[GRASS-SVN] r41712 - in grass/branches/develbranch_6/raster:
r.basins.fill r.carve r.fill.dir r.flow r.lake r.terraflow
r.topidx r.topmodel r.water.outlet r.watershed/front
simwe/r.sim.sediment simwe/r.sim.water
svn_grass at osgeo.org
Sun Apr 4 10:41:34 EDT 2010
Author: martinl
Date: 2010-04-04 10:41:33 -0400 (Sun, 04 Apr 2010)
New Revision: 41712
grass/branches/develbranch_6/raster/r.basins.fill/main.c
grass/branches/develbranch_6/raster/r.carve/main.c
grass/branches/develbranch_6/raster/r.fill.dir/main.c
grass/branches/develbranch_6/raster/r.flow/calc.c
grass/branches/develbranch_6/raster/r.lake/main.c
grass/branches/develbranch_6/raster/r.terraflow/main.cc
grass/branches/develbranch_6/raster/r.topidx/main.c
grass/branches/develbranch_6/raster/r.topmodel/main.c
grass/branches/develbranch_6/raster/r.water.outlet/main.c
grass/branches/develbranch_6/raster/r.watershed/front/main.c
grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
various minor changes in hydrologic modules
(merge r41705 from trunk)
Modified: grass/branches/develbranch_6/raster/r.basins.fill/main.c
--- grass/branches/develbranch_6/raster/r.basins.fill/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.basins.fill/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -8,7 +8,7 @@
* PURPOSE: Generates a raster map layer showing watershed subbasins.
- * COPYRIGHT: (C) 2005 by the GRASS Development Team
+ * COPYRIGHT: (C) 2005, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -50,38 +50,27 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, hydrology");
module->description =
- _("Generates a raster map layer showing " "watershed subbasins.");
- opt1 = G_define_option();
- opt1->key = "number";
- opt1->type = TYPE_INTEGER;
- opt1->required = YES;
- opt1->description = _("Number of passes through the dataset");
- opt1->gisprompt = "old,cell,raster";
- opt2 = G_define_option();
+ _("Generates watershed subbasins raster map.");
+ opt2 = G_define_standard_option(G_OPT_R_INPUT);
opt2->key = "c_map";
- opt2->type = TYPE_STRING;
- opt2->required = YES;
- opt2->description = _("Coded stream network file name");
- opt2->gisprompt = "old,cell,raster";
+ opt2->description = _("Name of input coded stream network raster map");
- opt3 = G_define_option();
+ opt3 = G_define_standard_option(G_OPT_R_INPUT);
opt3->key = "t_map";
- opt3->type = TYPE_STRING;
- opt3->required = YES;
- opt3->description = _("Thinned ridge network file name");
- opt3->gisprompt = "old,cell,raster";
+ opt3->description = _("Name of input thinned ridge network raster map");
- opt4 = G_define_option();
+ opt4 = G_define_standard_option(G_OPT_R_OUTPUT);
opt4->key = "result";
- opt4->type = TYPE_STRING;
- opt4->required = YES;
- opt4->description = _("Name for the resultant watershed partition file");
- opt4->gisprompt = "new,cell,raster";
+ opt1 = G_define_option();
+ opt1->key = "number";
+ opt1->type = TYPE_INTEGER;
+ opt1->required = YES;
+ opt1->description = _("Number of passes through the dataset");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/branches/develbranch_6/raster/r.carve/main.c
--- grass/branches/develbranch_6/raster/r.carve/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.carve/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -9,7 +9,7 @@
* PURPOSE: Takes vector stream data, converts it to 3D raster and
* subtracts a specified depth
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006, 2010 by the GRASS Development Team
@@ -74,7 +74,8 @@
G_gisinit(argv[0]);
+ module->label = _("Generates stream channels.");
module->description = _("Takes vector stream data, transforms it "
"to raster and subtracts depth from the output DEM.");
@@ -85,7 +86,7 @@
parm.invect = G_define_standard_option(G_OPT_V_INPUT);
parm.invect->key = "vect";
parm.invect->description =
- _("Name of vector input map containing stream(s)");
+ _("Name of input vector map containing stream(s)");
parm.outrast = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -98,8 +99,8 @@
width = G_define_option();
width->key = "width";
width->type = TYPE_DOUBLE;
- width->description = _("Stream width (in meters). "
- "Default is raster cell width");
+ width->label = _("Stream width (in meters)");
+ width->description = _("Default is raster cell width");
depth = G_define_option();
depth->key = "depth";
Modified: grass/branches/develbranch_6/raster/r.fill.dir/main.c
--- grass/branches/develbranch_6/raster/r.fill.dir/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.fill.dir/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -26,7 +26,7 @@
* program can be run repeatedly, using the output elevations from
* one run as input to the next run until all problems are
* resolved.
