[GRASS-SVN] r39178 - in grass-addons/raster: . r.clim
    svn_grass at osgeo.org
    Sun Sep 13 13:02:13 EDT 2009
Author: neteler
Date: 2009-09-13 13:02:12 -0400 (Sun, 13 Sep 2009)
New Revision: 39178
Added:
   grass-addons/raster/r.clim/
   grass-addons/raster/r.clim/Makefile
   grass-addons/raster/r.clim/description.html
   grass-addons/raster/r.clim/main.c
r.clim added with permission of authors
Added: grass-addons/raster/r.clim/Makefile
--- grass-addons/raster/r.clim/Makefile	                        (rev 0)
+++ grass-addons/raster/r.clim/Makefile	2009-09-13 17:02:12 UTC (rev 39178)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.clim
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/raster/r.clim/Makefile
___________________________________________________________________
Added: svn:eol-style
   + native
Added: grass-addons/raster/r.clim/description.html
--- grass-addons/raster/r.clim/description.html	                        (rev 0)
+++ grass-addons/raster/r.clim/description.html	2009-09-13 17:02:12 UTC (rev 39178)
@@ -0,0 +1,47 @@
+<H2>DESCRIPTION</H2>
+<EM>r.clim</EM> calculates solar radiation and percentage relative
+humidity maps. The calculation of the two values for each raster cell
+is based on the C code cclimm.c a simplified version of mtclim43.c by
+Peter Thornton (2000) of the NTSG, School of Forestry University of
+Montana.  The cclimm.c code is thought for monthly data and doesn't
+consider arid correction so this module isn't indic ated for arid
+region.
+<p>
+The input units are:
+<ul>
+<li>Temperatures:           degrees C
+<li>Precipitation:          mm / day
+<li>Elevation:              m
+<li>Slope:                  degrees
+<li>Aspect:                 degrees
+<li>Latitude:               decimal degrees
+<li>E/W horizons:           decimal degrees
+</ul>
+while the output units are:
+<ul>
+<li>Relative humidity:       %
+<li>Radiation:              W/m2, average over daylight period
+</ul>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="g.region.html">g.region</A><br>
+<A HREF="r.slope.aspect.html">r.slope.aspect</A><br>
+<A HREF="r.sun.html">r.sun</A><br>
+</em>
+<H2>REFERENCE</H2>
+C. Sboarina, 2002: <a href="http://www.ing.unitn.it/~grass/conferences/GRASS2002/proceedings/proceedings/pdfs/Sboarina_Chiara.pdf">Development of a complete climate database using a new GRASS module</a>. In B. Benciolini, M. Ciolli, and P. Zatelli, editors, Proc. of the Open Source Free Software GIS - GRASS users conference 2002, Trento, Italy, 11-13 September 2002
+<H2>AUTHOR</H2>
+Chiara Sboarina, Centro di Ecologia Alpina - Viote del Monte Bondone (TN) - Italy (2001)<br>
+based on <a href="http://www.ntsg.umt.edu/bioclimatology/mtclim/">"mtclim43"</a> by
+Peter Thornton (2000) of the NTSG, School of Forestry University of Montana.
+<p>
+<i>Last changed: $Date: 2006/09/10 06:26:43 $</i>
Added: grass-addons/raster/r.clim/main.c
--- grass-addons/raster/r.clim/main.c	                        (rev 0)
+++ grass-addons/raster/r.clim/main.c	2009-09-13 17:02:12 UTC (rev 39178)
@@ -0,0 +1,660 @@
+			r.clim
+ *   Copyright (C) 2002-2006 by the GRASS Development Team
+ *   Author(s): Chiara Sboarina, Centro di Ecologia Alpina - Viote del Monte Bondone (TN) - Italy (2001)
+ *      This program is free software under the GNU General Public
+ *      License (>=v2). Read the file COPYING that comes with GRASS
+ *      for details.
+This raster module creates two raster map layers:
+1. solar radiation
+2. percentage relative humidity
+The calculation of the two values for each raster cell is based on the C code cclimm.c a simplified version of
+mtclim43.c by Peter Thornton (2000) of the NTSG, School of Forestry University of Montana.
+The cclimm.c code is thought for monthly data and doesn't consider arid correction so this module isn't indicated
+for arid region.
