[GRASS-SVN] r39063 - grass/trunk
Mon Sep 7 08:22:57 EDT 2009
Author: martinl
Date: 2009-09-07 08:22:57 -0400 (Mon, 07 Sep 2009)
New Revision: 39063
   grass/trunk/configure
   grass/trunk/configure.in
Do not check Mac-related issues if not requested
   (merge r39062 from devbr6)
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-09-07 12:16:58 UTC (rev 39062)
+++ grass/trunk/configure	2009-09-07 12:22:57 UTC (rev 39063)
@@ -1315,49 +1315,50 @@
 echo "$ac_t"""$enable_macosx_app"" 1>&6
-# Check for MacOSX archs
-echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1322: checking for MacOSX architectures" >&5
-MACOSX_ARCHS=
-if test "$with_macosx_archs" = "no" ; then
-  echo "$ac_t""no" 1>&6
-else
-  for a in $with_macosx_archs
-  do
-    # check if valid arch?
-    case "$a" in
-      i386|ppc|x86_64|ppc64)
-        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
-    esac
-  done
-  echo "$ac_t""$MACOSX_ARCHS" 1>&6
-  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
-  CFLAGS="$CFLAGS $MACOSX_ARCHS"
-  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
-fi
-# Done checking MacOSX archs
-# Check for MacOSX SDK
-echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1351: checking for MacOSX SDK" >&5
-MACOSX_SDK=
-if test "$with_macosx_sdk" = "no" ; then
-else
+if test -n "$MACOSX_APP" ; then
+    # Check for MacOSX archs
+    echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
+echo "configure:1323: checking for MacOSX architectures" >&5
+    MACOSX_ARCHS=
+    if test "$with_macosx_archs" = "no" ; then
+      echo "$ac_t""no" 1>&6
+    else
+      for a in $with_macosx_archs
+      do
+        # check if valid arch?
+        case "$a" in
+          i386|ppc|x86_64|ppc64)
+            MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+        esac
+      done
+      echo "$ac_t""$MACOSX_ARCHS" 1>&6
+      LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+      CFLAGS="$CFLAGS $MACOSX_ARCHS"
+      CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+    fi
+    # Done checking MacOSX archs
+    # Check for MacOSX SDK
+    echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
+echo "configure:1352: checking for MacOSX SDK" >&5
+    MACOSX_SDK=
+    if test "$with_macosx_sdk" = "no" ; then
+    else
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1361: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1362: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1371,25 +1372,23 @@
 if eval "test \"`echo '$ac_cv_file_'$ac_safe`\" = yes"; then
   echo "$ac_t""yes" 1>&6
-    MACOSX_SDK="-isysroot $with_macosx_sdk"
+        MACOSX_SDK="-isysroot $with_macosx_sdk"
 else
-    { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
+        { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
 fi
-  LDFLAGS="$LDFLAGS $MACOSX_SDK"
-  CFLAGS="$CFLAGS $MACOSX_SDK"
-  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
-fi
+      LDFLAGS="$LDFLAGS $MACOSX_SDK"
+      CFLAGS="$CFLAGS $MACOSX_SDK"
+      CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+    fi
+    # Done checking MacOSX SDK
-# Done checking MacOSX SDK
-# Set INST_DIR
-if test -n "$MACOSX_APP" ; then
+    # Set INST_DIR
     INSTDIR='${prefix}'"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"
 else
     INSTDIR='${prefix}'"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"
@@ -1401,7 +1400,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1405: checking how to build libraries" >&5
+echo "configure:1404: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1444,7 +1443,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1448: checking for $ac_word" >&5
+echo "configure:1447: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1469,7 +1468,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1473: checking how to run the C preprocessor" >&5
+echo "configure:1472: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1482,13 +1481,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
   cat > conftest.$ac_ext <<EOF
-#line 1486 "configure"
+#line 1485 "configure"
 #include "confdefs.h"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1499,13 +1498,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1503 "configure"
+#line 1502 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1516,13 +1515,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1520 "configure"
+#line 1519 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1525: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1550,7 +1549,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1554: checking if 64bit support is requested" >&5
+echo "configure:1553: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1570,7 +1569,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1574: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1573: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1594,7 +1593,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1598: checking system version (for dynamic loading)" >&5
+echo "configure:1597: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1620,13 +1619,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1624: checking for dlopen in -ldl" >&5
+echo "configure:1623: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1630 "configure"
+#line 1629 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1637,7 +1636,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1684,7 +1683,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1688: checking for $ac_word" >&5
+echo "configure:1687: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1813,13 +1812,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1817: checking for gettimeofday in -lbsd" >&5
+echo "configure:1816: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1823 "configure"
+#line 1822 "configure"
@@ -1830,7 +1829,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1871,13 +1870,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1875: checking for inet_ntoa in -lbind" >&5
+echo "configure:1874: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1881 "configure"
+#line 1880 "configure"
@@ -1888,7 +1887,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1949,13 +1948,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1953: checking for shl_load in -ldld" >&5
+echo "configure:1952: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1959 "configure"
+#line 1958 "configure"
@@ -1966,7 +1965,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2031,13 +2030,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2035: checking for shl_load in -ldld" >&5
+echo "configure:2034: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2041 "configure"
+#line 2040 "configure"
@@ -2048,7 +2047,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2170,15 +2169,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2174: checking for dld.h" >&5
+echo "configure:2173: checking for dld.h" >&5
-#line 2177 "configure"
+#line 2176 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2238,15 +2237,15 @@
 	    else
-echo "configure:2242: checking for dld.h" >&5
+echo "configure:2241: checking for dld.h" >&5
-#line 2245 "configure"
+#line 2244 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2343,9 +2342,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2347: checking for ELF" >&5
+echo "configure:2346: checking for ELF" >&5
-#line 2349 "configure"
+#line 2348 "configure"
 #ifdef __ELF__
@@ -2375,15 +2374,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2379: checking for dlfcn.h" >&5
+echo "configure:2378: checking for dlfcn.h" >&5
-#line 2382 "configure"
+#line 2381 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2386: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2407,9 +2406,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2411: checking for ELF" >&5
+echo "configure:2410: checking for ELF" >&5
-#line 2413 "configure"
+#line 2412 "configure"
 #ifdef __ELF__
@@ -2733,17 +2732,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2737: checking for ld accepts -Bexport flag" >&5
+echo "configure:2736: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2740 "configure"
+#line 2739 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3539,7 +3538,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3543: checking for additional include dirs" >&5
