[GRASS-SVN] r41718 - grass/branches/releasebranch_6_4/vector/v.hull
svn_grass at osgeo.org
Sun Apr 4 12:38:22 EDT 2010
Author: martinl
Date: 2010-04-04 12:38:22 -0400 (Sun, 04 Apr 2010)
New Revision: 41718
grass/branches/releasebranch_6_4/vector/v.hull/description.html
grass/branches/releasebranch_6_4/vector/v.hull/main.c
v.hull: support for vector lines
(merge r41717 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.hull/description.html
--- grass/branches/releasebranch_6_4/vector/v.hull/description.html 2010-04-04 16:34:26 UTC (rev 41717)
+++ grass/branches/releasebranch_6_4/vector/v.hull/description.html 2010-04-04 16:38:22 UTC (rev 41718)
@@ -1,56 +1,60 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-v.hull computes the convex hull of a vector points map and outputs the
-convex hull polygon as a vector area map. The convex hull, or convex envelope,
-for an object or a set of objects is the minimal convex set containing the
-given objects. This module creates a vector polygon containing all vector
-points of the input map.
-<P>
-In the case of 3D input points, the hull will be a 3D hull as well, unless the
-user specifies the <b>-f</b> flag. The 3D hull will be composed of triangular
-faces.
-<P>
+<em>v.hull</em> computes the convex hull of a vector map and outputs
+the convex hull polygon as a vector area map. The convex hull, or
+convex envelope, for an object or a set of objects is the minimal
+convex set containing the given objects. This module creates a vector
+polygon containing all vector points or lines of the input map.
-<BR>
-Example of <em>v.hull</em> output:
+<p>
+In the case of 3D input points, the hull will be a 3D hull as well,
+unless the user specifies the <b>-f</b> flag. The 3D hull will be
+composed of triangular faces.
<center>
-<img src=v_hull.png border=1><BR>
+<img src=v_hull.png border=1><br>
<table border=0 width=590>
<tr><td><center>
-<i>Convex hull polygon created with v.hull</i>
+Fig: Convex hull polygon created with <em>v.hull</em>
</center></td></tr>
</table>
</center>
-<H2>EXAMPLE</H2>
+<h2>EXAMPLE</h2>
Example of <em>v.hull</em> 3D output (using two random 3D point clouds):
<div class="code"><pre>
g.region rural_1m -p
r.mapcalc zero=0
-v.random -z out=random3d_a n=10 zmin=0 zmax=200
-v.random -z out=random3d_b n=15 zmin=400 zmax=600
-v.hull random3d_a out=random3d_a_hull
-v.hull random3d_b out=random3d_b_hull
-nviz zero vect=random3d_a_hull,random3d_b_hull
+v.random -z output=random3d_a n=10 zmin=0 zmax=200
+v.random -z output=random3d_b n=15 zmin=400 zmax=600
+v.hull input=random3d_a output=random3d_a_hull
+v.hull input=random3d_b output=random3d_b_hull
+nviz elevation=zero vect=random3d_a_hull,random3d_b_hull
</pre></div>
-<H2>REFERENCES</H2>
-<EM>M. de Berg, M. van Kreveld, M. Overmars, O. Schwarzkopf, (2000).
- Computational geometry, chapter 1.1, 2-8.</EM>
+<h2>REFERENCES</h2>
-<BR>
+<ul>
+ <li>M. de Berg, M. van Kreveld, M. Overmars, O. Schwarzkopf,
+ (2000). Computational geometry, chapter 1.1, 2-8.
+ <li>J. O'Rourke, (1998). Computational Geometry in C (Second
+ Edition), chapter 4.
+</ul>
-<EM>J. O'Rourke, (1998).
