[GRASS-SVN] r41847 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Apr 13 13:41:23 EDT 2010
Author: martinl
Date: 2010-04-13 13:41:22 -0400 (Tue, 13 Apr 2010)
New Revision: 41847
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
wxGUI/modeler: improvements in search dialog
(merge r41846 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-13 17:27:13 UTC (rev 41846)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-13 17:41:22 UTC (rev 41847)
@@ -567,7 +567,7 @@
if p.get('prompt', '') in ('raster', 'vector', 'raster3d'):
try:
name, mapset = p.get('value', '').split('@', 1)
- except IndexError:
+ except (ValueError, IndexError):
continue
if mapset != grass.gisenv()['MAPSET']:
@@ -1124,15 +1124,28 @@
_("keywords")])
self.search = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
value = "", size = (-1, 25))
+ self.searchTip = menuform.StaticWrapText(parent = self.panel, id = wx.ID_ANY,
+ size = (-1, 35))
+ self.searchChoice = wx.Choice(parent = self.panel, id = wx.ID_ANY)
self.cmd_prompt = prompt.GPromptSTC(parent = self)
+ # get commands
+ items = self.cmd_prompt.GetCommandItems()
+ self.searchTip.SetLabel(_("%d modules found") % len(items))
+ self.searchChoice.SetItems(items)
self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
self.btnOk = wx.Button(self.panel, wx.ID_OK)
self.btnOk.SetDefault()
+ self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
+ self.searchChoice.Bind(wx.EVT_CHOICE, self.OnSelectModule)
self._layout()
- self.SetSize((500, 200))
+ self.SetSize((500, 250))
def _layout(self):
btnSizer = wx.StdDialogButtonSizer()
@@ -1141,18 +1154,26 @@
btnSizer.Realize()
findSizer = wx.StaticBoxSizer(self.findBox, wx.HORIZONTAL)
+ gridSizer = wx.GridBagSizer(hgap = 3, vgap = 3)
+ gridSizer.AddGrowableCol(1)
cmdSizer = wx.StaticBoxSizer(self.cmdBox, wx.VERTICAL)
- findSizer.Add(item = self.searchBy,
- proportion = 0, flag = wx.ALL, border = 1)
- findSizer.Add(item = self.search,
- proportion = 1, flag = wx.ALL, border = 1)
+ gridSizer.Add(item = self.searchBy,
+ flag=wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ gridSizer.Add(item = self.search,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (0, 1))
+ gridSizer.Add(item = self.searchTip,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (1, 0), span = (1, 2))
+ gridSizer.Add(item = self.searchChoice,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (2, 0), span = (1, 2))
+ findSizer.Add(item = gridSizer, proportion = 1)
cmdSizer.Add(item=self.cmd_prompt, proportion=1,
flag=wx.EXPAND | wx.ALL, border=1)
mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=findSizer, proportion=1,
+ mainSizer.Add(item=findSizer, proportion=0,
flag=wx.EXPAND | wx.ALL, border=5)
mainSizer.Add(item=cmdSizer, proportion=1,
flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
@@ -1163,7 +1184,7 @@
mainSizer.Fit(self.panel)
self.Layout()
def GetPanel(self):
"""!Get dialog panel"""
return self.panel
@@ -1181,6 +1202,52 @@
return cmd
+ def OnSearchModule(self, event):
+ """!Search module by keywords or description"""
+ text = event.GetString()
+ if not text:
+ self.cmd_prompt.SetFilter(None)
+ return
+ modules = dict()
+ iFound = 0
+ for module, data in self.cmd_prompt.moduleDesc.iteritems():
+ found = False
+ if self.searchBy.GetSelection() == 0: # -> description
+ if text in data['desc']:
+ found = True
+ else: # -> keywords
+ if self.cmd_prompt.CheckKey(text, data['keywords']):
+ found = True
+ if found:
+ iFound += 1
+ try:
+ group, name = module.split('.')
+ except ValueError:
+ continue # TODO
+ if not modules.has_key(group):
+ modules[group] = list()
+ modules[group].append(name)
+ self.cmd_prompt.SetFilter(modules)
+ self.searchTip.SetLabel(_("%d modules found") % iFound)
+ self.searchChoice.SetItems(self.cmd_prompt.GetCommandItems())
+ def OnSelectModule(self, event):
+ """!Module selected from choice, update command prompt"""
+ cmd = event.GetString().split(' ', 1)[0]
+ text = cmd + ' '
+ pos = len(text)
+ self.cmd_prompt.SetText(text)
+ self.cmd_prompt.SetSelectionStart(pos)
+ self.cmd_prompt.SetCurrentPos(pos)
+ self.cmd_prompt.SetFocus()
+ desc = self.cmd_prompt.GetCommandDesc(cmd)
+ self.searchTip.SetLabel(desc)
def OnOk(self, event):
self.btnOk.SetFocus()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-04-13 17:27:13 UTC (rev 41846)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-04-13 17:41:22 UTC (rev 41847)
@@ -1921,29 +1921,33 @@
return None
class StaticWrapText(wx.StaticText):
+ """! A Static Text field that wraps its text to fit its width,
+ enlarging its height if necessary.
- A Static Text field that wraps its text to fit its width, enlarging its height if necessary.
- def __init__(self, parent, id=wx.ID_ANY, label=u'', *args, **kwds):
+ def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
+ self.parent = parent
self.originalLabel = label
- wx.StaticText.__init__(self, parent, id, u'', *args, **kwds)
+ wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
self.SetLabel(label)
- self.Bind(wx.EVT_SIZE, self.onResize)
+ self.Bind(wx.EVT_SIZE, self.OnResize)
def SetLabel(self, label):
self.wrappedSize = None
- #self.onResize(None)
- def onResize(self, event):
+ self.OnResize(None)
+ def OnResize(self, event):
if not getattr(self, "resizing", False):
self.resizing = True
- newSize = self.GetSize()
+ newSize = wx.Size(self.parent.GetSize().width,
+ self.GetSize().height)
if self.wrappedSize != newSize:
wx.StaticText.SetLabel(self, self.originalLabel)
self.Wrap(newSize.width)
- self.wrappedSize = self.GetMinSize()
+ self.wrappedSize = newSize
self.SetSize(self.wrappedSize)
del self.resizing
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-04-13 17:27:13 UTC (rev 41846)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-04-13 17:41:22 UTC (rev 41847)
@@ -544,7 +544,33 @@
fileHistory.close()
return hist
+ def GetCommandDesc(self, cmd):
+ """!Get description for given command"""
+ if self.moduleDesc.has_key(cmd):
+ return self.moduleDesc[cmd]['desc']
+ return ''
+ def GetCommandItems(self):
+ """!Get list of available commands"""
+ items = list()
+ if self.autoCompFilter:
+ mList = self.autoCompFilter
+ else:
+ mList = self.moduleList
+ prefixes = mList.keys()
+ prefixes.sort()
+ for prefix in prefixes:
+ for command in mList[prefix]:
+ name = prefix + '.' + command
+ items.append(name)
+ return items
def _getListOfModules(self):
"""!Get list of modules"""
result = dict()
