[GRASS-SVN] r39051 - in grass/branches/develbranch_6: . display/d.what.vect gui/wxpython/nviz gui/wxpython/vdigit include/Make lib/form vector/v.digit vector/v.what visualization/nviz/src
Sun Sep 6 17:09:44 EDT 2009
Author: kyngchaos
Date: 2009-09-06 17:09:43 -0400 (Sun, 06 Sep 2009)
New Revision: 39051
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
   grass/branches/develbranch_6/display/d.what.vect/Makefile
   grass/branches/develbranch_6/gui/wxpython/nviz/Makefile
   grass/branches/develbranch_6/gui/wxpython/vdigit/Makefile
   grass/branches/develbranch_6/include/Make/Platform.make.in
   grass/branches/develbranch_6/lib/form/Makefile
   grass/branches/develbranch_6/vector/v.digit/Makefile
   grass/branches/develbranch_6/vector/v.what/Makefile
   grass/branches/develbranch_6/visualization/nviz/src/Makefile
Configure option for OSX architectures and SDK;
strip arch flags that may be in some builds of Python and wxPython
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/configure	2009-09-06 21:09:43 UTC (rev 39051)
@@ -25,6 +25,14 @@
 ac_help="$ac_help
   --with-cxx              support C++ functionality (default: no)"
 ac_help="$ac_help
+  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])"
+ac_help="$ac_help
+  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)"
+ac_help="$ac_help
   --with-jpeg             support JPEG functionality (default: yes)"
 ac_help="$ac_help
   --with-tiff             support TIFF functionality (default: yes)"
@@ -69,18 +77,25 @@
 ac_help="$ac_help
   --with-regex            support regex functionality (default: yes)"
 ac_help="$ac_help
-  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')"
+  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
-  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)"
+  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)"
 ac_help="$ac_help
-  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
+  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)"
 ac_help="$ac_help
-  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config', default: no)"
+  --with-geos[=path/geos-config]
+                          enable GEOS support (geos-config with path,
+                          e.g. '--with-geos=/usr/local/bin/geos-config',
+                          default: no)"
 ac_help="$ac_help
   --with-includes=DIRS    site include files are in DIRS"
 ac_help="$ac_help
@@ -740,7 +755,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:744: checking host system type" >&5
+echo "configure:759: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -763,7 +778,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:767: checking for $ac_word" >&5
+echo "configure:782: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -790,7 +805,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:794: checking for $ac_word" >&5
+echo "configure:809: checking for $ac_word" >&5
@@ -838,7 +853,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:842: checking for $ac_word" >&5
+echo "configure:857: checking for $ac_word" >&5
@@ -867,7 +882,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:871: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:886: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -878,12 +893,12 @@
 cat > conftest.$ac_ext << EOF
-#line 882 "configure"
+#line 897 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -909,19 +924,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:913: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:928: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:918: checking whether we are using GNU C" >&5
+echo "configure:933: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -939,7 +954,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:943: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:958: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -968,10 +983,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:972: checking for Cygwin environment" >&5
+echo "configure:987: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 975 "configure"
+#line 990 "configure"
 int main() {
@@ -982,7 +997,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -998,17 +1013,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1002: checking for mingw32 environment" >&5
+echo "configure:1017: checking for mingw32 environment" >&5
-#line 1005 "configure"
+#line 1020 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1026,7 +1041,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1030: checking for executable suffix" >&5
+echo "configure:1045: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1045,23 +1060,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1049: checking for full floating-point support" >&5
+echo "configure:1064: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1054: checking whether "cc -mieee" works" >&5
+echo "configure:1069: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1058 "configure"
+#line 1073 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1077,7 +1092,7 @@
 else
-#line 1081 "configure"
+#line 1096 "configure"
 #include <float.h>
@@ -1091,7 +1106,7 @@
 EOF
-if { (eval echo configure:1095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1104,14 +1119,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1108: checking for full floating-point support with -mieee" >&5
+echo "configure:1123: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1115 "configure"
+#line 1130 "configure"
 #include <float.h>
@@ -1125,7 +1140,7 @@
 EOF
-if { (eval echo configure:1129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1162,7 +1177,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1166: checking for $ac_word" >&5
+echo "configure:1181: checking for $ac_word" >&5
 case "$pwd" in
@@ -1200,7 +1215,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1204: checking for source directory" >&5
+echo "configure:1219: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1211,7 +1226,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1215: checking for build directory" >&5
+echo "configure:1230: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1296,7 +1311,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1300: checking for MacOSX App" >&5
+echo "configure:1315: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1305,6 +1320,78 @@
 echo "$ac_t"""$enable_macosx_app"" 1>&6
+# Check for MacOSX archs
+echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
+echo "configure:1327: checking for MacOSX architectures" >&5
+MACOSX_ARCHS=
+if test "$with_macosx_archs" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  echo "$ac_t""$MACOSX_ARCHS" 1>&6
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
+echo "configure:1356: checking for MacOSX SDK" >&5
+MACOSX_SDK=
+if test "$with_macosx_sdk" = "no" ; then
+else
+ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
+echo "configure:1366: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+if test "$cross_compiling" = yes; then
+    { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
+else
+  if test -r $with_macosx_sdk/SDKSettings.plist; then
+    eval "ac_cv_file_$ac_safe=yes"
+  else
+    eval "ac_cv_file_$ac_safe=no"
+  fi
+fi
+if eval "test \"`echo '$ac_cv_file_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    MACOSX_SDK="-isysroot $with_macosx_sdk"
+else
+    { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
+fi
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -1319,7 +1406,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1323: checking how to build libraries" >&5
+echo "configure:1410: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1362,7 +1449,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1366: checking for $ac_word" >&5
+echo "configure:1453: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1387,7 +1474,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1391: checking how to run the C preprocessor" >&5
+echo "configure:1478: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1400,13 +1487,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1404 "configure"
+#line 1491 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1417,13 +1504,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1421 "configure"
+#line 1508 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1434,13 +1521,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1438 "configure"
+#line 1525 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1468,7 +1555,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1472: checking if 64bit support is requested" >&5
+echo "configure:1559: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1488,7 +1575,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1492: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1579: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1512,7 +1599,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1516: checking system version (for dynamic loading)" >&5
+echo "configure:1603: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1538,13 +1625,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1542: checking for dlopen in -ldl" >&5
+echo "configure:1629: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1548 "configure"
+#line 1635 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1555,7 +1642,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1602,7 +1689,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1606: checking for $ac_word" >&5
+echo "configure:1693: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1731,13 +1818,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1735: checking for gettimeofday in -lbsd" >&5
+echo "configure:1822: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1741 "configure"
+#line 1828 "configure"
@@ -1748,7 +1835,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1789,13 +1876,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1793: checking for inet_ntoa in -lbind" >&5
+echo "configure:1880: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1799 "configure"
+#line 1886 "configure"
@@ -1806,7 +1893,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1867,13 +1954,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1871: checking for shl_load in -ldld" >&5
+echo "configure:1958: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1877 "configure"
+#line 1964 "configure"
@@ -1884,7 +1971,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1949,13 +2036,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1953: checking for shl_load in -ldld" >&5
+echo "configure:2040: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1959 "configure"
+#line 2046 "configure"
@@ -1966,7 +2053,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2088,15 +2175,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2092: checking for dld.h" >&5
+echo "configure:2179: checking for dld.h" >&5
-#line 2095 "configure"
+#line 2182 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2156,15 +2243,15 @@
 	    else
-echo "configure:2160: checking for dld.h" >&5
+echo "configure:2247: checking for dld.h" >&5
-#line 2163 "configure"
+#line 2250 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2261,9 +2348,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2265: checking for ELF" >&5
+echo "configure:2352: checking for ELF" >&5
-#line 2267 "configure"
+#line 2354 "configure"
 #ifdef __ELF__
@@ -2293,15 +2380,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2297: checking for dlfcn.h" >&5
+echo "configure:2384: checking for dlfcn.h" >&5
-#line 2300 "configure"
+#line 2387 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2325,9 +2412,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2329: checking for ELF" >&5
+echo "configure:2416: checking for ELF" >&5
-#line 2331 "configure"
+#line 2418 "configure"
 #ifdef __ELF__
@@ -2651,17 +2738,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2655: checking for ld accepts -Bexport flag" >&5
+echo "configure:2742: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2658 "configure"
+#line 2745 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2800,6 +2887,23 @@
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+# Check whether --with-macosx-archs or --without-macosx-archs was given.
+if test "${with_macosx_archs+set}" = set; then
+  withval="$with_macosx_archs"
+else
+  with_macosx_archs="no"
+fi
+# Check whether --with-macosx-sdk or --without-macosx-sdk was given.