- Computational Geometry in C (Second Edition), chapter 4.</EM>
+<h2>SEE ALSO</h2>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="v.delaunay.html">v.delaunay</A></EM>
+<em>
+<a href="v.delaunay.html">v.delaunay</a>
+</em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Andrea Aime, Modena, Italy<br>
Markus Neteler, ITC-irst (update to 5.7)<br>
-Benjamin Ducke, CAU Kiel (3D hull support)
+Benjamin Ducke, CAU Kiel (3D hull support)<br>
+Martin Landa, CTU in Prague, Czech Republic (vector lines support)
-<p><i>Last changed: $Date$</i></p>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/vector/v.hull/main.c
--- grass/branches/releasebranch_6_4/vector/v.hull/main.c 2010-04-04 16:34:26 UTC (rev 41717)
+++ grass/branches/releasebranch_6_4/vector/v.hull/main.c 2010-04-04 16:38:22 UTC (rev 41718)
@@ -1,26 +1,22 @@
-* hull.c <s.hull>
-* Creates the convex hull surrounding a sites list
+ * MODULE: v.hull (based s.hull)
+ * AUTHOR(S): Andrea Aime <aaime at libero.it>
+ * Updated by Markus Neteler to 5.7
+ * Updated by Benjamin Ducke to support 3D hull creation
+ * PURPOSE: Creates the convex hull surrounding a vector points
+ * COPYRIGHT: (C) 2001, 2010 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
-* @Copyright Andrea Aime <aaime at libero.it>
-* 23 Sept. 2001
-* Updated 19 Dec 2003, Markus Neteler to 5.7
-* Last updated 16 jan 2007, Benjamin Ducke to support 3D hull creation
-* This file is part of GRASS GIS. It is free software. You can
-* redistribute it and/or modify it under the terms of
-* the GNU General Public License as published by the Free Software
-* Foundation; either version 2 of the License, or (at your option)
-* any later version.
-* This program is distributed in the hope that it will be useful,
-* but WITHOUT ANY WARRANTY; without even the implied warranty of
-* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-* GNU General Public License for more details.
#include <stdlib.h>
#include <stdio.h>
#include <assert.h>
@@ -89,13 +85,10 @@
- printf("upPoints: %d\n", upPoints);
- for(pointIdx = 0; pointIdx <= upPoints; pointIdx ++)
- printf("%d ", upHull[pointIdx]);
- printf("\n");
+ G_debug(3, "upPoints: %d", upPoints);
+ for(pointIdx = 0; pointIdx <= upPoints; pointIdx++)
+ G_debug(5, " %d", upHull[pointIdx]);
/* compute lower hull, overwrite last point of upper hull */
loHull = &(upHull[upPoints]);
loHull[0] = numPoints - 1;
@@ -115,23 +108,17 @@
G_debug(3, "numPoints:%d loPoints:%d upPoints:%d",
numPoints, loPoints, upPoints);
- printf("loPoints: %d\n", loPoints);
- for(pointIdx = 0; pointIdx <= loPoints; pointIdx ++)
- printf("%d ", loHull[pointIdx]);
- printf("\n");
+ for (pointIdx = 0; pointIdx <= loPoints; pointIdx++)
+ G_debug(5, " %d", loHull[pointIdx]);
/* reclaim uneeded memory */
*hull = (int *)G_realloc(*hull, (loPoints + upPoints) * sizeof(int));
return loPoints + upPoints;
void convexHull3d(struct Point *P, const int numPoints, struct Map_info *Map)
int error;
int i;
double *px;
@@ -151,9 +138,9 @@
/* make 3D hull */
error = make3DHull(px, py, pz, numPoints, Map);
if (error < 0) {
- G_fatal_error("Simple planar hulls not implemented yet");
+ G_fatal_error(_("Simple planar hulls not implemented yet"));
G_free(px);
G_free(py);
G_free(pz);
@@ -164,7 +151,7 @@
int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
struct Cell_head *window)
- int pointIdx = 0;
+ int i, pointIdx;
struct line_pnts *sites;
struct line_cats *cats;
BOUND_BOX box;
@@ -174,35 +161,34 @@
cats = Vect_new_cats_struct();
*points = NULL;
+ pointIdx = 0;
/* copy window to box */
Vect_region_box(window, &box);
