[GRASS-SVN] r41684 - in grass-addons/raster/mcda: r.mcda.electre r.mcda.fuzzy r.mcda.regime r.roughset
Sat Apr 3 05:29:09 EDT 2010
Author: hamish
Date: 2010-04-03 05:29:09 -0400 (Sat, 03 Apr 2010)
New Revision: 41684
   grass-addons/raster/mcda/r.mcda.electre/dominance.c
   grass-addons/raster/mcda/r.mcda.electre/local_proto.h
   grass-addons/raster/mcda/r.mcda.electre/main.c
   grass-addons/raster/mcda/r.mcda.fuzzy/fuzzy.c
   grass-addons/raster/mcda/r.mcda.fuzzy/local_proto.h
   grass-addons/raster/mcda/r.mcda.fuzzy/main.c
   grass-addons/raster/mcda/r.mcda.regime/local_proto.h
   grass-addons/raster/mcda/r.mcda.regime/main.c
   grass-addons/raster/mcda/r.mcda.regime/regime.c
   grass-addons/raster/mcda/r.roughset/localproto.h
   grass-addons/raster/mcda/r.roughset/main.c
   grass-addons/raster/mcda/r.roughset/raccess.c
   grass-addons/raster/mcda/r.roughset/raccess.h
   grass-addons/raster/mcda/r.roughset/rbasic.c
   grass-addons/raster/mcda/r.roughset/rbasic.h
   grass-addons/raster/mcda/r.roughset/rclass.c
   grass-addons/raster/mcda/r.roughset/rclass.h
   grass-addons/raster/mcda/r.roughset/rcore.c
   grass-addons/raster/mcda/r.roughset/rcore.h
   grass-addons/raster/mcda/r.roughset/reduct1.c
   grass-addons/raster/mcda/r.roughset/reduct1.h
   grass-addons/raster/mcda/r.roughset/reduct2.c
   grass-addons/raster/mcda/r.roughset/reduct2.h
   grass-addons/raster/mcda/r.roughset/rerror.h
   grass-addons/raster/mcda/r.roughset/rough.h
   grass-addons/raster/mcda/r.roughset/rset.c
   grass-addons/raster/mcda/r.roughset/rset.h
   grass-addons/raster/mcda/r.roughset/rsystem.h
   grass-addons/raster/mcda/r.roughset/rule1.c
   grass-addons/raster/mcda/r.roughset/rule1.h
   grass-addons/raster/mcda/r.roughset/rule2.c
   grass-addons/raster/mcda/r.roughset/rule2.h
   grass-addons/raster/mcda/r.roughset/rules_extr.c
run the tools/grass_indent script. rsystem.c *NOT* indented due to these errors:
 indent: rsystem.c:110: Error:Unmatched 'else'
 indent: rsystem.c:114: Error:Unmatched 'else'
 indent: rsystem.c:375: Error:Stmt nesting error.
 indent: rsystem.c:376: Error:Unmatched 'else'
 indent: rsystem.c:467: Error:Unexpected end of file
Modified: grass-addons/raster/mcda/r.mcda.electre/dominance.c
--- grass-addons/raster/mcda/r.mcda.electre/dominance.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.electre/dominance.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -4,100 +4,99 @@
  * global function declaration
-void build_weight_vect(int nrows, int ncols, int ncriteria, struct Option *weight, double *weight_vect);
+void build_weight_vect(int nrows, int ncols, int ncriteria,
+		       struct Option *weight, double *weight_vect);
-void build_dominance_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double ***decision_vol);
+void build_dominance_matrix(int nrows, int ncols, int ncriteria,
+			    double *weight_vect, double ***decision_vol);
  * function definitions
-void build_weight_vect(int nrows, int ncols, int ncriteria,struct Option *weight, double *weight_vect)
-	int i,nweight=0;
-	double weight_sum=0;
-	while (weight->answers[nweight]!=NULL)
-    		nweight++;
-	if(nweight!=ncriteria)
-		G_fatal_error(_("criteria number  and weight number are different"));
+    int i, nweight = 0;
+    double weight_sum = 0;
-	for(i=0;i<nweight;i++)
-		weight_vect[i]=(atof(weight->answers[i]));	/*transfer  weight value  in double  array*/
-		weight_sum=weight_sum+weight_vect[i];		/*calculate sum weight*/
-		weight_vect[i]=weight_vect[i]/weight_sum;	/*normalize vector weight*/
+    while (weight->answers[nweight] != NULL) {
+	nweight++;
+    if (nweight != ncriteria)
+	G_fatal_error(_("criteria number  and weight number are different"));
+    for (i = 0; i < nweight; i++) {
+	weight_vect[i] = (atof(weight->answers[i]));	/*transfer  weight value  in double  array */
+	weight_sum = weight_sum + weight_vect[i];	/*calculate sum weight */
+	weight_vect[i] = weight_vect[i] / weight_sum;	/*normalize vector weight */
-void build_dominance_matrix(int nrows, int ncols, int ncriteria,double *weight_vect, double ***decision_vol)
-	int row1, col1, row2, col2;
-	int i, j, k, cont;
-	double *row_sum_conc = G_alloc_vector(nrows * ncols);
-	double *col_sum_conc = G_alloc_vector(nrows * ncols);
-	double *row_sum_disc = G_alloc_vector(nrows * ncols);
-	double *col_sum_disc = G_alloc_vector(nrows * ncols);
+    int row1, col1, row2, col2;
+    int i, j, k, cont;
+    double *row_sum_conc = G_alloc_vector(nrows * ncols);
+    double *col_sum_conc = G_alloc_vector(nrows * ncols);
+    double *row_sum_disc = G_alloc_vector(nrows * ncols);
+    double *col_sum_disc = G_alloc_vector(nrows * ncols);
-	k = 0; 							/* make pairwise comparation and build concordance/discordance matrix */
-	for (row1 = 0; row1 < nrows; row1++)
-		G_percent(row1, nrows, 2);
-		for (col1 = 0; col1 < ncols; col1++)
-			j = 0;
-			for (row2 = 0; row2 < nrows; row2++)
-				for (col2 = 0; col2 < ncols; col2++)
-					double conc = 0, disc = 0;
-					for (i = 0; i < ncriteria; i++)
-							double d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
-							if (d >= 0)
-								conc += weight_vect[i];
-							if (d < disc) /*WARNING: if(d>conc)*//**/
-								disc = -d;
-					row_sum_conc[k] += conc;
-					col_sum_conc[j] += conc;
-					row_sum_disc[k] += disc;
-					col_sum_disc[j] += disc;
+    k = 0;			/* make pairwise comparation and build concordance/discordance matrix */
+    for (row1 = 0; row1 < nrows; row1++) {
+	G_percent(row1, nrows, 2);
+	for (col1 = 0; col1 < ncols; col1++) {
+	    j = 0;
+	    for (row2 = 0; row2 < nrows; row2++) {
+		for (col2 = 0; col2 < ncols; col2++) {
+		    double conc = 0, disc = 0;
-					j++; /* increase rows index up to nrows*ncols */
-			k++; /* increase columns index up to nrows*ncols */
+		    for (i = 0; i < ncriteria; i++) {
+			double d =
+			    decision_vol[row1][col1][i] -
+			    decision_vol[row2][col2][i];
+			if (d >= 0)
+			    conc += weight_vect[i];
+			if (d < disc)	/*WARNING: if(d>conc) */
+			     /**/ disc = -d;
+		    row_sum_conc[k] += conc;
+		    col_sum_conc[j] += conc;
+		    row_sum_disc[k] += disc;
+		    col_sum_disc[j] += disc;
+		    j++;	/* increase rows index up to nrows*ncols */
+	    k++;		/* increase columns index up to nrows*ncols */
-		/*calculate concordance and discordance index and storage in decision_vol */
-	cont = 0; /*variabile progressiva per riga/colonna della concordance_map */
-	for (row1 = 0; row1 < nrows; row1++) {
-		for (col1 = 0; col1 < ncols; col1++) {
-							/*fill matrix with concordance index for each DCELL */
-							decision_vol[row1][col1][ncriteria] = row_sum_conc[cont] - col_sum_conc[cont];
-							/*fill matrix with discordance index for each DCELL */
-							decision_vol[row1][col1][ncriteria + 1] = row_sum_disc[cont] - col_sum_disc[cont];
-							cont++;
+    /*calculate concordance and discordance index and storage in decision_vol */
+    cont = 0;			/*variabile progressiva per riga/colonna della concordance_map */
+	    /*fill matrix with concordance index for each DCELL */
+	    decision_vol[row1][col1][ncriteria] =
+		row_sum_conc[cont] - col_sum_conc[cont];
+	    /*fill matrix with discordance index for each DCELL */
+	    decision_vol[row1][col1][ncriteria + 1] =
+		row_sum_disc[cont] - col_sum_disc[cont];
+	    cont++;
Modified: grass-addons/raster/mcda/r.mcda.electre/local_proto.h
--- grass-addons/raster/mcda/r.mcda.electre/local_proto.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.electre/local_proto.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -9,7 +9,7 @@
 struct input
-	char *name, *mapset; /* input raster name  and mapset name*/
-	int infd;
-	void *inrast;		/* input buffer */
+    char *name, *mapset;	/* input raster name  and mapset name */
+    int infd;
+    void *inrast;		/* input buffer */
Modified: grass-addons/raster/mcda/r.mcda.electre/main.c
--- grass-addons/raster/mcda/r.mcda.electre/main.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.electre/main.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
  * MODULE:	 r.mcda.electre
@@ -23,15 +24,15 @@
 int main(int argc, char *argv[])
     struct Cell_head cellhd;	/* it stores region information,  and header information of rasters */
-    char *result_concordance, *result_discordance;		/* outputs raster name */
+    char *result_concordance, *result_discordance;	/* outputs raster name */
     char *mapset;		/* mapset name */
     unsigned char *outrast_concordance, *outrast_discordance;	/* output buffer */
     char *message;
-	int i,j, ncriteria=0;	/* index and  files number*/
+    int i, j, ncriteria = 0;	/* index and  files number */
     int nrows, ncols;
     int row1, row2, col1, col2;
-    int outfd_concordance, outfd_discordance;		/* output file descriptor */
-	double *weight_vect, ***decision_vol;/* vector and matrix */
+    int outfd_concordance, outfd_discordance;	/* output file descriptor */
+    double *weight_vect, ***decision_vol;	/* vector and matrix */
     struct History history;	/* holds meta-data (title, comments,..) */
@@ -40,7 +41,7 @@
     struct Option *criteria, *weight, *discordance, *concordance;	/* options */
-	struct input *attributes; /*storage  alla input criteria GRID files and output concordance and discordance GRID files*/
+    struct input *attributes;	/*storage  alla input criteria GRID files and output concordance and discordance GRID files */
     /* initialize GIS environment */
@@ -49,38 +50,40 @@
     /* initialize module */
     module = G_define_module();
     module->keywords = _("raster,MCDA");
-    module->description = _("Multicirtieria decision analysis based on ELECTRE method");
+    module->description =
+	_("Multicirtieria decision analysis based on ELECTRE method");
     /* Define the different options as defined in gis.h */
-    criteria  = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
-    criteria->key        = "criteria";
-    criteria->type       = TYPE_STRING;
-    criteria->required   = YES;
-    criteria->multiple   = YES;
-    criteria->gisprompt  = "old,cell,raster" ;
-    criteria->description = "Input geographics criteria in information system";
+    criteria = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    criteria->key = "criteria";
+    criteria->type = TYPE_STRING;
+    criteria->required = YES;
+    criteria->multiple = YES;
+    criteria->gisprompt = "old,cell,raster";
+    criteria->description =
+	"Input geographics criteria in information system";
-	weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
-    weight->key        = "weight";
-    weight->type       = TYPE_DOUBLE;
-    weight->required   = YES;
-    weight->multiple   = YES;
+    weight = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    weight->key = "weight";
+    weight->type = TYPE_DOUBLE;
+    weight->required = YES;
+    weight->multiple = YES;
     weight->description = _("Criteria weight(s) (w1,w2,..)");
-    concordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	concordance->key = "concordance";
+    concordance = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    concordance->key = "concordance";
     concordance->type = TYPE_STRING;
     concordance->required = YES;
     concordance->gisprompt = "new,cell,raster";
-    concordance->answer ="concordance";
+    concordance->answer = "concordance";
     concordance->description = "concordance output map";
-	discordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	discordance->key = "discordance";
+    discordance = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    discordance->key = "discordance";
     discordance->type = TYPE_STRING;
     discordance->required = YES;
     discordance->gisprompt = "new,cell,raster";
-    discordance->answer ="discordance";
+    discordance->answer = "discordance";
     discordance->description = "discordance output map";
     /* options and flags parser */
@@ -88,134 +91,137 @@
 	exit(EXIT_FAILURE);
-	G_message("Start: %s",G_date()); /*write calculation start time*/
+    G_message("Start: %s", G_date());	/*write calculation start time */
-	/* number of file (=criteria) */
-    while (criteria->answers[ncriteria]!=NULL)
-    		ncriteria++;
+    /* number of file (=criteria) */
+    while (criteria->answers[ncriteria] != NULL) {
+	ncriteria++;
-	/* process the input maps:  stores options and flags to variables */
+    /* process the input maps:  stores options and flags to variables */
     /* CRITERIA grid */
-    attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files*/
-	weight_vect=G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight*/
+    attributes = G_malloc(ncriteria * sizeof(struct input));	/*attributes is input struct defined in top file and store alla criteria files */
+    weight_vect = G_malloc(ncriteria * sizeof(double));	/*allocate memory fron vector weight */
-	build_weight_vect(nrows,ncols,ncriteria,weight,weight_vect); /*calcolate weight vector*/
+    build_weight_vect(nrows, ncols, ncriteria, weight, weight_vect);	/*calcolate weight vector */
-		struct input *p = &attributes[i];
-		p->name = criteria->answers[i];
-		p->mapset = G_find_cell2(p->name,""); /* G_find_cell: Looks for the raster map "name" in the database. */
-		if (p->mapset==NULL) /* returns NULL if the map was not found in any mapset,   mapset name otherwise */
-			G_fatal_error(_("Raster file <%s> not found"), p->name);
+	struct input *p = &attributes[i];
-		if((p->infd = G_open_cell_old(p->name, p->mapset))<0) /* G_open_cell_old - returns file destriptor (>0) */
-			G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),p->name, p->mapset);
+	p->name = criteria->answers[i];
+	p->mapset = G_find_cell2(p->name, "");	/* G_find_cell: Looks for the raster map "name" in the database. */
+	if (p->mapset == NULL)	/* returns NULL if the map was not found in any mapset,   mapset name otherwise */
+	    G_fatal_error(_("Raster file <%s> not found"), p->name);
-		if(G_get_cellhd(p->name,p->mapset,&cellhd)<0)/* controlling, if we can open input raster */
-			G_fatal_error(_("Unable to read file header of <%s>"), p->name);
+	if ((p->infd = G_open_cell_old(p->name, p->mapset)) < 0)	/* G_open_cell_old - returns file destriptor (>0) */
+	    G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),
+			  p->name, p->mapset);
-		p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+	if (G_get_cellhd(p->name, p->mapset, &cellhd) < 0)	/* controlling, if we can open input raster */
+	    G_fatal_error(_("Unable to read file header of <%s>"), p->name);
-	result_concordance=concordance->answer; /* store outputn name in variables*/
-	result_discordance=discordance->answer;
+	p->inrast = G_allocate_d_raster_buf();	/* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+    result_concordance = concordance->answer;	/* store outputn name in variables */
+    result_discordance = discordance->answer;
-    if (G_legal_filename(result_concordance) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
-	if (G_legal_filename(result_discordance) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
+    if (G_legal_filename(result_concordance) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
-	/*values = G_malloc(ncriteria * sizeof(DCELL));*/
+    if (G_legal_filename(result_discordance) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
-	nrows = G_window_rows();
-        ncols = G_window_cols();
+    /*values = G_malloc(ncriteria * sizeof(DCELL)); */
-	/*memory allocation for-three dimensional matrix*/
-	decision_vol=G_malloc(nrows * sizeof(double*));
-	for (i=0; i<nrows; ++i)
-		decision_vol[i]=G_malloc(ncols * sizeof(double*));
-		for (j=0; j<ncols; ++j)
-			decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage enven concordance and discordance index map****/
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    /*memory allocation for-three dimensional matrix */
+    decision_vol = G_malloc(nrows * sizeof(double *));
+    for (i = 0; i < nrows; ++i) {
+	decision_vol[i] = G_malloc(ncols * sizeof(double *));
+	for (j = 0; j < ncols; ++j) {
+	    decision_vol[i][j] = G_malloc((ncriteria + 2) * sizeof(double));	     /****NOTE: it's storage enven concordance and discordance index map****/
     /* Allocate output buffer, use  DCELL_TYPE */
-    outrast_concordance = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
-	outrast_discordance = G_allocate_raster_buf(DCELL_TYPE);
+    outrast_concordance = G_allocate_raster_buf(DCELL_TYPE);	/* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_discordance = G_allocate_raster_buf(DCELL_TYPE);
     /* controlling, if we can write the raster */
-    if ((outfd_concordance = G_open_raster_new(result_concordance, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_concordance);
+    if ((outfd_concordance =
+	 G_open_raster_new(result_concordance, DCELL_TYPE)) < 0)
+	G_fatal_error(_("Unable to create raster map <%s>"),
+		      result_concordance);
-	if ((outfd_discordance = G_open_raster_new(result_discordance, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_discordance);
+    if ((outfd_discordance =
+	 G_open_raster_new(result_discordance, DCELL_TYPE)) < 0)
+		      result_discordance);
-		/*build a three dimensional matrix for storage all critera maps*/
-	for(i=0;i<ncriteria;i++)
-		for (row1 = 0; row1 < nrows;row1++)
-			G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
-				/*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
-				/* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array*/
-				DCELL v1 = ((DCELL *)attributes[i].inrast)[col1];
-				decision_vol[row1][col1][i]=(double)(v1);
+    /*build a three dimensional matrix for storage all critera maps */
+	    G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1, DCELL_TYPE);	/* Reads appropriate information into the buffer buf associated with the requested row */
+	    /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row); */
+		/* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array */
+		DCELL v1 = ((DCELL *) attributes[i].inrast)[col1];
+		decision_vol[row1][col1][i] = (double)(v1);
-	build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
+    build_dominance_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol);	/*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index */
-	for(row1 = 0; row1 < nrows; row1++)
-			((DCELL *) outrast_concordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];/*write concordance map*/
-			((DCELL *) outrast_discordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+1];/*write discordance map*/
-		if (G_put_raster_row(outfd_concordance, outrast_concordance,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_concordance);
-		if (G_put_raster_row(outfd_discordance, outrast_discordance,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_discordance);
+	    ((DCELL *) outrast_concordance)[col1] = (DCELL) decision_vol[row1][col1][ncriteria];	/*write concordance map */
+	    ((DCELL *) outrast_discordance)[col1] = (DCELL) decision_vol[row1][col1][ncriteria + 1];	/*write discordance map */
+	if (G_put_raster_row
+	    (outfd_concordance, outrast_concordance, DCELL_TYPE) < 0)
+	    G_fatal_error(_("Failed writing raster map <%s>"),
+	    (outfd_discordance, outrast_discordance, DCELL_TYPE) < 0)
-	G_message("End: %s",G_date());
+    G_message("End: %s", G_date());
     /* memory cleanup */
-	for (i = 0; i<ncriteria; i++)
-		G_free(attributes[i].inrast);
+	G_free(attributes[i].inrast);
     G_free(outrast_concordance);
-	G_free(outrast_discordance);
-	G_free(decision_vol);
+    G_free(outrast_discordance);
+    G_free(decision_vol);
     /* closing raster maps */
-		G_close_cell(attributes[i].infd);
+	G_close_cell(attributes[i].infd);
     G_close_cell(outfd_concordance);
-	G_close_cell(outfd_discordance);
+    G_close_cell(outfd_discordance);
     /* add command line incantation to history concordance file */
     G_short_history(result_concordance, "raster", &history);
@@ -229,5 +235,3 @@
     exit(EXIT_SUCCESS);
Modified: grass-addons/raster/mcda/r.mcda.fuzzy/fuzzy.c
--- grass-addons/raster/mcda/r.mcda.fuzzy/fuzzy.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.fuzzy/fuzzy.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -4,116 +4,109 @@
-void build_fuzzy_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double ***decision_vol);
+void build_fuzzy_matrix(int nrows, int ncols, int ncriteria,
-	int i,nweight=0;
-    		nweight++;
+	nweight++;
-	int row1,col1,row2,col2;
-	int i,j,k,cont;
-	double row_sum_conc, col_sum_conc,row_sum_disc, col_sum_disc;
-	double value;
-	/* apply linguistic modifier -*/
-	for (row1=0;row1<nrows;row1++)
-		for (col1=0;col1<ncols;col1++)
-				decision_vol[row1][col1][i]=pow(decision_vol[row1][col1][i],weight_vect[i]);
+    double row_sum_conc, col_sum_conc, row_sum_disc, col_sum_disc;
+    double value;
-		/* operate intersection - AND logic (find min value -)*/
-	for(row1=0;row1<nrows;row1++)
-		for(col1=0;col1<ncols;col1++)
-			value=decision_vol[row1][col1][0]; /* set value to firsth matrix i-value*/
-				if (decision_vol[row1][col1][i]>=value)
-				 	{value=value;}
-				else
-					{value=decision_vol[row1][col1][i];}
-			decision_vol[row1][col1][ncriteria]=value;
+    /* apply linguistic modifier - */
+		    pow(decision_vol[row1][col1][i], weight_vect[i]);
+    /* operate intersection - AND logic (find min value -) */
+	    value = decision_vol[row1][col1][0];	/* set value to firsth matrix i-value */
+		if (decision_vol[row1][col1][i] >= value) {
+		    value = value;
-		/* operate union - OR logic (find max value -)*/
-				if (decision_vol[row1][col1][i]<=value)
-				 	{value=value;}
-				else
-			decision_vol[row1][col1][ncriteria+1]=value;
+		else {
+		    value = decision_vol[row1][col1][i];
-		/* operate OWA (find average value -)*/
-				value=value+decision_vol[row1][col1][i];
-			decision_vol[row1][col1][ncriteria+2]=value/ncriteria;
+	    decision_vol[row1][col1][ncriteria] = value;
+    /* operate union - OR logic (find max value -) */
+		if (decision_vol[row1][col1][i] <= value) {
+		    value = value;
+		else {
+	    decision_vol[row1][col1][ncriteria + 1] = value;
+    /* operate OWA (find average value -) */
+		value = value + decision_vol[row1][col1][i];
+	    decision_vol[row1][col1][ncriteria + 2] = value / ncriteria;
Modified: grass-addons/raster/mcda/r.mcda.fuzzy/local_proto.h
--- grass-addons/raster/mcda/r.mcda.fuzzy/local_proto.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.fuzzy/local_proto.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -9,7 +9,7 @@
 struct input
-	int infd;
+    int infd;
Modified: grass-addons/raster/mcda/r.mcda.fuzzy/main.c
--- grass-addons/raster/mcda/r.mcda.fuzzy/main.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.fuzzy/main.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -23,14 +24,14 @@
-    char *result_and, *result_or, *result_owa;		/* outputs raster name */
+    char *result_and, *result_or, *result_owa;	/* outputs raster name */
     unsigned char *outrast_and, *outrast_or, *outrast_owa;	/* output buffer */
     int nrows, ncols;
-    int outfd_and, outfd_or,outfd_owa;		/* output file descriptor */
+    int outfd_and, outfd_or, outfd_owa;	/* output file descriptor */
@@ -39,7 +40,7 @@
     struct Option *criteria, *weight, *and, *or, *owa;	/* options */
@@ -48,192 +49,191 @@
     module->keywords = _("raster,fuzzy,MCDA");
-    module->description = _("Multicirtieria decision analysis based on Yager fuzzy method");
+	_("Multicirtieria decision analysis based on Yager fuzzy method");
     criteria->description = "Input geographics criteria in evaluation table";
     weight->description = _("Linguistic modifier (w1,w2,..)");
-    and = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	and->key = "AND";
+    and = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    and->key = "AND";
     and->type = TYPE_STRING;
     and->required = YES;
     and->gisprompt = "new,cell,raster";
-    and->answer ="intersect";
+    and->answer = "intersect";
     and->description = "Intersection output map";
-	or = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	or->key = "OR";
+    or = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    or->key = "OR";
     or->type = TYPE_STRING;
     or->required = YES;
     or->gisprompt = "new,cell,raster";
-    or->answer ="union";
+    or->answer = "union";
     or->description = "Union output map";
-	owa = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	owa->key = "OWA";
+    owa = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    owa->key = "OWA";
     owa->type = TYPE_STRING;
     owa->required = YES;
     owa->gisprompt = "new,cell,raster";
-    owa->answer ="OWA";
+    owa->answer = "OWA";
     owa->description = "OWA output map";
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-	G_message("\n\nstart: %s",G_date()); /*write calculation start time*/
+    G_message("\n\nstart: %s", G_date());	/*write calculation start time */
-    		ncriteria++;
+	ncriteria++;
     /* CRITERIA grid */
-	result_and=and->answer; /* store outputn name in variables*/
-	result_or=or->answer;
-	result_owa=owa->answer;
+    result_and = and->answer;	/* store outputn name in variables */
+    result_or = or->answer;
+    result_owa = owa->answer;
-    if (G_legal_filename(result_and) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_and);
-	if (G_legal_filename(result_or) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_or);
+    if (G_legal_filename(result_and) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_and);
-	if (G_legal_filename(result_owa) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_owa);
+    if (G_legal_filename(result_or) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_or);
+    if (G_legal_filename(result_owa) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_owa);
-			decision_vol[i][j]=G_malloc((ncriteria+3) * sizeof(double)); /****NOTE: it's storage enven and, or, owa map*/
+	    decision_vol[i][j] = G_malloc((ncriteria + 3) * sizeof(double));	     /****NOTE: it's storage enven and, or, owa map*/
-    outrast_and = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
-	outrast_or = G_allocate_raster_buf(DCELL_TYPE);
-	outrast_owa = G_allocate_raster_buf(DCELL_TYPE);
+    outrast_and = G_allocate_raster_buf(DCELL_TYPE);	/* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_or = G_allocate_raster_buf(DCELL_TYPE);
+    outrast_owa = G_allocate_raster_buf(DCELL_TYPE);
     if ((outfd_and = G_open_raster_new(result_and, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_and);
+	G_fatal_error(_("Unable to create raster map <%s>"), result_and);
-	if ((outfd_or = G_open_raster_new(result_or, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_or);
+    if ((outfd_or = G_open_raster_new(result_or, DCELL_TYPE)) < 0)
+	G_fatal_error(_("Unable to create raster map <%s>"), result_or);
-	if ((outfd_owa = G_open_raster_new(result_owa, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_owa);
+    if ((outfd_owa = G_open_raster_new(result_owa, DCELL_TYPE)) < 0)
+	G_fatal_error(_("Unable to create raster map <%s>"), result_owa);
-	build_fuzzy_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
-			((DCELL *) outrast_and)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];
-			((DCELL *) outrast_or)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+1];
-			((DCELL *) outrast_owa)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+2];
+    build_fuzzy_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol);	/*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index */
-		if (G_put_raster_row(outfd_and, outrast_and,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_and);
+	    ((DCELL *) outrast_and)[col1] =
+		(DCELL) decision_vol[row1][col1][ncriteria];
+	    ((DCELL *) outrast_or)[col1] =
+		(DCELL) decision_vol[row1][col1][ncriteria + 1];
+	    ((DCELL *) outrast_owa)[col1] =
+		(DCELL) decision_vol[row1][col1][ncriteria + 2];
-		if (G_put_raster_row(outfd_or, outrast_or,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_or);
+	if (G_put_raster_row(outfd_and, outrast_and, DCELL_TYPE) < 0)
+	    G_fatal_error(_("Failed writing raster map <%s>"), result_and);
-		if (G_put_raster_row(outfd_owa, outrast_owa,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_owa);
+	if (G_put_raster_row(outfd_or, outrast_or, DCELL_TYPE) < 0)
+	    G_fatal_error(_("Failed writing raster map <%s>"), result_or);
+	if (G_put_raster_row(outfd_owa, outrast_owa, DCELL_TYPE) < 0)
+	    G_fatal_error(_("Failed writing raster map <%s>"), result_owa);
-	G_message("end: %s, by!",G_date());
+    G_message("end: %s, by!", G_date());
     G_free(outrast_and);
-	G_free(outrast_or);
-	G_free(outrast_owa);
