[GRASS-SVN] r41745 - in grass/trunk: lib/init mswindows
svn_grass at osgeo.org
Tue Apr 6 10:11:52 EDT 2010
Author: martinl
Date: 2010-04-06 10:11:52 -0400 (Tue, 06 Apr 2010)
New Revision: 41745
grass/trunk/lib/init/grass.py
grass/trunk/mswindows/GRASS-Installer.nsi
various minor fixes in winGRASS installer
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2010-04-06 13:21:15 UTC (rev 41744)
+++ grass/trunk/lib/init/grass.py 2010-04-06 14:11:52 UTC (rev 41745)
@@ -39,7 +39,10 @@
cmd_name = "@START_UP@"
grass_version = "@GRASS_VERSION_NUMBER@"
ld_library_path_var = '@LD_LIBRARY_PATH_VAR@'
-config_projshare = "@CONFIG_PROJSHARE@"
+if os.getenv("GRASS_PROJSHARE"):
+ config_projshare = os.getenv("GRASS_PROJSHARE")
+else:
+ config_projshare = "@CONFIG_PROJSHARE@"
grass_config_dirname = "@GRASS_CONFIG_DIR@"
gisbase = os.path.normpath(gisbase)
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2010-04-06 13:21:15 UTC (rev 41744)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2010-04-06 14:11:52 UTC (rev 41745)
@@ -728,10 +728,7 @@
FileWrite $0 '"$$GRASS_PYTHON $$GISBASE/grass70.py" "$$@"'
FileClose $0
done_create_grass_command:
- ;Create the $INSTALL_DIR\msys\grass link directory
- CreateDirectory $INSTALL_DIR\msys\grass
;Get the short form of the install path (to allow for paths with spaces)
VAR /GLOBAL INST_DIR_SHORT
GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
@@ -753,6 +750,7 @@
;create $PROFILE\.grass7\rc
SetShellVarContext current
ClearErrors
+ CreateDirectory $PROFILE\.grass7
FileOpen $0 $PROFILE\.grass7\rc w
IfErrors done_create_.grass7\rc
FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
@@ -761,7 +759,8 @@
FileClose $0
done_create_.grass7\rc:
- CopyFiles $PROFILE\.grass7\rc $INSTALL_DIR\msys\home\$USERNAME
+ CreateDirectory $INSTALL_DIR\msys\home\$USERNAME\.grass7
+ CopyFiles $PROFILE\.grass7\rc $INSTALL_DIR\msys\home\$USERNAME\.grass7
SectionEnd
@@ -908,7 +907,7 @@
;remove the .grass7\rc file
- Delete "$PROFILE\.grass7\rc"
+ RMDir /r "$PROFILE\.grass7"
;remove the Registry Entries
DeleteRegKey HKLM "Software\${GRASS_BASE}"
