[GRASS-SVN] r39172 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Sep 13 06:58:56 EDT 2009
Author: mmetz
Date: 2009-09-13 06:58:56 -0400 (Sun, 13 Sep 2009)
New Revision: 39172
grass/trunk/lib/vector/Vlib/README
orthography
Modified: grass/trunk/lib/vector/Vlib/README
--- grass/trunk/lib/vector/Vlib/README 2009-09-13 10:58:15 UTC (rev 39171)
+++ grass/trunk/lib/vector/Vlib/README 2009-09-13 10:58:56 UTC (rev 39172)
@@ -11,8 +11,8 @@
is called. Plus_head.cidx_up_to_date is set to 1 if Category index is created.
Any later call to Vect_write_line() / Vect_rewrite_line() / Vect_delete_line() resets
Plus_head.cidx_up_to_date to 0 and doesn't update category index.
-All modules using update on level 2 mus call full build, i.e. Vect_build(), at the end.
+All modules using update on level 2 must call full build, i.e. Vect_build(), at the end.
All features without category are written to category index of field 0.
-In category index is stored also type of feture, that make s possible to find areas
-without centroid throug category index.
+The category index also stores type of feature, that makes it possible to find areas
+without centroid through category index.
