[GRASS-SVN] r39062 - grass/branches/develbranch_6
svn_grass at osgeo.org
Mon Sep 7 08:16:58 EDT 2009
Author: martinl
Date: 2009-09-07 08:16:58 -0400 (Mon, 07 Sep 2009)
New Revision: 39062
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
Do not check Mac-related issues if not requested
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2009-09-07 10:47:01 UTC (rev 39061)
+++ grass/branches/develbranch_6/configure 2009-09-07 12:16:58 UTC (rev 39062)
@@ -1320,49 +1320,50 @@
echo "$ac_t"""$enable_macosx_app"" 1>&6
-# Check for MacOSX archs
-echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1327: checking for MacOSX architectures" >&5
-MACOSX_ARCHS=
-if test "$with_macosx_archs" = "no" ; then
- echo "$ac_t""no" 1>&6
-else
- for a in $with_macosx_archs
- do
- # check if valid arch?
- case "$a" in
- i386|ppc|x86_64|ppc64)
- MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
- esac
- done
- echo "$ac_t""$MACOSX_ARCHS" 1>&6
- LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
- CFLAGS="$CFLAGS $MACOSX_ARCHS"
- CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
-fi
-# Done checking MacOSX archs
-# Check for MacOSX SDK
-echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1356: checking for MacOSX SDK" >&5
-MACOSX_SDK=
-if test "$with_macosx_sdk" = "no" ; then
-else
+if test -n "$MACOSX_APP" ; then
+ # Check for MacOSX archs
+ echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
+echo "configure:1328: checking for MacOSX architectures" >&5
+ MACOSX_ARCHS=
+ if test "$with_macosx_archs" = "no" ; then
+ echo "$ac_t""no" 1>&6
+ else
+ for a in $with_macosx_archs
+ do
+ # check if valid arch?
+ case "$a" in
+ i386|ppc|x86_64|ppc64)
+ MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+ esac
+ done
+ echo "$ac_t""$MACOSX_ARCHS" 1>&6
+ LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+ CFLAGS="$CFLAGS $MACOSX_ARCHS"
+ CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+ fi
+ # Done checking MacOSX archs
+ # Check for MacOSX SDK
+ echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
+echo "configure:1357: checking for MacOSX SDK" >&5
+ MACOSX_SDK=
+ if test "$with_macosx_sdk" = "no" ; then
+ else
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1366: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1367: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1376,25 +1377,23 @@
if eval "test \"`echo '$ac_cv_file_'$ac_safe`\" = yes"; then
echo "$ac_t""yes" 1>&6
- MACOSX_SDK="-isysroot $with_macosx_sdk"
+ MACOSX_SDK="-isysroot $with_macosx_sdk"
else
- { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
+ { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
fi
- LDFLAGS="$LDFLAGS $MACOSX_SDK"
- CFLAGS="$CFLAGS $MACOSX_SDK"
- CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
-fi
+ LDFLAGS="$LDFLAGS $MACOSX_SDK"
+ CFLAGS="$CFLAGS $MACOSX_SDK"
+ CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+ fi
+ # Done checking MacOSX SDK
-# Done checking MacOSX SDK
-# Set INST_DIR
-if test -n "$MACOSX_APP" ; then
+ # Set INST_DIR
INSTDIR='${prefix}'"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"
else
INSTDIR='${prefix}'"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"
@@ -1406,7 +1405,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1410: checking how to build libraries" >&5
+echo "configure:1409: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1449,7 +1448,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1453: checking for $ac_word" >&5
+echo "configure:1452: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1474,7 +1473,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1478: checking how to run the C preprocessor" >&5
+echo "configure:1477: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1487,13 +1486,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
cat > conftest.$ac_ext <<EOF
-#line 1491 "configure"
+#line 1490 "configure"
#include "confdefs.h"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1496: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1504,13 +1503,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1508 "configure"
+#line 1507 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1521,13 +1520,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1525 "configure"
+#line 1524 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1530: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1555,7 +1554,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1559: checking if 64bit support is requested" >&5
+echo "configure:1558: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1575,7 +1574,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1579: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1578: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1599,7 +1598,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1603: checking system version (for dynamic loading)" >&5
+echo "configure:1602: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1625,13 +1624,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1629: checking for dlopen in -ldl" >&5
+echo "configure:1628: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1635 "configure"
+#line 1634 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1642,7 +1641,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1689,7 +1688,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1693: checking for $ac_word" >&5
+echo "configure:1692: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1818,13 +1817,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1822: checking for gettimeofday in -lbsd" >&5
+echo "configure:1821: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1828 "configure"
+#line 1827 "configure"
@@ -1835,7 +1834,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1876,13 +1875,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1880: checking for inet_ntoa in -lbind" >&5
+echo "configure:1879: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1886 "configure"
+#line 1885 "configure"
@@ -1893,7 +1892,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1954,13 +1953,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1958: checking for shl_load in -ldld" >&5
+echo "configure:1957: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1964 "configure"
+#line 1963 "configure"
@@ -1971,7 +1970,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2036,13 +2035,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:2040: checking for shl_load in -ldld" >&5
+echo "configure:2039: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 2046 "configure"
+#line 2045 "configure"
@@ -2053,7 +2052,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2175,15 +2174,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2179: checking for dld.h" >&5
+echo "configure:2178: checking for dld.h" >&5
-#line 2182 "configure"
+#line 2181 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2243,15 +2242,15 @@
else
-echo "configure:2247: checking for dld.h" >&5
+echo "configure:2246: checking for dld.h" >&5
-#line 2250 "configure"
+#line 2249 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2348,9 +2347,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2352: checking for ELF" >&5
+echo "configure:2351: checking for ELF" >&5
-#line 2354 "configure"
+#line 2353 "configure"
#ifdef __ELF__
@@ -2380,15 +2379,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2384: checking for dlfcn.h" >&5
+echo "configure:2383: checking for dlfcn.h" >&5
-#line 2387 "configure"
+#line 2386 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2412,9 +2411,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2416: checking for ELF" >&5
+echo "configure:2415: checking for ELF" >&5
-#line 2418 "configure"
+#line 2417 "configure"
#ifdef __ELF__
@@ -2738,17 +2737,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2742: checking for ld accepts -Bexport flag" >&5
+echo "configure:2741: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2745 "configure"
+#line 2744 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3573,7 +3572,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3577: checking for additional include dirs" >&5
+echo "configure:3576: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3596,7 +3595,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3600: checking for additional library dirs" >&5
+echo "configure:3599: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3630,7 +3629,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3634: checking for a BSD compatible install" >&5
+echo "configure:3633: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3683,7 +3682,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3687: checking for $ac_word" >&5
+echo "configure:3686: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3714,13 +3713,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3718: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3717: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3724 "configure"
+#line 3723 "configure"
@@ -3731,7 +3730,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3756,7 +3755,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3760: checking for $ac_word" >&5
+echo "configure:3759: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3796,7 +3795,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3800: checking for $ac_word" >&5
+echo "configure:3799: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3827,7 +3826,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3831: checking for $ac_word" >&5
+echo "configure:3830: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3865,7 +3864,7 @@
-echo "configure:3869: checking for $ac_word" >&5
+echo "configure:3868: checking for $ac_word" >&5
@@ -3894,7 +3893,7 @@
-echo "configure:3898: checking for $ac_word" >&5
+echo "configure:3897: checking for $ac_word" >&5
@@ -3925,7 +3924,7 @@
-echo "configure:3929: checking for $ac_word" >&5
+echo "configure:3928: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3954,7 +3953,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3958: checking for $ac_word" >&5
+echo "configure:3957: checking for $ac_word" >&5
case "$PERL" in
@@ -3985,10 +3984,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3989: checking for ANSI C header files" >&5
+echo "configure:3988: checking for ANSI C header files" >&5
-#line 3992 "configure"
+#line 3991 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3996,7 +3995,7 @@
#include <float.h>
EOF
-{ (eval echo configure:4000: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3999: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4013,7 +4012,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4017 "configure"
+#line 4016 "configure"
#include <string.h>
EOF
@@ -4031,7 +4030,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4035 "configure"
+#line 4034 "configure"
#include <stdlib.h>
EOF
@@ -4052,7 +4051,7 @@
else
-#line 4056 "configure"
+#line 4055 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4063,7 +4062,7 @@
exit (0); }
EOF
-if { (eval echo configure:4067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -4090,15 +4089,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4094: checking for $ac_hdr" >&5
+echo "configure:4093: checking for $ac_hdr" >&5
-#line 4097 "configure"
+#line 4096 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4102: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4127,15 +4126,15 @@
do
-echo "configure:4131: checking for $ac_hdr" >&5
+echo "configure:4130: checking for $ac_hdr" >&5
-#line 4134 "configure"
+#line 4133 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4164,15 +4163,15 @@
do
-echo "configure:4168: checking for $ac_hdr" >&5
+echo "configure:4167: checking for $ac_hdr" >&5
-#line 4171 "configure"
