[GRASS-SVN] r41778 - grass/trunk/lib/vector/neta
Sat Apr 10 11:16:06 EDT 2010
Author: martinl
Date: 2010-04-10 11:16:06 -0400 (Sat, 10 Apr 2010)
New Revision: 41778
   grass/trunk/lib/vector/neta/allpairs.c
   grass/trunk/lib/vector/neta/articulation_point.c
   grass/trunk/lib/vector/neta/bridge.c
   grass/trunk/lib/vector/neta/centrality.c
   grass/trunk/lib/vector/neta/components.c
   grass/trunk/lib/vector/neta/flow.c
   grass/trunk/lib/vector/neta/path.c
   grass/trunk/lib/vector/neta/spanningtree.c
   grass/trunk/lib/vector/neta/timetables.c
   grass/trunk/lib/vector/neta/utils.c
run grass_indent.sh
Modified: grass/trunk/lib/vector/neta/allpairs.c
--- grass/trunk/lib/vector/neta/allpairs.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/allpairs.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,19 +1,19 @@
-  \file vector/neta/allpairs.c
-  \brief Network Analysis library - shortest path between all pairs
-  Computes the length of the shortest path between all pairs of nodes
-  in the network.
-  (C) 2009-2010 by Daniel Bundala, and the GRASS Development Team
-  This program is free software under the GNU General Public License
-  (>=v2). Read the file COPYING that comes with GRASS for details.
-  \author Daniel Bundala (Google Summer of Code 2009)
+   \file vector/neta/allpairs.c
+   \brief Network Analysis library - shortest path between all pairs
+   Computes the length of the shortest path between all pairs of nodes
+   in the network.
+   (C) 2009-2010 by Daniel Bundala, and the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
+   \author Daniel Bundala (Google Summer of Code 2009)
 #include <stdio.h>
 #include <stdlib.h>
 #include <grass/gis.h>
@@ -22,18 +22,18 @@
 #include <grass/dgl/graph.h>
-  \brief Stores the directed distance between every pair
+   \brief Stores the directed distance between every pair
-  \todo Use only O(W*W) memory where W is the number of nodes present in the graph
+   \todo Use only O(W*W) memory where W is the number of nodes present in the graph
-  Upon the completion, dist stores the directed distance between every pair (i,j)
-  or -1 if the nodes are unreachable. It must be an array of dimension [nodes+1]*[nodes+1]
-  \param graph input graph
-  \param[out] dist list of directed distance
-  \return -1 on error
-  \return 0 on success
+   Upon the completion, dist stores the directed distance between every pair (i,j)
+   or -1 if the nodes are unreachable. It must be an array of dimension [nodes+1]*[nodes+1]
+   \param graph input graph
+   \param[out] dist list of directed distance
+   \return -1 on error
+   \return 0 on success
 int NetA_allpairs(dglGraph_s * graph, dglInt32_t ** dist)
@@ -41,8 +41,10 @@
     dglEdgesetTraverser_s et;
     dglNodeTraverser_s nt;
     dglInt32_t *node;
     nnodes = dglGet_NodeCount(graph);
     dglInt32_t *node_indices;
     node_indices = (dglInt32_t *) G_calloc(nnodes, sizeof(dglInt32_t));
     if (!node_indices) {
 	G_fatal_error(_("Out of memory"));
@@ -57,9 +59,12 @@
     indices = 0;
     for (node = dglNode_T_First(&nt); node; node = dglNode_T_Next(&nt)) {
 	dglInt32_t node_id = dglNodeGet_Id(graph, node);
 	node_indices[indices++] = node_id;
 	dglInt32_t *edge;
-	dglEdgeset_T_Initialize(&et, graph, dglNodeGet_OutEdgeset(graph, node));
+	dglEdgeset_T_Initialize(&et, graph,
+				dglNodeGet_OutEdgeset(graph, node));
 	for (edge = dglEdgeset_T_First(&et); edge;
 	     edge = dglEdgeset_T_Next(&et))
 	    if (dglEdgeGet_Id(graph, edge) < 0)	/*ignore backward edges */
@@ -71,16 +76,20 @@
     dglNode_T_Release(&nt);
     for (k = 0; k < indices; k++) {
 	dglInt32_t k_index = node_indices[k];
 	G_percent(k + 1, indices, 1);
 	for (i = 0; i < indices; i++) {
 	    dglInt32_t i_index = node_indices[i];
 	    if (dist[i_index][k_index] == -1)
 		continue;	/*no reason to proceed along infinite path */
 	    for (j = 0; j < indices; j++) {
 		dglInt32_t j_index = node_indices[j];
 		if (dist[k_index][j_index] != -1 &&
 		    (dist[i_index][k_index] + dist[k_index][j_index] <
-		     dist[i_index][j_index] || dist[i_index][j_index] == -1)) {
+		     dist[i_index][j_index] ||
+		     dist[i_index][j_index] == -1)) {
 			dist[i_index][k_index] + dist[k_index][j_index];
Modified: grass/trunk/lib/vector/neta/articulation_point.c
--- grass/trunk/lib/vector/neta/articulation_point.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/articulation_point.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/articulation_point.c
-  \brief Network Analysis library - connected components
+   \file vector/neta/articulation_point.c
-  Computes strongly and weakly connected components.
+   \brief Network Analysis library - connected components
+   Computes strongly and weakly connected components.