+echo "configure:3542: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3562,7 +3561,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3566: checking for additional library dirs" >&5
+echo "configure:3565: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3596,7 +3595,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3600: checking for a BSD compatible install" >&5
+echo "configure:3599: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3649,7 +3648,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3653: checking for $ac_word" >&5
+echo "configure:3652: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3680,13 +3679,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3684: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3683: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3690 "configure"
+#line 3689 "configure"
@@ -3697,7 +3696,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3722,7 +3721,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3726: checking for $ac_word" >&5
+echo "configure:3725: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3762,7 +3761,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3766: checking for $ac_word" >&5
+echo "configure:3765: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3793,7 +3792,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3797: checking for $ac_word" >&5
+echo "configure:3796: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3831,7 +3830,7 @@
-echo "configure:3835: checking for $ac_word" >&5
+echo "configure:3834: checking for $ac_word" >&5
@@ -3860,7 +3859,7 @@
-echo "configure:3864: checking for $ac_word" >&5
+echo "configure:3863: checking for $ac_word" >&5
@@ -3891,7 +3890,7 @@
-echo "configure:3895: checking for $ac_word" >&5
+echo "configure:3894: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3920,7 +3919,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3924: checking for $ac_word" >&5
+echo "configure:3923: checking for $ac_word" >&5
 case "$PERL" in
@@ -3951,10 +3950,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3955: checking for ANSI C header files" >&5
+echo "configure:3954: checking for ANSI C header files" >&5
-#line 3958 "configure"
+#line 3957 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3962,7 +3961,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3979,7 +3978,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3983 "configure"
+#line 3982 "configure"
 #include <string.h>
 EOF
@@ -3997,7 +3996,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4001 "configure"
+#line 4000 "configure"
 #include <stdlib.h>
 EOF
@@ -4018,7 +4017,7 @@
 else
-#line 4022 "configure"
+#line 4021 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4029,7 +4028,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4056,15 +4055,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4060: checking for $ac_hdr" >&5
+echo "configure:4059: checking for $ac_hdr" >&5
-#line 4063 "configure"
+#line 4062 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4093,15 +4092,15 @@
 do
-echo "configure:4097: checking for $ac_hdr" >&5
+echo "configure:4096: checking for $ac_hdr" >&5
-#line 4100 "configure"
+#line 4099 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4130,15 +4129,15 @@
 do
-echo "configure:4134: checking for $ac_hdr" >&5
+echo "configure:4133: checking for $ac_hdr" >&5
-#line 4137 "configure"
+#line 4136 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4167,15 +4166,15 @@
 do
-echo "configure:4171: checking for $ac_hdr" >&5
+echo "configure:4170: checking for $ac_hdr" >&5
-#line 4174 "configure"
+#line 4173 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4179: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4204,15 +4203,15 @@
 do
-echo "configure:4208: checking for $ac_hdr" >&5
+echo "configure:4207: checking for $ac_hdr" >&5
-#line 4211 "configure"
+#line 4210 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4238,10 +4237,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4242: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4241: checking whether time.h and sys/time.h may both be included" >&5
-#line 4245 "configure"
+#line 4244 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4250,7 +4249,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4254: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4253: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4270,10 +4269,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4274: checking for off_t" >&5
+echo "configure:4273: checking for off_t" >&5
-#line 4277 "configure"
+#line 4276 "configure"
 #if STDC_HEADERS
@@ -4300,10 +4299,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4304: checking for uid_t in sys/types.h" >&5
+echo "configure:4303: checking for uid_t in sys/types.h" >&5
-#line 4307 "configure"
+#line 4306 "configure"
 EOF
@@ -4331,10 +4330,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4335: checking return type of signal handlers" >&5
+echo "configure:4334: checking return type of signal handlers" >&5
-#line 4338 "configure"
+#line 4337 "configure"
 #include <signal.h>
@@ -4351,7 +4350,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4354: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4369,10 +4368,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4373: checking for Cygwin environment" >&5
+echo "configure:4372: checking for Cygwin environment" >&5
-#line 4376 "configure"
+#line 4375 "configure"
 int main() {
@@ -4383,7 +4382,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4387: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4386: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4401,10 +4400,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4405: checking for $ac_func" >&5
+echo "configure:4404: checking for $ac_func" >&5
-#line 4408 "configure"
+#line 4407 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4427,7 +4426,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4453,10 +4452,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4457: checking for $ac_func" >&5
+echo "configure:4456: checking for $ac_func" >&5
-#line 4460 "configure"
+#line 4459 "configure"
@@ -4479,7 +4478,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4505,10 +4504,10 @@
 for ac_func in drand48
 do
-echo "configure:4509: checking for $ac_func" >&5
+echo "configure:4508: checking for $ac_func" >&5
-#line 4512 "configure"
+#line 4511 "configure"
@@ -4531,7 +4530,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4557,10 +4556,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4561: checking for $ac_func" >&5
+echo "configure:4560: checking for $ac_func" >&5
-#line 4564 "configure"
+#line 4563 "configure"
@@ -4583,7 +4582,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4609,10 +4608,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4613: checking for $ac_func" >&5
+echo "configure:4612: checking for $ac_func" >&5
-#line 4616 "configure"
+#line 4615 "configure"
@@ -4635,7 +4634,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4660,13 +4659,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4664: checking whether setpgrp takes no argument" >&5
+echo "configure:4663: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4670 "configure"
+#line 4669 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4686,7 +4685,7 @@
 EOF
-if { (eval echo configure:4690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4714,16 +4713,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4718: checking for long long int" >&5
+echo "configure:4717: checking for long long int" >&5
-#line 4720 "configure"
+#line 4719 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4727: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4726: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4743,7 +4742,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4747: checking for W11" >&5
+echo "configure:4746: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4771,7 +4770,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4775: checking for X" >&5
+echo "configure:4774: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4831,12 +4830,12 @@