+#line 4170 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4176: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4175: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4201,15 +4200,15 @@
do
-echo "configure:4205: checking for $ac_hdr" >&5
+echo "configure:4204: checking for $ac_hdr" >&5
-#line 4208 "configure"
+#line 4207 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4238,15 +4237,15 @@
do
-echo "configure:4242: checking for $ac_hdr" >&5
+echo "configure:4241: checking for $ac_hdr" >&5
-#line 4245 "configure"
+#line 4244 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4272,10 +4271,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4276: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4275: checking whether time.h and sys/time.h may both be included" >&5
-#line 4279 "configure"
+#line 4278 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4284,7 +4283,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4288: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4287: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4304,10 +4303,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4308: checking for off_t" >&5
+echo "configure:4307: checking for off_t" >&5
-#line 4311 "configure"
+#line 4310 "configure"
#if STDC_HEADERS
@@ -4334,10 +4333,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4338: checking for uid_t in sys/types.h" >&5
+echo "configure:4337: checking for uid_t in sys/types.h" >&5
-#line 4341 "configure"
+#line 4340 "configure"
EOF
@@ -4365,10 +4364,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4369: checking return type of signal handlers" >&5
+echo "configure:4368: checking return type of signal handlers" >&5
-#line 4372 "configure"
+#line 4371 "configure"
#include <signal.h>
@@ -4385,7 +4384,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4389: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4388: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4403,10 +4402,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4407: checking for Cygwin environment" >&5
+echo "configure:4406: checking for Cygwin environment" >&5
-#line 4410 "configure"
+#line 4409 "configure"
int main() {
@@ -4417,7 +4416,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4420: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4435,10 +4434,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4439: checking for $ac_func" >&5
+echo "configure:4438: checking for $ac_func" >&5
-#line 4442 "configure"
+#line 4441 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4461,7 +4460,7 @@
; return 0; }
EOF
-if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4487,10 +4486,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4491: checking for $ac_func" >&5
+echo "configure:4490: checking for $ac_func" >&5
-#line 4494 "configure"
+#line 4493 "configure"
@@ -4513,7 +4512,7 @@
; return 0; }
EOF
-if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4539,10 +4538,10 @@
for ac_func in drand48
do
-echo "configure:4543: checking for $ac_func" >&5
+echo "configure:4542: checking for $ac_func" >&5
-#line 4546 "configure"
+#line 4545 "configure"
@@ -4565,7 +4564,7 @@
; return 0; }
EOF
-if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4591,10 +4590,10 @@
for ac_func in putenv setenv
do
-echo "configure:4595: checking for $ac_func" >&5
+echo "configure:4594: checking for $ac_func" >&5
-#line 4598 "configure"
+#line 4597 "configure"
@@ -4617,7 +4616,7 @@
; return 0; }
EOF
-if { (eval echo configure:4621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4643,10 +4642,10 @@
for ac_func in nanosleep
do
-echo "configure:4647: checking for $ac_func" >&5
+echo "configure:4646: checking for $ac_func" >&5
-#line 4650 "configure"
+#line 4649 "configure"
@@ -4669,7 +4668,7 @@
; return 0; }
EOF
-if { (eval echo configure:4673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4694,13 +4693,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4698: checking whether setpgrp takes no argument" >&5
+echo "configure:4697: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4704 "configure"
+#line 4703 "configure"
#ifdef HAVE_UNISTD_H
@@ -4720,7 +4719,7 @@
EOF
-if { (eval echo configure:4724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4748,16 +4747,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4752: checking for long long int" >&5
+echo "configure:4751: checking for long long int" >&5
-#line 4754 "configure"
+#line 4753 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4760: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4777,7 +4776,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4781: checking for W11" >&5
+echo "configure:4780: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4805,7 +4804,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4809: checking for X" >&5
+echo "configure:4808: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4865,12 +4864,12 @@
# First, try using that file with no special directory specified.
-#line 4869 "configure"
+#line 4868 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4939,14 +4938,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4943 "configure"
+#line 4942 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -5051,17 +5050,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5055: checking whether -R must be followed by a space" >&5
+echo "configure:5054: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5058 "configure"
+#line 5057 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -5077,14 +5076,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5081 "configure"
+#line 5080 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5116,13 +5115,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5120: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5119: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5126 "configure"
+#line 5125 "configure"
@@ -5133,7 +5132,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5154,13 +5153,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5158: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5157: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5164 "configure"
+#line 5163 "configure"
@@ -5171,7 +5170,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5199,10 +5198,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5203: checking for gethostbyname" >&5
+echo "configure:5202: checking for gethostbyname" >&5
-#line 5206 "configure"
+#line 5205 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5225,7 +5224,7 @@
; return 0; }
EOF
-if { (eval echo configure:5229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5245,13 +5244,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5249: checking for gethostbyname in -lnsl" >&5
+echo "configure:5248: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5255 "configure"
+#line 5254 "configure"
@@ -5262,7 +5261,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5291,10 +5290,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5295: checking for connect" >&5
+echo "configure:5294: checking for connect" >&5
-#line 5298 "configure"
+#line 5297 "configure"
which can conflict with char connect(); below. */
@@ -5317,7 +5316,7 @@
; return 0; }
EOF
-if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5337,13 +5336,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5341: checking for connect in -lsocket" >&5
+echo "configure:5340: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5347 "configure"
+#line 5346 "configure"
@@ -5354,7 +5353,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5377,10 +5376,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5381: checking for remove" >&5
+echo "configure:5380: checking for remove" >&5
-#line 5384 "configure"
+#line 5383 "configure"
which can conflict with char remove(); below. */
@@ -5403,7 +5402,7 @@
; return 0; }
EOF
-if { (eval echo configure:5407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5423,13 +5422,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5427: checking for remove in -lposix" >&5
+echo "configure:5426: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5433 "configure"
+#line 5432 "configure"
@@ -5440,7 +5439,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5463,10 +5462,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5467: checking for shmat" >&5
+echo "configure:5466: checking for shmat" >&5
-#line 5470 "configure"
+#line 5469 "configure"
which can conflict with char shmat(); below. */
@@ -5489,7 +5488,7 @@
; return 0; }
EOF
-if { (eval echo configure:5493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5509,13 +5508,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5513: checking for shmat in -lipc" >&5
+echo "configure:5512: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5519 "configure"
+#line 5518 "configure"
@@ -5526,7 +5525,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5558,13 +5557,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5562: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5561: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5568 "configure"
+#line 5567 "configure"
@@ -5575,7 +5574,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5613,7 +5612,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5617: checking whether to use Curses" >&5
+echo "configure:5616: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5632,15 +5631,15 @@
do
-echo "configure:5636: checking for $ac_hdr" >&5
+echo "configure:5635: checking for $ac_hdr" >&5
-#line 5639 "configure"
+#line 5638 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5671,10 +5670,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5675: checking curses.h WINDOW structure component" >&5
+echo "configure:5674: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5678 "configure"
+#line 5677 "configure"
#include <curses.h>
@@ -5683,7 +5682,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5687: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5686: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5692,7 +5691,7 @@
fi
rm -f conftest*
-#line 5696 "configure"
+#line 5695 "configure"
#include <curses.h>
@@ -5701,7 +5700,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5705: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5704: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5717,13 +5716,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5721: checking for initscr in -lncurses" >&5
+echo "configure:5720: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5727 "configure"
+#line 5726 "configure"
@@ -5734,7 +5733,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5753,13 +5752,13 @@
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5757: checking for initscr in -lcurses" >&5
+echo "configure:5756: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5763 "configure"
+#line 5762 "configure"
@@ -5770,7 +5769,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5799,13 +5798,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5803: checking for keypad in -lncurses" >&5
+echo "configure:5802: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5809 "configure"
+#line 5808 "configure"
@@ -5816,7 +5815,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5838,13 +5837,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5842: checking for keypad in -lcurses" >&5
+echo "configure:5841: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5848 "configure"
+#line 5847 "configure"
@@ -5855,7 +5854,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5885,13 +5884,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5889: checking for gtty in -lcompat" >&5
+echo "configure:5888: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5895 "configure"
+#line 5894 "configure"
