[GRASS-SVN] r38971 - grass/trunk/include
svn_grass at osgeo.org
Fri Sep 4 13:28:58 EDT 2009
Author: martinl
Date: 2009-09-04 13:28:57 -0400 (Fri, 04 Sep 2009)
New Revision: 38971
grass/trunk/include/vector.h
don't use argument identifiers in header files
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-09-04 15:30:27 UTC (rev 38970)
+++ grass/trunk/include/vector.h 2009-09-04 17:28:57 UTC (rev 38971)
@@ -192,9 +192,9 @@
int Vect_get_num_areas(const struct Map_info *);
int Vect_get_num_faces(const struct Map_info *);
int Vect_get_num_kernels(struct Map_info *);
-int Vect_get_num_volumes(struct Map_info *map);
+int Vect_get_num_volumes(struct Map_info *);
int Vect_get_num_islands(const struct Map_info *);
-int Vect_get_num_holes(struct Map_info *map);
+int Vect_get_num_holes(struct Map_info *);
int Vect_get_line_box(const struct Map_info *, int, struct bound_box *);
int Vect_get_area_box(const struct Map_info *, int, struct bound_box *);
int Vect_get_isle_box(const struct Map_info *, int, struct bound_box *);
