[GRASS-SVN] r38970 - grass/branches/develbranch_6/vector/v.out.ogr
svn_grass at osgeo.org
Fri Sep 4 11:30:28 EDT 2009
Author: benducke
Date: 2009-09-04 11:30:27 -0400 (Fri, 04 Sep 2009)
New Revision: 38970
grass/branches/develbranch_6/vector/v.out.ogr/main.c
Fixed export of centroids only.
Added some type checks that make sure no action is performed if there is actually nothing to export.
Added infrastructure for GV_VOLUME (but no functionality and not exposed to user yet).
Fixed counting of areas (was counted like a primitive type, which it is not).
Modified: grass/branches/develbranch_6/vector/v.out.ogr/main.c
--- grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-09-04 15:29:27 UTC (rev 38969)
+++ grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-09-04 15:30:27 UTC (rev 38970)
@@ -39,6 +39,7 @@
int main(int argc, char *argv[])
int i, j, k, centroid, otype, donocat;
+ int num_to_export;
char *mapset;
int field;
struct GModule *module;
@@ -94,7 +95,7 @@
type_opt->answer = "line,boundary";
type_opt->description =
_("Feature type. Combination of types is not supported "
- "by all formats.");
+ "by all output formats.");
type_opt->guisection = _("Input");
dsn_opt = G_define_option();
@@ -196,6 +197,8 @@
wkbtype = wkbPolygon;
else if (otype & GV_FACE)
wkbtype = wkbPolygon25D;
+ else if (otype & GV_VOLUME)
+ wkbtype = wkbPolygon25D;
if (poly_flag->answer)
@@ -444,21 +447,100 @@
"Verify 'type' parameter."), Vect_get_num_primitives(&In,
GV_CENTROID));
- if (Vect_get_num_primitives(&In, GV_AREA) > 0 && !(otype & GV_AREA))
+ if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
G_warning(_("%d areas found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_primitives(&In,
- GV_AREA));
+ "Verify 'type' parameter."), Vect_get_num_areas(&In));
if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
- G_warning(_("%d faces found, but not requested to be exported. "
+ G_warning(_("%d face(s) found, but not requested to be exported. "
GV_FACE));
- /* add? GV_KERNEL */
+ if (Vect_get_num_primitives(&In, GV_KERNEL) > 0 &&
+ !(otype & GV_KERNEL) && !(otype & GV_VOLUME))
+ G_warning(_("%d kernel(s) found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_primitives(&In,
+ GV_KERNEL));
+ if (Vect_get_num_volumes(&In) > 0 && !(otype & GV_VOLUME))
+ G_warning(_("%d volume(s) found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_volumes(&In));
+ /* warn and eventually abort if there is nothing to be exported */
+ num_to_export = 0;
+ if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
+ G_warning(_("No points found, but requested to be exported. "
+ "Will skip this geometry type."));
+ } else {
+ if ( otype & GV_POINT )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+ if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
+ G_warning(_("No lines found, but requested to be exported. "
+ } else {
+ if ( otype & GV_LINE )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 && (otype & GV_BOUNDARY)) {
+ G_warning(_("No boundaries found, but requested to be exported. "
+ } else {
+ if ( otype & GV_BOUNDARY )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+ if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
+ G_warning(_("No areas found, but requested to be exported. "
+ } else {
+ if ( otype & GV_AREA )
+ num_to_export = num_to_export + Vect_get_num_areas(&In);
+ if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 && (otype & GV_CENTROID)) {
+ G_warning(_("No centroids found, but requested to be exported. "
+ } else {
+ if ( otype & GV_CENTROID )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+ if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
+ G_warning(_("No faces found, but requested to be exported. "
+ } else {
+ if ( otype & GV_FACE )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+ if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
+ G_warning(_("No kernels found, but requested to be exported. "
+ } else {
+ if ( otype & GV_KERNEL )
+ num_to_export = num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+ if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
+ G_warning(_("No volumes found, but requested to be exported. "
+ } else {
+ if ( otype & GV_VOLUME )
+ num_to_export = num_to_export + Vect_get_num_volumes(&In);
+ G_debug(1, "Requested to export %d geometries", num_to_export);
+ if ( num_to_export < 1 ) {
+ G_fatal_error(_("Nothing to export. Aborting."));
/* Lines (run always to count features of different type) */
if ((otype & GV_POINTS) || (otype & GV_LINES)) {
- G_message(_("Exporting %i points/lines..."), Vect_get_num_lines(&In));
+ G_message(_("Exporting %i geometries..."), Vect_get_num_lines(&In));
for (i = 1; i <= Vect_get_num_lines(&In); i++) {
G_percent(i, Vect_get_num_lines(&In), 1);
@@ -499,7 +581,7 @@
OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
- else if (type == GV_POINT) {
+ else if ((type == GV_POINT) || ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
Points->z[0]);
@@ -674,7 +756,71 @@
} /* for */
+ /* Kernels */
+ if (otype & GV_KERNEL) {
+ G_message(_("Exporting %i kernels..."), Vect_get_num_kernels(&In));
+ for (i = 1; i <= Vect_get_num_lines(&In); i++) {
+ G_percent(i, Vect_get_num_lines(&In), 1);
+ type = Vect_read_line(&In, Points, Cats, i);
+ G_debug(2, "line = %d type = %d", i, type);
+ if (!(otype & type)) {
+ G_debug(2, "type %d not specified -> skipping", type);
+ fskip++;
+ continue;
+ Vect_cat_get(Cats, field, &cat);
+ if (cat < 0 && !donocat) { /* Do not export not labeled */
+ nocatskip++;
+ continue;
+ /* Geometry */
+ if (type == GV_KERNEL) {
+ Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
+ OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+ Points->z[0]);
+ Ogr_feature = OGR_F_Create(Ogr_featuredefn);
+ OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
+ /* Output one feature for each category */
+ for (j = -1; j < Cats->n_cats; j++) {
+ if (j == -1) {
+ if (cat >= 0)
+ continue; /* cat(s) exists */
+ else {
+ if (Cats->field[j] == field)
+ cat = Cats->cat[j];
+ else
+ continue;
+ mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer, Ogr_feature);
+ OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
+ OGR_G_DestroyGeometry(Ogr_geometry);
+ OGR_F_Destroy(Ogr_feature);
+ TODO: Volumes. Do not export kernels here, that's already done.
+ We do need to worry about holes, though.
+ NOTE: We can probably just merge this with faces export function.
+ Except for GRASS, which output format would know the difference?
+ if ((otype & GV_VOLUME)) {
+ G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
+ G_warning(_("Export of volumes not implemented yet. Skipping."));
OGR_DS_Destroy(Ogr_ds);
Vect_close(&In);
