[GRASS-SVN] r39173 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Sun Sep 13 07:00:12 EDT 2009
Author: mmetz
Date: 2009-09-13 07:00:12 -0400 (Sun, 13 Sep 2009)
New Revision: 39173
grass/trunk/lib/vector/diglib/plus.c
grass/trunk/lib/vector/diglib/plus_struct.c
grass/trunk/lib/vector/diglib/spindex.c
grass/trunk/lib/vector/diglib/spindex_rw.c
3D initialization, cosmetics
Modified: grass/trunk/lib/vector/diglib/plus.c
--- grass/trunk/lib/vector/diglib/plus.c 2009-09-13 10:58:56 UTC (rev 39172)
+++ grass/trunk/lib/vector/diglib/plus.c 2009-09-13 11:00:12 UTC (rev 39173)
@@ -39,7 +39,6 @@
Plus->Version_Minor = 0;
Plus->Back_Major = 0;
Plus->Back_Minor = 0;
- Plus->with_z = 0;
Plus->off_t_size = 0;
Modified: grass/trunk/lib/vector/diglib/plus_struct.c
--- grass/trunk/lib/vector/diglib/plus_struct.c 2009-09-13 10:58:56 UTC (rev 39172)
+++ grass/trunk/lib/vector/diglib/plus_struct.c 2009-09-13 11:00:12 UTC (rev 39173)
@@ -175,12 +175,12 @@
if (0 >= dig__fread_port_O(&(ptr->offset), 1, fp, Plus->off_t_size))
return (-1);
- /* First node */
+ /* first node */
if (ptr->type & (GV_POINTS | GV_LINES | GV_KERNEL))
if (0 >= dig__fread_port_P(&(ptr->N1), 1, fp))
return -1;
- /* Second node, for points/centroids not needed */
+ /* second node, for points/centroids not needed */
if (ptr->type & (GV_LINE | GV_BOUNDARY)) {
if (0 >= dig__fread_port_P(&(ptr->N2), 1, fp))
return -1;
@@ -215,7 +215,7 @@
if (0 >= dig__fread_port_P(&vol, 1, fp))
return -1;
- /* Bounding box */
+ /* bounding box */
if (ptr->type & (GV_LINE | GV_BOUNDARY | GV_FACE)) {
if (0 >= dig__fread_port_D(&(ptr->N), 1, fp))
return -1;
@@ -261,7 +261,7 @@
ptr = Plus->Line[n];
- /* If NULL i.e. dead write just 0 instead of type */
+ /* if NULL i.e. dead write just 0 instead of type */
if (ptr == NULL) {
G_debug(3, " line is dead -> write 0 only");
ch = 0;
@@ -280,12 +280,12 @@
if (0 >= dig__fwrite_port_O(&(ptr->offset), 1, fp, Plus->off_t_size))
return (-1);
- /* First node */
+ /* first node */
if (0 >= dig__fwrite_port_P(&(ptr->N1), 1, fp))
return (-1);
if (0 >= dig__fwrite_port_P(&(ptr->N2), 1, fp))
return (-1);
@@ -317,7 +317,7 @@
if (0 >= dig__fwrite_port_P(&vol, 1, fp))
return (-1);
if (0 >= dig__fwrite_port_D(&(ptr->N), 1, fp))
return (-1);
@@ -383,6 +383,7 @@
if (0 >= dig__fread_port_P(&(ptr->centroid), 1, fp))
return -1;
return -1;
if (0 >= dig__fread_port_D(&(ptr->S), 1, fp))
@@ -443,6 +444,7 @@
if (0 >= dig__fwrite_port_P(&(ptr->centroid), 1, fp))
return (-1);
return (-1);
if (0 >= dig__fwrite_port_D(&(ptr->S), 1, fp))
@@ -495,6 +497,7 @@
if (0 >= dig__fread_port_P(&(ptr->area), 1, fp))
return -1;
return -1;
@@ -547,6 +550,7 @@
if (0 >= dig__fwrite_port_P(&(ptr->area), 1, fp))
return (-1);
return (-1);
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c 2009-09-13 10:58:56 UTC (rev 39172)
+++ grass/trunk/lib/vector/diglib/spindex.c 2009-09-13 11:00:12 UTC (rev 39173)
@@ -35,10 +35,9 @@
int ndims;
- ndims = Plus->with_z ? 3 : 2;
+ ndims = (Plus->with_z != 0) ? 3 : 2;
+ Plus->spidx_with_z = (Plus->with_z != 0);
- G_debug(1, "dig_spidx_init()");
Plus->Node_spidx = RTreeNewIndex(ndims);
Plus->Line_spidx = RTreeNewIndex(ndims);
Plus->Area_spidx = RTreeNewIndex(ndims);
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-09-13 10:58:56 UTC (rev 39172)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-09-13 11:00:12 UTC (rev 39173)
@@ -883,7 +883,8 @@
G_debug(1, "dig_read_spindx()");
- /* TODO: free old tree */
+ /* free old trees, init new trees */
+ dig_spidx_free(Plus);
dig_spidx_init(Plus);
dig_rewind(fp);