   # First, try using that file with no special directory specified.
-#line 4835 "configure"
+#line 4834 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4905,14 +4904,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4909 "configure"
+#line 4908 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5017,17 +5016,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5021: checking whether -R must be followed by a space" >&5
+echo "configure:5020: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5024 "configure"
+#line 5023 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5043,14 +5042,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5047 "configure"
+#line 5046 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5082,13 +5081,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5086: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5085: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5092 "configure"
+#line 5091 "configure"
@@ -5099,7 +5098,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5120,13 +5119,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5124: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5123: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5130 "configure"
+#line 5129 "configure"
@@ -5137,7 +5136,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5165,10 +5164,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5169: checking for gethostbyname" >&5
+echo "configure:5168: checking for gethostbyname" >&5
-#line 5172 "configure"
+#line 5171 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5191,7 +5190,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5211,13 +5210,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5215: checking for gethostbyname in -lnsl" >&5
+echo "configure:5214: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5221 "configure"
+#line 5220 "configure"
@@ -5228,7 +5227,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5257,10 +5256,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5261: checking for connect" >&5
+echo "configure:5260: checking for connect" >&5
-#line 5264 "configure"
+#line 5263 "configure"
     which can conflict with char connect(); below.  */
@@ -5283,7 +5282,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5303,13 +5302,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5307: checking for connect in -lsocket" >&5
+echo "configure:5306: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5313 "configure"
+#line 5312 "configure"
@@ -5320,7 +5319,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5343,10 +5342,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5347: checking for remove" >&5
+echo "configure:5346: checking for remove" >&5
-#line 5350 "configure"
+#line 5349 "configure"
     which can conflict with char remove(); below.  */
@@ -5369,7 +5368,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5389,13 +5388,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5393: checking for remove in -lposix" >&5
+echo "configure:5392: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5399 "configure"
+#line 5398 "configure"
@@ -5406,7 +5405,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5429,10 +5428,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5433: checking for shmat" >&5
+echo "configure:5432: checking for shmat" >&5
-#line 5436 "configure"
+#line 5435 "configure"
     which can conflict with char shmat(); below.  */
@@ -5455,7 +5454,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5475,13 +5474,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5479: checking for shmat in -lipc" >&5
+echo "configure:5478: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5485 "configure"
+#line 5484 "configure"
@@ -5492,7 +5491,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5524,13 +5523,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5528: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5527: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5534 "configure"
+#line 5533 "configure"
@@ -5541,7 +5540,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5581,12 +5580,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5585: checking for library containing cuserid" >&5
+echo "configure:5584: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5590 "configure"
+#line 5589 "configure"
@@ -5597,7 +5596,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5608,7 +5607,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5612 "configure"
+#line 5611 "configure"
@@ -5619,7 +5618,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5645,10 +5644,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5649: checking for xdrmem_create" >&5
+echo "configure:5648: checking for xdrmem_create" >&5
-#line 5652 "configure"
+#line 5651 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5671,7 +5670,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5689,13 +5688,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5693: checking for xdrmem_create in -lsun" >&5
+echo "configure:5692: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5699 "configure"
+#line 5698 "configure"
@@ -5706,7 +5705,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5725,13 +5724,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5729: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5728: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5735 "configure"
+#line 5734 "configure"
@@ -5742,7 +5741,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5761,13 +5760,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5765: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5764: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5771 "configure"
+#line 5770 "configure"
@@ -5778,7 +5777,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5797,13 +5796,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5801: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5800: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5807 "configure"
+#line 5806 "configure"
@@ -5814,7 +5813,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5848,10 +5847,10 @@
 for ac_func in asprintf
 do
-echo "configure:5852: checking for $ac_func" >&5
+echo "configure:5851: checking for $ac_func" >&5
-#line 5855 "configure"
+#line 5854 "configure"
@@ -5874,7 +5873,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5901,10 +5900,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5905: checking for atan" >&5
+echo "configure:5904: checking for atan" >&5
-#line 5908 "configure"
+#line 5907 "configure"
     which can conflict with char atan(); below.  */
@@ -5927,7 +5926,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5945,13 +5944,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5949: checking for atan in -lm" >&5
+echo "configure:5948: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5955 "configure"
+#line 5954 "configure"
@@ -5962,7 +5961,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:5966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5989,10 +5988,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5993: checking for dlsym" >&5
+echo "configure:5992: checking for dlsym" >&5
-#line 5996 "configure"
+#line 5995 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6015,7 +6014,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6033,13 +6032,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6037: checking for dlsym in -ldl" >&5
+echo "configure:6036: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6043 "configure"
+#line 6042 "configure"
@@ -6050,7 +6049,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6077,10 +6076,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6081: checking for iconv" >&5
+echo "configure:6080: checking for iconv" >&5
-#line 6084 "configure"
+#line 6083 "configure"
     which can conflict with char iconv(); below.  */
@@ -6103,7 +6102,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6121,13 +6120,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6125: checking for iconv in -liconv" >&5
+echo "configure:6124: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6131 "configure"
+#line 6130 "configure"
@@ -6138,7 +6137,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6157,13 +6156,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6161: checking for iconv in -lgiconv" >&5
+echo "configure:6160: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6167 "configure"
+#line 6166 "configure"
@@ -6174,7 +6173,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6193,10 +6192,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6197: checking for libiconv" >&5
+echo "configure:6196: checking for libiconv" >&5
-#line 6200 "configure"
+#line 6199 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6219,7 +6218,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6237,13 +6236,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6241: checking for libiconv in -liconv" >&5
+echo "configure:6240: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6247 "configure"
+#line 6246 "configure"
@@ -6254,7 +6253,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6273,13 +6272,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6277: checking for libiconv in -lgiconv" >&5
+echo "configure:6276: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6283 "configure"
+#line 6282 "configure"
@@ -6290,7 +6289,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6327,10 +6326,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6331: checking for socket" >&5
+echo "configure:6330: checking for socket" >&5
-#line 6334 "configure"
+#line 6333 "configure"
     which can conflict with char socket(); below.  */
@@ -6353,7 +6352,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6371,13 +6370,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6375: checking for socket in -lsocket" >&5
+echo "configure:6374: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6381 "configure"
+#line 6380 "configure"
@@ -6388,7 +6387,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6436,7 +6435,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6440: checking for location of zlib includes" >&5
+echo "configure:6439: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6462,15 +6461,15 @@
 do
-echo "configure:6466: checking for $ac_hdr" >&5
+echo "configure:6465: checking for $ac_hdr" >&5
-#line 6469 "configure"
+#line 6468 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6474: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6473: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6504,7 +6503,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6508: checking for location of zlib library" >&5
+echo "configure:6507: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6529,13 +6528,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6533: checking for deflate in -lz" >&5
+echo "configure:6532: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6539 "configure"
+#line 6538 "configure"
@@ -6546,7 +6545,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6594,7 +6593,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6598: checking for location of External PROJ.4 includes" >&5
+echo "configure:6597: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6620,15 +6619,15 @@
 do
-echo "configure:6624: checking for $ac_hdr" >&5
+echo "configure:6623: checking for $ac_hdr" >&5
-#line 6627 "configure"
+#line 6626 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6631: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6665,7 +6664,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6669: checking External PROJ.4 version" >&5