@@ -5902,7 +5901,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5921,13 +5920,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5925: checking for gtty in -lbsd-compat" >&5
+echo "configure:5924: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5931 "configure"
+#line 5930 "configure"
@@ -5938,7 +5937,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5957,13 +5956,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5961: checking for gtty in -lbsd" >&5
+echo "configure:5960: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5967 "configure"
+#line 5966 "configure"
@@ -5974,7 +5973,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6008,12 +6007,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6012: checking for library containing cuserid" >&5
+echo "configure:6011: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 6017 "configure"
+#line 6016 "configure"
@@ -6024,7 +6023,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -6035,7 +6034,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 6039 "configure"
+#line 6038 "configure"
@@ -6046,7 +6045,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -6072,10 +6071,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6076: checking for xdrmem_create" >&5
+echo "configure:6075: checking for xdrmem_create" >&5
-#line 6079 "configure"
+#line 6078 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -6098,7 +6097,7 @@
; return 0; }
EOF
-if { (eval echo configure:6102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -6116,13 +6115,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6120: checking for xdrmem_create in -lsun" >&5
+echo "configure:6119: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 6126 "configure"
+#line 6125 "configure"
@@ -6133,7 +6132,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6152,13 +6151,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6156: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6155: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 6162 "configure"
+#line 6161 "configure"
@@ -6169,7 +6168,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6188,13 +6187,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6192: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6191: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6198 "configure"
+#line 6197 "configure"
@@ -6205,7 +6204,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6224,13 +6223,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6228: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6227: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6234 "configure"
+#line 6233 "configure"
@@ -6241,7 +6240,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6275,10 +6274,10 @@
for ac_func in asprintf
do
-echo "configure:6279: checking for $ac_func" >&5
+echo "configure:6278: checking for $ac_func" >&5
-#line 6282 "configure"
+#line 6281 "configure"
@@ -6301,7 +6300,7 @@
; return 0; }
EOF
-if { (eval echo configure:6305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6328,10 +6327,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6332: checking for atan" >&5
+echo "configure:6331: checking for atan" >&5
-#line 6335 "configure"
+#line 6334 "configure"
which can conflict with char atan(); below. */
@@ -6354,7 +6353,7 @@
; return 0; }
EOF
-if { (eval echo configure:6358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6372,13 +6371,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6376: checking for atan in -lm" >&5
+echo "configure:6375: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6382 "configure"
+#line 6381 "configure"
@@ -6389,7 +6388,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6416,10 +6415,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6420: checking for dlsym" >&5
+echo "configure:6419: checking for dlsym" >&5
-#line 6423 "configure"
+#line 6422 "configure"
which can conflict with char dlsym(); below. */
@@ -6442,7 +6441,7 @@
; return 0; }
EOF
-if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6460,13 +6459,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6464: checking for dlsym in -ldl" >&5
+echo "configure:6463: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6470 "configure"
+#line 6469 "configure"
@@ -6477,7 +6476,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6504,10 +6503,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6508: checking for iconv" >&5
+echo "configure:6507: checking for iconv" >&5
-#line 6511 "configure"
+#line 6510 "configure"
which can conflict with char iconv(); below. */
@@ -6530,7 +6529,7 @@
; return 0; }
EOF
-if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6548,13 +6547,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6552: checking for iconv in -liconv" >&5
+echo "configure:6551: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6558 "configure"
+#line 6557 "configure"
@@ -6565,7 +6564,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6584,13 +6583,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6588: checking for iconv in -lgiconv" >&5
+echo "configure:6587: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6594 "configure"
+#line 6593 "configure"
@@ -6601,7 +6600,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6620,10 +6619,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6624: checking for libiconv" >&5
+echo "configure:6623: checking for libiconv" >&5
-#line 6627 "configure"
+#line 6626 "configure"
which can conflict with char libiconv(); below. */
@@ -6646,7 +6645,7 @@
; return 0; }
EOF
-if { (eval echo configure:6650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6664,13 +6663,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6668: checking for libiconv in -liconv" >&5
+echo "configure:6667: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6674 "configure"
+#line 6673 "configure"
@@ -6681,7 +6680,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6700,13 +6699,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6704: checking for libiconv in -lgiconv" >&5
+echo "configure:6703: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6710 "configure"
+#line 6709 "configure"
@@ -6717,7 +6716,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6754,10 +6753,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6758: checking for socket" >&5
+echo "configure:6757: checking for socket" >&5
-#line 6761 "configure"
+#line 6760 "configure"
which can conflict with char socket(); below. */
@@ -6780,7 +6779,7 @@
; return 0; }
EOF
-if { (eval echo configure:6784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6798,13 +6797,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6802: checking for socket in -lsocket" >&5
+echo "configure:6801: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6808 "configure"
+#line 6807 "configure"
@@ -6815,7 +6814,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6863,7 +6862,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6867: checking for location of zlib includes" >&5
+echo "configure:6866: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6889,15 +6888,15 @@
do
-echo "configure:6893: checking for $ac_hdr" >&5
+echo "configure:6892: checking for $ac_hdr" >&5
-#line 6896 "configure"
+#line 6895 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6931,7 +6930,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6935: checking for location of zlib library" >&5
+echo "configure:6934: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6956,13 +6955,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6960: checking for deflate in -lz" >&5
+echo "configure:6959: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6966 "configure"
+#line 6965 "configure"
@@ -6973,7 +6972,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7021,7 +7020,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7025: checking for location of External PROJ.4 includes" >&5
+echo "configure:7024: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7047,15 +7046,15 @@
do
-echo "configure:7051: checking for $ac_hdr" >&5
+echo "configure:7050: checking for $ac_hdr" >&5
-#line 7054 "configure"
+#line 7053 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7058: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7092,7 +7091,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7096: checking External PROJ.4 version" >&5
+echo "configure:7095: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7100,7 +7099,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 7104 "configure"
+#line 7103 "configure"
#include <stdio.h>
@@ -7112,7 +7111,7 @@
EOF
-if { (eval echo configure:7116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -7137,7 +7136,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7141: checking for location of External PROJ.4 library" >&5
+echo "configure:7140: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7162,13 +7161,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7166: checking for pj_get_def in -lproj" >&5
+echo "configure:7165: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 7172 "configure"
+#line 7171 "configure"
@@ -7179,7 +7178,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7213,7 +7212,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7217: checking for location of External PROJ.4 data files" >&5
+echo "configure:7216: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7237,14 +7236,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7241: checking for epsg" >&5
+echo "configure:7240: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7248: checking for $PROJSHARE/epsg" >&5
+echo "configure:7247: checking for $PROJSHARE/epsg" >&5
@@ -7276,7 +7275,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:7280: checking for $ac_word" >&5
+echo "configure:7279: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7316,7 +7315,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7320: checking whether to use regex" >&5
+echo "configure:7319: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -7336,7 +7335,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7340: checking for location of regex includes" >&5
+echo "configure:7339: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7362,15 +7361,15 @@
do
-echo "configure:7366: checking for $ac_hdr" >&5
+echo "configure:7365: checking for $ac_hdr" >&5
-#line 7369 "configure"
+#line 7368 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7373: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7404,7 +7403,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7408: checking for location of regex library" >&5
+echo "configure:7407: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7429,10 +7428,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7433: checking for regcomp" >&5
+echo "configure:7432: checking for regcomp" >&5
-#line 7436 "configure"
+#line 7435 "configure"
which can conflict with char regcomp(); below. */
@@ -7455,7 +7454,7 @@
; return 0; }
EOF
-if { (eval echo configure:7459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7482,13 +7481,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7486: checking for regcomp in -lregex" >&5
+echo "configure:7485: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7492 "configure"
+#line 7491 "configure"
@@ -7499,7 +7498,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7549,7 +7548,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7553: checking whether to use Readline" >&5
+echo "configure:7552: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7570,7 +7569,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7574: checking for location of Readline includes" >&5
+echo "configure:7573: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7596,15 +7595,15 @@
do
-echo "configure:7600: checking for $ac_hdr" >&5
