[GRASS-SVN] r41719 - grass/trunk/vector/v.hull
svn_grass at osgeo.org
Sun Apr 4 13:00:26 EDT 2010
Author: martinl
Date: 2010-04-04 13:00:25 -0400 (Sun, 04 Apr 2010)
New Revision: 41719
grass/trunk/vector/v.hull/main.c
grass/trunk/vector/v.hull/read.c
grass/trunk/vector/v.hull/v.hull.html
v.hull: support for vector lines
(merge r41717 from devbr6)
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c 2010-04-04 16:38:22 UTC (rev 41718)
+++ grass/trunk/vector/v.hull/main.c 2010-04-04 17:00:25 UTC (rev 41719)
@@ -10,7 +10,7 @@
* PURPOSE: Creates the convex hull surrounding a vector points.
- * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2010 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -50,14 +50,14 @@
G_add_keyword(_("vector"));
G_add_keyword(_("geometry"));
module->description =
- _("Creates convex hull for vector point map.");
+ _("Produces a convex hull for a given vector map.");
input = G_define_standard_option(G_OPT_V_INPUT);
field = G_define_standard_option(G_OPT_V_FIELD_ALL);
output = G_define_standard_option(G_OPT_V_OUTPUT);
all = G_define_flag();
all->key = 'a';
all->description =
@@ -67,7 +67,7 @@
flat->key = 'f';
flat->description =
_("Create a 'flat' 2D hull even if the input is 3D points");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -75,22 +75,23 @@
Vect_check_input_output_name(input->answer, output->answer,
GV_FATAL_EXIT);
Vect_set_open_level(1);
if (Vect_open_old2(&Map, sitefile, "", field->answer) < 0)
G_fatal_error(_("Unable to open vector map <%s>"), sitefile);
/* load site coordinates */
G_get_window(&window);
numSitePoints = loadSiteCoordinates(&Map, &points, all->answer, &window,
Vect_get_field_number(&Map, field->answer));
if (numSitePoints < 0)
- G_fatal_error(_("Error loading vector points map <%s>"), sitefile);
+ G_fatal_error(_("Error loading vector points from <%s>"), sitefile);
if (numSitePoints < 3)
G_fatal_error(_("Convex hull calculation requires at least three points (%d found)"), numSitePoints);
+ G_verbose_message(_("%d points read from vector map <%s>"), sitefile);
/* create a 2D or a 3D hull? */
MODE2D = 1;
if (Vect_is_3d(&Map)) {
@@ -100,23 +101,14 @@
MODE2D = 1;
/* create vector map */
- if (MODE2D) {
- if (0 > Vect_open_new(&Map, output->answer, 0)) {
- G_fatal_error(_("Unable to create vector map <%s>"), output->answer);
+ if (0 > Vect_open_new(&Map, output->answer, MODE2D ? WITHOUT_Z : WITH_Z)) {
+ G_fatal_error(_("Unable to create vector map <%s>"), output->answer);
- else {
- if (0 > Vect_open_new(&Map, output->answer, 1)) {
Vect_hist_command(&Map);
if (MODE2D) {
/* compute convex hull */
numHullPoints = convexHull(points, numSitePoints, &hull);
Modified: grass/trunk/vector/v.hull/read.c
--- grass/trunk/vector/v.hull/read.c 2010-04-04 16:38:22 UTC (rev 41718)
+++ grass/trunk/vector/v.hull/read.c 2010-04-04 17:00:25 UTC (rev 41719)
@@ -5,7 +5,7 @@
int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
struct Cell_head *window, int field)
- int pointIdx = 0;
+ int i, pointIdx;
struct line_pnts *sites;
struct line_cats *cats;
struct bound_box box;
@@ -15,43 +15,42 @@
cats = Vect_new_cats_struct();
*points = NULL;
+ pointIdx = 0;
/* copy window to box */
Vect_region_box(window, &box);
while ((type = Vect_read_next_line(Map, sites, cats)) > -1) {
- if (type != GV_POINT)
+ if (type != GV_POINT && !(type & GV_LINES))
continue;
if (field != -1 && Vect_cat_get(cats, field, &cat) == 0)
continue;
- G_debug(4, "Point: %f|%f|%f|#%d", sites->x[0], sites->y[0],
- sites->z[0], cat);
- if (all ||
- Vect_point_in_box(sites->x[0], sites->y[0], sites->z[0], &box)) {
+ for (i = 0; i < sites->n_points; i++) {
+ G_debug(4, "Point: %f|%f|%f|#%d", sites->x[i], sites->y[i],
+ sites->z[i], cat);
+ if (!all && !Vect_point_in_box(sites->x[i], sites->y[i], sites->z[i], &box))
+ continue;
G_debug(4, "Point in the box");
if ((pointIdx % ALLOC_CHUNK) == 0)
- *points =