+if test "${with_macosx_sdk+set}" = set; then
+  withval="$with_macosx_sdk"
+else
+  with_macosx_sdk="no"
+fi
 # Check whether --with-jpeg or --without-jpeg was given.
 if test "${with_jpeg+set}" = set; then
   withval="$with_jpeg"
@@ -3469,7 +3573,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3473: checking for additional include dirs" >&5
+echo "configure:3577: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3492,7 +3596,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3496: checking for additional library dirs" >&5
+echo "configure:3600: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3526,7 +3630,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3530: checking for a BSD compatible install" >&5
+echo "configure:3634: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3579,7 +3683,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3583: checking for $ac_word" >&5
+echo "configure:3687: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3610,13 +3714,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3614: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3718: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3620 "configure"
+#line 3724 "configure"
@@ -3627,7 +3731,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3652,7 +3756,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3656: checking for $ac_word" >&5
+echo "configure:3760: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3692,7 +3796,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3696: checking for $ac_word" >&5
+echo "configure:3800: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3723,7 +3827,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3727: checking for $ac_word" >&5
+echo "configure:3831: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3761,7 +3865,7 @@
-echo "configure:3765: checking for $ac_word" >&5
+echo "configure:3869: checking for $ac_word" >&5
@@ -3790,7 +3894,7 @@
-echo "configure:3794: checking for $ac_word" >&5
+echo "configure:3898: checking for $ac_word" >&5
@@ -3821,7 +3925,7 @@
-echo "configure:3825: checking for $ac_word" >&5
+echo "configure:3929: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3850,7 +3954,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3854: checking for $ac_word" >&5
+echo "configure:3958: checking for $ac_word" >&5
 case "$PERL" in
@@ -3881,10 +3985,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3885: checking for ANSI C header files" >&5
+echo "configure:3989: checking for ANSI C header files" >&5
-#line 3888 "configure"
+#line 3992 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3892,7 +3996,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4000: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3909,7 +4013,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3913 "configure"
+#line 4017 "configure"
 #include <string.h>
 EOF
@@ -3927,7 +4031,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3931 "configure"
+#line 4035 "configure"
 #include <stdlib.h>
 EOF
@@ -3948,7 +4052,7 @@
 else
-#line 3952 "configure"
+#line 4056 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3959,7 +4063,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3986,15 +4090,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3990: checking for $ac_hdr" >&5
+echo "configure:4094: checking for $ac_hdr" >&5
-#line 3993 "configure"
+#line 4097 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4102: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4023,15 +4127,15 @@
 do
-echo "configure:4027: checking for $ac_hdr" >&5
+echo "configure:4131: checking for $ac_hdr" >&5
-#line 4030 "configure"
+#line 4134 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4035: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4060,15 +4164,15 @@
 do
-echo "configure:4064: checking for $ac_hdr" >&5
+echo "configure:4168: checking for $ac_hdr" >&5
-#line 4067 "configure"
+#line 4171 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4176: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4097,15 +4201,15 @@
 do
-echo "configure:4101: checking for $ac_hdr" >&5
+echo "configure:4205: checking for $ac_hdr" >&5
-#line 4104 "configure"
+#line 4208 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4134,15 +4238,15 @@
 do
-echo "configure:4138: checking for $ac_hdr" >&5
+echo "configure:4242: checking for $ac_hdr" >&5
-#line 4141 "configure"
+#line 4245 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4146: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4168,10 +4272,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4172: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4276: checking whether time.h and sys/time.h may both be included" >&5
-#line 4175 "configure"
+#line 4279 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4180,7 +4284,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4184: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4288: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4200,10 +4304,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4204: checking for off_t" >&5
+echo "configure:4308: checking for off_t" >&5
-#line 4207 "configure"
+#line 4311 "configure"
 #if STDC_HEADERS
@@ -4230,10 +4334,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4234: checking for uid_t in sys/types.h" >&5
+echo "configure:4338: checking for uid_t in sys/types.h" >&5
-#line 4237 "configure"
+#line 4341 "configure"
 EOF
@@ -4261,10 +4365,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4265: checking return type of signal handlers" >&5
+echo "configure:4369: checking return type of signal handlers" >&5
-#line 4268 "configure"
+#line 4372 "configure"
 #include <signal.h>
@@ -4281,7 +4385,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4285: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4389: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4299,10 +4403,10 @@
-echo "configure:4303: checking for Cygwin environment" >&5
+echo "configure:4407: checking for Cygwin environment" >&5
-#line 4306 "configure"
+#line 4410 "configure"
 int main() {
@@ -4313,7 +4417,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4317: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4331,10 +4435,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4335: checking for $ac_func" >&5
+echo "configure:4439: checking for $ac_func" >&5
-#line 4338 "configure"
+#line 4442 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4357,7 +4461,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4383,10 +4487,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4387: checking for $ac_func" >&5
+echo "configure:4491: checking for $ac_func" >&5
-#line 4390 "configure"
+#line 4494 "configure"
@@ -4409,7 +4513,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4435,10 +4539,10 @@
 for ac_func in drand48
 do
-echo "configure:4439: checking for $ac_func" >&5
+echo "configure:4543: checking for $ac_func" >&5
-#line 4442 "configure"
+#line 4546 "configure"
@@ -4461,7 +4565,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4487,10 +4591,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4491: checking for $ac_func" >&5
+echo "configure:4595: checking for $ac_func" >&5
-#line 4494 "configure"
+#line 4598 "configure"
@@ -4513,7 +4617,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4539,10 +4643,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4543: checking for $ac_func" >&5
+echo "configure:4647: checking for $ac_func" >&5
-#line 4546 "configure"
+#line 4650 "configure"
@@ -4565,7 +4669,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4590,13 +4694,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4594: checking whether setpgrp takes no argument" >&5
+echo "configure:4698: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4600 "configure"
+#line 4704 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4616,7 +4720,7 @@
 EOF
-if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4644,16 +4748,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4648: checking for long long int" >&5
+echo "configure:4752: checking for long long int" >&5
-#line 4650 "configure"
+#line 4754 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4657: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4673,7 +4777,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4677: checking for W11" >&5
+echo "configure:4781: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4701,7 +4805,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4705: checking for X" >&5
+echo "configure:4809: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4761,12 +4865,12 @@
   # First, try using that file with no special directory specified.
-#line 4765 "configure"
+#line 4869 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4835,14 +4939,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4839 "configure"
+#line 4943 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4947,17 +5051,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4951: checking whether -R must be followed by a space" >&5
+echo "configure:5055: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4954 "configure"
+#line 5058 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4973,14 +5077,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4977 "configure"
+#line 5081 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5012,13 +5116,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5016: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5120: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5022 "configure"
+#line 5126 "configure"
@@ -5029,7 +5133,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5050,13 +5154,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5054: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5158: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5060 "configure"
+#line 5164 "configure"
@@ -5067,7 +5171,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5095,10 +5199,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5099: checking for gethostbyname" >&5
+echo "configure:5203: checking for gethostbyname" >&5
-#line 5102 "configure"
+#line 5206 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5121,7 +5225,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5141,13 +5245,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5145: checking for gethostbyname in -lnsl" >&5
+echo "configure:5249: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5151 "configure"
+#line 5255 "configure"
@@ -5158,7 +5262,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5187,10 +5291,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5191: checking for connect" >&5
+echo "configure:5295: checking for connect" >&5
-#line 5194 "configure"
+#line 5298 "configure"
     which can conflict with char connect(); below.  */
@@ -5213,7 +5317,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5233,13 +5337,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5237: checking for connect in -lsocket" >&5
+echo "configure:5341: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5243 "configure"
+#line 5347 "configure"
@@ -5250,7 +5354,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5273,10 +5377,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5277: checking for remove" >&5
+echo "configure:5381: checking for remove" >&5
-#line 5280 "configure"
+#line 5384 "configure"
     which can conflict with char remove(); below.  */
@@ -5299,7 +5403,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5319,13 +5423,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5323: checking for remove in -lposix" >&5
+echo "configure:5427: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5329 "configure"
+#line 5433 "configure"
@@ -5336,7 +5440,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5359,10 +5463,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5363: checking for shmat" >&5
+echo "configure:5467: checking for shmat" >&5
-#line 5366 "configure"
+#line 5470 "configure"
     which can conflict with char shmat(); below.  */
@@ -5385,7 +5489,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5405,13 +5509,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5409: checking for shmat in -lipc" >&5
+echo "configure:5513: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5415 "configure"
+#line 5519 "configure"
@@ -5422,7 +5526,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5454,13 +5558,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5458: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5562: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5464 "configure"
+#line 5568 "configure"
@@ -5471,7 +5575,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5509,7 +5613,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5513: checking whether to use Curses" >&5
+echo "configure:5617: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5528,15 +5632,15 @@
 do
-echo "configure:5532: checking for $ac_hdr" >&5
+echo "configure:5636: checking for $ac_hdr" >&5
-#line 5535 "configure"
+#line 5639 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5540: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5567,10 +5671,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5571: checking curses.h WINDOW structure component" >&5
+echo "configure:5675: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5574 "configure"
+#line 5678 "configure"
 #include <curses.h>
@@ -5579,7 +5683,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5687: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5588,7 +5692,7 @@
 fi
 rm -f conftest*
-#line 5592 "configure"
+#line 5696 "configure"
