[GRASS-SVN] r39076 - in grass/branches/releasebranch_6_4: . display/d.what.vect gui/wxpython/nviz gui/wxpython/vdigit include/Make lib/form swig/python vector/v.digit vector/v.what visualization/nviz/src
Mon Sep 7 14:34:35 EDT 2009
Author: kyngchaos
Date: 2009-09-07 14:34:33 -0400 (Mon, 07 Sep 2009)
New Revision: 39076
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
   grass/branches/releasebranch_6_4/display/d.what.vect/Makefile
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/Makefile
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/Makefile
   grass/branches/releasebranch_6_4/include/Make/Platform.make.in
   grass/branches/releasebranch_6_4/include/Make/Python.make
   grass/branches/releasebranch_6_4/lib/form/Makefile
   grass/branches/releasebranch_6_4/swig/python/Makefile
   grass/branches/releasebranch_6_4/vector/v.digit/Makefile
   grass/branches/releasebranch_6_4/vector/v.what/Makefile
   grass/branches/releasebranch_6_4/visualization/nviz/src/Makefile
fix PYMOD_LD for OSX; replace OSX archs for swig/python (from dev6 r39071)
Configure option for OSX architectures and SDK; strip arch flags that may be in some builds of Python and wxPython (from dev6 r39051)
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/configure	2009-09-07 18:34:33 UTC (rev 39076)
@@ -25,6 +25,14 @@
 ac_help="$ac_help
   --with-cxx              support C++ functionality (default: no)"
 ac_help="$ac_help
+  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])"
+ac_help="$ac_help
+  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)"
+ac_help="$ac_help
   --with-jpeg             support JPEG functionality (default: yes)"
 ac_help="$ac_help
   --with-tiff             support TIFF functionality (default: yes)"
@@ -69,15 +77,20 @@
 ac_help="$ac_help
   --with-regex            support regex functionality (default: yes)"
 ac_help="$ac_help
-  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')"
+  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
-  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)"
+  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)"
 ac_help="$ac_help
-  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
+  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)"
 ac_help="$ac_help
   --with-includes=DIRS    site include files are in DIRS"
 ac_help="$ac_help
@@ -737,7 +750,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:741: checking host system type" >&5
+echo "configure:754: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -760,7 +773,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:764: checking for $ac_word" >&5
+echo "configure:777: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -787,7 +800,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:791: checking for $ac_word" >&5
+echo "configure:804: checking for $ac_word" >&5
@@ -835,7 +848,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:839: checking for $ac_word" >&5
+echo "configure:852: checking for $ac_word" >&5
@@ -864,7 +877,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:868: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -875,12 +888,12 @@
 cat > conftest.$ac_ext << EOF
-#line 879 "configure"
+#line 892 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -906,19 +919,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:910: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:915: checking whether we are using GNU C" >&5
+echo "configure:928: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -936,7 +949,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:940: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -965,10 +978,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:969: checking for Cygwin environment" >&5
+echo "configure:982: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 972 "configure"
+#line 985 "configure"
 int main() {
@@ -979,7 +992,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:983: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -995,17 +1008,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:999: checking for mingw32 environment" >&5
+echo "configure:1012: checking for mingw32 environment" >&5
-#line 1002 "configure"
+#line 1015 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1009: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1023,7 +1036,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1027: checking for executable suffix" >&5
+echo "configure:1040: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1042,23 +1055,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1046: checking for full floating-point support" >&5
+echo "configure:1059: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1051: checking whether "cc -mieee" works" >&5
+echo "configure:1064: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1055 "configure"
+#line 1068 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1074,7 +1087,7 @@
 else
-#line 1078 "configure"
+#line 1091 "configure"
 #include <float.h>
@@ -1088,7 +1101,7 @@
 EOF
-if { (eval echo configure:1092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1101,14 +1114,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1105: checking for full floating-point support with -mieee" >&5
+echo "configure:1118: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1112 "configure"
+#line 1125 "configure"
 #include <float.h>
@@ -1122,7 +1135,7 @@
 EOF
-if { (eval echo configure:1126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1159,7 +1172,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1163: checking for $ac_word" >&5
+echo "configure:1176: checking for $ac_word" >&5
 case "$pwd" in
@@ -1197,7 +1210,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1201: checking for source directory" >&5
+echo "configure:1214: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1208,7 +1221,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1212: checking for build directory" >&5
+echo "configure:1225: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1293,7 +1306,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1297: checking for MacOSX App" >&5
+echo "configure:1310: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1302,6 +1315,78 @@
 echo "$ac_t"""$enable_macosx_app"" 1>&6
+# Check for MacOSX archs
+echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
+echo "configure:1322: checking for MacOSX architectures" >&5
+MACOSX_ARCHS=
+if test -z "$with_macosx_archs" ; then
+  echo "$ac_t""no" 1>&6
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  echo "$ac_t""$MACOSX_ARCHS" 1>&6
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
+echo "configure:1351: checking for MacOSX SDK" >&5
+MACOSX_SDK=
+if test -z "$with_macosx_sdk" ; then
+else
+ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
+echo "configure:1361: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+if test "$cross_compiling" = yes; then
+    { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
+else
+  if test -r $with_macosx_sdk/SDKSettings.plist; then
+    eval "ac_cv_file_$ac_safe=yes"
+  else
+    eval "ac_cv_file_$ac_safe=no"
+  fi
+fi
+if eval "test \"`echo '$ac_cv_file_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    MACOSX_SDK="-isysroot $with_macosx_sdk"
+else
+    { echo "configure: error: *** specified SDK does not exist or is not a SDK" 1>&2; exit 1; }
+fi
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -1316,7 +1401,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1320: checking how to build libraries" >&5
+echo "configure:1405: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1359,7 +1444,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1363: checking for $ac_word" >&5
+echo "configure:1448: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1384,7 +1469,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1388: checking how to run the C preprocessor" >&5
+echo "configure:1473: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1397,13 +1482,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1401 "configure"
+#line 1486 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1407: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1414,13 +1499,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1418 "configure"
+#line 1503 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1431,13 +1516,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1435 "configure"
+#line 1520 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1465,7 +1550,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1469: checking if 64bit support is requested" >&5
+echo "configure:1554: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1485,7 +1570,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1489: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1574: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1509,7 +1594,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1513: checking system version (for dynamic loading)" >&5
+echo "configure:1598: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1535,13 +1620,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1539: checking for dlopen in -ldl" >&5
+echo "configure:1624: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1545 "configure"
+#line 1630 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1552,7 +1637,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1599,7 +1684,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1603: checking for $ac_word" >&5
+echo "configure:1688: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1728,13 +1813,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1732: checking for gettimeofday in -lbsd" >&5
+echo "configure:1817: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1738 "configure"
+#line 1823 "configure"
@@ -1745,7 +1830,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1786,13 +1871,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1790: checking for inet_ntoa in -lbind" >&5
+echo "configure:1875: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1796 "configure"
+#line 1881 "configure"
@@ -1803,7 +1888,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1864,13 +1949,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1868: checking for shl_load in -ldld" >&5
+echo "configure:1953: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1874 "configure"
+#line 1959 "configure"
@@ -1881,7 +1966,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1946,13 +2031,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1950: checking for shl_load in -ldld" >&5
+echo "configure:2035: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1956 "configure"
+#line 2041 "configure"
@@ -1963,7 +2048,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2085,15 +2170,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2089: checking for dld.h" >&5
+echo "configure:2174: checking for dld.h" >&5
-#line 2092 "configure"
+#line 2177 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2153,15 +2238,15 @@
 	    else
-echo "configure:2157: checking for dld.h" >&5
+echo "configure:2242: checking for dld.h" >&5
-#line 2160 "configure"
+#line 2245 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2258,9 +2343,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2262: checking for ELF" >&5
+echo "configure:2347: checking for ELF" >&5
-#line 2264 "configure"
+#line 2349 "configure"
 #ifdef __ELF__
@@ -2290,15 +2375,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2294: checking for dlfcn.h" >&5
+echo "configure:2379: checking for dlfcn.h" >&5
-#line 2297 "configure"
+#line 2382 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2322,9 +2407,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2326: checking for ELF" >&5
+echo "configure:2411: checking for ELF" >&5
-#line 2328 "configure"
+#line 2413 "configure"
 #ifdef __ELF__
@@ -2648,17 +2733,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2652: checking for ld accepts -Bexport flag" >&5
+echo "configure:2737: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2655 "configure"
+#line 2740 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2797,6 +2882,23 @@
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+# Check whether --with-macosx-archs or --without-macosx-archs was given.
+if test "${with_macosx_archs+set}" = set; then
+  withval="$with_macosx_archs"
+else
+  with_macosx_archs="no"
+fi
+# Check whether --with-macosx-sdk or --without-macosx-sdk was given.
