[GRASS-SVN] r41822 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules xml
svn_grass at osgeo.org
Mon Apr 12 12:42:47 EDT 2010
Author: martinl
Date: 2010-04-12 12:42:47 -0400 (Mon, 12 Apr 2010)
New Revision: 41822
Added:
grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass-gxm.dtd added, some tags renamed
(merge r41820 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-12 16:42:08 UTC (rev 41821)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-12 16:42:47 UTC (rev 41822)
@@ -1133,7 +1133,7 @@
"""!Process model file"""
for data in self.root.findall('data'):
pos, size = self._getDim(data)
- param = data.find('parameter')
+ param = data.find('data-parameter')
name = prompt = value = None
if param is not None:
name = param.get('name', None)
@@ -1142,7 +1142,7 @@
aId = list()
fromDir = list()
- for action in data.findall('action'):
+ for action in data.findall('data-action'):
aId.append(int(action.get('id', None)))
if action.get('dir', 'to') == 'to':
fromDir.append(False)
@@ -1256,23 +1256,22 @@
(' ' * self.indent, data.GetX(), data.GetY(),
data.GetWidth(), data.GetHeight()))
self.indent += 4
- self.fd.write('%s<parameter name="%s" prompt="%s">\n' % \
+ self.fd.write('%s<data-parameter name="%s" prompt="%s">\n' % \
(' ' * self.indent, data.GetName(), data.GetPrompt()))
self.indent += 4
self.fd.write('%s<value>%s</value>\n' %
(' ' * self.indent, self._filterValue(data.GetValue())))
self.indent -= 4
- self.fd.write('%s</parameter>\n' % (' ' * self.indent))
- self.indent -= 4
+ self.fd.write('%s</data-parameter>\n' % (' ' * self.indent))
for action in data.GetActions('from'):
id = action.GetId()
- self.fd.write('%s<action id="%d" dir="from" />\n' % \
+ self.fd.write('%s<data-action id="%d" dir="from" />\n' % \
(' ' * self.indent, id))
for action in data.GetActions('to'):
id = action.GetId()
- self.fd.write('%s<action id="%d" dir="to" />\n' % \
+ self.fd.write('%s<data-action id="%d" dir="to" />\n' % \
+ self.indent -= 4
self.fd.write('%s</data>\n' % (' ' * self.indent))
self.indent -= 4
Copied: grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd (from rev 41820, grass/trunk/gui/wxpython/xml/grass-gxm.dtd)
--- grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd 2010-04-12 16:42:47 UTC (rev 41822)
@@ -0,0 +1,63 @@
+<!-- grass-gxm.dtd
+ Copyright (C) 2010 by the GRASS Development Team
+ Author: Martin Landa <landa.martin gmail.com>
+ This program is free software under the GPL (>=v2)
+ Read the file COPYING coming with GRASS for details.
+ grass-gxm defines model file content
+<!ELEMENT grass-gxm (gxm)>
+<!ELEMENT gxm (action*, data*)>
+<!-- an action defines action properties (usually GRASS modules)
+<!ELEMENT action (task)>
+<!ATTLIST action id CDATA #REQUIRED>
+<!ATTLIST action name CDATA #REQUIRED>
+<!ATTLIST action pos CDATA #REQUIRED>
+<!ATTLIST action size CDATA #REQUIRED>
+<!-- a task describes the interface of a single
+ GRASS command
+<!ELEMENT task (flag*, parameter*)>
+<!ATTLIST task name CDATA #REQUIRED>
+<!-- a parameter must have a name and a value
+<!ELEMENT parameter (value)>
+<!ATTLIST parameter name CDATA #REQUIRED>
+<!-- value of parameter
+<!ELEMENT value (#PCDATA)>
+<!-- enabled flag
+<!ELEMENT flag EMPTY>
+<!ATTLIST flag name CDATA #REQUIRED>
+<!-- a data defines data properties (usually data layers)
+<!ELEMENT data (data-parameter, data-action*)>
+<!ATTLIST data pos CDATA #REQUIRED>
+<!ATTLIST data size CDATA #REQUIRED>
+<!-- a data-parameter defines data items properties
+<!ELEMENT data-parameter (value)>
+<!ATTLIST data-parameter name CDATA #REQUIRED>
+<!ATTLIST data-parameter prompt CDATA #REQUIRED>
+<!-- a data-action defines relation between data and actions
+<!ELEMENT data-action EMPTY>
+<!ATTLIST data-action id CDATA #REQUIRED>
+<!ATTLIST data-action dir (from | to) #REQUIRED>