 #include <stdio.h>
 #include <stdlib.h>
@@ -21,13 +21,13 @@
-  \brief Get number of articulation points in the graph
+   \brief Get number of articulation points in the graph
-  \param[out] articulation_list list of articulation points
-  \return number of points
+   \param[out] articulation_list list of articulation points
+   \return number of points
 int NetA_articulation_points(dglGraph_s * graph,
 			     struct ilist *articulation_list)
@@ -45,6 +45,7 @@
     dglInt32_t *current_node;
     int stack_size;
     int i, time;
     current =
 	(dglEdgesetTraverser_s *) G_calloc(nnodes + 1,
@@ -74,14 +75,17 @@
     for (current_node = dglNode_T_First(&nt); current_node;
 	 current_node = dglNode_T_Next(&nt)) {
 	dglInt32_t current_id = dglNodeGet_Id(graph, current_node);
 	if (tin[current_id] == 0) {
 	    int children = 0;	/*number of subtrees rooted at the root/current_node */
 	    stack[0] = current_node;
 	    stack_size = 1;
 	    parent[current_id] = NULL;
 	    while (stack_size) {
 		dglInt32_t *node = stack[stack_size - 1];
 		if (tin[node_id] == 0)	/*vertex visited for the first time */
 		    min_tin[node_id] = tin[node_id] = ++time;
 		else {		/*return from the recursion */
@@ -102,6 +106,7 @@
 		    if (to == parent[node_id])
 			continue;	/*skip parrent */
 		    int to_id = dglNodeGet_Id(graph, to);
 		    if (tin[to_id]) {	/*back edge, cannot be a bridge/articualtion point */
 			if (tin[to_id] < min_tin[node_id])
 			    min_tin[node_id] = tin[to_id];
Modified: grass/trunk/lib/vector/neta/bridge.c
--- grass/trunk/lib/vector/neta/bridge.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/bridge.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/bridges.c
-  \brief Network Analysis library - bridges
+   \file vector/neta/bridges.c
-  Computes number of bridges in the graph.
+   \brief Network Analysis library - bridges
+   Computes number of bridges in the graph.
 #include <stdio.h>
 #include <stdlib.h>
@@ -21,16 +21,16 @@
-  \brief Get number of bridges in the graph.
-  Bridge is an array containing the indices of the bridges.
+   \brief Get number of bridges in the graph.
-  \param[out] bridges_list list of bridges
+   Bridge is an array containing the indices of the bridges.
-  \return number of bridges
+   \param[out] bridges_list list of bridges
+   \return number of bridges
 int NetA_compute_bridges(dglGraph_s * graph, struct ilist *bridge_list)
     int nnodes;
@@ -45,6 +45,7 @@
     int stack_size;
     int i, time;
     current =
@@ -73,6 +74,7 @@
 	    stack_size = 1;
@@ -80,6 +82,7 @@
@@ -103,6 +106,7 @@
 		    if (abs(edge_id) == parent[node_id])
 			continue;	/*skip edge we used to travel to this node */
Modified: grass/trunk/lib/vector/neta/centrality.c
--- grass/trunk/lib/vector/neta/centrality.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/centrality.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/centality.c
-  \brief Network Analysis library - centrality
+   \file vector/neta/centality.c
-  Centrality measures
+   \brief Network Analysis library - centrality
+   Centrality measures
 #include <stdio.h>
 #include <stdlib.h>
@@ -22,17 +22,18 @@
 #include <grass/neta.h>
-  \brief Computes degree centrality measure.
+   \brief Computes degree centrality measure.
-  Array degree has to be properly initialised to nnodes+1 elements
+   Array degree has to be properly initialised to nnodes+1 elements
-  \param[out] array of degrees
+   \param[out] array of degrees
 void NetA_degree_centrality(dglGraph_s * graph, double *degree)
     int i;
     double nnodes = dglGet_NodeCount(graph);
     for (i = 1; i <= nnodes; i++)
 	degree[i] =
 	    dglNodeGet_OutDegree(graph,
@@ -40,21 +41,22 @@
-  \brief Computes eigenvector centrality using edge costs as weights.
+   \brief Computes eigenvector centrality using edge costs as weights.
-  \param iterations number of iterations
-  \param error ?
-  \param[out] eigenvector eigen vector value
-  \return -1 on failure
+   \param iterations number of iterations
+   \param error ?
+   \param[out] eigenvector eigen vector value
+   \return -1 on failure
 int NetA_eigenvector_centrality(dglGraph_s * graph, int iterations,
 				double error, double *eigenvector)
     int i, iter, nnodes;
     double *tmp;
     tmp = (double *)G_calloc(nnodes + 1, sizeof(double));
     if (!tmp) {
@@ -71,11 +73,13 @@
 	dglInt32_t *node;
 	dglNode_T_Initialize(&nt, graph);
 	    double cur_value = eigenvector[node_id];
 	    dglInt32_t *edge;
@@ -87,12 +91,14 @@
 	double cum_error = 0, max_value = tmp[1];
 	for (i = 2; i <= nnodes; i++)
 	    if (tmp[i] > max_value)
 		max_value = tmp[i];
 	for (i = 1; i <= nnodes; i++) {
 	    tmp[i] /= max_value;
-	    cum_error += (tmp[i] - eigenvector[i]) * (tmp[i] - eigenvector[i]);
+	    cum_error +=
+		(tmp[i] - eigenvector[i]) * (tmp[i] - eigenvector[i]);
 	    eigenvector[i] = tmp[i];
 	if (cum_error < error)
@@ -105,18 +111,18 @@
-  \brief Computes betweenness and closeness centrality measure using Brandes algorithm.
+   \brief Computes betweenness and closeness centrality measure using Brandes algorithm.