+echo "configure:6668: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6673,7 +6672,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 6677 "configure"
+#line 6676 "configure"
 #include <stdio.h>
@@ -6685,7 +6684,7 @@
 EOF
-if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6710,7 +6709,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6714: checking for location of External PROJ.4 library" >&5
+echo "configure:6713: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6735,13 +6734,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6739: checking for pj_get_def in -lproj" >&5
+echo "configure:6738: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6745 "configure"
+#line 6744 "configure"
@@ -6752,7 +6751,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6786,7 +6785,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6790: checking for location of External PROJ.4 data files" >&5
+echo "configure:6789: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6810,14 +6809,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6814: checking for epsg" >&5
+echo "configure:6813: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6821: checking for $PROJSHARE/epsg" >&5
+echo "configure:6820: checking for $PROJSHARE/epsg" >&5
@@ -6849,7 +6848,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:6853: checking for $ac_word" >&5
+echo "configure:6852: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6889,7 +6888,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6893: checking whether to use regex" >&5
+echo "configure:6892: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6909,7 +6908,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6913: checking for location of regex includes" >&5
+echo "configure:6912: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6935,15 +6934,15 @@
 do
-echo "configure:6939: checking for $ac_hdr" >&5
+echo "configure:6938: checking for $ac_hdr" >&5
-#line 6942 "configure"
+#line 6941 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6977,7 +6976,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6981: checking for location of regex library" >&5
+echo "configure:6980: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7002,10 +7001,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7006: checking for regcomp" >&5
+echo "configure:7005: checking for regcomp" >&5
-#line 7009 "configure"
+#line 7008 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7028,7 +7027,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7055,13 +7054,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7059: checking for regcomp in -lregex" >&5
+echo "configure:7058: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7065 "configure"
+#line 7064 "configure"
@@ -7072,7 +7071,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7122,7 +7121,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7126: checking whether to use Readline" >&5
+echo "configure:7125: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7143,7 +7142,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7147: checking for location of Readline includes" >&5
+echo "configure:7146: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7169,15 +7168,15 @@
 do
-echo "configure:7173: checking for $ac_hdr" >&5
+echo "configure:7172: checking for $ac_hdr" >&5
-#line 7176 "configure"
+#line 7175 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7180: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7213,15 +7212,15 @@
 do
-echo "configure:7217: checking for $ac_hdr" >&5
+echo "configure:7216: checking for $ac_hdr" >&5
-#line 7220 "configure"
+#line 7219 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7255,7 +7254,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7259: checking for location of Readline library" >&5
+echo "configure:7258: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7280,13 +7279,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7284: checking for readline in -lreadline" >&5
+echo "configure:7283: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7290 "configure"
+#line 7289 "configure"
@@ -7297,7 +7296,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7332,13 +7331,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7336: checking for add_history in -lhistory" >&5
+echo "configure:7335: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7342 "configure"
+#line 7341 "configure"
@@ -7349,7 +7348,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7392,7 +7391,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7396: checking whether to use JPEG" >&5
+echo "configure:7395: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7412,7 +7411,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7416: checking for location of JPEG includes" >&5
+echo "configure:7415: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7438,15 +7437,15 @@
 do
-echo "configure:7442: checking for $ac_hdr" >&5
+echo "configure:7441: checking for $ac_hdr" >&5
-#line 7445 "configure"
+#line 7444 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7449: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7480,7 +7479,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7484: checking for location of JPEG library" >&5
+echo "configure:7483: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7507,13 +7506,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7511: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7510: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7517 "configure"
+#line 7516 "configure"
@@ -7524,7 +7523,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7543,13 +7542,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7547: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7546: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7553 "configure"
+#line 7552 "configure"
@@ -7560,7 +7559,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7609,7 +7608,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7613: checking whether to use GDAL" >&5
+echo "configure:7612: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7627,7 +7626,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7631: checking for $ac_word" >&5
+echo "configure:7630: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7682,14 +7681,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7686 "configure"
+#line 7685 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7698,14 +7697,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7702 "configure"
+#line 7701 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7737,7 +7736,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7741: checking whether to use GEOS" >&5
+echo "configure:7740: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7754,7 +7753,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7758: checking for $ac_word" >&5
+echo "configure:7757: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7802,15 +7801,15 @@
 do
-echo "configure:7806: checking for $ac_hdr" >&5
+echo "configure:7805: checking for $ac_hdr" >&5
-#line 7809 "configure"
+#line 7808 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7813: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7845,13 +7844,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7849: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7848: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7855 "configure"
+#line 7854 "configure"
 #include "confdefs.h"
@@ -7862,7 +7861,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:7866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7905,7 +7904,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7909: checking whether to use TIFF" >&5
+echo "configure:7908: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7925,7 +7924,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7929: checking for location of TIFF includes" >&5
+echo "configure:7928: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7951,15 +7950,15 @@
 do
-echo "configure:7955: checking for $ac_hdr" >&5
+echo "configure:7954: checking for $ac_hdr" >&5
-#line 7958 "configure"
+#line 7957 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7962: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7993,7 +7992,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7997: checking for location of TIFF library" >&5
+echo "configure:7996: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8024,13 +8023,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8028: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8027: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8034 "configure"
+#line 8033 "configure"
@@ -8041,7 +8040,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8060,13 +8059,13 @@
-echo "configure:8064: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8063: checking for TIFFOpen in -ltiff" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8070 "configure"
+#line 8069 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -8077,7 +8076,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8096,13 +8095,13 @@
-echo "configure:8100: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8099: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8106 "configure"
+#line 8105 "configure"
@@ -8113,7 +8112,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8132,13 +8131,13 @@
-echo "configure:8136: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8135: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8142 "configure"
+#line 8141 "configure"
@@ -8149,7 +8148,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8168,13 +8167,13 @@
-echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8171: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8178 "configure"
+#line 8177 "configure"
@@ -8185,7 +8184,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8204,13 +8203,13 @@
-echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8207: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8214 "configure"
+#line 8213 "configure"
@@ -8221,7 +8220,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8240,13 +8239,13 @@
-echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8243: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8250 "configure"
+#line 8249 "configure"
@@ -8257,7 +8256,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8276,13 +8275,13 @@
-echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8279: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8286 "configure"
+#line 8285 "configure"
@@ -8293,7 +8292,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8391,7 +8390,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8395: checking whether to use PNG" >&5
+echo "configure:8394: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8410,7 +8409,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8414: checking for location of PNG includes" >&5
+echo "configure:8413: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8436,15 +8435,15 @@
 do
-echo "configure:8440: checking for $ac_hdr" >&5
+echo "configure:8439: checking for $ac_hdr" >&5
-#line 8443 "configure"
+#line 8442 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8448: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8478,7 +8477,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8482: checking for location of PNG library" >&5
+echo "configure:8481: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8503,13 +8502,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8507: checking for png_read_image in -lpng" >&5
