[GRASS-SVN] r39161 - in grass/trunk: include lib/gis
lib/vector/Vlib vector/v.info
svn_grass at osgeo.org
Sat Sep 12 19:18:18 EDT 2009
Author: martinl
Date: 2009-09-12 19:18:17 -0400 (Sat, 12 Sep 2009)
New Revision: 39161
grass/trunk/include/vector.h
grass/trunk/lib/gis/parser.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/close_ogr.c
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/open_nat.c
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/vector/v.info/main.c
initial steps towards direct OGR support (map/layer <-> OGR dsn/layer)
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/include/vector.h 2009-09-12 23:18:17 UTC (rev 39161)
@@ -212,7 +212,9 @@
int Vect_legal_filename(const char *);
int Vect_set_open_level(int);
int Vect_open_old(struct Map_info *, const char *, const char *);
+int Vect_open_old2(struct Map_info *, const char *, const char *, const char *);
int Vect_open_old_head(struct Map_info *, const char *, const char *);
+int Vect_open_old_head2(struct Map_info *, const char *, const char *, const char *);
int Vect_open_new(struct Map_info *, const char *, int);
int Vect_open_update(struct Map_info *, const char *, const char *);
int Vect_open_update_head(struct Map_info *, const char *, const char *);
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/gis/parser.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -626,10 +626,10 @@
break;
case G_OPT_V_FIELD:
Opt->key = "layer";
- Opt->type = TYPE_INTEGER;
+ Opt->type = TYPE_STRING;
Opt->required = NO;
Opt->answer = "1";
- Opt->label = _("Layer number");
+ Opt->label = _("Layer number or name");
Opt->description =
_("A single vector map can be connected to multiple database "
"tables. This number determines which table to use.");
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/close.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -51,9 +51,9 @@
- \brief Close vector data file
+ \brief Close vector map
- \param Map vector map to be closed
+ \param Map pointer to Map_info
\return 0 on success
\return non-zero on error
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -23,9 +23,9 @@
#include <ogr_api.h>
- \brief Close OGR layer
+ \brief Close vector map (OGR dsn & layer)
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/header.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -213,20 +213,27 @@
- \brief Get full map name
- Allocated string should be freed by G_free().
- \return poiter to map name (name at mapset)
+ \brief Get full vector map name (i.e., "name at mapset")
+ Allocated string should be freed by G_free().
+ \param Map pointer to Map_info structure
+ \return pointer to map name (name at mapset)
const char *Vect_get_full_name(const struct Map_info *Map)
char *ptr;
ptr = (char *)G_malloc(strlen(Map->name) + strlen(Map->mapset) + 2);
- sprintf(ptr, "%s@%s", Map->name, Map->mapset);
- return (ptr);
+ if (strlen(Map->mapset) > 0) {
+ sprintf(ptr, "%s@%s", Map->name, Map->mapset);
+ else {
+ sprintf(ptr, "%s", Map->name);
+ return ptr;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -1,7 +1,7 @@
* \file vector/Vlib/open.c
- * \brief Vector library - Open vector map
+ * \brief Vector library - Open vector map (native or OGR format)
* Higher level functions for reading/writing/manipulating vectors.
@@ -14,6 +14,7 @@
* Higgins.
* \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
#include <grass/config.h>
#include <stdlib.h>
#include <stdio.h>
@@ -21,10 +22,14 @@
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
-#include <grass/glocale.h>
#include <grass/gis.h>
#include <grass/vector.h>
+#include <grass/glocale.h>
+ \brief Number of available levels
#define MAX_OPEN_LEVEL 2
static int open_old_dummy()
@@ -68,7 +73,6 @@
* \brief Predetermine level at which a vector map will be opened for
* reading.
@@ -80,12 +84,12 @@
* NOTE: This should only be used to set when you wish to force a
* lower level open. If you require a higher level, then just check
- * the return to verify the level instead of forcing it. This is
+ * the return to verify the level instead of forcing it. This is
* because future releases will have higher levels which will be
* downward compatible and which your programs should support by
* default.
- * \param level vector (topo) level
+ * \param level vector access level
* \return 0 on success
* \return 1 on error
@@ -95,7 +99,7 @@
Open_level = level;
if (Open_level < 1 || Open_level > MAX_OPEN_LEVEL) {
- G_warning(_("Programmer requested unknown open level %d"),
+ G_warning(_("Programmer requested unknown access level %d"),
Open_level);
Open_level = 0;
return 1;
@@ -105,22 +109,22 @@
- * \brief Open old vector for reading.
+ * \brief Open existing vector map for reading (internal use only)
* In case of error, the functions respect fatal error settings.