+Temperatures           degrees C
+Precipitation          mm / day
+Elevation              m
+Slope		       degrees
+Aspect		       degrees
+Latitude               decimal degrees
+E/W horizons           decimal degrees
+Relative humidity	%
+Radiation              W/m2, average over daylight period
+'r.clim' can be run in two standard GRASS modes: interactive and command line.
+For an interactive run, type in r.clim and follows the prompt.
+For a command line mode type in
+	r.clim tmin=name tmax=name prcp=name elev=name slope=name aspect=name lat=name ehoriz=name
+	whoriz=name month=number rad=name hum=name
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+/* optical airmass by degrees */
+float optam[21] =
+    { 2.90, 3.05, 3.21, 3.39, 3.69, 3.82, 4.07, 4.37, 4.72, 5.12, 5.60, 6.18,
+    6.88, 7.77, 8.90, 10.39, 12.44, 15.36, 19.79, 26.96, 30.00
+/* julian day for each month */
+float julian[12] =
+    { 15, 45, 74, 105, 135, 166, 196, 227, 258, 288, 319, 349 };
+struct Cell_head window;
+int main(int argc, char *argv[])
+    /* physical constants and model parameters
+     * (dim) stands for dimensionless values   */
+#define SECPERRAD 13750.9871	/* seconds per radian of hour angle */
+#define RADPERDAY 0.017214	/* radians of Earth orbit per julian day */
+#define RADPERDEG 0.01745329	/* radians per degree */
+#define MINDECL -0.4092797	/* minimum declination (radians) */
+#define DAYSOFF 11.25		/* julian day offset of winter solstice */
+#define SRADDT 600.0		/* timestep for radiation routine (seconds) */
+#define MA       28.9644e-3	/* (kg mol-1) molecular weight of air */
+#define MW       18.0148e-3	/* (kg mol-1) molecular weight of water */
+#define R        8.3143		/* (m3 Pa mol-1 K-1) gas law constant */
+#define G_STD    9.80665	/* (m s-2) standard gravitational accel. */
+#define P_STD    101325.0	/* (Pa) standard pressure at 0.0 m elevation */
+#define T_STD    288.15		/* (K) standard temp at 0.0 m elevation  */
+#define CP       1010.0		/* (J kg-1 K-1) specific heat of air */
+#define LR_STD   0.0065		/* (-K m-1) standard temperature lapse rate */
+#define EPS      0.62196351	/* (MW/MA) unitless ratio of molec weights */
+#define PI       3.14159265	/* pi */
+    /* parameters for the Tair algorithm */
+#define TDAYCOEF     0.45	/* (dim) daylight air temperature coefficient (dim) */
+    /* parameters for the snowpack algorithm */
+#define SNOW_TCRIT   -6.0	/* (deg C) critical temperature for snowmelt */
+#define SNOW_TRATE  0.042	/* (cm/degC/day) snowmelt rate */
+    /* parameters for the radiation algorithm */
+#define TBASE       0.851904	/* (dim) max inst. trans., 0m, nadir, dry atm */
+#define ABASE     -5.79e-5	/* (1/Pa) vapor pressure effect on transmittance */
+#define C             1.548	/* (dim) radiation parameter */
+#define B0          0.0130104	/* (dim) radiation parameter */
+#define B1          0.20224	/* (dim) radiation parameter */
+#define B2          0.185896	/* (dim) radiation parameter */
+#define RAIN_SCALAR  0.75	/* (dim) correction to trans. for rain day */
+#define DIF_ALB       0.6	/* (dim) diffuse albedo for horizon correction */
+#define SC_INT       1.32	/* (MJ/m2/day) snow correction intercept */
+#define SC_SLOPE    0.096	/* (MJ/m2/day/cm) snow correction slope */
+    /* variables */
+    int nrows, ncols;
+    int nmonth, ami;
+    double newsnow, snowmelt, snowpack =
+	0.0, swe, t1, t2, pratio, trans1, lati, pend, esp, coszeh, coszwh, dt,
+	dh, decl;
+    double bsg1, bsg2, bsg3, cosegeom, sinegeom, coshss, hss, daylen, sc,
+	dir_beam_topa, sum_trans, sum_flat_potrad, sum_slope_potrad;
+    double h, cza, cbsa, dir_flat_topa, am, trans2, ttmax0, flat_potrad,
