[GRASS-SVN] r39052 - in grass/trunk: . display/d.what.vect gui/wxpython/nviz gui/wxpython/vdigit include/Make lib/form visualization/nviz/src visualization/xganim
Sun Sep 6 17:49:29 EDT 2009
Author: kyngchaos
Date: 2009-09-06 17:49:28 -0400 (Sun, 06 Sep 2009)
New Revision: 39052
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/display/d.what.vect/Makefile
   grass/trunk/gui/wxpython/nviz/Makefile
   grass/trunk/gui/wxpython/vdigit/Makefile
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/lib/form/Makefile
   grass/trunk/visualization/nviz/src/Makefile
   grass/trunk/visualization/xganim/Makefile
Configure option for OSX architectures and SDK;
> strip arch flags that may be in some builds of Python and wxPython
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/configure	2009-09-06 21:49:28 UTC (rev 39052)
@@ -25,6 +25,14 @@
 ac_help="$ac_help
   --with-cxx              support C++ functionality (default: no)"
 ac_help="$ac_help
+  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])"
+ac_help="$ac_help
+  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)"
+ac_help="$ac_help
   --with-jpeg             support JPEG functionality (default: yes)"
 ac_help="$ac_help
   --with-tiff             support TIFF functionality (default: yes)"
@@ -65,18 +73,25 @@
 ac_help="$ac_help
   --with-pthread          support POSIX threads functionality (default: no)"
 ac_help="$ac_help
-  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')"
+  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
-  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)"
+  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)"
 ac_help="$ac_help
-  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
+  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)"
 ac_help="$ac_help
-  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config', default: no)"
+  --with-geos[=path/geos-config]
+                          enable GEOS support (geos-config with path,
+                          e.g. '--with-geos=/usr/local/bin/geos-config',
+                          default: no)"
 ac_help="$ac_help
   --with-includes=DIRS    site include files are in DIRS"
 ac_help="$ac_help
@@ -735,7 +750,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:739: checking host system type" >&5
+echo "configure:754: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -758,7 +773,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:762: checking for $ac_word" >&5
+echo "configure:777: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -785,7 +800,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:789: checking for $ac_word" >&5
+echo "configure:804: checking for $ac_word" >&5
@@ -833,7 +848,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:837: checking for $ac_word" >&5
+echo "configure:852: checking for $ac_word" >&5
@@ -862,7 +877,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:866: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -873,12 +888,12 @@
 cat > conftest.$ac_ext << EOF
-#line 877 "configure"
+#line 892 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -904,19 +919,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:908: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:913: checking whether we are using GNU C" >&5
+echo "configure:928: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:920: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -934,7 +949,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:938: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -963,10 +978,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:967: checking for Cygwin environment" >&5
+echo "configure:982: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 970 "configure"
+#line 985 "configure"
 int main() {
@@ -977,7 +992,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:981: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -993,17 +1008,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:997: checking for mingw32 environment" >&5
+echo "configure:1012: checking for mingw32 environment" >&5
-#line 1000 "configure"
+#line 1015 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1007: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1021,7 +1036,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1025: checking for executable suffix" >&5
+echo "configure:1040: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1040,23 +1055,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1044: checking for full floating-point support" >&5
+echo "configure:1059: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1049: checking whether "cc -mieee" works" >&5
+echo "configure:1064: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1053 "configure"
+#line 1068 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1072,7 +1087,7 @@
 else
-#line 1076 "configure"
+#line 1091 "configure"
 #include <float.h>
@@ -1086,7 +1101,7 @@
 EOF
-if { (eval echo configure:1090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1099,14 +1114,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1103: checking for full floating-point support with -mieee" >&5
+echo "configure:1118: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1110 "configure"
+#line 1125 "configure"
 #include <float.h>
@@ -1120,7 +1135,7 @@
 EOF
-if { (eval echo configure:1124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1157,7 +1172,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1161: checking for $ac_word" >&5
+echo "configure:1176: checking for $ac_word" >&5
 case "$pwd" in
@@ -1195,7 +1210,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1199: checking for source directory" >&5
+echo "configure:1214: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1206,7 +1221,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1210: checking for build directory" >&5
+echo "configure:1225: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1291,7 +1306,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1295: checking for MacOSX App" >&5
+echo "configure:1310: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1300,6 +1315,78 @@
 echo "$ac_t"""$enable_macosx_app"" 1>&6
+# Check for MacOSX archs
+echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
+echo "configure:1322: checking for MacOSX architectures" >&5
+MACOSX_ARCHS=
+if test "$with_macosx_archs" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  echo "$ac_t""$MACOSX_ARCHS" 1>&6
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
+echo "configure:1351: checking for MacOSX SDK" >&5
+MACOSX_SDK=
+if test "$with_macosx_sdk" = "no" ; then
+else
+ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
+echo "configure:1361: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+if test "$cross_compiling" = yes; then
+    { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
+else
+  if test -r $with_macosx_sdk/SDKSettings.plist; then
+    eval "ac_cv_file_$ac_safe=yes"
+  else
+    eval "ac_cv_file_$ac_safe=no"
+  fi
+fi
+if eval "test \"`echo '$ac_cv_file_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    MACOSX_SDK="-isysroot $with_macosx_sdk"
+else
+    { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
+fi
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -1314,7 +1401,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1318: checking how to build libraries" >&5
+echo "configure:1405: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1357,7 +1444,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1361: checking for $ac_word" >&5
+echo "configure:1448: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1382,7 +1469,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1386: checking how to run the C preprocessor" >&5
+echo "configure:1473: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1395,13 +1482,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1399 "configure"
+#line 1486 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1412,13 +1499,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1416 "configure"
+#line 1503 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1429,13 +1516,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1433 "configure"
+#line 1520 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1463,7 +1550,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1467: checking if 64bit support is requested" >&5
+echo "configure:1554: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1483,7 +1570,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1487: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1574: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1507,7 +1594,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1511: checking system version (for dynamic loading)" >&5
+echo "configure:1598: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1533,13 +1620,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1537: checking for dlopen in -ldl" >&5
+echo "configure:1624: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1543 "configure"
+#line 1630 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1550,7 +1637,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1597,7 +1684,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1601: checking for $ac_word" >&5
+echo "configure:1688: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1726,13 +1813,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1730: checking for gettimeofday in -lbsd" >&5
+echo "configure:1817: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1736 "configure"
+#line 1823 "configure"
@@ -1743,7 +1830,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1784,13 +1871,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1788: checking for inet_ntoa in -lbind" >&5
+echo "configure:1875: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1794 "configure"
+#line 1881 "configure"
@@ -1801,7 +1888,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1862,13 +1949,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1866: checking for shl_load in -ldld" >&5
+echo "configure:1953: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1872 "configure"
+#line 1959 "configure"
@@ -1879,7 +1966,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1944,13 +2031,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1948: checking for shl_load in -ldld" >&5
+echo "configure:2035: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1954 "configure"
+#line 2041 "configure"
@@ -1961,7 +2048,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2083,15 +2170,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2087: checking for dld.h" >&5
+echo "configure:2174: checking for dld.h" >&5
-#line 2090 "configure"
+#line 2177 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2095: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2151,15 +2238,15 @@
 	    else
-echo "configure:2155: checking for dld.h" >&5
+echo "configure:2242: checking for dld.h" >&5
-#line 2158 "configure"
+#line 2245 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2256,9 +2343,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2260: checking for ELF" >&5
+echo "configure:2347: checking for ELF" >&5
-#line 2262 "configure"
+#line 2349 "configure"
 #ifdef __ELF__
@@ -2288,15 +2375,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2292: checking for dlfcn.h" >&5
+echo "configure:2379: checking for dlfcn.h" >&5
-#line 2295 "configure"
+#line 2382 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2320,9 +2407,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2324: checking for ELF" >&5
+echo "configure:2411: checking for ELF" >&5
-#line 2326 "configure"
+#line 2413 "configure"
 #ifdef __ELF__
@@ -2646,17 +2733,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2650: checking for ld accepts -Bexport flag" >&5
+echo "configure:2737: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2653 "configure"
+#line 2740 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2795,6 +2882,23 @@
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+# Check whether --with-macosx-archs or --without-macosx-archs was given.
+if test "${with_macosx_archs+set}" = set; then
+  withval="$with_macosx_archs"
+else
+  with_macosx_archs="no"
+fi
+# Check whether --with-macosx-sdk or --without-macosx-sdk was given.