+    G_free(outrast_or);
+    G_free(outrast_owa);
     G_close_cell(outfd_and);
-	G_close_cell(outfd_or);
-	G_close_cell(outfd_owa);
+    G_close_cell(outfd_or);
+    G_close_cell(outfd_owa);
     /* add command line incantation to history AND file */
     G_short_history(result_and, "raster", &history);
@@ -252,5 +252,3 @@
     exit(EXIT_SUCCESS);
Modified: grass-addons/raster/mcda/r.mcda.regime/local_proto.h
--- grass-addons/raster/mcda/r.mcda.regime/local_proto.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.regime/local_proto.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -9,7 +9,7 @@
 struct input
-	int infd;
+    int infd;
Modified: grass-addons/raster/mcda/r.mcda.regime/main.c
--- grass-addons/raster/mcda/r.mcda.regime/main.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.regime/main.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -23,15 +24,15 @@
-    char *result_preference;		/* outputs raster name */
+    char *result_preference;	/* outputs raster name */
     unsigned char *outrast_preference;	/* output buffer */
     char *message;
     int nrows, ncols;
-    int outfd_preference;		/* output file descriptor */
+    int outfd_preference;	/* output file descriptor */
@@ -40,7 +41,7 @@
     struct Option *criteria, *weight, *preference;	/* options */
@@ -49,30 +50,32 @@
-    module->description = _("Multicirtieria decision analysis based on REGIME method");
+	_("Multicirtieria decision analysis based on REGIME method");
-    preference = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-	preference->key = "preference";
+    preference = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    preference->key = "preference";
     preference->type = TYPE_STRING;
     preference->required = YES;
     preference->gisprompt = "new,cell,raster";
-    preference->answer ="regime_map";
+    preference->answer = "regime_map";
     preference->description = "regime preference output map";
@@ -81,115 +84,113 @@
 	exit(EXIT_FAILURE);
-	G_message("start: %s",G_date()); /*write calculation start time*/
+    G_message("start: %s", G_date());	/*write calculation start time */
-    		ncriteria++;
+	ncriteria++;
     /* CRITERIA grid */
-		p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL*/
-	result_preference=preference->answer; /* store outputn name in variables*/
+    result_preference = preference->answer;	/* store outputn name in variables */
-    if (G_legal_filename(result_preference) < 0) /* check for legal database file names */
-		G_fatal_error(_("<%s> is an illegal file name"), result_preference);
+    if (G_legal_filename(result_preference) < 0)	/* check for legal database file names */
+	G_fatal_error(_("<%s> is an illegal file name"), result_preference);
-			decision_vol[i][j]=G_malloc((ncriteria+1) * sizeof(double)); /*NOTE: it's storage enven preference regime index map*/
+	    decision_vol[i][j] = G_malloc((ncriteria + 1) * sizeof(double));	/*NOTE: it's storage enven preference regime index map */
-    outrast_preference = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_preference = G_allocate_raster_buf(DCELL_TYPE);	/* Allocate memory for a raster map of type DCELL_TYPE. */
-    if ((outfd_preference = G_open_raster_new(result_preference, DCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), result_preference);
+    if ((outfd_preference =
+	 G_open_raster_new(result_preference, DCELL_TYPE)) < 0)
+		      result_preference);
-	G_message("build matrix: %s",G_date());
-	build_regime_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil regime index matrix */
+    G_message("build matrix: %s", G_date());
+    build_regime_matrix(nrows, ncols, ncriteria, weight_vect, decision_vol);	/*scan all DCELL, make a pairwise comparatione, buil regime index matrix */
-			((DCELL *) outrast_preference)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];/*write concordance map*/
-		if (G_put_raster_row(outfd_preference, outrast_preference,  DCELL_TYPE) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result_preference);
-	G_message("end: %s",G_date());
+	    ((DCELL *) outrast_preference)[col1] = (DCELL) decision_vol[row1][col1][ncriteria];	/*write concordance map */
+	if (G_put_raster_row(outfd_preference, outrast_preference, DCELL_TYPE)
+	    < 0)
+    G_message("end: %s", G_date());
     G_free(outrast_preference);
     G_close_cell(outfd_preference);
@@ -200,5 +201,3 @@
     exit(EXIT_SUCCESS);
Modified: grass-addons/raster/mcda/r.mcda.regime/regime.c
--- grass-addons/raster/mcda/r.mcda.regime/regime.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.mcda.regime/regime.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -4,89 +4,85 @@
-void build_regime_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double ***decision_vol);
+void build_regime_matrix(int nrows, int ncols, int ncriteria,
-	int i,nweight=0;
-    		nweight++;
+	nweight++;
-	int i,j,k,cont;
-	double *row_sum_regime = G_alloc_vector(nrows * ncols);
-	j=0;	/* make pairwise comparation and built regime matrix*/
-					double reg = 0;
-						double d=decision_vol[row1][col1][i]-decision_vol[row2][col2][i];
-						if(d>0)
-							reg += (1*weight_vect[i]);
-						else if(d<0)
-							reg += (-1*weight_vect[i]);
-						else
-							reg += 0;
-					row_sum_regime[j] += reg;
-			j++;/* increase rows index up to nrows*ncols*/
-		G_percent(row1, nrows, 1);
+    double *row_sum_regime = G_alloc_vector(nrows * ncols);
-		/*calculate concordance and discordance index and storage in decision_vol*/
-	cont=0;
-			decision_vol[row1][col1][ncriteria]=row_sum_regime[cont]/(nrows*ncols-1);/*fill matrix with regime index for each DCELL*/
-			cont++;
+    j = 0;			/* make pairwise comparation and built regime matrix */
+		    double reg = 0;
+			double d =
+			if (d > 0)
+			    reg += (1 * weight_vect[i]);
+			else if (d < 0)
+			    reg += (-1 * weight_vect[i]);
+			else
+			    reg += 0;
+		    row_sum_regime[j] += reg;
+	G_percent(row1, nrows, 1);
+    cont = 0;
+	    decision_vol[row1][col1][ncriteria] = row_sum_regime[cont] / (nrows * ncols - 1);	/*fill matrix with regime index for each DCELL */
+	    cont++;
Modified: grass-addons/raster/mcda/r.roughset/localproto.h
--- grass-addons/raster/mcda/r.roughset/localproto.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/localproto.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -9,12 +9,7 @@
 struct input
-	int fd;
-	CELL *buf;
+    int fd;
+    CELL *buf;
Modified: grass-addons/raster/mcda/r.roughset/main.c
--- grass-addons/raster/mcda/r.roughset/main.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/main.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
  * MODULE:       r.roughset
@@ -21,29 +22,31 @@
-    struct Cell_head cellhd;		/* it stores region information, and header of rasters */
-    char *mapset;					/* mapset name */
-    int i,j;						/* index and  files number*/
-    int row,col,nrows, ncols;
-    int nattributes;			/*attributes numer*/
-    int strgy, cls;				/* strategy rules extraction and classifiy index*/
-	char *result;			/* output raster name */
-	int *classify_vect;  	/* matrix for classified value storage*/
-	int outfd;				/* output file descriptor */
-	unsigned char *outrast;	/* output buffer */
+    struct Cell_head cellhd;	/* it stores region information, and header of rasters */
+    char *mapset;		/* mapset name */
+    int i, j;			/* index and  files number */
+    int row, col, nrows, ncols;
+    int nattributes;		/*attributes numer */
+    int strgy, cls;		/* strategy rules extraction and classifiy index */
+    char *result;		/* output raster name */
+    int *classify_vect;		/* matrix for classified value storage */
+    int outfd;			/* output file descriptor */
+    unsigned char *outrast;	/* output buffer */
     RASTER_MAP_TYPE data_type;	/* type of the map (CELL/DCELL/...) */
-    /*int value, decvalue;*/	/*single attribute and decision value*/
+    /*int value, decvalue; *//*single attribute and decision value */
     struct GModule *module;	/* GRASS module for parsing arguments */
     struct Option *attr_map, *dec_map, *dec_txt, *genrules, *clssfy, *output_txt, *output_map;	/* options */
-    /*struct Flag *flagQuiet		flags */
+    /*struct Flag *flagQuiet            flags */
     G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
@@ -54,209 +57,214 @@
-    attr_map = G_define_option() ; /* Allocates memory for the Option structure and returns a pointer to this memory */
-    attr_map->key        = "attributes";
-    attr_map->type       = TYPE_STRING;
-    attr_map->required   = YES;
-    attr_map->multiple   = YES;
-    attr_map->gisprompt  = "old,cell,raster" ;
-    attr_map->description = _("Input geographics ATTRIBUTES in information system");
-    dec_map = G_define_option() ;
-    dec_map->key        = "decision";
-    dec_map->type       = TYPE_STRING;
-    dec_map->required   = NO;
-    dec_map->gisprompt  = "old,cell,raster" ;
-    dec_map->description = _("Input geographics DECISION in information system");
+    attr_map = G_define_option();	/* Allocates memory for the Option structure and returns a pointer to this memory */
+    attr_map->key = "attributes";
+    attr_map->type = TYPE_STRING;
+    attr_map->required = YES;
+    attr_map->multiple = YES;
+    attr_map->gisprompt = "old,cell,raster";
+    attr_map->description =
+	_("Input geographics ATTRIBUTES in information system");
-    genrules = G_define_option() ;
-    genrules->key        = "strgy";
-    genrules->type       = TYPE_STRING;
-    genrules->required   = YES;
-    genrules->options	 = "Very fast,Fast,Medium,Best,All,Low,Upp,Normal";
-    genrules->answer	 = "Very fast";
+    dec_map = G_define_option();
+    dec_map->key = "decision";
+    dec_map->type = TYPE_STRING;
+    dec_map->required = NO;
+    dec_map->gisprompt = "old,cell,raster";
+    dec_map->description =
+	_("Input geographics DECISION in information system");
+    genrules = G_define_option();
+    genrules->key = "strgy";
+    genrules->type = TYPE_STRING;
+    genrules->required = YES;
+    genrules->options = "Very fast,Fast,Medium,Best,All,Low,Upp,Normal";
+    genrules->answer = "Very fast";
     genrules->description = _("Strategies for generating rules");
-	dec_txt = G_define_option();
-    dec_txt->key 		= "sample";
-    dec_txt->type 		= TYPE_STRING;
-    dec_txt->required 	= NO;
-    dec_txt->gisprompt 	= "old_file,file,input";
-    dec_txt->description = _("Input text file  with  data and decision sample");
-    clssfy = G_define_option() ;
-    clssfy->key        	= "clssfy";
-    clssfy->type       	= TYPE_STRING;
-    clssfy->required  	= YES;
-    clssfy->options	   	= "Classify1,Classify2,Classify3";
-    clssfy->answer 		="Classify1";
-    clssfy->description = _("Strategies for classified map (conflict resolution)");
+    dec_txt = G_define_option();
+    dec_txt->key = "sample";
+    dec_txt->type = TYPE_STRING;
+    dec_txt->required = NO;
+    dec_txt->gisprompt = "old_file,file,input";
+    dec_txt->description =
+	_("Input text file  with  data and decision sample");
+    clssfy = G_define_option();
+    clssfy->key = "clssfy";
+    clssfy->type = TYPE_STRING;
+    clssfy->required = YES;
+    clssfy->options = "Classify1,Classify2,Classify3";
+    clssfy->answer = "Classify1";
+    clssfy->description =
+	_("Strategies for classified map (conflict resolution)");
     output_txt = G_define_option();
     output_txt->key = "outTXT";
     output_txt->type = TYPE_STRING;
     output_txt->required = YES;
-   // output_txt->gisprompt = "new_file,file,output";
-    output_txt->answer ="InfoSys";
+    // output_txt->gisprompt = "new_file,file,output";
+    output_txt->answer = "InfoSys";
     output_txt->description = _("Output information system file");
-  	output_map = G_define_option();
-	output_map->key = "outMAP";
+    output_map = G_define_option();
+    output_map->key = "outMAP";
     output_map->type = TYPE_STRING;
     output_map->required = YES;
-    output_map->answer ="classify";
+    output_map->answer = "classify";
     output_map->description = _("Output classified map");
 	exit(EXIT_FAILURE);
-	/* Either decision map or sample file are necesary*/
-	if (dec_map->answer==NULL && dec_txt->answer==NULL)
-			G_fatal_error(_("Either decision map or sample file are necessary!"));
+    /* Either decision map or sample file are necesary */
+    if (dec_map->answer == NULL && dec_txt->answer == NULL)
+	G_fatal_error(_("Either decision map or sample file are necessary!"));
 /********Prepare and controlling Information System files **************/
-       /* number of file (=attributes) */
-    nattributes=0;
-    while (attr_map->answers[nattributes]!=NULL)
-    		nattributes++;
+    /* number of file (=attributes) */
+    nattributes = 0;
+    while (attr_map->answers[nattributes] != NULL) {
+	nattributes++;
-/* store output classified MAP name in variable*/
-	result=output_map->answer;
+    /* store output classified MAP name in variable */
+    result = output_map->answer;
-/*Convert strategy rules extraction answer in index.  strcmp return 0 if answer is the passed string*/
-    if(strcmp(genrules->answer,"Very fast")==0)
-    	strgy=0;
-    else if(strcmp(genrules->answer,"Fast")==0)
-    	strgy=1;
-    else if(strcmp(genrules->answer,"Medium")==0)
-    	strgy=2;
-    else if(strcmp(genrules->answer,"Best")==0)
-    	strgy=3;
-    else if(strcmp(genrules->answer,"All")==0)
-    	strgy=4;
-    else if(strcmp(genrules->answer,"Low")==0)
-    	strgy=5;
-    else if(strcmp(genrules->answer,"Upp")==0)
-    	strgy=6;
+    /*Convert strategy rules extraction answer in index.  strcmp return 0 if answer is the passed string */
+    if (strcmp(genrules->answer, "Very fast") == 0)
+	strgy = 0;
+    else if (strcmp(genrules->answer, "Fast") == 0)
+	strgy = 1;
+    else if (strcmp(genrules->answer, "Medium") == 0)
+	strgy = 2;
+    else if (strcmp(genrules->answer, "Best") == 0)
+	strgy = 3;
+    else if (strcmp(genrules->answer, "All") == 0)
+	strgy = 4;
+    else if (strcmp(genrules->answer, "Low") == 0)
+	strgy = 5;
+    else if (strcmp(genrules->answer, "Upp") == 0)
+	strgy = 6;
     else
-    	strgy=7;
+	strgy = 7;
- /*Convert strategy map lassify answer in index.  strcmp return 0 if answer is the passed string*/
+    /*Convert strategy map lassify answer in index.  strcmp return 0 if answer is the passed string */
-	if(strcmp(clssfy->answer,"Classify1")==0)
-		cls=0;
-	else if(strcmp(clssfy->answer,"Classify2")==0)
-		cls=1;
-	else if(strcmp(clssfy->answer,"Classify3")==0)
-		cls=2;
-	else
-		cls=0;
+    if (strcmp(clssfy->answer, "Classify1") == 0)
+	cls = 0;
+    else if (strcmp(clssfy->answer, "Classify2") == 0)
+	cls = 1;
+    else if (strcmp(clssfy->answer, "Classify3") == 0)
+	cls = 2;
+    else
+	cls = 0;
-    /* process the input maps:*/
+    /* process the input maps: */
     /* ATTRIBUTES grid */
-    attributes = G_malloc((nattributes+1) * sizeof(struct input)); /*attributes is input struct defined in localproto.h*/
+    attributes = G_malloc((nattributes + 1) * sizeof(struct input));	/*attributes is input struct defined in localproto.h */
-	for (i = 0; i < nattributes; i++)
-		p->name = attr_map->answers[i];
-		p->mapset = G_find_cell(p->name,""); /* G_find_cell: Looks for the raster map "name" in the database. */
-		p->fd = G_open_cell_old(p->name, p->mapset);
-		if (!p->mapset)
-		if (p->fd < 0)
-		if (CELL_TYPE!=G_raster_map_type(p->name, p->mapset))
-			G_fatal_error(_("Input map <%s> in mapset <%s> isn't CELL type"),p->name, p->mapset);
-		p->buf = G_allocate_c_raster_buf(); /* Allocate an array of CELL based on the number of columns in the current region. Return DCELL *  */
+    for (i = 0; i < nattributes; i++) {
-	/* define the inputmap DECISION type (CELL) */
-    data_type = CELL_TYPE; //
-   /* Allocate output buffer, use input map data_type */
-	outrast = G_allocate_raster_buf(data_type);
-   /* DECISION grid (at last column in Information System matrix) */
-	if(dec_map->answer!=NULL)
-		struct input *p = &attributes[nattributes];
-		p->name = dec_map->answer;
-		if (!p->mapset)
-		p->fd = G_open_cell_old(p->name, p->mapset);/*opens the raster file name in mapset for reading. A nonnegative file descriptor is returned if the open is successful.*/
-		if (p->fd < 0)
-		p->buf = G_allocate_raster_buf(data_type); /* Allocate an array of DCELL based on the number of columns in the current region.
-		Return DCELL *  */
-		rough_set_library_out(nrows, ncols, nattributes, attributes, output_txt->answer);/*build RSL standard file*/
-	classify_vect = G_malloc(sizeof(int) * (nrows*ncols)); /* memory allocation*/
-	rough_analysis(nrows, ncols, output_txt->answer, classify_vect, attributes, dec_txt->answer, strgy,cls); /* extract rules from RSL and generate classified vectpr*/
-	/* controlling, if we can write the raster */
+	p->name = attr_map->answers[i];
+	p->mapset = G_find_cell(p->name, "");	/* G_find_cell: Looks for the raster map "name" in the database. */
+	p->fd = G_open_cell_old(p->name, p->mapset);
+	if (!p->mapset)
+	if (p->fd < 0)
+	if (CELL_TYPE != G_raster_map_type(p->name, p->mapset))
+	    G_fatal_error(_("Input map <%s> in mapset <%s> isn't CELL type"),
+	p->buf = G_allocate_c_raster_buf();	/* Allocate an array of CELL based on the number of columns in the current region. Return DCELL *  */
+    /* define the inputmap DECISION type (CELL) */
+    data_type = CELL_TYPE;	//
+    /* Allocate output buffer, use input map data_type */
+    outrast = G_allocate_raster_buf(data_type);
+    /* DECISION grid (at last column in Information System matrix) */
+    if (dec_map->answer != NULL) {
+	struct input *p = &attributes[nattributes];
+	p->name = dec_map->answer;
+	if (!p->mapset)
+	p->fd = G_open_cell_old(p->name, p->mapset);	/*opens the raster file name in mapset for reading. A nonnegative file descriptor is returned if the open is successful. */
+	if (p->fd < 0)
+	p->buf = G_allocate_raster_buf(data_type);	/* Allocate an array of DCELL based on the number of columns in the current region.
+							   Return DCELL *  */
+	rough_set_library_out(nrows, ncols, nattributes, attributes, output_txt->answer);	/*build RSL standard file */
+    classify_vect = G_malloc(sizeof(int) * (nrows * ncols));	/* memory allocation */
+    rough_analysis(nrows, ncols, output_txt->answer, classify_vect, attributes, dec_txt->answer, strgy, cls);	/* extract rules from RSL and generate classified vectpr */
+    /* controlling, if we can write the raster */
     if ((outfd = G_open_raster_new(result, CELL_TYPE)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), result);
-	 /* generate classified map*/
-	G_message("Building calssified map...");
-	j=0; /* builder map index*/
-	for(row = 0; row < nrows; row++)
-		CELL c;
-		G_percent(row, nrows, 2);
-		for (col = 0; col < ncols; col++)
-			c=((CELL *) classify_vect[j]);
-			((CELL *) outrast)[col] = c;
-			j++;
-		if (G_put_raster_row(outfd, outrast,  data_type) < 0)
-			G_fatal_error(_("Failed writing raster map <%s>"), result);
+    /* generate classified map */
+    G_message("Building calssified map...");
+    j = 0;			/* builder map index */
+    for (row = 0; row < nrows; row++) {
+	CELL c;
+	G_percent(row, nrows, 2);
+	for (col = 0; col < ncols; col++) {
+	    c = ((CELL *) classify_vect[j]);
+	    ((CELL *) outrast)[col] = c;
+	    j++;
-		/* memory cleanup */
-	for (i = 0; i<=nattributes; i++)
-		G_close_cell(attributes[i].fd);
-	G_close_cell(outfd);
-	for (i = 0; i<nattributes; i++)
-		G_free(attributes[i].buf);
-	//G_free(outrast);
-	G_message("End: %s, with %d cells.",G_date(),j);
-	/* add command line incantation to history file */
+	if (G_put_raster_row(outfd, outrast, data_type) < 0)
+	    G_fatal_error(_("Failed writing raster map <%s>"), result);
+    /* memory cleanup */
+    for (i = 0; i <= nattributes; i++)
+	G_close_cell(attributes[i].fd);
+    G_close_cell(outfd);
+	G_free(attributes[i].buf);
+    //G_free(outrast);
+    G_message("End: %s, with %d cells.", G_date(), j);
+    /* add command line incantation to history file */
     G_short_history(result, "raster", &history);
     G_command_history(&history);
     G_write_history(result, &history);
-	exit(EXIT_SUCCESS);
+    exit(EXIT_SUCCESS);
-/* dom 07 dic 2008 07:05:15 CET */
+/* dom 07 dic 2008 07:05:15 CET */
Modified: grass-addons/raster/mcda/r.roughset/raccess.c
--- grass-addons/raster/mcda/r.roughset/raccess.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/raccess.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,160 +16,213 @@
  *   	    	 for details.
 /***            FUNCTION OF ACCESS TO SYSTEM TABLES                        ***/
 /*** part of the ROUGH system written by M.Gawrys J. Sienkiewicz           ***/
 #include "rough.h"
-setA _table_element=NULL;
-setA _table_end=NULL;
-int  _table_row;
-int  _table_column;
-int  _table_no;
+setA _table_element = NULL;
+setA _table_end = NULL;
+int _table_row;
+int _table_column;
+int _table_no;
-static void (*_current_next)(void);
+static void (*_current_next) (void);
 void next_of_d(void)
-{  if (++_table_column>=_table_row)
-      _table_column=0, _table_row++;
-   _table_element=(_mainsys->matD)+(_mainsys->setAsize*++_table_no);
+    if (++_table_column >= _table_row)
+	_table_column = 0, _table_row++;
+    _table_element = (_mainsys->matD) + (_mainsys->setAsize * ++_table_no);
 void next_of_x(void)
-{  _table_element+=_mainsys->setAsize;
-   ++_table_no;
+    _table_element += _mainsys->setAsize;
+    ++_table_no;
 void next_of_a(void)
- { ++_table_no;
-   if (++_table_column>=_table_row)
-    { _table_column=0;
-      if (++_table_row>=_mainsys->objects_num)
-       { CloseSetA(_table_element);
-	 _table_end=_table_element;
-	 _table_row=0;
-	 return;
+    ++_table_no;
+    if (++_table_column >= _table_row) {
+	_table_column = 0;
+	if (++_table_row >= _mainsys->objects_num) {
+	    CloseSetA(_table_element);
+	    _table_end = _table_element;
+	    _table_row = 0;
+	    return;
-  GetDfromA(_table_element,_table_row,_table_column);
-  return;
+    GetDfromA(_table_element, _table_row, _table_column);
+    return;
 int start_of_tab(int matrix_type)
-   if (matrix_type==MATD)
-   {  _table_no=0;
-      _table_row=1;
-      _table_column=0;
-      _table_element=_mainsys->matD;
-      _table_end=_table_element+Dsize(_mainsys);
-      _current_next=next_of_d;
-   else if (matrix_type==MATX)
-   {  START_OF_X;
-      _table_no=0;
-      _current_next=next_of_x;
-   else if (matrix_type==MATA)
-   {  _table_no=0;
-      _table_row=0;
-      _table_column=0;
-      _table_element=InitEmptySetA();
-      _table_end=_table_element+1;
-      _current_next=next_of_a;
-      next_of_a();
-   if (_table_element==NULL) ERROR(3)
-      return(1);
+    if (matrix_type == MATD) {
+	_table_no = 0;
+	_table_row = 1;
+	_table_element = _mainsys->matD;
+	_table_end = _table_element + Dsize(_mainsys);
+	_current_next = next_of_d;
+    else if (matrix_type == MATX) {
+	START_OF_X;
+	_table_no = 0;
+	_current_next = next_of_x;
+    else if (matrix_type == MATA) {
+	_table_no = 0;
+	_table_row = 0;
+	_table_element = InitEmptySetA();
+	_table_end = _table_element + 1;
+	_current_next = next_of_a;
+	next_of_a();
+    if (_table_element == NULL)
+	ERROR(3)
+	    return (1);
 int end_of_tab(void)
-{ return (_table_element<_table_end);
+    return (_table_element < _table_end);
 void next_of_tab(void)
-{ (*_current_next)();
+    (*_current_next) ();
-setA GetD(int ob1,int ob2)
- { int pom;
-   if(ob2>ob1) { pom=ob1; ob1=ob2; ob2=pom; }
-   return (_mainsys->matD)+((ob1-1)*ob1/2+ob2)*_mainsys->setAsize;
+setA GetD(int ob1, int ob2)
+    int pom;
- value_type GetA(int ob,int atr)
- { return (_mainsys->matA)[ob*(_mainsys->attributes_num)+atr]; }
+    if (ob2 > ob1) {
+	pom = ob1;
+	ob1 = ob2;
+	ob2 = pom;
+    return (_mainsys->matD) + ((ob1 - 1) * ob1 / 2 +
+			       ob2) * _mainsys->setAsize;
-int GetDfromA(setA elem,int obj1,int obj2)
- { int nby=(_mainsys->attributes_num)/_cluster_bits; /* number of full clusters in element */
-   int nbi=_mainsys->attributes_num%_cluster_bits;   /* number of bits in the last cluster */
-   int atrnum=_mainsys->attributes_num;  	     /* number of attributes */
-   value_type *A=_mainsys->matA;
-   cluster_type val;
-   int cluster,bit;
-   for(cluster=0;cluster<nby;cluster++)
-    { val=0;
-      for(bit=0;bit<_cluster_bits;bit++)
-	 if(A[obj1*atrnum+_cluster_bits*cluster+bit]!=A[obj2*atrnum+_cluster_bits*cluster+bit] &&
-	    A[obj1*atrnum+_cluster_bits*cluster+bit]!=(value_type)-1 &&
-	    A[obj2*atrnum+_cluster_bits*cluster+bit]!=(value_type)-1 )
-	       val=val|_mask[bit];
-      elem[cluster]=val;
+value_type GetA(int ob, int atr)
+    return (_mainsys->matA)[ob * (_mainsys->attributes_num) + atr];
+int GetDfromA(setA elem, int obj1, int obj2)
+    int nby = (_mainsys->attributes_num) / _cluster_bits;	/* number of full clusters in element */
+    int nbi = _mainsys->attributes_num % _cluster_bits;	/* number of bits in the last cluster */
+    int atrnum = _mainsys->attributes_num;	/* number of attributes */
+    value_type *A = _mainsys->matA;
+    cluster_type val;
+    int cluster, bit;
+    for (cluster = 0; cluster < nby; cluster++) {
+	val = 0;
+	for (bit = 0; bit < _cluster_bits; bit++)
+	    if (A[obj1 * atrnum + _cluster_bits * cluster + bit] !=
+		A[obj2 * atrnum + _cluster_bits * cluster + bit] &&
+		A[obj1 * atrnum + _cluster_bits * cluster + bit] !=
+		(value_type) - 1 &&
+		A[obj2 * atrnum + _cluster_bits * cluster + bit] !=
+		(value_type) - 1)
+		val = val | _mask[bit];
+	elem[cluster] = val;
-   if(nbi)
-    { val=0;
-      for(bit=0;bit<nbi;bit++)
-   return 1;
-int CompareA(int ob1,int ob2,setA P)
- { int attr;
-   for(attr=0;attr<_mainsys->attributes_num;attr++)
-     if(ContSetA(P,attr))
-	if((_mainsys->matA)[ob1*(_mainsys->attributes_num)+attr]==(value_type)-1  ||
-	   (_mainsys->matA)[ob2*(_mainsys->attributes_num)+attr]==(value_type)-1  )
-	    continue;
-	else if((_mainsys->matA)[ob1*(_mainsys->attributes_num)+attr]!=
-	        (_mainsys->matA)[ob2*(_mainsys->attributes_num)+attr])
+    if (nbi) {
+	val = 0;
+	for (bit = 0; bit < nbi; bit++)
+		(value_type) - 1)
+    return 1;
+int CompareA(int ob1, int ob2, setA P)
+    int attr;
+    for (attr = 0; attr < _mainsys->attributes_num; attr++)
+	if (ContSetA(P, attr))
+	    if ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) + attr] ==
+		(value_type) - 1 ||
+		(_mainsys->matA)[ob2 * (_mainsys->attributes_num) + attr] ==
+		(value_type) - 1)
+		continue;
+	    else if ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) +
+				      attr] !=
+				      attr])
+		return 0;
+    return 1;
+int CompareD(int ob1, int ob2, setA P)
+    int pom;
+    int cluster;
+    setA elem;
+    if (ob2 > ob1) {
+	pom = ob1;
+	ob1 = ob2;
+	ob2 = pom;
+    elem =
+	(_mainsys->matD) + ((ob1 - 1) * ob1 / 2 + ob2) * (_mainsys->setAsize);
+    for (cluster = _mainsys->setAsize - 1; cluster >= 0; cluster--)
+	if (elem[cluster] & P[cluster])
 	    return 0;
-   return 1;
+    return 1;
-int CompareD(int ob1,int ob2,setA P)
- { int pom;
-   int cluster;
-   setA elem;
-   elem=(_mainsys->matD)+((ob1-1)*ob1/2+ob2)*(_mainsys->setAsize);
-   for (cluster=_mainsys->setAsize-1;cluster>=0;cluster--)
-	if (elem[cluster] & P[cluster]) return 0;
-   return 1;
+int SingCompA(int ob1, int ob2, int atr)
+    return ((_mainsys->matA)[ob1 * (_mainsys->attributes_num) + atr] ==
+	    (_mainsys->matA)[ob2 * (_mainsys->attributes_num) + atr] ||
+	    (_mainsys->matA)[ob1 * (_mainsys->attributes_num) + atr] ==
+	    (_mainsys->matA)[ob2 * (_mainsys->attributes_num) + atr] ==
+	    (value_type) - 1);
-int SingCompA(int ob1,int ob2,int atr)
- { return ((_mainsys->matA)[ob1*(_mainsys->attributes_num)+atr]==
-	   (_mainsys->matA)[ob2*(_mainsys->attributes_num)+atr] ||
-	   (_mainsys->matA)[ob1*(_mainsys->attributes_num)+atr]==(value_type)-1  ||
-	   (_mainsys->matA)[ob2*(_mainsys->attributes_num)+atr]==(value_type)-1  );
+int SingCompD(int ob1, int ob2, int atr)
+    int pom;
-int SingCompD(int ob1,int ob2,int atr)
- { int pom;
-   return !( (_mainsys->matD)[((ob1-1)*ob1/2+ob2)
-				  *(_mainsys->setAsize) + atr/_cluster_bits
-				 ] & _mask[atr%_cluster_bits] );
+    if (ob2 > ob1) {
+	pom = ob1;
+	ob1 = ob2;
+	ob2 = pom;
+    return !((_mainsys->matD)[((ob1 - 1) * ob1 / 2 + ob2)
+			      * (_mainsys->setAsize) +
+			      atr / _cluster_bits] & _mask[atr %
+							   _cluster_bits]);
Modified: grass-addons/raster/mcda/r.roughset/raccess.h
--- grass-addons/raster/mcda/r.roughset/raccess.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/raccess.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,11 +16,17 @@
  *   	    	 for details.