-  Edge costs must be nonnegative. If some edge costs are negative then
-  the behaviour of this method is undefined.
-  \param[out] betweenness betweeness values
-  \param[out] closeness cloneness values
+   Edge costs must be nonnegative. If some edge costs are negative then
+   the behaviour of this method is undefined.
+   \param[out] betweenness betweeness values
+   \param[out] closeness cloneness values
 int NetA_betweenness_closeness(dglGraph_s * graph, double *betweenness,
 			       double *closeness)
@@ -172,6 +178,7 @@
 	dglHeapInsertMin(&heap, 0, ' ', heap_data);
 	while (1) {
 	    dglInt32_t v, dist;
 	    if (!dglHeapExtractMin(&heap, &heap_node))
 		break;
 	    v = heap_node.value.ul;
@@ -181,6 +188,7 @@
 	    stack[stack_size++] = v;
 	    dglInt32_t *edge;
 							  dglGetNode(graph,
@@ -190,6 +198,7 @@
 		dglInt32_t *to = dglEdgeGet_Tail(graph, edge);
 		dglInt32_t to_id = dglNodeGet_Id(graph, to);
 		dglInt32_t d = dglEdgeGet_Cost(graph, edge);
 		if (dst[to_id] == -1 || dst[to_id] > dist + d) {
 		    dst[to_id] = dist + d;
 		    Vect_reset_list(prev[to_id]);
@@ -209,11 +218,13 @@
 	    delta[i] = 0;
 	for (i = stack_size - 1; i >= 0; i--) {
 	    dglInt32_t w = stack[i];
 	    if (closeness)
 		closeness[s] += dst[w];
 	    for (j = 0; j < prev[w]->n_values; j++) {
 		dglInt32_t v = prev[w]->value[j];
 		delta[v] += (cnt[v] / (double)cnt[w]) * (1.0 + delta[w]);
 	    if (w != s && betweenness)
Modified: grass/trunk/lib/vector/neta/components.c
--- grass/trunk/lib/vector/neta/components.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/components.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/components.c
-  \brief Network Analysis library - graph componets
+   \file vector/neta/components.c
+   \brief Network Analysis library - graph componets
 #include <stdio.h>
 #include <stdlib.h>
@@ -21,14 +21,14 @@
-  \brief Computes weekly connected components
+   \brief Computes weekly connected components
-  \param[out] component list of components
+   \param[out] component list of components
-  \return number of components
+   \return number of components
 int NetA_weakly_connected_components(dglGraph_s * graph, int *component)
     int nnodes;
@@ -52,6 +52,7 @@
     for (cur_node = dglNode_T_First(&nt); cur_node;
 	 cur_node = dglNode_T_Next(&nt)) {
 	dglInt32_t node_id = dglNodeGet_Id(graph, cur_node);
 	if (!visited[node_id]) {
 	    visited[node_id] = 1;
 	    stack[0] = node_id;
@@ -60,12 +61,14 @@
 		dglInt32_t *node, *edgeset, *edge;
 		node = dglGetNode(graph, stack[--stack_size]);
 		edgeset = dglNodeGet_OutEdgeset(graph, node);
 		dglEdgeset_T_Initialize(&et, graph, edgeset);
 		     edge = dglEdgeset_T_Next(&et)) {
 		    dglInt32_t to;
 		    to = dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
 		    if (!visited[to]) {
 			visited[to] = 1;
@@ -83,14 +86,14 @@
-  \brief Computes strongly connected components
+   \brief Computes strongly connected components
 int NetA_strongly_connected_components(dglGraph_s * graph, int *component)
     int nnodes;
@@ -116,6 +119,7 @@
 	component[node_id] = 0;
@@ -125,6 +129,7 @@
 		dglInt32_t cur_node_id = stack[stack_size - 1];
 		if (processed[cur_node_id]) {
 		    stack_size--;
 		    order[order_size++] = cur_node_id;
@@ -137,6 +142,7 @@
 		    dglInt32_t to;
 			continue;	/*ignore backward edges */
@@ -154,6 +160,7 @@
     while (order_size) {
 	dglInt32_t node_id = order[--order_size];
 	if (component[node_id])
 	    continue;
 	components++;
@@ -164,12 +171,14 @@
 	    dglInt32_t cur_node_id = stack[--stack_size];
 	    node = dglGetNode(graph, cur_node_id);
 		dglInt32_t to;
 		if (dglEdgeGet_Id(graph, edge) > 0)
 		    continue;	/*ignore forward edges */
Modified: grass/trunk/lib/vector/neta/flow.c
--- grass/trunk/lib/vector/neta/flow.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/flow.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,19 +1,19 @@
-  \file vector/neta/flow.c
-  \brief Network Analysis library - flow in graph
+   \file vector/neta/flow.c
-  in the network.
+   \brief Network Analysis library - flow in graph
+   in the network.
 #include <stdio.h>
 #include <stdlib.h>
@@ -30,20 +30,20 @@
-  \brief Get max flow from source to sink.
+   \brief Get max flow from source to sink.
-  Array flow stores flow for each edge. Negative flow corresponds to a
-  flow in opposite direction The function assumes that the edge costs
-  correspond to edge capacities.
+   Array flow stores flow for each edge. Negative flow corresponds to a
+   flow in opposite direction The function assumes that the edge costs
+   correspond to edge capacities.
