[GRASS-SVN] r39077 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Sep 7 15:09:00 EDT 2009
Author: martinl
Date: 2009-09-07 15:08:58 -0400 (Mon, 07 Sep 2009)
New Revision: 39077
grass/trunk/gui/wxpython/gui_modules/help.py
grass/trunk/gui/wxpython/wxgui.py
fix wxGUI menu tree window (all items activated)
Modified: grass/trunk/gui/wxpython/gui_modules/help.py
--- grass/trunk/gui/wxpython/gui_modules/help.py 2009-09-07 18:34:33 UTC (rev 39076)
+++ grass/trunk/gui/wxpython/gui_modules/help.py 2009-09-07 19:08:58 UTC (rev 39077)
@@ -165,11 +165,15 @@
return # should not happen
data = self.tree.GetPyData(self.tree.GetSelected())
- if not data or not data.has_key('command'):
+ if not data:
return
+ handler = 'self.parent.' + data['handler'].lstrip('self.')
+ if data['command']:
+ eval(handler)(event = None, cmd = data['command'].split())
+ else:
+ eval(handler)(None)
- gcmd.RunCommand(data['command'])
if self.closeOnRun.IsChecked():
self.OnCloseWindow(None)
@@ -197,8 +201,13 @@
return
- self.statusbar.SetStatusText(data['command'] + ' -- ' + data['help'], 0)
+ label = data['command'] + ' -- ' + data['help']
+ else:
+ label = data['help']
+ self.statusbar.SetStatusText(label, 0)
def OnShowItem(self, event):
"""!Highlight first found item in menu tree"""
if len(self.tree.itemsMarked) > 0:
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-09-07 18:34:33 UTC (rev 39076)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-09-07 19:08:58 UTC (rev 39077)
@@ -428,7 +428,8 @@
Return command as a list"""
layer = None
- cmd = self.menucmd[event.GetId()]
+ if event:
+ cmd = self.menucmd[event.GetId()]
try:
cmdlist = cmd.split(' ')
@@ -460,9 +461,10 @@
cmd = self.GetMenuCmd(event)
self.goutput.RunCmd(cmd, switchPage=True)
- def OnMenuCmd(self, event):
+ def OnMenuCmd(self, event, cmd = ''):
"""!Parse command selected from menu"""
- cmd = self.GetMenuCmd(event)
+ if event:
+ cmd = self.GetMenuCmd(event)
menuform.GUI().ParseCommand(cmd, parentframe=self)
def OnNewVector(self, event):
