[GRASS-SVN] r39177 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Sun Sep 13 12:47:39 EDT 2009
Author: martinl
Date: 2009-09-13 12:47:38 -0400 (Sun, 13 Sep 2009)
New Revision: 39177
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/level_two.c
long -> plus_t
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-09-13 13:39:37 UTC (rev 39176)
+++ grass/trunk/include/vector.h 2009-09-13 16:47:38 UTC (rev 39177)
@@ -186,15 +186,15 @@
/* Get map level 2 informations */
int Vect_level(const struct Map_info *);
-long Vect_get_num_nodes(const struct Map_info *);
-long Vect_get_num_primitives(const struct Map_info *, int);
-long Vect_get_num_lines(const struct Map_info *);
-long Vect_get_num_areas(const struct Map_info *);
-long Vect_get_num_faces(const struct Map_info *);
-long Vect_get_num_kernels(const struct Map_info *);
-long Vect_get_num_volumes(const struct Map_info *);
-long Vect_get_num_islands(const struct Map_info *);
-long Vect_get_num_holes(const struct Map_info *);
+plus_t Vect_get_num_nodes(const struct Map_info *);
+plus_t Vect_get_num_primitives(const struct Map_info *, int);
+plus_t Vect_get_num_lines(const struct Map_info *);
+plus_t Vect_get_num_areas(const struct Map_info *);
+plus_t Vect_get_num_faces(const struct Map_info *);
+plus_t Vect_get_num_kernels(const struct Map_info *);
+plus_t Vect_get_num_volumes(const struct Map_info *);
+plus_t Vect_get_num_islands(const struct Map_info *);
+plus_t Vect_get_num_holes(const struct Map_info *);
int Vect_get_line_box(const struct Map_info *, int, struct bound_box *);
int Vect_get_area_box(const struct Map_info *, int, struct bound_box *);
int Vect_get_isle_box(const struct Map_info *, int, struct bound_box *);
@@ -462,7 +462,7 @@
off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
const struct line_cats *);
#if 0
-long V1_write_line_ogr(struct Map_info *, int, struct line_pnts *,
+off_t V1_write_line_ogr(struct Map_info *, int, struct line_pnts *,
#endif
off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
@@ -470,7 +470,7 @@
int V2_rewrite_line_nat(struct Map_info *, int, int,
const struct line_pnts *, const struct line_cats *);
#if 0
-long V1_rewrite_line_ogr(struct Map_info *, long offset, int type,
+off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
struct line_pnts *, struct line_cats *);
#endif
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2009-09-13 13:39:37 UTC (rev 39176)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2009-09-13 16:47:38 UTC (rev 39177)
@@ -25,7 +25,7 @@
\return number of nodes
-long Vect_get_num_nodes(const struct Map_info *map)
+plus_t Vect_get_num_nodes(const struct Map_info *map)
return (map->plus.n_nodes);
@@ -38,9 +38,9 @@
\return number of primitives
-long Vect_get_num_primitives(const struct Map_info *map, int type)
+plus_t Vect_get_num_primitives(const struct Map_info *map, int type)
- long int num = 0;
+ plus_t num = 0;
if (type & GV_POINT)
num += map->plus.n_plines;
@@ -65,7 +65,7 @@
\return number of features
-long Vect_get_num_lines(const struct Map_info *map)
+plus_t Vect_get_num_lines(const struct Map_info *map)
return (map->plus.n_lines);
@@ -77,7 +77,7 @@
\return number of areas
-long Vect_get_num_areas(const struct Map_info *map)
+plus_t Vect_get_num_areas(const struct Map_info *map)
return (map->plus.n_areas);
@@ -89,7 +89,7 @@
\return number of kernels
-long Vect_get_num_kernels(const struct Map_info *map)
+plus_t Vect_get_num_kernels(const struct Map_info *map)
return (map->plus.n_klines);
@@ -102,7 +102,7 @@
\return number of faces
-long Vect_get_num_faces(const struct Map_info *map)
+plus_t Vect_get_num_faces(const struct Map_info *map)
return (map->plus.n_flines);
@@ -115,7 +115,7 @@
\return number of volumes
-long Vect_get_num_volumes(const struct Map_info *map)
+plus_t Vect_get_num_volumes(const struct Map_info *map)
return (map->plus.n_volumes);
@@ -128,7 +128,7 @@
\return number of islands
-long Vect_get_num_islands(const struct Map_info *map)
+plus_t Vect_get_num_islands(const struct Map_info *map)
return (map->plus.n_isles);
@@ -141,7 +141,7 @@
\return number of holes
-long Vect_get_num_holes(const struct Map_info *map)
+plus_t Vect_get_num_holes(const struct Map_info *map)
return (map->plus.n_holes);