 #include <curses.h>
@@ -5597,7 +5701,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5601: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5705: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5613,13 +5717,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5617: checking for initscr in -lncurses" >&5
+echo "configure:5721: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5623 "configure"
+#line 5727 "configure"
@@ -5630,7 +5734,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5649,13 +5753,13 @@
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5653: checking for initscr in -lcurses" >&5
+echo "configure:5757: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5659 "configure"
+#line 5763 "configure"
@@ -5666,7 +5770,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5695,13 +5799,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5699: checking for keypad in -lncurses" >&5
+echo "configure:5803: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5705 "configure"
+#line 5809 "configure"
@@ -5712,7 +5816,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5734,13 +5838,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5738: checking for keypad in -lcurses" >&5
+echo "configure:5842: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5744 "configure"
+#line 5848 "configure"
@@ -5751,7 +5855,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5781,13 +5885,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5785: checking for gtty in -lcompat" >&5
+echo "configure:5889: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5791 "configure"
+#line 5895 "configure"
@@ -5798,7 +5902,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5817,13 +5921,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5821: checking for gtty in -lbsd-compat" >&5
+echo "configure:5925: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5827 "configure"
+#line 5931 "configure"
@@ -5834,7 +5938,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5853,13 +5957,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5857: checking for gtty in -lbsd" >&5
+echo "configure:5961: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5863 "configure"
+#line 5967 "configure"
@@ -5870,7 +5974,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5904,12 +6008,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5908: checking for library containing cuserid" >&5
+echo "configure:6012: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5913 "configure"
+#line 6017 "configure"
@@ -5920,7 +6024,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5931,7 +6035,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5935 "configure"
+#line 6039 "configure"
@@ -5942,7 +6046,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5968,10 +6072,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5972: checking for xdrmem_create" >&5
+echo "configure:6076: checking for xdrmem_create" >&5
-#line 5975 "configure"
+#line 6079 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5994,7 +6098,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6012,13 +6116,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6016: checking for xdrmem_create in -lsun" >&5
+echo "configure:6120: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6022 "configure"
+#line 6126 "configure"
@@ -6029,7 +6133,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6048,13 +6152,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6052: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6156: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6058 "configure"
+#line 6162 "configure"
@@ -6065,7 +6169,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6084,13 +6188,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6088: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6192: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6094 "configure"
+#line 6198 "configure"
@@ -6101,7 +6205,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6120,13 +6224,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6124: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6228: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6130 "configure"
+#line 6234 "configure"
@@ -6137,7 +6241,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6171,10 +6275,10 @@
 for ac_func in asprintf
 do
-echo "configure:6175: checking for $ac_func" >&5
+echo "configure:6279: checking for $ac_func" >&5
-#line 6178 "configure"
+#line 6282 "configure"
@@ -6197,7 +6301,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6224,10 +6328,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6228: checking for atan" >&5
+echo "configure:6332: checking for atan" >&5
-#line 6231 "configure"
+#line 6335 "configure"
     which can conflict with char atan(); below.  */
@@ -6250,7 +6354,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6268,13 +6372,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6272: checking for atan in -lm" >&5
+echo "configure:6376: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6278 "configure"
+#line 6382 "configure"
@@ -6285,7 +6389,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6312,10 +6416,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6316: checking for dlsym" >&5
+echo "configure:6420: checking for dlsym" >&5
-#line 6319 "configure"
+#line 6423 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6338,7 +6442,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6356,13 +6460,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6360: checking for dlsym in -ldl" >&5
+echo "configure:6464: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6366 "configure"
+#line 6470 "configure"
@@ -6373,7 +6477,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6400,10 +6504,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6404: checking for iconv" >&5
+echo "configure:6508: checking for iconv" >&5
-#line 6407 "configure"
+#line 6511 "configure"
     which can conflict with char iconv(); below.  */
@@ -6426,7 +6530,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6444,13 +6548,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6448: checking for iconv in -liconv" >&5
+echo "configure:6552: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6454 "configure"
+#line 6558 "configure"
@@ -6461,7 +6565,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6480,13 +6584,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6484: checking for iconv in -lgiconv" >&5
+echo "configure:6588: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6490 "configure"
+#line 6594 "configure"
@@ -6497,7 +6601,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6516,10 +6620,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6520: checking for libiconv" >&5
+echo "configure:6624: checking for libiconv" >&5
-#line 6523 "configure"
+#line 6627 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6542,7 +6646,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6560,13 +6664,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6564: checking for libiconv in -liconv" >&5
+echo "configure:6668: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6570 "configure"
+#line 6674 "configure"
@@ -6577,7 +6681,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6596,13 +6700,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6600: checking for libiconv in -lgiconv" >&5
+echo "configure:6704: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6606 "configure"
+#line 6710 "configure"
@@ -6613,7 +6717,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6650,10 +6754,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6654: checking for socket" >&5
+echo "configure:6758: checking for socket" >&5
-#line 6657 "configure"
+#line 6761 "configure"
     which can conflict with char socket(); below.  */
@@ -6676,7 +6780,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6694,13 +6798,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6698: checking for socket in -lsocket" >&5
+echo "configure:6802: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6704 "configure"
+#line 6808 "configure"
@@ -6711,7 +6815,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6759,7 +6863,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6763: checking for location of zlib includes" >&5
+echo "configure:6867: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6785,15 +6889,15 @@
 do
-echo "configure:6789: checking for $ac_hdr" >&5
+echo "configure:6893: checking for $ac_hdr" >&5
-#line 6792 "configure"
+#line 6896 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6827,7 +6931,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6831: checking for location of zlib library" >&5
+echo "configure:6935: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6852,13 +6956,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6856: checking for deflate in -lz" >&5
+echo "configure:6960: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6862 "configure"
+#line 6966 "configure"
@@ -6869,7 +6973,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6917,7 +7021,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6921: checking for location of External PROJ.4 includes" >&5
+echo "configure:7025: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6943,15 +7047,15 @@
 do
-echo "configure:6947: checking for $ac_hdr" >&5
+echo "configure:7051: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 6950 "configure"
+#line 7054 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6955: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6988,7 +7092,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6992: checking External PROJ.4 version" >&5
+echo "configure:7096: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6996,7 +7100,7 @@
 else
-#line 7000 "configure"
+#line 7104 "configure"
 #include <stdio.h>
@@ -7008,7 +7112,7 @@
 EOF
-if { (eval echo configure:7012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7033,7 +7137,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7037: checking for location of External PROJ.4 library" >&5
+echo "configure:7141: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7058,13 +7162,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7062: checking for pj_get_def in -lproj" >&5
+echo "configure:7166: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7068 "configure"
+#line 7172 "configure"
@@ -7075,7 +7179,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7109,7 +7213,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7113: checking for location of External PROJ.4 data files" >&5
+echo "configure:7217: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7133,14 +7237,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7137: checking for epsg" >&5
+echo "configure:7241: checking for epsg" >&5
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7144: checking for $PROJSHARE/epsg" >&5
+echo "configure:7248: checking for $PROJSHARE/epsg" >&5
@@ -7172,7 +7276,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7176: checking for $ac_word" >&5
+echo "configure:7280: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7212,7 +7316,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7216: checking whether to use regex" >&5
+echo "configure:7320: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7232,7 +7336,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7236: checking for location of regex includes" >&5
+echo "configure:7340: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7258,15 +7362,15 @@
 do
-echo "configure:7262: checking for $ac_hdr" >&5
+echo "configure:7366: checking for $ac_hdr" >&5
-#line 7265 "configure"
+#line 7369 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7300,7 +7404,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7304: checking for location of regex library" >&5
+echo "configure:7408: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7325,10 +7429,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7329: checking for regcomp" >&5
+echo "configure:7433: checking for regcomp" >&5
-#line 7332 "configure"
+#line 7436 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7351,7 +7455,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7378,13 +7482,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7382: checking for regcomp in -lregex" >&5
+echo "configure:7486: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7388 "configure"
+#line 7492 "configure"
@@ -7395,7 +7499,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7445,7 +7549,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7449: checking whether to use Readline" >&5
+echo "configure:7553: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7466,7 +7570,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7470: checking for location of Readline includes" >&5
+echo "configure:7574: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7492,15 +7596,15 @@
 do
-echo "configure:7496: checking for $ac_hdr" >&5
+echo "configure:7600: checking for $ac_hdr" >&5
-#line 7499 "configure"
+#line 7603 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7536,15 +7640,15 @@
 do
-echo "configure:7540: checking for $ac_hdr" >&5
+echo "configure:7644: checking for $ac_hdr" >&5
-#line 7543 "configure"
+#line 7647 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7578,7 +7682,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7582: checking for location of Readline library" >&5
+echo "configure:7686: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7603,13 +7707,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7607: checking for readline in -lreadline" >&5