 /***             FUNCTIONS OF ACCESS TO SYSTEM TABLES                      ***/
 /***  part of the RSL system written by M.Gawrys J. Sienkiewicz            ***/
@@ -31,35 +38,40 @@
 #define ELEM_OF_MAT    _table_element
 #define ElemOfRule(rules,num,attr) (rules)[(num)*(_mainsys->attributes_num)+(attr)]
-extern setA     _table_element;
-extern setA     _table_end;
-extern int	_table_row;
-extern int      _table_column;
-extern int	_table_no;
+extern setA _table_element;
+extern setA _table_end;
+extern int _table_row;
+extern int _table_column;
+extern int _table_no;
-int  start_of_tab(int matrix_type);
+int start_of_tab(int matrix_type);
 void next_of_tab(void);
-int  end_of_tab(void);
+int end_of_tab(void);
-int CompareA(int ob1,int ob2,setA P);
-int CompareD(int ob1,int ob2,setA P);
+int CompareA(int ob1, int ob2, setA P);
+int CompareD(int ob1, int ob2, setA P);
 	/* compares two objects, returns 1 if all attributes from */
 	/* the set P are identical, otherwise returns 0 */
-int SingCompA(int ob1,int ob2,int atr);
-int SingCompD(int ob1,int ob2,int atr);
+int SingCompA(int ob1, int ob2, int atr);
+int SingCompD(int ob1, int ob2, int atr);
 	/* compares two objects on the sigle attribute atr */
 	/* returns 1 if identical, otherwise returns 0 */
-setA GetD(int ob1,int ob2);
+setA GetD(int ob1, int ob2);
 	/* returns a single element of matrix D, if this set */
 	/* is going to be changed, it has to be first copied */
-value_type GetA(int obj,int atr);
+value_type GetA(int obj, int atr);
 	/* returns value of attribute atr of object obj */
 	/* from matrix A */
-int GetDfromA(setA elem,int ob1,int ob2);
+int GetDfromA(setA elem, int ob1, int ob2);
 	/* generate a single element of matrix D into elem */
Modified: grass-addons/raster/mcda/r.roughset/rbasic.c
--- grass-addons/raster/mcda/r.roughset/rbasic.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rbasic.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,473 +16,592 @@
  *   	    	 for details.
 /***               BASIC QUERIES FOR ACTIVE SYSTEM                         ***/
 /***  part of the RSL system written by M.Gawrys J.Sienkiewicz             ***/
 #include "rough.h"
-int LowAppr( setO lowappr, setO X, setA P,int matrix_type)
- { switch(matrix_type)
-     { case MATA : return LowApprA(lowappr,X,P);
-       case MATD : return LowApprD(lowappr,X,P);
-       default   : ERROR(8)
+int LowAppr(setO lowappr, setO X, setA P, int matrix_type)
+    switch (matrix_type) {
+    case MATA:
+	return LowApprA(lowappr, X, P);
+    case MATD:
+	return LowApprD(lowappr, X, P);
+    default:
+	ERROR(8)
-int LowApprA( setO lowappr, setO X, setA P)
- { setO notX;
-   int ob1,ob2,disc;
-   if(_mainsys->matA==NULL) ERROR(5);
-   notX=InitEmptySetO();
-   ClearSetO(lowappr);
-   NotSetO(notX,X);
-   for(ob1=0;ob1<_mainsys->objects_num;ob1++)
-     if(ContSetO(X,ob1))
-	 { disc=1;
-	   for(ob2=0;ob2<_mainsys->objects_num;ob2++)
-	     if(ContSetO(notX,ob2))
-		if(CompareA(ob1,ob2,P)) {disc=0; break;}
-	   if(disc) AddSetO(lowappr,ob1);
-   CloseSetO(notX);
-   return 0;
+int LowApprA(setO lowappr, setO X, setA P)
+    setO notX;
+    int ob1, ob2, disc;
-int LowApprD( setO lowappr, setO X, setA P)
- { setO notX;
-   int ob1,ob2,disc;
-   if(_mainsys->matD==NULL) ERROR(6);
-   NotSetO(notX,X);
-       { disc=1;
-	     if(CompareD(ob1,ob2,P)) { disc=0; break; }
-   CloseSetO(notX);
-   return 0;
+    if (_mainsys->matA == NULL)
+	ERROR(5);
+    notX = InitEmptySetO();
+    ClearSetO(lowappr);
+    NotSetO(notX, X);
+    for (ob1 = 0; ob1 < _mainsys->objects_num; ob1++)
+	if (ContSetO(X, ob1)) {
+	    disc = 1;
+	    for (ob2 = 0; ob2 < _mainsys->objects_num; ob2++)
+		if (ContSetO(notX, ob2))
+		    if (CompareA(ob1, ob2, P)) {
+			disc = 0;
+			break;
+	    if (disc)
+		AddSetO(lowappr, ob1);
+    CloseSetO(notX);
+    return 0;
-int UppAppr( setO uppappr, setO X, setA P, int matrix_type)
-     { case MATA : return UppApprA(uppappr,X,P);
-	case MATD : return UppApprD(uppappr,X,P);
+int LowApprD(setO lowappr, setO X, setA P)
+    setO notX;
-int UppApprA( setO uppappr, setO X, setA P)
- { setO notX;
-   int ob1,ob2;
-   CopySetO(uppappr,X);
-   NotSetO(notX,X);
-	      if(CompareA(ob1,ob2,P)) AddSetO(uppappr,ob2);
-   CloseSetO(notX);
-   return 0;
+    if (_mainsys->matD == NULL)
+	ERROR(6);
+    NotSetO(notX, X);
+	    disc = 1;
+		    if (CompareD(ob1, ob2, P)) {
+			disc = 0;
+			break;
+	    if (disc)
+    CloseSetO(notX);
+    return 0;
-int UppApprD( setO uppappr, setO X, setA P)
- { setO notX;
-   int ob1,ob2;
-   NotSetO(notX,X);
-	      if(CompareD(ob1,ob2,P)) AddSetO(uppappr,ob2);
-   CloseSetO(notX);
-   return 0;
+int UppAppr(setO uppappr, setO X, setA P, int matrix_type)
+    case MATA:
+	return UppApprA(uppappr, X, P);
+    case MATD:
+	return UppApprD(uppappr, X, P);
+    default:
+	ERROR(8)
-int Bound( setO bound, setO X, setA P, int matrix_type)
-     { case MATA : return BoundA(bound,X,P);
-	case MATD : return BoundD(bound,X,P);
+int UppApprA(setO uppappr, setO X, setA P)
+    setO notX;
+    int ob1, ob2;
-int BoundA( setO bound, setO X, setA P)
-  { setO lower,upper;
-    lower=InitEmptySetO();
-    upper=InitEmptySetO();
-    LowApprA(lower,X,P);
-    UppApprA(upper,X,P);
-    DifSetO(bound,upper,lower);
+	ERROR(5);
+    CopySetO(uppappr, X);
+    NotSetO(notX, X);
+			AddSetO(uppappr, ob2);
+    CloseSetO(notX);
+    return 0;
+int UppApprD(setO uppappr, setO X, setA P)
+    setO notX;
+    int ob1, ob2;
+	ERROR(6);
+    NotSetO(notX, X);
+    CloseSetO(notX);
+    return 0;
+int Bound(setO bound, setO X, setA P, int matrix_type)
+    case MATA:
+	return BoundA(bound, X, P);
+    case MATD:
+	return BoundD(bound, X, P);
+    default:
+	ERROR(8)
+int BoundA(setO bound, setO X, setA P)
+    setO lower, upper;
+	ERROR(5);
+    lower = InitEmptySetO();
+    upper = InitEmptySetO();
+    LowApprA(lower, X, P);
+    UppApprA(upper, X, P);
+    DifSetO(bound, upper, lower);
     CloseSetO(lower);
     CloseSetO(upper);
     return 0;
-int BoundD( setO bound, setO X, setA P)
-    LowApprD(lower,X,P);
-    UppApprD(upper,X,P);
+int BoundD(setO bound, setO X, setA P)
+	ERROR(6);
+    LowApprD(lower, X, P);
+    UppApprD(upper, X, P);
     CloseSetO(lower);
     CloseSetO(upper);
     return 0;
-float AccurCoef( setO X, setA P, int matrix_type)
-     { case MATA : return AccurCoefA(X,P);
-	case MATD : return AccurCoefD(X,P);
+float AccurCoef(setO X, setA P, int matrix_type)
+    case MATA:
+	return AccurCoefA(X, P);
+    case MATD:
+	return AccurCoefD(X, P);
+    default:
+	ERROR(8)
-float AccurCoefA( setO X, setA P)
-   float coef;
-   coef= (float)CardSetO(lower) / (float)CardSetO(upper);
-   CloseSetO(lower);
-   CloseSetO(upper);
-   return coef;
+float AccurCoefA(setO X, setA P)
+    float coef;
-float AccurCoefD( setO X, setA P)
-   float coef;
-   CloseSetO(lower);
-   CloseSetO(upper);
-   return coef;
+	ERROR(5);
+    coef = (float)CardSetO(lower) / (float)CardSetO(upper);
+    CloseSetO(lower);
+    CloseSetO(upper);
+    return coef;
-float ClassCoef( setO X, setA P, int matrix_type)
-     { case MATA : return ClassCoefA(X,P);
-	case MATD : return ClassCoefD(X,P);
+float AccurCoefD(setO X, setA P)
+    float coef;
-float ClassCoefA( setO X, setA P)
- { float coef;
-   setO notX,pos;
-   int ob1,ob2;
-   pos=InitFullSetO();
-   NotSetO(notX,X);
-	if(ContSetO(X,ob1) && ContSetO(notX,ob2) && CompareA(ob1,ob2,P))
-	  { DelSetO(pos,ob1);
-	    DelSetO(pos,ob2);
-   coef= (float)CardSetO(pos) / _mainsys->objects_num;
-   CloseSetO(notX);
-   CloseSetO(pos);
-   return coef;
+	ERROR(6);
+    CloseSetO(lower);
+    CloseSetO(upper);
+    return coef;
-float ClassCoefD( setO X, setA P)
- { float coef;
-   setO notX,pos;
-   int ob1,ob2;
-   NotSetO(notX,X);
-	if(ContSetO(X,ob1) && ContSetO(notX,ob2) && CompareD(ob1,ob2,P))
-	    DelSetO(pos,ob2);
-   CloseSetO(notX);
-   CloseSetO(pos);
-   return coef;
+float ClassCoef(setO X, setA P, int matrix_type)
+    case MATA:
+	return ClassCoefA(X, P);
+    case MATD:
+	return ClassCoefD(X, P);
+    default:
+	ERROR(8)
-int Pos( setO pos, setA P, setA Q, int matrix_type)
-     { case MATA : return PosA(pos,P,Q);
-	case MATD : return PosD(pos,P,Q);
+float ClassCoefA(setO X, setA P)
+    float coef;
+    setO notX, pos;
+    int ob1, ob2;
-int PosA( setO pos, setA P, setA Q)
- { int i,j;
-   setA redQ;
-   if(IsEmptySetA(P))
-     { ClearSetO(pos);
+	ERROR(5);
+    pos = InitFullSetO();
+    NotSetO(notX, X);
+	    if (ContSetO(X, ob1) && ContSetO(notX, ob2) &&
+		CompareA(ob1, ob2, P)) {
+		DelSetO(pos, ob1);
+		DelSetO(pos, ob2);
+    coef = (float)CardSetO(pos) / _mainsys->objects_num;
+    CloseSetO(notX);
+    CloseSetO(pos);
+    return coef;
+float ClassCoefD(setO X, setA P)
+    float coef;
+    setO notX, pos;
+    int ob1, ob2;
+	ERROR(6);
+    NotSetO(notX, X);
+		CompareD(ob1, ob2, P)) {
+    CloseSetO(notX);
+    CloseSetO(pos);
+    return coef;
+int Pos(setO pos, setA P, setA Q, int matrix_type)
+    case MATA:
+	return PosA(pos, P, Q);
+    case MATD:
+	return PosD(pos, P, Q);
+    default:
+	ERROR(8)
+int PosA(setO pos, setA P, setA Q)
+    int i, j;
+    setA redQ;
+	ERROR(5);
+    if (IsEmptySetA(P)) {
+	ClearSetO(pos);
 	return 0;
-   redQ=InitEmptySetA();
-   DifSetA(redQ,Q,P);
-   FillSetO(pos);
-   if(IsEmptySetA(redQ))
-     return 0;
-   for(i=_mainsys->objects_num-1;i>0;i--)
-     for(j=i-1;j>=0;j--)
-	if(!CompareA(i,j,redQ) && CompareA(i,j,P))
-	  { DelSetO(pos,i);
-	    DelSetO(pos,j);
-   return 0;
+    redQ = InitEmptySetA();
+    DifSetA(redQ, Q, P);
+    FillSetO(pos);
+    if (IsEmptySetA(redQ))
+	return 0;
+    for (i = _mainsys->objects_num - 1; i > 0; i--)
+	for (j = i - 1; j >= 0; j--)
+	    if (!CompareA(i, j, redQ) && CompareA(i, j, P)) {
+		DelSetO(pos, i);
+		DelSetO(pos, j);
+    return 0;
-int PosD(setO pos,setA P,setA Q)
- { int i,j;
-   setA elem,redQ;
-     { ClearSetO(pos);
+int PosD(setO pos, setA P, setA Q)
+    int i, j;
+    setA elem, redQ;
+	ERROR(6);
+	ClearSetO(pos);
 	return 0;
-   FillSetO(pos);
-     return 0;
-	{ elem=GetD(i,j);
-	  if(InterSetA(elem,redQ) && !InterSetA(elem,P))
-	      { DelSetO(pos,i);
-		DelSetO(pos,j);
+    FillSetO(pos);
+	return 0;
+	for (j = i - 1; j >= 0; j--) {
+	    elem = GetD(i, j);
+	    if (InterSetA(elem, redQ) && !InterSetA(elem, P)) {
+		DelSetO(pos, i);
+		DelSetO(pos, j);
-   CloseSetA(redQ);
-   return 0;
+    CloseSetA(redQ);
+    return 0;
-float DependCoef(setA P,setA Q,int matrix_type)
-     { case MATA : return DependCoefA(P,Q);
-	case MATD : return DependCoefD(P,Q);
+float DependCoef(setA P, setA Q, int matrix_type)
+    case MATA:
+	return DependCoefA(P, Q);
+    case MATD:
+	return DependCoefD(P, Q);
+    default:
+	ERROR(8)
-float DependCoefA(setA P,setA Q)
- { setO pos;
-   float coef;
-   pos=InitEmptySetO();
-   PosA(pos,P,Q);
-   coef= (float)CardSetO(pos) / (float)_mainsys->objects_num;
-   CloseSetO(pos);
-   return coef;
+float DependCoefA(setA P, setA Q)
+    setO pos;
+    float coef;
-float DependCoefD(setA P,setA Q)
- { setO pos;
-   float coef;
-   PosD(pos,P,Q);
-   CloseSetO(pos);
-   return coef;
+	ERROR(5);
+    pos = InitEmptySetO();
+    PosA(pos, P, Q);
+    coef = (float)CardSetO(pos) / (float)_mainsys->objects_num;
+    CloseSetO(pos);
+    return coef;
-float SignifCoef(int attr,setA P,int matrix_type)
-     { case MATA : return SignifCoefA(attr,P);
-	case MATD : return SignifCoefD(attr,P);
+float DependCoefD(setA P, setA Q)
+    setO pos;
+    float coef;
-float SignifCoefA(int attr,setA P)
- { setO pos1,pos2;
-   setA Pprim;
-   int i,j;
-   float coef;
-   if( IsEmptySetA(P) || !ContSetA(P,attr) ) return 0;
-   pos1=InitFullSetO();
-   pos2=InitFullSetO();
-   Pprim=InitEmptySetA();
-   CopySetA(Pprim,P);
-   DelSetA(Pprim,attr);
-      if(CompareA(i,j,P))
-	  { DelSetO(pos1,i);
-	    DelSetO(pos2,i);
-	    DelSetO(pos1,j);
-	    DelSetO(pos2,j);
-	    continue;
-	else if(CompareA(i,j,Pprim))
-	  { DelSetO(pos2,i);
-	    DelSetO(pos2,j);
-   DifSetO(pos1,pos1,pos2);
-   coef=(float)CardSetO(pos1) / (float)_mainsys->objects_num;
-   CloseSetO(pos1);
-   CloseSetO(pos2);
-   CloseSetA(Pprim);
-   return coef;
+	ERROR(6);
+    PosD(pos, P, Q);
+    CloseSetO(pos);
+    return coef;
-float SignifCoefD(int attr,setA P)
- { setO pos1,pos2;
-   setA Pprim,elem;
-   int i,j;
-   float coef;
-      { elem=GetD(i,j);
-	 if(!InterSetA(elem,P))
-	     DelSetO(pos2,i);
-	     DelSetO(pos1,j);
-	     DelSetO(pos2,j);
-	     continue;
-	 if(!InterSetA(elem,Pprim))
-	     DelSetO(pos2,j);
-   CloseSetO(pos1);
-   CloseSetO(pos2);
-   CloseSetA(Pprim);
-   return coef;
+float SignifCoef(int attr, setA P, int matrix_type)
+    case MATA:
+	return SignifCoefA(attr, P);
+    case MATD:
+	return SignifCoefD(attr, P);
+    default:
+	ERROR(8)
-float SignifRelCoef(int attr,setA P,setA Q,int matrix_type)
-     { case MATA : return SignifRelCoefA(attr,P,Q);
-	case MATD : return SignifRelCoefD(attr,P,Q);
+float SignifCoefA(int attr, setA P)
+    setO pos1, pos2;
+    setA Pprim;
+    int i, j;
+    float coef;
-float SignifRelCoefA(int attr,setA P,setA Q)
- { setO pos1,pos2;
-   setA Pprim,redQ;
-   int i,j;
-   float coef;
-   DifSetA(redQ,Q,Pprim);
-   if( IsEmptySetA(redQ) ) return 1;
-	if(CompareA(i,j,redQ)) continue;
-	else if(CompareA(i,j,P))
-	    DelSetO(pos2,i);
-	    DelSetO(pos1,j);
-	    DelSetO(pos2,j);
-	    continue;
-	    DelSetO(pos2,j);
-   CloseSetO(pos1);
-   CloseSetO(pos2);
-   CloseSetA(Pprim);
-   CloseSetA(redQ);
-   return coef;
+	ERROR(5);
+    if (IsEmptySetA(P) || !ContSetA(P, attr))
+	return 0;
+    pos1 = InitFullSetO();
+    pos2 = InitFullSetO();
+    Pprim = InitEmptySetA();
+    CopySetA(Pprim, P);
+    DelSetA(Pprim, attr);
+	    if (CompareA(i, j, P)) {
+		DelSetO(pos1, i);
+		DelSetO(pos2, i);
+		DelSetO(pos1, j);
+		DelSetO(pos2, j);
+		continue;
+	    else if (CompareA(i, j, Pprim)) {
+		DelSetO(pos2, i);
+		DelSetO(pos2, j);
+    DifSetO(pos1, pos1, pos2);
+    coef = (float)CardSetO(pos1) / (float)_mainsys->objects_num;
+    CloseSetO(pos1);
+    CloseSetO(pos2);
+    CloseSetA(Pprim);
+    return coef;
-float SignifRelCoefD(int attr,setA P,setA Q)
- { setO pos1,pos2;
-   setA Pprim,redQ,elem;
-   int i,j;
-   float coef;
-      { elem=GetD(i,j);
-	 if(!InterSetA(elem,redQ)) continue;
-	     DelSetO(pos2,i);
-	     DelSetO(pos1,j);
-	     DelSetO(pos2,j);
-	     continue;
-	     DelSetO(pos2,j);
-   CloseSetO(pos1);
-   CloseSetO(pos2);
-   CloseSetA(Pprim);
-   CloseSetA(redQ);
-   return coef;
+float SignifCoefD(int attr, setA P)
+    setO pos1, pos2;
+    setA Pprim, elem;
+    int i, j;
+    float coef;
+	ERROR(6);
+	return 0;
+	    if (!InterSetA(elem, P)) {
+		DelSetO(pos1, i);
+		DelSetO(pos2, i);
+		DelSetO(pos1, j);
+		DelSetO(pos2, j);
+		continue;
+	    if (!InterSetA(elem, Pprim)) {
+		DelSetO(pos2, i);
+		DelSetO(pos2, j);
+    CloseSetO(pos1);
+    CloseSetO(pos2);
+    CloseSetA(Pprim);
+    return coef;
+float SignifRelCoef(int attr, setA P, setA Q, int matrix_type)
+    case MATA:
+	return SignifRelCoefA(attr, P, Q);
+    case MATD:
+	return SignifRelCoefD(attr, P, Q);
+    default:
+	ERROR(8)
+float SignifRelCoefA(int attr, setA P, setA Q)
+    setO pos1, pos2;
+    setA Pprim, redQ;
+    int i, j;
+    float coef;
+	ERROR(5);
+    DifSetA(redQ, Q, Pprim);
+	return 0;
+	return 1;
+	    if (CompareA(i, j, redQ))
+		continue;
+	    else if (CompareA(i, j, P)) {
+		DelSetO(pos1, i);
+		DelSetO(pos2, i);
+		DelSetO(pos1, j);
+		DelSetO(pos2, j);
+		continue;
+		DelSetO(pos2, i);
+		DelSetO(pos2, j);
+    CloseSetO(pos1);
+    CloseSetO(pos2);
+    CloseSetA(Pprim);
+    CloseSetA(redQ);
+    return coef;
+float SignifRelCoefD(int attr, setA P, setA Q)
+    setO pos1, pos2;
+    setA Pprim, redQ, elem;
+    int i, j;
+    float coef;
+	ERROR(6);
+	return 0;
+	return 1;
+	    if (!InterSetA(elem, redQ))
+		continue;
+		DelSetO(pos1, i);
+		DelSetO(pos2, i);
+		DelSetO(pos1, j);
+		DelSetO(pos2, j);
+		continue;
+		DelSetO(pos2, i);
+		DelSetO(pos2, j);
+    CloseSetO(pos1);
+    CloseSetO(pos2);
+    CloseSetA(Pprim);
+    CloseSetA(redQ);
+    return coef;
 int CardCoef(setA P, int matrix_type)
- { int res = 0;
-   for( start_of_tab( matrix_type ); end_of_tab(); next_of_tab() )
-     if ( InterSetA( P, _table_element ) )
-       res++;
-   if ( _rerror>0 ) return -_rerror;
-   return res;
+    int res = 0;
+    for (start_of_tab(matrix_type); end_of_tab(); next_of_tab())
+	if (InterSetA(P, _table_element))
+	    res++;
+    if (_rerror > 0)
+	return -_rerror;
+    return res;
Modified: grass-addons/raster/mcda/r.roughset/rbasic.h
--- grass-addons/raster/mcda/r.roughset/rbasic.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rbasic.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,11 +16,17 @@
  *   	    	 for details.
 /***                   BASIC QUERRIES FOR SYSTEM                           ***/
@@ -27,56 +34,66 @@
 /* first initialized and then given to the function as a first     */
 /* argument. Functions from this group does not work on matrix X.  */
-int LowAppr (setO appr,setO X,setA P,int matrix_type);
-int LowApprA(setO appr,setO X,setA P);
-int LowApprD(setO appr,setO X,setA P);
+int LowAppr(setO appr, setO X, setA P, int matrix_type);
+int LowApprA(setO appr, setO X, setA P);
+int LowApprD(setO appr, setO X, setA P);
 	/* P-lower approximation of X */
-int UppAppr (setO appr,setO X,setA P,int matrix_type);
-int UppApprA(setO appr,setO X,setA P);
-int UppApprD(setO appr,setO X,setA P);
+int UppAppr(setO appr, setO X, setA P, int matrix_type);
+int UppApprA(setO appr, setO X, setA P);
+int UppApprD(setO appr, setO X, setA P);
 	/* P-upper appriximation of X */
-int Bound (setO bound,setO X,setA P,int matrix_type);
-int BoundA(setO bound,setO X,setA P);
-int BoundD(setO bound,setO X,setA P);
+int Bound(setO bound, setO X, setA P, int matrix_type);
+int BoundA(setO bound, setO X, setA P);
+int BoundD(setO bound, setO X, setA P);
 	/* P-boundary of X */
-float AccurCoef (setO X,setA P,int matrix_type);
-float AccurCoefA(setO X,setA P);
-float AccurCoefD(setO X,setA P);
+float AccurCoef(setO X, setA P, int matrix_type);
+float AccurCoefA(setO X, setA P);
+float AccurCoefD(setO X, setA P);
 	/* Accuracy coefficient of X with respect to P */
-float ClassCoef (setO X,setA P,int matrix_type);
-float ClassCoefA(setO X,setA P);
-float ClassCoefD(setO X,setA P);
+float ClassCoef(setO X, setA P, int matrix_type);
+float ClassCoefA(setO X, setA P);
+float ClassCoefD(setO X, setA P);
 	/* quality of classification (X,not X) */
 	/* with respect to P */
-int Pos (setO pos,setA P,setA Q,int matrix_type);
-int PosA(setO pos,setA P,setA Q);
-int PosD(setO pos,setA P,setA Q);
+int Pos(setO pos, setA P, setA Q, int matrix_type);
+int PosA(setO pos, setA P, setA Q);
+int PosD(setO pos, setA P, setA Q);
 	/* P-positive region of Q */
-float DependCoef (setA P,setA Q,int matrix_type);
-float DependCoefA(setA P,setA Q);
-float DependCoefD(setA P,setA Q);
+float DependCoef(setA P, setA Q, int matrix_type);
+float DependCoefA(setA P, setA Q);
+float DependCoefD(setA P, setA Q);
 	/* degree of dependency Q from P */
-float SignifCoef (int attr,setA P,int matrix_type);
-float SignifCoefA(int attr,setA P);
-float SignifCoefD(int attr,setA P);
+float SignifCoef(int attr, setA P, int matrix_type);
+float SignifCoefA(int attr, setA P);
+float SignifCoefD(int attr, setA P);
 	/* significance of attribute attr  */
 	/* in the set P */
-float SignifRelCoef (int attr,setA P,setA Q,int matrix_type);
-float SignifRelCoefA(int attr,setA P,setA Q);
-float SignifRelCoefD(int attr,setA P,setA Q);
+float SignifRelCoef(int attr, setA P, setA Q, int matrix_type);
+float SignifRelCoefA(int attr, setA P, setA Q);
+float SignifRelCoefD(int attr, setA P, setA Q);
 	/* in the set P, relatively to Q */
-int CardCoef(setA P,int matrix_type);
+int CardCoef(setA P, int matrix_type);
 	/* returns number of matrix fields */
 	/* covered by P (MATA is treated as MATD) */
 	/* but elements are evaluated "on-line" */
Modified: grass-addons/raster/mcda/r.roughset/rclass.c
--- grass-addons/raster/mcda/r.roughset/rclass.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rclass.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,12 +16,19 @@
  *   	    	 for details.