+	slope_potrad, avg_horizon, horizon_scalar, slope_excess;
+    double slope_scalar, sky_prop, b, t_fmax, pva, tday, pvs, t_tmax, t_final,
+	pdif, pdir, srad1, srad2, tdew;
+    /*other local variables */
+    int col, row, verbose, tmin_fd, tmax_fd, prcp_fd, elev_fd, slope_fd,
+	aspect_fd, lat_fd, ehoriz_fd, whoriz_fd, rad_fd, hum_fd;
+    FCELL *tmin,		/*fcell buffer for minimum temperature map layer */
+     *tmax,			/*fcell buffer for maximum temperature map layer */
+     *prcp,			/*fcell buffer for precipitation map layer */
+     *lat;			/*fcell buffer for latitudine map layer */
+    CELL *elev,			/*cell buffer for elevation map layer */
+     *slope,			/*cell buffer for slope map layer */
+     *aspect,			/*cell buffer for aspect map layer */
+     *ehoriz,			/*cell buffer for east horizon map layer */
+     *whoriz,			/*cell buffer for west horizon map layer */
+     *rad,			/*cell buffer for solar radiation map layer */
+     *hum;			/*cell buffer for relative humidity map layer */
+    extern struct Cell_head window;
+    struct
+	struct Option *tmin, *tmax, *prcp, *elev, *slope,
+	    *aspect, *lat, *ehoriz, *whoriz, *month, *rad, *hum;
+    } parm;
+    struct Flag *flag1;
+    struct GModule *module;
+    /* initialize access to database and create temporary files */
+    G_gisinit(argv[0]);
+    /* Set description */
+    module = G_define_module();
+    module->description =
+	_("Creates two raster map layers: 1. solar radiation  2. percentage relative humidity");
+    parm.tmin = G_define_option();
+    parm.tmin->key = "tmin";
+    parm.tmin->key_desc = "name";
+    parm.tmin->type = TYPE_STRING;
+    parm.tmin->required = YES;
+    parm.tmin->gisprompt = "old,cell,raster";
+    parm.tmin->description =
+	_("Name of input raster map containing MINIMUM TEMPERATURE");
+    parm.tmax = G_define_option();
+    parm.tmax->key = "tmax";
+    parm.tmax->key_desc = "name";
+    parm.tmax->type = TYPE_STRING;
+    parm.tmax->required = YES;
+    parm.tmax->gisprompt = "old,cell,raster";
+    parm.tmax->description =
+	_("Name of input raster map containing MAXIMUM TEMPERATURE");
+    parm.prcp = G_define_option();
+    parm.prcp->key = "prcp";
+    parm.prcp->key_desc = "name";
+    parm.prcp->type = TYPE_STRING;
+    parm.prcp->required = YES;
+    parm.prcp->gisprompt = "old,cell,raster";
+    parm.prcp->description =
+	_("Name of input raster map containing PRECIPITATION in mm");
+    parm.elev = G_define_option();
+    parm.elev->key = "elev";
+    parm.elev->key_desc = "name";
+    parm.elev->type = TYPE_STRING;
+    parm.elev->gisprompt = "old,cell,raster";
+    parm.elev->description =
+	_("Name of input raster map containing ELEVATION (m)");
+    parm.slope = G_define_option();
+    parm.slope->key = "slope";
+    parm.slope->key_desc = "name";
+    parm.slope->type = TYPE_STRING;
+    parm.slope->gisprompt = "old,cell,raster";
+    parm.slope->description =
+	_("Name of input raster map containing SLOPE (degree)");
+    parm.aspect = G_define_option();
+    parm.aspect->key = "aspect";
+    parm.aspect->key_desc = "name";
+    parm.aspect->type = TYPE_STRING;
+    parm.aspect->gisprompt = "old,cell,raster";
+    parm.aspect->description =
+	_("Name of input raster map containing ASPECT (degree, anti-clockwise from E)");
+    parm.lat = G_define_option();
+    parm.lat->key = "lat";
+    parm.lat->key_desc = "name";
+    parm.lat->type = TYPE_STRING;
+    parm.lat->required = YES;
+    parm.lat->gisprompt = "old,cell,raster";
+    parm.lat->description =
+	_("Name of input raster map containing LATITUDE in decimal degrees");
+    parm.ehoriz = G_define_option();
+    parm.ehoriz->key = "ehoriz";
+    parm.ehoriz->key_desc = "name";