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001, 2010 by the GRASS Development Team
@@ -81,61 +81,46 @@
G_gisinit(argv[0]);
_("Filters and generates a depressionless elevation map and a flow "
- "direction map from a given elevation layer.");
+ "direction map from a given elevation raster map.");
opt1 = G_define_standard_option(G_OPT_R_INPUT);
- _("Name of existing raster map containing elevation surface");
+ opt1->description = _("Name of input elevation raster map");
+ opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
opt2->key = "elevation";
- opt2->gisprompt = "new,cell,raster";
- opt2->description = _("Output elevation raster map after filling");
+ opt2->description = _("Name for output elevation raster map after filling");
opt4->key = "direction";
- opt4->description = _("Output direction raster map");
+ opt4->description = _("Name for output direction raster map");
- opt5 = G_define_option();
+ opt5 = G_define_standard_option(G_OPT_R_OUTPUT);
opt5->key = "areas";
- opt5->type = TYPE_STRING;
opt5->required = NO;
- opt5->gisprompt = "new,cell,raster";
- opt5->description = _("Output raster map of problem areas");
+ opt5->description = _("Name for output raster map of problem areas");
opt3->key = "type";
opt3->required = NO;
opt3->description =
- _("Output aspect direction format (agnps, answers, or grass)");
+ _("Aspect direction format");
+ opt3->options = "agnps,answers,grass";
opt3->answer = "grass";
- /* TODO after feature freeze
- opt3->options = "agnps,answers,grass";
flag1 = G_define_flag();
flag1->key = 'f';
flag1->description = _("Find unresolved areas only");
- flag1->answer = '0';
exit(EXIT_FAILURE);
- if (flag1->answer != '0' && opt5->answer == NULL) {
- fprintf(stdout,
- "\nThe \"f\" flag requires that you name a file for the output area map\n");
- fprintf(stdout, "\tEnter the file name, or <Enter> to quit: ");
- scanf("%s", opt5->answer);
+ if (flag1->answer && opt5->answer == NULL) {
+ G_fatal_error(_("The '%c' flag requires '%s'to be specified"),
+ flag1->key, opt5->key);
type = 0;
@@ -147,30 +132,21 @@
if (strcmp(opt3->answer, "agnps") == 0)
type = 1;
- else if (strcmp(opt3->answer, "AGNPS") == 0)
- type = 1;
else if (strcmp(opt3->answer, "answers") == 0)
type = 2;
- else if (strcmp(opt3->answer, "ANSWERS") == 0)
- type = 2;
else if (strcmp(opt3->answer, "grass") == 0)
type = 3;
- else if (strcmp(opt3->answer, "GRASS") == 0)
- type = 3;
G_debug(1, "output type (1=AGNPS, 2=ANSWERS, 3=GRASS): %d", type);
- if (type == 0)
- G_fatal_error
- ("direction format must be either agnps, answers, or grass.");
if (type == 3)
- G_warning("Direction map is D8 resolution, i.e. 45 degrees.");
+ G_verbose_message(_("Direction map is D8 resolution, i.e. 45 degrees"));
/* get the name of the elevation map layer for filling */
map_mapset = G_find_cell(map_name, "");
if (!map_mapset)
G_fatal_error(_("Raster map <%s> not found"), map_name);
/* open the maps and get their file id */
map_id = G_open_cell_old(map_name, map_mapset);
@@ -209,13 +185,15 @@
fd = open(tempfile2, O_RDWR | O_CREAT, 0666); /* dirn */
fm = open(tempfile3, O_RDWR | O_CREAT, 0666); /* problems */
- G_message(_("Reading map..."));
+ G_message(_("Reading elevation map..."));
for (i = 0; i < nrows; i++) {
+ G_percent(i, nrows, 2);
get_row(map_id, in_buf, i);
write(fe, in_buf, bnd.sz);
+ G_percent(1, 1, 1);
G_close_cell(map_id);
/* fill single-cell holes and take a first stab at flow directions */
G_message(_("Filling sinks..."));
filldir(fe, fd, nrows, &bnd);
Modified: grass/branches/develbranch_6/raster/r.flow/calc.c
--- grass/branches/develbranch_6/raster/r.flow/calc.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.flow/calc.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -408,7 +408,8 @@
G_fatal_error(_("Unable to get current region"));
- module->keywords = "raster";
+ module->keywords = "raster, hydrology";
+ module->label = _("Constructs flow lines.");
_("Construction of slope curves (flowlines), flowpath lengths, "
"and flowline densities (upslope areas) from a raster "
@@ -443,26 +444,18 @@
sprintf(offset_opt, "0.0-500.0");
#endif
- pelevin = G_define_option();
+ pelevin = G_define_standard_option(G_OPT_R_ELEV);
pelevin->key = "elevin";
- pelevin->type = TYPE_STRING;
- pelevin->required = YES;
- pelevin->gisprompt = "old,cell,raster";
- pelevin->description = _("Input elevation raster map");
- paspin = G_define_option();
+ paspin = G_define_standard_option(G_OPT_R_INPUT);
paspin->key = "aspin";
- paspin->type = TYPE_STRING;
paspin->required = NO;
- paspin->gisprompt = "old,cell,raster";
- paspin->description = _("Input aspect raster map");
+ paspin->description = _("Name of input aspect raster map");
- pbarin = G_define_option();
+ pbarin = G_define_standard_option(G_OPT_R_INPUT);
pbarin->key = "barin";
- pbarin->type = TYPE_STRING;
pbarin->required = NO;
- pbarin->gisprompt = "old,cell,raster";
- pbarin->description = _("Input barrier raster map");
+ pbarin->description = _("Name of input barrier raster map");
pskip = G_define_option();
pskip->key = "skip";
@@ -480,26 +473,20 @@
pbound->description = _("Maximum number of segments per flowline");
pbound->answer = default_bound_ans + 2;
- pflout = G_define_option();
+ pflout = G_define_standard_option(G_OPT_V_OUTPUT);
pflout->key = "flout";
- pflout->type = TYPE_STRING;
pflout->required = NO;
- pflout->gisprompt = "any,dig,vector";
- pflout->description = _("Output flowline vector map");
+ pflout->description = _("Name for output flowline vector map");
- plgout = G_define_option();
+ plgout = G_define_standard_option(G_OPT_R_OUTPUT);
plgout->key = "lgout";
- plgout->type = TYPE_STRING;
plgout->required = NO;
- plgout->gisprompt = "any,cell,raster";
- plgout->description = _("Output flowpath length raster map");
+ plgout->description = _("Name for flowpath length raster map");
- pdsout = G_define_option();
+ pdsout = G_define_standard_option(G_OPT_R_OUTPUT);
pdsout->key = "dsout";
- pdsout->type = TYPE_STRING;
pdsout->required = NO;
- pdsout->gisprompt = "any,cell,raster";
- pdsout->description = _("Output flowline density raster map");
+ pdsout->description = _("Name for output flowline density raster map");
fup = G_define_flag();
fup->key = 'u';
@@ -508,7 +495,7 @@
flg = G_define_flag();
flg->key = '3';
- flg->description = _("3-D lengths instead of 2-D");
+ flg->description = _("3D lengths instead of 2D");
fmem = G_define_flag();
fmem->key = 'm';
Modified: grass/branches/develbranch_6/raster/r.lake/main.c
--- grass/branches/develbranch_6/raster/r.lake/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.lake/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -10,7 +10,7 @@
* As seed You can use already existing map or
* X,Y coordinates.