+if test "${with_macosx_sdk+set}" = set; then
+  withval="$with_macosx_sdk"
+else
+  with_macosx_sdk="no"
+fi
 # Check whether --with-jpeg or --without-jpeg was given.
 if test "${with_jpeg+set}" = set; then
   withval="$with_jpeg"
@@ -3435,7 +3539,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3439: checking for additional include dirs" >&5
+echo "configure:3543: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3458,7 +3562,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3462: checking for additional library dirs" >&5
+echo "configure:3566: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3492,7 +3596,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3496: checking for a BSD compatible install" >&5
+echo "configure:3600: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3545,7 +3649,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3549: checking for $ac_word" >&5
+echo "configure:3653: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3576,13 +3680,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3580: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3684: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3586 "configure"
+#line 3690 "configure"
@@ -3593,7 +3697,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3618,7 +3722,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3622: checking for $ac_word" >&5
+echo "configure:3726: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3658,7 +3762,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3662: checking for $ac_word" >&5
+echo "configure:3766: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3689,7 +3793,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3693: checking for $ac_word" >&5
+echo "configure:3797: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3727,7 +3831,7 @@
-echo "configure:3731: checking for $ac_word" >&5
+echo "configure:3835: checking for $ac_word" >&5
@@ -3756,7 +3860,7 @@
-echo "configure:3760: checking for $ac_word" >&5
+echo "configure:3864: checking for $ac_word" >&5
@@ -3787,7 +3891,7 @@
-echo "configure:3791: checking for $ac_word" >&5
+echo "configure:3895: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3816,7 +3920,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3820: checking for $ac_word" >&5
+echo "configure:3924: checking for $ac_word" >&5
 case "$PERL" in
@@ -3847,10 +3951,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3851: checking for ANSI C header files" >&5
+echo "configure:3955: checking for ANSI C header files" >&5
-#line 3854 "configure"
+#line 3958 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3858,7 +3962,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3862: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3875,7 +3979,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3879 "configure"
+#line 3983 "configure"
 #include <string.h>
 EOF
@@ -3893,7 +3997,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3897 "configure"
+#line 4001 "configure"
 #include <stdlib.h>
 EOF
@@ -3914,7 +4018,7 @@
 else
-#line 3918 "configure"
+#line 4022 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3925,7 +4029,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3952,15 +4056,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3956: checking for $ac_hdr" >&5
+echo "configure:4060: checking for $ac_hdr" >&5
-#line 3959 "configure"
+#line 4063 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3989,15 +4093,15 @@
 do
-echo "configure:3993: checking for $ac_hdr" >&5
+echo "configure:4097: checking for $ac_hdr" >&5
-#line 3996 "configure"
+#line 4100 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4026,15 +4130,15 @@
 do
-echo "configure:4030: checking for $ac_hdr" >&5
+echo "configure:4134: checking for $ac_hdr" >&5
-#line 4033 "configure"
+#line 4137 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4063,15 +4167,15 @@
 do
-echo "configure:4067: checking for $ac_hdr" >&5
+echo "configure:4171: checking for $ac_hdr" >&5
-#line 4070 "configure"
+#line 4174 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4179: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4100,15 +4204,15 @@
 do
-echo "configure:4104: checking for $ac_hdr" >&5
+echo "configure:4208: checking for $ac_hdr" >&5
-#line 4107 "configure"
+#line 4211 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4134,10 +4238,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4138: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4242: checking whether time.h and sys/time.h may both be included" >&5
-#line 4141 "configure"
+#line 4245 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4146,7 +4250,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4150: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4254: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4166,10 +4270,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4170: checking for off_t" >&5
+echo "configure:4274: checking for off_t" >&5
-#line 4173 "configure"
+#line 4277 "configure"
 #if STDC_HEADERS
@@ -4196,10 +4300,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4200: checking for uid_t in sys/types.h" >&5
+echo "configure:4304: checking for uid_t in sys/types.h" >&5
-#line 4203 "configure"
+#line 4307 "configure"
 EOF
@@ -4227,10 +4331,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4231: checking return type of signal handlers" >&5
+echo "configure:4335: checking return type of signal handlers" >&5
-#line 4234 "configure"
+#line 4338 "configure"
 #include <signal.h>
@@ -4247,7 +4351,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4265,10 +4369,10 @@
-echo "configure:4269: checking for Cygwin environment" >&5
+echo "configure:4373: checking for Cygwin environment" >&5
-#line 4272 "configure"
+#line 4376 "configure"
 int main() {
@@ -4279,7 +4383,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4283: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4387: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4297,10 +4401,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4301: checking for $ac_func" >&5
+echo "configure:4405: checking for $ac_func" >&5
-#line 4304 "configure"
+#line 4408 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4323,7 +4427,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4349,10 +4453,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4353: checking for $ac_func" >&5
+echo "configure:4457: checking for $ac_func" >&5
-#line 4356 "configure"
+#line 4460 "configure"
@@ -4375,7 +4479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4401,10 +4505,10 @@
 for ac_func in drand48
 do
-echo "configure:4405: checking for $ac_func" >&5
+echo "configure:4509: checking for $ac_func" >&5
-#line 4408 "configure"
+#line 4512 "configure"
@@ -4427,7 +4531,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4453,10 +4557,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4457: checking for $ac_func" >&5
+echo "configure:4561: checking for $ac_func" >&5
-#line 4460 "configure"
+#line 4564 "configure"
@@ -4479,7 +4583,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4505,10 +4609,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4509: checking for $ac_func" >&5
+echo "configure:4613: checking for $ac_func" >&5
-#line 4512 "configure"
+#line 4616 "configure"
@@ -4531,7 +4635,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4556,13 +4660,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4560: checking whether setpgrp takes no argument" >&5
+echo "configure:4664: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4566 "configure"
+#line 4670 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4582,7 +4686,7 @@
 EOF
-if { (eval echo configure:4586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4610,16 +4714,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4614: checking for long long int" >&5
+echo "configure:4718: checking for long long int" >&5
-#line 4616 "configure"
+#line 4720 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4623: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4727: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4639,7 +4743,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4643: checking for W11" >&5
+echo "configure:4747: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4667,7 +4771,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4671: checking for X" >&5
+echo "configure:4775: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4727,12 +4831,12 @@
   # First, try using that file with no special directory specified.
-#line 4731 "configure"
+#line 4835 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4801,14 +4905,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4805 "configure"
+#line 4909 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4913,17 +5017,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4917: checking whether -R must be followed by a space" >&5
+echo "configure:5021: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4920 "configure"
+#line 5024 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4939,14 +5043,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4943 "configure"
+#line 5047 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4978,13 +5082,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4982: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5086: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4988 "configure"
+#line 5092 "configure"
@@ -4995,7 +5099,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5016,13 +5120,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5020: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5124: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5026 "configure"
+#line 5130 "configure"
@@ -5033,7 +5137,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5061,10 +5165,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5065: checking for gethostbyname" >&5
+echo "configure:5169: checking for gethostbyname" >&5
-#line 5068 "configure"
+#line 5172 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5087,7 +5191,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5107,13 +5211,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5111: checking for gethostbyname in -lnsl" >&5
+echo "configure:5215: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5117 "configure"
+#line 5221 "configure"
@@ -5124,7 +5228,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5153,10 +5257,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5157: checking for connect" >&5
+echo "configure:5261: checking for connect" >&5
-#line 5160 "configure"
+#line 5264 "configure"
     which can conflict with char connect(); below.  */
@@ -5179,7 +5283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5199,13 +5303,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5203: checking for connect in -lsocket" >&5
+echo "configure:5307: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5209 "configure"
+#line 5313 "configure"
@@ -5216,7 +5320,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5239,10 +5343,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5243: checking for remove" >&5
+echo "configure:5347: checking for remove" >&5
-#line 5246 "configure"
+#line 5350 "configure"
     which can conflict with char remove(); below.  */
@@ -5265,7 +5369,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5285,13 +5389,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5289: checking for remove in -lposix" >&5
+echo "configure:5393: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5295 "configure"
+#line 5399 "configure"
@@ -5302,7 +5406,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5325,10 +5429,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5329: checking for shmat" >&5
+echo "configure:5433: checking for shmat" >&5
-#line 5332 "configure"
+#line 5436 "configure"
     which can conflict with char shmat(); below.  */
@@ -5351,7 +5455,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5371,13 +5475,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5375: checking for shmat in -lipc" >&5
+echo "configure:5479: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5381 "configure"
+#line 5485 "configure"
@@ -5388,7 +5492,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5420,13 +5524,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5424: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5528: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5430 "configure"