+echo "configure:7599: checking for $ac_hdr" >&5
-#line 7603 "configure"
+#line 7602 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7640,15 +7639,15 @@
do
-echo "configure:7644: checking for $ac_hdr" >&5
+echo "configure:7643: checking for $ac_hdr" >&5
-#line 7647 "configure"
+#line 7646 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7682,7 +7681,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7686: checking for location of Readline library" >&5
+echo "configure:7685: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7707,13 +7706,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7711: checking for readline in -lreadline" >&5
+echo "configure:7710: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7717 "configure"
+#line 7716 "configure"
#include "confdefs.h"
@@ -7724,7 +7723,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7759,13 +7758,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7763: checking for add_history in -lhistory" >&5
+echo "configure:7762: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7769 "configure"
+#line 7768 "configure"
@@ -7776,7 +7775,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7819,7 +7818,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7823: checking whether to use JPEG" >&5
+echo "configure:7822: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7839,7 +7838,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7843: checking for location of JPEG includes" >&5
+echo "configure:7842: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7865,15 +7864,15 @@
do
-echo "configure:7869: checking for $ac_hdr" >&5
+echo "configure:7868: checking for $ac_hdr" >&5
-#line 7872 "configure"
+#line 7871 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7907,7 +7906,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7911: checking for location of JPEG library" >&5
+echo "configure:7910: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7934,13 +7933,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7938: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7937: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ljpeg $LIBS"
-#line 7944 "configure"
+#line 7943 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7951,7 +7950,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7970,13 +7969,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:7974: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7973: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7980 "configure"
+#line 7979 "configure"
@@ -7987,7 +7986,7 @@
; return 0; }
EOF
-if { (eval echo configure:7991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8036,7 +8035,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8040: checking whether to use GDAL" >&5
+echo "configure:8039: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -8054,7 +8053,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8058: checking for $ac_word" >&5
+echo "configure:8057: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -8109,14 +8108,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8113 "configure"
+#line 8112 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -8125,14 +8124,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8129 "configure"
+#line 8128 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:8136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -8164,7 +8163,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8168: checking whether to use GEOS" >&5
+echo "configure:8167: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -8181,7 +8180,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:8185: checking for $ac_word" >&5
+echo "configure:8184: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -8229,15 +8228,15 @@
do
-echo "configure:8233: checking for $ac_hdr" >&5
+echo "configure:8232: checking for $ac_hdr" >&5
-#line 8236 "configure"
+#line 8235 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8272,13 +8271,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8276: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8275: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 8282 "configure"
+#line 8281 "configure"
@@ -8289,7 +8288,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8332,7 +8331,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8336: checking whether to use TIFF" >&5
+echo "configure:8335: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8352,7 +8351,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8356: checking for location of TIFF includes" >&5
+echo "configure:8355: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8378,15 +8377,15 @@
do
-echo "configure:8382: checking for $ac_hdr" >&5
+echo "configure:8381: checking for $ac_hdr" >&5
-#line 8385 "configure"
+#line 8384 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8420,7 +8419,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8424: checking for location of TIFF library" >&5
+echo "configure:8423: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8451,13 +8450,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8455: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8454: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8461 "configure"
+#line 8460 "configure"
@@ -8468,7 +8467,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8487,13 +8486,13 @@
-echo "configure:8491: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8490: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8497 "configure"
+#line 8496 "configure"
@@ -8504,7 +8503,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8523,13 +8522,13 @@
-echo "configure:8527: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8526: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8533 "configure"
+#line 8532 "configure"
@@ -8540,7 +8539,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8559,13 +8558,13 @@
-echo "configure:8563: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8562: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8569 "configure"
+#line 8568 "configure"
@@ -8576,7 +8575,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8595,13 +8594,13 @@
-echo "configure:8599: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8598: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8605 "configure"
+#line 8604 "configure"
@@ -8612,7 +8611,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8631,13 +8630,13 @@
-echo "configure:8635: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8634: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8641 "configure"
+#line 8640 "configure"
@@ -8648,7 +8647,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8667,13 +8666,13 @@
-echo "configure:8671: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8670: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8677 "configure"
+#line 8676 "configure"
@@ -8684,7 +8683,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8703,13 +8702,13 @@
-echo "configure:8707: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8706: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8713 "configure"
+#line 8712 "configure"
@@ -8720,7 +8719,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8818,7 +8817,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8822: checking whether to use PNG" >&5
+echo "configure:8821: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8837,7 +8836,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8841: checking for location of PNG includes" >&5
+echo "configure:8840: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8863,15 +8862,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8867: checking for $ac_hdr" >&5
+echo "configure:8866: checking for $ac_hdr" >&5
-#line 8870 "configure"
+#line 8869 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8875: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8905,7 +8904,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8909: checking for location of PNG library" >&5
+echo "configure:8908: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8930,13 +8929,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8934: checking for png_read_image in -lpng" >&5
+echo "configure:8933: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8940 "configure"
+#line 8939 "configure"
@@ -8947,7 +8946,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8989,7 +8988,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8993: checking whether to use PostgreSQL" >&5
+echo "configure:8992: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9016,7 +9015,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9020: checking for location of PostgreSQL includes" >&5
+echo "configure:9019: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9042,15 +9041,15 @@
do
-echo "configure:9046: checking for $ac_hdr" >&5
+echo "configure:9045: checking for $ac_hdr" >&5
-#line 9049 "configure"
+#line 9048 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9088,7 +9087,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9092: checking for location of PostgreSQL library" >&5
+echo "configure:9091: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9117,13 +9116,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9121: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9120: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9127 "configure"
+#line 9126 "configure"
@@ -9134,7 +9133,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9153,13 +9152,13 @@
-echo "configure:9157: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9156: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9163 "configure"
+#line 9162 "configure"
@@ -9170,7 +9169,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9189,13 +9188,13 @@
-echo "configure:9193: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9192: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9199 "configure"
+#line 9198 "configure"
@@ -9206,7 +9205,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9225,13 +9224,13 @@
-echo "configure:9229: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9228: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9235 "configure"
+#line 9234 "configure"
@@ -9242,7 +9241,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9299,13 +9298,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9303: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9302: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9309 "configure"
+#line 9308 "configure"
@@ -9316,7 +9315,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9338,13 +9337,13 @@
-echo "configure:9342: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9341: checking for PQcmdTuples in -lpq" >&5
-#line 9348 "configure"
+#line 9347 "configure"
@@ -9355,7 +9354,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9398,7 +9397,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9402: checking whether to use MySQL" >&5
+echo "configure:9401: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9418,7 +9417,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9422: checking for location of MySQL includes" >&5
+echo "configure:9421: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9444,15 +9443,15 @@
do
-echo "configure:9448: checking for $ac_hdr" >&5
+echo "configure:9447: checking for $ac_hdr" >&5
-#line 9451 "configure"
+#line 9450 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9489,7 +9488,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9493: checking for location of MySQL library" >&5
+echo "configure:9492: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9520,13 +9519,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9524: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9523: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9530 "configure"