+if test "${with_macosx_sdk+set}" = set; then
+  withval="$with_macosx_sdk"
+else
+  with_macosx_sdk="no"
+fi
 # Check whether --with-jpeg or --without-jpeg was given.
 if test "${with_jpeg+set}" = set; then
   withval="$with_jpeg"
@@ -3457,7 +3559,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3461: checking for additional include dirs" >&5
+echo "configure:3563: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3480,7 +3582,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3484: checking for additional library dirs" >&5
+echo "configure:3586: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3514,7 +3616,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3518: checking for a BSD compatible install" >&5
+echo "configure:3620: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3567,7 +3669,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3571: checking for $ac_word" >&5
+echo "configure:3673: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3598,13 +3700,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3602: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3704: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3608 "configure"
+#line 3710 "configure"
@@ -3615,7 +3717,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3640,7 +3742,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3644: checking for $ac_word" >&5
+echo "configure:3746: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3680,7 +3782,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3684: checking for $ac_word" >&5
+echo "configure:3786: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3711,7 +3813,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3715: checking for $ac_word" >&5
+echo "configure:3817: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3749,7 +3851,7 @@
-echo "configure:3753: checking for $ac_word" >&5
+echo "configure:3855: checking for $ac_word" >&5
@@ -3778,7 +3880,7 @@
-echo "configure:3782: checking for $ac_word" >&5
+echo "configure:3884: checking for $ac_word" >&5
@@ -3809,7 +3911,7 @@
-echo "configure:3813: checking for $ac_word" >&5
+echo "configure:3915: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3838,7 +3940,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3842: checking for $ac_word" >&5
+echo "configure:3944: checking for $ac_word" >&5
 case "$PERL" in
@@ -3869,10 +3971,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3873: checking for ANSI C header files" >&5
+echo "configure:3975: checking for ANSI C header files" >&5
-#line 3876 "configure"
+#line 3978 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3880,7 +3982,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3897,7 +3999,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3901 "configure"
+#line 4003 "configure"
 #include <string.h>
 EOF
@@ -3915,7 +4017,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3919 "configure"
+#line 4021 "configure"
 #include <stdlib.h>
 EOF
@@ -3936,7 +4038,7 @@
 else
-#line 3940 "configure"
+#line 4042 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3947,7 +4049,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3974,15 +4076,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3978: checking for $ac_hdr" >&5
+echo "configure:4080: checking for $ac_hdr" >&5
-#line 3981 "configure"
+#line 4083 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4011,15 +4113,15 @@
 do
-echo "configure:4015: checking for $ac_hdr" >&5
+echo "configure:4117: checking for $ac_hdr" >&5
-#line 4018 "configure"
+#line 4120 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4048,15 +4150,15 @@
 do
-echo "configure:4052: checking for $ac_hdr" >&5
+echo "configure:4154: checking for $ac_hdr" >&5
-#line 4055 "configure"
+#line 4157 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4085,15 +4187,15 @@
 do
-echo "configure:4089: checking for $ac_hdr" >&5
+echo "configure:4191: checking for $ac_hdr" >&5
-#line 4092 "configure"
+#line 4194 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4097: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4199: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4122,15 +4224,15 @@
 do
-echo "configure:4126: checking for $ac_hdr" >&5
+echo "configure:4228: checking for $ac_hdr" >&5
-#line 4129 "configure"
+#line 4231 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4134: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4156,10 +4258,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4160: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4262: checking whether time.h and sys/time.h may both be included" >&5
-#line 4163 "configure"
+#line 4265 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4168,7 +4270,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4274: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4188,10 +4290,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4192: checking for off_t" >&5
+echo "configure:4294: checking for off_t" >&5
-#line 4195 "configure"
+#line 4297 "configure"
 #if STDC_HEADERS
@@ -4218,10 +4320,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4222: checking for uid_t in sys/types.h" >&5
+echo "configure:4324: checking for uid_t in sys/types.h" >&5
-#line 4225 "configure"
+#line 4327 "configure"
 EOF
@@ -4249,10 +4351,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4253: checking return type of signal handlers" >&5
+echo "configure:4355: checking return type of signal handlers" >&5
-#line 4256 "configure"
+#line 4358 "configure"
 #include <signal.h>
@@ -4269,7 +4371,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4287,10 +4389,10 @@
-echo "configure:4291: checking for Cygwin environment" >&5
+echo "configure:4393: checking for Cygwin environment" >&5
-#line 4294 "configure"
+#line 4396 "configure"
 int main() {
@@ -4301,7 +4403,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4305: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4407: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4319,10 +4421,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4323: checking for $ac_func" >&5
+echo "configure:4425: checking for $ac_func" >&5
-#line 4326 "configure"
+#line 4428 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4345,7 +4447,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4371,10 +4473,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4375: checking for $ac_func" >&5
+echo "configure:4477: checking for $ac_func" >&5
-#line 4378 "configure"
+#line 4480 "configure"
@@ -4397,7 +4499,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4423,10 +4525,10 @@
 for ac_func in drand48
 do
-echo "configure:4427: checking for $ac_func" >&5
+echo "configure:4529: checking for $ac_func" >&5
-#line 4430 "configure"
+#line 4532 "configure"
@@ -4449,7 +4551,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4475,10 +4577,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4479: checking for $ac_func" >&5
+echo "configure:4581: checking for $ac_func" >&5
-#line 4482 "configure"
+#line 4584 "configure"
@@ -4501,7 +4603,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4527,10 +4629,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4531: checking for $ac_func" >&5
+echo "configure:4633: checking for $ac_func" >&5
-#line 4534 "configure"
+#line 4636 "configure"
@@ -4553,7 +4655,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4578,13 +4680,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4582: checking whether setpgrp takes no argument" >&5
+echo "configure:4684: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4588 "configure"
+#line 4690 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4604,7 +4706,7 @@
 EOF
-if { (eval echo configure:4608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4632,16 +4734,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4636: checking for long long int" >&5
+echo "configure:4738: checking for long long int" >&5
-#line 4638 "configure"
+#line 4740 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4645: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4661,7 +4763,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4665: checking for W11" >&5
+echo "configure:4767: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4689,7 +4791,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4693: checking for X" >&5
+echo "configure:4795: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4749,12 +4851,12 @@
   # First, try using that file with no special directory specified.
-#line 4753 "configure"
+#line 4855 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4860: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4823,14 +4925,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4827 "configure"
+#line 4929 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4935,17 +5037,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4939: checking whether -R must be followed by a space" >&5
+echo "configure:5041: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4942 "configure"
+#line 5044 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4961,14 +5063,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4965 "configure"
+#line 5067 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5000,13 +5102,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5004: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5106: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5010 "configure"
+#line 5112 "configure"
@@ -5017,7 +5119,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5038,13 +5140,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5042: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5144: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5048 "configure"
+#line 5150 "configure"
@@ -5055,7 +5157,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5083,10 +5185,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5087: checking for gethostbyname" >&5
+echo "configure:5189: checking for gethostbyname" >&5
-#line 5090 "configure"
+#line 5192 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5109,7 +5211,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5129,13 +5231,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5133: checking for gethostbyname in -lnsl" >&5
+echo "configure:5235: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5139 "configure"
+#line 5241 "configure"
@@ -5146,7 +5248,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5175,10 +5277,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5179: checking for connect" >&5
+echo "configure:5281: checking for connect" >&5
-#line 5182 "configure"
+#line 5284 "configure"
     which can conflict with char connect(); below.  */
@@ -5201,7 +5303,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5221,13 +5323,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5225: checking for connect in -lsocket" >&5
+echo "configure:5327: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5231 "configure"
+#line 5333 "configure"
@@ -5238,7 +5340,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5261,10 +5363,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5265: checking for remove" >&5
+echo "configure:5367: checking for remove" >&5
-#line 5268 "configure"
+#line 5370 "configure"
     which can conflict with char remove(); below.  */
@@ -5287,7 +5389,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5307,13 +5409,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5311: checking for remove in -lposix" >&5
+echo "configure:5413: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5317 "configure"
+#line 5419 "configure"
@@ -5324,7 +5426,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5347,10 +5449,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5351: checking for shmat" >&5
+echo "configure:5453: checking for shmat" >&5
-#line 5354 "configure"
+#line 5456 "configure"
     which can conflict with char shmat(); below.  */
@@ -5373,7 +5475,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5393,13 +5495,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5397: checking for shmat in -lipc" >&5
+echo "configure:5499: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5403 "configure"
+#line 5505 "configure"
@@ -5410,7 +5512,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5442,13 +5544,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5446: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5548: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5452 "configure"
+#line 5554 "configure"
@@ -5459,7 +5561,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5497,7 +5599,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5501: checking whether to use Curses" >&5
+echo "configure:5603: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5516,15 +5618,15 @@
 do
-echo "configure:5520: checking for $ac_hdr" >&5
+echo "configure:5622: checking for $ac_hdr" >&5
-#line 5523 "configure"
+#line 5625 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5528: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5630: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5555,10 +5657,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5559: checking curses.h WINDOW structure component" >&5
+echo "configure:5661: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5562 "configure"
+#line 5664 "configure"
 #include <curses.h>
@@ -5567,7 +5669,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5571: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5673: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5576,7 +5678,7 @@
 fi
 rm -f conftest*
-#line 5580 "configure"
+#line 5682 "configure"
 #include <curses.h>
@@ -5585,7 +5687,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5589: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5601,13 +5703,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5605: checking for initscr in -lncurses" >&5
+echo "configure:5707: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5611 "configure"
+#line 5713 "configure"
@@ -5618,7 +5720,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5637,13 +5739,13 @@
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5641: checking for initscr in -lcurses" >&5
+echo "configure:5743: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5647 "configure"
+#line 5749 "configure"
@@ -5654,7 +5756,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5683,13 +5785,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5687: checking for keypad in -lncurses" >&5
+echo "configure:5789: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5693 "configure"
+#line 5795 "configure"
@@ -5700,7 +5802,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5722,13 +5824,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5726: checking for keypad in -lcurses" >&5
+echo "configure:5828: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5732 "configure"
+#line 5834 "configure"