 /***               SOME MORE QUERIES FOR SYSTEM                            ***/
 /***                     ( CLASSIFICATION )                                ***/
@@ -28,190 +36,207 @@
 #include "rough.h"
-int DecisionEQ( value_type *rule1, value_type *rule2, setA Q)
- { int i;
-   for (i=0; i<_mainsys->attributes_num; i++ )
-      if ( ContSetA( Q, i ) )
-	 if ( rule1[i] != rule2[i] )
-	    return 0;
-   return 1;
+int DecisionEQ(value_type * rule1, value_type * rule2, setA Q)
+    int i;
+    for (i = 0; i < _mainsys->attributes_num; i++)
+	if (ContSetA(Q, i))
+	    if (rule1[i] != rule2[i])
+		return 0;
+    return 1;
-int StrengthOfRule( value_type *rule )
-{  int obj,attr,
-       find,
-       result=0,
-       size=_mainsys->attributes_num;
-   for (obj=0;obj<_mainsys->objects_num;obj++)
-      {  find = 1;
-	 for (attr=0;attr<size;attr++)
-	    if ( rule[attr] != GetA(obj,attr) )
-	       if ( rule[attr]!=MINUS && GetA(obj,attr)!=MINUS )
-	       { find=0; break; }
-	 if (find)
+int StrengthOfRule(value_type * rule)
+    int obj, attr, find, result = 0, size = _mainsys->attributes_num;
+    for (obj = 0; obj < _mainsys->objects_num; obj++) {
+	find = 1;
+	for (attr = 0; attr < size; attr++)
+	    if (rule[attr] != GetA(obj, attr))
+		if (rule[attr] != MINUS && GetA(obj, attr) != MINUS) {
+		    find = 0;
+		    break;
+	if (find)
 	    result++;
-   return result;
+    return result;
-int *StrengthOfRules( value_type *rules, int N )
-{  int *result;
-   int i,size=_mainsys->attributes_num;
-   if ( N <= 0 ) return NULL;
-   result = (int *) calloc( N, sizeof(int) );
-   for (i=0;i<N;i++)
-      result[i] = StrengthOfRule( rules+i*size );
-   return result;
+int *StrengthOfRules(value_type * rules, int N)
+    int *result;
+    int i, size = _mainsys->attributes_num;
+    if (N <= 0)
+	return NULL;
+    result = (int *)calloc(N, sizeof(int));
+    for (i = 0; i < N; i++)
+	result[i] = StrengthOfRule(rules + i * size);
+    return result;
-int ObjectsForRule( setO set, value_type *rule )
-{  int i,j,
-   find,
-   for (i=0;i<_mainsys->objects_num;i++)
-    { find = 1;
-      for (j=0;j<size;j++)
-	 if ( rule[j] != GetA(i,j) )
-	    if ( rule[j]!=MINUS && GetA(i,j)!=MINUS )
-      if (find)
-	 AddSetO( set, i );
+int ObjectsForRule(setO set, value_type * rule)
+    int i, j, find, size = _mainsys->attributes_num;
+    for (i = 0; i < _mainsys->objects_num; i++) {
+	find = 1;
+	for (j = 0; j < size; j++)
+	    if (rule[j] != GetA(i, j))
+		if (rule[j] != MINUS && GetA(i, j) != MINUS) {
+		    find = 0;
+		    break;
+	if (find)
+	    AddSetO(set, i);
-   return CardSetO( set );
+    return CardSetO(set);
-int CompareToRule( value_type *sample, value_type *rule, setA P )
-{  int j,
-       result=0,
-   {  if ( !ContSetA(P,j) ) continue;
-      	if ( rule[j] != sample[j] )
-	 		if ( rule[j]!=MINUS && sample[j]!=MINUS )
-	    		result++;
-   return result;
+int CompareToRule(value_type * sample, value_type * rule, setA P)
+    int j, result = 0, size = _mainsys->attributes_num;
+    for (j = 0; j < size; j++) {
+	if (!ContSetA(P, j))
+	    continue;
+	if (rule[j] != sample[j])
+	    if (rule[j] != MINUS && sample[j] != MINUS)
+		result++;
+    return result;
-int *CompareToRules( value_type *sample, value_type *rules, int N, setA P )
-{  int *result;
-   result = (int *)calloc( N, sizeof(int) );
-   for (i=0;i<N;i++)
-      result[i] = CompareToRule( sample, rules+i*size, P );
-   return result;
+int *CompareToRules(value_type * sample, value_type * rules, int N, setA P)
+    int *result;
+    if (N <= 0)
+	return NULL;
+	result[i] = CompareToRule(sample, rules + i * size, P);
+    return result;
-int Classify1( value_type *sample, value_type *rules, int N, setA P, setA Q )
-{  int done=0,
-       result=-1,
-       count=0,
-       *diff, minDiff=_mainsys->attributes_num,
-       i, j=0, max=0,
-   diff = CompareToRules( sample, rules, N, P );
-   for (i=0; i<N; i++)
-      if ( diff[i]<minDiff ) minDiff = diff[i];
-   while ( !done )                 /* while there is an unprocessed rule */
-   {  while ( diff[j]!= minDiff ) j++; /* to find the rule with new decision */
-      done = 1;
-      diff[j]++;
-      count = 1;
-      for (i=j; i<N; i++)
-	 if ( diff[i] == minDiff )
-	    if ( DecisionEQ( rules+i*size,rules+j*size,Q ) )
-	    {  diff[j]++;   /* to protect from next use */
-	       count++;
-	    else done = 0;
-      if ( count>max ) max=count, result=j;
-   free( diff );
-   return result;
+int Classify1(value_type * sample, value_type * rules, int N, setA P, setA Q)
+    int done = 0,
+	result = -1,
+	count = 0,
+	*diff, minDiff = _mainsys->attributes_num,
+	i, j = 0, max = 0, size = _mainsys->attributes_num;
+    diff = CompareToRules(sample, rules, N, P);
+	if (diff[i] < minDiff)
+	    minDiff = diff[i];
+    while (!done) {		/* while there is an unprocessed rule */
+	while (diff[j] != minDiff)
+	    j++;		/* to find the rule with new decision */
+	done = 1;
+	diff[j]++;
+	count = 1;
+	for (i = j; i < N; i++)
+	    if (diff[i] == minDiff)
+		if (DecisionEQ(rules + i * size, rules + j * size, Q)) {
+		    diff[j]++;	/* to protect from next use */
+		    count++;
+		else
+		    done = 0;
+	if (count > max)
+	    max = count, result = j;
+    free(diff);
+    return result;
-int Classify2( value_type *sample, value_type *rules, int N, setA P, setA Q )
-{  int i,
-       *diff,
-       first=0,maxindex,
-       size=_mainsys->attributes_num,
-       minDiff=_mainsys->attributes_num,
-       done=0;
-   setO cover, maxcover, rulecover;
-   cover = InitEmptySetO();
-   maxcover = InitEmptySetO();
-   rulecover = InitEmptySetO();
-   {  while ( diff[first]!= minDiff ) first++; /* to find the rule with new decision */
-      done = 1;
-      diff[first]++;    /* to protect from next use */
-      ObjectsForRule( cover, rules+first*size );
-      for (i=first; i<N; i++)
-	 if ( diff[i]==minDiff )
-	    if ( DecisionEQ( rules+first*size, rules+i*size, Q ) )
-	    {  diff[i]++;
-	       ObjectsForRule( rulecover, rules+i*size );
-	       OrSetO( cover, cover, rulecover );
-	    else
-	       done = 0;
-      if ( CardSetO( maxcover ) < CardSetO( cover ) )
-      {  CopySetO( maxcover, cover );
-	 maxindex = first;
-   free( diff );
-   CloseSetO( cover );
-   CloseSetO( maxcover );
-   CloseSetO( rulecover );
-   return maxindex;
+int Classify2(value_type * sample, value_type * rules, int N, setA P, setA Q)
+    int i,
+	*diff,
+	first = 0, maxindex,
+	size = _mainsys->attributes_num,
+	minDiff = _mainsys->attributes_num, done = 0;
+    setO cover, maxcover, rulecover;
+    cover = InitEmptySetO();
+    maxcover = InitEmptySetO();
+    rulecover = InitEmptySetO();
+	while (diff[first] != minDiff)
+	    first++;		/* to find the rule with new decision */
+	done = 1;
+	diff[first]++;		/* to protect from next use */
+	ObjectsForRule(cover, rules + first * size);
+	for (i = first; i < N; i++)
+		if (DecisionEQ(rules + first * size, rules + i * size, Q)) {
+		    diff[i]++;
+		    ObjectsForRule(rulecover, rules + i * size);
+		    OrSetO(cover, cover, rulecover);
+		else
+		    done = 0;
+	if (CardSetO(maxcover) < CardSetO(cover)) {
+	    CopySetO(maxcover, cover);
+	    maxindex = first;
+    free(diff);
+    CloseSetO(cover);
+    CloseSetO(maxcover);
+    CloseSetO(rulecover);
+    return maxindex;
-int Classify3( value_type *sample, value_type *rules, int N,
-	       int *strength, setA P, setA Q )
-{  int i,
-       *diff,
-       first=0,maxindex,
-       done=0;
-   int cover, maxcover=0;
-      done = 1;
-      cover = strength[first];
-	    {  diff[i]++;
-	       cover += strength[i];
-	    else
-	       done = 0;
-      if ( maxcover < cover )
-      {  maxcover = cover;
-	 maxindex = first;
-   free( diff );
-   return maxindex;
+int Classify3(value_type * sample, value_type * rules, int N,
+	      int *strength, setA P, setA Q)
+    int i,
+	*diff,
+    int cover, maxcover = 0;
+	done = 1;
+	cover = strength[first];
+		    diff[i]++;
+		    cover += strength[i];
+		else
+		    done = 0;
+	if (maxcover < cover) {
+	    maxcover = cover;
+	    maxindex = first;
+    free(diff);
+    return maxindex;
Modified: grass-addons/raster/mcda/r.roughset/rclass.h
--- grass-addons/raster/mcda/r.roughset/rclass.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rclass.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,51 +16,66 @@
  *   	    	 for details.
-int DecisionEQ(value_type *rule1,value_type *rule2,setA Q);
+int DecisionEQ(value_type * rule1, value_type * rule2, setA Q);
 	/* compares decisions of two rules */
 	/* returns 1 if equal */
-int StrengthOfRule( value_type *rule );
+int StrengthOfRule(value_type * rule);
 	/* return a number of objects covered by rule (strength) */
-int *StrengthOfRules( value_type *rules, int N );
+int *StrengthOfRules(value_type * rules, int N);
 	/* creates a table of rules strengths */
 	/* allocates memory, size = N * sizeof(int) */
-int ObjectsForRule( setO set, value_type *rule );
+int ObjectsForRule(setO set, value_type * rule);
 	/* finds a set of objects covered by rule */
-int CompareToRule( value_type *sample, value_type *rule, setA P );
+int CompareToRule(value_type * sample, value_type * rule, setA P);
 	/* compares a sample with rule on a set of attributes */
 	/* returns a number of dissimilar attributes (distance) */
-int *CompareToRules( value_type *sample, value_type *rules, int N, setA P );
+int *CompareToRules(value_type * sample, value_type * rules, int N, setA P);
 	/* compares a sample with rules on a set of attributes */
 	/* creates a table of distances (number of dissimilar attributes) */
-int Classify1( value_type *sample, value_type *rules, int N, setA P, setA Q );
+int Classify1(value_type * sample, value_type * rules, int N, setA P, setA Q);
 	/* chooses the best rule to cover sample, strategy no. 1 */
 	/* finds the most frequent decision among rules with minimal */
 	/* distances from a given sample, returns index of a proper rule */
-int Classify2( value_type *sample, value_type *rules, int N, setA P, setA Q );
+int Classify2(value_type * sample, value_type * rules, int N, setA P, setA Q);
 	/* chooses the best rule to cover sample, strategy no. 2 */
 	/* finds a decision that covers the largerst number of objects */
 	/* among rules with minimal distances from a given sample */
 	/* returns index of a proper rule */
-	        int *strength, setA P, setA Q );
+	      int *strength, setA P, setA Q);
 	/* chooses the best rule to cover sample, strategy no. 3 */
 	/* finds a decision with the largest total strength among */
 	/* rules with minimal distances from a given sample */
Modified: grass-addons/raster/mcda/r.roughset/rcore.c
--- grass-addons/raster/mcda/r.roughset/rcore.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rcore.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,12 +16,19 @@
  *   	    	 for details.
 /***          ( FINDING CORES AND CHECKING REDUCTS )                       ***/
@@ -28,241 +36,312 @@
 #include <stdlib.h>
-int Core(setA core,int matrix_type)
-     {  case MATA : return CoreA(core);
-        case MATD : return CoreDX(core,matrix_type);
-        case MATX : return CoreDX(core,matrix_type);
+int Core(setA core, int matrix_type)
+    case MATA:
+	return CoreA(core);
+    case MATD:
+	return CoreDX(core, matrix_type);
+    case MATX:
+    default:
+	ERROR(8)
 int CoreA(setA core)
- { int ob1,ob2,attr,no1,pattr;
-   if (_mainsys->matA==NULL) ERROR(5)
-   ClearSetA(core);
-   for(ob1=_mainsys->objects_num-1;ob1>0;ob1--)
-     for(ob2=ob1-1;ob2>=0;ob2--)
-	{ no1=0;
-	  for(attr=_mainsys->attributes_num-1;attr>=0;attr--)
-	      if(!SingCompA(ob1,ob2,attr))
-		 { no1++;
-		   if (no1>1) break;
-		   else pattr=attr;
-	  if (no1==1) AddSetA(core,pattr);
+    int ob1, ob2, attr, no1, pattr;
+	ERROR(5)
+	    ClearSetA(core);
+    for (ob1 = _mainsys->objects_num - 1; ob1 > 0; ob1--)
+	for (ob2 = ob1 - 1; ob2 >= 0; ob2--) {
+	    no1 = 0;
+	    for (attr = _mainsys->attributes_num - 1; attr >= 0; attr--)
+		if (!SingCompA(ob1, ob2, attr)) {
+		    no1++;
+		    if (no1 > 1)
+			break;
+		    else
+			pattr = attr;
+	    if (no1 == 1)
+		AddSetA(core, pattr);
-   return 0;
+    return 0;
 int CoreDX(setA core, int matrix_type)
- { int cluster,bit,flag,no1,pcluster;
-   ClearSetA(core);
-   if(matrix_type==MATD)
-     { if (_mainsys->matD==NULL) ERROR(6)
-       START_OF_D;
-   else
-     { if (_mainsys->matX==NULL) ERROR(7)
-       START_OF_X;
-   for(;END_OF_MAT;NEXT_OF_MAT)
-     { flag=0;no1=0;
-	for(cluster=_mainsys->setAsize-1;cluster>=0;cluster--)
-	  { for(bit=0;bit<_cluster_bits;bit++)
-	     if(_mask[bit] & ELEM_OF_MAT[cluster])
-		{ no1++;
-		  if (no1>1) { flag=1; break; }
-		  else pcluster=cluster;
+    int cluster, bit, flag, no1, pcluster;
+    ClearSetA(core);
+	    ERROR(6)
+		START_OF_D;
+    else {
+	if (_mainsys->matX == NULL)
+	    ERROR(7)
+		START_OF_X;
+    for (; END_OF_MAT; NEXT_OF_MAT) {
+	flag = 0;
+	no1 = 0;
+	for (cluster = _mainsys->setAsize - 1; cluster >= 0; cluster--) {
+		if (_mask[bit] & ELEM_OF_MAT[cluster]) {
+		    no1++;
+		    if (no1 > 1) {
+			flag = 1;
+			break;
+		    else
+			pcluster = cluster;
-	    if(flag) break;
-      if (no1==1) core[pcluster] |= ELEM_OF_MAT[pcluster];
+	    if (flag)
+		break;
+	if (no1 == 1)
+	    core[pcluster] |= ELEM_OF_MAT[pcluster];
-   return 0;
+    return 0;
-int CoreRel(setA core,setA P,setA Q,int matrix_type)
-     { case MATA : return CoreRelA(core,P,Q);
-       case MATD : return CoreRelD(core,P,Q);
+int CoreRel(setA core, setA P, setA Q, int matrix_type)
+    case MATA:
+	return CoreRelA(core, P, Q);
+    case MATD:
+	return CoreRelD(core, P, Q);
+    default:
+	ERROR(8)
-int CoreRelA(setA core,setA P,setA Q)
-   ClearSetA(core);
-	if(!CompareA(ob1,ob2,Q))
-	  { no1=0;
-		   { no1++;
-		     if (no1>1) break;
-		     else pattr=attr;
-   return 0;
+int CoreRelA(setA core, setA P, setA Q)
-int CoreRelD(setA core,setA P,setA Q)
-   setA elem;
-   if (_mainsys->matD==NULL) ERROR(6)
-   ClearSetA(core);
-   elem=InitEmptySetA();
-   for(START_OF_D;END_OF_MAT;NEXT_OF_MAT)
-     { AndSetA(elem,ELEM_OF_MAT,P);
-	flag=0;no1=0;
-	if (!InterSetA(Q,ELEM_OF_MAT)) continue;
-	     if(_mask[bit] & elem[cluster])
-		{ no1++;
-	   if(flag) break;
-	if (no1==1) core[pcluster] |= elem[pcluster];
-   CloseSetA(elem);
-   return 0;
+	ERROR(5)
+	    ClearSetA(core);
+	    if (!CompareA(ob1, ob2, Q)) {
+		no1 = 0;
+			    no1++;
+			    if (no1 > 1)
+				break;
+			    else
+				pattr = attr;
+		if (no1 == 1)
+    return 0;
-int IsOrtho(setA red,setA over,int matrix_type)
- { setA and, redprim;
-   and=InitEmptySetA();
-   redprim=InitEmptySetA();
-   for(start_of_tab(matrix_type); end_of_tab(); next_of_tab())
-     { AndSetA( and, _table_element, red );
-       if ( CardSetA( and ) == 1 )
-	 OrSetA( redprim, redprim, and );
-   CloseSetA(and);
-   DifSetA( over, red, redprim );
-   CloseSetA( redprim );
-   return IsEmptySetA( over );
+int CoreRelD(setA core, setA P, setA Q)
+    setA elem;
+	ERROR(6)
+	    ClearSetA(core);
+    elem = InitEmptySetA();
+    for (START_OF_D; END_OF_MAT; NEXT_OF_MAT) {
+	AndSetA(elem, ELEM_OF_MAT, P);
+	flag = 0;
+	no1 = 0;
+	if (!InterSetA(Q, ELEM_OF_MAT))
+	    continue;
+		if (_mask[bit] & elem[cluster]) {
+		    no1++;
+		    if (no1 > 1) {
+			flag = 1;
+			break;
+		    else
+	    if (flag)
+		break;
+	if (no1 == 1)
+	    core[pcluster] |= elem[pcluster];
+    CloseSetA(elem);
+    return 0;
+int IsOrtho(setA red, setA over, int matrix_type)
+    setA and, redprim;
+    and = InitEmptySetA();
+    redprim = InitEmptySetA();
+    for (start_of_tab(matrix_type); end_of_tab(); next_of_tab()) {
+	AndSetA(and, _table_element, red);
+	if (CardSetA(and) == 1)
+	    OrSetA(redprim, redprim, and);
+    CloseSetA(and);
+    DifSetA(over, red, redprim);
+    CloseSetA(redprim);
+    return IsEmptySetA(over);
 int IsOrthoRel(setA red, setA over, setA P, setA Q, int matrix_type)
-     if ( InterSetA( _table_element, Q ) )
-	 AndSetA( and, and, P );
-   CloseSetA(and);
-int IsCover(setA red,int matrix_type)
-     { case MATA : return IsCoverA(red);
-       case MATD : return IsCoverDX(red,matrix_type);
-       case MATX : return IsCoverDX(red,matrix_type);
+	if (InterSetA(_table_element, Q)) {
+	    AndSetA(and, and, P);
+    CloseSetA(and);
+int IsCover(setA red, int matrix_type)
+    case MATA:
+	return IsCoverA(red);
+    case MATD:
+	return IsCoverDX(red, matrix_type);
+    case MATX:
+    default:
+	ERROR(8)
 int IsCoverA(setA red)
- { int ob1,ob2;
-   setA P=InitFullSetA();
-   DifSetA(P,P,red);
-       if(CompareA(ob1,ob2,red))
-	  if(!CompareA(ob1,ob2,P))
-	    { CloseSetA(P);
-	      return 0;
-   CloseSetA(P);
-   return 1;
+    int ob1, ob2;
+    setA P = InitFullSetA();
+    DifSetA(P, P, red);
+	ERROR(5);
+	    if (CompareA(ob1, ob2, red))
+		if (!CompareA(ob1, ob2, P)) {
+		    CloseSetA(P);
+		    return 0;
+    CloseSetA(P);
+    return 1;
 int IsCoverDX(setA red, int matrix_type)
- { if(matrix_type==MATD)
-       START_OF_D;
-   else
-       START_OF_X;
-     if( !IsEmptySetA(ELEM_OF_MAT) )
-	if(!InterSetA(ELEM_OF_MAT,red))
-	      return 0;
-   return 1;
+	    ERROR(6)
+		START_OF_D;
+    else {
+	    ERROR(7)
+		START_OF_X;
+	if (!IsEmptySetA(ELEM_OF_MAT))
+	    if (!InterSetA(ELEM_OF_MAT, red))
+		return 0;
+    return 1;
-int IsCoverRel(setA red,setA P,setA Q,int matrix_type)
-     { case MATA : return IsCoverRelA(red,P,Q);
-       case MATD : return IsCoverRelD(red,P,Q);
+int IsCoverRel(setA red, setA P, setA Q, int matrix_type)
+    case MATA:
+	return IsCoverRelA(red, P, Q);
+    case MATD:
+	return IsCoverRelD(red, P, Q);
+    default:
+	ERROR(8)
-int IsCoverRelA(setA red,setA P,setA Q)
- { int ob1,ob2;
-   setA Pprim;
-   DifSetA(Pprim,P,red);
-	   if(!CompareA(ob1,ob2,Pprim))
-	     { CloseSetA(Pprim);
-	       return 0;
-   CloseSetA(Pprim);
-   return 1;
+int IsCoverRelA(setA red, setA P, setA Q)
+    int ob1, ob2;
+    setA Pprim;
-int IsCoverRelD(setA red,setA P,setA Q)
- { if(_mainsys->matD==NULL) ERROR(6);
-     if(InterSetA(ELEM_OF_MAT,Q))
-	  if(InterSetA(ELEM_OF_MAT,P))
-	      return 0;
-  return 1;
+	ERROR(5);
+    DifSetA(Pprim, P, red);
+		    if (!CompareA(ob1, ob2, Pprim)) {
+			CloseSetA(Pprim);
+			return 0;
+    CloseSetA(Pprim);
+    return 1;
-int IsRed(setA red,int matrix_type)
-{ int result;
-  setA over;
-  if(!IsCover(red,matrix_type))
-     return 0;
-  over=InitEmptySetA();
-  result=IsOrtho(red,over,matrix_type);
-  CloseSetA(over);
-  return result;
+int IsCoverRelD(setA red, setA P, setA Q)
+	ERROR(6);
+	if (InterSetA(ELEM_OF_MAT, Q))
+		if (InterSetA(ELEM_OF_MAT, P))
+		    return 0;
+    return 1;
+int IsRed(setA red, int matrix_type)
+    int result;
+    setA over;
-int IsRedRel(setA red,setA P,setA Q,int matrix_type)
- { int result;
-   setA over;
-   if(!IsCoverRel(red,P,Q,matrix_type))
-     return 0;
-   result=IsOrthoRel(red,over,P,Q,matrix_type);
-   CloseSetA(over);
-   return result;
+    if (!IsCover(red, matrix_type))
+	return 0;
+    over = InitEmptySetA();
+    result = IsOrtho(red, over, matrix_type);
+    CloseSetA(over);
+    return result;
+int IsRedRel(setA red, setA P, setA Q, int matrix_type)
+    int result;
+    setA over;
+    if (!IsCoverRel(red, P, Q, matrix_type))
+	return 0;
+    result = IsOrthoRel(red, over, P, Q, matrix_type);
+    CloseSetA(over);
+    return result;
Modified: grass-addons/raster/mcda/r.roughset/rcore.h
--- grass-addons/raster/mcda/r.roughset/rcore.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rcore.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,51 +16,65 @@
  *   	    	 for details.
-int Core  (setA core,int matrix_type);
-int CoreA (setA core);
-int CoreDX(setA core,int matrix_type);
+int Core(setA core, int matrix_type);
+int CoreA(setA core);
+int CoreDX(setA core, int matrix_type);
 	/* finds a core of all attributes */
-int CoreRel (setA core,setA P,setA Q,int matrix_type);
-int CoreRelA(setA core,setA P,setA Q);
-int CoreRelD(setA core,setA P,setA Q);
+int CoreRel(setA core, setA P, setA Q, int matrix_type);
+int CoreRelA(setA core, setA P, setA Q);
+int CoreRelD(setA core, setA P, setA Q);
 	/* finds a core of P relativly to Q */
-int IsOrtho(setA red,setA over,int matrix_type);
+int IsOrtho(setA red, setA over, int matrix_type);
 	/* return 1 if red is orthogonal */
 	/* otherwise returns 0 */
-int IsOrthoRel(setA red,setA over,setA P,setA Q,int matrix_type);
+int IsOrthoRel(setA red, setA over, setA P, setA Q, int matrix_type);
 	/* return 1 if red is Q-orthogonal in P */
-int IsCover  (setA red,int matrix_type);
-int IsCoverA (setA red);
-int IsCoverDX(setA red,int matrix_type);
+int IsCover(setA red, int matrix_type);
+int IsCoverA(setA red);
+int IsCoverDX(setA red, int matrix_type);
 	/* return 1 if red is a cover */
-int IsCoverRel (setA red,setA P,setA Q,int matrix_type);
-int IsCoverRelA(setA red,setA P,setA Q);
-int IsCoverRelD(setA red,setA P,setA Q);
+int IsCoverRel(setA red, setA P, setA Q, int matrix_type);
+int IsCoverRelA(setA red, setA P, setA Q);
+int IsCoverRelD(setA red, setA P, setA Q);
 	/* return 1 if red is Q-cover in P */
-int IsRed(setA red,int matrix_type);
+int IsRed(setA red, int matrix_type);
 	/* returns 1 if red is a reduct */
-int IsRedRel(setA red,setA P,setA Q,int matrix_type);
+int IsRedRel(setA red, setA P, setA Q, int matrix_type);
 	/* returns 1 if red is a Q-relative reduct of P */
Modified: grass-addons/raster/mcda/r.roughset/reduct1.c
--- grass-addons/raster/mcda/r.roughset/reduct1.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/reduct1.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,1023 +16,1151 @@
  *   	    	 for details.