+    parm.ehoriz->type = TYPE_STRING;
+    parm.ehoriz->gisprompt = "old,cell,raster";
+    parm.ehoriz->description =
+	_("Name of input raster map containing EAST HORIZON (degree)");
+    parm.whoriz = G_define_option();
+    parm.whoriz->key = "whoriz";
+    parm.whoriz->key_desc = "name";
+    parm.whoriz->type = TYPE_STRING;
+    parm.whoriz->gisprompt = "old,cell,raster";
+    parm.whoriz->description =
+	_("Name of input raster map containing WEST HORIZON (degree)");
+    parm.month = G_define_option();
+    parm.month->key = "month";
+    parm.month->type = TYPE_INTEGER;
+    parm.month->required = YES;
+    parm.month->description =
+	_("Number of the month in the year i.e. January=1, February=2,...");
+    parm.rad = G_define_option();
+    parm.rad->key = "rad";
+    parm.rad->key_desc = "name";
+    parm.rad->type = TYPE_STRING;
+    parm.rad->required = YES;
+    parm.rad->gisprompt = "new,cell,raster";
+    parm.rad->description =
+	_("Name of output raster map containing SOLAR RADIATION in W/m^2");
+    parm.hum = G_define_option();
+    parm.hum->key = "hum";
+    parm.hum->key_desc = "name";
+    parm.hum->type = TYPE_STRING;
+    parm.hum->required = YES;
+    parm.hum->gisprompt = "new,cell,raster";
+    parm.hum->description =
+	_("Name of output raster map containing RELATIVE HUMIDITY in %");
+    flag1 = G_define_flag();
+    flag1->key = 'v';
+    flag1->description = _("Run verbosely");
+    /*   Parse command line */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    verbose = flag1->answer;
+    /*  Check if input layers exists in data base  */
+    if (G_find_cell2(parm.tmin->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.tmin->answer);
+    if (G_find_cell2(parm.tmax->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.tmax->answer);
+    if (G_find_cell2(parm.prcp->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.prcp->answer);
+    if (G_find_cell2(parm.elev->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.elev->answer);
+    if (G_find_cell2(parm.slope->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.slope->answer);
+    if (G_find_cell2(parm.aspect->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.aspect->answer);
+    if (G_find_cell2(parm.lat->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.lat->answer);
+    if (G_find_cell2(parm.ehoriz->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.ehoriz->answer);
+    if (G_find_cell2(parm.whoriz->answer, "") == NULL) {
+	G_fatal_error(_("%s - not found"), parm.whoriz->answer);
+    /*  Check if specified output layer name IS LEGAL  */
+    if (G_legal_filename(parm.rad->answer) < 0) {
+	G_fatal_error(_("%s - illegal name"), parm.rad->answer);
+    if (G_legal_filename(parm.hum->answer) < 0) {
+	G_fatal_error(_("%s - illegal name"), parm.hum->answer);
+    /*check if the output layer names EXIST */
+    if (G_find_cell2((parm.rad->answer), G_mapset())) {
+	G_fatal_error(_("%s - exits in Mapset <%s>, select another name"),
+		      parm.rad->answer, G_mapset());
+    if (G_find_cell2((parm.hum->answer), G_mapset())) {
+		      parm.hum->answer, G_mapset());
+    /*  Get database window parameters  */
+    if (G_get_window(&window) < 0) {
+	G_fatal_error(_("Can't read current window parameters"));
+    /*  find number of rows and columns in window    */
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    tmin = G_allocate_f_raster_buf();
+    tmax = G_allocate_f_raster_buf();
+    prcp = G_allocate_f_raster_buf();
+    elev = G_allocate_cell_buf();
+    slope = G_allocate_cell_buf();
+    aspect = G_allocate_cell_buf();
+    lat = G_allocate_f_raster_buf();
+    ehoriz = G_allocate_cell_buf();