+echo "configure:7711: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7613 "configure"
+#line 7717 "configure"
@@ -7620,7 +7724,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7655,13 +7759,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7659: checking for add_history in -lhistory" >&5
+echo "configure:7763: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7665 "configure"
+#line 7769 "configure"
@@ -7672,7 +7776,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7715,7 +7819,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7719: checking whether to use JPEG" >&5
+echo "configure:7823: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7735,7 +7839,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7739: checking for location of JPEG includes" >&5
+echo "configure:7843: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7761,15 +7865,15 @@
 do
-echo "configure:7765: checking for $ac_hdr" >&5
+echo "configure:7869: checking for $ac_hdr" >&5
-#line 7768 "configure"
+#line 7872 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7803,7 +7907,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7807: checking for location of JPEG library" >&5
+echo "configure:7911: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7830,13 +7934,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7834: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7938: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ljpeg  $LIBS"
-#line 7840 "configure"
+#line 7944 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7847,7 +7951,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7866,13 +7970,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7870: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7974: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7876 "configure"
+#line 7980 "configure"
@@ -7883,7 +7987,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7932,7 +8036,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7936: checking whether to use GDAL" >&5
+echo "configure:8040: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7950,7 +8054,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7954: checking for $ac_word" >&5
+echo "configure:8058: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -8005,14 +8109,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8009 "configure"
+#line 8113 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:8016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -8021,14 +8125,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8025 "configure"
+#line 8129 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:8032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8060,7 +8164,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8064: checking whether to use GEOS" >&5
+echo "configure:8168: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -8077,7 +8181,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:8081: checking for $ac_word" >&5
+echo "configure:8185: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8125,15 +8229,15 @@
 do
-echo "configure:8129: checking for $ac_hdr" >&5
+echo "configure:8233: checking for $ac_hdr" >&5
-#line 8132 "configure"
+#line 8236 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8168,13 +8272,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8172: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8276: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 8178 "configure"
+#line 8282 "configure"
@@ -8185,7 +8289,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8228,7 +8332,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8232: checking whether to use TIFF" >&5
+echo "configure:8336: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8248,7 +8352,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8252: checking for location of TIFF includes" >&5
+echo "configure:8356: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8274,15 +8378,15 @@
 do
-echo "configure:8278: checking for $ac_hdr" >&5
+echo "configure:8382: checking for $ac_hdr" >&5
-#line 8281 "configure"
+#line 8385 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8316,7 +8420,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8320: checking for location of TIFF library" >&5
+echo "configure:8424: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8347,13 +8451,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8351: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8455: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8357 "configure"
+#line 8461 "configure"
@@ -8364,7 +8468,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8383,13 +8487,13 @@
-echo "configure:8387: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8491: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8393 "configure"
+#line 8497 "configure"
@@ -8400,7 +8504,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8419,13 +8523,13 @@
-echo "configure:8423: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8527: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8429 "configure"
+#line 8533 "configure"
@@ -8436,7 +8540,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8455,13 +8559,13 @@
-echo "configure:8459: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8563: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8465 "configure"
+#line 8569 "configure"
@@ -8472,7 +8576,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8491,13 +8595,13 @@
-echo "configure:8495: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8599: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8501 "configure"
+#line 8605 "configure"
@@ -8508,7 +8612,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8527,13 +8631,13 @@
-echo "configure:8531: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8635: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8537 "configure"
+#line 8641 "configure"
@@ -8544,7 +8648,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8563,13 +8667,13 @@
-echo "configure:8567: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8671: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8573 "configure"
+#line 8677 "configure"
@@ -8580,7 +8684,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8599,13 +8703,13 @@
-echo "configure:8603: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8707: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8609 "configure"
+#line 8713 "configure"
@@ -8616,7 +8720,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8714,7 +8818,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8718: checking whether to use PNG" >&5
+echo "configure:8822: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8733,7 +8837,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8737: checking for location of PNG includes" >&5
+echo "configure:8841: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8759,15 +8863,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8763: checking for $ac_hdr" >&5
+echo "configure:8867: checking for $ac_hdr" >&5
-#line 8766 "configure"
+#line 8870 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8771: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8875: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8801,7 +8905,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8805: checking for location of PNG library" >&5
+echo "configure:8909: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8826,13 +8930,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8830: checking for png_read_image in -lpng" >&5
+echo "configure:8934: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8836 "configure"
+#line 8940 "configure"
@@ -8843,7 +8947,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8885,7 +8989,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8889: checking whether to use PostgreSQL" >&5
+echo "configure:8993: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8912,7 +9016,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8916: checking for location of PostgreSQL includes" >&5
+echo "configure:9020: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8938,15 +9042,15 @@
 do
-echo "configure:8942: checking for $ac_hdr" >&5
+echo "configure:9046: checking for $ac_hdr" >&5
-#line 8945 "configure"
+#line 9049 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8984,7 +9088,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8988: checking for location of PostgreSQL library" >&5
+echo "configure:9092: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9013,13 +9117,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9017: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9121: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9023 "configure"
+#line 9127 "configure"
@@ -9030,7 +9134,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9049,13 +9153,13 @@
-echo "configure:9053: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9157: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9059 "configure"
+#line 9163 "configure"
@@ -9066,7 +9170,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9085,13 +9189,13 @@
-echo "configure:9089: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9193: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9095 "configure"
+#line 9199 "configure"
@@ -9102,7 +9206,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9121,13 +9225,13 @@
-echo "configure:9125: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9229: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9131 "configure"
+#line 9235 "configure"
@@ -9138,7 +9242,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9195,13 +9299,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9199: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9303: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9205 "configure"
+#line 9309 "configure"
@@ -9212,7 +9316,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9234,13 +9338,13 @@
-echo "configure:9238: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9342: checking for PQcmdTuples in -lpq" >&5
-#line 9244 "configure"
+#line 9348 "configure"
@@ -9251,7 +9355,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9294,7 +9398,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9298: checking whether to use MySQL" >&5
+echo "configure:9402: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9314,7 +9418,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9318: checking for location of MySQL includes" >&5
+echo "configure:9422: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9340,15 +9444,15 @@
 do
-echo "configure:9344: checking for $ac_hdr" >&5
+echo "configure:9448: checking for $ac_hdr" >&5
-#line 9347 "configure"
+#line 9451 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9385,7 +9489,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9389: checking for location of MySQL library" >&5
+echo "configure:9493: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9416,13 +9520,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9420: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9524: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9426 "configure"
+#line 9530 "configure"
@@ -9433,7 +9537,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9452,13 +9556,13 @@
-echo "configure:9456: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9560: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9462 "configure"
+#line 9566 "configure"
@@ -9469,7 +9573,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9488,13 +9592,13 @@
-echo "configure:9492: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9596: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9498 "configure"
+#line 9602 "configure"
@@ -9505,7 +9609,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9524,13 +9628,13 @@
-echo "configure:9528: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9632: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9534 "configure"
+#line 9638 "configure"
@@ -9541,7 +9645,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9560,13 +9664,13 @@
-echo "configure:9564: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9668: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9570 "configure"
+#line 9674 "configure"
@@ -9577,7 +9681,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9596,13 +9700,13 @@
-echo "configure:9600: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9704: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9606 "configure"
+#line 9710 "configure"
@@ -9613,7 +9717,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9632,13 +9736,13 @@
-echo "configure:9636: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9740: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9642 "configure"
+#line 9746 "configure"
@@ -9649,7 +9753,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9668,13 +9772,13 @@
-echo "configure:9672: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9776: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9678 "configure"
+#line 9782 "configure"
@@ -9685,7 +9789,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9775,7 +9879,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9779: checking for $ac_word" >&5
+echo "configure:9883: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9816,10 +9920,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9820: checking for mysql_server_init" >&5
+echo "configure:9924: checking for mysql_server_init" >&5
-#line 9823 "configure"
+#line 9927 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9842,7 +9946,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9880,7 +9984,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9884: checking whether to use SQLite" >&5