-  \param source_list list of sources
-  \param sink_list list of sinks
-  \param[out] flow max flows
+   \param source_list list of sources
+   \param sink_list list of sinks
+   \param[out] flow max flows
-  \return number of flows
+   \return number of flows
 int NetA_flow(dglGraph_s * graph, struct ilist *source_list,
 	      struct ilist *sink_list, int *flow)
@@ -77,6 +77,7 @@
     while (1) {
 	dglInt32_t node, edge_id, min_residue;
 	int found = -1;
 	begin = end = 0;
 	for (i = 0; i < source_list->n_values; i++)
 	    queue[end++] = source_list->value[i];
@@ -87,6 +88,7 @@
 	while (begin != end && found == -1) {
 	    dglInt32_t vertex = queue[begin++];
 	    dglInt32_t *edge, *node = dglGetNode(graph, vertex);
@@ -117,6 +119,7 @@
 			    prev[node]) - sign(edge_id) * flow[abs(edge_id)];
 	while (!is_source[node]) {
 	    dglInt32_t residue;
 	    edge_id = dglEdgeGet_Id(graph, prev[node]);
 	    residue =
@@ -145,20 +148,20 @@
-  \brief Calculates minimum cut between source(s) and sink(s).
+   \brief Calculates minimum cut between source(s) and sink(s).
-  Flow is the array produced by NetA_flow() method when called with
-  source_list and sink_list as the input. The output of this and
-  NetA_flow() method should be the same.
+   Flow is the array produced by NetA_flow() method when called with
+   source_list and sink_list as the input. The output of this and
+   NetA_flow() method should be the same.
-  \param[out] cut list of edges (cut)
+   \param[out] cut list of edges (cut)
-  \return number of edges
+   \return number of edges
 int NetA_min_cut(dglGraph_s * graph, struct ilist *source_list,
 		 struct ilist *sink_list, int *flow, struct ilist *cut)
@@ -190,12 +193,15 @@
     while (begin != end) {
 	    dglInt32_t cap = dglEdgeGet_Cost(graph, edge);
 	    dglInt32_t id = dglEdgeGet_Id(graph, edge);
-	    dglInt32_t to = dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
+	    dglInt32_t to =
+		dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
 	    if (!visited[to] && cap > sign(id) * flow[abs(id)]) {
 		visited[to] = 1;
 		queue[end++] = to;
@@ -209,12 +215,14 @@
 	if (!visited[i])
 	    continue;
 	node = dglGetNode(graph, i);
 	    dglInt32_t to, edge_id;
 	    edge_id = abs(dglEdgeGet_Id(graph, edge));
 	    if (!visited[to] && flow[edge_id] != 0) {
@@ -231,22 +239,22 @@
-  \brief Splits each vertex of in graph into two vertices
+   \brief Splits each vertex of in graph into two vertices
-  The method splits each vertex of in graph into two vertices: in
-  vertex and out vertex. Also, it adds an edge from an in vertex to
-  the corresponding out vertex (capacity=2) and it adds an edge from
-  out vertex to in vertex for each edge present in the in graph
-  (forward capacity=1, backward capacity=0). If the id of a vertex is
-  v then id of in vertex is 2*v-1 and of out vertex 2*v.
-  \param in from graph
-  \param out to graph
-  \param node_cost list of node costs
+   The method splits each vertex of in graph into two vertices: in
+   vertex and out vertex. Also, it adds an edge from an in vertex to
+   the corresponding out vertex (capacity=2) and it adds an edge from
+   out vertex to in vertex for each edge present in the in graph
+   (forward capacity=1, backward capacity=0). If the id of a vertex is
+   v then id of in vertex is 2*v-1 and of out vertex 2*v.
-  \return number of undirected edges in the graph
+   \param in from graph
+   \param out to graph
+   \param node_cost list of node costs
+   \return number of undirected edges in the graph
 int NetA_split_vertices(dglGraph_s * in, dglGraph_s * out, int *node_costs)
     dglInt32_t opaqueset[16] =
@@ -254,17 +262,21 @@
     dglInt32_t nnodes, edge_cnt;
     dglInt32_t *cur_node;
     nnodes = dglGet_NodeCount(in);
     dglInitialize(out, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
 		  opaqueset);
     dglNode_T_Initialize(&nt, in);
     edge_cnt = 0;
     dglInt32_t max_node_cost = 0;
 	dglInt32_t v = dglNodeGet_Id(in, cur_node);
 	edge_cnt++;
 	dglInt32_t cost = 1;
 	if (node_costs)
 	    cost = node_costs[v];
 	if (cost > max_node_cost)
@@ -279,10 +291,12 @@
 	dglInt32_t *edge;
 	dglEdgeset_T_Initialize(&et, in, dglNodeGet_OutEdgeset(in, cur_node));
 	    dglInt32_t to;
 	    to = dglNodeGet_Id(in, dglEdgeGet_Tail(in, edge));
 	    edge_cnt++;
 	    dglAddEdge(out, 2 * v, 2 * to - 1, max_node_cost + 1, edge_cnt);
Modified: grass/trunk/lib/vector/neta/path.c
--- grass/trunk/lib/vector/neta/path.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/path.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/path.c
+   \file vector/neta/path.c
-  Shortest paths from a set of nodes.
+   Shortest paths from a set of nodes.
 #include <stdio.h>
 #include <stdlib.h>
@@ -22,27 +22,29 @@
-  \brief Computes shortests paths to every node from  nodes in "from".
+   \brief Computes shortests paths to every node from  nodes in "from".
-  Array "dst" contains the length of the path or -1 if the node is not
-  reachable. Prev contains edges from predecessor along the shortest
-  path.
+   Array "dst" contains the length of the path or -1 if the node is not
+   reachable. Prev contains edges from predecessor along the shortest
+   path.