+    whoriz = G_allocate_cell_buf();
+    rad = G_allocate_cell_buf();
+    hum = G_allocate_cell_buf();
+    sscanf(parm.month->answer, "%d", &nmonth);
+    /*  Open input cell layers for reading  */
+    tmin_fd =
+	G_open_cell_old(parm.tmin->answer,
+			G_find_cell2(parm.tmin->answer, ""));
+    if (tmin_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.tmin->answer);
+    tmax_fd =
+	G_open_cell_old(parm.tmax->answer,
+			G_find_cell2(parm.tmax->answer, ""));
+    if (tmax_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.tmax->answer);
+    prcp_fd =
+	G_open_cell_old(parm.prcp->answer,
+			G_find_cell2(parm.prcp->answer, ""));
+    if (prcp_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.prcp->answer);
+    elev_fd =
+	G_open_cell_old(parm.elev->answer,
+			G_find_cell2(parm.elev->answer, ""));
+    if (elev_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.elev->answer);
+    slope_fd =
+	G_open_cell_old(parm.slope->answer,
+			G_find_cell2(parm.slope->answer, ""));
+    if (slope_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.slope->answer);
+    aspect_fd =
+	G_open_cell_old(parm.aspect->answer,
+			G_find_cell2(parm.aspect->answer, ""));
+    if (aspect_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.aspect->answer);
+    lat_fd =
+	G_open_cell_old(parm.lat->answer, G_find_cell2(parm.lat->answer, ""));
+    if (lat_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.lat->answer);
+    ehoriz_fd =
+	G_open_cell_old(parm.ehoriz->answer,
+			G_find_cell2(parm.ehoriz->answer, ""));
+    if (ehoriz_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.ehoriz->answer);
+    whoriz_fd =
+	G_open_cell_old(parm.whoriz->answer,
+			G_find_cell2(parm.whoriz->answer, ""));
+    if (whoriz_fd < 0) {
+	G_fatal_error(_("%s - can't open raster file"), parm.whoriz->answer);
+    rad_fd = G_open_cell_new(parm.rad->answer);
+    hum_fd = G_open_cell_new(parm.hum->answer);
+    /*major computation: compute HUM and RAD one cell a time */
+    if (verbose)
+	fprintf(stderr, "Percent Completed ... ");
+    for (row = 0; row < nrows; row++) {
+	if (verbose)
+	    G_percent(row, nrows, 10);
+	if (G_get_f_raster_row(tmin_fd, tmin, row) < 0)
+	    G_fatal_error(_("Error reading row of data"));
+	if (G_get_f_raster_row(tmax_fd, tmax, row) < 0)
+	if (G_get_f_raster_row(prcp_fd, prcp, row) < 0)
+	if (G_get_map_row(elev_fd, elev, row) < 0)
+	if (G_get_map_row(slope_fd, slope, row) < 0)
+	if (G_get_map_row(aspect_fd, aspect, row) < 0)
+	if (G_get_f_raster_row(lat_fd, lat, row) < 0)
+	if (G_get_map_row(ehoriz_fd, ehoriz, row) < 0)
+	if (G_get_map_row(whoriz_fd, whoriz, row) < 0)
+	/*initialize cell buffers for output map layers */
+	for (col = 0; col < ncols; col++) {
+	    rad[col] = hum[col] = 0;
+	    newsnow = 0.0;
+	    snowmelt = 0.0;
+	    if (tmin[col] <= SNOW_TCRIT)
+		newsnow = prcp[col];
+	    else
+		snowmelt = SNOW_TRATE * (tmin[col] - SNOW_TCRIT);
+	    snowpack += newsnow - snowmelt;
+	    if (snowpack < 0.0)
+		snowpack = 0.0;
+	    swe = snowpack;
+	    /* STEP (1) calculate pressure ratio (site/reference) = f(elevation) */
+	    t1 = 1.0 - (LR_STD * elev[col]) / T_STD;
+	    t2 = G_STD / (LR_STD * (R / MA));
+	    pratio = pow(t1, t2);
+	    /* STEP (2) correct initial transmittance for elevation */
+	    trans1 = pow(TBASE, pratio);
+	    /* STEP (3) calculation of ttmax0, potential rad, and daylength */
+	    /* precalculate the transcendentals */
+	    lati = lat[col] * RADPERDEG;
+	    if (lati > 1.5707)
+		lati = 1.5707;
+	    if (lati < -1.5707)
+		lati = -1.5707;
+	    pend = slope[col] * RADPERDEG;
+	    esp = (-aspect[col] + 90) * RADPERDEG;
+	    /* cosine of zenith angle for east and west horizons */