+#line 5534 "configure"
@@ -5437,7 +5541,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5477,12 +5581,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5481: checking for library containing cuserid" >&5
+echo "configure:5585: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5486 "configure"
+#line 5590 "configure"
@@ -5493,7 +5597,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5504,7 +5608,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5508 "configure"
+#line 5612 "configure"
@@ -5515,7 +5619,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5541,10 +5645,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5545: checking for xdrmem_create" >&5
+echo "configure:5649: checking for xdrmem_create" >&5
-#line 5548 "configure"
+#line 5652 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5567,7 +5671,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5585,13 +5689,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5589: checking for xdrmem_create in -lsun" >&5
+echo "configure:5693: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5595 "configure"
+#line 5699 "configure"
@@ -5602,7 +5706,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5621,13 +5725,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5625: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5729: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5631 "configure"
+#line 5735 "configure"
@@ -5638,7 +5742,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5657,13 +5761,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5661: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5765: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5667 "configure"
+#line 5771 "configure"
@@ -5674,7 +5778,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5693,13 +5797,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5697: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5801: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5703 "configure"
+#line 5807 "configure"
@@ -5710,7 +5814,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5744,10 +5848,10 @@
 for ac_func in asprintf
 do
-echo "configure:5748: checking for $ac_func" >&5
+echo "configure:5852: checking for $ac_func" >&5
-#line 5751 "configure"
+#line 5855 "configure"
@@ -5770,7 +5874,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5797,10 +5901,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5801: checking for atan" >&5
+echo "configure:5905: checking for atan" >&5
-#line 5804 "configure"
+#line 5908 "configure"
     which can conflict with char atan(); below.  */
@@ -5823,7 +5927,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5841,13 +5945,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5845: checking for atan in -lm" >&5
+echo "configure:5949: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5851 "configure"
+#line 5955 "configure"
@@ -5858,7 +5962,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5885,10 +5989,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5889: checking for dlsym" >&5
+echo "configure:5993: checking for dlsym" >&5
-#line 5892 "configure"
+#line 5996 "configure"
     which can conflict with char dlsym(); below.  */
@@ -5911,7 +6015,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -5929,13 +6033,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5933: checking for dlsym in -ldl" >&5
+echo "configure:6037: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 5939 "configure"
+#line 6043 "configure"
@@ -5946,7 +6050,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5973,10 +6077,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5977: checking for iconv" >&5
+echo "configure:6081: checking for iconv" >&5
-#line 5980 "configure"
+#line 6084 "configure"
     which can conflict with char iconv(); below.  */
@@ -5999,7 +6103,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6017,13 +6121,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6021: checking for iconv in -liconv" >&5
+echo "configure:6125: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6027 "configure"
+#line 6131 "configure"
@@ -6034,7 +6138,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6053,13 +6157,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6057: checking for iconv in -lgiconv" >&5
+echo "configure:6161: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6063 "configure"
+#line 6167 "configure"
@@ -6070,7 +6174,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6089,10 +6193,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6093: checking for libiconv" >&5
+echo "configure:6197: checking for libiconv" >&5
-#line 6096 "configure"
+#line 6200 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6115,7 +6219,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6133,13 +6237,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6137: checking for libiconv in -liconv" >&5
+echo "configure:6241: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6143 "configure"
+#line 6247 "configure"
@@ -6150,7 +6254,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6169,13 +6273,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6173: checking for libiconv in -lgiconv" >&5
+echo "configure:6277: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6179 "configure"
+#line 6283 "configure"
@@ -6186,7 +6290,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6223,10 +6327,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6227: checking for socket" >&5
+echo "configure:6331: checking for socket" >&5
-#line 6230 "configure"
+#line 6334 "configure"
     which can conflict with char socket(); below.  */
@@ -6249,7 +6353,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6267,13 +6371,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6271: checking for socket in -lsocket" >&5
+echo "configure:6375: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6277 "configure"
+#line 6381 "configure"
@@ -6284,7 +6388,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6332,7 +6436,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6336: checking for location of zlib includes" >&5
+echo "configure:6440: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6358,15 +6462,15 @@
 do
-echo "configure:6362: checking for $ac_hdr" >&5
+echo "configure:6466: checking for $ac_hdr" >&5
-#line 6365 "configure"
+#line 6469 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6474: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6400,7 +6504,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6404: checking for location of zlib library" >&5
+echo "configure:6508: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6425,13 +6529,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6429: checking for deflate in -lz" >&5
+echo "configure:6533: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6435 "configure"
+#line 6539 "configure"
@@ -6442,7 +6546,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6490,7 +6594,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6494: checking for location of External PROJ.4 includes" >&5
+echo "configure:6598: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6516,15 +6620,15 @@
 do
-echo "configure:6520: checking for $ac_hdr" >&5
+echo "configure:6624: checking for $ac_hdr" >&5
-#line 6523 "configure"
+#line 6627 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6528: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6561,7 +6665,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6565: checking External PROJ.4 version" >&5
+echo "configure:6669: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6569,7 +6673,7 @@
 else
-#line 6573 "configure"
+#line 6677 "configure"
 #include <stdio.h>
@@ -6581,7 +6685,7 @@
 EOF
-if { (eval echo configure:6585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6606,7 +6710,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6610: checking for location of External PROJ.4 library" >&5
+echo "configure:6714: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6631,13 +6735,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6635: checking for pj_get_def in -lproj" >&5
+echo "configure:6739: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6641 "configure"
+#line 6745 "configure"
@@ -6648,7 +6752,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6682,7 +6786,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6686: checking for location of External PROJ.4 data files" >&5
+echo "configure:6790: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6706,14 +6810,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6710: checking for epsg" >&5
+echo "configure:6814: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6717: checking for $PROJSHARE/epsg" >&5
+echo "configure:6821: checking for $PROJSHARE/epsg" >&5
@@ -6745,7 +6849,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6749: checking for $ac_word" >&5
+echo "configure:6853: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6785,7 +6889,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6789: checking whether to use regex" >&5
+echo "configure:6893: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6805,7 +6909,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6809: checking for location of regex includes" >&5
+echo "configure:6913: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6831,15 +6935,15 @@
 do
-echo "configure:6835: checking for $ac_hdr" >&5
+echo "configure:6939: checking for $ac_hdr" >&5
-#line 6838 "configure"
+#line 6942 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6873,7 +6977,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6877: checking for location of regex library" >&5
+echo "configure:6981: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6898,10 +7002,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6902: checking for regcomp" >&5
+echo "configure:7006: checking for regcomp" >&5
-#line 6905 "configure"
+#line 7009 "configure"
 #include "confdefs.h"
     which can conflict with char regcomp(); below.  */
@@ -6924,7 +7028,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6951,13 +7055,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6955: checking for regcomp in -lregex" >&5
+echo "configure:7059: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 6961 "configure"
+#line 7065 "configure"
@@ -6968,7 +7072,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7018,7 +7122,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7022: checking whether to use Readline" >&5
+echo "configure:7126: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7039,7 +7143,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7043: checking for location of Readline includes" >&5
+echo "configure:7147: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7065,15 +7169,15 @@
 do
-echo "configure:7069: checking for $ac_hdr" >&5
+echo "configure:7173: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7072 "configure"
+#line 7176 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7109,15 +7213,15 @@
 do
-echo "configure:7113: checking for $ac_hdr" >&5
+echo "configure:7217: checking for $ac_hdr" >&5
-#line 7116 "configure"
+#line 7220 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7151,7 +7255,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7155: checking for location of Readline library" >&5
+echo "configure:7259: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7176,13 +7280,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7180: checking for readline in -lreadline" >&5
+echo "configure:7284: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7186 "configure"
+#line 7290 "configure"
@@ -7193,7 +7297,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7228,13 +7332,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7232: checking for add_history in -lhistory" >&5
+echo "configure:7336: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7238 "configure"
+#line 7342 "configure"
@@ -7245,7 +7349,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7288,7 +7392,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7292: checking whether to use JPEG" >&5
+echo "configure:7396: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7308,7 +7412,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7312: checking for location of JPEG includes" >&5
+echo "configure:7416: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7334,15 +7438,15 @@
