[GRASS-SVN] r41821 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Mon Apr 12 12:42:08 EDT 2010
Author: martinl
Date: 2010-04-12 12:42:08 -0400 (Mon, 12 Apr 2010)
New Revision: 41821
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: export to Python script
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-12 15:07:10 UTC (rev 41820)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-12 16:42:08 UTC (rev 41821)
@@ -25,6 +25,8 @@
import shlex
import time
import traceback
+import getpass
+import stat
try:
import xml.etree.ElementTree as etree
@@ -348,6 +350,120 @@
message = _('Model is valid.'),
msgType = 'info')
+ def OnExportPython(self, event):
+ """!Export model to Python script"""
+ filename = ''
+ dlg = wx.FileDialog(parent = self,
+ message = _("Choose file to save"),
+ defaultDir = os.getcwd(),
+ wildcard=_("Python script (*.py)|*.py"),
+ style=wx.FD_SAVE)
+ if dlg.ShowModal() == wx.ID_OK:
+ filename = dlg.GetPath()
+ if not filename:
+ return
+ # check for extension
+ if filename[-3:] != ".py":
+ filename += ".py"
+ if os.path.exists(filename):
+ dlg = wx.MessageDialog(self, message=_("File <%s> already exists. "
+ "Do you want to overwrite this file?") % filename,
+ caption=_("Save file"),
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_NO:
+ dlg.Destroy()
+ return
+ dlg.Destroy()
+ fd = open(filename, "w")
+ try:
+ self._writePython(fd)
+ finally:
+ fd.close()
+ # executable file
+ os.chmod(filename, stat.S_IRWXU | stat.S_IWUSR)
+ def _writePython(self, fd):
+ """!Write model to file"""
+ fd.write(
+r"""#!/usr/bin/env python
+# MODULE: Graphical modeler script
+# AUTHOR(S): %s
+# PURPOSE: Script generated by wxGUI Graphical Modeler
+# DATE: %s
+""" % (getpass.getuser(), time.asctime()))
+ fd.write(
+r"""
+import sys
+import os
+import grass.script as grass
+import atexit
+ fd.write(
+r"""
+def cleanup():
+ pass
+ fd.write("\ndef main():\n")
+ for action in self.actions:
+ task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
+ show = None)
+ opts = task.get_options()
+ flags = ''
+ params = list()
+ strcmd = " grass.run_command("
+ indent = len(strcmd)
+ fd.write(strcmd + "'%s',\n" % task.get_name())
+ for f in opts['flags']:
+ if f.get('value', False) == True:
+ name = f.get('name', '')
+ if len(name) > 1:
+ params.append('%s=True' % name)
+ else:
+ flags += name
+ for p in opts['params']:
+ name = p.get('name', None)
+ value = p.get('value', None)
+ if name and value:
+ ptype = p.get('type', 'string')
+ if ptype == 'string':
+ params.append("%s='%s'" % (name, value))
+ else:
+ params.append("%s=%s" % (name, value))
+ for opt in params[:-1]:
+ fd.write("%s%s,\n" % (' ' * indent, opt))
+ fd.write("%s%s)\n" % (' ' * indent, params[-1]))
+ fd.write("\n return 0\n")
+ fd.write(
+r"""
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
def _validateModel(self):
"""!Validate model"""
self.SetStatusText(_('Validating model...'), 0)
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-12 15:07:10 UTC (rev 41820)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-12 16:42:08 UTC (rev 41821)
@@ -33,6 +33,12 @@
</menuitem>
<separator />
<menuitem>
+ <label>Export to Python</label>
+ <help>Export model to Python script</help>
+ <handler>OnExportPython</handler>
+ </menuitem>
+ <separator />
+ <menuitem>
<label>Close modeler</label>
<help>Close modeler window</help>
<handler>OnCloseWindow</handler>