 /***                   ( FINDING REDUCTS )                                 ***/
 #include "rough.h"
 #include <stdlib.h>
-int RedRel(setA *reducts,setA P,setA Q,int matrix_type)
-{ int MEMOKWANT=_mainsys->attributes_num*_mainsys->attributes_num,
-      j,atr,
-      over,size=_mainsys->setAsize,
-      memoryN=1,memoryO=1, 	/* size of the allocated memory    */
-      newcount=0,oldcount;	/* number of new/old reducts       */
-  int no_A=_mainsys->attributes_num;
-  setA arg,            /* arguments are elements of matrix*/
-       oldhead,        /* head of static list of reducts  */
-       oldtail,        /* tail ends the old reducts list  */
-       el,el1,         /* elements of this list           */
-       new_el,         /* probably new element of the list*/
-       newhead,        /* begin of new reducts            */
-       newtail;        /* tail of the list of new reducts */
-  setA CORE,keep;
-  CORE=InitEmptySetA();
-  _rerror=0;
-  CoreRel(CORE,P,Q,matrix_type);
-  if (_rerror!=0) { CloseSetA(CORE); return(-_rerror); }
-  if ((oldhead=(setA)malloc(MEMOKWANT))==NULL)
-     { CloseSetA(CORE); ERROR(3); }
-  if ((newhead=(setA)malloc(MEMOKWANT))==NULL)
-     { free(oldhead); CloseSetA(CORE); ERROR(3);}
-  new_el=InitEmptySetA();
-  arg=InitEmptySetA();
-  oldtail=oldhead;
-  newtail=newhead;
-  start_of_tab(matrix_type); /* initializing the reducts list */
-  if ( !IsEmptySetA(CORE) )
-   { CopySetA(oldtail,CORE);
-     oldtail+=size,oldcount=1;
-  else  do
-   { AndSetA(arg,_table_element,P);
-     oldcount=0;
-     if (InterSetA(_table_element,Q))
-      for(atr=0;atr<no_A;atr++)
-	if ( ContSetA(arg,atr) )
-	  { ClearSetA(oldtail);
-	    AddSetA(oldtail,atr);
-	    oldtail+=size;
-	    oldcount++;
-    next_of_tab();
-  while ((oldcount==0) && end_of_tab());
-  for(;end_of_tab();next_of_tab())   /* for each element of matD do  */
-   { AndSetA(arg,_table_element,P);	   /* take next element */
-     over = 0;
-     if ( InterSetA(CORE,arg) ) continue;
-     if ( !InterSetA(_table_element,Q) ) continue;
-     if ( IsEmptySetA(arg) ) continue;
-     el=oldhead;
-     while (el<oldtail)    /* compare arg to all the old reducts  */
-      { if ( !InterSetA(el,arg) )
-	 { for(atr=0;atr<no_A;atr++) /* for each atribute of arg  */
-	    { CopySetA(new_el,el); /* creating potentialy new reduct */
-	      AddSetA(new_el,atr);
-	      over=0;
-	      el1=oldhead;
-	      while ((el1!=el) && !over) /* comparing new reduct to old reducts */
-	       { over = InSetA(new_el,el1);
-		 el1+=size;
-	      el1=el+size;
-	      while ((el1!=oldtail) && !over)
-		 el1+=size;
-	      if (!over) /* appending new reduct */
-	       { newcount++;
-		 if (newcount*size*_cluster_bytes>memoryN*MEMOKWANT)
-		  { keep=newhead;
-		    if ((newhead=(setA)realloc(keep,MEMOKWANT*(++memoryN)))==NULL)
-		     { free(oldhead);
-		       CloseSetA(new_el);
-		       CloseSetA(arg);
-		       CloseSetA(CORE); ERROR(3);
-		    if (keep!=newhead) newtail=newhead+(newcount-1)*size;
-                 CopySetA(newtail,new_el);
-		 newtail+=size;
+int RedRel(setA * reducts, setA P, setA Q, int matrix_type)
+    int MEMOKWANT = _mainsys->attributes_num * _mainsys->attributes_num, j, atr, over, size = _mainsys->setAsize, memoryN = 1, memoryO = 1,	/* size of the allocated memory    */
+	newcount = 0, oldcount;	/* number of new/old reducts       */
+    int no_A = _mainsys->attributes_num;
+    setA arg,			/* arguments are elements of matrix */
+      oldhead,			/* head of static list of reducts  */
+      oldtail,			/* tail ends the old reducts list  */
+      el, el1,			/* elements of this list           */
+      new_el,			/* probably new element of the list */
+      newhead,			/* begin of new reducts            */
+      newtail;			/* tail of the list of new reducts */
+    setA CORE, keep;
+    CORE = InitEmptySetA();
+    _rerror = 0;
+    CoreRel(CORE, P, Q, matrix_type);
+    if (_rerror != 0) {
+	CloseSetA(CORE);
+	return (-_rerror);
+    if ((oldhead = (setA) malloc(MEMOKWANT)) == NULL) {
+	CloseSetA(CORE);
+	ERROR(3);
+    if ((newhead = (setA) malloc(MEMOKWANT)) == NULL) {
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    new_el = InitEmptySetA();
+    arg = InitEmptySetA();
+    oldtail = oldhead;
+    newtail = newhead;
+    start_of_tab(matrix_type);	/* initializing the reducts list */
+    if (!IsEmptySetA(CORE)) {
+	CopySetA(oldtail, CORE);
+	oldtail += size, oldcount = 1;
+    else
+	do {
+	    AndSetA(arg, _table_element, P);
+	    oldcount = 0;
+		for (atr = 0; atr < no_A; atr++)
+		    if (ContSetA(arg, atr)) {
+			ClearSetA(oldtail);
+			AddSetA(oldtail, atr);
+			oldtail += size;
+			oldcount++;
+	    next_of_tab();
+	while ((oldcount == 0) && end_of_tab());
+    for (; end_of_tab(); next_of_tab()) {	/* for each element of matD do  */
+	AndSetA(arg, _table_element, P);	/* take next element */
+	over = 0;
+	if (InterSetA(CORE, arg))
+	    continue;
+	if (!InterSetA(_table_element, Q))
+	    continue;
+	if (IsEmptySetA(arg))
+	    continue;
+	el = oldhead;
+	while (el < oldtail) {	/* compare arg to all the old reducts  */
+	    if (!InterSetA(el, arg)) {
+		for (atr = 0; atr < no_A; atr++)	/* for each atribute of arg  */
+			CopySetA(new_el, el);	/* creating potentialy new reduct */
+			AddSetA(new_el, atr);
+			over = 0;
+			el1 = oldhead;
+			while ((el1 != el) && !over) {	/* comparing new reduct to old reducts */
+			    over = InSetA(new_el, el1);
+			    el1 += size;
+			el1 = el + size;
+			while ((el1 != oldtail) && !over) {
+			    el1 += size;
+			if (!over) {	/* appending new reduct */
+			    newcount++;
+			    if (newcount * size * _cluster_bytes >
+				memoryN * MEMOKWANT) {
+				keep = newhead;
+				if ((newhead =
+				     (setA) realloc(keep,
+						    MEMOKWANT *
+						    (++memoryN))) == NULL) {
+				    free(oldhead);
+				    CloseSetA(new_el);
+				    CloseSetA(arg);
+				    CloseSetA(CORE);
+				    ERROR(3);
+				if (keep != newhead)
+				    newtail = newhead + (newcount - 1) * size;
+			    CopySetA(newtail, new_el);
+			    newtail += size;
-	else /* if reduct covers arg - rewrite it */
-	 { newcount++;
-	    { keep=newhead;
-	       { free(oldhead);
-		 CloseSetA(arg);
-		 CloseSetA(CORE);
-		 ERROR(3);
+	    else {		/* if reduct covers arg - rewrite it */
+		newcount++;
+		if (newcount * size * _cluster_bytes > memoryN * MEMOKWANT) {
+		    keep = newhead;
+		    if ((newhead =
+					MEMOKWANT * (++memoryN))) == NULL) {
+			free(oldhead);
+			CloseSetA(arg);
+			CloseSetA(CORE);
+			ERROR(3);
+		CopySetA(newtail, el);
+		newtail += size;
-           CopySetA(newtail,el);
-	   newtail+=size;
-	el+=size;
-     oldtail=newhead;/* new reducts list becomes old */
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     oldcount=newcount;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-   { free(oldhead);
-     *reducts=NULL;
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
- CloseSetA(arg);
- return (oldcount);
+	    el += size;
+	oldtail = newhead;	/* new reducts list becomes old */
+	newhead = oldhead;
+	oldhead = oldtail;
+	oldtail = newtail;
+	oldcount = newcount;
+	newcount = 0;
+	j = memoryO;
+	memoryO = memoryN;
+	memoryN = j;
+    if (oldcount == 0) {
+	free(oldhead);
+	*reducts = NULL;
+    else
+	*reducts = oldhead;
+    free(newhead);
+    CloseSetA(CORE);
+    CloseSetA(arg);
+    return (oldcount);
-int Red(setA *reducts,int matrix_type)
- {int j, MEMOKWANT=_mainsys->attributes_num*_mainsys->attributes_num,
-      atr,
-  setA oldhead,        /* head of static list of reducts  */
-  setA CORE,keep,and,redprim;
+int Red(setA * reducts, int matrix_type)
+    int j, MEMOKWANT = _mainsys->attributes_num * _mainsys->attributes_num, atr, over, size = _mainsys->setAsize, memoryN = 1, memoryO = 1,	/* size of the allocated memory    */
+    setA oldhead,		/* head of static list of reducts  */
+    setA CORE, keep, and, redprim;
-  _rerror=0;
-  Core(CORE,matrix_type);
-  if (_rerror!=0)
-    { CloseSetA(CORE); return(-_rerror); }
-      keep=NULL;
-      ERROR(3);
+    _rerror = 0;
+    Core(CORE, matrix_type);
+	CloseSetA(CORE);
-    { free(oldhead);
-      CloseSetA(CORE);
-      ERROR(3);
+	CloseSetA(CORE);
+	keep = NULL;
+	ERROR(3);
-  oldtail=oldhead;
-  newtail=newhead;
-  if ( !IsEmptySetA(CORE) ) /* initializing of the reducts list */
-  else  do
-   { oldcount=0;
-      if ( ContSetA(_table_element,atr) )
-	 oldtail+=size;
-	 oldcount++;
-     next_of_tab();
-  for(;end_of_tab();next_of_tab()) /* for each element of matrix */
-   { over = 0;
-     if ( InterSetA(CORE,_table_element) ) continue;
-     if ( IsEmptySetA(_table_element) ) continue;
-     el=oldhead;
-     while (el<oldtail) /* compare _table_element to all the old reducts  */
-      { if ( !InterSetA(el,_table_element) ) /* old reduct does not cover new element */
-	 { for(atr=0;atr<no_A;atr++) /* for each atribute of _table_element  */
-	      over=0;
-	      el1=oldhead;
-	      /*  if ( matrix_type==MATX && (_mainsys->matXsize<(oldtail-oldhead)))
-	       { ClearSetA( redprim );
-		 for(el1=_mainsys->matX;el1<_table_end;el1+=size)
-		  { AndSetA( and, el1, new_el );
-		    if ( CardSetA( and ) == 1 ) OrSetA( redprim, redprim, and );
-		 over = !CompSetA( redprim, new_el );
-	      else
-	       { while ((el1!=el) && !over) /* comparing new reduct to all the old reducts */
-		    el1+=size;
-		 el1=el+size;
-		    el1+=size;
-	       { newcount++;
-		  { keep=newhead;
-		     { free(oldhead);
-		 newtail+=size;
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    if (!IsEmptySetA(CORE)) {	/* initializing of the reducts list */
+    else
+	do {
+	    oldcount = 0;
+		if (ContSetA(_table_element, atr)) {
+		    oldtail += size;
+		    oldcount++;
+	    next_of_tab();
+    for (; end_of_tab(); next_of_tab()) {	/* for each element of matrix */
+	over = 0;
+	if (InterSetA(CORE, _table_element))
+	    continue;
+	if (IsEmptySetA(_table_element))
+	    continue;
+	el = oldhead;
+	while (el < oldtail) {	/* compare _table_element to all the old reducts  */
+	    if (!InterSetA(el, _table_element)) {	/* old reduct does not cover new element */
+		for (atr = 0; atr < no_A; atr++)	/* for each atribute of _table_element  */
+			over = 0;
+			el1 = oldhead;
+			/*  if ( matrix_type==MATX && (_mainsys->matXsize<(oldtail-oldhead)))
+			   { ClearSetA( redprim );
+			   for(el1=_mainsys->matX;el1<_table_end;el1+=size)
+			   { AndSetA( and, el1, new_el );
+			   if ( CardSetA( and ) == 1 ) OrSetA( redprim, redprim, and );
+			   over = !CompSetA( redprim, new_el );
+			   else
+			    while ((el1 != el) && !over) {	/* comparing new reduct to all the old reducts */
+				el1 += size;
+			    el1 = el + size;
+				el1 += size;
+			    newcount++;
+				keep = newhead;
+				if ((newhead =
+						    MEMOKWANT *
+				    free(oldhead);
+				    CloseSetA(CORE);
+				    ERROR(3);
+			    newtail += size;
-	else /* old reduct covers new element */
-	 { newcount++;
-	    { keep=newhead;
-	       { free(oldhead);
+	    else {		/* old reduct covers new element */
+		newcount++;
+		    keep = newhead;
+		    if ((newhead =
+			free(oldhead);
+			CloseSetA(CORE);
+			ERROR(3);
+		newtail += size;
-	   newtail+=size;
-	el+=size;
-     oldtail=newhead; /* new reducts list becomes old */
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-   { free(oldhead); *reducts=NULL; }
- else
-   *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
- CloseSetA(redprim);
- CloseSetA(and);
+	    el += size;
+	newcount = 0;
+	j = memoryO;
+	memoryN = j;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
+    CloseSetA(and);
-int RedRelLess(setA *reducts,setA P,setA Q,int N,int matrix_type)
-{ int j, MEMOKWANT=_mainsys->attributes_num*_mainsys->attributes_num,
-      atr,
-  setA CORE,keep;
+int RedRelLess(setA * reducts, setA P, setA Q, int N, int matrix_type)
+    setA CORE, keep;
-  _rerror=0;
-  if ( CardSetA(CORE)>N ) { free(CORE); return(0); }
-     { free(oldhead);
-       CloseSetA(CORE);
-       ERROR(3);
-  oldtail=oldhead;
-  newtail=newhead;
-  else do
-     oldcount=0;
-	    oldtail+=size;
-	    oldcount++;
-     next_of_tab();
-  for(;end_of_tab();next_of_tab()) /* for each element of matrix do  */
-     over = 0;
-     el=oldhead;
-     while (el<oldtail) /* compare arg to all old reducts  */
-      { if ( !InterSetA(el,arg) ) /* old reduct does not cover new element */
-	 { if ( CardSetA(el)<N ) /* shorter elements should be corected */
-	     for(atr=0;atr<no_A;atr++) /* for each atribute of arg  */
-		over=0;
-		el1=oldhead;
-		while ((el1!=el) && !over) /* comparing new reduct to all the old list */
-		   el1+=size;
-		el1=el+size;
-		   el1+=size;
-		if (!over) /* appending to new list */
-		 { newcount++;
-		    { keep=newhead;
-		       { free(oldhead);
-			 CloseSetA(arg);
-			 CloseSetA(CORE);
-			 ERROR(3);
+    _rerror = 0;
+	CloseSetA(CORE);
+    if (CardSetA(CORE) > N) {
+	free(CORE);
+	return (0);
+	CloseSetA(CORE);
+	ERROR(3);
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    else
+	do {
+	    oldcount = 0;
+			oldtail += size;
+			oldcount++;
-	           newtail+=size;
-	 { newcount++;
-	   { keep=newhead;
-	      { free(oldhead);
-		CloseSetA(arg);
-	   newtail+=size;
-	el+=size;
-     oldtail=newhead; /* new list becomes old*/
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-  { free(oldhead);
-    *reducts=NULL;
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
- CloseSetA(arg);
+	    next_of_tab();
+    for (; end_of_tab(); next_of_tab()) {	/* for each element of matrix do  */
+	over = 0;
+	    continue;
+	    continue;
+	    continue;
+	el = oldhead;
+	while (el < oldtail) {	/* compare arg to all old reducts  */
+	    if (!InterSetA(el, arg)) {	/* old reduct does not cover new element */
+		if (CardSetA(el) < N)	/* shorter elements should be corected */
+			    over = 0;
+			    el1 = oldhead;
+			    while ((el1 != el) && !over) {	/* comparing new reduct to all the old list */
+				el1 += size;
+			    el1 = el + size;
+				el1 += size;
+			    if (!over) {	/* appending to new list */
+				newcount++;
+				    keep = newhead;
+				    if ((newhead =
+							MEMOKWANT *
+							(++memoryN))) ==
+					NULL) {
+					free(oldhead);
+					CloseSetA(arg);
+					CloseSetA(CORE);
+					ERROR(3);
+					newtail =
+					    newhead + (newcount - 1) * size;
+				newtail += size;
+		newcount++;
+		    keep = newhead;
+		    if ((newhead =
+			free(oldhead);
+			CloseSetA(arg);
+			CloseSetA(CORE);
+			ERROR(3);
+		newtail += size;
+	    el += size;
+	oldtail = newhead;	/* new list becomes old */
+	newcount = 0;
+	j = memoryO;
+	memoryN = j;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
+    CloseSetA(arg);
-int RedLess(setA *reducts,int N,int matrix_type)
-      atr,
-  setA CORE,keep;
-  _rerror=0;
-       ERROR(3);
-     { free(oldhead);
-  oldtail=oldhead;
-  newtail=newhead;
-  if ( !IsEmptySetA(CORE) )  /*initializing the reducts list  */
-     oldtail+=size;
-     oldcount=1;
-  else  do
-   { oldcount=0;
-	 oldtail+=size;
-	 oldcount++;
-     next_of_tab();
-   { over = 0;
-    if ( InterSetA(_table_element,CORE) ) continue;
-     el=oldhead;
-	    for(atr=0;atr<no_A;atr++) /* for each atribute of element */
-		over=0;
-		el1=oldhead; /* comparing new reduct to the old reducts */
-		   el1+=size;
-		el1=el+size;
-		   el1+=size;
-		if (!over) /* appending new reduct to list */
-		 { newcount++;
-		    { keep=newhead;
-		       { free(oldhead);
-			 CloseSetA(CORE);
-			 ERROR(3);
+int RedLess(setA * reducts, int N, int matrix_type)
+    setA CORE, keep;
+    _rerror = 0;
+	CloseSetA(CORE);
+	free(CORE);
+	return (0);
+	CloseSetA(CORE);
+	ERROR(3);
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    if (!IsEmptySetA(CORE)) {	/*initializing the reducts list  */
+	oldtail += size;
+	oldcount = 1;
+    else
+	do {
+	    oldcount = 0;
+		    oldtail += size;
+		    oldcount++;
+	    next_of_tab();
+	over = 0;
+	if (InterSetA(_table_element, CORE))
+	    continue;
+	    continue;
+	el = oldhead;
+		    for (atr = 0; atr < no_A; atr++)	/* for each atribute of element */
+			    over = 0;
+			    el1 = oldhead;	/* comparing new reduct to the old reducts */
+				el1 += size;
+			    el1 = el + size;
+				el1 += size;
+			    if (!over) {	/* appending new reduct to list */
+				newcount++;
+				    keep = newhead;
+				    if ((newhead =
+							MEMOKWANT *
+							(++memoryN))) ==
+					NULL) {
+					free(oldhead);
+					CloseSetA(CORE);
+					ERROR(3);
+					newtail =
+				newtail += size;
+		newcount++;
+		    keep = newhead;
+		    if ((newhead =
+			free(oldhead);
+			CloseSetA(CORE);
+			ERROR(3);
-	           newtail+=size;
-	 { newcount++;
-	   { keep=newhead;
-	      { free(oldhead);
-	   newtail+=size;
-	el+=size;
-     oldtail=newhead; /* new list becomes old */
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-  { free(oldhead);
-    *reducts=NULL;
- else
-   *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
+		newtail += size;
+	    el += size;
+	newcount = 0;
+	j = memoryO;
+	memoryN = j;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
-int RedRelSetA(setA *reducts,setA quasicore,setA P,setA Q,int matrix_type)
+int RedRelSetA(setA * reducts, setA quasicore, setA P, setA Q,
+	       int matrix_type)
-  int j, MEMOKWANT=_mainsys->attributes_num*_mainsys->attributes_num,
-      atr,
-  setA CORE,keep;
+    setA CORE, keep;
-  _rerror=0;
-  if (_rerror!=0)
-      return(-_rerror);
+    _rerror = 0;
+	CloseSetA(CORE);
-  OrSetA(CORE,CORE,quasicore);
-      ERROR(3);
+    OrSetA(CORE, CORE, quasicore);
+	CloseSetA(CORE);
+	ERROR(3);
-   { free(oldhead);
-     CloseSetA(CORE);
-     ERROR(3);
-  oldtail=oldhead;
-  newtail=newhead;
-     oldtail+=size;
-     oldcount=1;
-  else do
-     oldcount=0;
-	    oldtail+=size;
-	    oldcount++;
-     next_of_tab();
-     over = 0;
-     el=oldhead;
-     while (el<oldtail) /* compare element to all the old reducts  */
-	 { for(atr=0;atr<no_A;atr++)/* for each atribute of element */
-	      over=0;
-	      el1=oldhead;
-	      while ((el1!=el) && !over)/* comparing new reduct to all the old reducts */
-		 el1+=size;
-	      el1=el+size;
-		 el1+=size;
-	       {  newcount++;
-		  { keep=newhead;
-		     { free(oldhead);
-		       CloseSetA(arg);
-	         newtail+=size;
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+	oldtail += size;
+	oldcount = 1;
+    else
+	do {
+	    oldcount = 0;
+			oldtail += size;
+			oldcount++;
+	    next_of_tab();
+	over = 0;
+	    continue;
+	    continue;
+	    continue;
+	el = oldhead;
+	while (el < oldtail) {	/* compare element to all the old reducts  */
+			over = 0;
+			el1 = oldhead;
+			    el1 += size;
+			el1 = el + size;
+			    el1 += size;
+			    newcount++;
+				keep = newhead;
+				if ((newhead =
+						    MEMOKWANT *
+				    free(oldhead);
+				    CloseSetA(arg);
+				    CloseSetA(CORE);
+				    ERROR(3);
+			    newtail += size;
-	else /* old reduct covers new elemet */
-	 { newcount++;
-	   { keep=newhead;
-	      { free(oldhead);
-		CloseSetA(arg);
-	   newtail+=size;
-	el+=size;
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-   { free(oldhead);
-     *reducts=NULL;
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
- CloseSetA(arg);
+	    else {		/* old reduct covers new elemet */
+		newcount++;
+		    keep = newhead;
+		    if ((newhead =
+			free(oldhead);
+			CloseSetA(arg);
+			CloseSetA(CORE);
+			ERROR(3);
+		newtail += size;
+	    el += size;
+	newcount = 0;
+	j = memoryO;
+	memoryN = j;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
+    CloseSetA(arg);
-int RedSetA(setA *reducts,setA quasicore,int matrix_type)
- { int j, MEMOKWANT=_mainsys->attributes_num*_mainsys->attributes_num,
-      atr,
- setA CORE,keep;
+int RedSetA(setA * reducts, setA quasicore, int matrix_type)
+    setA CORE, keep;
-  _rerror=0;
-      ERROR(3);
+    _rerror = 0;
+	CloseSetA(CORE);
-    { free(oldhead);
-      CloseSetA(CORE);
-      ERROR(3);
+	CloseSetA(CORE);
+	ERROR(3);
-  oldtail=oldhead;
-  newtail=newhead;
-  else  do
-   { oldcount=0;
-	 oldtail+=size;
-	 oldcount++;
-     next_of_tab();
-   { over = 0;
-     el=oldhead;
-     while (el<oldtail) /* compare elment to all the old reducts  */
-      { if ( !InterSetA(el,_table_element) ) /* old reduct does not cover element */
-	 { for(atr=0;atr<no_A;atr++) /* for each atribute of element  */
-	      over=0;
-	      el1=oldhead;
-	      while ((el1!=el) && !over) /* comparing new reduct to all the old reducts */
-		 el1+=size;
-	      el1=el+size;
-		 el1+=size;
-	       { newcount++;
-		  { keep=newhead;
-		     { free(oldhead);
-	         newtail+=size;
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    else
+	do {
+	    oldcount = 0;
+		    oldtail += size;
+		    oldcount++;
+	    next_of_tab();
+	over = 0;
+	    continue;
+	    continue;
+	el = oldhead;
+	while (el < oldtail) {	/* compare elment to all the old reducts  */
+	    if (!InterSetA(el, _table_element)) {	/* old reduct does not cover element */
+			over = 0;
+			el1 = oldhead;
+			    el1 += size;
+			el1 = el + size;
+			    el1 += size;
+			    newcount++;
+				keep = newhead;
+				if ((newhead =
+						    MEMOKWANT *
+				    free(oldhead);
+				    CloseSetA(CORE);
+				    ERROR(3);
+			    newtail += size;
-	 { newcount++;
-	   { keep=newhead;
-	      { free(oldhead);
-	   newtail+=size;
-	el+=size;
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
-     j=memoryO;
-     memoryO=memoryN;
-     memoryN=j;
- if (oldcount==0)
-   { free(oldhead);
-     *reducts=NULL;
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
+		newcount++;
+		    keep = newhead;
+		    if ((newhead =
+			free(oldhead);
+			CloseSetA(CORE);
+			ERROR(3);
+		newtail += size;
+	    el += size;
+	newcount = 0;
+	j = memoryO;
+	memoryN = j;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
-int RedRelFirst(setA *reducts,setA P,setA Q,int N,int matrix_type)
-{ int atr,
-      newcount=0,oldcount;  /* number of new,old reducts       */
-  setA CORE;
+int RedRelFirst(setA * reducts, setA P, setA Q, int N, int matrix_type)
+    int atr, over, size = _mainsys->setAsize, newcount = 0, oldcount;	/* number of new,old reducts       */
+    setA CORE;
-  if (N==0) return 0;
-  _rerror=0;
-  if ((oldhead=(setA)malloc(N*size*_cluster_bytes))==NULL)
-      ERROR(3);
+    if (N == 0)
+	return 0;
+    _rerror = 0;
+	CloseSetA(CORE);
-  if ((newhead=(setA)malloc(N*size*_cluster_bytes))==NULL)
-    { free(oldhead);
-      CloseSetA(CORE);
-      ERROR(3);
+    if ((oldhead = (setA) malloc(N * size * _cluster_bytes)) == NULL) {
+	CloseSetA(CORE);
+	ERROR(3);
-  oldtail=oldhead;
-  newtail=newhead;
-  if ( !IsEmptySetA(CORE) ) /* initializing  the reducts list  */
-  else do
-     oldcount=0;
-	 if ( ContSetA(arg,atr)&&(oldcount<N) )
-	    oldtail+=size;
-	    oldcount++;
-    next_of_tab();
-     over = 0;
-     el=oldhead;
-      { if ( !InterSetA(el,arg) ) /* old reduct does not cover element */
-	 { for(atr=0;atr<no_A;atr++) /* for each atribute of elememt */
-	    if ( ContSetA(arg,atr)&&(newcount<N) )
-	       over=0;
-	       el1=oldhead;
-		   el1+=size;
-	       el1=el+size;
-		  el1+=size;
-	       if (!over) /* appending new reduct to list*/
-	        { CopySetA(newtail,new_el);
-		  newtail+=size;
-	 	  newcount++;
-	else if (newcount<N)
-	      { CopySetA(newtail,el);
-		newtail+=size;
+    if ((newhead = (setA) malloc(N * size * _cluster_bytes)) == NULL) {
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    if (!IsEmptySetA(CORE)) {	/* initializing  the reducts list  */
+    else
+	do {
+	    oldcount = 0;
+		    if (ContSetA(arg, atr) && (oldcount < N)) {
+			oldtail += size;
+			oldcount++;
+	    next_of_tab();
+	over = 0;
+	    continue;
+	    continue;
+	    continue;
+	el = oldhead;
+	    if (!InterSetA(el, arg)) {	/* old reduct does not cover element */
+		for (atr = 0; atr < no_A; atr++)	/* for each atribute of elememt */
+		    if (ContSetA(arg, atr) && (newcount < N)) {
+			over = 0;
+			el1 = oldhead;
+			    el1 += size;
+			el1 = el + size;
+			    el1 += size;
+			    newtail += size;
+			    newcount++;
+	    else if (newcount < N) {
+		newtail += size;
 		newcount++;
-	el+=size;
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
- if (oldcount==0)
-   { free(oldhead);
-     *reducts=NULL;
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
- CloseSetA(arg);
+	    el += size;
+	newcount = 0;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
+    CloseSetA(arg);
-int RedFirst(setA *reducts,int N,int matrix_type)
-{ int atr,over,size=_mainsys->setAsize,
-      newcount=0,oldcount; /* sizes of reduct lists */
-  setA CORE;
+int RedFirst(setA * reducts, int N, int matrix_type)
+    int atr, over, size = _mainsys->setAsize, newcount = 0, oldcount;	/* sizes of reduct lists */
+    setA CORE;
-  _rerror=0;
-    { free(oldhead); CloseSetA(CORE); ERROR(3); }
-  oldtail=oldhead;
-  newtail=newhead;
-  else  do
-   { oldcount=0;
-      if ( ContSetA(_table_element,atr)&&(oldcount<N) )
-	 oldtail+=size;
-	 oldcount++;
-     next_of_tab();
-   { over = 0;
-     el=oldhead;
-	    if ( ContSetA(_table_element,atr)&&(newcount<N) )
-	      { CopySetA(new_el,el); /* creating potentialy new element */
-	        over=0;
-	        el1=oldhead;
-	        while ((el1!=el) && !over) /* comparing new reduct to old list */
-		   el1+=size;
-	        el1=el+size;
-		    el1+=size;
-	        if (!over)
-		   newtail+=size;
-		   newcount++;
-	      { CopySetA(newtail,el); /* rewriting reduct from old list */
-		newtail+=size;
+    if (N == 0)
+	return 0;
+    _rerror = 0;
+	CloseSetA(CORE);
+	CloseSetA(CORE);
+	ERROR(3);
+	free(oldhead);
+	CloseSetA(CORE);
+	ERROR(3);
+    else
+	do {
+	    oldcount = 0;
+		if (ContSetA(_table_element, atr) && (oldcount < N)) {
+		    oldtail += size;
+		    oldcount++;
+	    next_of_tab();
+	over = 0;
+	    continue;
+	    continue;
+	el = oldhead;
+		    if (ContSetA(_table_element, atr) && (newcount < N)) {
+			CopySetA(new_el, el);	/* creating potentialy new element */
+			over = 0;
+			el1 = oldhead;
+			while ((el1 != el) && !over) {	/* comparing new reduct to old list */
+			    el1 += size;
+			el1 = el + size;
+			    el1 += size;
+			if (!over) {
+			    newtail += size;
+			    newcount++;
+		CopySetA(newtail, el);	/* rewriting reduct from old list */
+		newtail += size;
 		newcount++;
-	el+=size;
-     newhead=oldhead;
-     oldhead=oldtail;
-     oldtail=newtail;
-     newtail=newhead;
-     newcount=0;
- if (oldcount==0)
- else
-    *reducts=oldhead;
- free(newhead);
- CloseSetA(CORE);
+	    el += size;
+	newcount = 0;
+	free(oldhead);
+	*reducts = NULL;
+    else
+    free(newhead);
+    CloseSetA(CORE);
Modified: grass-addons/raster/mcda/r.roughset/reduct1.h
--- grass-addons/raster/mcda/r.roughset/reduct1.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/reduct1.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
  * MODULE:       r.roughset
@@ -15,49 +16,63 @@
  *   	    	 for details.
 /*** part of the RSL system written by M.Gawrys J.Sienkiewicz              ***/
-int Red (setA *red,int matrix);
+int Red(setA * red, int matrix);
      /* finds all reducts for information system,      */
-     /* sets red to yhe allocated reducts table	       */
+     /* sets red to yhe allocated reducts table        */
      /* function returns number of reducts             */
-int RedRel (setA *red,setA P,setA Q,int matrix_type);
+int RedRel(setA * red, setA P, setA Q, int matrix_type);
       /* like Red, but reducts are Q-relative and      */
       /* computed from set of attributes P             */
-int RedLess (setA *red,int N,int matrix_type);
+int RedLess(setA * red, int N, int matrix_type);
       /* finds all reducts which contain less than     */
       /* N attributes, other parameters and result     */
       /* like Red                                      */
-int RedRelLess (setA *red,setA P,setA Q,int N,int matrix_type);
+int RedRelLess(setA * red, setA P, setA Q, int N, int matrix_type);
       /* like RedLess, but reducts are Q-relative of P */
-int RedSetA (setA *red,setA quasicore,int matrix_type);
+int RedSetA(setA * red, setA quasicore, int matrix_type);
       /* finds only reducts including quasicore ,      */
       /* some reducts can be not minimal ( formally    */
       /* they are not reducts ) , other parameters and */
       /* result like Red                               */
-int RedRelSetA (setA *red,setA quasicore,setA P,setA Q,int matrix_type);
+int RedRelSetA(setA * red, setA quasicore, setA P, setA Q, int matrix_type);
       /* like RedSetA, but reducts are Q-relative of P  */
-int RedFirst (setA *red,int N,int matrix_type);
+int RedFirst(setA * red, int N, int matrix_type);
       /* finds first N reducts ( only quasi-reduct ),  */
       /* other parameters and result like Red          */
-int RedRelFirst (setA *red,setA P,setA Q,int N,int matrix_type);
+int RedRelFirst(setA * red, setA P, setA Q, int N, int matrix_type);
       /* like RedFirst, but reducts are Q-relative of P */
Modified: grass-addons/raster/mcda/r.roughset/reduct2.c
--- grass-addons/raster/mcda/r.roughset/reduct2.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/reduct2.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,174 +16,214 @@
  *   	    	 for details.
 /***              ( AUXILIARY  REDUCTS ROUTINES )                          ***/
 #include <stdlib.h>
 #include "rough.h"
-int RedSingle( setA red, int matrix_type)
+int RedSingle(setA red, int matrix_type)
     int i;
-    int cont=1;
+    int cont = 1;
     setA over;
-    Core( red, matrix_type );
-    for (i=0;(i<_mainsys->attributes_num)&&cont;i++)
-       if ( IsCover( red, matrix_type ) ) cont=0;
-       else  AddSetA( red, i );
-    cont=1;
-    while(cont)
-       if ( IsOrtho( red, over, matrix_type ) ) cont=0;
-       else
-	  for (i=0;i<_mainsys->attributes_num;i++)
-	     if (ContSetA( over, i ))
-	        { DelSetA( red, i ); break; }
-    CloseSetA( over );
+    Core(red, matrix_type);
+    for (i = 0; (i < _mainsys->attributes_num) && cont; i++)
+	if (IsCover(red, matrix_type))
+	    cont = 0;
+	else
+	    AddSetA(red, i);
+    cont = 1;
+    while (cont)
+	if (IsOrtho(red, over, matrix_type))
+	    cont = 0;
+	else
+		if (ContSetA(over, i)) {
+		    DelSetA(red, i);
+		    break;
+    CloseSetA(over);
     return 1;
-int RedRelSingle( setA red, setA P, setA Q, int matrix_type)
-{ int i;
-  int cont=1;
-  setA over;
-  over = InitEmptySetA();
-  CoreRel( red, P, Q, matrix_type );
-     if ( IsCoverRel( red, P, Q, matrix_type ) ) cont=0;
-  cont=1;
-  while(cont)
-     if ( IsOrthoRel( red, over, P, Q, matrix_type ) ) cont=0;
-     else
-         if (ContSetA( over, i )) { DelSetA( red, i ); break; }
-  return 1;
+int RedRelSingle(setA red, setA P, setA Q, int matrix_type)
+    int i;
+    int cont = 1;
+    setA over;
+    CoreRel(red, P, Q, matrix_type);
+    for (i = 0; (i < _mainsys->attributes_num) && cont; i++) {
+	if (IsCoverRel(red, P, Q, matrix_type))
+	    cont = 0;
+	else
+	    AddSetA(red, i);
+    cont = 1;
+    while (cont) {
+	if (IsOrthoRel(red, over, P, Q, matrix_type))
+	    cont = 0;
+	else
+		    DelSetA(red, i);
+		    break;
+    CloseSetA(over);
+    return 1;
-int RedOptim( setA red, int matrix_type)
-{ int max, f, fmax;
-  int i, atr;
-  int cont=1;
-  setA over;
-  over = InitFullSetA();
-  fmax = CardCoef( over, matrix_type );
-  max = CardCoef( red, matrix_type );
-  while ( max < fmax )
-   { for( i=0; i<_mainsys->attributes_num; i++ )
-       if ( !ContSetA( red, i) )
-	{ AddSetA( red, i );
-	   f = CardCoef( red, matrix_type );
-	   if ( f >= max ) max = f, atr = i;
-	   DelSetA( red, i );
-     AddSetA( red, atr );
-  cont=1;
-  while( cont )
-   { if ( IsOrtho( red, over, matrix_type ) ) cont=0;
-     else
-      for( i=0; i<_mainsys->attributes_num; i++ )
-	if ( ContSetA( over, i ) )
-  return 1;
-int RedRelOptim( setA red, setA P, setA Q, int matrix_type)
- { float max, f, fmax;
-   int i, atr;
-   int cont=1;
-   setA over;
-   fmax = DependCoef( P, Q, matrix_type );
-   while (cont)
-    { max = 0;
-	if (ContSetA( P, i ) && !ContSetA( red, i))
-	   f = DependCoef( red, Q, matrix_type );
-     if ( max==fmax ) cont=0;
+int RedOptim(setA red, int matrix_type)
+    int max, f, fmax;
+    int i, atr;
+    int cont = 1;
+    setA over;
+    over = InitFullSetA();
+    fmax = CardCoef(over, matrix_type);
+    max = CardCoef(red, matrix_type);
+    while (max < fmax) {
+	    if (!ContSetA(red, i)) {
+		AddSetA(red, i);
+		f = CardCoef(red, matrix_type);
+		if (f >= max)
+		    max = f, atr = i;
+		DelSetA(red, i);
+	AddSetA(red, atr);
-   cont=1;
-   while(cont)
-    { if ( IsOrthoRel( red, over, P, Q, matrix_type ) ) cont=0;
-      else
+    cont = 1;
+    while (cont) {
+	    cont = 0;
+	else
+		    DelSetA(red, i);
+		    break;
-   return 1;
-int RedFew( setA *reds, int matrix_type)
- { setA r;
-   int n;
-   r = InitEmptySetA();
-   RedSingle( r, matrix_type );
-   n = RedLess( reds, CardSetA(r), matrix_type );
-   CloseSetA( r );
-   return n;
+    CloseSetA(over);
+    return 1;
-int RedRelFew( setA *reds, setA P, setA Q, int matrix_type)
- { setA r;
-   int n;
-   RedRelSingle( r, P, Q, matrix_type );
-   n = RedRelLess( reds, P, Q, CardSetA(r), matrix_type );
-   CloseSetA( r );
-   return n;
-int SelectOneShort( setA reds, int N )
- { int min, m, i, num=0;
-   min = _mainsys->attributes_num;
-   for( i=0,START_OF_MAT(reds,N); END_OF_MAT; i++,NEXT_OF_MAT )
-     if ( min > (m=CardSetA( ELEM_OF_MAT )) )
-       min = m, num = i;
-  return num;
+int RedRelOptim(setA red, setA P, setA Q, int matrix_type)
+    float max, f, fmax;
+    int i, atr;
+    int cont = 1;
+    setA over;
-int SelectAllShort( setA *newreds, setA reds, int N)
- { int num, m, min;
-   int size = _mainsys->setAsize;
-   min = _mainsys->attributes_num+1;
-   *newreds = (cluster_type *)malloc( N*size*_cluster_bytes );
-   for( START_OF_MAT(reds,N); END_OF_MAT; NEXT_OF_MAT )
-      {  min = m;
-         num = 0;
-         CopySetA( *newreds+num*size, ELEM_OF_MAT );
-     else if ( min==m )
-      {  num++;
-   *newreds = (cluster_type *)realloc( *newreds, (num+1)*size*_cluster_bytes );
-   if ( *newreds==0 ) num=-1;
-   return num+1;
+    fmax = DependCoef(P, Q, matrix_type);
+    while (cont) {
+	max = 0;
+	    if (ContSetA(P, i) && !ContSetA(red, i)) {
+		AddSetA(red, i);
+		f = DependCoef(red, Q, matrix_type);
+		if (f >= max)
+		    max = f, atr = i;
+		DelSetA(red, i);
+	if (max == fmax)
+	    cont = 0;
+    cont = 1;
+    while (cont) {
+	    cont = 0;
+	else
+		    DelSetA(red, i);
+		    break;
+    CloseSetA(over);
+    return 1;
+int RedFew(setA * reds, int matrix_type)
+    setA r;
+    int n;
+    r = InitEmptySetA();
+    RedSingle(r, matrix_type);
+    n = RedLess(reds, CardSetA(r), matrix_type);
+    CloseSetA(r);
+    return n;
+int RedRelFew(setA * reds, setA P, setA Q, int matrix_type)
+    setA r;
+    int n;
+    RedRelSingle(r, P, Q, matrix_type);
+    n = RedRelLess(reds, P, Q, CardSetA(r), matrix_type);
+    CloseSetA(r);
+    return n;
+int SelectOneShort(setA reds, int N)
+    int min, m, i, num = 0;
+    min = _mainsys->attributes_num;
+    for (i = 0, START_OF_MAT(reds, N); END_OF_MAT; i++, NEXT_OF_MAT)
+	if (min > (m = CardSetA(ELEM_OF_MAT)))
+	    min = m, num = i;
+    return num;
+int SelectAllShort(setA * newreds, setA reds, int N)
+    int num, m, min;
+    int size = _mainsys->setAsize;
+    min = _mainsys->attributes_num + 1;
+    *newreds = (cluster_type *) malloc(N * size * _cluster_bytes);
+    for (START_OF_MAT(reds, N); END_OF_MAT; NEXT_OF_MAT)
+	if (min > (m = CardSetA(ELEM_OF_MAT))) {
+	    min = m;
+	    num = 0;
+	    CopySetA(*newreds + num * size, ELEM_OF_MAT);
+	else if (min == m) {
+	    num++;
+    *newreds =
+	(cluster_type *) realloc(*newreds, (num + 1) * size * _cluster_bytes);
+    if (*newreds == 0)
+	num = -1;
+    return num + 1;
Modified: grass-addons/raster/mcda/r.roughset/reduct2.h
--- grass-addons/raster/mcda/r.roughset/reduct2.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/reduct2.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,46 +16,59 @@
  *   	    	 for details.