- * COPYRIGHT: (C) 2005-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2005-2008, 2010 by the GRASS Development Team
@@ -145,29 +145,20 @@
struct History history;
module->description = _("Fills lake from seed at given level.");
- tmap_opt = G_define_option();
+ tmap_opt = G_define_standard_option(G_OPT_R_ELEV);
tmap_opt->key = "dem";
- tmap_opt->key_desc = "name";
- tmap_opt->description = _("Name of terrain raster map (DEM)");
- tmap_opt->type = TYPE_STRING;
- tmap_opt->gisprompt = "old,cell,raster";
- tmap_opt->required = YES;
wlvl_opt = G_define_option();
wlvl_opt->key = "wl";
wlvl_opt->description = _("Water level");
wlvl_opt->type = TYPE_DOUBLE;
wlvl_opt->required = YES;
- lake_opt = G_define_option();
+ lake_opt = G_define_standard_option(G_OPT_R_OUTPUT);
lake_opt->key = "lake";
- lake_opt->key_desc = "name";
- lake_opt->description = _("Name for output raster map with lake");
- lake_opt->type = TYPE_STRING;
- lake_opt->gisprompt = "new,cell,raster";
lake_opt->required = NO;
sdxy_opt = G_define_option();
@@ -178,13 +169,10 @@
sdxy_opt->required = NO;
sdxy_opt->multiple = NO;
- smap_opt = G_define_option();
+ smap_opt = G_define_standard_option(G_OPT_R_INPUT);
smap_opt->key = "seed";
- smap_opt->key_desc = "name";
smap_opt->description =
- _("Name of raster map with seed (at least 1 cell > 0)");
- smap_opt->type = TYPE_STRING;
- smap_opt->gisprompt = "old,cell,raster";
+ _("Name of input raster map with seed (at least 1 cell > 0)");
smap_opt->required = NO;
negative_flag = G_define_flag();
Modified: grass/branches/develbranch_6/raster/r.terraflow/main.cc
--- grass/branches/develbranch_6/raster/r.terraflow/main.cc 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.terraflow/main.cc 2010-04-04 14:41:33 UTC (rev 41712)
@@ -2,7 +2,7 @@
* MODULE: r.terraflow
- * COPYRIGHT (C) 2007 Laura Toma
+ * COPYRIGHT (C) 2007, 2010 Laura Toma
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
@@ -70,32 +70,32 @@
struct Option *output_elev;
output_elev = G_define_standard_option(G_OPT_R_OUTPUT);
output_elev->key = "filled";
- output_elev->description= _("Output filled (flooded) elevation raster map");
+ output_elev->description= _("Name for output filled (flooded) elevation raster map");
/* output direction grid */
struct Option *output_dir;
output_dir = G_define_standard_option(G_OPT_R_OUTPUT);
output_dir->key = "direction";
- output_dir->description= _("Output flow direction raster map");
+ output_dir->description= _("Name for output flow direction raster map");
/* output sinkwatershed grid */
struct Option *output_watershed;
output_watershed = G_define_standard_option(G_OPT_R_OUTPUT);
output_watershed->key = "swatershed";
- output_watershed->description= _("Output sink-watershed raster map");
+ output_watershed->description= _("Name for output sink-watershed raster map");
/* output flow accumulation grid */
struct Option *output_accu;
output_accu = G_define_standard_option(G_OPT_R_OUTPUT);
output_accu->key = "accumulation";
- output_accu->description= _("Output flow accumulation raster map");
+ output_accu->description= _("Name for output flow accumulation raster map");
#ifdef OUTPUT_TCI
struct Option *output_tci;
output_tci = G_define_standard_option(G_OPT_R_OUTPUT);
output_tci->key = "tci";
output_tci->description=
- _("Output topographic convergence index (tci) raster map");
+ _("Name for output topographic convergence index (tci) raster map");
#endif
/* MFD/SFD flag */
@@ -103,7 +103,6 @@
sfd_flag = G_define_flag() ;
sfd_flag->key = 's';
sfd_flag->description= _("SFD (D8) flow (default is MFD)");
- /* sfd_flag->answer = 'n'; */
/* D8CUT value*/
struct Option *d8cut;
@@ -112,9 +111,10 @@
d8cut->type = TYPE_DOUBLE;
d8cut->required = NO;
d8cut->answer = G_store("infinity"); /* default value */
- d8cut->description =
+ d8cut->label = _("Routing using SFD (D8) direction");
+ d8cut->description =
_("If flow accumulation is larger than this value it is routed using "
- "SFD (D8) direction \n \t\t (meaningfull only for MFD flow)");
+ "SFD (D8) direction (meaningfull only for MFD flow)");
/* main memory */
struct Option *mem;
@@ -469,12 +469,12 @@
#ifdef ELEV_SHORT
- module->description = _("Flow computation for massive grids (Integer version).");
+ module->description = _("Flow computation for massive grids (integer version).");
#endif
#ifdef ELEV_FLOAT
- module->description = _("Flow computation for massive grids (Float version).");
+ module->description = _("Flow computation for massive grids (float version).");
#endif
/* read user options; fill in global <opt> */
opt = (userOptions*)malloc(sizeof(userOptions));
Modified: grass/branches/develbranch_6/raster/r.topidx/main.c
--- grass/branches/develbranch_6/raster/r.topidx/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.topidx/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -10,7 +10,7 @@
* PURPOSE: Creates topographic index map from elevation map.