- * \param[out] Map vector map
+ * \param[out] Map pointer to Map_info structure
* \param name name of vector map to open
- * \param mapset mapset name
- * \param update open for update
- * \param head_only read only header info from 'head', 'dbln', 'topo', 'cidx' is not opened. The header may be opened on level 2 only.
+ * \param mapset mapset name ("" for search path)
+ * \param update non-zero to open for update otherwise read-only mode
+ * \param head_only read only header info from 'head', 'dbln', 'topo',
+ * 'cidx' is not opened. The header may be opened on level 2 only.
* \return level of openness (1, 2)
* \return -1 in error
-int
-Vect__open_old(struct Map_info *Map, const char *name, const char *mapset,
- int update, int head_only)
+int Vect__open_old(struct Map_info *Map, const char *name, const char *mapset, const char *layer,
+ int update, int head_only)
char buf[GNAME_MAX + 10], buf2[GMAPSET_MAX + 10], xname[GNAME_MAX],
xmapset[GMAPSET_MAX], errmsg[2000];
@@ -149,17 +153,18 @@
/* initialize Map->plus */
dig_init_plus(&(Map->plus));
+ /* check OGR mapset */
ogr_mapset = 0;
if (G_name_is_fully_qualified(name, xname, xmapset)) {
- if (strcmp(xmapset, "OGR") == 0) {
+ if (strcasecmp(xmapset, "ogr") == 0) {
/* unique OGR mapset detected */
G_debug(1, "OGR mapset detected");
ogr_mapset = 1;
- Map->fInfo.ogr.dsn = xname;
- Map->fInfo.ogr.layer_name = NULL; /* no layer to be open */
+ Map->fInfo.ogr.dsn = G_store(xname);
+ Map->fInfo.ogr.layer_name = G_store(layer); /* no layer to be open */
else {
- sprintf(buf, "%s/%s", GV_DIRECTORY, xname);
+ sprintf(buf, "%s/%s", GV_DIRECTORY, xname);
sprintf(buf2, "%s@%s", GV_COOR_ELEMENT, xmapset);
Map->name = G_store(xname);
@@ -167,7 +172,7 @@
else {
sprintf(buf, "%s/%s", GV_DIRECTORY, name);
- sprintf(buf2, "%s", GV_COOR_ELEMENT);
+ sprintf(buf2, "%s", GV_COOR_ELEMENT);
Map->name = G_store(name);
if (mapset)
@@ -176,15 +181,24 @@
Map->mapset = G_store("");
- fmapset = G_find_vector2(Map->name, Map->mapset);
- if (fmapset == NULL) {
- sprintf(errmsg, _("Vector map <%s> not found"),
- Vect_get_full_name(Map));
- fatal_error(ferror, errmsg);
- return -1;
+ if (!ogr_mapset) {
+ /* try to find vector map (not for OGR mapset) */
+ fmapset = G_find_vector2(Map->name, Map->mapset);
+ if (fmapset == NULL) {
+ sprintf(errmsg, _("Vector map <%s> not found"),
+ Vect_get_full_name(Map));
+ fatal_error(ferror, errmsg);
+ return -1;
+ Map->mapset = G_store(fmapset);
- Map->mapset = G_store(fmapset);
+ else { /* OGR mapset */
+ if (update) {
+ sprintf(errmsg, _("OGR layer cannot be opened for update"));
+ return -1;
Map->location = G_store(G_location());
Map->gisdbase = G_store(G_gisdbase());
@@ -225,34 +239,37 @@
Map->format = format;
+ /* projection info */
Vect_set_proj(Map, G_projection());
Vect_set_zone(Map, G_zone());
- /* Read vector head */
+ /* read vector head (ignored for OGR mapset) */
if (!ogr_mapset && Vect__read_head(Map) != 0) {
sprintf(errmsg,
_("Unable to open vector map <%s> on level %d. "
"Try to rebuild vector topology by v.build."),
Vect_get_full_name(Map), level_request);
- G_warning(_("Unable to read head file of vector <%s>"),
+ G_warning(_("Unable to read header file of vector map <%s>"),
/* zone not set */
if (Vect_get_zone(Map) == -1)
G_debug(1, "Level request = %d", level_request);
- /* There are only 2 possible open levels, 1 and 2. Try first to open 'support' files
- * (topo,sidx,cidx), these files are the same for all formats.