+echo "configure:9988: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9900,7 +10004,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9904: checking for location of SQLite includes" >&5
+echo "configure:10008: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9926,15 +10030,15 @@
 do
-echo "configure:9930: checking for $ac_hdr" >&5
+echo "configure:10034: checking for $ac_hdr" >&5
-#line 9933 "configure"
+#line 10037 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9977,7 +10081,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9981: checking for location of SQLite library" >&5
+echo "configure:10085: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10004,13 +10108,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10008: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10112: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10014 "configure"
+#line 10118 "configure"
@@ -10021,7 +10125,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10040,13 +10144,13 @@
-echo "configure:10044: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10148: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10050 "configure"
+#line 10154 "configure"
@@ -10057,7 +10161,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10110,7 +10214,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10114: checking whether to use FFMPEG" >&5
+echo "configure:10218: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10130,7 +10234,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10134: checking for location of FFMPEG includes" >&5
+echo "configure:10238: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10156,15 +10260,15 @@
 do
-echo "configure:10160: checking for $ac_hdr" >&5
+echo "configure:10264: checking for $ac_hdr" >&5
-#line 10163 "configure"
+#line 10267 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10200,15 +10304,15 @@
 do
-echo "configure:10204: checking for $ac_hdr" >&5
+echo "configure:10308: checking for $ac_hdr" >&5
-#line 10207 "configure"
+#line 10311 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10244,15 +10348,15 @@
 do
-echo "configure:10248: checking for $ac_hdr" >&5
+echo "configure:10352: checking for $ac_hdr" >&5
-#line 10251 "configure"
+#line 10355 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10256: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10295,7 +10399,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10299: checking for location of FFMPEG library" >&5
+echo "configure:10403: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10322,13 +10426,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10326: checking for av_free in -lavutil" >&5
+echo "configure:10430: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10332 "configure"
+#line 10436 "configure"
@@ -10339,7 +10443,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10358,13 +10462,13 @@
-echo "configure:10362: checking for av_free in -lavutil" >&5
+echo "configure:10466: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10368 "configure"
+#line 10472 "configure"
@@ -10375,7 +10479,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10420,13 +10524,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10424: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10528: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10430 "configure"
+#line 10534 "configure"
@@ -10437,7 +10541,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10456,13 +10560,13 @@
-echo "configure:10460: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10564: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10466 "configure"
+#line 10570 "configure"
@@ -10473,7 +10577,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10518,13 +10622,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10522: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10626: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10528 "configure"
+#line 10632 "configure"
@@ -10535,7 +10639,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10554,13 +10658,13 @@
-echo "configure:10558: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10662: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10564 "configure"
+#line 10668 "configure"
@@ -10571,7 +10675,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10630,7 +10734,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10634: checking whether to use OpenGL" >&5
+echo "configure:10738: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10664,7 +10768,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10668: checking for location of OpenGL includes" >&5
+echo "configure:10772: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10690,15 +10794,15 @@
 do
-echo "configure:10694: checking for $ac_hdr" >&5
+echo "configure:10798: checking for $ac_hdr" >&5
-#line 10697 "configure"
+#line 10801 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10732,7 +10836,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10736: checking for location of OpenGL library" >&5
+echo "configure:10840: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10761,13 +10865,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10765: checking for glBegin in -lGL" >&5
+echo "configure:10869: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10771 "configure"
+#line 10875 "configure"
@@ -10778,7 +10882,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10797,13 +10901,13 @@
-echo "configure:10801: checking for glBegin in -lGL" >&5
+echo "configure:10905: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10807 "configure"
+#line 10911 "configure"
@@ -10814,7 +10918,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10833,13 +10937,13 @@
-echo "configure:10837: checking for glBegin in -lGL" >&5
+echo "configure:10941: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10843 "configure"
+#line 10947 "configure"
@@ -10850,7 +10954,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10869,13 +10973,13 @@
-echo "configure:10873: checking for glBegin in -lGL" >&5
+echo "configure:10977: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10879 "configure"
+#line 10983 "configure"
@@ -10886,7 +10990,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10948,13 +11052,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10952: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11056: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10958 "configure"
+#line 11062 "configure"
@@ -10965,7 +11069,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10984,13 +11088,13 @@
-echo "configure:10988: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11092: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10994 "configure"
+#line 11098 "configure"
@@ -11001,7 +11105,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11045,10 +11149,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11049: checking for glXCreatePbuffer" >&5
+echo "configure:11153: checking for glXCreatePbuffer" >&5
-#line 11052 "configure"
+#line 11156 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11071,7 +11175,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11093,10 +11197,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11097: checking for glXCreateGLXPixmap" >&5
+echo "configure:11201: checking for glXCreateGLXPixmap" >&5
-#line 11100 "configure"
+#line 11204 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11119,7 +11223,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11158,7 +11262,7 @@
-echo "configure:11162: checking for location of OpenGL includes" >&5
+echo "configure:11266: checking for location of OpenGL includes" >&5
@@ -11184,15 +11288,15 @@
 do
-echo "configure:11188: checking for $ac_hdr" >&5
+echo "configure:11292: checking for $ac_hdr" >&5
-#line 11191 "configure"
+#line 11295 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11227,10 +11331,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11231: checking for glBegin" >&5
+echo "configure:11335: checking for glBegin" >&5
-#line 11234 "configure"
+#line 11338 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11253,7 +11357,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11268,10 +11372,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11272: checking for gluBeginCurve" >&5
+echo "configure:11376: checking for gluBeginCurve" >&5
-#line 11275 "configure"
+#line 11379 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11294,7 +11398,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11338,7 +11442,7 @@
-echo "configure:11342: checking for location of OpenGL includes" >&5
+echo "configure:11446: checking for location of OpenGL includes" >&5
@@ -11364,15 +11468,15 @@
 do
-echo "configure:11368: checking for $ac_hdr" >&5
+echo "configure:11472: checking for $ac_hdr" >&5
-#line 11371 "configure"
+#line 11475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11376: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11406,7 +11510,7 @@
-echo "configure:11410: checking for location of OpenGL library" >&5
+echo "configure:11514: checking for location of OpenGL library" >&5
@@ -11431,18 +11535,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11435: checking for OpenGL library" >&5
+echo "configure:11539: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11439 "configure"
+#line 11543 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11466,18 +11570,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11470: checking for GLU library" >&5
+echo "configure:11574: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11474 "configure"
+#line 11578 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11526,7 +11630,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11530: checking whether to use Tcl/Tk" >&5
+echo "configure:11634: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11546,7 +11650,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11550: checking for location of Tcl/Tk includes" >&5
+echo "configure:11654: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11572,15 +11676,15 @@
 do
-echo "configure:11576: checking for $ac_hdr" >&5
+echo "configure:11680: checking for $ac_hdr" >&5
-#line 11579 "configure"
+#line 11683 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11617,15 +11721,15 @@
 do
-echo "configure:11621: checking for $ac_hdr" >&5
+echo "configure:11725: checking for $ac_hdr" >&5
-#line 11624 "configure"
+#line 11728 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11629: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11658,7 +11762,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11662: checking Tcl version" >&5
+echo "configure:11766: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11666,7 +11770,7 @@
 else
-#line 11670 "configure"
+#line 11774 "configure"
 #include <stdio.h>
@@ -11678,7 +11782,7 @@
 EOF
-if { (eval echo configure:11682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11696,7 +11800,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11700: checking Tk version" >&5
+echo "configure:11804: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11704,7 +11808,7 @@
 else
-#line 11708 "configure"
+#line 11812 "configure"
 #include <stdio.h>
@@ -11716,7 +11820,7 @@
 EOF
-if { (eval echo configure:11720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11747,7 +11851,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11751: checking for location of Tcl/Tk library" >&5
+echo "configure:11855: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11768,22 +11872,14 @@
 TCLLIB=
 TKLIB=
+MACOSX_ARCHS_TCLTK=
 # Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
-# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
-TCLTKAQUA_IS64BIT=
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua
 if test "$OPENGL_AQUA" = 1 ; then
-    temp_CFLAGS="$CFLAGS"
+    save_CFLAGS="$CFLAGS"
     CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-    # can't save LDFLAGS, need to remember arch flags to insert back later
-    temp_ARCHES=
-    for a in x86_64 ppc64
-    do
-        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
-            temp_ARCHES="$temp_ARCHES -arch $a"
-        fi
-    done
+    save_LDFLAGS="$LDFLAGS"
     LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
 fi
@@ -11795,13 +11891,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11799: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11895: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11805 "configure"
+#line 11901 "configure"
@@ -11812,7 +11908,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11831,13 +11927,13 @@
-echo "configure:11835: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11931: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11841 "configure"
+#line 11937 "configure"
@@ -11848,7 +11944,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11875,13 +11971,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11879: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11975: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11885 "configure"
+#line 11981 "configure"
 #include "confdefs.h"
@@ -11892,7 +11988,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11911,13 +12007,13 @@
-echo "configure:11915: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12011: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11921 "configure"
+#line 12017 "configure"
@@ -11928,7 +12024,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11955,13 +12051,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11959: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12055: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11965 "configure"
