[GRASS-SVN] r41713 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Sun Apr 4 10:43:23 EDT 2010
Author: martinl
Date: 2010-04-04 10:43:23 -0400 (Sun, 04 Apr 2010)
New Revision: 41713
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
update menudata items by support/update_menudata.py
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-04-04 14:41:33 UTC (rev 41712)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-04-04 14:43:23 UTC (rev 41713)
@@ -1068,7 +1068,7 @@
</menuitem>
<menuitem>
<label>Shadows map</label>
- <help>Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask it</help>
+ <help>Calculates cast shadow areas from sun position and elevation raster map.</help>
<keywords>raster</keywords>
<handler>OnMenuCmd</handler>
<command>r.sunmask</command>
@@ -1186,51 +1186,51 @@
<items>
<menuitem>
<label>Carve stream channels</label>
- <help>Takes vector stream data, transforms it to raster and subtracts depth from the output DEM.</help>
- <keywords>raster</keywords>
+ <help>Generates stream channels.</help>
+ <keywords>raster,hydrology</keywords>
<command>r.carve</command>
</menuitem>
<menuitem>
<label>Fill lake</label>
<help>Fills lake from seed at given level.</help>
<command>r.lake</command>
</menuitem>
<separator />
<menuitem>
<label>Depressionless map and flowlines</label>
- <help>Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer.</help>
+ <help>Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map.</help>
<command>r.fill.dir</command>
</menuitem>
<menuitem>
<label>Flow accumulation</label>
- <help>Flow computation for massive grids (Float version).</help>
+ <help>Flow computation for massive grids (float version).</help>
<command>r.terraflow</command>
</menuitem>
<menuitem>
<label>Flow lines</label>
- <help>Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)</help>
+ <help>Constructs flow lines.</help>
<command>r.flow</command>
</menuitem>
<separator />
<menuitem>
<label>SIMWE Overland flow modeling</label>
- <help>Overland flow hydrologic simulation using path sampling method (SIMWE)</help>
+ <help>Overland flow hydrologic simulation using path sampling method (SIMWE).</help>
<keywords>raster,flow,hydrology</keywords>
<command>r.sim.water</command>
</menuitem>
<menuitem>
<label>SIMWE Sediment flux modeling</label>
- <help>Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)</help>
+ <help>Sediment transport and erosion/deposition simulation using path sampling method (SIMWE).</help>
<keywords>raster,sediment flow,erosion,deposition</keywords>
<command>r.sim.sediment</command>
@@ -1238,37 +1238,37 @@
<separator />
<menuitem>
<label>Topographic index map</label>
- <help>Creates topographic index [ln(a/tan(beta))] map from elevation map.</help>
+ <help>Creates topographic index map from elevation raster map.</help>
<command>r.topidx</command>
</menuitem>
<menuitem>
<label>TOPMODEL simulation</label>
<help>Simulates TOPMODEL which is a physically based hydrologic model.</help>
<command>r.topmodel</command>
</menuitem>
<separator />
<menuitem>
<label>Watershed subbasins</label>
- <help>Generates a raster map layer showing watershed subbasins.</help>
+ <help>Generates watershed subbasins raster map.</help>
<command>r.basins.fill</command>
</menuitem>
<menuitem>
<label>Watershed analysis</label>
- <help>Watershed basin analysis program.</help>
+ <help>Creates watershed basins.</help>
<command>r.watershed</command>
</menuitem>
<menuitem>
<label>Watershed basin creation</label>
- <help>Watershed basin creation program.</help>
<command>r.water.outlet</command>
</menuitem>
@@ -2714,22 +2714,22 @@
<menuitem>
<label>Connect</label>
<help>Prints/sets general DB connection for current mapset and exits.</help>
- <keywords>database,attribute table,connection settings</keywords>
+ <keywords>database,attribute table</keywords>
<command>db.connect</command>
</menuitem>
<menuitem>
<label>Login</label>
<help>Sets user/password for driver/database.</help>
- <keywords>database,connection</keywords>
+ <keywords>database,SQL</keywords>
<command>db.login</command>
</menuitem>
<separator />
<menuitem>
<label>Drop table</label>
- <help>Removes a table from database.</help>
- <keywords>database,SQL</keywords>
+ <help>Drops an attribute table.</help>
<command>db.droptable</command>
</menuitem>