while ((type = Vect_read_next_line(Map, sites, cats)) > -1) {
- if (type != GV_POINT)
+ if (type != GV_POINT && !(type & GV_LINES))
continue;
Vect_cat_get(cats, 1, &cat);
- G_debug(4, "Point: %f|%f|%f|#%d", sites->x[0], sites->y[0],
- sites->z[0], cat);
- if (all ||
- Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box)) {
+ for (i = 0; i < sites->n_points; i++) {
+ G_debug(4, "Point: %f|%f|%f|#%d", sites->x[i], sites->y[i],
+ sites->z[i], cat);
+ if (!all && !Vect_point_in_box(sites->x[i], sites->y[i], sites->z[i], &box))
+ continue;
G_debug(4, "Point in the box");
if ((pointIdx % ALLOC_CHUNK) == 0)
- *points =
- (struct Point *)G_realloc(*points,
- (pointIdx +
- ALLOC_CHUNK) *
- sizeof(struct Point));
- (*points)[pointIdx].x = sites->x[0];
- (*points)[pointIdx].y = sites->y[0];
- (*points)[pointIdx].z = sites->z[0];
+ *points = (struct Point *) G_realloc(*points,
+ (pointIdx + ALLOC_CHUNK) * sizeof(struct Point));
+ (*points)[pointIdx].x = sites->x[i];
+ (*points)[pointIdx].y = sites->y[i];
+ (*points)[pointIdx].z = sites->z[i];
pointIdx++;
@@ -281,20 +267,19 @@
int MODE2D;
G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("vector, geometry");
module->description =
- _("Uses a GRASS vector points map to produce a convex hull vector map.");
+ _("Produces a convex hull for a given vector map.");
input = G_define_standard_option(G_OPT_V_INPUT);
- input->description = _("Name of input vector points map");
+ input->label = _("Name of input vector map");
+ input->description = _("For vector lines reads their vertices");
output = G_define_standard_option(G_OPT_V_OUTPUT);
- output->description = _("Name of output vector area map");
all = G_define_flag();
all->key = 'a';
all->description =
@@ -304,7 +289,7 @@
flat->key = 'f';
flat->description =
_("Create a 'flat' 2D hull even if the input is 3D points");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -319,18 +304,22 @@
/* open site file */
if (Vect_open_old(&Map, sitefile, mapset) < 0)
- G_fatal_error(_("Cannot open vector map <%s>"), sitefile);
+ G_fatal_error(_("Unable to open vector map <%s>"),
+ G_fully_qualified_name(sitefile, mapset));
/* load site coordinates */
G_get_window(&window);
numSitePoints = loadSiteCoordinates(&Map, &points, all->answer, &window);
if (numSitePoints < 0)
- G_fatal_error(_("Error loading vector points map <%s>"), sitefile);
+ G_fatal_error(_("Error loading vector points from <%s>"),
if (numSitePoints < 3)
- G_fatal_error(_("Convex hull calculation requires at least three points"));
+ G_fatal_error(_("Convex hull calculation requires at least three points. Exiting."));
+ G_verbose_message(_("%d points read from vector map <%s>"),
+ numSitePoints, G_fully_qualified_name(sitefile, mapset));
/* create a 2D or a 3D hull? */
MODE2D = 1;
if (Vect_is_3d(&Map)) {
@@ -340,38 +329,25 @@
MODE2D = 1;
/* create vector map */
- if (MODE2D) {
- if (0 > Vect_open_new(&Map, output->answer, 0)) {
- G_fatal_error(_("Cannot open vector map <%s>"), output->answer);
+ if (0 > Vect_open_new(&Map, output->answer, MODE2D ? WITHOUT_Z : WITH_Z)) {
+ G_fatal_error(_("Unable to create vector map <%s>"), output->answer);
- else {
- if (0 > Vect_open_new(&Map, output->answer, 1)) {
Vect_hist_command(&Map);
if (MODE2D) {
/* compute convex hull */
numHullPoints = convexHull(points, numSitePoints, &hull);
/* output vector map */
outputHull(&Map, points, hull, numHullPoints);
else {
/* this does everything for the 3D hull including vector map creation */
convexHull3d(points, numSitePoints, &Map);
/* clean up and bye bye */
Vect_build(&Map);
Vect_close(&Map);