- * If it is not possible and requested level is 2, return error,
- * otherwise call Open_old_array[format][1], to open remaining files/sources (level 1)
+ /* There are only 2 possible open levels, 1 and 2. Try first to
+ * open 'support' files (topo,sidx,cidx), these files are the same
+ * for all formats. If it is not possible and requested level is
+ * 2, return error, otherwise call Open_old_array[format][1], to
+ * open remaining files/sources (level 1)
- /* Try to open support files if level was not requested or requested level is 2 (format independent) */
+ /* Try to open support files if level was not requested or
+ * requested level is 2 (format independent) */
if (level_request == 0 || level_request == 2) {
- level = 2; /* We expect success */
+ level = 2; /* we expect success */
/* open topo */
ret = Vect_open_topo(Map, head_only);
if (ret == 1) { /* topo file is not available */
@@ -321,12 +338,12 @@
else {
- level = 1; /* I.e. requested level is 1 */
+ level = 1; /* i.e. requested level is 1 */
- /* Open level 1 files / sources (format specific) */
- if (!head_only) { /* No need to open coordinates */
- if (0 != (*Open_old_array[format][1]) (Map, update)) { /* Cannot open */
+ /* open level 1 files / sources (format specific) */
+ if (!head_only || ogr_mapset) { /* no need to open coordinates */
+ if (0 != (*Open_old_array[format][1]) (Map, update)) { /* cannot open */
if (level == 2) { /* support files opened */
dig_free_plus(&(Map->plus));
dig_spidx_free(&(Map->plus));
@@ -344,7 +361,7 @@
Map->head.with_z = Map->plus.with_z; /* take dimension from topo */
- /* Set status */
+ /* set status */
Map->open = VECT_OPEN_CODE;
Map->level = level;
Map->head_only = head_only;
@@ -372,17 +389,18 @@
Map->plus.built = GV_BUILD_NONE;
else { /* level 2, with topology */
- Map->plus.built = GV_BUILD_ALL; /* Highest level of topology for level 2 */
+ Map->plus.built = GV_BUILD_ALL; /* highest level of topology for level 2 */
Map->plus.do_uplist = 0;
+ /* read db links */
Map->dblnk = Vect_new_dblinks_struct();
- Vect_read_dblinks(Map);
+ if (!ogr_mapset)
+ Vect_read_dblinks(Map);
- /* Open history file */
+ /* open history file */
sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
if (update) { /* native only */
Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
if (Map->hist_fp == NULL) {
@@ -408,11 +426,11 @@
- if (!head_only) { /* Cannot rewind if not fully opened */
+ if (!head_only) { /* cannot rewind if not fully opened */
Vect_rewind(Map);
- /* Delete support files if native format was opened for update (not head_only) */
+ /* delete support files if native format was opened for update (not head_only) */
if (update && !head_only) {
char file_path[2000];
struct stat info;
@@ -440,8 +458,8 @@
- * \param name name of vector map
+ * \param name name of vector map to open
* \return level of openness [1, 2, (3)]
@@ -449,28 +467,32 @@
int Vect_open_old(struct Map_info *Map, const char *name, const char *mapset)
- return (Vect__open_old(Map, name, mapset, 0, 0));
+ return (Vect__open_old(Map, name, mapset, NULL, 0, 0));
+int Vect_open_old2(struct Map_info *Map, const char *name, const char *mapset, const char *layer)
+ return (Vect__open_old(Map, name, mapset, layer, 0, 0));
* \brief Open existing vector for reading/writing
* \param name name of vector map to update
* \return -1 on error
-int
-Vect_open_update(struct Map_info *Map, const char *name, const char *mapset)
+int Vect_open_update(struct Map_info *Map, const char *name, const char *mapset)
int ret;
- ret = Vect__open_old(Map, name, mapset, 1, 0);
+ ret = Vect__open_old(Map, name, mapset, NULL, 1, 0);
if (ret > 0) {
Map->plus.do_uplist = 1;
@@ -482,7 +504,6 @@
Map->plus.alloc_upnodes = 0;
/* read spatial index */
/* Build spatial index from topo */
/* Vect_build_sidx_from_topo(Map); */
@@ -497,36 +518,42 @@
- * \param name name of vector map to read
+ * \param name name of vector map to read (dsn for OGR)
+ * \param layer layer name (only for OGR)
int Vect_open_old_head(struct Map_info *Map, const char *name, const char *mapset)
- return (Vect__open_old(Map, name, mapset, 0, 1));