+echo "configure:8506: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8513 "configure"
+#line 8512 "configure"
@@ -8520,7 +8519,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8562,7 +8561,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8566: checking whether to use PostgreSQL" >&5
+echo "configure:8565: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8589,7 +8588,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8593: checking for location of PostgreSQL includes" >&5
+echo "configure:8592: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8615,15 +8614,15 @@
 do
-echo "configure:8619: checking for $ac_hdr" >&5
+echo "configure:8618: checking for $ac_hdr" >&5
-#line 8622 "configure"
+#line 8621 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8626: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8661,7 +8660,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8665: checking for location of PostgreSQL library" >&5
+echo "configure:8664: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8690,13 +8689,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8694: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8693: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8700 "configure"
+#line 8699 "configure"
@@ -8707,7 +8706,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8726,13 +8725,13 @@
-echo "configure:8730: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8729: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8736 "configure"
+#line 8735 "configure"
@@ -8743,7 +8742,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8762,13 +8761,13 @@
-echo "configure:8766: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8765: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8772 "configure"
+#line 8771 "configure"
@@ -8779,7 +8778,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8798,13 +8797,13 @@
-echo "configure:8802: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8801: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8808 "configure"
+#line 8807 "configure"
@@ -8815,7 +8814,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8872,13 +8871,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8876: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8875: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8882 "configure"
+#line 8881 "configure"
@@ -8889,7 +8888,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8911,13 +8910,13 @@
-echo "configure:8915: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8914: checking for PQcmdTuples in -lpq" >&5
-#line 8921 "configure"
+#line 8920 "configure"
@@ -8928,7 +8927,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8971,7 +8970,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8975: checking whether to use MySQL" >&5
+echo "configure:8974: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -8991,7 +8990,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8995: checking for location of MySQL includes" >&5
+echo "configure:8994: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9017,15 +9016,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9021: checking for $ac_hdr" >&5
+echo "configure:9020: checking for $ac_hdr" >&5
-#line 9024 "configure"
+#line 9023 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9062,7 +9061,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9066: checking for location of MySQL library" >&5
+echo "configure:9065: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9093,13 +9092,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9097: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9096: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9103 "configure"
+#line 9102 "configure"
@@ -9110,7 +9109,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9129,13 +9128,13 @@
-echo "configure:9133: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9132: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9139 "configure"
+#line 9138 "configure"
@@ -9146,7 +9145,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9165,13 +9164,13 @@
-echo "configure:9169: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9168: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9175 "configure"
+#line 9174 "configure"
@@ -9182,7 +9181,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9201,13 +9200,13 @@
-echo "configure:9205: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9204: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9211 "configure"
+#line 9210 "configure"
@@ -9218,7 +9217,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9237,13 +9236,13 @@
-echo "configure:9241: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9240: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9247 "configure"
+#line 9246 "configure"
@@ -9254,7 +9253,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9273,13 +9272,13 @@
-echo "configure:9277: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9276: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9283 "configure"
+#line 9282 "configure"
@@ -9290,7 +9289,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9309,13 +9308,13 @@
-echo "configure:9313: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9312: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9319 "configure"
+#line 9318 "configure"
@@ -9326,7 +9325,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9345,13 +9344,13 @@
-echo "configure:9349: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9348: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9355 "configure"
+#line 9354 "configure"
@@ -9362,7 +9361,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9452,7 +9451,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9456: checking for $ac_word" >&5
+echo "configure:9455: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9501,10 +9500,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9505: checking for mysql_server_init" >&5
+echo "configure:9504: checking for mysql_server_init" >&5
-#line 9508 "configure"
+#line 9507 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9530,7 +9529,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9582,7 +9581,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9586: checking whether to use SQLite" >&5
+echo "configure:9585: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9602,7 +9601,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9606: checking for location of SQLite includes" >&5
+echo "configure:9605: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9628,15 +9627,15 @@
 do
-echo "configure:9632: checking for $ac_hdr" >&5
+echo "configure:9631: checking for $ac_hdr" >&5
-#line 9635 "configure"
+#line 9634 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9639: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9679,7 +9678,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9683: checking for location of SQLite library" >&5
+echo "configure:9682: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9706,13 +9705,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9710: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9709: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9716 "configure"
+#line 9715 "configure"
@@ -9723,7 +9722,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9742,13 +9741,13 @@
-echo "configure:9746: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9745: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9752 "configure"
+#line 9751 "configure"
@@ -9759,7 +9758,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9812,7 +9811,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9816: checking whether to use FFMPEG" >&5
+echo "configure:9815: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -9832,7 +9831,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9836: checking for location of FFMPEG includes" >&5
+echo "configure:9835: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9858,15 +9857,15 @@
 do
-echo "configure:9862: checking for $ac_hdr" >&5
+echo "configure:9861: checking for $ac_hdr" >&5
-#line 9865 "configure"
+#line 9864 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9902,15 +9901,15 @@
 do
-echo "configure:9906: checking for $ac_hdr" >&5
+echo "configure:9905: checking for $ac_hdr" >&5
-#line 9909 "configure"
+#line 9908 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9946,15 +9945,15 @@
 do
-echo "configure:9950: checking for $ac_hdr" >&5
+echo "configure:9949: checking for $ac_hdr" >&5
-#line 9953 "configure"
+#line 9952 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9997,7 +9996,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10001: checking for location of FFMPEG library" >&5
+echo "configure:10000: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10024,13 +10023,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10028: checking for av_free in -lavutil" >&5
+echo "configure:10027: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10034 "configure"
+#line 10033 "configure"
@@ -10041,7 +10040,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10060,13 +10059,13 @@
-echo "configure:10064: checking for av_free in -lavutil" >&5
+echo "configure:10063: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10070 "configure"
+#line 10069 "configure"
@@ -10077,7 +10076,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10122,13 +10121,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10126: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10125: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10132 "configure"
+#line 10131 "configure"
@@ -10139,7 +10138,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10158,13 +10157,13 @@
-echo "configure:10162: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10161: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10168 "configure"
+#line 10167 "configure"
@@ -10175,7 +10174,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10220,13 +10219,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10224: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10223: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10230 "configure"
+#line 10229 "configure"
@@ -10237,7 +10236,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10256,13 +10255,13 @@
-echo "configure:10260: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10259: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10266 "configure"
+#line 10265 "configure"
@@ -10273,7 +10272,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10332,7 +10331,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10336: checking whether to use OpenGL" >&5
+echo "configure:10335: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10366,7 +10365,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10370: checking for location of OpenGL includes" >&5
+echo "configure:10369: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10392,15 +10391,15 @@
 do
-echo "configure:10396: checking for $ac_hdr" >&5
+echo "configure:10395: checking for $ac_hdr" >&5
-#line 10399 "configure"
+#line 10398 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10434,7 +10433,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10438: checking for location of OpenGL library" >&5
+echo "configure:10437: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10463,13 +10462,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10467: checking for glBegin in -lGL" >&5
+echo "configure:10466: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10473 "configure"
+#line 10472 "configure"
@@ -10480,7 +10479,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10499,13 +10498,13 @@