 do
-echo "configure:7338: checking for $ac_hdr" >&5
+echo "configure:7442: checking for $ac_hdr" >&5
-#line 7341 "configure"
+#line 7445 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7376,7 +7480,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7380: checking for location of JPEG library" >&5
+echo "configure:7484: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7403,13 +7507,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7407: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7511: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7413 "configure"
+#line 7517 "configure"
@@ -7420,7 +7524,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7439,13 +7543,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7443: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7547: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7449 "configure"
+#line 7553 "configure"
@@ -7456,7 +7560,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7505,7 +7609,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7509: checking whether to use GDAL" >&5
+echo "configure:7613: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7523,7 +7627,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7527: checking for $ac_word" >&5
+echo "configure:7631: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7578,14 +7682,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7582 "configure"
+#line 7686 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7594,14 +7698,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7598 "configure"
+#line 7702 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7633,7 +7737,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7637: checking whether to use GEOS" >&5
+echo "configure:7741: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7650,7 +7754,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7654: checking for $ac_word" >&5
+echo "configure:7758: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7698,15 +7802,15 @@
 do
-echo "configure:7702: checking for $ac_hdr" >&5
+echo "configure:7806: checking for $ac_hdr" >&5
-#line 7705 "configure"
+#line 7809 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7741,13 +7845,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7745: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7849: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 7751 "configure"
+#line 7855 "configure"
@@ -7758,7 +7862,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:7762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7801,7 +7905,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7805: checking whether to use TIFF" >&5
+echo "configure:7909: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7821,7 +7925,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7825: checking for location of TIFF includes" >&5
+echo "configure:7929: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7847,15 +7951,15 @@
 do
-echo "configure:7851: checking for $ac_hdr" >&5
+echo "configure:7955: checking for $ac_hdr" >&5
-#line 7854 "configure"
+#line 7958 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7889,7 +7993,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7893: checking for location of TIFF library" >&5
+echo "configure:7997: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7920,13 +8024,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7924: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8028: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7930 "configure"
+#line 8034 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7937,7 +8041,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7956,13 +8060,13 @@
-echo "configure:7960: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8064: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7966 "configure"
+#line 8070 "configure"
@@ -7973,7 +8077,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7992,13 +8096,13 @@
-echo "configure:7996: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8100: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8002 "configure"
+#line 8106 "configure"
@@ -8009,7 +8113,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8028,13 +8132,13 @@
-echo "configure:8032: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8136: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8038 "configure"
+#line 8142 "configure"
@@ -8045,7 +8149,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8064,13 +8168,13 @@
-echo "configure:8068: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8074 "configure"
+#line 8178 "configure"
@@ -8081,7 +8185,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8100,13 +8204,13 @@
-echo "configure:8104: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8110 "configure"
+#line 8214 "configure"
@@ -8117,7 +8221,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8136,13 +8240,13 @@
-echo "configure:8140: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8146 "configure"
+#line 8250 "configure"
@@ -8153,7 +8257,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8172,13 +8276,13 @@
-echo "configure:8176: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8182 "configure"
+#line 8286 "configure"
@@ -8189,7 +8293,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8287,7 +8391,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8291: checking whether to use PNG" >&5
+echo "configure:8395: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8306,7 +8410,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8310: checking for location of PNG includes" >&5
+echo "configure:8414: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8332,15 +8436,15 @@
 do
-echo "configure:8336: checking for $ac_hdr" >&5
+echo "configure:8440: checking for $ac_hdr" >&5
-#line 8339 "configure"
+#line 8443 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8448: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8374,7 +8478,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8378: checking for location of PNG library" >&5
+echo "configure:8482: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8399,13 +8503,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8403: checking for png_read_image in -lpng" >&5
+echo "configure:8507: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8409 "configure"
+#line 8513 "configure"
@@ -8416,7 +8520,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8458,7 +8562,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8462: checking whether to use PostgreSQL" >&5
+echo "configure:8566: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8485,7 +8589,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8489: checking for location of PostgreSQL includes" >&5
+echo "configure:8593: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8511,15 +8615,15 @@
 do
-echo "configure:8515: checking for $ac_hdr" >&5
+echo "configure:8619: checking for $ac_hdr" >&5
-#line 8518 "configure"
+#line 8622 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8557,7 +8661,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8561: checking for location of PostgreSQL library" >&5
+echo "configure:8665: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8586,13 +8690,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8590: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8694: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8596 "configure"
+#line 8700 "configure"
@@ -8603,7 +8707,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8622,13 +8726,13 @@
-echo "configure:8626: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8730: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8632 "configure"
+#line 8736 "configure"
@@ -8639,7 +8743,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8658,13 +8762,13 @@
-echo "configure:8662: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8766: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8668 "configure"
+#line 8772 "configure"
@@ -8675,7 +8779,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8694,13 +8798,13 @@
-echo "configure:8698: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8802: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8704 "configure"
+#line 8808 "configure"
@@ -8711,7 +8815,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8768,13 +8872,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8772: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8876: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8778 "configure"
+#line 8882 "configure"
@@ -8785,7 +8889,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8807,13 +8911,13 @@
-echo "configure:8811: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8915: checking for PQcmdTuples in -lpq" >&5
-#line 8817 "configure"
+#line 8921 "configure"
@@ -8824,7 +8928,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8867,7 +8971,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8871: checking whether to use MySQL" >&5
+echo "configure:8975: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -8887,7 +8991,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8891: checking for location of MySQL includes" >&5
+echo "configure:8995: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8913,15 +9017,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8917: checking for $ac_hdr" >&5
+echo "configure:9021: checking for $ac_hdr" >&5
-#line 8920 "configure"
+#line 9024 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8958,7 +9062,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8962: checking for location of MySQL library" >&5
+echo "configure:9066: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8989,13 +9093,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8993: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9097: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8999 "configure"
+#line 9103 "configure"
@@ -9006,7 +9110,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9025,13 +9129,13 @@
-echo "configure:9029: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9133: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9035 "configure"
+#line 9139 "configure"
@@ -9042,7 +9146,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9061,13 +9165,13 @@
-echo "configure:9065: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9169: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9071 "configure"
+#line 9175 "configure"
@@ -9078,7 +9182,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9097,13 +9201,13 @@
-echo "configure:9101: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9205: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9107 "configure"
+#line 9211 "configure"
@@ -9114,7 +9218,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9133,13 +9237,13 @@
-echo "configure:9137: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9241: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9143 "configure"
+#line 9247 "configure"
@@ -9150,7 +9254,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9169,13 +9273,13 @@
-echo "configure:9173: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9277: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9179 "configure"
+#line 9283 "configure"
@@ -9186,7 +9290,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9205,13 +9309,13 @@
-echo "configure:9209: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9313: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9215 "configure"
+#line 9319 "configure"
@@ -9222,7 +9326,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9241,13 +9345,13 @@
-echo "configure:9245: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9349: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9251 "configure"
+#line 9355 "configure"
@@ -9258,7 +9362,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9348,7 +9452,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9352: checking for $ac_word" >&5
+echo "configure:9456: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9397,10 +9501,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9401: checking for mysql_server_init" >&5
+echo "configure:9505: checking for mysql_server_init" >&5
-#line 9404 "configure"
+#line 9508 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9426,7 +9530,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9478,7 +9582,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9482: checking whether to use SQLite" >&5
