[GRASS-SVN] r41685 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Apr 3 07:15:56 EDT 2010
Author: martinl
Date: 2010-04-03 07:15:55 -0400 (Sat, 03 Apr 2010)
New Revision: 41685
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI:use floatspin
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-03 09:29:09 UTC (rev 41684)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-03 11:15:55 UTC (rev 41685)
@@ -75,6 +75,11 @@
from wx.lib.newevent import NewEvent
try:
+ import wx.lib.agw.floatspin as FS
+except ImportError:
+ FS = None
+try:
import xml.etree.ElementTree as etree
except ImportError:
import elementtree.ElementTree as etree # Python <= 2.4
@@ -1252,7 +1257,7 @@
title_txt.SetLabel("%s. %s %s" % (title, _('Valid range'),
str(valuelist[0]) + ':'))
- if p.get('type','') == 'integer' and \
+ if p.get('type', '') == 'integer' and \
p.get('multiple','no') == 'no':
# for multiple integers use textctrl instead of spinsctrl
@@ -1304,7 +1309,7 @@
title_txt.SetLabel(title + ':' )
if p.get('multiple','yes') == 'yes' or \
- p.get('type', 'string') in ('string', 'float') or \
+ p.get('type', 'string') == 'string' or \
len(p.get('key_desc', [])) > 1:
txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''))
@@ -1316,15 +1321,35 @@
else:
minValue = -1e9
maxValue = 1e9
- txt3 = wx.SpinCtrl(parent=which_panel, value=p.get('default',''),
- size=globalvar.DIALOG_SPIN_SIZE,
- min=minValue, max=maxValue)
- if p.get('value','') != '':
- txt3.SetValue(int(p['value'])) # parameter previously set
- txt3.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
- txt3.Bind(wx.EVT_TEXT, self.OnSetValue)
- style = wx.BOTTOM | wx.LEFT | wx.RIGHT
+ if p.get('type', '') == 'integer':
+ txt3 = wx.SpinCtrl(parent=which_panel, value=p.get('default',''),
+ size=globalvar.DIALOG_SPIN_SIZE,
+ min=minValue, max=maxValue)
+ style = wx.BOTTOM | wx.LEFT | wx.RIGHT
+ if p.get('value', '') != '':
+ txt3.SetValue(int(p['value'])) # parameter previously set
+ txt3.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
+ elif FS:
+ txt3 = FS.FloatSpin(parent = which_panel, id = wx.ID_ANY,
+ size = globalvar.DIALOG_SPIN_SIZE,
+ min_val = minValue, max_val = maxValue)
+ txt3.SetDigits(3)
+ txt3.SetValue(float(p['value'])) # parameter previously set
+ txt3.Bind(FS.EVT_FLOATSPIN, self.OnSetValue)
+ else:
+ txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''))
+ style = wx.EXPAND | wx.BOTTOM | wx.LEFT | wx.RIGHT
+ txt3.SetValue(str(p['value'])) # parameter previously set
+ # txt3.Bind(wx.EVT_TEXT, self.OnSetValue)
which_sizer.Add(item=txt3, proportion=0,
flag=style, border=5)