+#line 9529 "configure"
@@ -9537,7 +9536,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9556,13 +9555,13 @@
-echo "configure:9560: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9559: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9566 "configure"
+#line 9565 "configure"
@@ -9573,7 +9572,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9592,13 +9591,13 @@
-echo "configure:9596: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9595: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9602 "configure"
+#line 9601 "configure"
@@ -9609,7 +9608,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9628,13 +9627,13 @@
-echo "configure:9632: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9631: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9638 "configure"
+#line 9637 "configure"
@@ -9645,7 +9644,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9664,13 +9663,13 @@
-echo "configure:9668: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9667: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9674 "configure"
+#line 9673 "configure"
@@ -9681,7 +9680,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9700,13 +9699,13 @@
-echo "configure:9704: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9703: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9710 "configure"
+#line 9709 "configure"
@@ -9717,7 +9716,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9736,13 +9735,13 @@
-echo "configure:9740: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9739: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9746 "configure"
+#line 9745 "configure"
@@ -9753,7 +9752,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9772,13 +9771,13 @@
-echo "configure:9776: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9775: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9782 "configure"
+#line 9781 "configure"
@@ -9789,7 +9788,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9879,7 +9878,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9883: checking for $ac_word" >&5
+echo "configure:9882: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9920,10 +9919,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9924: checking for mysql_server_init" >&5
+echo "configure:9923: checking for mysql_server_init" >&5
-#line 9927 "configure"
+#line 9926 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9946,7 +9945,7 @@
; return 0; }
EOF
-if { (eval echo configure:9950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9984,7 +9983,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9988: checking whether to use SQLite" >&5
+echo "configure:9987: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10004,7 +10003,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10008: checking for location of SQLite includes" >&5
+echo "configure:10007: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10030,15 +10029,15 @@
do
-echo "configure:10034: checking for $ac_hdr" >&5
+echo "configure:10033: checking for $ac_hdr" >&5
-#line 10037 "configure"
+#line 10036 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10041: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10081,7 +10080,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10085: checking for location of SQLite library" >&5
+echo "configure:10084: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10108,13 +10107,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10112: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10111: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10118 "configure"
+#line 10117 "configure"
@@ -10125,7 +10124,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10144,13 +10143,13 @@
-echo "configure:10148: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10147: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10154 "configure"
+#line 10153 "configure"
@@ -10161,7 +10160,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10214,7 +10213,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10218: checking whether to use FFMPEG" >&5
+echo "configure:10217: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10234,7 +10233,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10238: checking for location of FFMPEG includes" >&5
+echo "configure:10237: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10260,15 +10259,15 @@
do
-echo "configure:10264: checking for $ac_hdr" >&5
+echo "configure:10263: checking for $ac_hdr" >&5
-#line 10267 "configure"
+#line 10266 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10271: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10304,15 +10303,15 @@
do
-echo "configure:10308: checking for $ac_hdr" >&5
+echo "configure:10307: checking for $ac_hdr" >&5
-#line 10311 "configure"
+#line 10310 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10348,15 +10347,15 @@
do
-echo "configure:10352: checking for $ac_hdr" >&5
+echo "configure:10351: checking for $ac_hdr" >&5
-#line 10355 "configure"
+#line 10354 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10359: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10399,7 +10398,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10403: checking for location of FFMPEG library" >&5
+echo "configure:10402: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10426,13 +10425,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10430: checking for av_free in -lavutil" >&5
+echo "configure:10429: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10436 "configure"
+#line 10435 "configure"
@@ -10443,7 +10442,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10462,13 +10461,13 @@
-echo "configure:10466: checking for av_free in -lavutil" >&5
+echo "configure:10465: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10472 "configure"
+#line 10471 "configure"
@@ -10479,7 +10478,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10524,13 +10523,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10528: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10527: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10534 "configure"
+#line 10533 "configure"
@@ -10541,7 +10540,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10560,13 +10559,13 @@
-echo "configure:10564: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10563: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10570 "configure"
+#line 10569 "configure"
@@ -10577,7 +10576,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10622,13 +10621,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10626: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10625: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10632 "configure"
+#line 10631 "configure"
@@ -10639,7 +10638,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10658,13 +10657,13 @@
-echo "configure:10662: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10661: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10668 "configure"
+#line 10667 "configure"
@@ -10675,7 +10674,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10734,7 +10733,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10738: checking whether to use OpenGL" >&5
+echo "configure:10737: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10768,7 +10767,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10772: checking for location of OpenGL includes" >&5
+echo "configure:10771: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10794,15 +10793,15 @@
do
-echo "configure:10798: checking for $ac_hdr" >&5
+echo "configure:10797: checking for $ac_hdr" >&5
-#line 10801 "configure"
+#line 10800 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10836,7 +10835,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10840: checking for location of OpenGL library" >&5
+echo "configure:10839: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10865,13 +10864,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10869: checking for glBegin in -lGL" >&5
+echo "configure:10868: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10875 "configure"
+#line 10874 "configure"
@@ -10882,7 +10881,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10901,13 +10900,13 @@
-echo "configure:10905: checking for glBegin in -lGL" >&5
+echo "configure:10904: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10911 "configure"
+#line 10910 "configure"
@@ -10918,7 +10917,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10937,13 +10936,13 @@
-echo "configure:10941: checking for glBegin in -lGL" >&5
+echo "configure:10940: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10947 "configure"
+#line 10946 "configure"
@@ -10954,7 +10953,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10973,13 +10972,13 @@
-echo "configure:10977: checking for glBegin in -lGL" >&5
+echo "configure:10976: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10983 "configure"
+#line 10982 "configure"
@@ -10990,7 +10989,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11052,13 +11051,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11056: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11055: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11062 "configure"
+#line 11061 "configure"
@@ -11069,7 +11068,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11088,13 +11087,13 @@
-echo "configure:11092: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11091: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11098 "configure"
+#line 11097 "configure"
@@ -11105,7 +11104,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11149,10 +11148,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11153: checking for glXCreatePbuffer" >&5
+echo "configure:11152: checking for glXCreatePbuffer" >&5
-#line 11156 "configure"
+#line 11155 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11175,7 +11174,7 @@
; return 0; }
EOF
-if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11197,10 +11196,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11201: checking for glXCreateGLXPixmap" >&5
+echo "configure:11200: checking for glXCreateGLXPixmap" >&5
-#line 11204 "configure"
+#line 11203 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11223,7 +11222,7 @@
; return 0; }
EOF
-if { (eval echo configure:11227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11262,7 +11261,7 @@
-echo "configure:11266: checking for location of OpenGL includes" >&5
+echo "configure:11265: checking for location of OpenGL includes" >&5
@@ -11288,15 +11287,15 @@
do
-echo "configure:11292: checking for $ac_hdr" >&5
+echo "configure:11291: checking for $ac_hdr" >&5
-#line 11295 "configure"
+#line 11294 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11331,10 +11330,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11335: checking for glBegin" >&5
+echo "configure:11334: checking for glBegin" >&5
-#line 11338 "configure"
+#line 11337 "configure"
which can conflict with char glBegin(); below. */
@@ -11357,7 +11356,7 @@
; return 0; }
EOF
-if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11372,10 +11371,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11376: checking for gluBeginCurve" >&5
+echo "configure:11375: checking for gluBeginCurve" >&5
-#line 11379 "configure"
+#line 11378 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11398,7 +11397,7 @@
; return 0; }
EOF
-if { (eval echo configure:11402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11442,7 +11441,7 @@
-echo "configure:11446: checking for location of OpenGL includes" >&5
+echo "configure:11445: checking for location of OpenGL includes" >&5
@@ -11468,15 +11467,15 @@
do
-echo "configure:11472: checking for $ac_hdr" >&5
+echo "configure:11471: checking for $ac_hdr" >&5
-#line 11475 "configure"