* Based on GRIDATB.FOR.
- * COPYRIGHT: (C) 2000-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2010 by the GRASS Development Team
@@ -34,17 +34,14 @@
G_gisinit(argv[0]);
- _("Creates topographic index [ln(a/tan(beta))] map from elevation map.");
+ _("Creates topographic index map from elevation raster map.");
params.input = G_define_standard_option(G_OPT_R_INPUT);
- params.input->description = _("Input elevation map");
params.output = G_define_standard_option(G_OPT_R_OUTPUT);
- params.output->key = "output";
- params.output->description = _("Output topographic index map");
exit(EXIT_FAILURE);
Modified: grass/branches/develbranch_6/raster/r.topmodel/main.c
--- grass/branches/develbranch_6/raster/r.topmodel/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.topmodel/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -4,7 +4,7 @@
* TMOD9502.FOR Author: Keith Beven <k.beven at lancaster.ac.uk>
* http://www.es.lancs.ac.uk/hfdg/topmodel.html
- * Copyright (C) 2000 by the GRASS Development Team
+ * Copyright (C) 2000, 2010 by the GRASS Development Team
* Author: Huidae Cho <grass4u at gmail.com>
* Hydro Laboratory, Kyungpook National University
* South Korea
@@ -52,111 +52,98 @@
G_gisinit(argv[0]);
_("Simulates TOPMODEL which is a physically based hydrologic model.");
/* Parameter definitions */
- param.basin = G_define_option();
+ param.basin = G_define_standard_option(G_OPT_R_INPUT);
param.basin->key = "basin";
- param.basin->description =
- _("(i) Basin map created by r.water.outlet (MASK)");
- param.basin->type = TYPE_STRING;
+ param.basin->label =
+ _("Name of input basin raster map");
+ param.basin->description = _("Created by r.water.outlet (MASK)");
param.basin->required = NO;
- param.basin->gisprompt = "old,cell,raster";
+ param.basin->guisection = _("Input");
- param.elev = G_define_option();
- param.elev->key = "elevation";
- param.elev->description = _("(i) Elevation map");
- param.elev->type = TYPE_STRING;
+ param.elev = G_define_standard_option(G_OPT_R_ELEV);
param.elev->required = NO;
- param.elev->gisprompt = "old,cell,raster";
+ param.elev->guisection = _("Input");
- param.fill = G_define_option();
+ param.fill = G_define_standard_option(G_OPT_R_OUTPUT);
param.fill->key = "depressionless";
- param.fill->description = _("(o) Depressionless elevation map");
- param.fill->type = TYPE_STRING;
+ param.fill->description = _("Name for output depressionless elevation raster map");
param.fill->required = NO;
- param.fill->gisprompt = "new,cell,raster";
+ param.fill->guisection = _("Output");
- param.dir = G_define_option();
+ param.dir = G_define_standard_option(G_OPT_R_OUTPUT);
param.dir->key = "direction";
param.dir->description =
- _("(o) Direction map for depressionless elevation map");
- param.dir->type = TYPE_STRING;
+ _("Name for output direction map for depressionless elevation raster map");
param.dir->required = NO;
- param.dir->gisprompt = "new,cell,raster";
+ param.dir->guisection = _("Output");
- param.belev = G_define_option();
+ param.belev = G_define_standard_option(G_OPT_R_OUTPUT);
param.belev->key = "belevation";
- param.belev->description = _("(o/i) Basin elevation map (MASK applied)");
- param.belev->type = TYPE_STRING;
+ param.belev->label = _("Name for output basin elevation raster map (o/i)");
+ param.belev->description = _("MASK applied");
param.belev->required = NO;
- param.belev->gisprompt = "new,cell,raster";
+ param.belev->guisection = _("Output");
- param.topidx = G_define_option();
+ param.topidx = G_define_standard_option(G_OPT_R_OUTPUT);
param.topidx->key = "topidx";
- param.topidx->description =
- _("(o) Topographic index ln(a/tanB) map (MASK applied)");
- param.topidx->type = TYPE_STRING;
+ param.topidx->label =
+ _("Name for output opographic index ln(a/tanB) raster map");
+ param.topidx->description = _("MASK applied");
param.topidx->required = NO;
- param.topidx->gisprompt = "new,cell,raster";
+ param.topidx->guisection = _("Output");
param.nidxclass = G_define_option();
param.nidxclass->key = "nidxclass";
param.nidxclass->description =
- _("(i) Number of topographic index classes");
+ _("Number of topographic index classes");
param.nidxclass->type = TYPE_INTEGER;
param.nidxclass->required = NO;
param.nidxclass->answer = "30";
- param.idxstats = G_define_option();
+ param.nidxclass->guisection = _("Parameters");
+ param.idxstats = G_define_standard_option(G_OPT_F_INPUT);
param.idxstats->key = "idxstats";
param.idxstats->description =