-echo "configure:10503: checking for glBegin in -lGL" >&5
+echo "configure:10502: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10509 "configure"
+#line 10508 "configure"
@@ -10516,7 +10515,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10535,13 +10534,13 @@
-echo "configure:10539: checking for glBegin in -lGL" >&5
+echo "configure:10538: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10545 "configure"
+#line 10544 "configure"
@@ -10552,7 +10551,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10571,13 +10570,13 @@
-echo "configure:10575: checking for glBegin in -lGL" >&5
+echo "configure:10574: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10581 "configure"
+#line 10580 "configure"
@@ -10588,7 +10587,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10650,13 +10649,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10654: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10653: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10660 "configure"
+#line 10659 "configure"
@@ -10667,7 +10666,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10686,13 +10685,13 @@
-echo "configure:10690: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10689: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10696 "configure"
+#line 10695 "configure"
@@ -10703,7 +10702,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10750,10 +10749,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10754: checking for glXCreatePbuffer" >&5
+echo "configure:10753: checking for glXCreatePbuffer" >&5
-#line 10757 "configure"
+#line 10756 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -10776,7 +10775,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -10813,10 +10812,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10817: checking for glXCreateGLXPixmap" >&5
+echo "configure:10816: checking for glXCreateGLXPixmap" >&5
-#line 10820 "configure"
+#line 10819 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -10839,7 +10838,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -10882,7 +10881,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10886: checking for location of OpenGL framework" >&5
+echo "configure:10885: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10906,15 +10905,15 @@
 do
-echo "configure:10910: checking for $ac_hdr" >&5
+echo "configure:10909: checking for $ac_hdr" >&5
-#line 10913 "configure"
+#line 10912 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10950,10 +10949,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10954: checking for glBegin" >&5
+echo "configure:10953: checking for glBegin" >&5
-#line 10957 "configure"
+#line 10956 "configure"
     which can conflict with char glBegin(); below.  */
@@ -10976,7 +10975,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11013,10 +11012,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11017: checking for gluBeginCurve" >&5
+echo "configure:11016: checking for gluBeginCurve" >&5
-#line 11020 "configure"
+#line 11019 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11039,7 +11038,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11087,7 +11086,7 @@
-echo "configure:11091: checking for location of OpenGL includes" >&5
+echo "configure:11090: checking for location of OpenGL includes" >&5
@@ -11113,15 +11112,15 @@
 do
-echo "configure:11117: checking for $ac_hdr" >&5
+echo "configure:11116: checking for $ac_hdr" >&5
-#line 11120 "configure"
+#line 11119 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11155,7 +11154,7 @@
-echo "configure:11159: checking for location of OpenGL library" >&5
+echo "configure:11158: checking for location of OpenGL library" >&5
@@ -11180,18 +11179,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11184: checking for OpenGL library" >&5
+echo "configure:11183: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11188 "configure"
+#line 11187 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11215,18 +11214,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11219: checking for GLU library" >&5
+echo "configure:11218: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11223 "configure"
+#line 11222 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11275,7 +11274,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11279: checking whether to use Tcl/Tk" >&5
+echo "configure:11278: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11295,7 +11294,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11299: checking for location of Tcl/Tk includes" >&5
+echo "configure:11298: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11321,15 +11320,15 @@
 do
-echo "configure:11325: checking for $ac_hdr" >&5
+echo "configure:11324: checking for $ac_hdr" >&5
-#line 11328 "configure"
+#line 11327 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11332: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11366,15 +11365,15 @@
 do
-echo "configure:11370: checking for $ac_hdr" >&5
+echo "configure:11369: checking for $ac_hdr" >&5
-#line 11373 "configure"
+#line 11372 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11408,7 +11407,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11412: checking Tcl version" >&5
+echo "configure:11411: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11416,7 +11415,7 @@
 else
-#line 11420 "configure"
+#line 11419 "configure"
 #include <stdio.h>
@@ -11428,7 +11427,7 @@
 EOF
-if { (eval echo configure:11432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11446,7 +11445,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11450: checking Tk version" >&5
+echo "configure:11449: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11454,7 +11453,7 @@
 else
-#line 11458 "configure"
+#line 11457 "configure"
 #include <stdio.h>
@@ -11466,7 +11465,7 @@
 EOF
-if { (eval echo configure:11470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11495,7 +11494,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11499: checking for location of Tcl/Tk library" >&5
+echo "configure:11498: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11535,13 +11534,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11539: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11538: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11545 "configure"
+#line 11544 "configure"
@@ -11552,7 +11551,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11571,13 +11570,13 @@
-echo "configure:11575: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11574: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11581 "configure"
+#line 11580 "configure"
@@ -11588,7 +11587,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11615,13 +11614,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11619: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11618: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11625 "configure"
+#line 11624 "configure"
@@ -11632,7 +11631,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11651,13 +11650,13 @@
-echo "configure:11655: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11654: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11661 "configure"
+#line 11660 "configure"
@@ -11668,7 +11667,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11695,13 +11694,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11699: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11698: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11705 "configure"
+#line 11704 "configure"
@@ -11712,7 +11711,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11731,13 +11730,13 @@
-echo "configure:11735: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11734: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11741 "configure"
+#line 11740 "configure"
@@ -11748,7 +11747,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11826,13 +11825,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11830: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11829: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11836 "configure"
+#line 11835 "configure"
@@ -11843,7 +11842,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11862,13 +11861,13 @@
-echo "configure:11866: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11865: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11872 "configure"
+#line 11871 "configure"
@@ -11879,7 +11878,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11906,13 +11905,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11910: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11909: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11916 "configure"
+#line 11915 "configure"
@@ -11923,7 +11922,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11942,13 +11941,13 @@
-echo "configure:11946: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11945: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11952 "configure"
+#line 11951 "configure"
@@ -11959,7 +11958,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11986,13 +11985,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11990: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11989: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11996 "configure"
+#line 11995 "configure"
@@ -12003,7 +12002,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12022,13 +12021,13 @@
-echo "configure:12026: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12025: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12032 "configure"
+#line 12031 "configure"
@@ -12039,7 +12038,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12129,13 +12128,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12133: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12132: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12139 "configure"
+#line 12138 "configure"
@@ -12146,7 +12145,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12195,7 +12194,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12199: checking whether to use ODBC" >&5
+echo "configure:12198: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12214,7 +12213,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12218: checking for location of ODBC includes" >&5
+echo "configure:12217: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12240,15 +12239,15 @@
 do
-echo "configure:12244: checking for $ac_hdr" >&5
+echo "configure:12243: checking for $ac_hdr" >&5
-#line 12247 "configure"
+#line 12246 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12251: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12282,7 +12281,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12286: checking for location of ODBC library" >&5
+echo "configure:12285: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12307,13 +12306,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12311: checking for SQLConnect in -lodbc" >&5
+echo "configure:12310: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12317 "configure"
+#line 12316 "configure"
@@ -12324,7 +12323,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12349,13 +12348,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12353: checking for SQLConnect in -liodbc" >&5
+echo "configure:12352: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12359 "configure"
+#line 12358 "configure"
@@ -12366,7 +12365,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12391,11 +12390,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12395: checking for ODBC library" >&5
+echo "configure:12394: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12399 "configure"