+#line 11474 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11510,7 +11509,7 @@
-echo "configure:11514: checking for location of OpenGL library" >&5
+echo "configure:11513: checking for location of OpenGL library" >&5
@@ -11535,18 +11534,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11539: checking for OpenGL library" >&5
+echo "configure:11538: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11543 "configure"
+#line 11542 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11570,18 +11569,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11574: checking for GLU library" >&5
+echo "configure:11573: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11578 "configure"
+#line 11577 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11630,7 +11629,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11634: checking whether to use Tcl/Tk" >&5
+echo "configure:11633: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11650,7 +11649,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11654: checking for location of Tcl/Tk includes" >&5
+echo "configure:11653: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11676,15 +11675,15 @@
do
-echo "configure:11680: checking for $ac_hdr" >&5
+echo "configure:11679: checking for $ac_hdr" >&5
-#line 11683 "configure"
+#line 11682 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11721,15 +11720,15 @@
do
-echo "configure:11725: checking for $ac_hdr" >&5
+echo "configure:11724: checking for $ac_hdr" >&5
-#line 11728 "configure"
+#line 11727 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11762,7 +11761,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11766: checking Tcl version" >&5
+echo "configure:11765: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11770,7 +11769,7 @@
else
-#line 11774 "configure"
+#line 11773 "configure"
#include <stdio.h>
@@ -11782,7 +11781,7 @@
EOF
-if { (eval echo configure:11786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11800,7 +11799,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11804: checking Tk version" >&5
+echo "configure:11803: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11808,7 +11807,7 @@
else
-#line 11812 "configure"
+#line 11811 "configure"
#include <stdio.h>
@@ -11820,7 +11819,7 @@
EOF
-if { (eval echo configure:11824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11851,7 +11850,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11855: checking for location of Tcl/Tk library" >&5
+echo "configure:11854: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11891,13 +11890,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11895: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11894: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11901 "configure"
+#line 11900 "configure"
@@ -11908,7 +11907,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11927,13 +11926,13 @@
-echo "configure:11931: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11930: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11937 "configure"
+#line 11936 "configure"
@@ -11944,7 +11943,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11971,13 +11970,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11975: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11974: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11981 "configure"
+#line 11980 "configure"
@@ -11988,7 +11987,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12007,13 +12006,13 @@
-echo "configure:12011: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12010: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12017 "configure"
+#line 12016 "configure"
@@ -12024,7 +12023,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12051,13 +12050,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12055: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12054: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12061 "configure"
+#line 12060 "configure"
@@ -12068,7 +12067,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12087,13 +12086,13 @@
-echo "configure:12091: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12090: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12097 "configure"
+#line 12096 "configure"
@@ -12104,7 +12103,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12182,13 +12181,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12186: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12185: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12192 "configure"
+#line 12191 "configure"
@@ -12199,7 +12198,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12218,13 +12217,13 @@
-echo "configure:12222: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12221: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12228 "configure"
+#line 12227 "configure"
@@ -12235,7 +12234,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12262,13 +12261,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12266: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12265: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12272 "configure"
+#line 12271 "configure"
@@ -12279,7 +12278,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12298,13 +12297,13 @@
-echo "configure:12302: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12301: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12308 "configure"
+#line 12307 "configure"
@@ -12315,7 +12314,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12342,13 +12341,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12346: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12345: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12352 "configure"
+#line 12351 "configure"
@@ -12359,7 +12358,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12378,13 +12377,13 @@
-echo "configure:12382: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12381: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12388 "configure"
+#line 12387 "configure"
@@ -12395,7 +12394,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12485,13 +12484,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12489: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12488: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12495 "configure"
+#line 12494 "configure"
@@ -12502,7 +12501,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12551,7 +12550,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12555: checking whether to use ODBC" >&5
+echo "configure:12554: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12570,7 +12569,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12574: checking for location of ODBC includes" >&5
+echo "configure:12573: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12596,15 +12595,15 @@
do
-echo "configure:12600: checking for $ac_hdr" >&5
+echo "configure:12599: checking for $ac_hdr" >&5
-#line 12603 "configure"
+#line 12602 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12638,7 +12637,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12642: checking for location of ODBC library" >&5
+echo "configure:12641: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12663,13 +12662,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12667: checking for SQLConnect in -lodbc" >&5
+echo "configure:12666: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12673 "configure"
+#line 12672 "configure"
@@ -12680,7 +12679,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12705,13 +12704,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12709: checking for SQLConnect in -liodbc" >&5
+echo "configure:12708: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12715 "configure"
+#line 12714 "configure"
@@ -12722,7 +12721,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12747,11 +12746,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12751: checking for ODBC library" >&5
+echo "configure:12750: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12755 "configure"
+#line 12754 "configure"
#include <windows.h>
#include <sql.h>
@@ -12759,7 +12758,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12808,7 +12807,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12812: checking whether to use FFTW" >&5
+echo "configure:12811: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12827,7 +12826,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12831: checking for location of FFTW includes" >&5
+echo "configure:12830: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12853,15 +12852,15 @@
do
-echo "configure:12857: checking for $ac_hdr" >&5
+echo "configure:12856: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12860 "configure"
+#line 12859 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12864: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12889,15 +12888,15 @@
do
-echo "configure:12893: checking for $ac_hdr" >&5
+echo "configure:12892: checking for $ac_hdr" >&5
-#line 12896 "configure"
+#line 12895 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12925,15 +12924,15 @@
do
-echo "configure:12929: checking for $ac_hdr" >&5
+echo "configure:12928: checking for $ac_hdr" >&5
-#line 12932 "configure"
+#line 12931 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12936: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12979,7 +12978,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12983: checking for location of FFTW library" >&5
+echo "configure:12982: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13004,13 +13003,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13008: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13007: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13014 "configure"
+#line 13013 "configure"
@@ -13021,7 +13020,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13046,13 +13045,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13050: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13049: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13056 "configure"
+#line 13055 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13063,7 +13062,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13088,13 +13087,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13092: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13091: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13098 "configure"
+#line 13097 "configure"
@@ -13105,7 +13104,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13162,7 +13161,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13166: checking whether to use BLAS" >&5
+echo "configure:13165: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13183,7 +13182,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13187: checking for location of BLAS includes" >&5
+echo "configure:13186: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13203,7 +13202,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13207: checking for location of BLAS library" >&5
+echo "configure:13206: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13229,15 +13228,15 @@
do
-echo "configure:13233: checking for $ac_hdr" >&5
+echo "configure:13232: checking for $ac_hdr" >&5
-#line 13236 "configure"
+#line 13235 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13272,13 +13271,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13276: checking for dnrm2_ in -lblas" >&5
+echo "configure:13275: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13282 "configure"
+#line 13281 "configure"
@@ -13289,7 +13288,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13308,13 +13307,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13312: checking for dnrm2_ in -lblas" >&5
+echo "configure:13311: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13318 "configure"
+#line 13317 "configure"
