[GRASS-SVN] r41882 - grass/branches/develbranch_6/imagery/i.group
Fri Apr 16 03:35:19 EDT 2010
Author: hamish
Date: 2010-04-16 03:34:58 -0400 (Fri, 16 Apr 2010)
New Revision: 41882
   grass/branches/develbranch_6/imagery/i.group/main.c
remove problematic unused function (partial backport, see #1039)
Modified: grass/branches/develbranch_6/imagery/i.group/main.c
--- grass/branches/develbranch_6/imagery/i.group/main.c	2010-04-15 21:38:37 UTC (rev 41881)
+++ grass/branches/develbranch_6/imagery/i.group/main.c	2010-04-16 07:34:58 UTC (rev 41882)
@@ -39,7 +39,6 @@
 int main(int argc, char *argv[])
-    char title[80];
     char group[GNAME_MAX], mapset[GMAPSET_MAX];
     int m, k = 0;
@@ -102,9 +101,6 @@
     if (k < 1 && !l->answer)	/* remove if input is requirement */
 	G_fatal_error(_("No input raster map(s) specified"));
-    I_location_info(title, argv[0]);	/* unused? */
     /* check if current mapset:  (imagery libs are very lacking in this dept)
        - abort if not,
        - remove @mapset part if it is