+ return (Vect__open_old(Map, name, mapset, NULL, 0, 1));
+int Vect_open_old_head2(struct Map_info *Map, const char *name, const char *mapset, const char *layer)
+ return (Vect__open_old(Map, name, mapset, layer, 0, 1));
- * \brief Open old vector head for updating (mostly for database link updates)
+ * \brief Open header file of existing vector map for updating (mostly
+ * for database link updates)
-int
-Vect_open_update_head(struct Map_info *Map, const char *name,
- const char *mapset)
+int Vect_open_update_head(struct Map_info *Map, const char *name,
+ const char *mapset)
int ret;
- ret = Vect__open_old(Map, name, mapset, 1, 1);
+ ret = Vect__open_old(Map, name, mapset, NULL, 1, 1);
if (ret > 0) { /* Probably not important */
@@ -543,7 +570,7 @@
- * \brief Open new vector for reading/writing
+ * \brief Create new vector map for reading/writing
* \param[in,out] Map pointer to Map_info structure
@@ -559,8 +586,11 @@
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
G_debug(2, "Vect_open_new(): name = %s", name);
+ /* init header */
+ Vect__init_head(Map);
- Vect__init_head(Map);
+ /* error handling */
ferror = Vect_get_fatal_error();
Vect_set_fatal_error(GV_FATAL_EXIT);
@@ -611,7 +641,7 @@
Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
- sprintf(errmsg, _("Unable to open history file for vector map <%s>"),
+ sprintf(errmsg, _("Unable to open history file of vector map <%s>"),
return (-1);
@@ -694,13 +724,17 @@
- * \brief Gets maptype (native, shape, postgis)
+ * \brief Gets vector map format (as string)
* Note: string is allocated by G_store(). Free allocated memory with
* G_free().
- * \param Map vector map
+ * Currently are implemeted:
+ * - Native format (native)
+ * - OGR format (ogr)
+ * \param Map pointer to Map_info structure
* \return maptype string on success
* \return error message on error
@@ -725,7 +759,7 @@
- * \brief Open topo file
+ * \brief Open topology file ('topo')
* \param head_only open only head
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -1,17 +1,17 @@
- \file open_nat.c
- \brief Vector library - open vector map (native format)
- Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
- \author Original author CERL, probably Dave Gerdes or Mike Higgins.
- \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \file vector/Vlib/open_nat.c
+ \brief Vector library - open vector map (native format) - level 1
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2001-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+ \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
@@ -27,15 +27,15 @@
static int check_coor(struct Map_info *Map);
- \brief Open existing vector map
+ \brief Open existing vector map (level 1)
+ Map->name and Map->mapset must be set before.
+ \param Map poiter to Map_info structure
+ \param update non-zero for write mode, otherwise read-only
- Map->name and Map->mapset must be set before.
- \param Map poiter to vector map
- \param update non-zero for write mode, otherwise read-only
- \return 0 success
- \return -1 error
+ \return 0 success
+ \return -1 error
int V1_open_old_nat(struct Map_info *Map, int update)
@@ -54,7 +54,8 @@
G_fopen_old(buf, GV_COOR_ELEMENT, Map->mapset);
if (Map->dig_fp.file == NULL) {
- G_warning(_("Unable to open coor file for vector map <%s>"), Map->name);
+ G_warning(_("Unable to open coor file for vector map <%s>"),
return -1;
@@ -78,10 +79,10 @@
- \brief Open/Create new vector map (level 1)
+ \brief Create new vector map (level 1)
- \param name map name
+ \param name vector map name to be created
\param with_z 2D or 3D (unused?)
\return 0 success
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -1,17 +1,20 @@
- \file open_ogr.c
+ \file vector/Vlib/open_ogr.c
- \brief Vector library - open vector map (OGR format)
+ \brief Vector library - Open OGR layer as vector map layer
+ \todo Implement V1_open_new_ogr()
+ \author Update to GRASS 7.0 Martin Landa <landa.martin gmail.com> (2009)
@@ -28,14 +31,15 @@
+ \brief Open existing OGR layer (level 1 - without feature index file)
+ Map->name, Map->mapset, Map->fInfo.ogr.dsn and
+ Map->fInfo.ogr.layer_name must be set before.