@@ -5739,7 +5841,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5769,13 +5871,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5773: checking for gtty in -lcompat" >&5
+echo "configure:5875: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5779 "configure"
+#line 5881 "configure"
@@ -5786,7 +5888,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5805,13 +5907,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5809: checking for gtty in -lbsd-compat" >&5
+echo "configure:5911: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5815 "configure"
+#line 5917 "configure"
@@ -5822,7 +5924,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5841,13 +5943,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5845: checking for gtty in -lbsd" >&5
+echo "configure:5947: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5851 "configure"
+#line 5953 "configure"
@@ -5858,7 +5960,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5892,12 +5994,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5896: checking for library containing cuserid" >&5
+echo "configure:5998: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5901 "configure"
+#line 6003 "configure"
@@ -5908,7 +6010,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5919,7 +6021,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5923 "configure"
+#line 6025 "configure"
@@ -5930,7 +6032,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5956,10 +6058,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5960: checking for xdrmem_create" >&5
+echo "configure:6062: checking for xdrmem_create" >&5
-#line 5963 "configure"
+#line 6065 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5982,7 +6084,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6000,13 +6102,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6004: checking for xdrmem_create in -lsun" >&5
+echo "configure:6106: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6010 "configure"
+#line 6112 "configure"
@@ -6017,7 +6119,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6036,13 +6138,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6040: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6142: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6046 "configure"
+#line 6148 "configure"
@@ -6053,7 +6155,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6072,13 +6174,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6076: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6178: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6082 "configure"
+#line 6184 "configure"
@@ -6089,7 +6191,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6108,13 +6210,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6112: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6214: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6118 "configure"
+#line 6220 "configure"
@@ -6125,7 +6227,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6159,10 +6261,10 @@
 for ac_func in asprintf
 do
-echo "configure:6163: checking for $ac_func" >&5
+echo "configure:6265: checking for $ac_func" >&5
-#line 6166 "configure"
+#line 6268 "configure"
@@ -6185,7 +6287,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6212,10 +6314,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6216: checking for atan" >&5
+echo "configure:6318: checking for atan" >&5
-#line 6219 "configure"
+#line 6321 "configure"
     which can conflict with char atan(); below.  */
@@ -6238,7 +6340,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6256,13 +6358,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6260: checking for atan in -lm" >&5
+echo "configure:6362: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6266 "configure"
+#line 6368 "configure"
@@ -6273,7 +6375,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6300,10 +6402,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6304: checking for dlsym" >&5
+echo "configure:6406: checking for dlsym" >&5
-#line 6307 "configure"
+#line 6409 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6326,7 +6428,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6344,13 +6446,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6348: checking for dlsym in -ldl" >&5
+echo "configure:6450: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6354 "configure"
+#line 6456 "configure"
@@ -6361,7 +6463,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6388,10 +6490,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6392: checking for iconv" >&5
+echo "configure:6494: checking for iconv" >&5
-#line 6395 "configure"
+#line 6497 "configure"
     which can conflict with char iconv(); below.  */
@@ -6414,7 +6516,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6432,13 +6534,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6436: checking for iconv in -liconv" >&5
+echo "configure:6538: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6442 "configure"
+#line 6544 "configure"
@@ -6449,7 +6551,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6468,13 +6570,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6472: checking for iconv in -lgiconv" >&5
+echo "configure:6574: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6478 "configure"
+#line 6580 "configure"
@@ -6485,7 +6587,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6504,10 +6606,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6508: checking for libiconv" >&5
+echo "configure:6610: checking for libiconv" >&5
-#line 6511 "configure"
+#line 6613 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6530,7 +6632,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6548,13 +6650,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6552: checking for libiconv in -liconv" >&5
+echo "configure:6654: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6558 "configure"
+#line 6660 "configure"
@@ -6565,7 +6667,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6584,13 +6686,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6588: checking for libiconv in -lgiconv" >&5
+echo "configure:6690: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6594 "configure"
+#line 6696 "configure"
@@ -6601,7 +6703,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6638,10 +6740,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6642: checking for socket" >&5
+echo "configure:6744: checking for socket" >&5
-#line 6645 "configure"
+#line 6747 "configure"
     which can conflict with char socket(); below.  */
@@ -6664,7 +6766,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6682,13 +6784,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6686: checking for socket in -lsocket" >&5
+echo "configure:6788: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6692 "configure"
+#line 6794 "configure"
@@ -6699,7 +6801,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6747,7 +6849,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6751: checking for location of zlib includes" >&5
+echo "configure:6853: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6773,15 +6875,15 @@
 do
-echo "configure:6777: checking for $ac_hdr" >&5
+echo "configure:6879: checking for $ac_hdr" >&5
-#line 6780 "configure"
+#line 6882 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6785: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6815,7 +6917,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6819: checking for location of zlib library" >&5
+echo "configure:6921: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6840,13 +6942,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6844: checking for deflate in -lz" >&5
+echo "configure:6946: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6850 "configure"
+#line 6952 "configure"
@@ -6857,7 +6959,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6905,7 +7007,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6909: checking for location of External PROJ.4 includes" >&5
+echo "configure:7011: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6931,15 +7033,15 @@
 do
-echo "configure:6935: checking for $ac_hdr" >&5
+echo "configure:7037: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 6938 "configure"
+#line 7040 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6976,7 +7078,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6980: checking External PROJ.4 version" >&5
+echo "configure:7082: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6984,7 +7086,7 @@
 else
-#line 6988 "configure"
+#line 7090 "configure"
 #include <stdio.h>
@@ -6996,7 +7098,7 @@
 EOF
-if { (eval echo configure:7000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7021,7 +7123,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7025: checking for location of External PROJ.4 library" >&5
+echo "configure:7127: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7046,13 +7148,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7050: checking for pj_get_def in -lproj" >&5
+echo "configure:7152: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7056 "configure"
+#line 7158 "configure"
@@ -7063,7 +7165,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7097,7 +7199,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7101: checking for location of External PROJ.4 data files" >&5
+echo "configure:7203: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7121,14 +7223,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7125: checking for epsg" >&5
+echo "configure:7227: checking for epsg" >&5
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7132: checking for $PROJSHARE/epsg" >&5
+echo "configure:7234: checking for $PROJSHARE/epsg" >&5
@@ -7160,7 +7262,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7164: checking for $ac_word" >&5
+echo "configure:7266: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7200,7 +7302,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7204: checking whether to use regex" >&5
+echo "configure:7306: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7220,7 +7322,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7224: checking for location of regex includes" >&5
+echo "configure:7326: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7246,15 +7348,15 @@
 do
-echo "configure:7250: checking for $ac_hdr" >&5
+echo "configure:7352: checking for $ac_hdr" >&5
-#line 7253 "configure"
+#line 7355 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7288,7 +7390,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7292: checking for location of regex library" >&5
+echo "configure:7394: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7313,10 +7415,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7317: checking for regcomp" >&5
+echo "configure:7419: checking for regcomp" >&5
-#line 7320 "configure"
+#line 7422 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7339,7 +7441,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7366,13 +7468,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7370: checking for regcomp in -lregex" >&5
+echo "configure:7472: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7376 "configure"
+#line 7478 "configure"
@@ -7383,7 +7485,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7433,7 +7535,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7437: checking whether to use Readline" >&5
+echo "configure:7539: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7454,7 +7556,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7458: checking for location of Readline includes" >&5
+echo "configure:7560: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7480,15 +7582,15 @@
 do
-echo "configure:7484: checking for $ac_hdr" >&5
+echo "configure:7586: checking for $ac_hdr" >&5
-#line 7487 "configure"
+#line 7589 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7524,15 +7626,15 @@
 do
-echo "configure:7528: checking for $ac_hdr" >&5
+echo "configure:7630: checking for $ac_hdr" >&5
-#line 7531 "configure"
+#line 7633 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7638: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7566,7 +7668,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7570: checking for location of Readline library" >&5
+echo "configure:7672: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7591,13 +7693,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7595: checking for readline in -lreadline" >&5
+echo "configure:7697: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7601 "configure"
+#line 7703 "configure"
@@ -7608,7 +7710,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7643,13 +7745,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7647: checking for add_history in -lhistory" >&5
+echo "configure:7749: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7653 "configure"
+#line 7755 "configure"
@@ -7660,7 +7762,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7703,7 +7805,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7707: checking whether to use JPEG" >&5
+echo "configure:7809: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7723,7 +7825,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7727: checking for location of JPEG includes" >&5
+echo "configure:7829: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7749,15 +7851,15 @@
 do
-echo "configure:7753: checking for $ac_hdr" >&5
+echo "configure:7855: checking for $ac_hdr" >&5
-#line 7756 "configure"
+#line 7858 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7863: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7791,7 +7893,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7795: checking for location of JPEG library" >&5
+echo "configure:7897: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7818,13 +7920,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7822: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7924: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ljpeg  $LIBS"
-#line 7828 "configure"
+#line 7930 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7835,7 +7937,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7854,13 +7956,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:7858: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7960: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7864 "configure"
+#line 7966 "configure"
@@ -7871,7 +7973,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7920,7 +8022,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7924: checking whether to use GDAL" >&5
+echo "configure:8026: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7938,7 +8040,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7942: checking for $ac_word" >&5
+echo "configure:8044: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7993,14 +8095,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7997 "configure"
+#line 8099 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:8004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -8009,14 +8111,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8013 "configure"