 /***              (AUXILIARY REDUCTS ROUTINES)                             ***/
-int RedSingle( setA red, int matrix_type);
+int RedSingle(setA red, int matrix_type);
 	/* heuristicly searches for a single reduct and stores it in red */
-int RedRelSingle( setA red, setA P, setA Q, int matrix_type);
+int RedRelSingle(setA red, setA P, setA Q, int matrix_type);
 	/* heuristicly searches for a single Q-relative reduct of P */
 	/* and stores it in red */
-int RedOptim( setA red, int matrix_type);
+int RedOptim(setA red, int matrix_type);
 	/* dependency coefficient is used to select */
 	/* attributes for search optimization */
-int RedRelOptim( setA red, setA P, setA Q, int matrix_type);
+int RedRelOptim(setA red, setA P, setA Q, int matrix_type);
 	/* and stores it in red; dependency coefficient is used to select */
-int RedFew( setA *reds, int matrix_type);
+int RedFew(setA * reds, int matrix_type);
 	/* finds all reducts shortesest or equal in size to the first */
 	/* reduct found by the heuristic algorithm */
-int RedRelFew( setA *reds, setA P, setA Q, int matrix_type);
+int RedRelFew(setA * reds, setA P, setA Q, int matrix_type);
 	/* finds all Q-relative P-reducts shortesest or equal in size */
 	/* to the first reduct found by the heuristic algorithm */
-int SelectOneShort( setA reds, int num );
+int SelectOneShort(setA reds, int num);
 	/* returns index of the single shortest reduct */
 	/* from the table of num reducts pointed by reds */
-int SelectAllShort( setA *newreds, setA reds, int num);
+int SelectAllShort(setA * newreds, setA reds, int num);
 	/* copies all the shortest reducts */
Modified: grass-addons/raster/mcda/r.roughset/rerror.h
--- grass-addons/raster/mcda/r.roughset/rerror.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rerror.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,25 +16,30 @@
  *   	    	 for details.
 /***         OPTIONAL ERROR HANDLING AND ERROR MESSAGES                    ***/
 /*** part of the RSL system written by M.Gawrys J. Sienkiewicz             ***/
-char *errcodes[10]={   "everything O.K.",
-		       "Cannot open file",
-		       "Wrong format of file",
-		       "Not enough memory",
-		       "Cannot write to file",
-		       "Matrix A not initialized",
-		       "Matrix D not initialized",
-		       "Matrix X not initialized",
-		       "Wrong matrix type",
-		       "Set element out of domain"
+char *errcodes[10] = { "everything O.K.",
+    "Cannot open file",
+    "Wrong format of file",
+    "Not enough memory",
+    "Cannot write to file",
+    "Matrix A not initialized",
+    "Matrix D not initialized",
+    "Matrix X not initialized",
+    "Wrong matrix type",
+    "Set element out of domain"
 #define ErrorPrint() {printf("ERROR no: %i: %s\n",_rerror,errcodes[_rerror]);_rerror=0;}
Modified: grass-addons/raster/mcda/r.roughset/rough.h
--- grass-addons/raster/mcda/r.roughset/rough.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rough.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,12 +16,19 @@
  *   	    	 for details.
 /***       OBLIGATORY FILE TO INCLUDE IN APPLICATION SOURCE                ***/
 /***             (DATA TYPES, CONSTANTS AND HEADERS)	                   ***/
 /********************* CONSTANTS AND TYPES ***********************************/
@@ -36,19 +44,20 @@
 typedef cluster_type *setO;
 typedef cluster_type *setA;
-typedef struct {
-       char     name[50];
-       int      objects_num;
-       int      attributes_num;
-       int      descr_size;
-       void    *description;
-       int      setAsize;
-       int      setOsize;
-       value_type      *matA;
-       cluster_type    *matD;
-       cluster_type    *matX;
-       unsigned int  matXsize;
- } SYSTEM;
+typedef struct
+    char name[50];
+    int objects_num;
+    int attributes_num;
+    int descr_size;
+    void *description;
+    int setAsize;
+    int setOsize;
+    value_type *matA;
+    cluster_type *matD;
+    cluster_type *matX;
+    unsigned int matXsize;
+} SYSTEM;
 /************** H-FILES CONTAINING DECLARATIONS OF FUNCTIONS *********/
@@ -58,7 +67,7 @@
 #include "rbasic.h"
 #include "rcore.h"
 #include "reduct1.h"
-#include "reduct2.h"
+#include "reduct2.h"
 #include "rule1.h"
 #include "rule2.h"
 #include "rclass.h"
Modified: grass-addons/raster/mcda/r.roughset/rset.c
--- grass-addons/raster/mcda/r.roughset/rset.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rset.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,11 +16,17 @@
  *   	    	 for details.
 /***       OPERATIONS ON SETS OF ATTRIBUTES AND OBJECTS                    ***/
@@ -27,362 +34,473 @@
 #include <stdlib.h>
-int _cluster_bytes=sizeof(cluster_type);
-int _cluster_bits=8*sizeof(cluster_type);
-cluster_type _mask[8*sizeof(cluster_type)];
-setA InitEmptySetA( void)
- { int cluster;
-   setA set;
-   set=(setA)malloc(_mainsys->setAsize*_cluster_bytes);
-     set[cluster]=0;
-   return set;
+int _cluster_bytes = sizeof(cluster_type);
+int _cluster_bits = 8 * sizeof(cluster_type);
+cluster_type _mask[8 * sizeof(cluster_type)];
-setO InitEmptySetO( void)
- { int cluster;
-   setO set;
-   set=(setA)malloc(_mainsys->setOsize*_cluster_bytes);
-   for(cluster=_mainsys->setOsize-1;cluster>=0;cluster--)
-     set[cluster]=0;
-   return set;
+setA InitEmptySetA(void)
+    int cluster;
+    setA set;
-setA InitFullSetA( void)
- { int attr,cluster;
-   setA set;
-   for(cluster=_mainsys->setAsize-2;cluster>=0;cluster--)
-     set[cluster]=~(cluster_type)0;
-   set[_mainsys->setAsize-1]=0;
-   for (attr=_mainsys->attributes_num-1;
-        attr>=_cluster_bits*(_mainsys->setAsize-1);attr--)
-     AddSetA(set,attr);
-   return set;
+    set = (setA) malloc(_mainsys->setAsize * _cluster_bytes);
+	set[cluster] = 0;
+    return set;
-setO InitFullSetO( void)
- { int cluster,attr;
-   setO set;
-   for(cluster=_mainsys->setOsize-2;cluster>=0;cluster--)
-   set[_mainsys->setOsize-1]=0;
-   for (attr=_mainsys->objects_num-1;
-        attr>=_cluster_bits*(_mainsys->setOsize-1);attr--)
-     AddSetO(set,attr);
-   return set;
+setO InitEmptySetO(void)
+    int cluster;
+    setO set;
-void TabToSetA(setA set,int num,int tab[])
- { int atr;
-   ClearSetA(set);
-   for(atr=0; atr<num; atr++)
-     AddSetA(set,tab[atr]);
+    set = (setA) malloc(_mainsys->setOsize * _cluster_bytes);
+    for (cluster = _mainsys->setOsize - 1; cluster >= 0; cluster--)
+	set[cluster] = 0;
+    return set;
-void TabToSetO(setO set,int num,int tab[])
- { int obj;
-   ClearSetO(set);
-   for(obj=0; obj<num; obj++)
-     AddSetO(set,tab[obj]);
+setA InitFullSetA(void)
+    int attr, cluster;
+    setA set;
-void ArgToSetA(setA set,int num,...)
-{ int atr;
-  va_list list;
-   ClearSetA(set);
-   va_start(list,num);
-      AddSetA(set,va_arg(list,int));
-   va_end(list);
+    for (cluster = _mainsys->setAsize - 2; cluster >= 0; cluster--)
+	set[cluster] = ~(cluster_type) 0;
+    set[_mainsys->setAsize - 1] = 0;
+	 attr >= _cluster_bits * (_mainsys->setAsize - 1); attr--)
+	AddSetA(set, attr);
+    return set;
-void ArgToSetO(setO set,int num,...)
-{ int obj;
-  va_list list;
-   ClearSetO(set);
-     AddSetO(set,va_arg(list,int));
-   va_end(list);
+setO InitFullSetO(void)
+    int cluster, attr;
+    setO set;
-void CloseSetA( setA set)
- { free(set); }
+    for (cluster = _mainsys->setOsize - 2; cluster >= 0; cluster--)
+    set[_mainsys->setOsize - 1] = 0;
+    for (attr = _mainsys->objects_num - 1;
+	 attr >= _cluster_bits * (_mainsys->setOsize - 1); attr--)
+	AddSetO(set, attr);
+    return set;
-void CloseSetO( setA set)
- { free(set); }
+void TabToSetA(setA set, int num, int tab[])
+    int atr;
-void OrSetO( setO or, setO s1, setO s2)
- { int cluster;
-   for (cluster=_mainsys->setOsize-1;cluster>=0;cluster--)
-     or[cluster]= s1[cluster] | s2[cluster];
-   return;
+    ClearSetA(set);
+    for (atr = 0; atr < num; atr++)
+	AddSetA(set, tab[atr]);
-void OrSetA( setA or, setA s1, setA s2)
- { int cluster;
-   for (cluster=_mainsys->setAsize-1;cluster>=0;cluster--)
-   return;
+void TabToSetO(setO set, int num, int tab[])
+    int obj;
-void AndSetO( setO and, setO s1, setO s2)
- { int cluster;
-     and[cluster]= s1[cluster] & s2[cluster];
-   return;
+    ClearSetO(set);
+    for (obj = 0; obj < num; obj++)
+	AddSetO(set, tab[obj]);
-void AndSetA( setA and, setA s1, setA s2)
- { int cluster;
-   return;
+void ArgToSetA(setA set, int num, ...)
+    int atr;
+    va_list list;
-void DifSetO( setO dif, setO s1, setO s2)
- { int cluster;
-     dif[cluster]= s1[cluster] & ~s2[cluster];
-   return;
+    ClearSetA(set);
+    va_start(list, num);
+	AddSetA(set, va_arg(list, int));
-void DifSetA( setA dif, setA s1, setA s2)
- { int cluster;
-   return;
+    va_end(list);
+void ArgToSetO(setO set, int num, ...)
+    int obj;
+    va_list list;
-void NotSetO( setO not, setO set)
- { int cluster, obj;
-   for (cluster=_mainsys->setOsize-2;cluster>=0;cluster--)
-     not[cluster]= ~set[cluster] ;
-   cluster=_mainsys->setOsize-1;
-   for (obj=_mainsys->objects_num-1-_cluster_bits*(_mainsys->setOsize-1);
-        obj>=0;obj--)
-      if ( set[cluster]&_mask[obj] )
-	 not[cluster] &= ~_mask[obj];
-      else
-	 not[cluster] |= _mask[obj];
-   return;
+    ClearSetO(set);
+	AddSetO(set, va_arg(list, int));
-void NotSetA( setA not, setA set)
- { int cluster, attr;
-   for (cluster=_mainsys->setAsize-2;cluster>=0;cluster--)
-   cluster=_mainsys->setAsize-1;
-   for (attr=_mainsys->attributes_num-1-_cluster_bits*(_mainsys->setAsize-1);
-        attr>=0;attr--)
-      if ( set[cluster]&_mask[attr] )
-	 not[cluster] &= ~_mask[attr];
-      else
-	 not[cluster] |= _mask[attr];
-   return;
+    va_end(list);
-void ClearSetO( setO set)
- { int cluster;
-     set[cluster]=0;
-   return;
+void CloseSetA(setA set)
+    free(set);
-void ClearSetA( setA set)
- { int cluster;
-     set[cluster]=0;
-   return;
+void CloseSetO(setA set)
+    free(set);
-void FillSetO( setO set)
- { int cluster,obj;
-   for(obj=_mainsys->objects_num-1;
-       obj>=_cluster_bits*(_mainsys->setOsize-1);obj--)
-     AddSetO(set,obj);
-   return;
+void OrSetO(setO or, setO s1, setO s2)
+    int cluster;
-void FillSetA( setA set)
-   return;
+	or[cluster] = s1[cluster] | s2[cluster];
+    return;
-int AddSetO( setO set, int obj)
- { if (obj>=_mainsys->objects_num) ERROR(9)
-   set[obj/_cluster_bits] |= _mask[obj%_cluster_bits];
-   return 0;
+void OrSetA(setA or, setA s1, setA s2)
+    int cluster;
-int AddSetA( setA set, int attr)
- { if (attr>=_mainsys->attributes_num) ERROR(9)
-   set[attr/_cluster_bits] |= _mask[attr%_cluster_bits];
-   return 0;
+    return;
-int DelSetO( setO set, int obj)
-   set[obj/_cluster_bits] &= ~_mask[obj%_cluster_bits];
-   return 0;
+void AndSetO(setO and, setO s1, setO s2)
+    int cluster;
-int DelSetA( setA set, int attr)
-   set[attr/_cluster_bits] &= ~_mask[attr%_cluster_bits];
-   return 0;
+	and[cluster] = s1[cluster] & s2[cluster];
+    return;
-int InSetO( setO big, setO small)
- { int cluster;
-   for (cluster=_mainsys->setOsize-1; cluster>=0 ; cluster--)
-     if(big[cluster]!=(big[cluster] | small[cluster])) return 0;
-   return 1;
+void AndSetA(setA and, setA s1, setA s2)
+    int cluster;
-int InSetA( setA big, setA small)
- { int cluster;
-   for (cluster=_mainsys->setAsize-1; cluster>=0 ; cluster--)
-   return 1;
+    return;
-int ContSetA( setA set, int attr)
- { if(attr>=_mainsys->attributes_num) ERROR(9)
-   return (_mask[attr%_cluster_bits] & set[attr/_cluster_bits]);
+void DifSetO(setO dif, setO s1, setO s2)
+    int cluster;
-int ContSetO( setO set,int obj)
- { if(obj>=_mainsys->objects_num) ERROR(9)
-   return (_mask[obj%_cluster_bits] & set[obj/_cluster_bits]);
+	dif[cluster] = s1[cluster] & ~s2[cluster];
+    return;
-int InterSetO( setO s1, setO s2)
- { int cluster;
-     if(s1[cluster] & s2[cluster]) return 1;
-   return 0;
+void DifSetA(setA dif, setA s1, setA s2)
+    int cluster;
-int InterSetA( setA s1, setA s2)
- { int cluster;
-   return 0;
+    return;
-int IsEmptySetO( setO set )
- { int cluster;
-     if(set[cluster]) return 0;
-   return 1;
+void NotSetO(setO not, setO set)
+    int cluster, obj;
-int IsEmptySetA( setA set )
- { int cluster;
-   return 1;
+	not[cluster] = ~set[cluster];
+    cluster = _mainsys->setOsize - 1;
+    for (obj =
+	 _mainsys->objects_num - 1 - _cluster_bits * (_mainsys->setOsize - 1);
+	 obj >= 0; obj--)
+	if (set[cluster] & _mask[obj])
+	    not[cluster] &= ~_mask[obj];
+	else
+	    not[cluster] |= _mask[obj];
+    return;
-int CardSetO( setO set)
- { int obj,card=0;
-   for(obj=_mainsys->objects_num-1;obj>=0;obj--)
-     if(ContSetO(set,obj)) card++;
-   return card;
+void NotSetA(setA not, setA set)
-int CardSetA( setA set)
- {  int cluster,attr,card=0;
-       for(attr=_cluster_bits-1;attr>=0;attr--)
-	  if( _mask[attr] & set[cluster] ) card++;
-    for(attr=_mainsys->attributes_num-1-_cluster_bits*(_mainsys->setAsize-1);
-        attr>=0;attr--)
+    cluster = _mainsys->setAsize - 1;
+    for (attr =
+	 _mainsys->attributes_num - 1 - _cluster_bits * (_mainsys->setAsize -
+							 1); attr >= 0;
+	 attr--)
+	if (set[cluster] & _mask[attr])
+	    not[cluster] &= ~_mask[attr];
+	else
+	    not[cluster] |= _mask[attr];
+    return;
+void ClearSetO(setO set)
+    int cluster;
+	set[cluster] = 0;
+    return;
+void ClearSetA(setA set)
+    int cluster;
+	set[cluster] = 0;
+    return;
+void FillSetO(setO set)
+    int cluster, obj;
+    for (obj = _mainsys->objects_num - 1;
+	 obj >= _cluster_bits * (_mainsys->setOsize - 1); obj--)
+	AddSetO(set, obj);
+    return;
+void FillSetA(setA set)
+    return;
+int AddSetO(setO set, int obj)
+    if (obj >= _mainsys->objects_num)
+	ERROR(9)
+	    set[obj / _cluster_bits] |= _mask[obj % _cluster_bits];
+    return 0;
+int AddSetA(setA set, int attr)
+    if (attr >= _mainsys->attributes_num)
+	ERROR(9)
+	    set[attr / _cluster_bits] |= _mask[attr % _cluster_bits];
+    return 0;
+int DelSetO(setO set, int obj)
+	ERROR(9)
+	    set[obj / _cluster_bits] &= ~_mask[obj % _cluster_bits];
+    return 0;
+int DelSetA(setA set, int attr)
+	ERROR(9)
+	    set[attr / _cluster_bits] &= ~_mask[attr % _cluster_bits];
+    return 0;
+int InSetO(setO big, setO small)
+    int cluster;
+	if (big[cluster] != (big[cluster] | small[cluster]))
+	    return 0;
+    return 1;
+int InSetA(setA big, setA small)
+    int cluster;
+	    return 0;
+    return 1;
+int ContSetA(setA set, int attr)
+	ERROR(9)
+	    return (_mask[attr % _cluster_bits] & set[attr / _cluster_bits]);
+int ContSetO(setO set, int obj)
+	ERROR(9)
+	    return (_mask[obj % _cluster_bits] & set[obj / _cluster_bits]);
+int InterSetO(setO s1, setO s2)
+    int cluster;
+	if (s1[cluster] & s2[cluster])
+	    return 1;
+    return 0;
+int InterSetA(setA s1, setA s2)
+    int cluster;
+	    return 1;
+    return 0;
+int IsEmptySetO(setO set)
+    int cluster;
+	if (set[cluster])
+	    return 0;
+    return 1;
+int IsEmptySetA(setA set)
+    int cluster;
+	if (set[cluster])
+	    return 0;
+    return 1;
+int CardSetO(setO set)
+    int obj, card = 0;
+    for (obj = _mainsys->objects_num - 1; obj >= 0; obj--)
+	if (ContSetO(set, obj))
+	    card++;
     return card;
-void CopySetO( setO dest, setO source)
- { int cluster;
-     dest[cluster]=source[cluster];
-   return;
-void CopySetA( setA dest, setA source)
- { int cluster;
-   return;
+int CardSetA(setA set)
+    int cluster, attr, card = 0;
-int CompSetO( setO set1, setO set2)
- { int cluster;
-     if(set1[cluster] != set2[cluster]) return 0;
-   return 1;
+	for (attr = _cluster_bits - 1; attr >= 0; attr--)
+	    if (_mask[attr] & set[cluster])
+		card++;
+    for (attr =
+							 1); attr >= 0;
+	 attr--)
+	    card++;
+    return card;
-int CompSetA( setA set1, setA set2)
- { int cluster;
-   return 1;
+void CopySetO(setO dest, setO source)
+    int cluster;
+	dest[cluster] = source[cluster];
+    return;
+void CopySetA(setA dest, setA source)
+    int cluster;
+    return;
+int CompSetO(setO set1, setO set2)
+    int cluster;
+	if (set1[cluster] != set2[cluster])
+	    return 0;
+    return 1;
+int CompSetA(setA set1, setA set2)
+    int cluster;
+	    return 0;
+    return 1;
 int SizeSetO(void)
- { return _mainsys->setOsize; }
+    return _mainsys->setOsize;
 int SizeSetA(void)
- { return _mainsys->setAsize; }
+    return _mainsys->setAsize;
-void AttrValSetO( setO set, int attr, value_type val)
- { int obj;
-   ClearSetO(set);
-   for (obj=0; obj<_mainsys->objects_num ;obj++)
-     if( val==GetA(obj,attr))
-	AddSetO(set,obj);
+void AttrValSetO(setO set, int attr, value_type val)
+    int obj;
-int ClassSetO( setO aclass, int obj, setA Q )
- { int i;
-   ClearSetO( aclass );
-   for (i=0;i<_mainsys->objects_num;i++)
-      if ( CompareA( i, obj, Q ) ) AddSetO( aclass, i );
-   return 0;
+    ClearSetO(set);
+    for (obj = 0; obj < _mainsys->objects_num; obj++)
+	if (val == GetA(obj, attr))
+int ClassSetO(setO aclass, int obj, setA Q)
+    int i;
-void PrintSetO( setO set )
- { int obj,i=0;
-   printf("{");
-    if (ContSetO(set,obj)) printf("%c%i",(i++>0?',':' '),obj);
-   printf(" }\n");
+    ClearSetO(aclass);
+    for (i = 0; i < _mainsys->objects_num; i++)
+	if (CompareA(i, obj, Q))
+	    AddSetO(aclass, i);
+    return 0;
-void PrintSetA( setA set )
- { int attr,i=0;
-   printf("{");
-   for (attr=0; attr<_mainsys->attributes_num ;attr++)
-    if (ContSetA(set,attr)) printf("%c%i",(i++>0?',':' '),attr);
-   printf(" }\n");
+void PrintSetO(setO set)
+    int obj, i = 0;
+    printf("{");
+	    printf("%c%i", (i++ > 0 ? ',' : ' '), obj);
+    printf(" }\n");
+void PrintSetA(setA set)
+    int attr, i = 0;
+    printf("{");
+    for (attr = 0; attr < _mainsys->attributes_num; attr++)
+	if (ContSetA(set, attr))
+	    printf("%c%i", (i++ > 0 ? ',' : ' '), attr);
+    printf(" }\n");
Modified: grass-addons/raster/mcda/r.roughset/rset.h
--- grass-addons/raster/mcda/r.roughset/rset.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rset.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,11 +16,17 @@
  *   	    	 for details.
@@ -31,104 +38,128 @@
 setO InitEmptySetO(void);
 setA InitEmptySetA(void);
 	/* allocates memory for set and initializes it */
-        /* as empty, returns allocated set */
+	/* as empty, returns allocated set */
 setO InitFullSetO(void);
 setO InitFullSetA(void);
 	/* as full, returns newly allocated set */
-void TabToSetO(setO set,int num,int tab[]);
-void TabToSetA(setA set,int num,int tab[]);
+void TabToSetO(setO set, int num, int tab[]);
+void TabToSetA(setA set, int num, int tab[]);
 	/* sets a set with num elements of table tab */
-void ArgToSetO(setO set,int num,...);
-void ArgToSetA(setA set,int num,...);
+void ArgToSetO(setO set, int num, ...);
+void ArgToSetA(setA set, int num, ...);
 	/* sets a set with num arguments of function */
 void CloseSetO(setO set);
 void CloseSetA(setA set);
 	/* free memory used by set */
-void OrSetO(setO or,setO s1,setO s2);
-void OrSetA(setA or,setA s1,setA s2);
+void OrSetO(setO or, setO s1, setO s2);
+void OrSetA(setA or, setA s1, setA s2);
 	/* puts union of s1 and s2 to or */
-void AndSetO(setO and,setO s1,setO s2);
-void AndSetA(setA and,setA s1,setA s2);
+void AndSetO(setO and, setO s1, setO s2);
+void AndSetA(setA and, setA s1, setA s2);
 	/* puts product of s1 and s2 to and */
-void DifSetO(setO dif,setO s1,setO s2);
-void DifSetA(setA dif,setA s1,setA s2);
+void DifSetO(setO dif, setO s1, setO s2);
+void DifSetA(setA dif, setA s1, setA s2);
 	/* puts complement of s1 in s2 to dif */
-void NotSetO(setO not,setO set);
-void NotSetA(setO not,setA set);
+void NotSetO(setO not, setO set);
+void NotSetA(setO not, setA set);
 	/* puts a complement of set to not */
 void ClearSetO(setO set);
 void ClearSetA(setA set);
 	/* clears set */
 void FillSetO(setO set);
 void FillSetA(setA set);
 	/* fills set with domain */
-int AddSetO(setO set,int obj);
-int AddSetA(setA set,int attr);
+int AddSetO(setO set, int obj);
+int AddSetA(setA set, int attr);
 	/* adds element to set */
-int DelSetO(setO set,int obj);
-int DelSetA(setA set,int attr);
+int DelSetO(setO set, int obj);
+int DelSetA(setA set, int attr);
 	/* deletes element from set */
-int InSetO(setO big,setO small);
-int InSetA(setA big,setA small);
+int InSetO(setO big, setO small);
+int InSetA(setA big, setA small);
 	/* return 1 if set big contains set small */
-int ContSetO(setO set,int obj);
-int ContSetA(setA set,int attr);
+int ContSetO(setO set, int obj);
+int ContSetA(setA set, int attr);
 	/* returns 1 if set contains element */
-int InterSetO(setO s1,setO s2);
-int InterSetA(setA s1,setA s2);
+int InterSetO(setO s1, setO s2);
+int InterSetA(setA s1, setA s2);
 	/* returns 1 if s1 and s2 have nonempty product */
 int IsEmptySetO(setO set);
 int IsEmptySetA(setA set);
 	/* returns 1 if set is empty */
 int CardSetO(setO set);
 int CardSetA(setA set);
 	/* returns cardinality of set */
-void CopySetO(setO dest,setO source);
-void CopySetA(setA dest,setO source);
+void CopySetO(setO dest, setO source);
+void CopySetA(setA dest, setO source);
 	/* copy source to dest */
-int CompSetO(setO set1,setO set2);
-int CompSetA(setA set1,setA set2);
+int CompSetO(setO set1, setO set2);
+int CompSetA(setA set1, setA set2);
 	/* returns 1 if set1 and set2 are identical */
 int SizeSetO(void);
 int SizeSetA(void);
 	/* returns number of clusters in set representation */
 	/* in the active system sizeof(cluster_type)=_cluster_bytes */
-void AttrValSetO(setO set,int attr,value_type val);
+void AttrValSetO(setO set, int attr, value_type val);
 	/* puts into set all object that have value val */
 	/* on attribute attr */
-int ClassSetO( setO aclass, int obj, setA Q );
+int ClassSetO(setO aclass, int obj, setA Q);
 	/* fills class with all object that have the same values */
 	/* on all attributes from Q as the object obj, uses MATA */
 void PrintSetO(setO set);
 void PrintSetA(setA set);
 	/* outputs set to screen */
Modified: grass-addons/raster/mcda/r.roughset/rsystem.h
--- grass-addons/raster/mcda/r.roughset/rsystem.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rsystem.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,123 +16,157 @@
  *   	    	 for details.
