[GRASS-SVN] r41711 - grass/branches/develbranch_6/raster/r.sunmask
svn_grass at osgeo.org
Sun Apr 4 09:20:27 EDT 2010
Author: martinl
Date: 2010-04-04 09:20:27 -0400 (Sun, 04 Apr 2010)
New Revision: 41711
grass/branches/develbranch_6/raster/r.sunmask/main.c
r.sunmask: not A/B input options
(merge r41709 from trunk)
Modified: grass/branches/develbranch_6/raster/r.sunmask/main.c
--- grass/branches/develbranch_6/raster/r.sunmask/main.c 2010-04-04 13:17:22 UTC (rev 41710)
+++ grass/branches/develbranch_6/raster/r.sunmask/main.c 2010-04-04 13:20:27 UTC (rev 41711)
@@ -124,8 +124,8 @@
module = G_define_module();
module->keywords = _("raster");
module->label = _("Calculates cast shadow areas from sun position and elevation raster map.");
- module->description = _("Either exact sun position is specified, or date/time to calculate "
- "the sun position by r.sunmask itself.");
+ module->description = _("Either exact sun position (A) is specified, or date/time to calculate "
+ "the sun position (B) by r.sunmask itself.");
parm.opt1 = G_define_standard_option(G_OPT_R_ELEV);
parm.opt1->key = "elev";
@@ -138,7 +138,7 @@
parm.opt3->required = NO;
parm.opt3->options = "0-89.999";
parm.opt3->description =
- _("Altitude of the sun above horizon, degrees");
+ _("Altitude of the sun above horizon, degrees (A)");
parm.opt3->guisection = _("Position");
parm.opt4 = G_define_option();
@@ -147,14 +147,14 @@
parm.opt4->required = NO;
parm.opt4->options = "0-360";
parm.opt4->description =
- _("Azimuth of the sun from the north, degrees");
+ _("Azimuth of the sun from the north, degrees (A)");
parm.opt4->guisection = _("Position");
parm.year = G_define_option();
parm.year->key = "year";
parm.year->type = TYPE_INTEGER;
parm.year->required = NO;
- parm.year->description = _("Year");
+ parm.year->description = _("Year (B)");
parm.year->options = "1950-2050";
parm.year->guisection = _("Time");
@@ -162,7 +162,7 @@
parm.month->key = "month";
parm.month->type = TYPE_INTEGER;
parm.month->required = NO;
- parm.month->description = _("Month");
+ parm.month->description = _("Month (B)");
parm.month->options = "0-12";
parm.month->guisection = _("Time");
@@ -170,7 +170,7 @@
parm.day->key = "day";
parm.day->type = TYPE_INTEGER;
parm.day->required = NO;
- parm.day->description = _("Day");
+ parm.day->description = _("Day (B)");
parm.day->options = "0-31";
parm.day->guisection = _("Time");
@@ -178,7 +178,7 @@
parm.hour->key = "hour";
parm.hour->type = TYPE_INTEGER;
parm.hour->required = NO;
- parm.hour->description = _("Hour");
+ parm.hour->description = _("Hour (B)");
parm.hour->options = "0-24";
parm.hour->guisection = _("Time");
@@ -186,7 +186,7 @@
parm.minutes->key = "minute";
parm.minutes->type = TYPE_INTEGER;
parm.minutes->required = NO;
- parm.minutes->description = _("Minutes");
+ parm.minutes->description = _("Minutes (B)");
parm.minutes->options = "0-60";
parm.minutes->guisection = _("Time");
@@ -194,7 +194,7 @@
parm.seconds->key = "second";
parm.seconds->type = TYPE_INTEGER;
parm.seconds->required = NO;
- parm.seconds->description = _("Seconds");
+ parm.seconds->description = _("Seconds (B)");
parm.seconds->options = "0-60";
parm.seconds->guisection = _("Time");