- \param[out] Map pointer to vector map
+ \param[in,out] Map pointer to Map_info structure
(write mode is currently not supported)
\return 0 success
\return -1 error
@@ -43,27 +47,39 @@
int i, layer, nLayers;
OGRDataSourceH Ogr_ds;
- OGRLayerH Ogr_layer = NULL;
+ OGRLayerH Ogr_layer;
OGRFeatureDefnH Ogr_featuredefn;
+ Ogr_layer = NULL;
if (update) {
- G_warning(_("OGR format cannot be updated"));
+ G_warning(_("Write mode is not supported for OGR format"));
return -1;
+ if (!Map->fInfo.ogr.dsn) {
+ G_warning(_("OGR datasource not defined"));
+ return -1;
+ if (!Map->fInfo.ogr.layer_name) {
+ G_warning(_("OGR layer not defined"));
+ return -1;
G_debug(2, "V1_open_old_ogr(): dsn = %s layer = %s", Map->fInfo.ogr.dsn,
Map->fInfo.ogr.layer_name);
OGRRegisterAll();
- /*Data source handle */
+ /* open data source handle */
Ogr_ds = OGROpen(Map->fInfo.ogr.dsn, FALSE, NULL);
if (Ogr_ds == NULL)
G_fatal_error(_("Unable to open OGR data source '%s'"),
Map->fInfo.ogr.dsn);
Map->fInfo.ogr.ds = Ogr_ds;
- /* Layer number */
+ /* get layer number */
layer = -1;
nLayers = OGR_DS_GetLayerCount(Ogr_ds);
G_debug(2, "%d layers found in data source", nLayers);
@@ -71,40 +87,39 @@
for (i = 0; i < nLayers; i++) {
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name)
- == 0) {
+ if (strcmp(OGR_FD_GetName(Ogr_featuredefn), Map->fInfo.ogr.layer_name) == 0) {
layer = i;
break;
if (layer == -1) {
OGR_DS_Destroy(Ogr_ds);
- G_fatal_error(_("Unable to open layer <%s>"),
+ G_fatal_error(_("Unable to open OGR layer <%s>"),
G_debug(2, "OGR layer %d opened", layer);
Map->fInfo.ogr.layer = Ogr_layer;
Map->fInfo.ogr.lines = NULL;
Map->fInfo.ogr.lines_types = NULL;
Map->fInfo.ogr.lines_alloc = 0;
Map->fInfo.ogr.lines_num = 0;
Map->fInfo.ogr.lines_next = 0;
Map->head.with_z = WITHOUT_Z; /* TODO: 3D */
Map->fInfo.ogr.feature_cache = NULL;
Map->fInfo.ogr.feature_cache_id = -1; /* FID >= 0 */
return (0);
- \brief Open OGR specific level 2 files (feature index)
+ \brief Open existing OGR layer (level 2 - feature index)
- \param[out] Map pointer to Map_info structure
\return 0 success
\return -1 error
@@ -118,7 +133,7 @@
int Version_Major, Version_Minor, Back_Major, Back_Minor, byte_order;
G_debug(3, "V2_open_old_ogr()");
sprintf(elem, "%s/%s", GV_DIRECTORY, Map->name);
dig_file_init(&fp);
fp.file = G_fopen_old(elem, GV_FIDX_ELEMENT, Map->mapset);
@@ -136,8 +151,7 @@
Back_Major = buf[2];
Back_Minor = buf[3];
byte_order = buf[4];
/* check version numbers */
if (Version_Major > 5 || Version_Minor > 0) {
if (Back_Major > 5 || Back_Minor > 0) {
@@ -180,7 +194,6 @@
G_debug(3, "%d records read from fidx", Map->fInfo.ogr.offset_num);
Map->fInfo.ogr.next_line = 1;
return 0;
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c 2009-09-12 22:31:00 UTC (rev 39160)
+++ grass/trunk/vector/v.info/main.c 2009-09-12 23:18:17 UTC (rev 39161)
@@ -3,7 +3,7 @@
* MODULE: v.info
* AUTHOR(S): CERL, updated to 5.7 by Markus Neteler
- * Update to 7.0 by Martin Landa
+ * Update to 7.0 by Martin Landa <landa.martin gmail.com> (2009)
* Support for level 1 by Markus Metz (2009)
* PURPOSE: Print vector map info
@@ -47,18 +47,20 @@
if (level1_flag) {
Vect_set_open_level(1); /* no topology */
if (topo_flag)
- G_warning(_("Vector map requested on level1 (flag -t ignored)"));
+ G_warning(_("Vector map requested on level 1 (flag -t ignored)"));
topo_flag = 0;
- else
- Vect_set_open_level(2); /* topology requested */
if (level1_flag) {
- Vect_open_old(&Map, input_opt, ""); /* level 1 */
+ Vect_open_old2(&Map, input_opt, "", field_opt); /* level 1 */
level_one_info(&Map);
- else
- Vect_open_old_head(&Map, input_opt, ""); /* level 2 */
+ else {
+ /* level 2 */
+ if (Vect_open_old_head2(&Map, input_opt, "", field_opt) < 2)
+ G_fatal_error(_("Unable to open vector map <%s> on level 2"),
+ Vect_get_full_name(&Map));
if (hist_flag) {
char buf[1001];
@@ -92,4 +94,3 @@
return (EXIT_SUCCESS);