+echo "configure:9586: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9498,7 +9602,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9502: checking for location of SQLite includes" >&5
+echo "configure:9606: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9524,15 +9628,15 @@
 do
-echo "configure:9528: checking for $ac_hdr" >&5
+echo "configure:9632: checking for $ac_hdr" >&5
-#line 9531 "configure"
+#line 9635 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9575,7 +9679,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9579: checking for location of SQLite library" >&5
+echo "configure:9683: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9602,13 +9706,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9606: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9710: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9612 "configure"
+#line 9716 "configure"
@@ -9619,7 +9723,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9638,13 +9742,13 @@
-echo "configure:9642: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9746: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9648 "configure"
+#line 9752 "configure"
@@ -9655,7 +9759,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9708,7 +9812,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9712: checking whether to use FFMPEG" >&5
+echo "configure:9816: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -9728,7 +9832,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9732: checking for location of FFMPEG includes" >&5
+echo "configure:9836: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9754,15 +9858,15 @@
 do
-echo "configure:9758: checking for $ac_hdr" >&5
+echo "configure:9862: checking for $ac_hdr" >&5
-#line 9761 "configure"
+#line 9865 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9798,15 +9902,15 @@
 do
-echo "configure:9802: checking for $ac_hdr" >&5
+echo "configure:9906: checking for $ac_hdr" >&5
-#line 9805 "configure"
+#line 9909 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9842,15 +9946,15 @@
 do
-echo "configure:9846: checking for $ac_hdr" >&5
+echo "configure:9950: checking for $ac_hdr" >&5
-#line 9849 "configure"
+#line 9953 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9893,7 +9997,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9897: checking for location of FFMPEG library" >&5
+echo "configure:10001: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9920,13 +10024,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9924: checking for av_free in -lavutil" >&5
+echo "configure:10028: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 9930 "configure"
+#line 10034 "configure"
@@ -9937,7 +10041,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9956,13 +10060,13 @@
-echo "configure:9960: checking for av_free in -lavutil" >&5
+echo "configure:10064: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 9966 "configure"
+#line 10070 "configure"
@@ -9973,7 +10077,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10018,13 +10122,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10022: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10126: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10028 "configure"
+#line 10132 "configure"
@@ -10035,7 +10139,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10054,13 +10158,13 @@
-echo "configure:10058: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10162: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10064 "configure"
+#line 10168 "configure"
@@ -10071,7 +10175,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10116,13 +10220,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10120: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10224: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10126 "configure"
+#line 10230 "configure"
@@ -10133,7 +10237,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10152,13 +10256,13 @@
-echo "configure:10156: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10260: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10162 "configure"
+#line 10266 "configure"
@@ -10169,7 +10273,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10228,7 +10332,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10232: checking whether to use OpenGL" >&5
+echo "configure:10336: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10262,7 +10366,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10266: checking for location of OpenGL includes" >&5
+echo "configure:10370: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10288,15 +10392,15 @@
 do
-echo "configure:10292: checking for $ac_hdr" >&5
+echo "configure:10396: checking for $ac_hdr" >&5
-#line 10295 "configure"
+#line 10399 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10330,7 +10434,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10334: checking for location of OpenGL library" >&5
+echo "configure:10438: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10359,13 +10463,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10363: checking for glBegin in -lGL" >&5
+echo "configure:10467: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10369 "configure"
+#line 10473 "configure"
@@ -10376,7 +10480,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10395,13 +10499,13 @@
-echo "configure:10399: checking for glBegin in -lGL" >&5
+echo "configure:10503: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10405 "configure"
+#line 10509 "configure"
@@ -10412,7 +10516,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10431,13 +10535,13 @@
-echo "configure:10435: checking for glBegin in -lGL" >&5
+echo "configure:10539: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10441 "configure"
+#line 10545 "configure"
@@ -10448,7 +10552,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10467,13 +10571,13 @@
-echo "configure:10471: checking for glBegin in -lGL" >&5
+echo "configure:10575: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10477 "configure"
+#line 10581 "configure"
@@ -10484,7 +10588,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10546,13 +10650,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10550: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10654: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10556 "configure"
+#line 10660 "configure"
@@ -10563,7 +10667,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10582,13 +10686,13 @@
-echo "configure:10586: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10690: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10592 "configure"
+#line 10696 "configure"
@@ -10599,7 +10703,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10646,10 +10750,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10650: checking for glXCreatePbuffer" >&5
+echo "configure:10754: checking for glXCreatePbuffer" >&5
-#line 10653 "configure"
+#line 10757 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -10672,7 +10776,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -10709,10 +10813,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10713: checking for glXCreateGLXPixmap" >&5
+echo "configure:10817: checking for glXCreateGLXPixmap" >&5
-#line 10716 "configure"
+#line 10820 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -10735,7 +10839,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -10778,7 +10882,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10782: checking for location of OpenGL framework" >&5
+echo "configure:10886: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10802,15 +10906,15 @@
 do
-echo "configure:10806: checking for $ac_hdr" >&5
+echo "configure:10910: checking for $ac_hdr" >&5
-#line 10809 "configure"
+#line 10913 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10846,10 +10950,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10850: checking for glBegin" >&5
+echo "configure:10954: checking for glBegin" >&5
-#line 10853 "configure"
+#line 10957 "configure"
     which can conflict with char glBegin(); below.  */
@@ -10872,7 +10976,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -10909,10 +11013,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10913: checking for gluBeginCurve" >&5
+echo "configure:11017: checking for gluBeginCurve" >&5
-#line 10916 "configure"
+#line 11020 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -10935,7 +11039,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -10983,7 +11087,7 @@
-echo "configure:10987: checking for location of OpenGL includes" >&5
+echo "configure:11091: checking for location of OpenGL includes" >&5
@@ -11009,15 +11113,15 @@
 do
-echo "configure:11013: checking for $ac_hdr" >&5
+echo "configure:11117: checking for $ac_hdr" >&5
-#line 11016 "configure"
+#line 11120 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11021: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11051,7 +11155,7 @@
-echo "configure:11055: checking for location of OpenGL library" >&5
+echo "configure:11159: checking for location of OpenGL library" >&5
@@ -11076,18 +11180,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11080: checking for OpenGL library" >&5
+echo "configure:11184: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11084 "configure"
+#line 11188 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11111,18 +11215,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11115: checking for GLU library" >&5
+echo "configure:11219: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11119 "configure"
+#line 11223 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11171,7 +11275,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11175: checking whether to use Tcl/Tk" >&5
+echo "configure:11279: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11191,7 +11295,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11195: checking for location of Tcl/Tk includes" >&5
+echo "configure:11299: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11217,15 +11321,15 @@
 do
-echo "configure:11221: checking for $ac_hdr" >&5
+echo "configure:11325: checking for $ac_hdr" >&5
-#line 11224 "configure"
+#line 11328 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11262,15 +11366,15 @@
 do
-echo "configure:11266: checking for $ac_hdr" >&5
+echo "configure:11370: checking for $ac_hdr" >&5
-#line 11269 "configure"
+#line 11373 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11274: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11304,7 +11408,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11308: checking Tcl version" >&5
+echo "configure:11412: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11312,7 +11416,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 11316 "configure"
+#line 11420 "configure"
 #include <stdio.h>
@@ -11324,7 +11428,7 @@
 EOF
-if { (eval echo configure:11328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11342,7 +11446,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11346: checking Tk version" >&5
+echo "configure:11450: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11350,7 +11454,7 @@
 else
-#line 11354 "configure"
+#line 11458 "configure"
 #include <stdio.h>
@@ -11362,7 +11466,7 @@
 EOF
-if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11391,7 +11495,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11395: checking for location of Tcl/Tk library" >&5
+echo "configure:11499: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11412,22 +11516,14 @@
 TCLLIB=
 TKLIB=
+MACOSX_ARCHS_TCLTK=
 # Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
-# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
-TCLTKAQUA_IS64BIT=
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua
 if test "$OPENGL_AQUA" = 1 ; then
-    temp_CFLAGS="$CFLAGS"
+    save_CFLAGS="$CFLAGS"
     CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-    # can't save LDFLAGS, need to remember arch flags to insert back later
-    temp_ARCHES=
-    for a in x86_64 ppc64
-    do
-        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
-            temp_ARCHES="$temp_ARCHES -arch $a"
-        fi
-    done
+    save_LDFLAGS="$LDFLAGS"
     LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
 fi
@@ -11439,13 +11535,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11443: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11539: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11449 "configure"