+#line 12061 "configure"
@@ -11972,7 +12068,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11991,13 +12087,13 @@
-echo "configure:11995: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12091: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12001 "configure"
+#line 12097 "configure"
@@ -12008,7 +12104,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12086,13 +12182,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12090: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12186: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12096 "configure"
+#line 12192 "configure"
@@ -12103,7 +12199,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12122,13 +12218,13 @@
-echo "configure:12126: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12222: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12132 "configure"
+#line 12228 "configure"
@@ -12139,7 +12235,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12166,13 +12262,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12170: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12266: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12176 "configure"
+#line 12272 "configure"
@@ -12183,7 +12279,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12202,13 +12298,13 @@
-echo "configure:12206: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12302: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12212 "configure"
+#line 12308 "configure"
@@ -12219,7 +12315,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12246,13 +12342,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12250: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12346: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12256 "configure"
+#line 12352 "configure"
@@ -12263,7 +12359,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12282,13 +12378,13 @@
-echo "configure:12286: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12382: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12292 "configure"
+#line 12388 "configure"
@@ -12299,7 +12395,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12372,11 +12468,68 @@
 # restore CFLAGS/LDLFAGS from Aqua 64bit strip
 # only Tcl/Tk-based makefiles will strip 64bit out during compile
-   CFLAGS="$temp_CFLAGS"
-   LDFLAGS="$temp_ARCHES $LDFLAGS"
+   CFLAGS="$save_CFLAGS"
+   LDFLAGS="$save_LDFLAGS"
 fi
 TCLTKLIBS="$TKLIB $TCLLIB"
+# check for available OSX archs in TclTk
+if test -n "$MACOSX_ARCHS" ; then
+  LDFLAGS=
+  CFLAGS=
+  tlib=`echo "$TCLLIB" | sed -E -e 's/-l//' -e 's/^ +//' -e 's/ +$//'`
+  for a in i386 ppc x86_64 ppc64
+  do
+    # add only if in MACOSX_ARCHS
+    echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
+echo "configure:12489: checking for Tcl_Init in -l$tlib" >&5
+ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 12495 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:12506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+      if test -n "`echo "$MACOSX_ARCHS" | grep $a`" ; then
+        MACOSX_ARCHS_TCLTK="$MACOSX_ARCHS_TCLTK -arch $a"
+      fi
+else
+  echo "$ac_t""no" 1>&6
+fi
+  done
+fi
 cat >> confdefs.h <<\EOF
 #define HAVE_TCLTK 1
 EOF
@@ -12398,7 +12551,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12402: checking whether to use ODBC" >&5
+echo "configure:12555: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12417,7 +12570,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12421: checking for location of ODBC includes" >&5
+echo "configure:12574: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12443,15 +12596,15 @@
 do
-echo "configure:12447: checking for $ac_hdr" >&5
+echo "configure:12600: checking for $ac_hdr" >&5
-#line 12450 "configure"
+#line 12603 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12485,7 +12638,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12489: checking for location of ODBC library" >&5
+echo "configure:12642: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12510,13 +12663,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12514: checking for SQLConnect in -lodbc" >&5
+echo "configure:12667: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12520 "configure"
+#line 12673 "configure"
@@ -12527,7 +12680,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12552,13 +12705,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12556: checking for SQLConnect in -liodbc" >&5
+echo "configure:12709: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12562 "configure"
+#line 12715 "configure"
@@ -12569,7 +12722,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12594,11 +12747,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12598: checking for ODBC library" >&5
+echo "configure:12751: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12602 "configure"
+#line 12755 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12606,7 +12759,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12655,7 +12808,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12659: checking whether to use FFTW" >&5
+echo "configure:12812: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12674,7 +12827,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12678: checking for location of FFTW includes" >&5
+echo "configure:12831: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12700,15 +12853,15 @@
 do
-echo "configure:12704: checking for $ac_hdr" >&5
+echo "configure:12857: checking for $ac_hdr" >&5
-#line 12707 "configure"
+#line 12860 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12736,15 +12889,15 @@
 do
-echo "configure:12740: checking for $ac_hdr" >&5
+echo "configure:12893: checking for $ac_hdr" >&5
-#line 12743 "configure"
+#line 12896 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12772,15 +12925,15 @@
 do
-echo "configure:12776: checking for $ac_hdr" >&5
+echo "configure:12929: checking for $ac_hdr" >&5
-#line 12779 "configure"
+#line 12932 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12826,7 +12979,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12830: checking for location of FFTW library" >&5
+echo "configure:12983: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12851,13 +13004,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12855: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13008: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12861 "configure"
+#line 13014 "configure"
@@ -12868,7 +13021,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12893,13 +13046,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12897: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13050: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12903 "configure"
+#line 13056 "configure"
@@ -12910,7 +13063,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12935,13 +13088,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12939: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13092: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12945 "configure"
+#line 13098 "configure"
@@ -12952,7 +13105,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13009,7 +13162,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13013: checking whether to use BLAS" >&5
+echo "configure:13166: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13030,7 +13183,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13034: checking for location of BLAS includes" >&5
+echo "configure:13187: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13050,7 +13203,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13054: checking for location of BLAS library" >&5
+echo "configure:13207: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13076,15 +13229,15 @@
 do
-echo "configure:13080: checking for $ac_hdr" >&5
+echo "configure:13233: checking for $ac_hdr" >&5
-#line 13083 "configure"
+#line 13236 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13119,13 +13272,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13123: checking for dnrm2_ in -lblas" >&5
+echo "configure:13276: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13129 "configure"
+#line 13282 "configure"
@@ -13136,7 +13289,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13155,13 +13308,13 @@
-echo "configure:13159: checking for dnrm2_ in -lblas" >&5
+echo "configure:13312: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13165 "configure"
+#line 13318 "configure"
@@ -13172,7 +13325,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13216,13 +13369,13 @@
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13220: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13373: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13226 "configure"
+#line 13379 "configure"
@@ -13233,7 +13386,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13248,13 +13401,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13252: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13405: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13258 "configure"
+#line 13411 "configure"
@@ -13265,7 +13418,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13280,13 +13433,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13284: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13437: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13290 "configure"
+#line 13443 "configure"
@@ -13297,7 +13450,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13336,22 +13489,23 @@
 fi
 # BLAS in Apple vecLib framework? (Mac OS-X)
-if test -n "$MACOSX_APP"; then
+#  not dependent on APP build
+#if test -n "$MACOSX_APP"; then
 if test $blas_ok = no; then
 	vlib_flags="-framework vecLib"
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13346: checking for sgemm in $vlib_flags" >&5
+echo "configure:13500: checking for sgemm in $vlib_flags" >&5
-#line 13348 "configure"
+#line 13502 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13364,18 +13518,18 @@
 	echo "$ac_t""$blas_ok" 1>&6
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13373: checking for sgemm_ in -lblas" >&5
+echo "configure:13527: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13379 "configure"
+#line 13533 "configure"
@@ -13386,7 +13540,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13401,13 +13555,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13405: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13559: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13411 "configure"
+#line 13565 "configure"
@@ -13418,7 +13572,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13433,13 +13587,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13437: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13591: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13443 "configure"
+#line 13597 "configure"
@@ -13450,7 +13604,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13484,13 +13638,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13488: checking for acosp in -lsunmath" >&5
+echo "configure:13642: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13494 "configure"
+#line 13648 "configure"
@@ -13501,7 +13655,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13516,13 +13670,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13520: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13674: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13526 "configure"
+#line 13680 "configure"
@@ -13533,7 +13687,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13563,13 +13717,13 @@
 # Generic BLAS library
-echo "configure:13567: checking for sgemm_ in -lblas" >&5
+echo "configure:13721: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13573 "configure"
+#line 13727 "configure"
@@ -13580,7 +13734,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13619,7 +13773,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13623: checking whether to use LAPACK" >&5
+echo "configure:13777: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13644,7 +13798,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13648: checking for location of LAPACK includes" >&5
+echo "configure:13802: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13664,7 +13818,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13668: checking for location of LAPACK library" >&5
+echo "configure:13822: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13690,15 +13844,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13694: checking for $ac_hdr" >&5
+echo "configure:13848: checking for $ac_hdr" >&5
-#line 13697 "configure"
+#line 13851 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13730,10 +13884,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13734: checking for dsegv_" >&5
+echo "configure:13888: checking for dsegv_" >&5
-#line 13737 "configure"
+#line 13891 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13756,7 +13910,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13783,13 +13937,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13787: checking for desgv_ in -llapack" >&5
+echo "configure:13941: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13793 "configure"
+#line 13947 "configure"
@@ -13800,7 +13954,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13832,13 +13986,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13836: checking for dgesv_ in -llapack" >&5
+echo "configure:13990: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13842 "configure"
+#line 13996 "configure"
@@ -13849,7 +14003,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13868,13 +14022,13 @@
-echo "configure:13872: checking for dgesv_ in -llapack" >&5
+echo "configure:14026: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13878 "configure"
+#line 14032 "configure"