+	    coszeh = cos(1.570796 - (ehoriz[col] * RADPERDEG));
+	    coszwh = cos(1.570796 - (whoriz[col] * RADPERDEG));
+	    /* sub-daily time and angular increment information */
+	    dt = SRADDT;	/* set timestep */
+	    dh = dt / SECPERRAD;	/* calculate hour-angle step */
+	    /* calculate cos and sin of declination */
+	    decl = MINDECL * cos((julian[nmonth] + DAYSOFF) * RADPERDAY);
+	    /* do some precalculations for beam-slope geometry (bsg) */
+	    bsg1 = -sin(pend) * sin(esp) * cos(decl);
+	    bsg2 =
+		(-cos(esp) * sin(pend) * sin(lati) +
+		 cos(pend) * cos(lati)) * cos(decl);
+	    bsg3 =
+		(cos(esp) * sin(pend) * cos(lati) +
+		 cos(pend) * sin(lati)) * sin(decl);
+	    /* calculate daylength as a function of lat and decl */
+	    cosegeom = cos(lati) * cos(decl);
+	    sinegeom = sin(lati) * sin(decl);
+	    coshss = -(sinegeom) / cosegeom;
+	    if (coshss < -1.0)
+		coshss = -1.0;	/* 24-hr daylight */
+	    if (coshss > 1.0)
+		coshss = 1.0;	/* 0-hr daylight */
+	    hss = acos(coshss);	/* hour angle at sunset (radians) */
+	    /* daylength (seconds) */
+	    daylen = 2.0 * hss * SECPERRAD;
+	    /* solar constant as a function of yearday (W/m^2) */
+	    sc = 1368.0 + 45.5 * sin((2.0 * PI * julian[nmonth] / 365.25) +
+				     1.7);
+	    /* extraterrestrial radiation perpendicular to beam, total over the timestep (J) */
+	    dir_beam_topa = sc * dt;
+	    sum_trans = 0.0;
+	    sum_flat_potrad = 0.0;
+	    sum_slope_potrad = 0.0;
+	    /* begin sub-daily hour-angle loop, from -hss to hss */
+	    for (h = -hss; h < hss; h += dh) {
+		/* calculate cosine of solar zenith angle */
+		cza = cosegeom * cos(h) + sinegeom;
+		/* calculate cosine of beam-slope angle */
+		cbsa = sin(h) * bsg1 + cos(h) * bsg2 + bsg3;
+		/* check if sun is above a flat horizon */
+		if (cza > 0.0) {
+		    /* when sun is above the ideal (flat) horizon, do all the flat-surface calculations to determine daily total
+		     * transmittance, and save flat-surface potential radiation for later calculations of diffuse radiation */
+		    /* potential radiation for this time period, flat surface,top of atmosphere */
+		    dir_flat_topa = dir_beam_topa * cza;
+		    /* determine optical air mass */
+		    am = 1.0 / (cza + 0.0000001);
+		    if (am > 2.9) {
+			ami = (int)(acos(cza) / RADPERDEG) - 69;
+			if (ami < 0)
+			    ami = 0;
+			if (ami > 20)
+			    ami = 20;
+			am = optam[ami];
+		    /* correct instantaneous transmittance for this optical air mass */
+		    trans2 = pow(trans1, am);
+		    /* instantaneous transmittance is weighted by potential radiation for flat surface at top of atmosphere to get daily total transmittance */
+		    sum_trans += trans2 * dir_flat_topa;
+		    /* keep track of total potential radiation on a flat surface for ideal horizons */
+		    sum_flat_potrad += dir_flat_topa;
+		    /* keep track of whether this time step contributes to component 1 (direct on slope) */
+		    if ((h < 0.0 && cza > coszeh && cbsa > 0.0) ||
+			(h >= 0.0 && cza > coszwh && cbsa > 0.0)) {
+			/* sun between east and west horizons, and direct on slope. this period contributes to component 1 */
+			sum_slope_potrad += dir_beam_topa * cbsa;
+		}		/* end if sun above ideal horizon */
+	    }			/* end of sub-daily hour-angle loop */
+	    /* calculate maximum daily total transmittance and daylight average flux density for a flat surface and the slope */
+	    if (daylen) {
+		ttmax0 = sum_trans / sum_flat_potrad;
+		flat_potrad = sum_flat_potrad / daylen;
+		slope_potrad = sum_slope_potrad / daylen;
+	    else {
+		ttmax0 = 0.0;
+		flat_potrad = 0.0;
+		slope_potrad = 0.0;
+	    /* STEP (4)  calculate the sky proportion for diffuse radiation */