+#line 8115 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8049,7 +8151,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8053: checking whether to use TIFF" >&5
+echo "configure:8155: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8069,7 +8171,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8073: checking for location of TIFF includes" >&5
+echo "configure:8175: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8095,15 +8197,15 @@
 do
-echo "configure:8099: checking for $ac_hdr" >&5
+echo "configure:8201: checking for $ac_hdr" >&5
-#line 8102 "configure"
+#line 8204 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8137,7 +8239,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8141: checking for location of TIFF library" >&5
+echo "configure:8243: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8168,13 +8270,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8274: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8178 "configure"
+#line 8280 "configure"
@@ -8185,7 +8287,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8204,13 +8306,13 @@
-echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8310: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8214 "configure"
+#line 8316 "configure"
@@ -8221,7 +8323,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8240,13 +8342,13 @@
-echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8346: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8250 "configure"
+#line 8352 "configure"
@@ -8257,7 +8359,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8276,13 +8378,13 @@
-echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8382: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8286 "configure"
+#line 8388 "configure"
@@ -8293,7 +8395,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8312,13 +8414,13 @@
-echo "configure:8316: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8418: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8322 "configure"
+#line 8424 "configure"
@@ -8329,7 +8431,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8348,13 +8450,13 @@
-echo "configure:8352: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8454: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8358 "configure"
+#line 8460 "configure"
@@ -8365,7 +8467,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8384,13 +8486,13 @@
-echo "configure:8388: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8490: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8394 "configure"
+#line 8496 "configure"
@@ -8401,7 +8503,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8420,13 +8522,13 @@
-echo "configure:8424: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8526: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8430 "configure"
+#line 8532 "configure"
@@ -8437,7 +8539,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8535,7 +8637,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8539: checking whether to use PNG" >&5
+echo "configure:8641: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8554,7 +8656,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8558: checking for location of PNG includes" >&5
+echo "configure:8660: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8580,15 +8682,15 @@
 do
-echo "configure:8584: checking for $ac_hdr" >&5
+echo "configure:8686: checking for $ac_hdr" >&5
-#line 8587 "configure"
+#line 8689 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8592: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8622,7 +8724,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8626: checking for location of PNG library" >&5
+echo "configure:8728: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8647,13 +8749,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8651: checking for png_read_image in -lpng" >&5
+echo "configure:8753: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8657 "configure"
+#line 8759 "configure"
@@ -8664,7 +8766,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8706,7 +8808,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8710: checking whether to use PostgreSQL" >&5
+echo "configure:8812: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8733,7 +8835,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8737: checking for location of PostgreSQL includes" >&5
+echo "configure:8839: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8759,15 +8861,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8763: checking for $ac_hdr" >&5
+echo "configure:8865: checking for $ac_hdr" >&5
-#line 8766 "configure"
+#line 8868 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8771: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8805,7 +8907,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8809: checking for location of PostgreSQL library" >&5
+echo "configure:8911: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8834,13 +8936,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8838: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8940: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8844 "configure"
+#line 8946 "configure"
@@ -8851,7 +8953,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8870,13 +8972,13 @@
-echo "configure:8874: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8976: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8880 "configure"
+#line 8982 "configure"
@@ -8887,7 +8989,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8906,13 +9008,13 @@
-echo "configure:8910: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9012: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8916 "configure"
+#line 9018 "configure"
@@ -8923,7 +9025,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8942,13 +9044,13 @@
-echo "configure:8946: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9048: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8952 "configure"
+#line 9054 "configure"
@@ -8959,7 +9061,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9016,13 +9118,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9020: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9122: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9026 "configure"
+#line 9128 "configure"
@@ -9033,7 +9135,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9055,13 +9157,13 @@
-echo "configure:9059: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9161: checking for PQcmdTuples in -lpq" >&5
-#line 9065 "configure"
+#line 9167 "configure"
@@ -9072,7 +9174,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9115,7 +9217,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9119: checking whether to use MySQL" >&5
+echo "configure:9221: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9135,7 +9237,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9139: checking for location of MySQL includes" >&5
+echo "configure:9241: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9161,15 +9263,15 @@
 do
-echo "configure:9165: checking for $ac_hdr" >&5
+echo "configure:9267: checking for $ac_hdr" >&5
-#line 9168 "configure"
+#line 9270 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9275: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9206,7 +9308,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9210: checking for location of MySQL library" >&5
+echo "configure:9312: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9237,13 +9339,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9241: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9343: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9247 "configure"
+#line 9349 "configure"
@@ -9254,7 +9356,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9273,13 +9375,13 @@
-echo "configure:9277: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9379: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9283 "configure"
+#line 9385 "configure"
@@ -9290,7 +9392,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9309,13 +9411,13 @@
-echo "configure:9313: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9415: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9319 "configure"
+#line 9421 "configure"
@@ -9326,7 +9428,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9345,13 +9447,13 @@
-echo "configure:9349: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9451: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9355 "configure"
+#line 9457 "configure"
@@ -9362,7 +9464,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9381,13 +9483,13 @@
-echo "configure:9385: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9487: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9391 "configure"
+#line 9493 "configure"
@@ -9398,7 +9500,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9417,13 +9519,13 @@
-echo "configure:9421: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9523: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9427 "configure"
+#line 9529 "configure"
@@ -9434,7 +9536,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9453,13 +9555,13 @@
-echo "configure:9457: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9559: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9463 "configure"
+#line 9565 "configure"
@@ -9470,7 +9572,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9489,13 +9591,13 @@
-echo "configure:9493: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9595: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9499 "configure"
+#line 9601 "configure"
@@ -9506,7 +9608,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9596,7 +9698,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9600: checking for $ac_word" >&5
+echo "configure:9702: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9637,10 +9739,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9641: checking for mysql_server_init" >&5
+echo "configure:9743: checking for mysql_server_init" >&5
-#line 9644 "configure"
+#line 9746 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9663,7 +9765,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9701,7 +9803,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9705: checking whether to use SQLite" >&5
+echo "configure:9807: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9721,7 +9823,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9725: checking for location of SQLite includes" >&5
+echo "configure:9827: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9747,15 +9849,15 @@
 do
-echo "configure:9751: checking for $ac_hdr" >&5
+echo "configure:9853: checking for $ac_hdr" >&5
-#line 9754 "configure"
+#line 9856 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9861: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9798,7 +9900,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9802: checking for location of SQLite library" >&5
+echo "configure:9904: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9825,13 +9927,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9829: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9931: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9835 "configure"
+#line 9937 "configure"
@@ -9842,7 +9944,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9861,13 +9963,13 @@
-echo "configure:9865: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9967: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9871 "configure"
+#line 9973 "configure"
@@ -9878,7 +9980,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9931,7 +10033,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9935: checking whether to use FFMPEG" >&5
+echo "configure:10037: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -9951,7 +10053,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9955: checking for location of FFMPEG includes" >&5
+echo "configure:10057: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9977,15 +10079,15 @@
 do
-echo "configure:9981: checking for $ac_hdr" >&5
+echo "configure:10083: checking for $ac_hdr" >&5
-#line 9984 "configure"
+#line 10086 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9989: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10091: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10021,15 +10123,15 @@
 do
-echo "configure:10025: checking for $ac_hdr" >&5
+echo "configure:10127: checking for $ac_hdr" >&5
-#line 10028 "configure"
+#line 10130 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10033: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10065,15 +10167,15 @@
 do
-echo "configure:10069: checking for $ac_hdr" >&5
+echo "configure:10171: checking for $ac_hdr" >&5
-#line 10072 "configure"
+#line 10174 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10179: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10116,7 +10218,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10120: checking for location of FFMPEG library" >&5
+echo "configure:10222: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10143,13 +10245,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10147: checking for av_free in -lavutil" >&5
+echo "configure:10249: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10153 "configure"
+#line 10255 "configure"
@@ -10160,7 +10262,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10179,13 +10281,13 @@
-echo "configure:10183: checking for av_free in -lavutil" >&5
+echo "configure:10285: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10189 "configure"
+#line 10291 "configure"
@@ -10196,7 +10298,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10241,13 +10343,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10245: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10347: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10251 "configure"
+#line 10353 "configure"
@@ -10258,7 +10360,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10277,13 +10379,13 @@
-echo "configure:10281: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10383: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10287 "configure"
+#line 10389 "configure"
@@ -10294,7 +10396,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10339,13 +10441,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10343: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10445: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10349 "configure"
+#line 10451 "configure"
@@ -10356,7 +10458,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10375,13 +10477,13 @@
-echo "configure:10379: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10481: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10385 "configure"
+#line 10487 "configure"
@@ -10392,7 +10494,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10451,7 +10553,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10455: checking whether to use OpenGL" >&5
