[GRASS-SVN] r41744 - grass/branches/develbranch_6/raster/r.gwflow
svn_grass at osgeo.org
Tue Apr 6 09:21:16 EDT 2010
Author: huhabla
Date: 2010-04-06 09:21:15 -0400 (Tue, 06 Apr 2010)
New Revision: 41744
grass/branches/develbranch_6/raster/r.gwflow/main.c
grass/branches/develbranch_6/raster/r.gwflow/valid_calc_excavation.sh
Bugfix: Avoid segfault if q is not provided.
Modified: grass/branches/develbranch_6/raster/r.gwflow/main.c
--- grass/branches/develbranch_6/raster/r.gwflow/main.c 2010-04-06 13:20:59 UTC (rev 41743)
+++ grass/branches/develbranch_6/raster/r.gwflow/main.c 2010-04-06 13:21:15 UTC (rev 41744)
@@ -72,6 +72,7 @@
param.q = G_define_standard_option(G_OPT_R_INPUT);
param.q->key = "q";
+ param.q->required = NO;
param.q->description = _("Water sources and sinks in [m^3/s]");
param.s = G_define_standard_option(G_OPT_R_INPUT);
@@ -81,6 +82,7 @@
param.r = G_define_standard_option(G_OPT_R_INPUT);
param.r->key = "r";
param.r->guisection = _("Recharge");
+ param.r->required = NO;
param.r->description =
_("Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]");
@@ -181,7 +183,6 @@
char *buff = NULL;
int with_river = 0, with_drain = 0;
/* Initialize GRASS */
G_gisinit(argv[0]);
@@ -200,7 +201,6 @@
G_fatal_error(_("Lat/Long location is not supported by %s. Please reproject map first."),
G_program_name());
/*Check the river parameters */
if (param.river_leak->answer == NULL && param.river_bed->answer == NULL &&
param.river_head->answer == NULL) {
@@ -227,7 +227,6 @@
G_fatal_error(_("Please provide drain_head and drain_leak maps"));
/*Set the maximum iterations */
sscanf(param.maxit->answer, "%i", &(maxit));
/*Set the calculation error break criteria */
@@ -242,7 +241,6 @@
if (strcmp(solver, N_SOLVER_DIRECT_CHOLESKY) == 0 && param.sparse->answer)
G_fatal_error(_("The direct cholesky solver do not work with sparse matrices"));
/*get the current region */
G_get_set_window(®ion);
@@ -275,16 +273,13 @@
* null values.*/
N_read_rast_to_array_2d(param.phead->answer, data->phead);
N_convert_array_2d_null_to_zero(data->phead);
- N_read_rast_to_array_2d(param.phead->answer, data->phead_start);
- N_convert_array_2d_null_to_zero(data->phead_start);
+ N_copy_array_2d(data->phead, data->phead_start);
N_read_rast_to_array_2d(param.status->answer, data->status);
N_convert_array_2d_null_to_zero(data->status);
N_read_rast_to_array_2d(param.hc_x->answer, data->hc_x);
N_convert_array_2d_null_to_zero(data->hc_x);
N_read_rast_to_array_2d(param.hc_y->answer, data->hc_y);
N_convert_array_2d_null_to_zero(data->hc_y);
- N_read_rast_to_array_2d(param.q->answer, data->q);
- N_convert_array_2d_null_to_zero(data->q);
N_read_rast_to_array_2d(param.s->answer, data->s);
N_convert_array_2d_null_to_zero(data->s);
N_read_rast_to_array_2d(param.top->answer, data->top);
@@ -316,6 +311,12 @@
N_convert_array_2d_null_to_zero(data->r);
+ /*Sources or sinks are optional */
+ if (param.q->answer) {
+ N_read_rast_to_array_2d(param.q->answer, data->q);
+ N_convert_array_2d_null_to_zero(data->q);
/* Set the inactive values to zero, to assure a no flow boundary */
for (y = 0; y < geom->rows; y++) {
for (x = 0; x < geom->cols; x++) {
@@ -397,7 +398,6 @@
if (les)
N_free_les(les);
/*Compute the the velocity field if required and write the result into three rast maps */
if (param.vector->answer) {
field =
@@ -424,7 +424,6 @@
N_free_gradient_field_2d(field);
if (data)
N_free_gwflow_data2d(data);
if (geom)
Modified: grass/branches/develbranch_6/raster/r.gwflow/valid_calc_excavation.sh
--- grass/branches/develbranch_6/raster/r.gwflow/valid_calc_excavation.sh 2010-04-06 13:20:59 UTC (rev 41743)
+++ grass/branches/develbranch_6/raster/r.gwflow/valid_calc_excavation.sh 2010-04-06 13:21:15 UTC (rev 41744)
@@ -16,7 +16,6 @@
(col() == 2 && row() == 14) ||\
(row() == 19), 2, 1)"
-r.mapcalc "well=0.0"
r.mapcalc "hydcond=0.001"
r.mapcalc "recharge=0.000000006"
r.mapcalc "top=20"
@@ -26,7 +25,7 @@
#compute a steady state groundwater flow
r.gwflow --o solver=cholesky top=top bottom=bottom phead=phead \
- status=status hc_x=hydcond hc_y=hydcond q=well s=syield \
+ status=status hc_x=hydcond hc_y=hydcond s=syield \
r=recharge output=gwresult dt=864000000000 type=unconfined
# create contour lines