+#line 11545 "configure"
@@ -11456,7 +11552,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11475,13 +11571,13 @@
-echo "configure:11479: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11575: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11485 "configure"
+#line 11581 "configure"
@@ -11492,7 +11588,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11519,13 +11615,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11523: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11619: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11529 "configure"
+#line 11625 "configure"
@@ -11536,7 +11632,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11555,13 +11651,13 @@
-echo "configure:11559: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11655: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11565 "configure"
+#line 11661 "configure"
@@ -11572,7 +11668,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11599,13 +11695,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11603: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11699: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11609 "configure"
+#line 11705 "configure"
@@ -11616,7 +11712,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11635,13 +11731,13 @@
-echo "configure:11639: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11735: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11645 "configure"
+#line 11741 "configure"
@@ -11652,7 +11748,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11730,13 +11826,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11734: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11830: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11740 "configure"
+#line 11836 "configure"
@@ -11747,7 +11843,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11766,13 +11862,13 @@
-echo "configure:11770: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11866: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11776 "configure"
+#line 11872 "configure"
@@ -11783,7 +11879,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11810,13 +11906,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11814: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11910: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11820 "configure"
+#line 11916 "configure"
@@ -11827,7 +11923,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11846,13 +11942,13 @@
-echo "configure:11850: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11946: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11856 "configure"
+#line 11952 "configure"
@@ -11863,7 +11959,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11890,13 +11986,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11894: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11990: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11900 "configure"
+#line 11996 "configure"
@@ -11907,7 +12003,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11926,13 +12022,13 @@
-echo "configure:11930: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12026: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11936 "configure"
+#line 12032 "configure"
@@ -11943,7 +12039,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12016,11 +12112,68 @@
 # restore CFLAGS/LDLFAGS from Aqua 64bit strip
 # only Tcl/Tk-based makefiles will strip 64bit out during compile
-   CFLAGS="$temp_CFLAGS"
-   LDFLAGS="$temp_ARCHES $LDFLAGS"
+   CFLAGS="$save_CFLAGS"
+   LDFLAGS="$save_LDFLAGS"
 fi
 TCLTKLIBS="$TKLIB $TCLLIB"
+# check for available OSX archs in TclTk
+if test -n "$MACOSX_ARCHS" ; then
+  LDFLAGS=
+  CFLAGS=
+  tlib=`echo "$TCLLIB" | sed -E -e 's/-l//' -e 's/^ +//' -e 's/ +$//'`
+  for a in i386 ppc x86_64 ppc64
+  do
+    # add only if in MACOSX_ARCHS
+    echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
+echo "configure:12133: checking for Tcl_Init in -l$tlib" >&5
+ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 12139 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+      if test -n "`echo "$MACOSX_ARCHS" | grep $a`" ; then
+        MACOSX_ARCHS_TCLTK="$MACOSX_ARCHS_TCLTK -arch $a"
+      fi
+else
+  echo "$ac_t""no" 1>&6
+fi
+  done
+fi
 cat >> confdefs.h <<\EOF
 #define HAVE_TCLTK 1
 EOF
@@ -12042,7 +12195,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12046: checking whether to use ODBC" >&5
+echo "configure:12199: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12061,7 +12214,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12065: checking for location of ODBC includes" >&5
+echo "configure:12218: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12087,15 +12240,15 @@
 do
-echo "configure:12091: checking for $ac_hdr" >&5
+echo "configure:12244: checking for $ac_hdr" >&5
-#line 12094 "configure"
+#line 12247 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12129,7 +12282,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12133: checking for location of ODBC library" >&5
+echo "configure:12286: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12154,13 +12307,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12158: checking for SQLConnect in -lodbc" >&5
+echo "configure:12311: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12164 "configure"
+#line 12317 "configure"
@@ -12171,7 +12324,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12196,13 +12349,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12200: checking for SQLConnect in -liodbc" >&5
+echo "configure:12353: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12206 "configure"
+#line 12359 "configure"
@@ -12213,7 +12366,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12238,11 +12391,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12242: checking for ODBC library" >&5
+echo "configure:12395: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12246 "configure"
+#line 12399 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12250,7 +12403,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12299,7 +12452,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12303: checking whether to use FFTW" >&5
+echo "configure:12456: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12318,7 +12471,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12322: checking for location of FFTW includes" >&5
+echo "configure:12475: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12344,15 +12497,15 @@
 do
-echo "configure:12348: checking for $ac_hdr" >&5
+echo "configure:12501: checking for $ac_hdr" >&5
-#line 12351 "configure"
+#line 12504 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12356: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12380,15 +12533,15 @@
 do
-echo "configure:12384: checking for $ac_hdr" >&5
+echo "configure:12537: checking for $ac_hdr" >&5
-#line 12387 "configure"
+#line 12540 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12416,15 +12569,15 @@
 do
-echo "configure:12420: checking for $ac_hdr" >&5
+echo "configure:12573: checking for $ac_hdr" >&5
-#line 12423 "configure"
+#line 12576 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12470,7 +12623,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12474: checking for location of FFTW library" >&5
+echo "configure:12627: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12495,13 +12648,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12499: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12652: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12505 "configure"
+#line 12658 "configure"
@@ -12512,7 +12665,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12537,13 +12690,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12541: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12694: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12547 "configure"
+#line 12700 "configure"
@@ -12554,7 +12707,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12579,13 +12732,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12583: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12736: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12589 "configure"
+#line 12742 "configure"
@@ -12596,7 +12749,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12653,7 +12806,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12657: checking whether to use BLAS" >&5
+echo "configure:12810: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12674,7 +12827,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12678: checking for location of BLAS includes" >&5
+echo "configure:12831: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12694,7 +12847,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12698: checking for location of BLAS library" >&5
+echo "configure:12851: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12720,15 +12873,15 @@
 do
-echo "configure:12724: checking for $ac_hdr" >&5
+echo "configure:12877: checking for $ac_hdr" >&5
-#line 12727 "configure"
+#line 12880 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12763,13 +12916,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12767: checking for dnrm2_ in -lblas" >&5
+echo "configure:12920: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12773 "configure"
+#line 12926 "configure"
@@ -12780,7 +12933,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12799,13 +12952,13 @@
-echo "configure:12803: checking for dnrm2_ in -lblas" >&5
+echo "configure:12956: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12809 "configure"
+#line 12962 "configure"
@@ -12816,7 +12969,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12860,13 +13013,13 @@
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12864: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13017: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12870 "configure"
+#line 13023 "configure"
@@ -12877,7 +13030,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12892,13 +13045,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12896: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13049: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12902 "configure"
+#line 13055 "configure"
@@ -12909,7 +13062,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12924,13 +13077,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12928: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13081: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12934 "configure"
+#line 13087 "configure"
@@ -12941,7 +13094,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12980,22 +13133,23 @@
 fi
 # BLAS in Apple vecLib framework? (Mac OS-X)
-if test -n "$MACOSX_APP"; then
+#  not dependent on APP build
+#if test -n "$MACOSX_APP"; then
 if test $blas_ok = no; then
 	vlib_flags="-framework vecLib"
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12990: checking for sgemm in $vlib_flags" >&5
+echo "configure:13144: checking for sgemm in $vlib_flags" >&5
-#line 12992 "configure"
+#line 13146 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13008,18 +13162,18 @@
 	echo "$ac_t""$blas_ok" 1>&6
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13017: checking for sgemm_ in -lblas" >&5
+echo "configure:13171: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13023 "configure"
+#line 13177 "configure"
@@ -13030,7 +13184,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13045,13 +13199,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13049: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13203: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13055 "configure"
+#line 13209 "configure"
@@ -13062,7 +13216,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13077,13 +13231,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13081: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13235: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13087 "configure"
+#line 13241 "configure"
@@ -13094,7 +13248,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13128,13 +13282,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13132: checking for acosp in -lsunmath" >&5
+echo "configure:13286: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13138 "configure"
+#line 13292 "configure"
@@ -13145,7 +13299,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13160,13 +13314,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13164: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13318: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13170 "configure"