- _("(o/i) Topographic index statistics file");
- param.idxstats->type = TYPE_STRING;
- param.idxstats->required = YES;
- param.params = G_define_option();
+ _("Name of topographic index statistics file (o/i)");
+ param.params = G_define_standard_option(G_OPT_F_INPUT);
param.params->key = "parameters";
- param.params->description = _("(i) TOPMODEL Parameters file");
- param.params->type = TYPE_STRING;
- param.params->required = YES;
- param.input = G_define_option();
- param.input->key = "input";
+ param.params->description = _("Name of TOPMODEL parameters file");
+ param.input = G_define_standard_option(G_OPT_F_INPUT);
param.input->description =
- _("(i) Rainfall and potential evapotranspiration data file");
- param.input->type = TYPE_STRING;
- param.input->required = YES;
+ _("Name of rainfall and potential evapotranspiration data file");
- param.output = G_define_option();
- param.output->key = "output";
- param.output->description = _("(o) Output file");
- param.output->type = TYPE_STRING;
- param.output->required = YES;
+ param.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ param.output->description = _("Name for output file");
- param.Qobs = G_define_option();
+ param.Qobs = G_define_standard_option(G_OPT_F_OUTPUT);
param.Qobs->key = "Qobs";
- param.Qobs->description = _("(i) OPTIONAL Observed flow file");
- param.Qobs->type = TYPE_STRING;
+ param.Qobs->description = _("Name for observed flow file");
param.Qobs->required = NO;
+ param.Qobs->guisection = _("Output");
param.timestep = G_define_option();
param.timestep->key = "timestep";
param.timestep->description =
- _("(i) OPTIONAL Output for given time step");
+ _("Time step");
param.timestep->type = TYPE_INTEGER;
param.timestep->required = NO;
+ param.timestep->guisection = _("Parameters");
param.idxclass = G_define_option();
param.idxclass->key = "idxclass";
param.idxclass->description =
- _("(i) OPTIONAL Output for given topographic index class");
+ _("Topographic index class");
param.idxclass->type = TYPE_INTEGER;
param.idxclass->required = NO;
+ param.idxclass->guisection = _("Parameters");
/* Flag definitions */
flag.input = G_define_flag();
flag.input->key = 'i';
Modified: grass/branches/develbranch_6/raster/r.water.outlet/main.c
--- grass/branches/develbranch_6/raster/r.water.outlet/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.water.outlet/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -13,7 +13,7 @@
* PURPOSE: this program makes a watershed basin raster map using the
* drainage pointer map, from an outlet point defined by an
* easting and a northing.
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2010 by the GRASS Development Team
@@ -44,30 +44,22 @@
G_gisinit(argv[0]);
- module->description = _("Watershed basin creation program.");
+ module->description = _("Creates watershed basins.");
+ opt1 = G_define_standard_option(G_OPT_R_INPUT);
opt1->key = "drainage";
- opt1->type = TYPE_STRING;
- opt1->description = _("Name of input raster map");
opt2->key = "basin";
- opt2->description = _("Name of raster map to contain results");
opt3->key = "easting";
opt3->key_desc = "x";
opt3->multiple = NO;
- opt3->description = _("The map E grid coordinates");
+ opt3->description = _("Easting grid coordinates");
opt4->key = "northing";
@@ -75,7 +67,7 @@
opt4->key_desc = "y";
opt4->multiple = NO;
- opt4->description = _("The map N grid coordinates");
+ opt4->description = _("Northing grid coordinates");
/* Parse command line */
Modified: grass/branches/develbranch_6/raster/r.watershed/front/main.c
--- grass/branches/develbranch_6/raster/r.watershed/front/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/r.watershed/front/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -53,136 +53,115 @@
/* Set description */
- module->description = _("Watershed basin analysis program.");
opt1 = G_define_standard_option(G_OPT_R_ELEV);
- _("Input map: elevation on which entire analysis is based");
opt1->guisection = _("Input_options");
opt2->key = "depression";
- opt2->label = _("Input map: locations of real depressions");
+ opt2->label = _("Name of input depressions raster map");
opt2->description = _("All non-NULL and non-zero cells are considered as real depressions");
opt2->required = NO;
opt2->guisection = _("Input_options");
opt3->key = "flow";
- opt3->description = _("Input map: amount of overland flow per cell");
+ opt3->description = _("Name of input raster representing amount of overland flow per cell");