+echo "configure:10557: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10485,7 +10587,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10489: checking for location of OpenGL includes" >&5
+echo "configure:10591: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10511,15 +10613,15 @@
 do
-echo "configure:10515: checking for $ac_hdr" >&5
+echo "configure:10617: checking for $ac_hdr" >&5
-#line 10518 "configure"
+#line 10620 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10553,7 +10655,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10557: checking for location of OpenGL library" >&5
+echo "configure:10659: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10582,13 +10684,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10586: checking for glBegin in -lGL" >&5
+echo "configure:10688: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10592 "configure"
+#line 10694 "configure"
@@ -10599,7 +10701,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10618,13 +10720,13 @@
-echo "configure:10622: checking for glBegin in -lGL" >&5
+echo "configure:10724: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10628 "configure"
+#line 10730 "configure"
@@ -10635,7 +10737,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10654,13 +10756,13 @@
-echo "configure:10658: checking for glBegin in -lGL" >&5
+echo "configure:10760: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10664 "configure"
+#line 10766 "configure"
@@ -10671,7 +10773,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10690,13 +10792,13 @@
-echo "configure:10694: checking for glBegin in -lGL" >&5
+echo "configure:10796: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10700 "configure"
+#line 10802 "configure"
@@ -10707,7 +10809,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10769,13 +10871,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10773: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10875: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10779 "configure"
+#line 10881 "configure"
@@ -10786,7 +10888,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10805,13 +10907,13 @@
-echo "configure:10809: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10911: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10815 "configure"
+#line 10917 "configure"
@@ -10822,7 +10924,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10866,10 +10968,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10870: checking for glXCreatePbuffer" >&5
+echo "configure:10972: checking for glXCreatePbuffer" >&5
-#line 10873 "configure"
+#line 10975 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -10892,7 +10994,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -10914,10 +11016,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10918: checking for glXCreateGLXPixmap" >&5
+echo "configure:11020: checking for glXCreateGLXPixmap" >&5
-#line 10921 "configure"
+#line 11023 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -10940,7 +11042,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -10979,7 +11081,7 @@
-echo "configure:10983: checking for location of OpenGL includes" >&5
+echo "configure:11085: checking for location of OpenGL includes" >&5
@@ -11005,15 +11107,15 @@
 do
-echo "configure:11009: checking for $ac_hdr" >&5
+echo "configure:11111: checking for $ac_hdr" >&5
-#line 11012 "configure"
+#line 11114 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11119: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11048,10 +11150,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11052: checking for glBegin" >&5
+echo "configure:11154: checking for glBegin" >&5
-#line 11055 "configure"
+#line 11157 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11074,7 +11176,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11089,10 +11191,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11093: checking for gluBeginCurve" >&5
+echo "configure:11195: checking for gluBeginCurve" >&5
-#line 11096 "configure"
+#line 11198 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11115,7 +11217,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11159,7 +11261,7 @@
-echo "configure:11163: checking for location of OpenGL includes" >&5
+echo "configure:11265: checking for location of OpenGL includes" >&5
@@ -11185,15 +11287,15 @@
 do
-echo "configure:11189: checking for $ac_hdr" >&5
+echo "configure:11291: checking for $ac_hdr" >&5
-#line 11192 "configure"
+#line 11294 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11227,7 +11329,7 @@
-echo "configure:11231: checking for location of OpenGL library" >&5
+echo "configure:11333: checking for location of OpenGL library" >&5
@@ -11252,18 +11354,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11256: checking for OpenGL library" >&5
+echo "configure:11358: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11260 "configure"
+#line 11362 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11287,18 +11389,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11291: checking for GLU library" >&5
+echo "configure:11393: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11295 "configure"
+#line 11397 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11347,7 +11449,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11351: checking whether to use Tcl/Tk" >&5
+echo "configure:11453: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11367,7 +11469,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11371: checking for location of Tcl/Tk includes" >&5
+echo "configure:11473: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11393,15 +11495,15 @@
 do
-echo "configure:11397: checking for $ac_hdr" >&5
+echo "configure:11499: checking for $ac_hdr" >&5
-#line 11400 "configure"
+#line 11502 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11438,15 +11540,15 @@
 do
-echo "configure:11442: checking for $ac_hdr" >&5
+echo "configure:11544: checking for $ac_hdr" >&5
-#line 11445 "configure"
+#line 11547 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11479,7 +11581,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11483: checking Tcl version" >&5
+echo "configure:11585: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11487,7 +11589,7 @@
 else
-#line 11491 "configure"
+#line 11593 "configure"
 #include <stdio.h>
@@ -11499,7 +11601,7 @@
 EOF
-if { (eval echo configure:11503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11517,7 +11619,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11521: checking Tk version" >&5
+echo "configure:11623: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11525,7 +11627,7 @@
 else
-#line 11529 "configure"
+#line 11631 "configure"
 #include <stdio.h>
@@ -11537,7 +11639,7 @@
 EOF
-if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11568,7 +11670,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11572: checking for location of Tcl/Tk library" >&5
+echo "configure:11674: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11589,22 +11691,14 @@
 TCLLIB=
 TKLIB=
+MACOSX_ARCHS_TCLTK=
 # Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
-# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
-TCLTKAQUA_IS64BIT=
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua
 if test "$OPENGL_AQUA" = 1 ; then
-    temp_CFLAGS="$CFLAGS"
+    save_CFLAGS="$CFLAGS"
     CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-    # can't save LDFLAGS, need to remember arch flags to insert back later
-    temp_ARCHES=
-    for a in x86_64 ppc64
-    do
-        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
-            temp_ARCHES="$temp_ARCHES -arch $a"
-        fi
-    done
+    save_LDFLAGS="$LDFLAGS"
     LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
 fi
@@ -11616,13 +11710,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11620: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11714: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11626 "configure"
+#line 11720 "configure"
@@ -11633,7 +11727,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11652,13 +11746,13 @@
-echo "configure:11656: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11750: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11662 "configure"
+#line 11756 "configure"
@@ -11669,7 +11763,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11696,13 +11790,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11700: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11794: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11706 "configure"
+#line 11800 "configure"
@@ -11713,7 +11807,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11732,13 +11826,13 @@
-echo "configure:11736: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11830: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11742 "configure"
+#line 11836 "configure"
@@ -11749,7 +11843,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11776,13 +11870,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11780: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11874: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11786 "configure"
+#line 11880 "configure"
@@ -11793,7 +11887,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11812,13 +11906,13 @@
-echo "configure:11816: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11910: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11822 "configure"
+#line 11916 "configure"
 #include "confdefs.h"
@@ -11829,7 +11923,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11907,13 +12001,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11911: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12005: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11917 "configure"
+#line 12011 "configure"
@@ -11924,7 +12018,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11943,13 +12037,13 @@
-echo "configure:11947: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12041: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11953 "configure"
+#line 12047 "configure"
@@ -11960,7 +12054,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11987,13 +12081,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11991: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12085: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 11997 "configure"
+#line 12091 "configure"
@@ -12004,7 +12098,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12023,13 +12117,13 @@
-echo "configure:12027: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12121: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12033 "configure"
+#line 12127 "configure"
@@ -12040,7 +12134,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12067,13 +12161,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12071: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12165: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12077 "configure"
+#line 12171 "configure"
@@ -12084,7 +12178,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12103,13 +12197,13 @@
-echo "configure:12107: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12201: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12113 "configure"
+#line 12207 "configure"
@@ -12120,7 +12214,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12193,11 +12287,68 @@
 # restore CFLAGS/LDLFAGS from Aqua 64bit strip
 # only Tcl/Tk-based makefiles will strip 64bit out during compile
-   CFLAGS="$temp_CFLAGS"
-   LDFLAGS="$temp_ARCHES $LDFLAGS"
+   CFLAGS="$save_CFLAGS"
+   LDFLAGS="$save_LDFLAGS"
 fi
 TCLTKLIBS="$TKLIB $TCLLIB"
+# check for available OSX archs in TclTk
+if test -n "$MACOSX_ARCHS" ; then
+  LDFLAGS=
+  CFLAGS=
+  tlib=`echo "$TCLLIB" | sed -E -e 's/-l//' -e 's/^ +//' -e 's/ +$//'`
+  for a in i386 ppc x86_64 ppc64
+  do
+    # add only if in MACOSX_ARCHS
+    echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
+echo "configure:12308: checking for Tcl_Init in -l$tlib" >&5
+ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 12314 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char Tcl_Init();
+int main() {
+Tcl_Init()
+; return 0; }
+EOF
+if { (eval echo configure:12325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+      if test -n "`echo "$MACOSX_ARCHS" | grep $a`" ; then
+        MACOSX_ARCHS_TCLTK="$MACOSX_ARCHS_TCLTK -arch $a"
+      fi
+else
+  echo "$ac_t""no" 1>&6
+fi
+  done
+fi
 cat >> confdefs.h <<\EOF
 #define HAVE_TCLTK 1
 EOF
@@ -12219,7 +12370,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12223: checking whether to use ODBC" >&5
+echo "configure:12374: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12238,7 +12389,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12242: checking for location of ODBC includes" >&5
+echo "configure:12393: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12264,15 +12415,15 @@
 do
-echo "configure:12268: checking for $ac_hdr" >&5
+echo "configure:12419: checking for $ac_hdr" >&5
-#line 12271 "configure"
+#line 12422 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12306,7 +12457,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12310: checking for location of ODBC library" >&5
+echo "configure:12461: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12331,13 +12482,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12335: checking for SQLConnect in -lodbc" >&5
+echo "configure:12486: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12341 "configure"
+#line 12492 "configure"
@@ -12348,7 +12499,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12373,13 +12524,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12377: checking for SQLConnect in -liodbc" >&5
+echo "configure:12528: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12383 "configure"
+#line 12534 "configure"
@@ -12390,7 +12541,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12415,11 +12566,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12419: checking for ODBC library" >&5
+echo "configure:12570: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12423 "configure"
+#line 12574 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12427,7 +12578,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12476,7 +12627,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12480: checking whether to use FFTW" >&5
+echo "configure:12631: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12495,7 +12646,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12499: checking for location of FFTW includes" >&5
+echo "configure:12650: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12521,15 +12672,15 @@
 do
-echo "configure:12525: checking for $ac_hdr" >&5
+echo "configure:12676: checking for $ac_hdr" >&5
-#line 12528 "configure"
+#line 12679 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12557,15 +12708,15 @@
 do
-echo "configure:12561: checking for $ac_hdr" >&5
+echo "configure:12712: checking for $ac_hdr" >&5
-#line 12564 "configure"
+#line 12715 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12593,15 +12744,15 @@
 do