+	    /* uses the product of spherical cap defined by average horizon angle and the great-circle truncation
+	     * of a hemisphere. this factor does notvary by yearday. */
+	    avg_horizon = (ehoriz[col] + whoriz[col]) / 2.0;
+	    horizon_scalar = 1.0 - sin(avg_horizon * RADPERDEG);
+	    if (pend > avg_horizon)
+		slope_excess = pend - avg_horizon;
+	    else
+		slope_excess = 0.0;
+	    if (2.0 * avg_horizon > 180.0)
+		slope_scalar = 0.0;
+	    else {
+		slope_scalar =
+		    1.0 - (slope_excess / (180.0 - 2.0 * avg_horizon));
+		if (slope_scalar < 0.0)
+	    sky_prop = horizon_scalar * slope_scalar;
+	    /* b parameter, and t_fmax not varying with Tdew, so these can be calculated once, outside the iteration
+	     * between radiation and humidity estimates. Requires storing t_fmax in an array. */
+	    /* b parameter from 30-day average of DTR */
+	    b = B0 + B1 * exp(-B2 * (tmax[col] - tmin[col]));
+	    /* proportion of daily maximum transmittance */
+	    t_fmax = 1.0 - 0.9 * exp(-b * pow((tmax[col] - tmin[col]), C));
+	    /* correct for precipitation if this is a rain day */
+	    if (prcp[col])
+		t_fmax *= RAIN_SCALAR;
+	    /* calculate radiation assuming that Tdew = tmin+k*(tday-tmin) */
+	    tday = 0.725 * tmax[col] + 0.275 * tmin[col];
+	    tdew = tmin[col] + 0.29 * (tday - tmin[col]);
+	    pva = 610.7 * exp(17.38 * tdew / (239.0 + tdew));
+	    pvs = 610.7 * exp(17.38 * tday / (239.0 + tday));
+	    hum[col] = (int)(pva / pvs * 100);
+	    t_tmax = ttmax0 + ABASE * pva;
+	    /* final daily total transmittance */
+	    t_final = t_tmax * t_fmax;
+	    /* estimate fraction of radiation that is diffuse, on an instantaneous basis, from relationship with daily total
+	     * transmittance in Jones (Plants and Microclimate, 1992) Fig 2.8, p. 25, and Gates (Biophysical Ecology, 1980)
+	     * Fig 6.14, p. 122. */
+	    pdif = -1.25 * t_final + 1.25;
+	    if (pdif > 1.0)
+		pdif = 1.0;
+	    if (pdif < 0.0)
+		pdif = 0.0;
+	    /* estimate fraction of radiation that is direct, on an instantaneous basis */
+	    pdir = 1.0 - pdif;
+	    /* the daily total radiation is estimated as the sum of the following two components:
+	     * 1. The direct radiation arriving during the part of the day when there is direct beam on the slope.
+	     * 2. The diffuse radiation arriving over the entire daylength (when sun is above ideal horizon). */
+	    /* component 1 */
+	    srad1 = slope_potrad * t_final * pdir;
+	    /* component 2 (diffuse) */
+	    /* includes the effect of surface albedo in raising the diffuse radiation for obstructed horizons */
+	    srad2 =
+		flat_potrad * t_final * pdif * (sky_prop +
+						DIF_ALB * (1.0 - sky_prop));
+	    /* snow pack influence on radiation */
+	    if (swe > 0.0) {
+		/* snow correction in J/m2/day */
+		sc = (1.32 + 0.096 * swe) * 1e6;
+		/* convert to W/m2 and check for zero daylength */
+		if (daylen > 0.0)
+		    sc /= daylen;
+		else
+		    sc = 0.0;
+		/* set a maximum correction of 100 W/m2 */
+		if (sc > 100.0)
+		    sc = 100.0;
+	    else
+		sc = 0.0;
+	    /* save daily radiation and daylength */
+	    rad[col] = (int)(srad1 + srad2 + sc);
+	G_put_raster_row(rad_fd, rad, CELL_TYPE);
+	G_put_raster_row(hum_fd, hum, CELL_TYPE);
+    if (verbose)
+    G_close_cell(tmin_fd);
+    G_close_cell(tmax_fd);
+    G_close_cell(prcp_fd);
+    G_close_cell(elev_fd);
+    G_close_cell(slope_fd);
+    G_close_cell(aspect_fd);
+    G_close_cell(lat_fd);
+    G_close_cell(ehoriz_fd);
+    G_close_cell(whoriz_fd);
+    G_close_cell(rad_fd);
+    G_close_cell(hum_fd);
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/raster/r.clim/main.c
   + native