opt3->guisection = _("Input_options");
+ opt4 = G_define_standard_option(G_OPT_R_INPUT);
opt4->key = "disturbed.land";
- _("Input map or value: percent of disturbed land, for USLE");
+ opt4->label =
+ _("Name of input raster map percent of disturbed land");
+ opt4->description = _("For USLE");
opt4->required = NO;
- opt4->gisprompt = "old,cell,raster";
opt4->guisection = _("Input_options");
+ opt5 = G_define_standard_option(G_OPT_R_INPUT);
opt5->key = "blocking";
opt5->label =
- _("Input map: terrain blocking overland surface flow, for USLE");
+ _("Name of input raster map blocking overland surface flow");
opt5->description =
- _("All non-NULL and non-zero cells are considered as blocking terrain");
+ _("For USLE. All non-NULL and non-zero cells are considered as blocking terrain.");
- opt5->gisprompt = "old,cell,raster";
opt5->guisection = _("Input_options");
- opt6 = G_define_option();
- opt6->key = "threshold";
- opt6->description =
- _("Input value: minimum size of exterior watershed basin");
- opt6->required = NO;
- opt6->type = TYPE_INTEGER;
- opt6->guisection = _("Input_options");
- opt7 = G_define_option();
- opt7->key = "max.slope.length";
- opt7->description =
- _("Input value: maximum length of surface flow in map units, for USLE");
- opt7->required = NO;
- opt7->type = TYPE_DOUBLE;
- opt7->guisection = _("Input_options");
- opt8 = G_define_option();
+ opt8 = G_define_standard_option(G_OPT_R_OUTPUT);
opt8->key = "accumulation";
- opt8->description =
- _("Output map: number of cells that drain through each cell");
+ opt8->label = _("Name for output accumulation raster map");
+ opt8->description = _("Number of cells that drain through each cell");
opt8->required = NO;
- opt8->type = TYPE_STRING;
- opt8->gisprompt = "new,cell,raster";
opt8->guisection = _("Output_options");
- opt9 = G_define_option();
+ opt9 = G_define_standard_option(G_OPT_R_OUTPUT);
opt9->key = "drainage";
- opt9->description = _("Output map: drainage direction");
+ opt9->description = _("Name for output drainage direction raster map");
opt9->required = NO;
- opt9->type = TYPE_STRING;
- opt9->gisprompt = "new,cell,raster";
opt9->guisection = _("Output_options");
- opt10 = G_define_option();
+ opt10 = G_define_standard_option(G_OPT_R_OUTPUT);
opt10->key = "basin";
- opt10->description =
- _("Output map: unique label for each watershed basin");
+ opt10->label = _("Name for basins raster map");
+ opt10->description = _("Unique label for each watershed basin");
opt10->required = NO;
- opt10->type = TYPE_STRING;
- opt10->gisprompt = "new,cell,raster";
opt10->guisection = _("Output_options");
- opt11 = G_define_option();
+ opt11 = G_define_standard_option(G_OPT_R_OUTPUT);
opt11->key = "stream";
- opt11->description = _("Output map: stream segments");
+ opt11->description = _("Name for output stream segments raster map");
opt11->required = NO;
- opt11->type = TYPE_STRING;
- opt11->gisprompt = "new,cell,raster";
opt11->guisection = _("Output_options");
- opt12 = G_define_option();
+ opt12 = G_define_standard_option(G_OPT_R_OUTPUT);
opt12->key = "half.basin";
+ opt12->label = _("Name for output half basins raster map");
opt12->description =
- _("Output map: each half-basin is given a unique value");
+ _("Each half-basin is given a unique value");
opt12->required = NO;
- opt12->type = TYPE_STRING;
- opt12->gisprompt = "new,cell,raster";
opt12->guisection = _("Output_options");
- opt13 = G_define_option();
+ opt13 = G_define_standard_option(G_OPT_R_OUTPUT);
opt13->key = "visual";
opt13->description =
- _("Output map: useful for visual display of results. DEPRECATED.");
+ _("Name for output raster map useful for visual display of results (DEPRECATED)");
opt13->required = NO;
- opt13->type = TYPE_STRING;
- opt13->gisprompt = "new,cell,raster";
opt13->guisection = _("Output_options");
- opt14 = G_define_option();
+ opt14 = G_define_standard_option(G_OPT_R_OUTPUT);
opt14->key = "length.slope";
+ opt14->label = _("Name for output slope length raster map");
opt14->description =
- _("Output map: slope length and steepness (LS) factor for USLE");
+ _("Slope length and steepness (LS) factor for USLE");
opt14->required = NO;
- opt14->type = TYPE_STRING;
- opt14->gisprompt = "new,cell,raster";
opt14->guisection = _("Output_options");
- opt15 = G_define_option();
+ opt15 = G_define_standard_option(G_OPT_R_OUTPUT);
opt15->key = "slope.steepness";
- opt15->description = _("Output map: slope steepness (S) factor for USLE");
