[GRASS-SVN] r41757 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Apr 8 10:35:03 EDT 2010
Author: huhabla
Date: 2010-04-08 10:35:01 -0400 (Thu, 08 Apr 2010)
New Revision: 41757
grass/trunk/lib/gis/parser_wps.c
Renamed resolution parameter. Added band number parameter.
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c 2010-04-08 11:04:26 UTC (rev 41756)
+++ grass/trunk/lib/gis/parser_wps.c 2010-04-08 14:35:01 UTC (rev 41757)
@@ -174,12 +174,15 @@
wps_print_data_inputs_begin();
/* We have two default options, which define the resolution of the created mapset */
- wps_print_literal_input_output(WPS_INPUT, 0, 1, "resolution_ns", "Resolution of the mapset in north-south direction in [m] or [°]",
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ns", "Resolution of the mapset in north-south direction in [m] or [°]",
"This parameter defines the north-south resolution of the mapset in meter or degrees, which should be used ot process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
"float", 0, NULL, 0, "25", TYPE_OTHER);
- wps_print_literal_input_output(WPS_INPUT, 0, 1, "resolution_ew", "Resolution of the mapset in east-west direction in [m] or [°]",
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_resolution_ew", "Resolution of the mapset in east-west direction in [m] or [°]",
"This parameter defines the east-west resolution of the mapset in meters or degrees, which should be used ot process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "grass_band_number", "Band to select for processing (default is all bands)",
+ "This parameter defines band number of the input raster files which should be processed. As default all bands are processed and used as single and multiple inputs for raster modules.",
+ "integer", 0, NULL, 0, NULL, TYPE_OTHER);
/* Print the bounding box element with all the coordinate reference systems, which are supported by grass*/
/* Currently Disabled! A list of all proj4 supported EPSG coordinate reference systems must be implemented*/