 /***                 SYSTEM HANDLING FUNCTIONS                             ***/
 #include <stdio.h>
-extern SYSTEM  *_mainsys;
+extern SYSTEM *_mainsys;
 	/* active information system */
-extern int  _rerror;
+extern int _rerror;
 	/* error code */
-SYSTEM  *InitEmptySys(void);
-	/* allocates memory for a new system descriptor*/
+SYSTEM *InitEmptySys(void);
+	/* allocates memory for a new system descriptor */
 	/* and clears all parameters, no matrices connected */
-void SetParameters(SYSTEM *sys,int objects_num,int attributes_num);
+void SetParameters(SYSTEM * sys, int objects_num, int attributes_num);
 	/* puts system parameters to the system descriptor */
-void ConnectDescr(SYSTEM *sys,void *descr,int size);
+void ConnectDescr(SYSTEM * sys, void *descr, int size);
 	/* connects additional description to the system descriptor */
-void SetName(SYSTEM *sys,char *name);
+void SetName(SYSTEM * sys, char *name);
 	/* puts system name to the system descriptor */
-int FileToSys(SYSTEM *sys,char *filename);
+int FileToSys(SYSTEM * sys, char *filename);
 	/* imports system from the special format file */
 	/* including parameters, desicripton and matrix A */
 	/* other matrices are left uninitialed */
-int SysToFile(SYSTEM *sys,char *filename);
+int SysToFile(SYSTEM * sys, char *filename);
 	/* exports system descriptor, additional description */
 	/* and matrix A to a special format file */
-void ConnectA(SYSTEM *sys,value_type *buf);
+void ConnectA(SYSTEM * sys, value_type * buf);
 	/* connects matrix A (it may be empty) with */
 	/* the system descriptor */
-void PutToA(SYSTEM *sys,int object,int attribute,value_type value);
+void PutToA(SYSTEM * sys, int object, int attribute, value_type value);
 	/* sets value to element of matrix A */
-int FillAfromAscii(SYSTEM *sys,FILE *file);
+int FillAfromAscii(SYSTEM * sys, FILE * file);
 	/* fills matrix A with the values from Ascii file */
-int InitD(SYSTEM *sys);
+int InitD(SYSTEM * sys);
 	/* fills matrix D from A, allocates memory  */
 	/* and connects it with the system descriptor */
 	/* matrix A must already exist */
-int InitX(SYSTEM *sys,setA P,setA Q,int matrix_type);
+int InitX(SYSTEM * sys, setA P, setA Q, int matrix_type);
 	/* fills matrix X, allocates memory for it and */
 	/* connects it with the system descriptor */
 	/* matrix_type indicates the source matrix */
 	/* initialization is done with respect to Q from P */
-int InitXforObject(SYSTEM *sys,int obj,setA P,setA Q,int matrix_type);
+int InitXforObject(SYSTEM * sys, int obj, setA P, setA Q, int matrix_type);
 	/* works like InitX but considers only single column of MATD */
-int InitXforObjects(SYSTEM *sys,setO objects,setA P,setA Q,int matrix_type);
+int InitXforObjects(SYSTEM * sys, setO objects, setA P, setA Q,
+		    int matrix_type);
 	/* works like InitX but concider only columns of MATD */
 	/* belonging to objects */
-int InitXforObjectFromClass(SYSTEM* sys,int obj,setA P,setO aclass,
+int InitXforObjectFromClass(SYSTEM * sys, int obj, setA P, setO aclass,
 			    int matrix_type);
 	/* works like InitX, conciders only specified objects */
 	/* initialization is done with respect to objects from */
 	/* outside of aclass */
-void UseSys(SYSTEM *sys);
+void UseSys(SYSTEM * sys);
 	/* makes indicated system active, from now on */
 	/* all query routines will operate only on it */
-void CloseSys(SYSTEM *sys);
+void CloseSys(SYSTEM * sys);
 	/* frees memory allocated for all matrixes, */
 	/* system descriptor and additional description */
-void CloseMat(SYSTEM *sys, int matrix_type);
+void CloseMat(SYSTEM * sys, int matrix_type);
 	/* disconnects matrix X from the system descriptor */
 	/* and frees memory  */
-void DisconMat(SYSTEM *sys, int matrix_type);
+void DisconMat(SYSTEM * sys, int matrix_type);
 	/* disconnects matrix from the system descriptor */
 	/* does not free memory */
-unsigned int Asize(SYSTEM *sys);
+unsigned int Asize(SYSTEM * sys);
 	/* returns number of elements in matrix A */
 	/* memory size = Asize * sizeof(value_type) */
 	/* system parameters should be valued */
-unsigned int Dsize(SYSTEM *sys);
+unsigned int Dsize(SYSTEM * sys);
 	/* returns number of memory clusters for matrix D */
 	/* memory size = Dsize * sizeof(cluster_type) */
-unsigned int Xsize(SYSTEM *sys);
+unsigned int Xsize(SYSTEM * sys);
 	/* returns number of memory cluster used by matrix X */
 	/* memory size = Xsize * sizeof(cluster_type) */
 	/* matrix X should be generated */
-unsigned int MatMemSize(SYSTEM *sys,int matrix_type);
+unsigned int MatMemSize(SYSTEM * sys, int matrix_type);
 	/* returns the size of memory used by specified matrix */
-void *MatExist(SYSTEM *sys,int matrix_type);
-        /* return specified matrix if exist */
-        /* otherwise returns NULL */
-int ObjectsNum(SYSTEM *sys);
+void *MatExist(SYSTEM * sys, int matrix_type);
+	/* return specified matrix if exist */
+	/* otherwise returns NULL */
+int ObjectsNum(SYSTEM * sys);
 	/* returns number of objects in the system */
-int AttributesNum(SYSTEM *sys);
+int AttributesNum(SYSTEM * sys);
 	/* returns number of attributes in the system */
-void *Description(SYSTEM *sys);
+void *Description(SYSTEM * sys);
 	/* returns pointer to additional description */
-char *SysName(SYSTEM *sys);
+char *SysName(SYSTEM * sys);
 	/* returns system name */
Modified: grass-addons/raster/mcda/r.roughset/rule1.c
--- grass-addons/raster/mcda/r.roughset/rule1.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rule1.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,36 +16,47 @@
  *   	    	 for details.
 /***               SOME MORE QUERIES FOR SYSTEM                            ***/
 /***                   ( MENAGING RULES )                                  ***/
 /*** part of the ROUGH system written by M.Gawrys J.Sienkiewicz            ***/
 #include <stdlib.h>
 #include <string.h>
 #include "rough.h"
-void RuleCopy(value_type *dest,value_type *source)
- { memcpy( dest, source, _mainsys->attributes_num*sizeof(value_type) );
+void RuleCopy(value_type * dest, value_type * source)
+    memcpy(dest, source, _mainsys->attributes_num * sizeof(value_type));
-int RuleEQ(value_type *first,value_type *second)
- { return !memcmp(first, second, _mainsys->attributes_num*sizeof(value_type) );
+int RuleEQ(value_type * first, value_type * second)
+    return !memcmp(first, second,
+		   _mainsys->attributes_num * sizeof(value_type));
-void AddRule(value_type *rules,int *count,value_type *rule)
- { int i;
-   int size=_mainsys->attributes_num;
-   for( i=0; i<*count; i++ )
-     if ( RuleEQ( rules+i*size, rule ) )
-       return;
-   RuleCopy( rules+(*count)*size, rule );
-   *count += 1;
-   return;
+void AddRule(value_type * rules, int *count, value_type * rule)
+    int i;
+    int size = _mainsys->attributes_num;
+    for (i = 0; i < *count; i++)
+	if (RuleEQ(rules + i * size, rule))
+	    return;
+    RuleCopy(rules + (*count) * size, rule);
+    *count += 1;
+    return;
Modified: grass-addons/raster/mcda/r.roughset/rule1.h
--- grass-addons/raster/mcda/r.roughset/rule1.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rule1.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,23 +16,33 @@
  *   	    	 for details.
 #define MINUS ((value_type)-1)
-void RuleCopy( value_type *dest,value_type *source);
+void RuleCopy(value_type * dest, value_type * source);
 	/* copies a rule from source to dest */
-int RuleEQ( value_type *first,value_type *second);
+int RuleEQ(value_type * first, value_type * second);
 	/* returns 1 if first rule is equal to second */
-void AddRule( value_type *rules,int *size,value_type *rule);
+void AddRule(value_type * rules, int *size, value_type * rule);
 	/* adds new rule to array of rules */
 	/* if the rule is unique size is incremented */
Modified: grass-addons/raster/mcda/r.roughset/rule2.c
--- grass-addons/raster/mcda/r.roughset/rule2.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rule2.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,12 +16,19 @@
  *   	    	 for details.
 /***                   ( FINDING RULES )                                   ***/
@@ -28,538 +36,598 @@
 #include <stdlib.h>
 #include <string.h>
-int AllRules(value_type **rules,setA P,setA Q,int matrix_type)
- { int obj,attr,n,red;
-   int memo=_mainsys->objects_num;
-   int count=0;
-   int size=_mainsys->setAsize;
-   setA reducts=NULL;
-   value_type *rule=NULL;
+int AllRules(value_type ** rules, setA P, setA Q, int matrix_type)
+    int obj, attr, n, red;
+    int memo = _mainsys->objects_num;
+    int count = 0;
+    setA reducts = NULL;
+    value_type *rule = NULL;
-   *rules = (value_type *)malloc(memo*_mainsys->attributes_num*sizeof(value_type));
-   if (*rules == NULL)
-      ERROR(3);
-   if ( !MatExist(_mainsys,MATA) )
-      ERROR(5);
-   rule=(value_type *)malloc(_mainsys->attributes_num*sizeof(value_type));
-   if (rule == NULL)
-      ERROR(3);
-   for (obj=0; obj<_mainsys->objects_num; obj++)
-     { if ( InitXforObject(_mainsys,obj,P,Q,matrix_type) < 0 )
-         { free(rule); return(-_rerror); }
-       else if ( !MatExist(_mainsys,MATX) )
-	  continue;
-       n=Red(&reducts,MATX);
-       CloseMat(_mainsys,MATX);
-       if (memo<count+n)
-         { memo=count+n;
-	   if ((*rules=(value_type *)realloc(*rules,
-	      memo*_mainsys->attributes_num*sizeof(value_type))) == NULL)
-	    { free(reducts);
-	      free(rule);
-	      ERROR(3)
+    *rules =
+	(value_type *) malloc(memo * _mainsys->attributes_num *
+			      sizeof(value_type));
+    if (*rules == NULL)
+	ERROR(3);
+    if (!MatExist(_mainsys, MATA))
+	ERROR(5);
+    rule =
+	(value_type *) malloc(_mainsys->attributes_num * sizeof(value_type));
+    if (rule == NULL)
+	ERROR(3);
+    for (obj = 0; obj < _mainsys->objects_num; obj++) {
+	if (InitXforObject(_mainsys, obj, P, Q, matrix_type) < 0) {
+	    free(rule);
+	    return (-_rerror);
+	else if (!MatExist(_mainsys, MATX))
+	    continue;
+	n = Red(&reducts, MATX);
+	CloseMat(_mainsys, MATX);
+	if (memo < count + n) {
+	    memo = count + n;
+	    if ((*rules = (value_type *) realloc(*rules,
+						 memo *
+						 sizeof(value_type))) ==
+		NULL) {
+		free(reducts);
+		free(rule);
+		ERROR(3)
-       for (red=0;red<n;red++)
-         { for ( attr=_mainsys->attributes_num-1; attr>=0; attr--)
-	     if ( ContSetA( reducts+red*size, attr) || ContSetA(Q,attr) )
-	       rule[attr] = GetA(obj,attr);
-	     else
-	       rule[attr]=MINUS;
-	   AddRule(*rules, &count, rule);
-       if (n > 0)
-	 free(reducts);
-       reducts = NULL;
-   free(rule);
-       (*rules, count*_mainsys->attributes_num*sizeof(value_type)))==NULL)
-      ERROR(3);
-   return count;
+	for (red = 0; red < n; red++) {
+	    for (attr = _mainsys->attributes_num - 1; attr >= 0; attr--)
+		if (ContSetA(reducts + red * size, attr) || ContSetA(Q, attr))
+		    rule[attr] = GetA(obj, attr);
+		else
+		    rule[attr] = MINUS;
+	    AddRule(*rules, &count, rule);
+	if (n > 0)
+	    free(reducts);
+	reducts = NULL;
+    free(rule);
+	 (*rules,
+	  count * _mainsys->attributes_num * sizeof(value_type))) == NULL)
+	ERROR(3);
+    return count;
-int AllRulesForReducts(value_type **rules, cluster_type *reducts,
+int AllRulesForReducts(value_type ** rules, cluster_type * reducts,
 		       int N, setA Q, int matrix_type)
- { int red,num,i,count=0;
-   value_type *newrules=NULL;	/* rules for a single reduct */
-   *rules=NULL;
-   for (red=0;red<N;red++)
-     { num=AllRules(&newrules,reducts+red*_mainsys->setAsize,Q,matrix_type);
-	  (count+num)*_mainsys->attributes_num*sizeof(value_type) )) == NULL)
-         { free(newrules);
-	   ERROR(3)
-       for ( i=0; i<num; i++)
-	 AddRule(*rules,&count,newrules+i*_mainsys->attributes_num);
-       if (num > 0)
-	 free(newrules);
-       newrules=NULL;
-       (*rules,count*_mainsys->attributes_num*sizeof(value_type)))==NULL)
-     ERROR(3);
-   return count;
+    int red, num, i, count = 0;
+    value_type *newrules = NULL;	/* rules for a single reduct */
+    *rules = NULL;
+    for (red = 0; red < N; red++) {
+	num =
+	    AllRules(&newrules, reducts + red * _mainsys->setAsize, Q,
+		     matrix_type);
+	if ((*rules =
+	     (value_type *) realloc(*rules,
+				    (count +
+				     num) * _mainsys->attributes_num *
+				    sizeof(value_type))) == NULL) {
+	    free(newrules);
+	    ERROR(3)
+	for (i = 0; i < num; i++)
+	    AddRule(*rules, &count, newrules + i * _mainsys->attributes_num);
+	if (num > 0)
+	    free(newrules);
+	newrules = NULL;
+	 (*rules,
+	ERROR(3);
+    return count;
-int SelectRules( value_type **rules, int *N, setO set, setA P, int option )
-{ int i,j,obj,find,newXsize,
-      newN = 0,
-      next=-1,
-      size=_mainsys->attributes_num;
-  setA red, newfull;
-  SYSTEM *oldsys=_mainsys,
-         *newsys=InitEmptySys();
-  cluster_type *newX;
-  value_type *newrules;
-  SetParameters( newsys, *N, *N );
-  newXsize = CardSetO(set) * (newsys->setAsize);
-  newX = (cluster_type *)calloc( newXsize, _cluster_bytes );
-  if( newX==NULL )
-    {  CloseSys( newsys );
-       ERROR( 3 );
+int SelectRules(value_type ** rules, int *N, setO set, setA P, int option)
+    int i, j, obj, find, newXsize,
+	newN = 0, next = -1, size = _mainsys->attributes_num;
+    setA red, newfull;
+    SYSTEM *oldsys = _mainsys, *newsys = InitEmptySys();
+    cluster_type *newX;
+    value_type *newrules;
+    SetParameters(newsys, *N, *N);
+    newXsize = CardSetO(set) * (newsys->setAsize);
+    newX = (cluster_type *) calloc(newXsize, _cluster_bytes);
+    if (newX == NULL) {
+	CloseSys(newsys);
+	ERROR(3);
-  for( obj=0; obj<_mainsys->objects_num; obj++ )
-    if( ContSetO( set,obj ) )
-      for( i=0,next++; i<*N; i++ )
-	{ find=1;
-	  for( j=0; j<_mainsys->attributes_num; j++ )
-	    { if ( !ContSetA(P,j) ) continue;
-	      if ( (*rules+i*size)[j] != GetA(obj,j) )
-		 if ((*rules+i*size)[j]!=MINUS)
-		   { find=0; break; }
+	    for (i = 0, next++; i < *N; i++) {
+		find = 1;
+		for (j = 0; j < _mainsys->attributes_num; j++) {
+		    if (!ContSetA(P, j))
+			continue;
+		    if ((*rules + i * size)[j] != GetA(obj, j))
+			if ((*rules + i * size)[j] != MINUS) {
+			    find = 0;
+			    break;
+		if (find)
+		    newX[next * newsys->setAsize + i / _cluster_bits] |=
+			_mask[i % _cluster_bits];
-	  if(find)
-	    newX[ next*newsys->setAsize+i/_cluster_bits ] |=
-		 _mask[ i%_cluster_bits ];
-  UseSys( newsys );
-  newsys->matX = newX;
-  newsys->matXsize = newXsize;
-  newfull = InitFullSetA();
-  InitX( newsys, newfull, newfull, MATX );
-  free( newX );
-  CloseSetA( newfull );
-  if( _rerror!=0 )
-    { free( newsys );
-      UseSys( oldsys );
-      ERROR( 3 );
+    UseSys(newsys);
+    newsys->matX = newX;
+    newsys->matXsize = newXsize;
+    newfull = InitFullSetA();
+    InitX(newsys, newfull, newfull, MATX);
+    free(newX);
+    CloseSetA(newfull);
+    if (_rerror != 0) {
+	free(newsys);
+	UseSys(oldsys);
+	ERROR(3);
-  if( option==BESTOPT )
-    { i = Red( &red, MATX );
-      j = SelectOneShort( red, i );
+    if (option == BESTOPT) {
+	i = Red(&red, MATX);
+	j = SelectOneShort(red, i);
-  else
-    { red = InitEmptySetA();
-      RedOptim( red, MATX );
-      j=0;
+    else {
+	red = InitEmptySetA();
+	RedOptim(red, MATX);
+	j = 0;
-  newN = CardSetA( red + j * newsys->setAsize );
-  newrules = (value_type *)malloc( newN * oldsys->attributes_num *
-				   sizeof(value_type));
-  if( newrules==NULL )
-      UseSys( oldsys );
-      ERROR( 3 );
+    newN = CardSetA(red + j * newsys->setAsize);
+    newrules = (value_type *) malloc(newN * oldsys->attributes_num *
+    if (newrules == NULL) {
+	CloseSys(newsys);
+	UseSys(oldsys);
+	ERROR(3);
-  for( i=0,obj=0; i<*N; i++ )
-     if( ContSetA( red + j*newsys->setAsize , i ) )
-     	memcpy(newrules+obj++*oldsys->attributes_num,
-	       *rules+i*oldsys->attributes_num,
-	       oldsys->attributes_num*sizeof(value_type) );
-     free( red );
-  else
-     CloseSetA( red );
-  if( *N>0 )
-     free( *rules );
-  *N = newN;
-  *rules = newrules;
-  UseSys( oldsys );
-  CloseSys( newsys );
-  return 0;
+    for (i = 0, obj = 0; i < *N; i++)
+	if (ContSetA(red + j * newsys->setAsize, i))
+	    memcpy(newrules + obj++ * oldsys->attributes_num,
+		   *rules + i * oldsys->attributes_num,
+		   oldsys->attributes_num * sizeof(value_type));
+	free(red);
+    else
+	CloseSetA(red);
+    if (*N > 0)
+	free(*rules);
+    *N = newN;
+    *rules = newrules;
+    UseSys(oldsys);
+    CloseSys(newsys);
+    return 0;
-int BestRules( value_type **rules, setA P, setA Q, int matrix_type )
- { int i,obj,
-       num=0,			/* total number of rules */
-       classnum=0;		/* number of rules for class */
-   setO processed,		/* already covered objects */
-        newclass;		/* class */
-   value_type *classrules=NULL;	/* rules for a single class */
-   *rules=(value_type *)malloc( Asize(_mainsys)*sizeof(value_type) );
-   if (*rules==NULL)
-      ERROR(3);
-   if ( !MatExist( _mainsys,MATA ) )
-      ERROR(5);
-   processed = InitEmptySetO();
-   newclass = InitEmptySetO();
-     if( !ContSetO( processed, obj ) )
-       { ClassSetO( newclass, obj, Q );
-	 classnum = 0;
-	 OrSetO( processed, processed, newclass );
-	 classnum = BestRulesForClass( &classrules, newclass, P, Q, matrix_type );
-	 for( i=0; i<classnum; i++ )
-	    AddRule( *rules,&num,classrules+i*_mainsys->attributes_num );
-	 if( classnum >0 )
-	    free( classrules );
-	 classrules = NULL;
-   CloseSetO( processed );
-   CloseSetO( newclass );
-   if( (*rules=(value_type *)realloc( *rules,
-       num*_mainsys->attributes_num*sizeof(value_type) ) )==NULL )
-      ERROR(3);
-   return num;
+int BestRules(value_type ** rules, setA P, setA Q, int matrix_type)
+    int i, obj, num = 0,	/* total number of rules */
+	classnum = 0;		/* number of rules for class */
+    setO processed,		/* already covered objects */
+      newclass;			/* class */
+    value_type *classrules = NULL;	/* rules for a single class */
+    *rules = (value_type *) malloc(Asize(_mainsys) * sizeof(value_type));
+	ERROR(3);
+	ERROR(5);
+    processed = InitEmptySetO();
+    newclass = InitEmptySetO();
+	if (!ContSetO(processed, obj)) {
+	    ClassSetO(newclass, obj, Q);
+	    classnum = 0;
+	    OrSetO(processed, processed, newclass);
+	    classnum =
+		BestRulesForClass(&classrules, newclass, P, Q, matrix_type);
+	    for (i = 0; i < classnum; i++)
+		AddRule(*rules, &num,
+			classrules + i * _mainsys->attributes_num);
+	    if (classnum > 0)
+		free(classrules);
+	    classrules = NULL;
+    CloseSetO(processed);
+    CloseSetO(newclass);
+					 num * _mainsys->attributes_num *
+	ERROR(3);
+    return num;
-int BestRulesForClass( value_type **rules, setO set, setA P, setA Q, int matrix_type )
- { int n,attr,obj,red,
-       num=0;			/* total number of rules */
-   setA fewred=NULL,		/* selected reducts */
-        allred=NULL;		/* all reducts */
-   value_type *rule=NULL;	/* single rule */
+int BestRulesForClass(value_type ** rules, setO set, setA P, setA Q,
+		      int matrix_type)
+    int n, attr, obj, red, num = 0;	/* total number of rules */
+    setA fewred = NULL,		/* selected reducts */
+	allred = NULL;		/* all reducts */
+    value_type *rule = NULL;	/* single rule */
-   *rules = NULL;
-   if( !MatExist( _mainsys,MATA ) )
-      ERROR(5);
-   rule=(value_type *)malloc( _mainsys->attributes_num*sizeof(value_type) );
-   if( rule==NULL )
-      ERROR(3);
-     if ( ContSetO( set, obj ) )
-       { if( InitXforObject( _mainsys,obj,P,Q,matrix_type ) < 0 )
-	   { free( rule );
-	     return( -_rerror );
-	   continue;
-	 n = Red( &allred ,MATX);
- 	 if( n>0 )
-	   { n = SelectAllShort( &fewred, allred, n );
-	     free( allred );
-	 else
-	   { free( rule );
-	 if( ( *rules=(value_type *)realloc
-	       (*rules,(n+num)*_mainsys->attributes_num*sizeof(value_type)) ) == NULL )
-	   { free( rule );
-	     free( fewred );
-	 for( red=0; red<n; red++ )
-	   { for( attr=_mainsys->attributes_num-1; attr>=0; attr-- )
-	     if( ContSetA( fewred+red*size, attr ) || ContSetA( Q,attr ) )
-	        rule[attr] = GetA( obj,attr );
-	     else
-		rule[attr] = MINUS;
-	     AddRule( *rules,&num,rule );
-   if( n>0 )
-      free( fewred );
-   free( rule );
-   if( SelectRules( rules, &num, set, P, BESTOPT ) < 0 )
-      return ( -_rerror );
-   if ( (*rules=(value_type *)realloc
-	( *rules,num*_mainsys->attributes_num*sizeof(value_type) ) )==NULL )
-      ERROR(3);
-   return num;
+    *rules = NULL;
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+	if (ContSetO(set, obj)) {
+		free(rule);
+		continue;
+	    n = Red(&allred, MATX);
+	    if (n > 0) {
+		n = SelectAllShort(&fewred, allred, n);
+		free(allred);
+	    else {
+		free(rule);
+		 (*rules,
+		  (n +
+		   num) * _mainsys->attributes_num * sizeof(value_type))) ==
+		NULL) {
+		free(rule);
+		free(fewred);
+		    if (ContSetA(fewred + red * size, attr) ||
+			ContSetA(Q, attr))
+		    else
+		AddRule(*rules, &num, rule);
+    if (n > 0)
+	free(fewred);
+    free(rule);
+    if (SelectRules(rules, &num, set, P, BESTOPT) < 0)
+	 (*rules,
+	  num * _mainsys->attributes_num * sizeof(value_type))) == NULL)
+	ERROR(3);
+    return num;
-int Rules( value_type **rules, setA P, setA Q, int matrix_type )
- { int i,obj,
-   value_type *rule=NULL,	/* single rule */
-              *classrules=NULL;	/* rules for class */
-   if (*rules==NULL)
-      ERROR(3);
-      ERROR(5);
-   rule = (value_type *)malloc( _mainsys->attributes_num*sizeof(value_type) );
-   if ( rule==NULL )
-      ERROR(3);
-     if ( !ContSetO( processed, obj ) )
-	 classnum = 0;
-	 classnum = RulesForClass( &classrules, newclass, P, Q, matrix_type );
-	 for ( i=0; i<classnum; i++ )
-	 if ( classnum>0 )
-   free( rule );
-      ERROR(3);
-   return num;
+int Rules(value_type ** rules, setA P, setA Q, int matrix_type)
+    value_type *rule = NULL,	/* single rule */
+	*classrules = NULL;	/* rules for class */
+	ERROR(3);
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+	    classnum = 0;
+	    classnum =
+		RulesForClass(&classrules, newclass, P, Q, matrix_type);
+	    if (classnum > 0)
+		free(classrules);
+    free(rule);
+	 (*rules,
+	ERROR(3);
+    return num;
-int RulesForClass( value_type **rules, setO set, setA P, setA Q, int matrix_type )
- { int j,n,obj,red,
+int RulesForClass(value_type ** rules, setO set, setA P, setA Q,
+		  int matrix_type)
+    int j, n, obj, red, num = 0;	/* total number of rules */
-   *rules = NULL;
-      ERROR(5);
-   if( rule==NULL )
-      ERROR(3);
-	   { free( rule );
-	   continue;
- 	 if( n>0 )
-	     free( allred );
-	 else
-	   { free( rule );
-	   { free( rule );
-	     free( fewred );
-	   { for( j=_mainsys->attributes_num-1; j>=0; j-- )
-	     if( ContSetA( fewred+red*size, j ) || ContSetA( Q,j ) )
-	        rule[j] = GetA( obj,j );
-	     else
-		rule[j] = MINUS;
-   if( n>0 )
-      free( fewred );
-   free( rule );
-   if( SelectRules( rules, &num, set, P, FASTOPT ) < 0 )
-      ERROR(3);
-   return num;
+    *rules = NULL;
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+		free(rule);
+		continue;
+	    if (n > 0) {
+		free(allred);
+	    else {
+		free(rule);
+		 (*rules,
+		  (n +
+		NULL) {
+		free(rule);
+		free(fewred);
+		for (j = _mainsys->attributes_num - 1; j >= 0; j--)
+		    if (ContSetA(fewred + red * size, j) || ContSetA(Q, j))
+			rule[j] = GetA(obj, j);
+		    else
+			rule[j] = MINUS;
+    if (n > 0)
+	free(fewred);
+    free(rule);
+    if (SelectRules(rules, &num, set, P, FASTOPT) < 0)
+	 (*rules,
+	ERROR(3);
+    return num;
-int FastRules(value_type **rules,setA P,setA Q,int matrix_type)
- { int obj,attr,n,red,count=0;
-   *rules=(value_type *)malloc(Asize(_mainsys)*sizeof(value_type));
-   if(*rules==NULL)
-      ERROR(3);
-   if(!MatExist(_mainsys,MATA))
-      ERROR(5);
-   if(rule==NULL)
-      ERROR(3);
-   for(obj=0;obj<_mainsys->objects_num;obj++)
-    { if(InitXforObject(_mainsys,obj,P,Q,matrix_type)<0)
-	continue;
-      n=Red(&reducts, MATX);
-      red = SelectOneShort( reducts, n );
-      for (attr=_mainsys->attributes_num-1;attr>=0;attr--)
-	 if (ContSetA(reducts+red*size,attr) || ContSetA(Q,attr))
-	    rule[attr]=GetA(obj,attr);
-	 else
-	    rule[attr]=MINUS;
-      AddRule(*rules,&count,rule);
-      if (n>0) free(reducts);
-      reducts=NULL;
+int FastRules(value_type ** rules, setA P, setA Q, int matrix_type)
+    int obj, attr, n, red, count = 0;
+	ERROR(3);
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+	    free(rule);
+	    continue;
+	red = SelectOneShort(reducts, n);
+	    else
+	if (n > 0)
+	    free(reducts);
+	reducts = NULL;
-   free(rule);
-	(*rules, count*_mainsys->attributes_num*sizeof(value_type))) == NULL)
-      ERROR(3);
-   return count;
+    free(rule);
+	 (*rules,
+	ERROR(3);
+    return count;
-int VeryFastRules(value_type **rules,setA P,setA Q,int matrix_type)
-{  int obj,attr,count=0;
-   setA reduct;
-   if (*rules==NULL)
-      ERROR(3);
-   if (!MatExist(_mainsys,MATA))
-      ERROR(5);
-   if (rule==NULL)
-      ERROR(3);
-   reduct = InitEmptySetA();
-	continue;
-      RedOptim(reduct, MATX);
-	 if (ContSetA(reduct,attr) || ContSetA(Q,attr) )
-	 else
-	    rule[attr]=MINUS;
+int VeryFastRules(value_type ** rules, setA P, setA Q, int matrix_type)
+    int obj, attr, count = 0;
+    setA reduct;
+	ERROR(3);
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+    reduct = InitEmptySetA();
+	    free(rule);
+	    continue;
+	RedOptim(reduct, MATX);
+	    if (ContSetA(reduct, attr) || ContSetA(Q, attr))
+	    else
-   free( rule );
-   CloseSetA( reduct );
-      ERROR(3);
-   return count;
+    free(rule);
+    CloseSetA(reduct);
+	 (*rules,
+	ERROR(3);
+    return count;
-int ApprRules( value_type **rules, setA P, setA Q, int option, int matrix_type )
- { int i,obj,
-   if (*rules==NULL)
-      ERROR(3);
-      ERROR(5);
-   if ( rule==NULL )
-      ERROR(3);
-	 classnum = 0;
-	 classnum = ApprRulesForClass( &classrules, newclass, P, Q,
-				      option, matrix_type );
-	 if ( classnum>0 )
-   free( rule );
-      ERROR(3);
-   return num;
+int ApprRules(value_type ** rules, setA P, setA Q, int option,
+	      int matrix_type)
+	ERROR(3);
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+	    classnum = 0;
+	    classnum = ApprRulesForClass(&classrules, newclass, P, Q,
+					 option, matrix_type);
+	    if (classnum > 0)
+		free(classrules);
+    free(rule);
+	 (*rules,
+	ERROR(3);
+    return num;
-int ApprRulesForClass( value_type **rules, setO set, setA P, setA Q,
-		      int option, int matrix_type )
-   setO aclass;
-   *rules = NULL;
-      ERROR(5);
-   if( rule==NULL )
-      ERROR(3);
-   aclass = InitEmptySetO();
-   if ( option==LOWER ) LowAppr( aclass, set, P, matrix_type );
-   else if (option==UPPER ) UppAppr( aclass, set, P, matrix_type );
-   else CopySetO( aclass, set );
-     if ( ContSetO( aclass, obj ) )
-       { if( InitXforObjectFromClass( _mainsys,obj,P,aclass,matrix_type ) < 0 )
-	   { free( rule );
-	   continue;
- 	 if( n>0 )
-	     free( allred );
-	 else
-	   { free( rule );
-	   { free( rule );
-	     free( fewred );
-	     else
-		rule[j] = MINUS;
-   if( n>0 )
-      free( fewred );
-   free( rule );
-      ERROR(3);
-   return num;
+int ApprRulesForClass(value_type ** rules, setO set, setA P, setA Q,
+		      int option, int matrix_type)
+    setO aclass;
+    *rules = NULL;
+	ERROR(5);
+    rule =
+    if (rule == NULL)
+	ERROR(3);
+    aclass = InitEmptySetO();
+    if (option == LOWER)
+	LowAppr(aclass, set, P, matrix_type);
+    else if (option == UPPER)
+	UppAppr(aclass, set, P, matrix_type);
+    else
+	CopySetO(aclass, set);
+	if (ContSetO(aclass, obj)) {
+	    if (InitXforObjectFromClass(_mainsys, obj, P, aclass, matrix_type)
+		< 0) {
+		free(rule);
+		continue;
+	    if (n > 0) {
+		free(allred);
+	    else {
+		free(rule);
+		 (*rules,
+		  (n +
+		NULL) {
+		free(rule);
+		free(fewred);
+		    else
+			rule[j] = MINUS;
+    if (n > 0)
+	free(fewred);
+    free(rule);
+	 (*rules,
+	ERROR(3);
+    return num;
Modified: grass-addons/raster/mcda/r.roughset/rule2.h
--- grass-addons/raster/mcda/r.roughset/rule2.h	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rule2.h	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -15,12 +16,19 @@
  *   	    	 for details.