+ opt15->label = _("Name for output slope steepness raster map");
+ opt15->description = _("Slope steepness (S) factor for USLE");
opt15->required = NO;
- opt15->type = TYPE_STRING;
- opt15->gisprompt = "new,cell,raster";
opt15->guisection = _("Output_options");
+ opt6 = G_define_option();
+ opt6->key = "threshold";
+ opt6->description =
+ _("Minimum size of exterior watershed basin");
+ opt6->required = NO;
+ opt6->type = TYPE_INTEGER;
+ opt6->guisection = _("Input_options");
+ opt7 = G_define_option();
+ opt7->key = "max.slope.length";
+ opt7->label =
+ _("Maximum length of surface flow in map units");
+ opt7->description = _("For USLE");
+ opt7->required = NO;
+ opt7->type = TYPE_DOUBLE;
+ opt7->guisection = _("Input_options");
opt16 = G_define_option();
opt16->key = "convergence";
opt16->type = TYPE_INTEGER;
@@ -201,7 +180,7 @@
flag_mfd = G_define_flag();
flag_mfd->key = 'f';
- flag_mfd->label = _("enable MFD flow (default is SFD (D8))");
+ flag_mfd->label = _("Enable MFD flow (default is SFD (D8))");
flag_mfd->description =
_("SFD: single flow direction, MFD: multiple flow direction");
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -7,7 +7,7 @@
* AUTHOR(S): L. Mitas, H. Mitasova, J. Hofierka
* PURPOSE: Sediment transport simulation (SIMWE)
- * COPYRIGHT: (C) 2002 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002, 2010 by the GRASS Development Team
@@ -99,7 +99,7 @@
int main(int argc, char *argv[])
- int i, ii, j, l;
+ int i, j, l, ii;
int ret_val;
double x_orig, y_orig;
static int rand1 = 12345;
@@ -111,59 +111,51 @@
module->keywords = _("raster, sediment flow, erosion, deposition");
_("Sediment transport and erosion/deposition simulation "
- "using path sampling method (SIMWE)");
+ "using path sampling method (SIMWE).");
- parm.elevin = G_define_standard_option(G_OPT_R_INPUT);
+ parm.elevin = G_define_standard_option(G_OPT_R_ELEV);
parm.elevin->key = "elevin";
- parm.elevin->description = _("Name of the elevation raster map [m]");
- parm.elevin->guisection = _("Input_options");
parm.wdepth = G_define_standard_option(G_OPT_R_INPUT);
parm.wdepth->key = "wdepth";
- parm.wdepth->description = _("Name of the water depth raster map [m]");
- parm.wdepth->guisection = _("Input_options");
+ parm.wdepth->description = _("Name of water depth raster map [m]");
parm.dxin = G_define_standard_option(G_OPT_R_INPUT);
parm.dxin->key = "dxin";
- parm.dxin->description = _("Name of the x-derivatives raster map [m/m]");
- parm.dxin->guisection = _("Input_options");
+ parm.dxin->description = _("Name of x-derivatives raster map [m/m]");
parm.dyin = G_define_standard_option(G_OPT_R_INPUT);
parm.dyin->key = "dyin";
- parm.dyin->description = _("Name of the y-derivatives raster map [m/m]");
- parm.dyin->guisection = _("Input_options");
+ parm.dyin->description = _("Name of y-derivatives raster map [m/m]");
parm.detin = G_define_standard_option(G_OPT_R_INPUT);
parm.detin->key = "detin";
parm.detin->description =
- _("Name of the detachment capacity coefficient raster map [s/m]");
- parm.detin->guisection = _("Input_options");
+ _("Name of detachment capacity coefficient raster map [s/m]");
parm.tranin = G_define_standard_option(G_OPT_R_INPUT);
parm.tranin->key = "tranin";
parm.tranin->description =
- _("Name of the transport capacity coefficient raster map [s]");
- parm.tranin->guisection = _("Input_options");
+ _("Name of transport capacity coefficient raster map [s]");
parm.tauin = G_define_standard_option(G_OPT_R_INPUT);
parm.tauin->key = "tauin";
parm.tauin->description =
- _("Name of the critical shear stress raster map [Pa]");
- parm.tauin->guisection = _("Input_options");
+ _("Name of critical shear stress raster map [Pa]");
parm.manin = G_define_standard_option(G_OPT_R_INPUT);
parm.manin->key = "manin";
parm.manin->required = NO;
- parm.manin->description = _("Name of the Mannings n raster map");
- parm.manin->guisection = _("Input_options");
+ parm.manin->description = _("Name of mannings n raster map");
+ parm.manin->guisection = _("Input");
parm.maninval = G_define_option();
parm.maninval->key = "maninval";
parm.maninval->type = TYPE_DOUBLE;
parm.maninval->answer = MANINVAL;
parm.maninval->required = NO;
- parm.maninval->description = _("Name of the Mannings n value");
- parm.maninval->guisection = _("Input_options");
+ parm.maninval->description = _("Name of mannings n value");
+ parm.maninval->guisection = _("Input");
/* needs to be updated to GRASS 6 vector format !!