-  \param from list of 'from' positions
-  \param dst list of 'to' positions
-  \param[out] prev list of edges from predecessor along the shortest path
-int NetA_distance_from_points(dglGraph_s * graph, struct ilist *from, int *dst,
-			      dglInt32_t ** prev)
+   \param from list of 'from' positions
+   \param dst list of 'to' positions
+   \param[out] prev list of edges from predecessor along the shortest path
+int NetA_distance_from_points(dglGraph_s * graph, struct ilist *from,
+			      int *dst, dglInt32_t ** prev)
     int i, nnodes;
     dglHeap_s heap;
 	dst[i] = -1;
 	prev[i] = NULL;
@@ -52,10 +54,12 @@
     for (i = 0; i < from->n_values; i++) {
 	int v = from->value[i];
 	if (dst[v] == 0)
 	    continue;		/*ingore duplicates */
 	dst[v] = 0;
 	dglHeapData_u heap_data;
 	heap_data.ul = v;
@@ -63,6 +67,7 @@
 	dglInt32_t v, dist;
 	dglHeapNode_s heap_node;
 	    break;
@@ -71,6 +76,7 @@
 	    continue;
 	dglInt32_t *edge;
 						      dglGetNode(graph, v)));
@@ -79,6 +85,7 @@
 		prev[to_id] = edge;
@@ -96,21 +103,21 @@
-  \brief Find a path (minimum number of edges) from 'from' to 'to' using only edges in 'edges'.
+   \brief Find a path (minimum number of edges) from 'from' to 'to' using only edges in 'edges'.
-  Precisely, edge with id I is used iff edges[abs(i)] == 1. List
-  stores the indices of lines on the path. Method return number of
-  edges or -1 if no path exist.
+   Precisely, edge with id I is used iff edges[abs(i)] == 1. List
+   stores the indices of lines on the path. Method return number of
+   edges or -1 if no path exist.
-  \param from 'from' position
-  \param to 'to' position
-  \param edges list of available edges
-  \param[out] list list of edges
+   \param from 'from' position
+   \param to 'to' position
+   \param edges list of available edges
+   \param[out] list list of edges
 int NetA_find_path(dglGraph_s * graph, int from, int to, int *edges,
 		   struct ilist *list)
@@ -136,14 +143,18 @@
     prev[from] = NULL;
 	if (vertex == to)
 	    break;
 	    dglInt32_t id = abs(dglEdgeGet_Id(graph, edge));
+	    dglInt32_t to =
 	    if (edges[id] && !vis[to]) {
 		vis[to] = 'y';
 		prev[to] = edge;
Modified: grass/trunk/lib/vector/neta/spanningtree.c
--- grass/trunk/lib/vector/neta/spanningtree.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/spanningtree.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/spanningtree.c
-  \brief Network Analysis library - spanning tree
+   \file vector/neta/spanningtree.c
-  Computes minimum spanning tree in the network.
+   \brief Network Analysis library - spanning tree
+   Computes minimum spanning tree in the network.
 #include <stdio.h>
 #include <stdlib.h>
@@ -44,6 +44,7 @@
 static int uf_find(struct union_find *uf, int v)
     int cur = v, tmp;
     while (uf->parent[cur] != cur)
 	cur = uf->parent[cur];
     while (uf->parent[v] != v) {
@@ -59,6 +60,7 @@
     int parent_u = uf_find(uf, u);
     int parent_v = uf_find(uf, v);
     if (parent_u != parent_v)
 	uf->parent[parent_u] = parent_v;
@@ -75,20 +77,21 @@
-  \brief Get number of edges in the spanning forest
+   \brief Get number of edges in the spanning forest
-  \param[out] list of edges
+   \param[out] list of edges
 int NetA_spanning_tree(dglGraph_s * graph, struct ilist *tree_list)
     int nnodes, edges, nedges, i, index;
     edge_cost_pair *perm;	/*permutaion of edges in ascending order */
     struct union_find uf;
     nedges = dglGet_EdgeCount(graph);
     perm = (edge_cost_pair *) G_calloc(nedges, sizeof(edge_cost_pair));
@@ -103,6 +106,7 @@
 	G_percent(i, nnodes + nedges, 1);
 	dglInt32_t *edge;
 						      dglGetNode(graph,
Modified: grass/trunk/lib/vector/neta/timetables.c
--- grass/trunk/lib/vector/neta/timetables.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/timetables.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \file vector/neta/timetables.c
-  \brief Network Analysis library - timetables
+   \file vector/neta/timetables.c
-  Shortest path using timetables.
+   \brief Network Analysis library - timetables
+   Shortest path using timetables.
 #include <stdio.h>
 #include <stdlib.h>
@@ -23,16 +23,16 @@
-  \brief Get number of distinct elements
+   \brief Get number of distinct elements
-  \param driver DB driver
-  \param sql SQl string
-  \param[out] list of lengths
-  \param[out] list of ids
-  \return number of distinct elements
+   \param driver DB driver
+   \param sql SQl string
+   \param[out] list of lengths
+   \param[out] list of ids
+   \return number of distinct elements
 int NetA_init_distinct(dbDriver * driver, dbString * sql, int **lengths,
 		       int **ids)
@@ -94,22 +94,22 @@
-  \brief Initialises timetable from a database
+   \brief Initialises timetable from a database
-  \param In pointer to Map_info structure
-  \param route_layer layer number of routes
-  \param walk_layer layer number of walkers
-  \param route_id id of route
-  \param times list of timestamps
-  \param to_stop ?