@@ -13325,7 +13324,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13369,13 +13368,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13373: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13372: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13379 "configure"
+#line 13378 "configure"
@@ -13386,7 +13385,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13401,13 +13400,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13405: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13404: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13411 "configure"
+#line 13410 "configure"
@@ -13418,7 +13417,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13433,13 +13432,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13437: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13436: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13443 "configure"
+#line 13442 "configure"
@@ -13450,7 +13449,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13496,16 +13495,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13500: checking for sgemm in $vlib_flags" >&5
+echo "configure:13499: checking for sgemm in $vlib_flags" >&5
-#line 13502 "configure"
+#line 13501 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13523,13 +13522,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13527: checking for sgemm_ in -lblas" >&5
+echo "configure:13526: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13533 "configure"
+#line 13532 "configure"
@@ -13540,7 +13539,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13555,13 +13554,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13559: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13558: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13565 "configure"
+#line 13564 "configure"
@@ -13572,7 +13571,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13587,13 +13586,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13591: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13590: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13597 "configure"
+#line 13596 "configure"
@@ -13604,7 +13603,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13638,13 +13637,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13642: checking for acosp in -lsunmath" >&5
+echo "configure:13641: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13648 "configure"
+#line 13647 "configure"
@@ -13655,7 +13654,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13670,13 +13669,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13674: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13673: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13680 "configure"
+#line 13679 "configure"
@@ -13687,7 +13686,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13717,13 +13716,13 @@
# Generic BLAS library
-echo "configure:13721: checking for sgemm_ in -lblas" >&5
+echo "configure:13720: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13727 "configure"
+#line 13726 "configure"
@@ -13734,7 +13733,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13773,7 +13772,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13777: checking whether to use LAPACK" >&5
+echo "configure:13776: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13798,7 +13797,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13802: checking for location of LAPACK includes" >&5
+echo "configure:13801: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13818,7 +13817,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13822: checking for location of LAPACK library" >&5
+echo "configure:13821: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13844,15 +13843,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13848: checking for $ac_hdr" >&5
+echo "configure:13847: checking for $ac_hdr" >&5
-#line 13851 "configure"
+#line 13850 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13884,10 +13883,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13888: checking for dsegv_" >&5
+echo "configure:13887: checking for dsegv_" >&5
-#line 13891 "configure"
+#line 13890 "configure"
which can conflict with char dsegv_(); below. */
@@ -13910,7 +13909,7 @@
; return 0; }
EOF
-if { (eval echo configure:13914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13937,13 +13936,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13941: checking for desgv_ in -llapack" >&5
+echo "configure:13940: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13947 "configure"
+#line 13946 "configure"
@@ -13954,7 +13953,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13986,13 +13985,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13990: checking for dgesv_ in -llapack" >&5
+echo "configure:13989: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13996 "configure"
+#line 13995 "configure"
@@ -14003,7 +14002,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14022,13 +14021,13 @@
-echo "configure:14026: checking for dgesv_ in -llapack" >&5
+echo "configure:14025: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14032 "configure"
+#line 14031 "configure"
@@ -14039,7 +14038,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14095,7 +14094,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14099: checking whether to use Motif" >&5
+echo "configure:14098: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14114,7 +14113,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14118: checking for location of Motif includes" >&5
+echo "configure:14117: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14140,15 +14139,15 @@
do
-echo "configure:14144: checking for $ac_hdr" >&5
+echo "configure:14143: checking for $ac_hdr" >&5
-#line 14147 "configure"
+#line 14146 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14182,7 +14181,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14186: checking for location of Motif library" >&5
+echo "configure:14185: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14207,13 +14206,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14211: checking for XmStringCreate in -lXm" >&5
+echo "configure:14210: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14217 "configure"
+#line 14216 "configure"
@@ -14224,7 +14223,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14265,7 +14264,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14269: checking whether to use Cairo" >&5
+echo "configure:14268: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14291,7 +14290,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14295: checking for location of cairo includes" >&5
+echo "configure:14294: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14317,15 +14316,15 @@
do
-echo "configure:14321: checking for $ac_hdr" >&5
+echo "configure:14320: checking for $ac_hdr" >&5
-#line 14324 "configure"
+#line 14323 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14361,7 +14360,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14365: checking for location of cairo library" >&5
+echo "configure:14364: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14381,7 +14380,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14385: checking for cairo linking flags" >&5
+echo "configure:14384: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14397,10 +14396,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14401: checking for cairo_create" >&5
+echo "configure:14400: checking for cairo_create" >&5
-#line 14404 "configure"
+#line 14403 "configure"
which can conflict with char cairo_create(); below. */
@@ -14423,7 +14422,7 @@
; return 0; }
EOF
-if { (eval echo configure:14427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14457,10 +14456,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14461: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14460: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14464 "configure"
+#line 14463 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14483,7 +14482,7 @@
; return 0; }
EOF
-if { (eval echo configure:14487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14525,7 +14524,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14529: checking whether to use GLw" >&5
+echo "configure:14528: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14544,7 +14543,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14548: checking for location of GLw includes" >&5
+echo "configure:14547: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14570,15 +14569,15 @@
do
-echo "configure:14574: checking for $ac_hdr" >&5
+echo "configure:14573: checking for $ac_hdr" >&5
-#line 14577 "configure"
+#line 14576 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14606,15 +14605,15 @@
do
-echo "configure:14610: checking for $ac_hdr" >&5
+echo "configure:14609: checking for $ac_hdr" >&5
-#line 14613 "configure"
+#line 14612 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14654,7 +14653,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14658: checking for location of GLw library" >&5
+echo "configure:14657: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14679,13 +14678,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14683: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14682: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14689 "configure"
+#line 14688 "configure"
@@ -14696,7 +14695,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14721,13 +14720,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14725: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14724: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14731 "configure"
+#line 14730 "configure"
@@ -14738,7 +14737,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14763,13 +14762,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14767: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14766: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14773 "configure"
+#line 14772 "configure"
@@ -14780,7 +14779,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14805,13 +14804,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14809: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14808: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14815 "configure"
+#line 14814 "configure"
@@ -14822,7 +14821,7 @@
; return 0; }
EOF
-if { (eval echo configure:14826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14847,13 +14846,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14851: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14850: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14857 "configure"
+#line 14856 "configure"
@@ -14864,7 +14863,7 @@
; return 0; }
EOF
-if { (eval echo configure:14868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14889,13 +14888,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14893: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14892: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14899 "configure"
+#line 14898 "configure"
@@ -14906,7 +14905,7 @@
; return 0; }
EOF
-if { (eval echo configure:14910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14933,13 +14932,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14937: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14936: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14943 "configure"
+#line 14942 "configure"
@@ -14950,7 +14949,7 @@
; return 0; }
EOF
-if { (eval echo configure:14954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14969,13 +14968,13 @@
-echo "configure:14973: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14972: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14979 "configure"
+#line 14978 "configure"
@@ -14986,7 +14985,7 @@
; return 0; }
EOF
-if { (eval echo configure:14990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15013,13 +15012,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15017: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15016: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15023 "configure"
