[GRASS-SVN] r39162 - in grass/trunk/display: d.rast d.vect
Sat Sep 12 20:02:41 EDT 2009
Author: martinl
Date: 2009-09-12 20:02:41 -0400 (Sat, 12 Sep 2009)
New Revision: 39162
   grass/trunk/display/d.rast/main.c
   grass/trunk/display/d.vect/main.c
cosmetics in d.rast/vect module desc
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c	2009-09-12 23:18:17 UTC (rev 39161)
+++ grass/trunk/display/d.rast/main.c	2009-09-13 00:02:41 UTC (rev 39162)
@@ -52,10 +52,8 @@
     module = G_define_module();
     G_add_keyword(_("display"));
     G_add_keyword(_("raster"));
-    module->description =
-	_("Displays and overlays raster map layers "
-	  "in the active display frame on the graphics monitor.");
+    module->description = _("Displays raster map layer in the active map display window.");
     /* set up command line */
     map = G_define_standard_option(G_OPT_R_MAP);
     map->description = _("Raster map to be displayed");
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2009-09-12 23:18:17 UTC (rev 39161)
+++ grass/trunk/display/d.vect/main.c	2009-09-13 00:02:41 UTC (rev 39162)
@@ -3,9 +3,8 @@
  * MODULE:       d.vect
  * AUTHOR(S):    CERL, Radim Blazek, others
- * PURPOSE:      Display the binary vector file that the user wants displayed
- *               on top of the current image.
- * COPYRIGHT:    (C) 2004-2008 by the GRASS Development Team
+ * PURPOSE:      Display the vector map in map display
+ * COPYRIGHT:    (C) 2004-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -118,10 +117,8 @@
     G_add_keyword(_("vector"));
-	_("Displays vector data in the active "
-	  "frame on the graphics monitor.");
+    module->description = _("Displays vector map layer in the active map display window.");
     map_opt = G_define_standard_option(G_OPT_V_MAP);
     display_opt = G_define_option();