-echo "configure:12597: checking for $ac_hdr" >&5
+echo "configure:12748: checking for $ac_hdr" >&5
-#line 12600 "configure"
+#line 12751 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12647,7 +12798,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12651: checking for location of FFTW library" >&5
+echo "configure:12802: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12672,13 +12823,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12676: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12827: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12682 "configure"
+#line 12833 "configure"
@@ -12689,7 +12840,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12714,13 +12865,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12718: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12869: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12724 "configure"
+#line 12875 "configure"
@@ -12731,7 +12882,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12756,13 +12907,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12760: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12911: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12766 "configure"
+#line 12917 "configure"
@@ -12773,7 +12924,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12830,7 +12981,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12834: checking whether to use BLAS" >&5
+echo "configure:12985: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12851,7 +13002,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12855: checking for location of BLAS includes" >&5
+echo "configure:13006: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12871,7 +13022,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12875: checking for location of BLAS library" >&5
+echo "configure:13026: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12897,15 +13048,15 @@
 do
-echo "configure:12901: checking for $ac_hdr" >&5
+echo "configure:13052: checking for $ac_hdr" >&5
-#line 12904 "configure"
+#line 13055 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12940,13 +13091,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12944: checking for dnrm2_ in -lblas" >&5
+echo "configure:13095: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12950 "configure"
+#line 13101 "configure"
@@ -12957,7 +13108,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12976,13 +13127,13 @@
-echo "configure:12980: checking for dnrm2_ in -lblas" >&5
+echo "configure:13131: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12986 "configure"
+#line 13137 "configure"
@@ -12993,7 +13144,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13037,13 +13188,13 @@
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13041: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13192: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13047 "configure"
+#line 13198 "configure"
@@ -13054,7 +13205,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13069,13 +13220,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13073: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13224: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13079 "configure"
+#line 13230 "configure"
@@ -13086,7 +13237,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13101,13 +13252,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13105: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13256: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13111 "configure"
+#line 13262 "configure"
@@ -13118,7 +13269,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13157,22 +13308,23 @@
 fi
 # BLAS in Apple vecLib framework? (Mac OS-X)
-if test -n "$MACOSX_APP"; then
+#  not dependent on APP build
+#if test -n "$MACOSX_APP"; then
 if test $blas_ok = no; then
 	vlib_flags="-framework vecLib"
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13167: checking for sgemm in $vlib_flags" >&5
+echo "configure:13319: checking for sgemm in $vlib_flags" >&5
-#line 13169 "configure"
+#line 13321 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13185,18 +13337,18 @@
 	echo "$ac_t""$blas_ok" 1>&6
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13194: checking for sgemm_ in -lblas" >&5
+echo "configure:13346: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13200 "configure"
+#line 13352 "configure"
@@ -13207,7 +13359,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13222,13 +13374,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13226: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13378: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13232 "configure"
+#line 13384 "configure"
@@ -13239,7 +13391,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13254,13 +13406,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13258: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13410: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13264 "configure"
+#line 13416 "configure"
@@ -13271,7 +13423,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13305,13 +13457,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13309: checking for acosp in -lsunmath" >&5
+echo "configure:13461: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13315 "configure"
+#line 13467 "configure"
@@ -13322,7 +13474,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13337,13 +13489,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13341: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13493: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13347 "configure"
+#line 13499 "configure"
@@ -13354,7 +13506,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13384,13 +13536,13 @@
 # Generic BLAS library
-echo "configure:13388: checking for sgemm_ in -lblas" >&5
+echo "configure:13540: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13394 "configure"
+#line 13546 "configure"
@@ -13401,7 +13553,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13440,7 +13592,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13444: checking whether to use LAPACK" >&5
+echo "configure:13596: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13465,7 +13617,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13469: checking for location of LAPACK includes" >&5
+echo "configure:13621: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13485,7 +13637,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13489: checking for location of LAPACK library" >&5
+echo "configure:13641: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13511,15 +13663,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13515: checking for $ac_hdr" >&5
+echo "configure:13667: checking for $ac_hdr" >&5
-#line 13518 "configure"
+#line 13670 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13675: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13551,10 +13703,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13555: checking for dsegv_" >&5
+echo "configure:13707: checking for dsegv_" >&5
-#line 13558 "configure"
+#line 13710 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13577,7 +13729,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13604,13 +13756,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13608: checking for desgv_ in -llapack" >&5
+echo "configure:13760: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13614 "configure"
+#line 13766 "configure"
@@ -13621,7 +13773,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13653,13 +13805,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13657: checking for dgesv_ in -llapack" >&5
+echo "configure:13809: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13663 "configure"
+#line 13815 "configure"
@@ -13670,7 +13822,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13689,13 +13841,13 @@
-echo "configure:13693: checking for dgesv_ in -llapack" >&5
+echo "configure:13845: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13699 "configure"
+#line 13851 "configure"
@@ -13706,7 +13858,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13762,7 +13914,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13766: checking whether to use Motif" >&5
+echo "configure:13918: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13781,7 +13933,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13785: checking for location of Motif includes" >&5
+echo "configure:13937: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13807,15 +13959,15 @@
 do
-echo "configure:13811: checking for $ac_hdr" >&5
+echo "configure:13963: checking for $ac_hdr" >&5
-#line 13814 "configure"
+#line 13966 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13849,7 +14001,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13853: checking for location of Motif library" >&5
+echo "configure:14005: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13874,13 +14026,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13878: checking for XmStringCreate in -lXm" >&5
+echo "configure:14030: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13884 "configure"
+#line 14036 "configure"
@@ -13891,7 +14043,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13932,7 +14084,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13936: checking whether to use Cairo" >&5
+echo "configure:14088: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13958,7 +14110,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13962: checking for location of cairo includes" >&5
+echo "configure:14114: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13984,15 +14136,15 @@
 do
-echo "configure:13988: checking for $ac_hdr" >&5
+echo "configure:14140: checking for $ac_hdr" >&5
-#line 13991 "configure"
+#line 14143 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14028,7 +14180,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14032: checking for location of cairo library" >&5
+echo "configure:14184: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14048,7 +14200,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14052: checking for cairo linking flags" >&5
+echo "configure:14204: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14064,10 +14216,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14068: checking for cairo_create" >&5
+echo "configure:14220: checking for cairo_create" >&5
-#line 14071 "configure"
+#line 14223 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14090,7 +14242,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14124,10 +14276,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14128: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14280: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14131 "configure"
+#line 14283 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14150,7 +14302,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14192,7 +14344,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14196: checking whether to use GLw" >&5
+echo "configure:14348: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14211,7 +14363,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14215: checking for location of GLw includes" >&5
+echo "configure:14367: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14237,15 +14389,15 @@
 do
-echo "configure:14241: checking for $ac_hdr" >&5
+echo "configure:14393: checking for $ac_hdr" >&5
-#line 14244 "configure"
+#line 14396 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14401: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14273,15 +14425,15 @@
 do
-echo "configure:14277: checking for $ac_hdr" >&5
+echo "configure:14429: checking for $ac_hdr" >&5
-#line 14280 "configure"
+#line 14432 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14285: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14437: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14321,7 +14473,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14325: checking for location of GLw library" >&5
+echo "configure:14477: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14346,13 +14498,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14350: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14502: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14356 "configure"
+#line 14508 "configure"
@@ -14363,7 +14515,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14388,13 +14540,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14392: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14544: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14398 "configure"
+#line 14550 "configure"
@@ -14405,7 +14557,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14430,13 +14582,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14434: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14586: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14440 "configure"
+#line 14592 "configure"
@@ -14447,7 +14599,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14472,13 +14624,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14476: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14628: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14482 "configure"
+#line 14634 "configure"
@@ -14489,7 +14641,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14514,13 +14666,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14518: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14670: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14524 "configure"
+#line 14676 "configure"
@@ -14531,7 +14683,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14556,13 +14708,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14560: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14712: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14566 "configure"
+#line 14718 "configure"
@@ -14573,7 +14725,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14600,13 +14752,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14604: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14756: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14610 "configure"
+#line 14762 "configure"
@@ -14617,7 +14769,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14636,13 +14788,13 @@
-echo "configure:14640: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14792: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14646 "configure"
+#line 14798 "configure"
@@ -14653,7 +14805,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14680,13 +14832,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14684: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14836: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14690 "configure"
+#line 14842 "configure"
@@ -14697,7 +14849,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14716,13 +14868,13 @@
-echo "configure:14720: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14872: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14726 "configure"
+#line 14878 "configure"