+#line 15022 "configure"
@@ -15030,7 +15029,7 @@
; return 0; }
EOF
-if { (eval echo configure:15034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15049,13 +15048,13 @@
-echo "configure:15053: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15052: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15059 "configure"
+#line 15058 "configure"
@@ -15066,7 +15065,7 @@
; return 0; }
EOF
-if { (eval echo configure:15070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15179,7 +15178,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15183: checking whether to use FreeType" >&5
+echo "configure:15182: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15198,7 +15197,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15202: checking for location of FreeType includes" >&5
+echo "configure:15201: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15224,15 +15223,15 @@
do
-echo "configure:15228: checking for $ac_hdr" >&5
+echo "configure:15227: checking for $ac_hdr" >&5
-#line 15231 "configure"
+#line 15230 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15266,7 +15265,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15270: checking for location of FreeType library" >&5
+echo "configure:15269: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15291,13 +15290,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15295: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15294: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15301 "configure"
+#line 15300 "configure"
@@ -15308,7 +15307,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15349,7 +15348,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15353: checking whether to use NLS" >&5
+echo "configure:15352: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15369,10 +15368,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15373: checking for gettext" >&5
+echo "configure:15372: checking for gettext" >&5
-#line 15376 "configure"
+#line 15375 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15395,7 +15394,7 @@
; return 0; }
EOF
-if { (eval echo configure:15399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15413,13 +15412,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15417: checking for gettext in -lintl" >&5
+echo "configure:15416: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15423 "configure"
+#line 15422 "configure"
@@ -15430,7 +15429,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15465,7 +15464,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15469: checking whether to use C++" >&5
+echo "configure:15468: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15481,7 +15480,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15485: checking for $ac_word" >&5
+echo "configure:15484: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15510,7 +15509,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15514: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15513: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15521,12 +15520,12 @@
cat > conftest.$ac_ext << EOF
-#line 15525 "configure"
+#line 15524 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15552,19 +15551,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15556: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15555: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15561: checking whether we are using GNU C++" >&5
+echo "configure:15560: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15568: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15567: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15582,7 +15581,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15586: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15585: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15623,7 +15622,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15627: checking whether to use openDWG" >&5
+echo "configure:15626: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15643,7 +15642,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15647: checking for location of openDGW includes" >&5
+echo "configure:15646: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15669,15 +15668,15 @@
do
-echo "configure:15673: checking for $ac_hdr" >&5
+echo "configure:15672: checking for $ac_hdr" >&5
-#line 15676 "configure"
+#line 15675 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15711,7 +15710,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15715: checking for location of openDWG library" >&5
+echo "configure:15714: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15758,7 +15757,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15762: checking for special C compiler options needed for large files" >&5
+echo "configure:15761: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15766,7 +15765,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15770 "configure"
+#line 15769 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15782,7 +15781,7 @@
; return 0; }
EOF
-if { (eval echo configure:15786: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15785: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15791,7 +15790,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15795 "configure"
+#line 15794 "configure"
@@ -15807,7 +15806,7 @@
; return 0; }
EOF
-if { (eval echo configure:15811: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15810: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15827,11 +15826,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15831: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15830: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15835 "configure"
+#line 15834 "configure"
@@ -15847,14 +15846,14 @@
; return 0; }
EOF
-if { (eval echo configure:15851: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15850: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15858 "configure"
+#line 15857 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15872,7 +15871,7 @@
; return 0; }
EOF
-if { (eval echo configure:15876: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15891,11 +15890,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15895: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15894: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15899 "configure"
+#line 15898 "configure"
@@ -15911,14 +15910,14 @@
; return 0; }
EOF
-if { (eval echo configure:15915: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15914: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15922 "configure"
+#line 15921 "configure"
#define _LARGE_FILES 1
@@ -15936,7 +15935,7 @@
; return 0; }
EOF
-if { (eval echo configure:15940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15939: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15955,25 +15954,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15959: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15958: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15963 "configure"
+#line 15962 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15977 "configure"
+#line 15976 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15982,7 +15981,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15985: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16003,10 +16002,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16007: checking if system supports Large Files at all" >&5
+echo "configure:16006: checking if system supports Large Files at all" >&5
-#line 16010 "configure"
+#line 16009 "configure"
#include <stdio.h>
@@ -16038,7 +16037,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16067,7 +16066,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16071: checking whether to use Python" >&5
+echo "configure:16070: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16088,7 +16087,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16092: checking for $ac_word" >&5
+echo "configure:16091: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16130,15 +16129,15 @@
do
-echo "configure:16134: checking for $ac_hdr" >&5
+echo "configure:16133: checking for $ac_hdr" >&5
-#line 16137 "configure"
+#line 16136 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16186,7 +16185,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:16190: checking for $ac_word" >&5
+echo "configure:16189: checking for $ac_word" >&5
case "$SWIG" in
@@ -16248,7 +16247,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16252: checking whether to use wxWidgets" >&5
+echo "configure:16251: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16269,7 +16268,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16273: checking for $ac_word" >&5
+echo "configure:16272: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16317,7 +16316,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16321: checking wxWidgets version" >&5
+echo "configure:16320: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16340,15 +16339,15 @@
do
-echo "configure:16344: checking for $ac_hdr" >&5
+echo "configure:16343: checking for $ac_hdr" >&5
-#line 16347 "configure"
+#line 16346 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16351: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2009-09-07 10:47:01 UTC (rev 39061)
+++ grass/branches/develbranch_6/configure.in 2009-09-07 12:16:58 UTC (rev 39062)
@@ -148,58 +148,57 @@
AC_MSG_RESULT("$enable_macosx_app")
AC_SUBST(MACOSX_APP)
-# Check for MacOSX archs
-AC_MSG_CHECKING(for MacOSX architectures)
-MACOSX_ARCHS=
-if test "$with_macosx_archs" = "no" ; then
- AC_MSG_RESULT(no)
-else
- for a in $with_macosx_archs
- do
- # check if valid arch?
- case "$a" in
- i386|ppc|x86_64|ppc64)
- MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
- esac
- done
- AC_MSG_RESULT([$MACOSX_ARCHS])
- LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
- CFLAGS="$CFLAGS $MACOSX_ARCHS"
- CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
-fi
-AC_SUBST(MACOSX_ARCHS)
-# Done checking MacOSX archs
-# Check for MacOSX SDK
-AC_MSG_CHECKING(for MacOSX SDK)
-MACOSX_SDK=
-if test "$with_macosx_sdk" = "no" ; then
- AC_MSG_RESULT(no)
-else
- AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
- MACOSX_SDK="-isysroot $with_macosx_sdk"],[
- AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
- LDFLAGS="$LDFLAGS $MACOSX_SDK"
- CFLAGS="$CFLAGS $MACOSX_SDK"
- CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
-fi
-AC_SUBST(MACOSX_SDK)
-# Done checking MacOSX SDK
-# Set INST_DIR
if test -n "$MACOSX_APP" ; then
+ # Check for MacOSX archs
+ AC_MSG_CHECKING(for MacOSX architectures)
+ MACOSX_ARCHS=
+ if test "$with_macosx_archs" = "no" ; then
+ AC_MSG_RESULT(no)
+ else
+ for a in $with_macosx_archs
+ do
+ # check if valid arch?
+ case "$a" in
+ i386|ppc|x86_64|ppc64)
+ MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+ esac
+ done
+ AC_MSG_RESULT([$MACOSX_ARCHS])
+ LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+ CFLAGS="$CFLAGS $MACOSX_ARCHS"
+ CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+ fi
+ AC_SUBST(MACOSX_ARCHS)
+ # Done checking MacOSX archs
+ # Check for MacOSX SDK
+ AC_MSG_CHECKING(for MacOSX SDK)
+ MACOSX_SDK=
+ if test "$with_macosx_sdk" = "no" ; then
+ AC_MSG_RESULT(no)
+ else
+ AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
+ MACOSX_SDK="-isysroot $with_macosx_sdk"],[
+ AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
+ LDFLAGS="$LDFLAGS $MACOSX_SDK"
+ CFLAGS="$CFLAGS $MACOSX_SDK"
+ CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+ fi
+ AC_SUBST(MACOSX_SDK)
+ # Done checking MacOSX SDK
+ # Set INST_DIR
INSTDIR='${prefix}'"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"
else
INSTDIR='${prefix}'"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"