-  \param walk_length walk length as string
-  \param timetable pointer to neta_timetable
-  \param route_ids list of route ids
-  \param stop_ids lits of stop ids
+   \param In pointer to Map_info structure
+   \param route_layer layer number of routes
+   \param walk_layer layer number of walkers
+   \param route_id id of route
+   \param times list of timestamps
+   \param to_stop ?
+   \param walk_length walk length as string
+   \param timetable pointer to neta_timetable
+   \param route_ids list of route ids
+   \param stop_ids lits of stop ids
-  \return non-zero value on failure
+   \return non-zero value on failure
 int NetA_init_timetable_from_db(struct Map_info *In, int route_layer,
 				int walk_layer, char *route_id, char *times,
 				char *to_stop, char *walk_length,
@@ -126,6 +126,7 @@
     dbDriver *driver;
     struct field_info *Fi;
     Fi = Vect_get_field(In, route_layer);
     driver = db_start_driver_open_database(Fi->driver, Fi->database);
     if (driver == NULL)
@@ -138,20 +139,25 @@
 	    route_id);
     db_set_string(&sql, buf);
     timetable->routes =
-	NetA_init_distinct(driver, &sql, &(timetable->route_length), route_ids);
+	NetA_init_distinct(driver, &sql, &(timetable->route_length),
+			   route_ids);
     if (timetable->routes < 0)
 	return 1;
-    sprintf(buf, "select %s from %s order by %s", Fi->key, Fi->table, Fi->key);
+    sprintf(buf, "select %s from %s order by %s", Fi->key, Fi->table,
+	    Fi->key);
     timetable->stops =
 	NetA_init_distinct(driver, &sql, &(timetable->stop_length), stop_ids);
     if (timetable->stops < 0)
 	return 1;
-    timetable->route_stops = (int **)G_calloc(timetable->routes, sizeof(int *));
-    timetable->route_times = (int **)G_calloc(timetable->routes, sizeof(int *));
-    timetable->stop_routes = (int **)G_calloc(timetable->stops, sizeof(int *));
+    timetable->route_stops =
+	(int **)G_calloc(timetable->routes, sizeof(int *));
+    timetable->route_times =
+    timetable->stop_routes =
+	(int **)G_calloc(timetable->stops, sizeof(int *));
     timetable->stop_times = (int **)G_calloc(timetable->stops, sizeof(int *));
     timetable->walk_length = (int *)G_calloc(timetable->stops, sizeof(int));
     timetable->walk_stops = (int **)G_calloc(timetable->stops, sizeof(int *));
@@ -221,15 +227,16 @@
 	timetable->stop_times[stop][timetable->stop_length[stop]++] = time;
 	timetable->route_stops[route][timetable->route_length[route]] = stop;
-	timetable->route_times[route][timetable->route_length[route]++] = time;
+	timetable->route_times[route][timetable->route_length[route]++] =
+	    time;
     db_close_cursor(&cursor);
     if (walk_layer != -1) {
 	Fi = Vect_get_field(In, walk_layer);
-	sprintf(buf, "select %s, %s, %s from %s", Fi->key, to_stop, walk_length,
-		Fi->table);
+	sprintf(buf, "select %s, %s, %s from %s", Fi->key, to_stop,
+		walk_length, Fi->table);
 	if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) !=
@@ -246,8 +253,8 @@
 	    value = db_get_column_value(column2);
 	    stop = db_get_value_int(value);
 	    stop_pnt =
-		(int *)bsearch(&stop, *stop_ids, timetable->stops, sizeof(int),
-			       cmp_int);
+		(int *)bsearch(&stop, *stop_ids, timetable->stops,
+			       sizeof(int), cmp_int);
 	    if (stop_pnt) {
 		value = db_get_column_value(column1);
@@ -289,8 +296,8 @@
 	    stop_pnt =
-			       cmp_int);
 	    if (stop_pnt) {
 		stop2 = stop_pnt - (*stop_ids);
@@ -324,26 +331,27 @@
 static neta_heap_data *new_heap_data(int conns, int v)
-    neta_heap_data *d = (neta_heap_data *) G_calloc(1, sizeof(neta_heap_data));
+    neta_heap_data *d =
+	(neta_heap_data *) G_calloc(1, sizeof(neta_heap_data));
     d->v = v;
     d->conns = conns;
     return d;
-  \brief Update Dijkstra structures
+   \brief Update Dijkstra structures
-  \param olc_conns old connection
-  \param new_conns new connection
-  \param to old 'to' node
-  \param new_dst new 'to' node
-  \param v ?
-  \param route id of route
-  \param rows ?
-  \param update ?
-  \param[out] result pointer to neta_timetable_result structure
-  \param heap ?
+   \param olc_conns old connection
+   \param new_conns new connection
+   \param to old 'to' node
+   \param new_dst new 'to' node
+   \param v ?
+   \param route id of route
+   \param rows ?
+   \param update ?
+   \param[out] result pointer to neta_timetable_result structure
+   \param heap ?
 void NetA_update_dijkstra(int old_conns, int new_conns, int to, int new_dst,
 			  int v, int route, int rows, int update,
 			  neta_timetable_result * result, dglHeap_s * heap)
@@ -356,6 +364,7 @@
 	result->prev_conn[new_conns][to] = old_conns;
 	if (update) {
 	    heap_data.pv = (void *)new_heap_data(new_conns, to);
 	    dglHeapInsertMin(heap, new_dst, ' ', heap_data);
@@ -363,23 +372,23 @@
-  \brief Computes the earliest arrival time.
