[GRASS-SVN] r41779 - in grass/trunk/lib: . vector vector/neta
svn_grass at osgeo.org
Sat Apr 10 11:36:51 EDT 2010
Author: martinl
Date: 2010-04-10 11:36:51 -0400 (Sat, 10 Apr 2010)
New Revision: 41779
Added:
grass/trunk/lib/vector/neta/netalib.dox
grass/trunk/lib/grasslib.dox
grass/trunk/lib/vector/Makefile
grass/trunk/lib/vector/neta/Makefile
netalib.dox file added
Modified: grass/trunk/lib/grasslib.dox
--- grass/trunk/lib/grasslib.dox 2010-04-10 15:16:06 UTC (rev 41778)
+++ grass/trunk/lib/grasslib.dox 2010-04-10 15:36:51 UTC (rev 41779)
@@ -108,6 +108,7 @@
- vask: Cursor management library - \ref vask
- %vector: \ref vectorlib (GRASS Vector and Direct Graph Library)
- vedit: \ref veditlib - %vector editing
+ - neta: \ref netalib
- nviz: \ref nvizlib (used by wxGUI Nviz extension and CLI-based Nviz module)
<!--<li>image3: extra imagery library (mainly still unused) - \ref image3lib-->
<!--<li>D: display library - \ref d_displaylib-->
Modified: grass/trunk/lib/vector/Makefile
--- grass/trunk/lib/vector/Makefile 2010-04-10 15:16:06 UTC (rev 41778)
+++ grass/trunk/lib/vector/Makefile 2010-04-10 15:36:51 UTC (rev 41779)
@@ -5,7 +5,8 @@
diglib \
Vlib \
transform \
- vedit
+ vedit \
+ neta
#doxygen:
DOXNAME=vector
Modified: grass/trunk/lib/vector/neta/Makefile
--- grass/trunk/lib/vector/neta/Makefile 2010-04-10 15:16:06 UTC (rev 41778)
+++ grass/trunk/lib/vector/neta/Makefile 2010-04-10 15:36:51 UTC (rev 41779)
@@ -11,3 +11,5 @@
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
default: lib
+DOXNAME=neta
\ No newline at end of file
Added: grass/trunk/lib/vector/neta/netalib.dox
--- grass/trunk/lib/vector/neta/netalib.dox (rev 0)
+++ grass/trunk/lib/vector/neta/netalib.dox 2010-04-10 15:36:51 UTC (rev 41779)
@@ -0,0 +1,45 @@
+/*! \page netalib GRASS Network Analysis Library
+by GRASS Development Team (http://grass.osgeo.org)
+This library is used for network-based analysis, see <tt>v.net.*</tt>
+modules for implementation issues.
+\section netaFn Functions
+- NetA_add_point_on_node()
+- NetA_allpairs()
+- NetA_articulation_points()
+- NetA_betweenness_closeness()
+- NetA_compute_bridges()
+- NetA_degree_centrality()
+- NetA_distance_from_points()
+- NetA_eigenvector_centrality()
+- NetA_find_path()
+- NetA_flow()
+- NetA_get_node_costs()
+- NetA_initialise_varray()
+- NetA_init_timetable_from_db()
+- NetA_min_cut()
+- NetA_points_to_nodes()
+- NetA_spanning_tree()
+- NetA_split_vertices()
+- NetA_strongly_connected_components()
+- NetA_timetable_get_route_time()
+- NetA_timetable_result_release()
+- NetA_timetable_shortest_path()
+- NetA_varray_to_nodes()
+- NetA_weakly_connected_components()
+\section netaAuthors Authors
+ Daniel Bundala (Google Summer of Code 2009)
+\section netaSeeAlso See Also
+ - \ref vectorlib
+ - \ref dbmilib
+Last change: $Date$
Property changes on: grass/trunk/lib/vector/neta/netalib.dox
___________________________________________________________________
Added: svn:mime-type
+ text/x-plain
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