+#line 13324 "configure"
@@ -13177,7 +13331,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13207,13 +13361,13 @@
 # Generic BLAS library
-echo "configure:13211: checking for sgemm_ in -lblas" >&5
+echo "configure:13365: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13217 "configure"
+#line 13371 "configure"
@@ -13224,7 +13378,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13263,7 +13417,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13267: checking whether to use LAPACK" >&5
+echo "configure:13421: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13288,7 +13442,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13292: checking for location of LAPACK includes" >&5
+echo "configure:13446: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13308,7 +13462,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13312: checking for location of LAPACK library" >&5
+echo "configure:13466: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13334,15 +13488,15 @@
 do
-echo "configure:13338: checking for $ac_hdr" >&5
+echo "configure:13492: checking for $ac_hdr" >&5
-#line 13341 "configure"
+#line 13495 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13374,10 +13528,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13378: checking for dsegv_" >&5
+echo "configure:13532: checking for dsegv_" >&5
-#line 13381 "configure"
+#line 13535 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13400,7 +13554,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13427,13 +13581,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13431: checking for desgv_ in -llapack" >&5
+echo "configure:13585: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13437 "configure"
+#line 13591 "configure"
@@ -13444,7 +13598,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13476,13 +13630,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13480: checking for dgesv_ in -llapack" >&5
+echo "configure:13634: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13486 "configure"
+#line 13640 "configure"
@@ -13493,7 +13647,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13512,13 +13666,13 @@
-echo "configure:13516: checking for dgesv_ in -llapack" >&5
+echo "configure:13670: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13522 "configure"
+#line 13676 "configure"
@@ -13529,7 +13683,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13585,7 +13739,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13589: checking whether to use Cairo" >&5
+echo "configure:13743: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13611,7 +13765,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13615: checking for location of cairo includes" >&5
+echo "configure:13769: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13637,15 +13791,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13641: checking for $ac_hdr" >&5
+echo "configure:13795: checking for $ac_hdr" >&5
-#line 13644 "configure"
+#line 13798 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13681,7 +13835,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13685: checking for location of cairo library" >&5
+echo "configure:13839: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13701,7 +13855,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13705: checking for cairo linking flags" >&5
+echo "configure:13859: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13717,10 +13871,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13721: checking for cairo_create" >&5
+echo "configure:13875: checking for cairo_create" >&5
-#line 13724 "configure"
+#line 13878 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13743,7 +13897,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13777,10 +13931,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13781: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13935: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13784 "configure"
+#line 13938 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13803,7 +13957,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13836,10 +13990,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13840: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13994: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13843 "configure"
+#line 13997 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -13862,7 +14016,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13904,7 +14058,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13908: checking whether to use FreeType" >&5
+echo "configure:14062: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13923,7 +14077,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13927: checking for location of FreeType includes" >&5
+echo "configure:14081: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13949,15 +14103,15 @@
 do
-echo "configure:13953: checking for $ac_hdr" >&5
+echo "configure:14107: checking for $ac_hdr" >&5
-#line 13956 "configure"
+#line 14110 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13961: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13991,7 +14145,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13995: checking for location of FreeType library" >&5
+echo "configure:14149: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14016,13 +14170,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14020: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14174: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14026 "configure"
+#line 14180 "configure"
@@ -14033,7 +14187,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14074,7 +14228,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14078: checking whether to use NLS" >&5
+echo "configure:14232: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14094,10 +14248,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14098: checking for gettext" >&5
+echo "configure:14252: checking for gettext" >&5
-#line 14101 "configure"
+#line 14255 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -14120,7 +14274,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14138,13 +14292,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14142: checking for gettext in -lintl" >&5
+echo "configure:14296: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14148 "configure"
+#line 14302 "configure"
@@ -14155,7 +14309,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14190,7 +14344,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14194: checking whether to use C++" >&5
+echo "configure:14348: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14206,7 +14360,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14210: checking for $ac_word" >&5
+echo "configure:14364: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14235,7 +14389,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14239: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14393: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14246,12 +14400,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14250 "configure"
+#line 14404 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14277,19 +14431,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14281: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14435: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14286: checking whether we are using GNU C++" >&5
+echo "configure:14440: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14307,7 +14461,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14311: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14465: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14348,7 +14502,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14352: checking whether to use openDWG" >&5
+echo "configure:14506: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14368,7 +14522,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14372: checking for location of openDGW includes" >&5
+echo "configure:14526: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14394,15 +14548,15 @@
 do
-echo "configure:14398: checking for $ac_hdr" >&5
+echo "configure:14552: checking for $ac_hdr" >&5
-#line 14401 "configure"
+#line 14555 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14406: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14436,7 +14590,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14440: checking for location of openDWG library" >&5
+echo "configure:14594: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14477,7 +14631,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14481: checking whether to use POSIX threads" >&5
+echo "configure:14635: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14497,7 +14651,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14501: checking for location of POSIX threads includes" >&5
+echo "configure:14655: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14523,15 +14677,15 @@
 do
-echo "configure:14527: checking for $ac_hdr" >&5
+echo "configure:14681: checking for $ac_hdr" >&5
-#line 14530 "configure"
+#line 14684 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14565,7 +14719,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14569: checking for location of POSIX threads library" >&5
+echo "configure:14723: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14590,10 +14744,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14594: checking for pthread_create" >&5
+echo "configure:14748: checking for pthread_create" >&5
-#line 14597 "configure"
+#line 14751 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14616,7 +14770,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14643,13 +14797,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14647: checking for pthread_create in -lpthread" >&5
+echo "configure:14801: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14653 "configure"
+#line 14807 "configure"
@@ -14660,7 +14814,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14716,7 +14870,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14720: checking for special C compiler options needed for large files" >&5
+echo "configure:14874: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14724,7 +14878,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14728 "configure"
+#line 14882 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14740,7 +14894,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14749,7 +14903,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14753 "configure"
+#line 14907 "configure"
@@ -14765,7 +14919,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14923: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14785,11 +14939,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14789: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14943: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14793 "configure"
+#line 14947 "configure"
@@ -14805,14 +14959,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14809: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14816 "configure"
+#line 14970 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14830,7 +14984,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14834: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14849,11 +15003,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14853: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15007: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14857 "configure"
+#line 15011 "configure"
@@ -14869,14 +15023,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14873: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14880 "configure"
+#line 15034 "configure"
 #define _LARGE_FILES 1
@@ -14894,7 +15048,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14913,25 +15067,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14917: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15071: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14921 "configure"
+#line 15075 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14935 "configure"
+#line 15089 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14940,7 +15094,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14961,10 +15115,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14965: checking if system supports Large Files at all" >&5
+echo "configure:15119: checking if system supports Large Files at all" >&5
-#line 14968 "configure"
+#line 15122 "configure"
 #include <stdio.h>