+#line 12398 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12403,7 +12402,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12452,7 +12451,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12456: checking whether to use FFTW" >&5
+echo "configure:12455: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12471,7 +12470,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12475: checking for location of FFTW includes" >&5
+echo "configure:12474: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12497,15 +12496,15 @@
 do
-echo "configure:12501: checking for $ac_hdr" >&5
+echo "configure:12500: checking for $ac_hdr" >&5
-#line 12504 "configure"
+#line 12503 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12533,15 +12532,15 @@
 do
-echo "configure:12537: checking for $ac_hdr" >&5
+echo "configure:12536: checking for $ac_hdr" >&5
-#line 12540 "configure"
+#line 12539 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12569,15 +12568,15 @@
 do
-echo "configure:12573: checking for $ac_hdr" >&5
+echo "configure:12572: checking for $ac_hdr" >&5
-#line 12576 "configure"
+#line 12575 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12580: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12623,7 +12622,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12627: checking for location of FFTW library" >&5
+echo "configure:12626: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12648,13 +12647,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12652: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12651: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12658 "configure"
+#line 12657 "configure"
@@ -12665,7 +12664,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12690,13 +12689,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12694: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12693: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12700 "configure"
+#line 12699 "configure"
@@ -12707,7 +12706,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12732,13 +12731,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12736: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12735: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12742 "configure"
+#line 12741 "configure"
@@ -12749,7 +12748,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12806,7 +12805,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12810: checking whether to use BLAS" >&5
+echo "configure:12809: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12827,7 +12826,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12831: checking for location of BLAS includes" >&5
+echo "configure:12830: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12847,7 +12846,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12851: checking for location of BLAS library" >&5
+echo "configure:12850: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12873,15 +12872,15 @@
 do
-echo "configure:12877: checking for $ac_hdr" >&5
+echo "configure:12876: checking for $ac_hdr" >&5
-#line 12880 "configure"
+#line 12879 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12916,13 +12915,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12920: checking for dnrm2_ in -lblas" >&5
+echo "configure:12919: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12926 "configure"
+#line 12925 "configure"
@@ -12933,7 +12932,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12952,13 +12951,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12956: checking for dnrm2_ in -lblas" >&5
+echo "configure:12955: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12962 "configure"
+#line 12961 "configure"
 #include "confdefs.h"
@@ -12969,7 +12968,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13013,13 +13012,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13017: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13016: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13023 "configure"
+#line 13022 "configure"
@@ -13030,7 +13029,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13045,13 +13044,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13049: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13048: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13055 "configure"
+#line 13054 "configure"
@@ -13062,7 +13061,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13077,13 +13076,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13081: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13080: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13087 "configure"
+#line 13086 "configure"
@@ -13094,7 +13093,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13140,16 +13139,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13144: checking for sgemm in $vlib_flags" >&5
+echo "configure:13143: checking for sgemm in $vlib_flags" >&5
-#line 13146 "configure"
+#line 13145 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13167,13 +13166,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13171: checking for sgemm_ in -lblas" >&5
+echo "configure:13170: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 13177 "configure"
+#line 13176 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13184,7 +13183,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13199,13 +13198,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13203: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13202: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13209 "configure"
+#line 13208 "configure"
@@ -13216,7 +13215,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13231,13 +13230,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13235: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13234: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13241 "configure"
+#line 13240 "configure"
@@ -13248,7 +13247,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13282,13 +13281,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13286: checking for acosp in -lsunmath" >&5
+echo "configure:13285: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13292 "configure"
+#line 13291 "configure"
@@ -13299,7 +13298,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13314,13 +13313,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13318: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13317: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13324 "configure"
+#line 13323 "configure"
@@ -13331,7 +13330,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13361,13 +13360,13 @@
 # Generic BLAS library
-echo "configure:13365: checking for sgemm_ in -lblas" >&5
+echo "configure:13364: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13371 "configure"
+#line 13370 "configure"
@@ -13378,7 +13377,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13417,7 +13416,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13421: checking whether to use LAPACK" >&5
+echo "configure:13420: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13442,7 +13441,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13446: checking for location of LAPACK includes" >&5
+echo "configure:13445: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13462,7 +13461,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13466: checking for location of LAPACK library" >&5
+echo "configure:13465: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13488,15 +13487,15 @@
 do
-echo "configure:13492: checking for $ac_hdr" >&5
+echo "configure:13491: checking for $ac_hdr" >&5
-#line 13495 "configure"
+#line 13494 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13528,10 +13527,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13532: checking for dsegv_" >&5
+echo "configure:13531: checking for dsegv_" >&5
-#line 13535 "configure"
+#line 13534 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13554,7 +13553,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13581,13 +13580,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13585: checking for desgv_ in -llapack" >&5
+echo "configure:13584: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13591 "configure"
+#line 13590 "configure"
@@ -13598,7 +13597,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13630,13 +13629,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13634: checking for dgesv_ in -llapack" >&5
+echo "configure:13633: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13640 "configure"
+#line 13639 "configure"
@@ -13647,7 +13646,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13666,13 +13665,13 @@
-echo "configure:13670: checking for dgesv_ in -llapack" >&5
+echo "configure:13669: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13676 "configure"
+#line 13675 "configure"
@@ -13683,7 +13682,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13739,7 +13738,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13743: checking whether to use Cairo" >&5
+echo "configure:13742: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13765,7 +13764,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13769: checking for location of cairo includes" >&5
+echo "configure:13768: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13791,15 +13790,15 @@
 do
-echo "configure:13795: checking for $ac_hdr" >&5
+echo "configure:13794: checking for $ac_hdr" >&5
-#line 13798 "configure"
+#line 13797 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13835,7 +13834,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13839: checking for location of cairo library" >&5
+echo "configure:13838: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13855,7 +13854,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13859: checking for cairo linking flags" >&5
+echo "configure:13858: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13871,10 +13870,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13875: checking for cairo_create" >&5
+echo "configure:13874: checking for cairo_create" >&5
-#line 13878 "configure"
+#line 13877 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13897,7 +13896,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13931,10 +13930,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13935: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13934: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13938 "configure"
+#line 13937 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13957,7 +13956,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13990,10 +13989,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13994: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13993: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13997 "configure"
+#line 13996 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14016,7 +14015,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14058,7 +14057,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14062: checking whether to use FreeType" >&5
+echo "configure:14061: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14077,7 +14076,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14081: checking for location of FreeType includes" >&5
+echo "configure:14080: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14103,15 +14102,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14107: checking for $ac_hdr" >&5
+echo "configure:14106: checking for $ac_hdr" >&5
-#line 14110 "configure"
+#line 14109 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14114: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14145,7 +14144,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14149: checking for location of FreeType library" >&5