+   \brief Computes the earliest arrival time.
-  Computes the earliest arrival time to to_stop from from_stop
-  starting at start_time, or -1 if no path exists
+   Computes the earliest arrival time to to_stop from from_stop
+   starting at start_time, or -1 if no path exists
-  \param timetable pointer to neta_timetable structure
-  \param from_stop 'from' node
-  \param to_stop 'to' stop
-  \param start_time start timestamp
-  \param min_change ?
-  \param max_changes ?
-  \param walking_change ?
+   \param timetable pointer to neta_timetable structure
+   \param from_stop 'from' node
+   \param to_stop 'to' stop
+   \param start_time start timestamp
+   \param min_change ?
+   \param max_changes ?
+   \param walking_change ?
-  \return ?
+   \return ?
 int NetA_timetable_shortest_path(neta_timetable * timetable, int from_stop,
 				 int to_stop, int start_time, int min_change,
 				 int max_changes, int walking_change,
@@ -389,6 +398,7 @@
     dglHeap_s heap;
     int opt_conns, rows = 1;
     if (max_changes != -1)
 	rows = max_changes + 2;
@@ -407,7 +417,8 @@
     for (i = 0; i < rows; i++) {
 	result->dst[i] = (int *)G_calloc(timetable->stops, sizeof(int));
 	result->prev_stop[i] = (int *)G_calloc(timetable->stops, sizeof(int));
-	result->prev_route[i] = (int *)G_calloc(timetable->stops, sizeof(int));
+	result->prev_route[i] =
+	    (int *)G_calloc(timetable->stops, sizeof(int));
 	result->prev_conn[i] = (int *)G_calloc(timetable->stops, sizeof(int));
 	if (!result->dst[i] || !result->prev_stop[i] || !result->prev_route[i]
 	    || !result->prev_conn[i]) {
@@ -438,6 +449,7 @@
     result->dst[0][from_stop] = start_time - min_change;
     result->prev_stop[0][from_stop] = result->prev_route[0][from_stop] = -1;
     heap_data.pv = (void *)new_heap_data(0, from_stop);
     dglHeapInsertMin(&heap, start_time - min_change, ' ', heap_data);
@@ -445,6 +457,7 @@
 	dglInt32_t v, dist, conns;
 	int new_conns, walk_conns, update;
 	    break;
 	v = ((neta_heap_data *) (heap_node.value.pv))->v;
@@ -465,6 +478,7 @@
 	    for (i = 0; i < timetable->walk_length[v]; i++) {
 		int to = timetable->walk_stops[v][i];
 		int new_dst = dist + timetable->walk_times[v][i];
 		NetA_update_dijkstra(conns, walk_conns, to, new_dst, v, -2,
 				     rows, update, result, &heap);
@@ -476,6 +490,7 @@
 	for (i = 0; i < timetable->stop_length[v]; i++)
 	    if (timetable->stop_times[v][i] >= dist + min_change) {
 		int route = timetable->stop_routes[v][i];
 		/*find the index of v on the route */
 		for (j = 0; j < timetable->route_length[route]; j++)
 		    if (timetable->route_stops[route][j] == v)
@@ -483,6 +498,7 @@
 		j++;
 		for (; j < timetable->route_length[route]; j++) {
 		    int to = timetable->route_stops[route][j];
 		    NetA_update_dijkstra(conns, new_conns, to,
 					 timetable->route_times[route][j], v,
 					 route, rows, 1, result, &heap);
@@ -504,21 +520,22 @@
-  \brief Get time
+   \brief Get time
-  Get time when route "route" arrives at stop "stop" or -1.
+   Get time when route "route" arrives at stop "stop" or -1.
-  \param stop 'stop' node id
-  \param route route id
+   \param stop 'stop' node id
+   \param route route id
-  \return time
-  \return -1 if not found
+   \return time
+   \return -1 if not found
 int NetA_timetable_get_route_time(neta_timetable * timetable, int stop,
 				  int route)
     int i;
     for (i = 0; i < timetable->route_length[route]; i++)
 	if (timetable->route_stops[route][i] == stop)
 	    return timetable->route_times[route][i];
@@ -526,13 +543,14 @@
-  \brief Free neta_timetable_result structure
-  \param result pointer to neta_timetable_result structure
+   \brief Free neta_timetable_result structure
+   \param result pointer to neta_timetable_result structure
 void NetA_timetable_result_release(neta_timetable_result * result)
     int i;
     for (i = 0; i < result->rows; i++) {
 	G_free(result->dst[i]);
 	G_free(result->prev_stop[i]);
Modified: grass/trunk/lib/vector/neta/utils.c
--- grass/trunk/lib/vector/neta/utils.c	2010-04-10 15:12:32 UTC (rev 41777)
+++ grass/trunk/lib/vector/neta/utils.c	2010-04-10 15:16:06 UTC (rev 41778)
@@ -1,18 +1,18 @@
-  \brief Network Analysis library - utils
-  Utils subroutines.
+   \brief Network Analysis library - utils
+   Utils subroutines.
 #include <stdio.h>
 #include <stdlib.h>
@@ -23,20 +23,21 @@
-  \brief Writes point
+   \brief Writes point
-  Writes GV_POINT to Out at the position of the node in <em>In</em>.
-  \param In pointer to Map_info structure (input vector map)
-  \param[in,out] Out pointer to Map_info structure (output vector map)
-  \param node node id
-  \param Cats pointer to line_cats structures
-void NetA_add_point_on_node(struct Map_info *In, struct Map_info *Out, int node,
-			    struct line_cats *Cats)
+   Writes GV_POINT to Out at the position of the node in <em>In</em>.