@@ -13885,7 +14039,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13941,7 +14095,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13945: checking whether to use Motif" >&5
+echo "configure:14099: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13960,7 +14114,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13964: checking for location of Motif includes" >&5
+echo "configure:14118: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13986,15 +14140,15 @@
 do
-echo "configure:13990: checking for $ac_hdr" >&5
+echo "configure:14144: checking for $ac_hdr" >&5
-#line 13993 "configure"
+#line 14147 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14028,7 +14182,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14032: checking for location of Motif library" >&5
+echo "configure:14186: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14053,13 +14207,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14057: checking for XmStringCreate in -lXm" >&5
+echo "configure:14211: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14063 "configure"
+#line 14217 "configure"
@@ -14070,7 +14224,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14111,7 +14265,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14115: checking whether to use Cairo" >&5
+echo "configure:14269: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14137,7 +14291,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14141: checking for location of cairo includes" >&5
+echo "configure:14295: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14163,15 +14317,15 @@
 do
-echo "configure:14167: checking for $ac_hdr" >&5
+echo "configure:14321: checking for $ac_hdr" >&5
-#line 14170 "configure"
+#line 14324 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14175: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14207,7 +14361,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14211: checking for location of cairo library" >&5
+echo "configure:14365: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14227,7 +14381,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14231: checking for cairo linking flags" >&5
+echo "configure:14385: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14243,10 +14397,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14247: checking for cairo_create" >&5
+echo "configure:14401: checking for cairo_create" >&5
-#line 14250 "configure"
+#line 14404 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14269,7 +14423,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14303,10 +14457,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14307: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14461: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14310 "configure"
+#line 14464 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14329,7 +14483,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14371,7 +14525,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14375: checking whether to use GLw" >&5
+echo "configure:14529: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14390,7 +14544,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14394: checking for location of GLw includes" >&5
+echo "configure:14548: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14416,15 +14570,15 @@
 do
-echo "configure:14420: checking for $ac_hdr" >&5
+echo "configure:14574: checking for $ac_hdr" >&5
-#line 14423 "configure"
+#line 14577 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14452,15 +14606,15 @@
 do
-echo "configure:14456: checking for $ac_hdr" >&5
+echo "configure:14610: checking for $ac_hdr" >&5
-#line 14459 "configure"
+#line 14613 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14500,7 +14654,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14504: checking for location of GLw library" >&5
+echo "configure:14658: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14525,13 +14679,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14529: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14683: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14535 "configure"
+#line 14689 "configure"
@@ -14542,7 +14696,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14567,13 +14721,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14571: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14725: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14577 "configure"
+#line 14731 "configure"
@@ -14584,7 +14738,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14609,13 +14763,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14613: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14767: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14619 "configure"
+#line 14773 "configure"
@@ -14626,7 +14780,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14651,13 +14805,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14655: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14809: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14661 "configure"
+#line 14815 "configure"
@@ -14668,7 +14822,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14693,13 +14847,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14697: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14851: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14703 "configure"
+#line 14857 "configure"
@@ -14710,7 +14864,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14735,13 +14889,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14739: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14893: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14745 "configure"
+#line 14899 "configure"
@@ -14752,7 +14906,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14779,13 +14933,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14783: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14937: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14789 "configure"
+#line 14943 "configure"
@@ -14796,7 +14950,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14815,13 +14969,13 @@
-echo "configure:14819: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14973: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14825 "configure"
+#line 14979 "configure"
@@ -14832,7 +14986,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14859,13 +15013,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14863: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15017: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14869 "configure"
+#line 15023 "configure"
@@ -14876,7 +15030,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14895,13 +15049,13 @@
-echo "configure:14899: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15053: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14905 "configure"
+#line 15059 "configure"
@@ -14912,7 +15066,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15025,7 +15179,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15029: checking whether to use FreeType" >&5
+echo "configure:15183: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15044,7 +15198,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15048: checking for location of FreeType includes" >&5
+echo "configure:15202: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15070,15 +15224,15 @@
 do
-echo "configure:15074: checking for $ac_hdr" >&5
+echo "configure:15228: checking for $ac_hdr" >&5
-#line 15077 "configure"
+#line 15231 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15082: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15112,7 +15266,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15116: checking for location of FreeType library" >&5
+echo "configure:15270: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15137,13 +15291,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15141: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15295: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15147 "configure"
+#line 15301 "configure"
@@ -15154,7 +15308,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15195,7 +15349,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15199: checking whether to use NLS" >&5
+echo "configure:15353: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15215,10 +15369,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15219: checking for gettext" >&5
+echo "configure:15373: checking for gettext" >&5
-#line 15222 "configure"
+#line 15376 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15241,7 +15395,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15259,13 +15413,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15263: checking for gettext in -lintl" >&5
+echo "configure:15417: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15269 "configure"
+#line 15423 "configure"
@@ -15276,7 +15430,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15311,7 +15465,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15315: checking whether to use C++" >&5
+echo "configure:15469: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15327,7 +15481,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15331: checking for $ac_word" >&5
+echo "configure:15485: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15356,7 +15510,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15360: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15514: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15367,12 +15521,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15371 "configure"
+#line 15525 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15398,19 +15552,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15402: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15556: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15407: checking whether we are using GNU C++" >&5
+echo "configure:15561: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15568: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15428,7 +15582,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15432: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15586: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15469,7 +15623,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15473: checking whether to use openDWG" >&5
+echo "configure:15627: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15489,7 +15643,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15493: checking for location of openDGW includes" >&5
+echo "configure:15647: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15515,15 +15669,15 @@
 do
-echo "configure:15519: checking for $ac_hdr" >&5
+echo "configure:15673: checking for $ac_hdr" >&5
-#line 15522 "configure"
+#line 15676 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15557,7 +15711,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15561: checking for location of openDWG library" >&5
+echo "configure:15715: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15604,7 +15758,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15608: checking for special C compiler options needed for large files" >&5
+echo "configure:15762: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15612,7 +15766,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15616 "configure"
+#line 15770 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15628,7 +15782,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15632: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15786: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15637,7 +15791,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15641 "configure"
+#line 15795 "configure"
@@ -15653,7 +15807,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15657: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15811: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15673,11 +15827,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15677: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15831: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15681 "configure"
+#line 15835 "configure"
@@ -15693,14 +15847,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15851: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15704 "configure"
+#line 15858 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15718,7 +15872,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15722: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15876: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15737,11 +15891,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15741: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15895: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15745 "configure"
+#line 15899 "configure"
@@ -15757,14 +15911,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15915: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15768 "configure"
+#line 15922 "configure"
 #define _LARGE_FILES 1
@@ -15782,7 +15936,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15786: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15801,25 +15955,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15805: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15959: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15809 "configure"
+#line 15963 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15823 "configure"
+#line 15977 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15828,7 +15982,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15832: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15849,10 +16003,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15853: checking if system supports Large Files at all" >&5
+echo "configure:16007: checking if system supports Large Files at all" >&5
