[GRASS-SVN] r41848 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Apr 13 14:36:19 EDT 2010
Author: martinl
Date: 2010-04-13 14:36:19 -0400 (Tue, 13 Apr 2010)
New Revision: 41848
grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
wxGUI/modeler: more Windows fixes
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-04-13 17:41:22 UTC (rev 41847)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2010-04-13 18:36:19 UTC (rev 41848)
@@ -117,29 +117,31 @@
EXT_SCT = ''
def GetGRASSCmds(bin=True, scripts=True, gui_scripts=True):
- Create list of all available GRASS commands to use when
+ """!Create list of all available GRASS commands to use when
parsing string from the command line
gisbase = os.environ['GISBASE']
- list = []
+ cmd = list()
if bin is True:
- list = os.listdir(os.path.join(gisbase, 'bin'))
+ for file in os.listdir(os.path.join(gisbase, 'bin')):
+ if not EXT_BIN or file[-4:] == EXT_BIN:
+ cmd.append(file)
# add special call for setting vector colors
- list.append('vcolors')
+ cmd.append('vcolors')
if scripts is True:
- list = list + os.listdir(os.path.join(gisbase, 'scripts'))
+ cmd = cmd + os.listdir(os.path.join(gisbase, 'scripts'))
if gui_scripts is True:
os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
- list = list + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
+ cmd = cmd + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
if subprocess.mswindows:
- for idx in range(len(list)):
- list[idx] = list[idx].replace(EXT_BIN, '')
- list[idx] = list[idx].replace(EXT_SCT, '')
+ for idx in range(len(cmd)):
+ cmd[idx] = cmd[idx].replace(EXT_BIN, '')
+ cmd[idx] = cmd[idx].replace(EXT_SCT, '')
+ return cmd
- return list
"""@brief Collected GRASS-relared binaries/scripts"""
grassCmd = {}
grassCmd['all'] = GetGRASSCmds()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-13 17:41:22 UTC (rev 41847)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-13 18:36:19 UTC (rev 41848)
@@ -110,6 +110,10 @@
self.SetMinSize((350, 200))
self.SetSize((640, 480))
+ # fix goutput's pane size
+ if self.goutput:
+ self.goutput.SetSashPosition(int(self.GetSize()[1] * .75))
def _layout(self):
"""!Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -556,7 +560,7 @@
info.SetWebSite('http://grass.osgeo.org')
info.SetDescription(_('(C) 2010 by the GRASS Development Team\n\n') +
'\n'.join(textwrap.wrap(_('This program is free software under the GNU General Public License'
- '(>=v2). Read the file COPYING that comes with GRASS for details.'), 100)))
+ '(>=v2). Read the file COPYING that comes with GRASS for details.'), 75)))
wx.AboutBox(info)
@@ -1122,6 +1126,7 @@
self.searchBy = wx.Choice(parent = self.panel, id = wx.ID_ANY,
choices = [_("description"),
_("keywords")])
+ self.searchBy.SetSelection(0)
self.search = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
value = "", size = (-1, 25))
self.searchTip = menuform.StaticWrapText(parent = self.panel, id = wx.ID_ANY,
@@ -1145,7 +1150,7 @@
self._layout()
- self.SetSize((500, 250))
+ self.SetSize((500, 275))
def _layout(self):
btnSizer = wx.StdDialogButtonSizer()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py 2010-04-13 17:41:22 UTC (rev 41847)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py 2010-04-13 18:36:19 UTC (rev 41848)
@@ -82,6 +82,8 @@
_('help'),
_('command'),
_('keywords')])
+ self.searchBy.SetSelection(3)
value = "", size = (-1, 25),
style = wx.TE_PROCESS_ENTER)