parm.sfile = G_define_standard_option(G_OPT_V_INPUT);
@@ -177,35 +169,35 @@
parm.tc = G_define_standard_option(G_OPT_R_OUTPUT);
parm.tc->key = "tc";
parm.tc->required = NO;
- parm.tc->description = _("Output transport capacity raster map [kg/ms]");
- parm.tc->guisection = _("Output_options");
+ parm.tc->description = _("Name for output transport capacity raster map [kg/ms]");
+ parm.tc->guisection = _("Output");
parm.et = G_define_standard_option(G_OPT_R_OUTPUT);
parm.et->key = "et";
parm.et->required = NO;
parm.et->description =
- _("Output transp.limited erosion-deposition raster map [kg/m2s]");
- parm.et->guisection = _("Output_options");
+ _("Name for output transp.limited erosion-deposition raster map [kg/m2s]");
+ parm.et->guisection = _("Output");
parm.conc = G_define_standard_option(G_OPT_R_OUTPUT);
parm.conc->key = "conc";
parm.conc->required = NO;
parm.conc->description =
- _("Output sediment concentration raster map [particle/m3]");
- parm.conc->guisection = _("Output_options");
+ _("Name for output sediment concentration raster map [particle/m3]");
+ parm.conc->guisection = _("Output");
parm.flux = G_define_standard_option(G_OPT_R_OUTPUT);
parm.flux->key = "flux";
parm.flux->required = NO;
- parm.flux->description = _("Output sediment flux raster map [kg/ms]");
- parm.flux->guisection = _("Output_options");
+ parm.flux->description = _("Name for output sediment flux raster map [kg/ms]");
+ parm.flux->guisection = _("Output");
parm.erdep = G_define_standard_option(G_OPT_R_OUTPUT);
parm.erdep->key = "erdep";
parm.erdep->required = NO;
parm.erdep->description =
- _("Output erosion-deposition raster map [kg/m2s]");
- parm.erdep->guisection = _("Output_options");
+ _("Name for output erosion-deposition raster map [kg/m2s]");
+ parm.erdep->guisection = _("Output");
parm.nwalk = G_define_option();
parm.nwalk->key = "nwalk";
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2010-04-04 13:20:27 UTC (rev 41711)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2010-04-04 14:41:33 UTC (rev 41712)
@@ -7,7 +7,7 @@
* PURPOSE: Hydrologic and sediment transport simulation (SIMWE)
@@ -106,7 +106,7 @@
- int i, ii, j, l;
+ int i, j, l, ii;
int ret_val;
@@ -118,30 +118,26 @@
module->keywords = _("raster, flow, hydrology");
_("Overland flow hydrologic simulation using "
- "path sampling method (SIMWE)");
+ "path sampling method (SIMWE).");
parm.rain = G_define_standard_option(G_OPT_R_INPUT);
parm.rain->key = "rain";
parm.rain->required = NO;
parm.rain->description =
- _("Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]");
- parm.rain->guisection = _("Input_options");
+ _("Name of rainfall excess rate (rain-infilt) raster map [mm/hr]");
+ parm.rain->guisection = _("Input");
parm.rainval = G_define_option();
parm.rainval->key = "rain_val";
parm.rainval->type = TYPE_DOUBLE;
@@ -149,14 +145,14 @@
parm.rainval->required = NO;
parm.rainval->description =
_("Rainfall excess rate unique value [mm/hr]");
- parm.rainval->guisection = _("Input_options");
+ parm.rainval->guisection = _("Input");
parm.infil = G_define_standard_option(G_OPT_R_INPUT);
parm.infil->key = "infil";
parm.infil->required = NO;
parm.infil->description =
- _("Name of the runoff infiltration rate raster map [mm/hr]");
- parm.infil->guisection = _("Input_options");
+ _("Name of runoff infiltration rate raster map [mm/hr]");
+ parm.infil->guisection = _("Input");
parm.infilval = G_define_option();
parm.infilval->key = "infil_val";
@@ -165,13 +161,13 @@
parm.infilval->required = NO;
parm.infilval->description =
_("Runoff infiltration rate unique value [mm/hr]");
- parm.infilval->guisection = _("Input_options");
+ parm.infilval->guisection = _("Input");
parm.maninval->key = "manin_val";
@@ -179,14 +175,14 @@
parm.maninval->description = _("Mannings n unique value");
parm.traps = G_define_standard_option(G_OPT_R_INPUT);
parm.traps->key = "traps";
parm.traps->required = NO;
parm.traps->description =
- _("Name of the flow controls raster map (permeability ratio 0-1)");
- parm.traps->guisection = _("Input_options");
+ _("Name of flow controls raster map (permeability ratio 0-1)");
+ parm.traps->guisection = _("Input");
@@ -200,20 +196,20 @@
parm.depth = G_define_standard_option(G_OPT_R_OUTPUT);
parm.depth->key = "depth";
parm.depth->required = NO;
- parm.depth->description = _("Output water depth raster map [m]");
- parm.depth->guisection = _("Output_options");
+ parm.depth->description = _("Name for output water depth raster map [m]");
+ parm.depth->guisection = _("Output");
parm.disch = G_define_standard_option(G_OPT_R_OUTPUT);
parm.disch->key = "disch";
parm.disch->required = NO;
- parm.disch->description = _("Output water discharge raster map [m3/s]");
- parm.disch->guisection = _("Output_options");
+ parm.disch->description = _("Name for output water discharge raster map [m3/s]");
+ parm.disch->guisection = _("Output");
parm.err = G_define_standard_option(G_OPT_R_OUTPUT);
parm.err->key = "err";
parm.err->required = NO;
- parm.err->description = _("Output simulation error raster map [m]");
- parm.err->guisection = _("Output_options");
+ parm.err->description = _("Name for output simulation error raster map [m]");
+ parm.err->guisection = _("Output");
parm.outwalk = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -272,8 +268,9 @@
parm.hmax->type = TYPE_DOUBLE;
parm.hmax->answer = HMAX;
parm.hmax->required = NO;
- parm.hmax->description =
- _("Threshold water depth [m] (diffusion increases after this water depth is reached)");
+ parm.hmax->label =
+ _("Threshold water depth [m]");
+ parm.hmax->description = _("Diffusion increases after this water depth is reached");
parm.hmax->guisection = _("Parameters");
parm.halpha = G_define_option();
@@ -297,7 +294,6 @@
flag.tserie->key = 't';
flag.tserie->description = _("Time-series output");
exit(EXIT_FAILURE);
