[GRASS-SVN] r39050 - grass/branches/develbranch_6/vector/v.label.sa
Sun Sep 6 15:42:47 EDT 2009
Author: wolf
Date: 2009-09-06 15:42:46 -0400 (Sun, 06 Sep 2009)
New Revision: 39050
   grass/branches/develbranch_6/vector/v.label.sa/labels.c
   grass/branches/develbranch_6/vector/v.label.sa/labels.h
Patched a few memory leaks
Modified: grass/branches/develbranch_6/vector/v.label.sa/labels.c
--- grass/branches/develbranch_6/vector/v.label.sa/labels.c	2009-09-06 17:31:58 UTC (rev 39049)
+++ grass/branches/develbranch_6/vector/v.label.sa/labels.c	2009-09-06 19:42:46 UTC (rev 39050)
@@ -5,8 +5,6 @@
 #include "labels.h"
 static int label_skyline(FT_Face face, const char *charset, label_t * label);
-static struct line_pnts *box_trans_rot(BOUND_BOX * bb, label_point_t * p,
-				       double angle);
 static void label_point_candidates(label_t * label);
 static void label_line_candidates(label_t * label);
 static int candidate_compare(const void *a, const void *b);
@@ -64,13 +62,13 @@
     label_sz = Vect_get_num_primitives(&Map, legal_types);
-    G_debug(1, "Need to allocate %d bytes of memory",
+    G_debug(1, "Need to allocate %ld bytes of memory",
 	    sizeof(label_t) * label_sz);
     labels = (label_t *) G_malloc(sizeof(label_t) * label_sz);
     G_debug(1, "labels=%p", labels);
     if (labels == NULL)
-	G_fatal_error(_("Cannot allocate %d bytes of memory"),
+	G_fatal_error(_("Cannot allocate %ld bytes of memory"),
     /* open database */
@@ -126,7 +124,7 @@
 	if (i == label_sz) {	/* we need more memory */
 	    label_sz += 100;
-	    G_debug(1, "Need to resize %p to %d bytes of memory",
+	    G_debug(1, "Need to resize %p to %ld bytes of memory",
 		    (void *)labels, sizeof(label_t) * label_sz);
 	    labels = G_realloc(labels, sizeof(label_t) * label_sz);
 	    if (labels == NULL) {
@@ -185,13 +183,18 @@
 	table = db_get_cursor_table(&cursor);
 	column = db_get_table_column(table, 0);	/* first column */
 	db_init_string(&value);
 	db_convert_column_value_to_string(column, &value);
 	G_debug(3, "Label: %s", db_get_string(&value));
 	/* ignore empty strings */
-	if (strlen(db_get_string(&value)) == 0)
+	if (strlen(db_get_string(&value)) == 0) {
+	    Vect_destroy_cats_struct(Cats);
+	    Vect_destroy_line_struct(Points);
 	    continue;
 	labels[i].text = G_strdup(db_get_string(&value));
 	labels[i].cat = cat;
@@ -372,6 +375,7 @@
     /* generate candidate location for each label based on feture type
      * see chapter 5 of MERL-TR-96-04 */
+	G_debug(3, "n_lables=%d", n_labels);
     fprintf(stderr, "Generating label candidates: ...");
     for (i = 0; i < n_labels; i++) {
 	G_percent(i, n_labels - 1, 1);
@@ -836,17 +840,8 @@
     return Points;
- * This function rotates and translates the label bounding box to the
- * given point, and returns it as a polygon.
- * @param bb The bounding box to translate and rotate.
- * @param p The point to translate the bounding box to
- * @param angle The angle (in radians) to rotate the label counter-clockwise
- * @return A lint_pnts structure containing the rotated and translated
- * bounding box as a polygon.
-				       double angle)
+struct line_pnts *box_trans_rot(BOUND_BOX * bb, label_point_t * p,
+				double angle)
     struct line_pnts *Points;
     double x0, y0, x1, y1, x2, y2;
@@ -1040,7 +1035,7 @@
     trbb = box_trans_rot(&label->bb, &candidate->point, candidate->rotation);
     n = Vect_select_lines_by_polygon(&Map, trbb, 0, NULL, GV_POINT, il);
+    Vect_destroy_line_struct(trbb);
     pointover = (double)il->n_values;
     Vect_destroy_list(il);
@@ -1074,13 +1069,15 @@
     n = Vect_select_lines_by_polygon(&Map, trbb, 0, NULL, linetype, il);
     if (n == 0) {
+	Vect_destroy_list(il);
 	return 0.0;
     for (i = 0; i < il->n_values; i++) {
 	int j, found = 0;
 	struct line_pnts *line;
-	label_point_t v, v1, v2;
+	label_point_t v = {0, 0}, v1 = {0, 0} , v2 = {0 ,0};
 	line = Vect_new_line_struct();
 	Vect_read_line(&Map, line, NULL, il->value[i]);
@@ -1131,6 +1128,7 @@
 	Vect_destroy_line_struct(line);
     return lineover;
@@ -1262,6 +1260,7 @@
+	G_debug(3, "i=%d n_lables=%d", i, n_labels);
 	G_percent(i, n_labels, 1);
     G_percent(n_labels, n_labels, 1);
Modified: grass/branches/develbranch_6/vector/v.label.sa/labels.h
--- grass/branches/develbranch_6/vector/v.label.sa/labels.h	2009-09-06 17:31:58 UTC (rev 39049)
+++ grass/branches/develbranch_6/vector/v.label.sa/labels.h	2009-09-06 19:42:46 UTC (rev 39050)
@@ -184,6 +184,18 @@
 struct line_pnts *skyline_trans_rot(struct line_pnts *skyline,
 				    label_point_t * p, double angle);
+ * This function rotates and translates the label bounding box to the
+ * given point, and returns it as a polygon.
+ * @param bb The bounding box to translate and rotate.
+ * @param p The point to translate the bounding box to
+ * @param angle The angle (in radians) to rotate the label counter-clockwise
+ * @return A lint_pnts structure containing the rotated and translated
+ * bounding box as a polygon.
+				double angle);
 void free_freetypecap(struct GFONT_CAP *ftcap);
 struct GFONT_CAP *find_font_from_freetypecap(const char *font);
