[GRASS-SVN] r38969 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Fri Sep 4 11:29:27 EDT 2009
Author: benducke
Date: 2009-09-04 11:29:27 -0400 (Fri, 04 Sep 2009)
New Revision: 38969
grass/trunk/vector/v.out.ogr/main.c
Fixed export of centroids only.
Added some type checks that make sure no action is performed if there is actually nothing to export.
Added infrastructure for GV_VOLUME (but no functionality and not exposed to user yet).
Fixed counting of areas (was counted like a primitive type, which it is not).
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-09-04 14:20:51 UTC (rev 38968)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-09-04 15:29:27 UTC (rev 38969)
@@ -39,6 +39,7 @@
int main(int argc, char *argv[])
int i, j, k, centroid, otype, donocat;
+ int num_to_export;
int field;
struct GModule *module;
struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt,
@@ -196,6 +197,8 @@
wkbtype = wkbPolygon;
else if (otype & GV_FACE)
wkbtype = wkbPolygon25D;
+ else if (otype & GV_VOLUME)
+ wkbtype = wkbPolygon25D;
if (poly_flag->answer)
@@ -445,21 +448,94 @@
"Verify 'type' parameter."), Vect_get_num_primitives(&In,
GV_CENTROID));
- if (Vect_get_num_primitives(&In, GV_AREA) > 0 && !(otype & GV_AREA))
+ if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
G_warning(_("%d areas found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_primitives(&In,
- GV_AREA));
+ "Verify 'type' parameter."), Vect_get_num_areas(&In));
if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
G_warning(_("%d faces found, but not requested to be exported. "
GV_FACE));
- /* add? GV_KERNEL */
+ if (Vect_get_num_volumes(&In) > 0 && !(otype & GV_VOLUME))
+ G_warning(_("%d volume(s) found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_volumes(&In));
+ /* warn and eventually abort if there is nothing to be exported */
+ num_to_export = 0;
+ if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
+ G_warning(_("No points found, but requested to be exported. "
+ "Will skip this geometry type."));
+ } else {
+ if ( otype & GV_POINT )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+ if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
+ G_warning(_("No lines found, but requested to be exported. "
+ } else {
+ if ( otype & GV_LINE )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 && (otype & GV_BOUNDARY)) {
+ G_warning(_("No boundaries found, but requested to be exported. "
+ } else {
+ if ( otype & GV_BOUNDARY )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+ if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
+ G_warning(_("No areas found, but requested to be exported. "
+ } else {
+ if ( otype & GV_AREA )
+ num_to_export = num_to_export + Vect_get_num_areas(&In);
+ if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 && (otype & GV_CENTROID)) {
+ G_warning(_("No centroids found, but requested to be exported. "
+ } else {
+ if ( otype & GV_CENTROID )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+ if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
+ G_warning(_("No faces found, but requested to be exported. "
+ } else {
+ if ( otype & GV_FACE )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+ if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
+ G_warning(_("No kernels found, but requested to be exported. "
+ } else {
+ if ( otype & GV_KERNEL )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+ if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
+ G_warning(_("No volumes found, but requested to be exported. "
+ } else {
+ if ( otype & GV_VOLUME )
+ num_to_export = num_to_export + Vect_get_num_volumes(&In);
+ G_debug(1, "Requested to export %d geometries", num_to_export);
+ if ( num_to_export < 1 ) {
+ G_fatal_error(_("Nothing to export. Aborting."));
/* Lines (run always to count features of different type) */
if ((otype & GV_POINTS) || (otype & GV_LINES)) {
- G_message(_("Exporting %i points/lines..."), Vect_get_num_lines(&In));
+ G_message(_("Exporting %i geometries..."), Vect_get_num_lines(&In));
for (i = 1; i <= Vect_get_num_lines(&In); i++) {
G_percent(i, Vect_get_num_lines(&In), 1);