@@ -14733,7 +14885,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14846,7 +14998,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14850: checking whether to use FreeType" >&5
+echo "configure:15002: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14865,7 +15017,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14869: checking for location of FreeType includes" >&5
+echo "configure:15021: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14891,15 +15043,15 @@
 do
-echo "configure:14895: checking for $ac_hdr" >&5
+echo "configure:15047: checking for $ac_hdr" >&5
-#line 14898 "configure"
+#line 15050 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15055: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14933,7 +15085,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14937: checking for location of FreeType library" >&5
+echo "configure:15089: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14958,13 +15110,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14962: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15114: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14968 "configure"
+#line 15120 "configure"
@@ -14975,7 +15127,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15016,7 +15168,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15020: checking whether to use NLS" >&5
+echo "configure:15172: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15036,10 +15188,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15040: checking for gettext" >&5
+echo "configure:15192: checking for gettext" >&5
-#line 15043 "configure"
+#line 15195 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15062,7 +15214,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15080,13 +15232,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15084: checking for gettext in -lintl" >&5
+echo "configure:15236: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15090 "configure"
+#line 15242 "configure"
@@ -15097,7 +15249,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15132,7 +15284,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15136: checking whether to use C++" >&5
+echo "configure:15288: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15148,7 +15300,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15152: checking for $ac_word" >&5
+echo "configure:15304: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15177,7 +15329,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15181: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15333: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15188,12 +15340,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15192 "configure"
+#line 15344 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15219,19 +15371,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15223: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15375: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15228: checking whether we are using GNU C++" >&5
+echo "configure:15380: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15249,7 +15401,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15253: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15405: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15290,7 +15442,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15294: checking whether to use openDWG" >&5
+echo "configure:15446: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15310,7 +15462,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15314: checking for location of openDGW includes" >&5
+echo "configure:15466: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15336,15 +15488,15 @@
 do
-echo "configure:15340: checking for $ac_hdr" >&5
+echo "configure:15492: checking for $ac_hdr" >&5
-#line 15343 "configure"
+#line 15495 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15348: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15378,7 +15530,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15382: checking for location of openDWG library" >&5
+echo "configure:15534: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15425,7 +15577,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15429: checking for special C compiler options needed for large files" >&5
+echo "configure:15581: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15433,7 +15585,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15437 "configure"
+#line 15589 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15449,7 +15601,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15453: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15458,7 +15610,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15462 "configure"
+#line 15614 "configure"
@@ -15474,7 +15626,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15478: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15630: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15494,11 +15646,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15498: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15650: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15502 "configure"
+#line 15654 "configure"
@@ -15514,14 +15666,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15518: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15670: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15525 "configure"
+#line 15677 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15539,7 +15691,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15543: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15558,11 +15710,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15562: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15714: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15566 "configure"
+#line 15718 "configure"
@@ -15578,14 +15730,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15582: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15734: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15589 "configure"
+#line 15741 "configure"
 #define _LARGE_FILES 1
@@ -15603,7 +15755,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15607: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15759: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15622,25 +15774,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15626: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15778: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15630 "configure"
+#line 15782 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15637: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15789: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15644 "configure"
+#line 15796 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15649,7 +15801,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15653: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15805: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15670,10 +15822,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15674: checking if system supports Large Files at all" >&5
+echo "configure:15826: checking if system supports Large Files at all" >&5
-#line 15677 "configure"
+#line 15829 "configure"
 #include <stdio.h>
@@ -15705,7 +15857,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15709: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15861: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15734,13 +15886,14 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15738: checking whether to use Python" >&5
+echo "configure:15890: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
+MACOSX_ARCHS_PYTHON=
 if test "$with_python" = "no" ; then
@@ -15754,7 +15907,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15758: checking for $ac_word" >&5
+echo "configure:15911: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15796,15 +15949,15 @@
 do
-echo "configure:15800: checking for $ac_hdr" >&5
+echo "configure:15953: checking for $ac_hdr" >&5
-#line 15803 "configure"
+#line 15956 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15961: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15839,13 +15992,20 @@
     # With Python library directory
     PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
+    # shouldn't have arch flags in C/LD flags on OSX
+    do
+      PYTHONCFLAGS=`echo "$PYTHONCFLAGS" | sed -E "s/-arch +$a//g"`
+      PYTHONLDFLAGS=`echo "$PYTHONLDFLAGS" | sed -E "s/-arch +$a//g"`
+    done
   fi
   # look for the swig program
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15849: checking for $ac_word" >&5
+echo "configure:16009: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15880,6 +16040,21 @@
     { echo "configure: error: *** couldn't find swig" 1>&2; exit 1; }
   fi
+  # check for available OSX archs in Python, assume framework
+  if test -n "$MACOSX_ARCHS" ; then
+    pylib=`"$PY_CONFIG" --prefix`/Python
+    pylibinfo=`file "$pylib"`
+    do
+      if test -n "`echo \"$pylibinfo\" | grep \"library $a\"`" ; then
+          MACOSX_ARCHS_PYTHON="$MACOSX_ARCHS_PYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # Done checking Python
@@ -15888,16 +16063,18 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15895: checking whether to use wxWidgets" >&5
+echo "configure:16071: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
+MACOSX_ARCHS_WXPYTHON=
 if test "$with_wxwidgets" = "no" ; then
@@ -15911,7 +16088,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15915: checking for $ac_word" >&5
+echo "configure:16092: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15959,7 +16136,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15963: checking wxWidgets version" >&5
+echo "configure:16140: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15982,15 +16159,15 @@
 do
-echo "configure:15986: checking for $ac_hdr" >&5
+echo "configure:16163: checking for $ac_hdr" >&5
-#line 15989 "configure"
+#line 16166 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15994: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16023,6 +16200,30 @@
  # With wxWidgets library directory
  WXWIDGETSLIB=`"$WX_CONFIG" --libs`
+ do
+   WXWIDGETSCXXFLAGS=`echo "$WXWIDGETSCXXFLAGS" | sed -E "s/-arch +$a//g"`
+   WXWIDGETSCPPFLAGS=`echo "$WXWIDGETSCPPFLAGS" | sed -E "s/-arch +$a//g"`
+   WXWIDGETSLIB=`echo "$WXWIDGETSLIB" | sed -E "s/-arch +$a//g"`
+ done
+  # check for available OSX archs in wxPython
+    wxver=`"$WX_CONFIG" --version`
+    wxlib=`"$WX_CONFIG" --prefix`/lib/lib`"$WX_CONFIG" --basename`-`echo "$wxver" | cut -d . -f1,2`.dylib
+    wxlibinfo=`file "$wxlib"`
+    do
+      if test -n "`echo \"$wxlibinfo\" | grep \"library $a\"`" ; then
+        if test -n "`echo \"$MACOSX_ARCHS\" | grep $a`" ; then
+          MACOSX_ARCHS_WXPYTHON="$MACOSX_ARCHS_WXPYTHON -arch $a"
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
@@ -16031,6 +16232,7 @@
 # Done checking wxWidgets
 USE_TERMIO=
@@ -16153,6 +16355,8 @@
 s%@NAME_VER@%$NAME_VER%g
 s%@LIB_VER@%$LIB_VER%g
 s%@MACOSX_APP@%$MACOSX_APP%g
+s%@MACOSX_ARCHS@%$MACOSX_ARCHS%g
+s%@MACOSX_SDK@%$MACOSX_SDK%g
 s%@INSTDIR@%$INSTDIR%g
 s%@GRASS_LIB_PREFIX@%$GRASS_LIB_PREFIX%g
 s%@GRASS_LIB_SUFFIX@%$GRASS_LIB_SUFFIX%g
@@ -16272,7 +16476,7 @@
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
 s%@TCLTKLIBS@%$TCLTKLIBS%g
 s%@TCL_VERSION@%$TCL_VERSION%g
-s%@TCLTKAQUA_IS64BIT@%$TCLTKAQUA_IS64BIT%g
+s%@MACOSX_ARCHS_TCLTK@%$MACOSX_ARCHS_TCLTK%g
 s%@ODBCINC@%$ODBCINC%g
 s%@ODBCLIB@%$ODBCLIB%g
 s%@FFTWINC@%$FFTWINC%g
@@ -16305,12 +16509,14 @@
 s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
 s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
 s%@USE_PYTHON@%$USE_PYTHON%g
+s%@MACOSX_ARCHS_PYTHON@%$MACOSX_ARCHS_PYTHON%g
 s%@WX_CONFIG@%$WX_CONFIG%g
 s%@WXVERSION@%$WXVERSION%g
 s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
 s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
 s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
 s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
+s%@MACOSX_ARCHS_WXPYTHON@%$MACOSX_ARCHS_WXPYTHON%g
 s%@USE_TERMIO@%$USE_TERMIO%g
 s%@STRIPFLAG@%$STRIPFLAG%g
 s%@GRASS_HOME@%$GRASS_HOME%g
@@ -16584,8 +16790,17 @@
 echo "  OpenGL platform:             ${OPENGL_TYPE}"
+echo ""
 echo "  MacOSX application:         `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
+echo "  MacOSX architectures:       ${MACOSX_ARCHS}"
+echo "  MacOSX SDK:                 ${MACOSX_SDK}"
 echo ""
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/configure.in	2009-09-07 18:34:33 UTC (rev 39076)
@@ -148,6 +148,55 @@
 AC_MSG_RESULT("$enable_macosx_app")
 AC_SUBST(MACOSX_APP)
+# Check for MacOSX archs
+AC_MSG_CHECKING(for MacOSX architectures)
+MACOSX_ARCHS=
+if test -z "$with_macosx_archs" ; then
+  AC_MSG_RESULT(no)
+else
+  for a in $with_macosx_archs
+  do
+    # check if valid arch?
+    case "$a" in
+      i386|ppc|x86_64|ppc64)
+        MACOSX_ARCHS="$MACOSX_ARCHS -arch $a"
+    esac
+  done
+  AC_MSG_RESULT([$MACOSX_ARCHS])
+  LDFLAGS="$LDFLAGS $MACOSX_ARCHS"
+  CFLAGS="$CFLAGS $MACOSX_ARCHS"
+  CXXFLAGS="$CXXFLAGS $MACOSX_ARCHS"
+fi
+AC_SUBST(MACOSX_ARCHS)
+# Done checking MacOSX archs
+# Check for MacOSX SDK
+AC_MSG_CHECKING(for MacOSX SDK)
+MACOSX_SDK=
+if test -z "$with_macosx_sdk" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_CHECK_FILE($with_macosx_sdk/SDKSettings.plist, [
+    MACOSX_SDK="-isysroot $with_macosx_sdk"],[
+    AC_MSG_ERROR([*** specified SDK does not exist or is not a SDK])])
+  LDFLAGS="$LDFLAGS $MACOSX_SDK"
+  CFLAGS="$CFLAGS $MACOSX_SDK"
+  CXXFLAGS="$CXXFLAGS $MACOSX_SDK"
+fi
+AC_SUBST(MACOSX_SDK)
+# Done checking MacOSX SDK
 # Set INST_DIR
 if test -n "$MACOSX_APP" ; then
@@ -176,6 +225,15 @@
 LOC_ARG_WITH(cxx, C++, no)
 #LOC_ARG_WITH(g77, GNU Fortran 77, no)
+AC_ARG_WITH(macosx-archs,
+[  --with-macosx-archs[=arch list]
+                          compile multiple architectures on MacOSX, ie.
+                          universal.  Valid architectures are i386, ppc,
+                          x86_64 and ppc64. (default: no [native])],, with_macosx_archs="no")
+AC_ARG_WITH(macosx-sdk,
+[  --with-macosx-sdk[=path/sdk]
+                          compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
 LOC_ARG_WITH(jpeg, JPEG)
 LOC_ARG_WITH(tiff, TIFF)
 LOC_ARG_WITH(png, PNG)
@@ -200,17 +258,22 @@
 LOC_ARG_WITH(regex, regex)
 AC_ARG_WITH(gdal,
-[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')])
+[  --with-gdal[=path/gdal-config]
+                          enable GDAL/OGR support (gdal-config with path,
+                          e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(python,
-[  --with-python[=path/python-config] enable support for Python SWIG bindings and wxGUI Python extensions \
-(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
-default: no)],, with_python="no")
+[  --with-python[=path/python-config]
+                          enable support for Python SWIG bindings and wxGUI
+                          Python extensions (python-config with path, e.g.