@@ -14996,7 +15150,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15025,13 +15179,14 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15029: checking whether to use Python" >&5
+echo "configure:15183: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
+MACOSX_ARCHS_PYTHON=
 if test "$with_python" = "no" ; then
@@ -15045,7 +15200,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15049: checking for $ac_word" >&5
+echo "configure:15204: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15087,15 +15242,15 @@
 do
-echo "configure:15091: checking for $ac_hdr" >&5
+echo "configure:15246: checking for $ac_hdr" >&5
-#line 15094 "configure"
+#line 15249 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15130,13 +15285,20 @@
     # With Python library directory
     PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
+    # shouldn't have arch flags in C/LD flags on OSX
+    do
+      PYTHONCFLAGS=`echo "$PYTHONCFLAGS" | sed "s/-arch +$a//g"`
+      PYTHONLDFLAGS=`echo "$PYTHONLDFLAGS" | sed "s/-arch +$a//g"`
+    done
   fi
   # look for the swig program
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15140: checking for $ac_word" >&5
+echo "configure:15302: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15171,6 +15333,21 @@
     { echo "configure: error: *** couldn't find swig" 1>&2; exit 1; }
   fi
+  # check for available OSX archs in Python, assume framework
+  if test -n "$MACOSX_ARCHS" ; then
+    pylib=`"$PY_CONFIG" --prefix`/Python
+    pylibinfo=`file "$pylib"`
+    do
+      if test -n "`echo \"$pylibinfo\" | grep \"library $a\"`" ; then
+          MACOSX_ARCHS_PYTHON="$MACOSX_ARCHS_PYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # Done checking Python
@@ -15179,16 +15356,18 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15186: checking whether to use wxWidgets" >&5
+echo "configure:15364: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
+MACOSX_ARCHS_WXPYTHON=
 if test "$with_wxwidgets" = "no" ; then
@@ -15202,7 +15381,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15206: checking for $ac_word" >&5
+echo "configure:15385: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15250,7 +15429,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15254: checking wxWidgets version" >&5
+echo "configure:15433: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15273,15 +15452,15 @@
 do
-echo "configure:15277: checking for $ac_hdr" >&5
+echo "configure:15456: checking for $ac_hdr" >&5
-#line 15280 "configure"
+#line 15459 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15285: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15314,6 +15493,30 @@
  # With wxWidgets library directory
  WXWIDGETSLIB=`"$WX_CONFIG" --libs`
+ do
+   WXWIDGETSCXXFLAGS=`echo "$WXWIDGETSCXXFLAGS" | sed "s/-arch +$a//g"`
+   WXWIDGETSCPPFLAGS=`echo "$WXWIDGETSCPPFLAGS" | sed "s/-arch +$a//g"`
+   WXWIDGETSLIB=`echo "$WXWIDGETSLIB" | sed "s/-arch +$a//g"`
+ done
+  # check for available OSX archs in wxPython
+    wxver=`"$WX_CONFIG" --version`
+    wxlib=`"$WX_CONFIG" --prefix`/lib/lib`"$WX_CONFIG" --basename`-`echo "$wxver" | cut -d . -f1,2`.dylib
+    wxlibinfo=`file "$wxlib"`
+    do
+      if test -n "`echo \"$wxlibinfo\" | grep \"library $a\"`" ; then
+        if test -n "`echo \"$MACOSX_ARCHS\" | grep $a`" ; then
+          MACOSX_ARCHS_WXPYTHON="$MACOSX_ARCHS_WXPYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
@@ -15322,6 +15525,7 @@
 # Done checking wxWidgets
 USE_TERMIO=
@@ -15444,6 +15648,8 @@
 s%@NAME_VER@%$NAME_VER%g
 s%@LIB_VER@%$LIB_VER%g
 s%@MACOSX_APP@%$MACOSX_APP%g
+s%@MACOSX_ARCHS@%$MACOSX_ARCHS%g
+s%@MACOSX_SDK@%$MACOSX_SDK%g
 s%@INSTDIR@%$INSTDIR%g
 s%@GRASS_LIB_PREFIX@%$GRASS_LIB_PREFIX%g
 s%@GRASS_LIB_SUFFIX@%$GRASS_LIB_SUFFIX%g
@@ -15562,7 +15768,7 @@
 s%@TKINCDIR@%$TKINCDIR%g
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
 s%@TCLTKLIBS@%$TCLTKLIBS%g
-s%@TCLTKAQUA_IS64BIT@%$TCLTKAQUA_IS64BIT%g
+s%@MACOSX_ARCHS_TCLTK@%$MACOSX_ARCHS_TCLTK%g
 s%@ODBCINC@%$ODBCINC%g
 s%@ODBCLIB@%$ODBCLIB%g
 s%@FFTWINC@%$FFTWINC%g
@@ -15596,12 +15802,14 @@
 s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
 s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
 s%@USE_PYTHON@%$USE_PYTHON%g
+s%@MACOSX_ARCHS_PYTHON@%$MACOSX_ARCHS_PYTHON%g
 s%@WX_CONFIG@%$WX_CONFIG%g
 s%@WXVERSION@%$WXVERSION%g
 s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
 s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
 s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
 s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
+s%@MACOSX_ARCHS_WXPYTHON@%$MACOSX_ARCHS_WXPYTHON%g
 s%@USE_TERMIO@%$USE_TERMIO%g
 s%@STRIPFLAG@%$STRIPFLAG%g
 s%@GRASS_HOME@%$GRASS_HOME%g
@@ -15880,6 +16088,12 @@
 echo "  MacOSX application:         `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
+echo "  MacOSX architectures:       ${MACOSX_ARCHS}"
+echo "  MacOSX SDK:                 ${MACOSX_SDK}"
 echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/configure.in	2009-09-06 21:49:28 UTC (rev 39052)
@@ -148,6 +148,55 @@
 AC_MSG_RESULT("$enable_macosx_app")
 AC_SUBST(MACOSX_APP)
+# Check for MacOSX archs
+AC_MSG_CHECKING(for MacOSX architectures)
+MACOSX_ARCHS=
+if test "$with_macosx_archs" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  AC_MSG_RESULT([$MACOSX_ARCHS])
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+AC_SUBST(MACOSX_ARCHS)
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+AC_MSG_CHECKING(for MacOSX SDK)
+MACOSX_SDK=
+if test "$with_macosx_sdk" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
+    MACOSX_SDK="-isysroot $with_macosx_sdk"],[
+    AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+AC_SUBST(MACOSX_SDK)
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -176,6 +225,15 @@
 LOC_ARG_WITH(cxx, C++, no)
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+AC_ARG_WITH(macosx-archs,
+[  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])],, with_macosx_archs="no")
+AC_ARG_WITH(macosx-sdk,
+[  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
 LOC_ARG_WITH(jpeg, JPEG)
 LOC_ARG_WITH(tiff, TIFF)
 LOC_ARG_WITH(png, PNG)
@@ -198,23 +256,30 @@
 LOC_ARG_WITH(pthread, POSIX threads, no)
 AC_ARG_WITH(gdal,
-[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')])
+[  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(python,
-[  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)],, with_python="no")
+[  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)],, with_python="no")
 AC_ARG_WITH(wxwidgets,
-[  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
+[  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)],, with_wxwidgets="no")
 # With includes and libs options
 AC_ARG_WITH(geos,
-[  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config', default: no)],, with_geos="no")
+[  --with-geos[=path/geos-config]
+                          enable GEOS support (geos-config with path,
+                          e.g. '--with-geos=/usr/local/bin/geos-config',
+                          default: no)],, with_geos="no")
 AC_ARG_WITH(includes,
 [  --with-includes=DIRS    site include files are in DIRS])
@@ -1171,22 +1236,14 @@
 TCLLIB=
 TKLIB=
-TCLTKAQUA_IS64BIT=
-    temp_ARCHES=
-    do
-        fi
-    done
 fi
@@ -1207,11 +1264,32 @@
 fi
+  LDFLAGS=
+  CFLAGS=
+  do
+    AC_CHECK_LIB($tlib, Tcl_Init, [
+      fi
+      ],, -arch $a $MACOSX_SDK $TCLTKLIBPATH)
+  done
+fi
 AC_DEFINE(HAVE_TCLTK)
 fi # $USE_TCLTK
@@ -1222,7 +1300,7 @@
 AC_SUBST(TKINCDIR)
 AC_SUBST(TCLTKLIBPATH)
 AC_SUBST(TCLTKLIBS)
-AC_SUBST(TCLTKAQUA_IS64BIT)
+AC_SUBST(MACOSX_ARCHS_TCLTK)
 # Done checking Tcl/Tk
@@ -1342,7 +1420,8 @@
 fi
 	save_LIBS="$LIBS"
@@ -1352,7 +1431,7 @@
 	AC_MSG_RESULT($blas_ok)
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
@@ -1661,6 +1740,7 @@
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
   AC_MSG_RESULT(no)
@@ -1684,6 +1764,13 @@
+    do
+    done
   fi
@@ -1693,6 +1780,21 @@
     AC_MSG_ERROR([*** couldn't find swig])
   fi
+    do
+        fi
+      fi
+    done
+  fi
 AC_SUBST(PYTHONINC)
@@ -1700,6 +1802,7 @@
 AC_SUBST(PYTHONLDFLAGS)
 AC_SUBST(SWIG)
 AC_SUBST(USE_PYTHON)
+AC_SUBST(MACOSX_ARCHS_PYTHON)
@@ -1710,6 +1813,7 @@
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
   AC_MSG_RESULT(no)
@@ -1759,6 +1863,30 @@
+ do
+ done
+    do
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
 AC_SUBST(WXVERSION)
@@ -1766,6 +1894,7 @@
 AC_SUBST(WXWIDGETSCPPFLAGS)
 AC_SUBST(WXWIDGETSLIB)
 AC_SUBST(USE_WXWIDGETS)
+AC_SUBST(MACOSX_ARCHS_WXPYTHON)
@@ -1805,6 +1934,8 @@
 LOC_MSG([  OpenGL platform:             ${OPENGL_TYPE}])
 LOC_MSG()
 LOC_MSG_USE(MacOSX application,MACOSX_APP)
+LOC_MSG([  MacOSX architectures:       ${MACOSX_ARCHS}])
+LOC_MSG([  MacOSX SDK:                 ${MACOSX_SDK}])
 LOC_MSG()
 LOC_MSG_USE(NVIZ,USE_TOGL)
 LOC_MSG()
Modified: grass/trunk/display/d.what.vect/Makefile
--- grass/trunk/display/d.what.vect/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/display/d.what.vect/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -12,12 +12,11 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
-ifeq ($(OPENGL_AQUA),1)
-ifneq ($(TCLTKAQUA_IS64BIT),1)
-CFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(CFLAGS)))
-LDFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(LDFLAGS)))
+# substitute OSX arch flags for tcltk
+ifneq ($(MACOSX_ARCHS),)
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_TCLTK)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_TCLTK)
 endif
-endif
 default: cmd
Modified: grass/trunk/gui/wxpython/nviz/Makefile
--- grass/trunk/gui/wxpython/nviz/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/gui/wxpython/nviz/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -2,12 +2,12 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
-ifeq ($(findstring darwin,$(ARCH)),darwin)
-ifneq ($(WX_ISOSX64BIT),1)
+# substitute OSX arch flags for wxpython
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+CXXFLAGS := $(subst $(MACOSX_ARCHS),,$(CXXFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
 endif
-endif
 LIB_NAME = grass7_wxnviz
Modified: grass/trunk/gui/wxpython/vdigit/Makefile
--- grass/trunk/gui/wxpython/vdigit/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/gui/wxpython/vdigit/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -2,12 +2,12 @@
 endif
-endif
 LIB_NAME = grass7_wxvdigit
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/include/Make/Platform.make.in	2009-09-06 21:49:28 UTC (rev 39052)
@@ -166,8 +166,7 @@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
 USE_TCLTK           = @USE_TCLTK@
-# set from configure when 64bit TclTk Aqua becomes possible on OSX
-TCLTKAQUA_IS64BIT    = @TCLTKAQUA_IS64BIT@
+MACOSX_ARCHS_TCLTK  = @MACOSX_ARCHS_TCLTK@
 #FFTW:
 FFTWINC             = @FFTWINC@
@@ -219,6 +218,7 @@
 PYTHONLDFLAGS       = @PYTHONLDFLAGS@
 SWIG                = @SWIG@
 USE_PYTHON          = @USE_PYTHON@
+MACOSX_ARCHS_PYTHON = @MACOSX_ARCHS_PYTHON@
 #wxWidgets
 WXVERSION           = @WXVERSION@
@@ -226,8 +226,7 @@
 WXWIDGETSCPPFLAGS   = @WXWIDGETSCPPFLAGS@
 WXWIDGETSLIB        = @WXWIDGETSLIB@
 USE_WXWIDGETS       = @USE_WXWIDGETS@
-# set from configure when 64bit wxWidgets becomes possible on OSX
-WX_ISOSX64BIT       =
+MACOSX_ARCHS_WXPYTHON = @MACOSX_ARCHS_WXPYTHON@
 #regex
 REGEXINCPATH        = @REGEXINCPATH@
@@ -252,6 +251,8 @@
 MINGW		    = @MINGW32@
 MACOSX_APP	    = @MACOSX_APP@
+MACOSX_ARCHS    = @MACOSX_ARCHS@
+MACOSX_SDK      = @MACOSX_SDK@
 # Cross compilation
 CROSS_COMPILING = @CROSS_COMPILING@
Modified: grass/trunk/lib/form/Makefile
--- grass/trunk/lib/form/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/lib/form/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -19,12 +19,11 @@
     GTCLTKFORM = $(HTMLLIB) $(FORM) $(FORMPROG)
 endif
 endif
-endif
 default: lib $(GTCLTKFORM)
Modified: grass/trunk/visualization/nviz/src/Makefile
--- grass/trunk/visualization/nviz/src/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/visualization/nviz/src/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -19,10 +19,11 @@
 endif
 OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
 endif
 endif
 SURFLIB = $(OGSFLIB)
Modified: grass/trunk/visualization/xganim/Makefile
--- grass/trunk/visualization/xganim/Makefile	2009-09-06 21:09:43 UTC (rev 39051)
+++ grass/trunk/visualization/xganim/Makefile	2009-09-06 21:49:28 UTC (rev 39052)
@@ -9,12 +9,12 @@
 endif
-endif
 LINK = $(CXX)