+echo "configure:14148: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14170,13 +14169,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14174: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14173: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14180 "configure"
+#line 14179 "configure"
@@ -14187,7 +14186,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14228,7 +14227,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14232: checking whether to use NLS" >&5
+echo "configure:14231: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14248,10 +14247,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14252: checking for gettext" >&5
+echo "configure:14251: checking for gettext" >&5
-#line 14255 "configure"
+#line 14254 "configure"
     which can conflict with char gettext(); below.  */
@@ -14274,7 +14273,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14292,13 +14291,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14296: checking for gettext in -lintl" >&5
+echo "configure:14295: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14302 "configure"
+#line 14301 "configure"
@@ -14309,7 +14308,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14344,7 +14343,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14348: checking whether to use C++" >&5
+echo "configure:14347: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14360,7 +14359,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14364: checking for $ac_word" >&5
+echo "configure:14363: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14389,7 +14388,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14393: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14392: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14400,12 +14399,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14404 "configure"
+#line 14403 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14431,19 +14430,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14435: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14434: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14440: checking whether we are using GNU C++" >&5
+echo "configure:14439: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14446: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14461,7 +14460,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14465: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14464: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14502,7 +14501,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14506: checking whether to use openDWG" >&5
+echo "configure:14505: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14522,7 +14521,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14526: checking for location of openDGW includes" >&5
+echo "configure:14525: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14548,15 +14547,15 @@
 do
-echo "configure:14552: checking for $ac_hdr" >&5
+echo "configure:14551: checking for $ac_hdr" >&5
-#line 14555 "configure"
+#line 14554 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14590,7 +14589,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14594: checking for location of openDWG library" >&5
+echo "configure:14593: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14631,7 +14630,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14635: checking whether to use POSIX threads" >&5
+echo "configure:14634: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14651,7 +14650,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14655: checking for location of POSIX threads includes" >&5
+echo "configure:14654: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14677,15 +14676,15 @@
 do
-echo "configure:14681: checking for $ac_hdr" >&5
+echo "configure:14680: checking for $ac_hdr" >&5
-#line 14684 "configure"
+#line 14683 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14719,7 +14718,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14723: checking for location of POSIX threads library" >&5
+echo "configure:14722: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14744,10 +14743,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14748: checking for pthread_create" >&5
+echo "configure:14747: checking for pthread_create" >&5
-#line 14751 "configure"
+#line 14750 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -14770,7 +14769,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14797,13 +14796,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14801: checking for pthread_create in -lpthread" >&5
+echo "configure:14800: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14807 "configure"
+#line 14806 "configure"
@@ -14814,7 +14813,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14870,7 +14869,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14874: checking for special C compiler options needed for large files" >&5
+echo "configure:14873: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14878,7 +14877,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14882 "configure"
+#line 14881 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14894,7 +14893,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14897: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14903,7 +14902,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14907 "configure"
+#line 14906 "configure"
@@ -14919,7 +14918,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14923: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14939,11 +14938,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14943: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14942: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14947 "configure"
+#line 14946 "configure"
@@ -14959,14 +14958,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14962: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14970 "configure"
+#line 14969 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14984,7 +14983,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15003,11 +15002,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15007: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15006: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15011 "configure"
+#line 15010 "configure"
@@ -15023,14 +15022,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15034 "configure"
+#line 15033 "configure"
 #define _LARGE_FILES 1
@@ -15048,7 +15047,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15067,25 +15066,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15071: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15070: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15075 "configure"
+#line 15074 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15081: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15089 "configure"
+#line 15088 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15094,7 +15093,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15097: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15115,10 +15114,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15119: checking if system supports Large Files at all" >&5
+echo "configure:15118: checking if system supports Large Files at all" >&5
-#line 15122 "configure"
+#line 15121 "configure"
 #include <stdio.h>
@@ -15150,7 +15149,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15153: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15179,7 +15178,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15183: checking whether to use Python" >&5
+echo "configure:15182: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15200,7 +15199,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15204: checking for $ac_word" >&5
+echo "configure:15203: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15242,15 +15241,15 @@
 do
-echo "configure:15246: checking for $ac_hdr" >&5
+echo "configure:15245: checking for $ac_hdr" >&5
-#line 15249 "configure"
+#line 15248 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15298,7 +15297,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15302: checking for $ac_word" >&5
+echo "configure:15301: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15360,7 +15359,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15364: checking whether to use wxWidgets" >&5
+echo "configure:15363: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15381,7 +15380,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15385: checking for $ac_word" >&5
+echo "configure:15384: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15429,7 +15428,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15433: checking wxWidgets version" >&5
+echo "configure:15432: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15452,15 +15451,15 @@
 do
-echo "configure:15456: checking for $ac_hdr" >&5
+echo "configure:15455: checking for $ac_hdr" >&5
-#line 15459 "configure"
+#line 15458 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-09-07 12:16:58 UTC (rev 39062)
+++ grass/trunk/configure.in	2009-09-07 12:22:57 UTC (rev 39063)
@@ -148,58 +148,57 @@
 AC_MSG_RESULT("$enable_macosx_app")
 AC_SUBST(MACOSX_APP)
-# Check for MacOSX archs
-AC_MSG_CHECKING(for MacOSX architectures)
-MACOSX_ARCHS=
-if test "$with_macosx_archs" = "no" ; then
-  AC_MSG_RESULT(no)
-else
-  for a in $with_macosx_archs
-  do
-    # check if valid arch?
-    case "$a" in
-      i386|ppc|x86_64|ppc64)
-        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
-    esac
-  done
-  AC_MSG_RESULT([$MACOSX_ARCHS])
-  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
-  CFLAGS="$CFLAGS $MACOSX_ARCHS"
-  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
-fi
-AC_SUBST(MACOSX_ARCHS)
-# Done checking MacOSX archs
-# Check for MacOSX SDK
-AC_MSG_CHECKING(for MacOSX SDK)
-MACOSX_SDK=
-if test "$with_macosx_sdk" = "no" ; then
-  AC_MSG_RESULT(no)
-else
-  AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
-    MACOSX_SDK="-isysroot $with_macosx_sdk"],[
-    AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
-  LDFLAGS="$LDFLAGS $MACOSX_SDK"
-  CFLAGS="$CFLAGS $MACOSX_SDK"
-  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
-fi
-AC_SUBST(MACOSX_SDK)
-# Done checking MacOSX SDK
-# Set INST_DIR
 if test -n "$MACOSX_APP" ; then
+    # Check for MacOSX archs
+    AC_MSG_CHECKING(for MacOSX architectures)
+    MACOSX_ARCHS=
+    if test "$with_macosx_archs" = "no" ; then
+      AC_MSG_RESULT(no)
+    else
+      for a in $with_macosx_archs
+      do
+        # check if valid arch?
+        case "$a" in
+          i386|ppc|x86_64|ppc64)
+            MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+        esac
+      done
+      AC_MSG_RESULT([$MACOSX_ARCHS])
+      LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+      CFLAGS="$CFLAGS $MACOSX_ARCHS"
+      CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+    fi
+    AC_SUBST(MACOSX_ARCHS)
+    # Done checking MacOSX archs
+    # Check for MacOSX SDK
+    AC_MSG_CHECKING(for MacOSX SDK)
+    MACOSX_SDK=
+    if test "$with_macosx_sdk" = "no" ; then
+      AC_MSG_RESULT(no)
+    else
+      AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
+        MACOSX_SDK="-isysroot $with_macosx_sdk"],[
+        AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
+      LDFLAGS="$LDFLAGS $MACOSX_SDK"
+      CFLAGS="$CFLAGS $MACOSX_SDK"
+      CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+    fi
+    AC_SUBST(MACOSX_SDK)
+    # Done checking MacOSX SDK
+    # Set INST_DIR
     INSTDIR='${prefix}'"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"
 else
     INSTDIR='${prefix}'"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"