+                          '--with-python=/usr/bin/python2.5-config',
+                          default: no)],, with_python="no")
 AC_ARG_WITH(wxwidgets,
-[  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
-e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
+[  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)],, with_wxwidgets="no")
 # With includes and libs options
@@ -1189,22 +1252,14 @@
 TCLLIB=
 TKLIB=
+MACOSX_ARCHS_TCLTK=
 # Can't test tcl/tk libs on 64bit OSX Aqua for now
-# assume that if OpenGL Aqua, then user specifies TclTk Aqua,
-# as there is no test for Tcl/Tk Aqua and Tck/Tk X11 won't work
-TCLTKAQUA_IS64BIT=
+# assume that if OpenGL Aqua, then user specifies TclTk Aqua
 if test "$OPENGL_AQUA" = 1 ; then
-    temp_CFLAGS="$CFLAGS"
+    save_CFLAGS="$CFLAGS"
     CFLAGS="`echo \"$CFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
-    # can't save LDFLAGS, need to remember arch flags to insert back later
-    temp_ARCHES=
-    for a in x86_64 ppc64
-    do
-        if test -n "`echo \"$LDFLAGS\" | grep -E -e '-arch +'$a`" ; then
-            temp_ARCHES="$temp_ARCHES -arch $a"
-        fi
-    done
+    save_LDFLAGS="$LDFLAGS"
     LDFLAGS="`echo \"$LDFLAGS\" | sed -E 's/-arch +x86_64//g' | sed -E 's/-arch +ppc64//g'`"
 fi
@@ -1225,11 +1280,32 @@
 fi
+  LDFLAGS=
+  CFLAGS=
+  do
+    AC_CHECK_LIB($tlib, Tcl_Init, [
+      fi
+      ],, -arch $a $MACOSX_SDK $TCLTKLIBPATH)
+  done
+fi
 AC_DEFINE(HAVE_TCLTK)
 fi # $USE_TCLTK
@@ -1241,7 +1317,7 @@
 AC_SUBST(TCLTKLIBPATH)
 AC_SUBST(TCLTKLIBS)
 AC_SUBST(TCL_VERSION)
-AC_SUBST(TCLTKAQUA_IS64BIT)
+AC_SUBST(MACOSX_ARCHS_TCLTK)
 # Done checking Tcl/Tk
 # Enable ODBC option
@@ -1360,7 +1436,8 @@
 fi
 	save_LIBS="$LIBS"
@@ -1370,7 +1447,7 @@
 	AC_MSG_RESULT($blas_ok)
 	LIBS="$save_LIBS"
 fi
-fi # $MACOSX_APP
+#fi # $MACOSX_APP
@@ -1716,6 +1793,7 @@
 PYTHONLDFLAGS=
 SWIG=
 USE_PYTHON=
   AC_MSG_RESULT(no)
@@ -1739,6 +1817,13 @@
+    do
+    done
   fi
@@ -1748,6 +1833,21 @@
     AC_MSG_ERROR([*** couldn't find swig])
   fi
+    do
+        fi
+      fi
+    done
+  fi
 AC_SUBST(PYTHONINC)
@@ -1755,6 +1855,7 @@
 AC_SUBST(PYTHONLDFLAGS)
 AC_SUBST(SWIG)
 AC_SUBST(USE_PYTHON)
+AC_SUBST(MACOSX_ARCHS_PYTHON)
@@ -1765,6 +1866,7 @@
 WXWIDGETSCPPFLAGS=
 WXWIDGETSLIB=
 USE_WXWIDGETS=
   AC_MSG_RESULT(no)
@@ -1814,6 +1916,30 @@
+ do
+ done
+    do
+        fi
+      fi
+    done
+  fi
 fi # $USE_WXWIDGETS
 AC_SUBST(WXVERSION)
@@ -1821,6 +1947,7 @@
 AC_SUBST(WXWIDGETSCPPFLAGS)
 AC_SUBST(WXWIDGETSLIB)
 AC_SUBST(USE_WXWIDGETS)
+AC_SUBST(MACOSX_ARCHS_WXPYTHON)
@@ -1858,7 +1985,10 @@
 LOC_MSG([  Building shared libraries:   ${shared_ok}])
 LOC_MSG([  64bit support:               ${do64bit}])
 LOC_MSG([  OpenGL platform:             ${OPENGL_TYPE}])
+LOC_MSG()
 LOC_MSG_USE(MacOSX application,MACOSX_APP)
+LOC_MSG([  MacOSX architectures:       ${MACOSX_ARCHS}])
+LOC_MSG([  MacOSX SDK:                 ${MACOSX_SDK}])
 LOC_MSG()
 LOC_MSG_USE(NVIZ,USE_TOGL)
 LOC_MSG()
Modified: grass/branches/releasebranch_6_4/display/d.what.vect/Makefile
--- grass/branches/releasebranch_6_4/display/d.what.vect/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/display/d.what.vect/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -12,12 +12,11 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
-ifeq ($(OPENGL_AQUA),1)
-ifneq ($(TCLTKAQUA_IS64BIT),1)
-CFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(CFLAGS)))
-LDFLAGS := $(subst -arch ppc64,,$(subst -arch x86_64,,$(LDFLAGS)))
+# substitute OSX arch flags for tcltk
+ifneq ($(MACOSX_ARCHS),)
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_TCLTK)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_TCLTK)
 endif
-endif
 default: cmd
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/Makefile
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -2,12 +2,12 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
-ifeq ($(findstring darwin,$(ARCH)),darwin)
-ifneq ($(WX_ISOSX64BIT),1)
+# substitute OSX arch flags for wxpython
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+CXXFLAGS := $(subst $(MACOSX_ARCHS),,$(CXXFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
 endif
-endif
 LIB_NAME = grass6_wxnviz
Modified: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/Makefile
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -2,12 +2,12 @@
 endif
-endif
 LIB_NAME = grass6_wxvdigit
Modified: grass/branches/releasebranch_6_4/include/Make/Platform.make.in
--- grass/branches/releasebranch_6_4/include/Make/Platform.make.in	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/include/Make/Platform.make.in	2009-09-07 18:34:33 UTC (rev 39076)
@@ -171,8 +171,7 @@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
 TCLVERSION          = @TCL_VERSION@
-# set from configure when 64bit TclTk Aqua becomes possible on OSX
-TCLTKAQUA_IS64BIT    = @TCLTKAQUA_IS64BIT@
+MACOSX_ARCHS_TCLTK  = @MACOSX_ARCHS_TCLTK@
 #FFTW:
 FFTWINC             = @FFTWINC@
@@ -217,6 +216,7 @@
 PYTHONLDFLAGS       = @PYTHONLDFLAGS@
 SWIG                = @SWIG@
 USE_PYTHON          = @USE_PYTHON@
+MACOSX_ARCHS_PYTHON = @MACOSX_ARCHS_PYTHON@
 #wxWidgets
 WXVERSION           = @WXVERSION@
@@ -224,8 +224,7 @@
 WXWIDGETSCPPFLAGS   = @WXWIDGETSCPPFLAGS@
 WXWIDGETSLIB        = @WXWIDGETSLIB@
 USE_WXWIDGETS       = @USE_WXWIDGETS@
-# set from configure when 64bit wxWidgets becomes possible on OSX
-WX_ISOSX64BIT       =
+MACOSX_ARCHS_WXPYTHON = @MACOSX_ARCHS_WXPYTHON@
 #regex
 REGEXINCPATH        = @REGEXINCPATH@
@@ -244,6 +243,8 @@
 MINGW		    = @MINGW32@
 MACOSX_APP	    = @MACOSX_APP@
+MACOSX_ARCHS    = @MACOSX_ARCHS@
+MACOSX_SDK      = @MACOSX_SDK@
 # Cross compilation
 CROSS_COMPILING = @CROSS_COMPILING@
Modified: grass/branches/releasebranch_6_4/include/Make/Python.make
--- grass/branches/releasebranch_6_4/include/Make/Python.make	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/include/Make/Python.make	2009-09-07 18:34:33 UTC (rev 39076)
@@ -1,11 +1,11 @@
 PYTHON = python
-PYMOD_LD = $(CXX) -shared
-PYMOD_LDFLAGS = $(SHLIB_LDFLAGS) -L$(ARCH_LIBDIR)
-PYMOD_LDFLAGS := $(PYMOD_LDFLAGS) -bundle -undefined dynamic_lookup
+PYMOD_LD = $(CXX) -bundle -undefined dynamic_lookup
+PYMOD_LDFLAGS := $(SHLIB_LDFLAGS) -L$(ARCH_LIBDIR)
 else
-PYMOD_LDFLAGS := $(PYMOD_LDFLAGS) $(PYTHONLDFLAGS)
+PYMOD_LD = $(CXX) -shared
+PYMOD_LDFLAGS := $(SHLIB_LDFLAGS) -L$(ARCH_LIBDIR) $(PYTHONLDFLAGS)
 endif
 PYMOD_CFLAGS = $(SHLIB_CFLAGS) $(PYTHONINC) $(PYTHON_CFLAGS)
Modified: grass/branches/releasebranch_6_4/lib/form/Makefile
--- grass/branches/releasebranch_6_4/lib/form/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/lib/form/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -20,12 +20,11 @@
 endif
-endif
 default: lib $(GTCLTKFORM)
Modified: grass/branches/releasebranch_6_4/swig/python/Makefile
--- grass/branches/releasebranch_6_4/swig/python/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/swig/python/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -5,6 +5,12 @@
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+# substitute OSX arch flags for python
+CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_PYTHON)
+LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_PYTHON)
+endif
 # doxygen:
 DOXNAME=
 DOXINPUT=grasspython.dox
Modified: grass/branches/releasebranch_6_4/vector/v.digit/Makefile
--- grass/branches/releasebranch_6_4/vector/v.digit/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/vector/v.digit/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -11,12 +11,11 @@
 endif
-endif
 AUXDIR := $(GISBASE)/etc/v.digit
 TCLFILES := $(patsubst %,$(AUXDIR)/%,$(wildcard *.tcl))
Modified: grass/branches/releasebranch_6_4/vector/v.what/Makefile
--- grass/branches/releasebranch_6_4/vector/v.what/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/vector/v.what/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -12,12 +12,11 @@
 endif
-endif
 default: cmd
Modified: grass/branches/releasebranch_6_4/visualization/nviz/src/Makefile
--- grass/branches/releasebranch_6_4/visualization/nviz/src/Makefile	2009-09-07 17:40:10 UTC (rev 39075)
+++ grass/branches/releasebranch_6_4/visualization/nviz/src/Makefile	2009-09-07 18:34:33 UTC (rev 39076)
@@ -18,10 +18,11 @@
 endif
 OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
 endif
 endif
 SURFLIB = $(OGSFLIB)