-#line 15856 "configure"
+#line 16010 "configure"
 #include <stdio.h>
@@ -15884,7 +16038,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15913,13 +16067,14 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15917: checking whether to use Python" >&5
+echo "configure:16071: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
+MACOSX_ARCHS_PYTHON=
 if test "$with_python" = "no" ; then
@@ -15933,7 +16088,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15937: checking for $ac_word" >&5
+echo "configure:16092: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15975,15 +16130,15 @@
 do
-echo "configure:15979: checking for $ac_hdr" >&5
+echo "configure:16134: checking for $ac_hdr" >&5
-#line 15982 "configure"
+#line 16137 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16018,13 +16173,20 @@
     # With Python library directory
     PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
+    # shouldn't have arch flags in C/LD flags on OSX
+    do
+      PYTHONCFLAGS=`echo "$PYTHONCFLAGS" | sed "s/-arch +$a//g"`
+      PYTHONLDFLAGS=`echo "$PYTHONLDFLAGS" | sed "s/-arch +$a//g"`
+    done
   fi
   # look for the swig program
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:16028: checking for $ac_word" >&5
+echo "configure:16190: checking for $ac_word" >&5
 case "$SWIG" in
@@ -16059,6 +16221,21 @@
     { echo "configure: error: *** couldn't find swig" 1>&2; exit 1; }
   fi
+  # check for available OSX archs in Python, assume framework
+  if test -n "$MACOSX_ARCHS" ; then
+    pylib=`"$PY_CONFIG" --prefix`/Python
+    pylibinfo=`file "$pylib"`
+    do
+      if test -n "`echo \"$pylibinfo\" | grep \"library $a\"`" ; then
+          MACOSX_ARCHS_PYTHON="$MACOSX_ARCHS_PYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # Done checking Python
@@ -16067,16 +16244,18 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16074: checking whether to use wxWidgets" >&5
+echo "configure:16252: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
+MACOSX_ARCHS_WXPYTHON=
 if test "$with_wxwidgets" = "no" ; then
@@ -16090,7 +16269,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16094: checking for $ac_word" >&5
+echo "configure:16273: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16138,7 +16317,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16142: checking wxWidgets version" >&5
+echo "configure:16321: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16161,15 +16340,15 @@
 do
-echo "configure:16165: checking for $ac_hdr" >&5
+echo "configure:16344: checking for $ac_hdr" >&5
-#line 16168 "configure"
+#line 16347 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16202,6 +16381,30 @@
  # With wxWidgets library directory
  WXWIDGETSLIB=`"$WX_CONFIG" --libs`
+ do
+   WXWIDGETSCXXFLAGS=`echo "$WXWIDGETSCXXFLAGS" | sed "s/-arch +$a//g"`
+   WXWIDGETSCPPFLAGS=`echo "$WXWIDGETSCPPFLAGS" | sed "s/-arch +$a//g"`
+   WXWIDGETSLIB=`echo "$WXWIDGETSLIB" | sed "s/-arch +$a//g"`
+ done
+  # check for available OSX archs in wxPython
+    wxver=`"$WX_CONFIG" --version`
+    wxlib=`"$WX_CONFIG" --prefix`/lib/lib`"$WX_CONFIG" --basename`-`echo "$wxver" | cut -d . -f1,2`.dylib
+    wxlibinfo=`file "$wxlib"`
+    do
+      if test -n "`echo \"$wxlibinfo\" | grep \"library $a\"`" ; then
+        if test -n "`echo \"$MACOSX_ARCHS\" | grep $a`" ; then
+          MACOSX_ARCHS_WXPYTHON="$MACOSX_ARCHS_WXPYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
@@ -16210,6 +16413,7 @@
 # Done checking wxWidgets
 USE_TERMIO=
@@ -16332,6 +16536,8 @@
 s%@NAME_VER@%$NAME_VER%g
 s%@LIB_VER@%$LIB_VER%g
 s%@MACOSX_APP@%$MACOSX_APP%g
+s%@MACOSX_ARCHS@%$MACOSX_ARCHS%g
+s%@MACOSX_SDK@%$MACOSX_SDK%g
 s%@INSTDIR@%$INSTDIR%g
 s%@GRASS_LIB_PREFIX@%$GRASS_LIB_PREFIX%g
 s%@GRASS_LIB_SUFFIX@%$GRASS_LIB_SUFFIX%g
@@ -16455,7 +16661,7 @@
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
 s%@TCLTKLIBS@%$TCLTKLIBS%g
 s%@TCL_VERSION@%$TCL_VERSION%g
-s%@TCLTKAQUA_IS64BIT@%$TCLTKAQUA_IS64BIT%g
+s%@MACOSX_ARCHS_TCLTK@%$MACOSX_ARCHS_TCLTK%g
 s%@ODBCINC@%$ODBCINC%g
 s%@ODBCLIB@%$ODBCLIB%g
 s%@FFTWINC@%$FFTWINC%g
@@ -16488,12 +16694,14 @@
 s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
 s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
 s%@USE_PYTHON@%$USE_PYTHON%g
+s%@MACOSX_ARCHS_PYTHON@%$MACOSX_ARCHS_PYTHON%g
 s%@WX_CONFIG@%$WX_CONFIG%g
 s%@WXVERSION@%$WXVERSION%g
 s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
 s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
 s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
 s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
+s%@MACOSX_ARCHS_WXPYTHON@%$MACOSX_ARCHS_WXPYTHON%g
 s%@USE_TERMIO@%$USE_TERMIO%g
 s%@STRIPFLAG@%$STRIPFLAG%g
 s%@GRASS_HOME@%$GRASS_HOME%g
@@ -16772,6 +16980,12 @@
 echo "  MacOSX application:         `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
+echo "  MacOSX architectures:       ${MACOSX_ARCHS}"
+echo "  MacOSX SDK:                 ${MACOSX_SDK}"
 echo ""
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/configure.in	2009-09-06 21:09:43 UTC (rev 39051)
@@ -148,6 +148,55 @@
 AC_MSG_RESULT("$enable_macosx_app")
 AC_SUBST(MACOSX_APP)
+# Check for MacOSX archs
+AC_MSG_CHECKING(for MacOSX architectures)
+MACOSX_ARCHS=
+if test "$with_macosx_archs" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  AC_MSG_RESULT([$MACOSX_ARCHS])
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+AC_SUBST(MACOSX_ARCHS)
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+AC_MSG_CHECKING(for MacOSX SDK)
+MACOSX_SDK=
+if test "$with_macosx_sdk" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
+    MACOSX_SDK="-isysroot $with_macosx_sdk"],[
+    AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+AC_SUBST(MACOSX_SDK)
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -176,6 +225,15 @@
 LOC_ARG_WITH(cxx, C++, no)
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+AC_ARG_WITH(macosx-archs,
+[  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])],, with_macosx_archs="no")
+AC_ARG_WITH(macosx-sdk,
+[  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
 LOC_ARG_WITH(jpeg, JPEG)
 LOC_ARG_WITH(tiff, TIFF)
 LOC_ARG_WITH(png, PNG)
@@ -200,23 +258,30 @@
 LOC_ARG_WITH(regex, regex)
 AC_ARG_WITH(gdal,
-[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')])
+[  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(python,
-[  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)],, with_python="no")
+[  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)],, with_python="no")
 AC_ARG_WITH(wxwidgets,
-[  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
+[  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)],, with_wxwidgets="no")
 # With includes and libs options
 AC_ARG_WITH(geos,
-[  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config', default: no)],, with_geos="no")
+[  --with-geos[=path/geos-config]
+                          enable GEOS support (geos-config with path,
+                          e.g. '--with-geos=/usr/local/bin/geos-config',
+                          default: no)],, with_geos="no")
 AC_ARG_WITH(includes,
 [  --with-includes=DIRS    site include files are in DIRS])
@@ -1230,22 +1295,14 @@
 TCLLIB=
 TKLIB=
+MACOSX_ARCHS_TCLTK=
 # Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
-# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
-TCLTKAQUA_IS64BIT=
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua
 if test "$OPENGL_AQUA" = 1 ; then
-    temp_CFLAGS="$CFLAGS"
+    save_CFLAGS="$CFLAGS"
     CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-    # can't save LDFLAGS, need to remember arch flags to insert back later
-    temp_ARCHES=
-    for a in x86_64 ppc64
-    do
-        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
-            temp_ARCHES="$temp_ARCHES -arch $a"
-        fi
-    done
+    save_LDFLAGS="$LDFLAGS"
     LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
 fi
@@ -1266,11 +1323,32 @@
 fi
+  LDFLAGS=
+  CFLAGS=
+  do
+    AC_CHECK_LIB($tlib, Tcl_Init, [
+      fi
+      ],, -arch $a $MACOSX_SDK $TCLTKLIBPATH)
+  done
+fi
 AC_DEFINE(HAVE_TCLTK)
 fi # $USE_TCLTK
@@ -1282,7 +1360,7 @@
 AC_SUBST(TCLTKLIBPATH)
 AC_SUBST(TCLTKLIBS)
 AC_SUBST(TCL_VERSION)
-AC_SUBST(TCLTKAQUA_IS64BIT)
+AC_SUBST(MACOSX_ARCHS_TCLTK)
 # Done checking Tcl/Tk
 # Enable ODBC option
@@ -1401,7 +1479,8 @@
 fi
 	save_LIBS="$LIBS"
@@ -1411,7 +1490,7 @@
 	AC_MSG_RESULT($blas_ok)
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
@@ -1757,6 +1836,7 @@
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
   AC_MSG_RESULT(no)
@@ -1780,6 +1860,13 @@
+    do
+    done
   fi
@@ -1789,6 +1876,21 @@
     AC_MSG_ERROR([*** couldn't find swig])
   fi
+    do
+        fi
+      fi
+    done
+  fi
 AC_SUBST(PYTHONINC)
@@ -1796,6 +1898,7 @@
 AC_SUBST(PYTHONLDFLAGS)
 AC_SUBST(SWIG)
 AC_SUBST(USE_PYTHON)
+AC_SUBST(MACOSX_ARCHS_PYTHON)
@@ -1806,6 +1909,7 @@
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
   AC_MSG_RESULT(no)
@@ -1855,6 +1959,30 @@
+ do
+ done
+    do
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
 AC_SUBST(WXVERSION)
@@ -1862,6 +1990,7 @@
 AC_SUBST(WXWIDGETSCPPFLAGS)
 AC_SUBST(WXWIDGETSLIB)
 AC_SUBST(USE_WXWIDGETS)
+AC_SUBST(MACOSX_ARCHS_WXPYTHON)
@@ -1901,6 +2030,8 @@
 LOC_MSG([  OpenGL platform:             ${OPENGL_TYPE}])
 LOC_MSG()
 LOC_MSG_USE(MacOSX application,MACOSX_APP)
+LOC_MSG([  MacOSX architectures:       ${MACOSX_ARCHS}])
+LOC_MSG([  MacOSX SDK:                 ${MACOSX_SDK}])
 LOC_MSG()
 LOC_MSG_USE(NVIZ,USE_TOGL)
 LOC_MSG()
Modified: grass/branches/develbranch_6/display/d.what.vect/Makefile
--- grass/branches/develbranch_6/display/d.what.vect/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/display/d.what.vect/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -12,12 +12,11 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
-ifeq ($(OPENGL_AQUA),1)
-ifneq ($(TCLTKAQUA_IS64BIT),1)
-CFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(CFLAGS)))
-LDFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(LDFLAGS)))
+# substitute OSX arch flags for tcltk
+ifneq ($(MACOSX_ARCHS),)
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_TCLTK)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_TCLTK)
 endif
-endif
 default: cmd
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/Makefile
--- grass/branches/develbranch_6/gui/wxpython/nviz/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -2,12 +2,12 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
-ifeq ($(findstring darwin,$(ARCH)),darwin)
-ifneq ($(WX_ISOSX64BIT),1)
+# substitute OSX arch flags for wxpython
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+CXXFLAGS := $(subst $(MACOSX_ARCHS),,$(CXXFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
 endif
-endif
 LIB_NAME = grass6_wxnviz
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/Makefile
--- grass/branches/develbranch_6/gui/wxpython/vdigit/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -2,12 +2,12 @@
 endif
-endif
 LIB_NAME = grass6_wxvdigit
Modified: grass/branches/develbranch_6/include/Make/Platform.make.in
--- grass/branches/develbranch_6/include/Make/Platform.make.in	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/include/Make/Platform.make.in	2009-09-06 21:09:43 UTC (rev 39051)
@@ -171,8 +171,7 @@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
 TCLVERSION          = @TCL_VERSION@
-# set from configure when 64bit TclTk Aqua becomes possible on OSX
-TCLTKAQUA_IS64BIT    = @TCLTKAQUA_IS64BIT@
+MACOSX_ARCHS_TCLTK  = @MACOSX_ARCHS_TCLTK@
 #FFTW:
 FFTWINC             = @FFTWINC@
@@ -222,6 +221,7 @@
 PYTHONLDFLAGS       = @PYTHONLDFLAGS@
 SWIG                = @SWIG@
 USE_PYTHON          = @USE_PYTHON@
+MACOSX_ARCHS_PYTHON = @MACOSX_ARCHS_PYTHON@
 #wxWidgets
 WXVERSION           = @WXVERSION@
@@ -229,8 +229,7 @@
 WXWIDGETSCPPFLAGS   = @WXWIDGETSCPPFLAGS@
 WXWIDGETSLIB        = @WXWIDGETSLIB@
 USE_WXWIDGETS       = @USE_WXWIDGETS@
-# set from configure when 64bit wxWidgets becomes possible on OSX
-WX_ISOSX64BIT       =
+MACOSX_ARCHS_WXPYTHON = @MACOSX_ARCHS_WXPYTHON@
 #regex
 REGEXINCPATH        = @REGEXINCPATH@
@@ -249,6 +248,8 @@
 MINGW		    = @MINGW32@
 MACOSX_APP	    = @MACOSX_APP@
+MACOSX_ARCHS    = @MACOSX_ARCHS@
+MACOSX_SDK      = @MACOSX_SDK@
 # Cross compilation
 CROSS_COMPILING = @CROSS_COMPILING@
Modified: grass/branches/develbranch_6/lib/form/Makefile
--- grass/branches/develbranch_6/lib/form/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/lib/form/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -20,12 +20,11 @@
 endif
-endif
 default: lib $(GTCLTKFORM)
Modified: grass/branches/develbranch_6/vector/v.digit/Makefile
--- grass/branches/develbranch_6/vector/v.digit/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/vector/v.digit/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -11,12 +11,11 @@
 endif
-endif
 AUXDIR := $(GISBASE)/etc/v.digit
 TCLFILES := $(patsubst %,$(AUXDIR)/%,$(wildcard *.tcl))
Modified: grass/branches/develbranch_6/vector/v.what/Makefile
--- grass/branches/develbranch_6/vector/v.what/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/vector/v.what/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -12,12 +12,11 @@
 endif
-endif
 default: cmd
Modified: grass/branches/develbranch_6/visualization/nviz/src/Makefile
--- grass/branches/develbranch_6/visualization/nviz/src/Makefile	2009-09-06 19:42:46 UTC (rev 39050)
+++ grass/branches/develbranch_6/visualization/nviz/src/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
@@ -18,10 +18,11 @@
 endif
 OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
 endif
 endif
 SURFLIB = $(OGSFLIB)
