ OGR_Fld_Destroy(Ogr_field);
+ } else {
+ /* skip export of 'cat' field */
+ if ( strcmp (Fi->key,db_get_column_name(Column)) != 0 ) {
+ Ogr_field =
if (keycol == -1)
G_fatal_error(_("Key column '%s' not found"), Fi->key);
@@ -386,7 +419,6 @@
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- Ogr_feature = OGR_F_Create(Ogr_featuredefn);
fout = fskip = nocat = noatt = nocatskip = 0;
@@ -481,6 +513,8 @@
Points->z[j]);
+ Ogr_feature = OGR_F_Create(Ogr_featuredefn);
OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
/* Output one feature for each category */
@@ -496,10 +530,11 @@
continue;
- mk_att(cat, Fi, Driver, ncol, doatt, Ogr_feature);
+ mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer, Ogr_feature);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
+ OGR_F_Destroy(Ogr_feature);
@@ -553,6 +588,7 @@
OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
@@ -568,10 +604,11 @@
continue;
@@ -598,6 +635,8 @@
if (type & GV_FACE) {
/* Geometry */
Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
ring = OGR_G_CreateGeometry(wkbLinearRing);
@@ -625,18 +664,18 @@
continue;
} /* if type & GV_FACE */
} /* for */
- OGR_F_Destroy(Ogr_feature);
OGR_DS_Destroy(Ogr_ds);
Vect_close(&In);
@@ -660,7 +699,7 @@
* all boundaries/centroids.
* OTOH why should be reported? */
- if ( ((otype & GV_POINTS) || (otype & GV_LINES)) && fskip > 0 )
+ if ( ((otype & GV_POINTS) || (otype & GV_LINES)) && fskip > 0 )
G_warning ( "%d features of different type skip", fskip);
@@ -669,7 +708,7 @@
int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
- int doatt, OGRFeatureH Ogr_feature)
+ int doatt, int nocat, OGRFeatureH Ogr_feature)
int j, ogrfieldnum;
char buf[2000];
@@ -710,9 +749,14 @@
if (!more) {
/* G_warning ("No database record for cat = %d", cat); */
/* Set at least key column to category */
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
- OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
- noatt++;
+ if (!nocat) {
+ ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
+ OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
+ noatt++;
+ } else {
+ G_fatal_error (_("No database record for cat = %d and export of 'cat' disabled"),
+ cat);
else {
Table = db_get_cursor_table(&cursor);
@@ -758,6 +802,7 @@
+ db_close_cursor ( &cursor );
@@ -772,6 +817,8 @@
fout++;
+ db_free_string(&dbstring);
return 1;