 #define BESTOPT 0
@@ -30,64 +38,73 @@
 #define LOWER   1
 #define UPPER   2
-int AllRules(value_type **rules, setA P, setA Q, int matrix_type);
+int AllRules(value_type ** rules, setA P, setA Q, int matrix_type);
 	/* finds all possible rules for condition attributes P */
 	/* and decision Q, allocates memory, returns number of rules */
 		       int N, setA Q, int matrix_type);
-        /* finds all possible rules for each reduct separatly */
- 	/* allocates memory, returns number of rules */
+	/* finds all possible rules for each reduct separatly */
+	/* allocates memory, returns number of rules */
-int SelectRules( value_type **rules, int *N, setO set, setA P, int option );
+int SelectRules(value_type ** rules, int *N, setO set, setA P, int option);
 	/* reduce set of rules to cover only some objects */
 	/* on attributes P, reallocates memory and decrease N */
 	/* option: FASTOPT for shortcomings      */
 	/*         BESTOPT for optimal computing */
-int BestRules( value_type **rules, setA P, setA Q, int matrix_type );
+int BestRules(value_type ** rules, setA P, setA Q, int matrix_type);
 	/* finds minimal set of rules, allocates memory */
 	/* P - condition attributes; Q - decision attributes */
- 	/* returns number of rules */
+	/* returns number of rules */
-int BestRulesForClass( value_type **rules, setO set, setA P, setA Q, int matrix_type );
+		      int matrix_type);
 	/* finds minimal set of rules to cover objects from set */
-int Rules( value_type **rules, setA P, setA Q, int matrix_type );
+int Rules(value_type ** rules, setA P, setA Q, int matrix_type);
 	/* finds set of rules, allocates memory */
-int RulesForClass( value_type **rules, setO set, setA P, setA Q, int matrix_type );
+		  int matrix_type);
 	/* finds set of rules to cover objects from set */
-int FastRules(value_type **rules,setA P,setA Q, int matrix_type);
+int FastRules(value_type ** rules, setA P, setA Q, int matrix_type);
 	/* finds quickly set of rules, allocates memory */
-int VeryFastRules(value_type **rules,setA P,setA Q, int matrix_type);
+int VeryFastRules(value_type ** rules, setA P, setA Q, int matrix_type);
 	/* finds very quickly set of rules, allocates memory */
-int ApprRules( value_type **rules, setA P, setA Q, int option, int matrix_type );
+	      int matrix_type);
 	/* finds set of rules for approximated classes */
 	/* option: LOWER - lower approximation - certain rules */
 	/*         UPPER - upper approximation - possible rules */
 	/*         NORMAL - no approximation - normal rules */
-		       int option, int matrix_type );
+		      int option, int matrix_type);
 	/* finds set of rules for approximated class (set) */
Modified: grass-addons/raster/mcda/r.roughset/rules_extr.c
--- grass-addons/raster/mcda/r.roughset/rules_extr.c	2010-04-03 09:17:52 UTC (rev 41683)
+++ grass-addons/raster/mcda/r.roughset/rules_extr.c	2010-04-03 09:29:09 UTC (rev 41684)
@@ -1,3 +1,4 @@
@@ -33,390 +34,429 @@
 #include "rough.h"
 #include "localproto.h"
-int rough_analysis(int nrows, int ncols, char *name, int *classify_vect, struct input *attributes, char *file_sample_txt, int strgy, int cls);
+int rough_analysis(int nrows, int ncols, char *name, int *classify_vect,
+		   struct input *attributes, char *file_sample_txt, int strgy,
+		   int cls);
-void rough_set_library_out(int nrows, int ncols, int nattributes, struct input *attributes, char *file_out_sys);
+void rough_set_library_out(int nrows, int ncols, int nattributes,
+			   struct input *attributes, char *file_out_sys);
-void output_to_txt( FILE *file_out_txt, value_type* rules, setA P,setA Q, setA core, setA beg, int n, SYSTEM * sys1, int strgy, int r, int *opr, struct input *attributes);
+void output_to_txt(FILE * file_out_txt, value_type * rules, setA P, setA Q,
+		   setA core, setA beg, int n, SYSTEM * sys1, int strgy,
+		   int r, int *opr, struct input *attributes);
-void fPrintSetA( FILE *file, setA set );
-void fPrintSetO( FILE *file, setO set );
-void fPrintRules( FILE *file, value_type* rules, int N, int *opr, setA P, setA Q, struct input *attributes);
+void fPrintSetA(FILE * file, setA set);
+void fPrintSetO(FILE * file, setO set);
+void fPrintRules(FILE * file, value_type * rules, int N, int *opr, setA P,
+		 setA Q, struct input *attributes);
-float MeanAttrInRule( value_type *rules, int N, setA P );
+float MeanAttrInRule(value_type * rules, int N, setA P);
-int LowRules( value_type **rules, setA P, setA Q, int mat );
-int UppRules( value_type **rules, setA P, setA Q, int mat );
-int NormRules( value_type **rules, setA P, setA Q, int mat );
+int LowRules(value_type ** rules, setA P, setA Q, int mat);
+int UppRules(value_type ** rules, setA P, setA Q, int mat);
+int NormRules(value_type ** rules, setA P, setA Q, int mat);
+		   int cls)
-	SYSTEM *sys1, *sys2; /* Information system descriptor structures.*/
-  	/* It contains information about the system parameters (number of objects, number of attributes, system name. */
- 	value_type value, *buf,*rules; /* stores a single value of attribute (used for attribute-value table and rule implementation)*/
-  	char c;
-  	int n,j,i,r, *opr;
-  	setA beg,P,Q,full,core; /*set of attributes*/
-  	setO train;		  /*set of object*/
-  	FILE *file_out_txt; /* pointer to text output file */
-  	int (*genrules)( value_type**, setA, setA, int );
-  	int nattributes, nobjects=nrows*ncols; /*objects in information system are all raster cells in working location with a defined resolution */
-  	int row, col,object,attribute; /*index and counter*/
-  	sys1=InitEmptySys();  /* Allocates memory for a system descriptor and returns a pointer.*/
-  	if(file_sample_txt != NULL) /*use sample txt file if input in dec_txt->answer isn't NUL*/
-  		{name=file_sample_txt;
-  		G_message("Using %s sys file for rules generation",name);} /* Imports a system from a file of the special format.*/
-  	FileToSys(sys1,name); /* Imports a system from a file of the special format.*/
-  	if (_rerror>0)
-  		{  G_fatal_error("  Can't open data file \n");
-  			return(1);}
-  	strcat(name,".out");
-  	if (!(file_out_txt=fopen(name,"a"))) 					/*output text file*/
-  		{G_fatal_error("  Can't open output file \n");
-  			return(1);}
-  	UseSys(sys1); /* Activates a system. All routines will work on this indicated system data and parameters.*/
-  	if (_rerror>0)
-    	{G_fatal_error("Can't open information system <%s>\n",sys1->name);
-    		return(1); }
-  	full=InitFullSetA(); /*Initialize a full set. Allocates memory for a set and initialize it with all elements of
-        		domain based on the active information system */
-  	InitD(sys1); /*Generates MATRIX D from MATRIX A.Connected to sys and filled*/
-  	P=InitEmptySetA(); /* Initialize an empty set. Memory size determined by active information system parameters */
-  	Q=InitEmptySetA();
+    SYSTEM *sys1, *sys2;	/* Information system descriptor structures. */
-  	nattributes=(AttributesNum(sys1)-1);
-  	/* define attribute */
-  	for(i=0;i<nattributes;i++)
-    	AddSetA(P,i); /* Adds a single element to a set */
-   /* define decision */
-   	AddSetA(Q,(AttributesNum(sys1)-1));
-  	InitX(sys1,P,Q,MATD); /*Generates MATRIX X from another matrix designed for use in core and reducts queries. */
-  	core=InitEmptySetA();
-  	Core(core,MATX); /* Puts a core of the active information system to core. */
-  	RedOptim( core, MATX ); /* Provides the optimized heuristic search for a single reduct */
-  	CloseSetA(core);  /* Frees memory allocated for a set */
-  	n=RedFew(&beg,MATX); /*Finds all reducts shorter than the first one found.*/
-  	CloseMat(sys1,MATX); /* Closes a matrix. */
-  	if ( n>0 ) free( beg );
+    /* It contains information about the system parameters (number of objects, number of attributes, system name. */
+    value_type value, *buf, *rules;	/* stores a single value of attribute (used for attribute-value table and rule implementation) */
+    char c;
+    int n, j, i, r, *opr;
+    setA beg, P, Q, full, core;	/*set of attributes */
+    setO train;			/*set of object */
+    FILE *file_out_txt;		/* pointer to text output file */
+    int (*genrules) (value_type **, setA, setA, int);
-  	switch ( strgy )
-	case 0: genrules = VeryFastRules;
-	   break;
-	case 1: genrules = FastRules;
-	   break;
-	case 2: genrules = Rules;
-	   break;
-	case 3: genrules = BestRules;
-	   break;
-	case 4: genrules = AllRules;
-	   break;
-	case 5: genrules = LowRules;
-	   break;
-	case 6: genrules = UppRules;
-	   break;
-	default: genrules = NormRules;
-	   break;
+    int nattributes, nobjects = nrows * ncols;	/*objects in information system are all raster cells in working location with a defined resolution */
+    int row, col, object, attribute;	/*index and counter */
-	r = genrules ( &rules, P, Q, MATD );  /* rules generator*/
-	if (r>0) {opr = StrengthOfRules( rules, r ); } /* Creates a table of rules strengths*/
+    sys1 = InitEmptySys();	/* Allocates memory for a system descriptor and returns a pointer. */
+    if (file_sample_txt != NULL) {	/*use sample txt file if input in dec_txt->answer isn't NUL */
+	name = file_sample_txt;
+	G_message("Using %s sys file for rules generation", name);
+    }				/* Imports a system from a file of the special format. */
+    FileToSys(sys1, name);	/* Imports a system from a file of the special format. */
+    if (_rerror > 0) {
+	G_fatal_error("  Can't open data file \n");
+	return (1);
+    strcat(name, ".out");
+    if (!(file_out_txt = fopen(name, "a"))) {	/*output text file */
+	G_fatal_error("  Can't open output file \n");
+	return (1);
+    UseSys(sys1);		/* Activates a system. All routines will work on this indicated system data and parameters. */
+	G_fatal_error("Can't open information system <%s>\n", sys1->name);
+	return (1);
+    full = InitFullSetA();	/*Initialize a full set. Allocates memory for a set and initialize it with all elements of
+				   domain based on the active information system */
+    InitD(sys1);		/*Generates MATRIX D from MATRIX A.Connected to sys and filled */
+    P = InitEmptySetA();	/* Initialize an empty set. Memory size determined by active information system parameters */
+    Q = InitEmptySetA();
+    nattributes = (AttributesNum(sys1) - 1);
+    /* define attribute */
+    for (i = 0; i < nattributes; i++) {
+	AddSetA(P, i);		/* Adds a single element to a set */
+    /* define decision */
+    AddSetA(Q, (AttributesNum(sys1) - 1));
+    InitX(sys1, P, Q, MATD);	/*Generates MATRIX X from another matrix designed for use in core and reducts queries. */
+    core = InitEmptySetA();
+    Core(core, MATX);		/* Puts a core of the active information system to core. */
+    RedOptim(core, MATX);	/* Provides the optimized heuristic search for a single reduct */
+    CloseSetA(core);		/* Frees memory allocated for a set */
+    n = RedFew(&beg, MATX);	/*Finds all reducts shorter than the first one found. */
+    CloseMat(sys1, MATX);	/* Closes a matrix. */
+    if (n > 0)
+	free(beg);
+    switch (strgy) {
+    case 0:
+	genrules = VeryFastRules;
+	break;
+    case 1:
+	genrules = FastRules;
+	break;
+    case 2:
+	genrules = Rules;
+	break;
+    case 3:
+	genrules = BestRules;
+	break;
+    case 4:
+	genrules = AllRules;
+	break;
+    case 5:
+	genrules = LowRules;
+	break;
+    case 6:
+	genrules = UppRules;
+	break;
+    default:
+	genrules = NormRules;
+	break;
+    r = genrules(&rules, P, Q, MATD);	/* rules generator */
+    if (r > 0) {
+	opr = StrengthOfRules(rules, r);
+    }				/* Creates a table of rules strengths */
 /**************************Output text files************************************/
 /***********print output about sys1 in a txt file (file_out_txt)****************/
-	output_to_txt(file_out_txt,rules,P,Q,core,beg,n,sys1,strgy,r,opr,attributes);
+    output_to_txt(file_out_txt, rules, P, Q, core, beg, n, sys1, strgy, r,
+		  opr, attributes);
 /**************************close all********************************************/
     //CloseSys(sys1);   /* close sys1 */
 /**************************Classify*********************************************/
-	sys2=InitEmptySys();
-	SetParameters(sys2,nobjects,nattributes); 		/* assigning system parameters */
-	ConnectA(sys2,malloc(MatMemSize(sys2,MATA))); 	/* Connects MATRIX A to a system descriptor. */
-													/*MatMemSize: Returns size of memory used by matrix.*/
-	SetName(sys2,"classys");
-	UseSys(sys2); /* active system sys2 was created in application and has only MATRIX A */
-	if (_rerror>0)
-    {  G_fatal_error("Can't open information system <%s>\n",_mainsys->name);
-    	return(1); }
+    sys2 = InitEmptySys();
+    SetParameters(sys2, nobjects, nattributes);	/* assigning system parameters */
+    ConnectA(sys2, malloc(MatMemSize(sys2, MATA)));	/* Connects MATRIX A to a system descriptor. */
+    /*MatMemSize: Returns size of memory used by matrix. */
+    SetName(sys2, "classys");
+    UseSys(sys2);		/* active system sys2 was created in application and has only MATRIX A */
+	G_fatal_error("Can't open information system <%s>\n", _mainsys->name);
+	return (1);
     G_message("Build information system for classification ");
-		object=0;  /* set object numbers =0 and increase it until rows*cells for each attribute */
-		for (row = 0; row < nrows; row++)
-			G_percent(row, nrows, 1);
-			/* Reads appropriate information into the buffer buf associated with the requested row*/
-			G_get_c_raster_row (attributes[i].fd, attributes[i].buf, row);
-			for (col=0;col<ncols;col++)
-					value = (attributes[i].buf[col]); /*make a cast on the DCELL output value*/
-					PutA(_mainsys,object,i,value);    /* filling MATRIX A */
-			      	object++;
-    buf = MatExist(_mainsys,MATA); /*Returns pointer to specified matrix if exists*/
+	object = 0;		/* set object numbers =0 and increase it until rows*cells for each attribute */
+	for (row = 0; row < nrows; row++) {
+	    G_percent(row, nrows, 1);
+	    /* Reads appropriate information into the buffer buf associated with the requested row */
+	    G_get_c_raster_row(attributes[i].fd, attributes[i].buf, row);
+	    for (col = 0; col < ncols; col++) {
+		value = (attributes[i].buf[col]);	/*make a cast on the DCELL output value */
+		PutA(_mainsys, object, i, value);	/* filling MATRIX A */
+		object++;
-    if (!buf)
-	{  G_fatal_error("Error in the information system <%s>\n",_mainsys->name);
-		return(1); }
-    switch ( cls )
-	case 0:
+    buf = MatExist(_mainsys, MATA);	/*Returns pointer to specified matrix if exists */
+    if (!buf) {
+	G_fatal_error("Error in the information system <%s>\n",
+		      _mainsys->name);
+	return (1);
+    switch (cls) {
+    case 0:
-		for (j=0;j<_mainsys->objects_num;j++)
-		{ /*Chooses the best rule to cover sample. Strategy no. 1*/
-			classify_vect[j]=Classify1(buf+j*_mainsys->attributes_num,rules,r,P,Q);
-			G_percent(j, _mainsys->objects_num, 1);
+	    for (j = 0; j < _mainsys->objects_num; j++) {	/*Chooses the best rule to cover sample. Strategy no. 1 */
+		classify_vect[j] =
+		    Classify1(buf + j * _mainsys->attributes_num, rules, r, P,
+			      Q);
+		G_percent(j, _mainsys->objects_num, 1);
-	   break;
-	case 1:
+	break;
+    case 1:
-		{ /*Chooses the best rule to cover sample. Strategy no. 2*/
-			classify_vect[j]=Classify2(buf+j*_mainsys->attributes_num,rules,r,P,Q);
+	    for (j = 0; j < _mainsys->objects_num; j++) {	/*Chooses the best rule to cover sample. Strategy no. 2 */
+		    Classify2(buf + j * _mainsys->attributes_num, rules, r, P,
+			      Q);
-	   break;
-    case 2:
-		{ /*Chooses the best rule to cover sample. Strategy no. 3*/
-			classify_vect[j]=Classify3(buf+j*_mainsys->attributes_num,rules,r,opr,P,Q);
-	   break;
-	default: 0;
-	   break;
+	break;
+    case 2:
+	    for (j = 0; j < _mainsys->objects_num; j++) {	/*Chooses the best rule to cover sample. Strategy no. 3 */
+		    Classify3(buf + j * _mainsys->attributes_num, rules, r,
+			      opr, P, Q);
+	break;
-	G_message("All cells classified (%d)",j);
+    default:
+	0;
+	break;
+    G_message("All cells classified (%d)", j);
-  	free( rules );
-  	free( opr );
-  	CloseSetA(P);
-  	CloseSetA(Q);
-  	CloseSetA(full);
-  	CloseSys(sys2);
-  //fclose(file);
-  	fclose(file_out_txt);
-  	return (0);
+    free(rules);
+    free(opr);
+    CloseSetA(P);
+    CloseSetA(Q);
+    CloseSetA(full);
+    CloseSys(sys2);
+    //fclose(file);
+    fclose(file_out_txt);
+    return (0);
-void rough_set_library_out(int nrows, int ncols, int nattribute, struct input *attributes, char *file_out_sys)
+void rough_set_library_out(int nrows, int ncols, int nattribute,
-	int row, col, i, j;
-	int value, decvalue;
-	int nobject;
-	char cell_buf[300];
-	FILE *fp;			/*file pointer for ASCII output*/
+    int row, col, i, j;
+    int value, decvalue;
+    int nobject;
+    char cell_buf[300];
+    FILE *fp;			/*file pointer for ASCII output */
-	/* open *.sys file for writing or use stdout */
-    if(NULL == (fp = fopen(file_out_sys, "w")))
-        	G_fatal_error("Not able to open file [%s]",file_out_sys);
+    /* open *.sys file for writing or use stdout */
+    if (NULL == (fp = fopen(file_out_sys, "w")))
+	G_fatal_error("Not able to open file [%s]", file_out_sys);
-	fprintf(fp,"NAME: %s\nATTRIBUTES: %d\nOBJECTS: %s\n",file_out_sys,nattribute+1,"            ");
+    fprintf(fp, "NAME: %s\nATTRIBUTES: %d\nOBJECTS: %s\n", file_out_sys,
+	    nattribute + 1, "            ");
 	/************** process the data *************/
-	G_message("Build information system for rules extraction in %s", file_out_sys);
-	nobject=0;
-			for(i=0;i<=nattribute;i++)
-				G_get_c_raster_row (attributes[i].fd, attributes[i].buf, row);/* Reads appropriate information into the buffer buf associated with the requested row*/
-					{	/*make a cast on the DCELL output value*/
-					decvalue=(int)attributes[nattribute].buf[col];
-					if(0<decvalue)  /* TODO: correct form will: decval!=null */
-						for(j=0;j<nattribute;j++)
-								value = (int)(attributes[j].buf[col]);
-								sprintf(cell_buf, "%d",value);
-			      				G_trim_decimal (cell_buf);
-			      				fprintf (fp,"%s ",cell_buf);
-			      			fprintf(fp,"%d\n",decvalue);
-			      			nobject++;
+    G_message("Build information system for rules extraction in %s",
+	      file_out_sys);
+    nobject = 0;
+	for (i = 0; i <= nattribute; i++) {
+	    G_get_c_raster_row(attributes[i].fd, attributes[i].buf, row);	/* Reads appropriate information into the buffer buf associated with the requested row */
+	for (col = 0; col < ncols; col++) {	/*make a cast on the DCELL output value */
+	    decvalue = (int)attributes[nattribute].buf[col];
+	    if (0 < decvalue) {	/* TODO: correct form will: decval!=null */
+		for (j = 0; j < nattribute; j++) {	/*make a cast on the DCELL output value */
+		    value = (int)(attributes[j].buf[col]);
+		    sprintf(cell_buf, "%d", value);
+		    G_trim_decimal(cell_buf);
+		    fprintf(fp, "%s ", cell_buf);
-	/************** write code file*************/
-		fprintf(fp,"\n%s",attributes[i].name);
+		fprintf(fp, "%d\n", decvalue);
+		nobject++;
+	/************** write code file*************/
+	fprintf(fp, "\n%s", attributes[i].name);
 	/************** write header file*************/
-	rewind(fp); /*move file pointer to header file*/
-				/* TODO: make a system to  detect errors like: G_fatal_error("Not able to write file [%s]",file_out_sys);*/
+    rewind(fp);			/*move file pointer to header file */
+    /* TODO: make a system to  detect errors like: G_fatal_error("Not able to write file [%s]",file_out_sys); */
-	fprintf(fp,"NAME: %s\nATTRIBUTES: %d\nOBJECTS: %d",file_out_sys,nattribute+1,nobject);
+    fprintf(fp, "NAME: %s\nATTRIBUTES: %d\nOBJECTS: %d", file_out_sys,
+	    nattribute + 1, nobject);
 	/************** close all and exit ***********/
-	fclose(fp);
+    fclose(fp);
-	int i;
-	fprintf(file_out_txt,"Condition attributes are\n");
-  	fPrintSetA(file_out_txt,P);
-  	fprintf(file_out_txt,"\nDecision attributes are\n");
-  	fPrintSetA(file_out_txt,Q);
-  	fprintf(file_out_txt,"\nDependCoef = %f\n",DependCoef(P,Q,MATD)); /* Returns degree of dependency Q from P in the active information system.*/
-	fprintf(file_out_txt,"CORE = ");
-  	fPrintSetA(file_out_txt,core);
-  	fprintf(file_out_txt,"\nRedOptim = ");
-  	fprintf( file_out_txt,"\nFew reducts ( %i ):\n", n );
-  	for (i=0;i<n;i++)
-     	fPrintSetA( file_out_txt, beg+i*sys1->setAsize );
-     	fprintf(file_out_txt,"\n");
-  	fprintf(file_out_txt, "%d strategy of generating rules\n", strgy);
-  	if (r>0)
-  	{   fprintf(file_out_txt,"Rules ( %i )\n", r );
-     	fPrintRules( file_out_txt, rules, r, opr, P, Q, attributes ); /*print to file generated rules*/
-     	fprintf(file_out_txt,"Mean number of attributes in rule = %.1f\n",MeanAttrInRule( rules, r, P ));
+    int i;
+    fprintf(file_out_txt, "Condition attributes are\n");
+    fPrintSetA(file_out_txt, P);
+    fprintf(file_out_txt, "\nDecision attributes are\n");
+    fPrintSetA(file_out_txt, Q);
+    fprintf(file_out_txt, "\nDependCoef = %f\n", DependCoef(P, Q, MATD));	/* Returns degree of dependency Q from P in the active information system. */
+    fprintf(file_out_txt, "CORE = ");
+    fPrintSetA(file_out_txt, core);
+    fprintf(file_out_txt, "\nRedOptim = ");
+    fprintf(file_out_txt, "\nFew reducts ( %i ):\n", n);
+    for (i = 0; i < n; i++) {
+	fPrintSetA(file_out_txt, beg + i * sys1->setAsize);
+	fprintf(file_out_txt, "\n");
+    fprintf(file_out_txt, "%d strategy of generating rules\n", strgy);
+    if (r > 0) {
+	fprintf(file_out_txt, "Rules ( %i )\n", r);
+	fPrintRules(file_out_txt, rules, r, opr, P, Q, attributes);	/*print to file generated rules */
+	fprintf(file_out_txt, "Mean number of attributes in rule = %.1f\n",
+		MeanAttrInRule(rules, r, P));
-void fPrintSetA( FILE *f, setA set )
-{  int attr;
-   fprintf(f,"{");
-      {  fprintf(f," %d",attr);
-	 attr++;
-	 break;
-   for (; attr<_mainsys->attributes_num ;attr++)
-      if (ContSetA(set,attr)) fprintf(f,",%d",attr);
-   fprintf(f," }");
+void fPrintSetA(FILE * f, setA set)
+    int attr;
+    fprintf(f, "{");
+	if (ContSetA(set, attr)) {
+	    fprintf(f, " %d", attr);
+	    attr++;
+	    break;
+    for (; attr < _mainsys->attributes_num; attr++)
+	    fprintf(f, ",%d", attr);
+    fprintf(f, " }");
-void fPrintSetO( FILE *f, setO set )
-{  int obj;
-   fprintf(f,"{");
-      {  fprintf(f," %d",obj);
-	 obj++;
-	 break;
-   for (; obj<_mainsys->objects_num ;obj++)
-      if (ContSetO(set,obj)) fprintf(f,",%d",obj);
-   fprintf(f," }");
+void fPrintSetO(FILE * f, setO set)
+    int obj;
+    fprintf(f, "{");
+	    fprintf(f, " %d", obj);
+	    obj++;
+	    break;
+    for (; obj < _mainsys->objects_num; obj++)
+	    fprintf(f, ",%d", obj);
+    fprintf(f, " }");
-		 int N, int *opr, setA P, setA Q, struct input *attributes  )
-{  int n,j;
-   for (n=0;n<N;n++)
-   {  for (j=0;j<_mainsys->attributes_num;j++)
-	 if ( ContSetA( P,j ) )
-	   if (rules[n*_mainsys->attributes_num+j]!=MINUS)
-	       fprintf(file,"%s=%d  ", attributes[j].name,rules[n*_mainsys->attributes_num+j]);
-      fprintf(file," => ");
-      for (j=0;j<_mainsys->attributes_num;j++)
-	 if ( ContSetA( Q, j ) )
-	   if ((rules+n*_mainsys->attributes_num)[j]!=MINUS)
-	     fprintf(file,"%s=%d  ", attributes[j].name,(rules+n*_mainsys->attributes_num)[j]);
-      fprintf(file," ( %i objects )\n", opr[n] );
-   return;
+		 int N, int *opr, setA P, setA Q, struct input *attributes)
+    int n, j;
+    for (n = 0; n < N; n++) {
+	    if (ContSetA(P, j))
+		if (rules[n * _mainsys->attributes_num + j] != MINUS)
+		    fprintf(file, "%s=%d  ", attributes[j].name,
+			    rules[n * _mainsys->attributes_num + j]);
+	fprintf(file, " => ");
+	    if (ContSetA(Q, j))
+		if ((rules + n * _mainsys->attributes_num)[j] != MINUS)
+			    (rules + n * _mainsys->attributes_num)[j]);
+	fprintf(file, " ( %i objects )\n", opr[n]);
+    return;
-{  int counter=0;
-   int i,j;
-   for (i=0; i<N; i++)
-      for (j=0; j<size; j++)
-	 if ( ContSetA( P, j ) )
-	    if ( (rules+i*size)[j]!=MINUS ) counter++;
-   return (float)counter/N;
+    int counter = 0;
+    int i, j;
+    for (i = 0; i < N; i++)
+	for (j = 0; j < size; j++)
+		if ((rules + i * size)[j] != MINUS)
+		    counter++;
+    return (float)counter / N;
-   return ApprRules( rules, P, Q, LOWER, mat );
+    return ApprRules(rules, P, Q, LOWER, mat);
-  return ApprRules( rules, P, Q, UPPER, mat );
+    return ApprRules(rules, P, Q, UPPER, mat);
-  return ApprRules( rules, P, Q, NORMAL, mat );
+    return ApprRules(rules, P, Q, NORMAL, mat);
 /* dom 07 dic 2008 07:04:58 CET */
