[GRASS-SVN] r38964 - grass/trunk/include/vect
Fri Sep 4 10:06:51 EDT 2009
Author: benducke
Date: 2009-09-04 10:06:50 -0400 (Fri, 04 Sep 2009)
New Revision: 38964
   grass/trunk/include/vect/dig_structs.h
small change to comment in struct Plus_head:
plus_t n_vfaces;		 /* current number of volume faces */
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2009-09-04 09:49:32 UTC (rev 38963)
+++ grass/trunk/include/vect/dig_structs.h	2009-09-04 14:06:50 UTC (rev 38964)
@@ -45,7 +45,7 @@
 /*! \brief Bounding box */
-struct bound_box
+struct bound_box
     double N;			/* north */
     double S;			/* south */
@@ -165,7 +165,7 @@
 /*! \brief Non-native format info (OGR)
-  \todo Structure size should not change depending on compilation I think, do it better
+  \todo Structure size should not change depending on compilation I think, do it better
 struct Format_info_ogr
@@ -284,9 +284,9 @@
     struct bound_box box;	 /* vector map bounding box */
     /*** topology ***/
-    struct P_node **Node;	 /* struct P_node array of pointers
+    struct P_node **Node;	 /* struct P_node array of pointers
 				    1st item is 1 for  */
-    struct P_line **Line;	 /* struct P_line array of pointers
+    struct P_line **Line;	 /* struct P_line array of pointers
 				    all these (not 0) */
     struct P_area **Area;
     struct P_isle **Isle;
@@ -307,7 +307,7 @@
     plus_t n_clines;		 /* current number of centroids */
     plus_t n_flines;		 /* current number of faces */
     plus_t n_klines;		 /* current number of kernels*/
-    plus_t n_vfaces;		 /* current number of volumes */
+    plus_t n_vfaces;		 /* current number of volume faces */
     plus_t n_hfaces;		 /* current number of hole faces */
     plus_t alloc_nodes;		 /* number of nodes we have alloc'ed
@@ -333,7 +333,7 @@
     int Spidx_new;               /* set to 1 if new spatial index will be generated */
     struct gvfile spidx_fp;	 /* spatial index file pointer */
     char *spidx_node_fname;      /* node spatial index file name */
     off_t Node_spidx_offset;	 /* offset of nodes in sidx file */
@@ -400,9 +400,9 @@
     double *node_costs;		/* node costs */
     int cost_multip;		/* edge and node costs
 				   multiplicator */
     int open;			/* should be 0x5522AA22 (VECT_OPEN_CODE) if opened correctly
-				   or        0x22AA2255 (VECT_CLOSED_CODE) if closed
+				   or        0x22AA2255 (VECT_CLOSED_CODE) if closed
 				   anything else implies that structure has
 				   never been initialized
@@ -477,7 +477,7 @@
     plus_t N2;			/* end node   */
     plus_t left;		/* area/isle number to left, negative
 				   for isle area number for centroid,
-				   negative for duplicate centroid
+				   negative for duplicate centroid
     plus_t right;		/* area/isle number to right, negative
 				 * for isle */