+   \param In pointer to Map_info structure (input vector map)
+   \param[in,out] Out pointer to Map_info structure (output vector map)
+   \param node node id
+   \param Cats pointer to line_cats structures
+void NetA_add_point_on_node(struct Map_info *In, struct Map_info *Out,
+			    int node, struct line_cats *Cats)
     static struct line_pnts *Points;
     double x, y, z;
     Points = Vect_new_line_struct();
     Vect_get_node_coor(In, node, &x, &y, &z);
     Vect_reset_line(Points);
@@ -62,16 +63,17 @@
-  \brief Finds node
+   \brief Finds node
-  Find the node corresponding to each point in the point_list
-  \param point_list list of points (their ids)
+   Find the node corresponding to each point in the point_list
+   \param point_list list of points (their ids)
 void NetA_points_to_nodes(struct Map_info *In, struct ilist *point_list)
     int i, node;
     for (i = 0; i < point_list->n_values; i++) {
 	Vect_get_line_nodes(In, point_list->value[i], &node, NULL);
 	point_list->value[i] = node;
@@ -79,23 +81,23 @@
-  \brief Get node cost
+   \brief Get node cost
-  For each node in the map, finds the category of the point on it (if
-  there is any) and stores the value associated with this category in
-  the array node_costs. If there is no point with a category,
-  node_costs=0.
-  node_costs are multiplied by 1000000 and truncated to integers (as
-  is done in Vect_net_build_graph)
-  \param layer layer number
-  \param column name of column
-  \param[out] node_costs list of node costs
+   For each node in the map, finds the category of the point on it (if
+   there is any) and stores the value associated with this category in
+   the array node_costs. If there is no point with a category,
+   node_costs=0.
-  \returns 1 on success
-  \return 0 on failure
+   node_costs are multiplied by 1000000 and truncated to integers (as
+   is done in Vect_net_build_graph)
+   \param layer layer number
+   \param column name of column
+   \param[out] node_costs list of node costs
+   \returns 1 on success
+   \return 0 on failure
 int NetA_get_node_costs(struct Map_info *In, int layer, char *column,
 			int *node_costs)
@@ -107,6 +109,7 @@
     dbDriver *driver;
     Fi = Vect_get_field(In, layer);
     if (driver == NULL)
@@ -127,9 +130,11 @@
 	return 0;
     for (i = 1; i <= nlines; i++) {
 	int type = Vect_read_line(In, Points, Cats, i);
 	if (type == GV_POINT) {
 	    int node, cat;
 	    double value;
 	    if (!Vect_cat_get(Cats, layer, &cat))
 		continue;
 	    Vect_get_line_nodes(In, i, &node, NULL);
@@ -145,23 +150,24 @@
-  \brief Get list of nodes from varray
+   \brief Get list of nodes from varray
-  Returns the list of all nodes on features selected by varray.
-  nodes_to_features conains the index of a feature adjecent to each
-  node or -1 if no such feature specified by varray
-  exists. Nodes_to_features might be NULL, in which case it is left
-  unitialised.
+   Returns the list of all nodes on features selected by varray.
+   nodes_to_features conains the index of a feature adjecent to each
+   node or -1 if no such feature specified by varray
+   exists. Nodes_to_features might be NULL, in which case it is left
+   unitialised.
-  \param map pointer to Map_info structure
-  \param varray pointer to varray structure
-  \param[out] nodes list of node ids
-  \param node_to_features ?
-void NetA_varray_to_nodes(struct Map_info *map, struct varray * varray,
+   \param map pointer to Map_info structure
+   \param varray pointer to varray structure
+   \param[out] nodes list of node ids
+   \param node_to_features ?
+void NetA_varray_to_nodes(struct Map_info *map, struct varray *varray,
 			  struct ilist *nodes, int *nodes_to_features)
     int nlines, nnodes, i;
     nlines = Vect_get_num_lines(map);
     nnodes = Vect_get_num_nodes(map);
     if (nodes_to_features)
@@ -171,8 +177,10 @@
 	if (varray->c[i]) {
 	    int type = Vect_read_line(map, NULL, NULL, i);
 		int node;
 		Vect_get_line_nodes(map, i, &node, NULL);
 		Vect_list_append(nodes, node);
@@ -180,6 +188,7 @@
 	    else {
 		int node1, node2;
 		Vect_get_line_nodes(map, i, &node1, &node2);
 		Vect_list_append(nodes, node1);
 		Vect_list_append(nodes, node2);
@@ -190,27 +199,26 @@
-  \brief Initialize varray
+   \brief Initialize varray
-  \param mask_type ?
-  \param where where statement
-  \param cat ?
-  \param[out] pointer to varray structure
+   \param mask_type ?
+   \param where where statement
+   \param cat ?
+   \param[out] pointer to varray structure
-  \return ?
+   \return ?
 int NetA_initialise_varray(struct Map_info *In, int layer, int mask_type,
-			   char *where, char *cat, struct varray ** varray)
+			   char *where, char *cat, struct varray **varray)
     /* parse filter option and select appropriate lines */
     if (where) {
 	if (layer < 1)
 	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
 	if (cat)
-	    G_warning(_
-		      ("'where' and 'cats' parameters were supplied, cat will be ignored"));
+	    G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
 	*varray = Vect_new_varray(Vect_get_num_lines(In));
 	if (Vect_set_varray_from_db
 	    (In, layer, where, mask_type, 1, *varray) == -1) {