- (struct Point *)G_realloc(*points,
- (pointIdx +
- ALLOC_CHUNK) *
- sizeof(struct Point));
- (*points)[pointIdx].x = sites->x[0];
- (*points)[pointIdx].y = sites->y[0];
- (*points)[pointIdx].z = sites->z[0];
+ *points = (struct Point *) G_realloc(*points,
+ (pointIdx + ALLOC_CHUNK) * sizeof(struct Point));
+ (*points)[pointIdx].x = sites->x[i];
+ (*points)[pointIdx].y = sites->y[i];
+ (*points)[pointIdx].z = sites->z[i];
pointIdx++;
if (pointIdx > 0)
- *points =
- (pointIdx + 1) * sizeof(struct Point));
+ *points = (struct Point *)G_realloc(*points,
+ (pointIdx + 1) * sizeof(struct Point));
return pointIdx;
Modified: grass/trunk/vector/v.hull/v.hull.html
--- grass/trunk/vector/v.hull/v.hull.html 2010-04-04 16:38:22 UTC (rev 41718)
+++ grass/trunk/vector/v.hull/v.hull.html 2010-04-04 17:00:25 UTC (rev 41719)
@@ -1,56 +1,60 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-v.hull computes the convex hull of a vector points map and outputs the
-convex hull polygon as a vector area map. The convex hull, or convex envelope,
-for an object or a set of objects is the minimal convex set containing the
-given objects. This module creates a vector polygon containing all vector
-points of the input map.
-<P>
-In the case of 3D input points, the hull will be a 3D hull as well, unless the
-user specifies the <b>-f</b> flag. The 3D hull will be composed of triangular
-faces.
-<P>
+<em>v.hull</em> computes the convex hull of a vector map and outputs
+the convex hull polygon as a vector area map. The convex hull, or
+convex envelope, for an object or a set of objects is the minimal
+convex set containing the given objects. This module creates a vector
+polygon containing all vector points or lines of the input map.
-<BR>
-Example of <em>v.hull</em> output:
+<p>
+In the case of 3D input points, the hull will be a 3D hull as well,
+unless the user specifies the <b>-f</b> flag. The 3D hull will be
+composed of triangular faces.
<center>
-<img src=v_hull.png border=1><BR>
+<img src=v_hull.png border=1><br>
<table border=0 width=590>
<tr><td><center>
-<i>Convex hull polygon created with v.hull</i>
+Fig: Convex hull polygon created with <em>v.hull</em>
</center></td></tr>
</table>
</center>
-<H2>EXAMPLE</H2>
+<h2>EXAMPLE</h2>
Example of <em>v.hull</em> 3D output (using two random 3D point clouds):
<div class="code"><pre>
g.region rural_1m -p
-r.mapcalc "zero = 0"
-v.random -z out=random3d_a n=10 zmin=0 zmax=200
-v.random -z out=random3d_b n=15 zmin=400 zmax=600
-v.hull random3d_a out=random3d_a_hull
-v.hull random3d_b out=random3d_b_hull
-nviz zero vect=random3d_a_hull,random3d_b_hull
+r.mapcalc zero=0
+v.random -z output=random3d_a n=10 zmin=0 zmax=200
+v.random -z output=random3d_b n=15 zmin=400 zmax=600
+v.hull input=random3d_a output=random3d_a_hull
+v.hull input=random3d_b output=random3d_b_hull
+nviz elevation=zero vect=random3d_a_hull,random3d_b_hull
</pre></div>
-<H2>REFERENCES</H2>
-<EM>M. de Berg, M. van Kreveld, M. Overmars, O. Schwarzkopf, (2000).
- Computational geometry, chapter 1.1, 2-8.</EM>
+<h2>REFERENCES</h2>
-<BR>
+<ul>
+ <li>M. de Berg, M. van Kreveld, M. Overmars, O. Schwarzkopf,
+ (2000). Computational geometry, chapter 1.1, 2-8.
+ <li>J. O'Rourke, (1998). Computational Geometry in C (Second
+ Edition), chapter 4.
+</ul>
-<EM>J. O'Rourke, (1998).
- Computational Geometry in C (Second Edition), chapter 4.</EM>
+<h2>SEE ALSO</h2>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="v.delaunay.html">v.delaunay</A></EM>
+<em>
+<a href="v.delaunay.html">v.delaunay</a>
+</em>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
Andrea Aime, Modena, Italy<br>
Markus Neteler, ITC-irst (update to 5.7)<br>
-Benjamin Ducke, CAU Kiel (3D hull support)
+Benjamin Ducke, CAU Kiel (3D hull support)<br>
+Martin Landa, CTU in Prague, Czech Republic (vector lines support)
-<p><i>Last changed: $Date$</i></p>
+<p>
+<i>Last changed: $Date$</i>
