[GRASS-SVN] r41758 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Thu Apr 8 15:47:42 EDT 2010
Author: neteler
Date: 2010-04-08 15:47:42 -0400 (Thu, 08 Apr 2010)
New Revision: 41758
grass/branches/develbranch_6/lib/python/core.py
backport docs
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2010-04-08 14:35:01 UTC (rev 41757)
+++ grass/branches/develbranch_6/lib/python/core.py 2010-04-08 19:47:42 UTC (rev 41758)
@@ -151,6 +151,11 @@
"""!Passes all arguments to start_command, then waits for the process to
complete, returning its exit code. Similar to subprocess.call(), but
with the make_command() interface.
+ @param args
+ @param kwargs
+ @return exit code
ps = start_command(*args, **kwargs)
return ps.wait()
@@ -183,6 +188,11 @@
def feed_command(*args, **kwargs):
"""!Passes all arguments to start_command, but also adds
"stdin = PIPE". Returns the Popen object.
+ @param args
+ @param kwargs
+ @return Popen object
kwargs['stdin'] = PIPE
return start_command(*args, **kwargs)
@@ -190,6 +200,11 @@
def read_command(*args, **kwargs):
"""!Passes all arguments to pipe_command, then waits for the process to
complete, returning its stdout (i.e. similar to shell `backticks`).
+ @param args
+ @param kwargs
+ @return stdout
ps = pipe_command(*args, **kwargs)
return ps.communicate()[0]
@@ -223,6 +238,11 @@
def write_command(*args, **kwargs):
"""!Passes all arguments to feed_command, with the string specified
by the 'stdin' argument fed to the process' stdin.
+ @param args
+ @param kwargs
+ @return return code
stdin = kwargs['stdin']
p = feed_command(*args, **kwargs)
@@ -387,6 +407,14 @@
def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
"""!Parse a string into a dictionary, where entries are separated
by newlines and the key and value are separated by `sep' (default: `=')
+ @param s string to be parsed
+ @param sep key/value separator
+ @param dflt default value to be used
+ @param val_type value type (None for no cast)
+ @param vsep vertical separator (default os.linesep)
+ @return parsed input (dictionary of keys/values)
result = {}
@@ -526,6 +554,9 @@
def mlist_grouped(type, mapset = None, pattern = None):
"""!Returns the output from running g.mlist, as a dictionary where the keys
are mapset names and the values are lists of maps in that mapset.
+ @param type element type
+ @param mapset mapset name (default all mapset in search path)
@param pattern pattern string
result = {}
@@ -617,7 +648,7 @@
@param val color value
@param dflt default color value
@return tuple RGB
if val in named_colors:
@@ -653,6 +684,9 @@
def basename(path, ext = None):
"""!Remove leading directory components and an optional extension
from the specified path
+ @param path path
+ @param ext extension
name = os.path.basename(path)
if not ext:
@@ -667,6 +701,9 @@
def find_program(pgm, args = []):
"""!Attempt to run a program, with optional arguments. Return False
if the attempt failed due to a missing executable, True otherwise
+ @param pgm program name
+ @param args list of arguments
nuldev = file(os.devnull, 'w+')
try:
@@ -682,6 +719,8 @@
def try_remove(path):
"""!Attempt to remove a file; no exception is generated if the
attempt fails.
+ @param path path
try:
os.remove(path)
