[GRASS-SVN] r41883 -
grass/branches/releasebranch_6_4/imagery/i.group
svn_grass at osgeo.org
Fri Apr 16 03:48:45 EDT 2010
Author: hamish
Date: 2010-04-16 03:48:24 -0400 (Fri, 16 Apr 2010)
New Revision: 41883
grass/branches/releasebranch_6_4/imagery/i.group/main.c
remove problematic unused function (partial backport, see #1039)
Modified: grass/branches/releasebranch_6_4/imagery/i.group/main.c
--- grass/branches/releasebranch_6_4/imagery/i.group/main.c 2010-04-16 07:34:58 UTC (rev 41882)
+++ grass/branches/releasebranch_6_4/imagery/i.group/main.c 2010-04-16 07:48:24 UTC (rev 41883)
@@ -39,7 +39,6 @@
int main(int argc, char *argv[])
- char title[80];
char group[GNAME_MAX], mapset[GMAPSET_MAX];
int m, k = 0;
@@ -102,9 +101,6 @@
if (k < 1 && !l->answer) /* remove if input is requirement */
G_fatal_error(_("No input raster map(s) specified"));
- I_location_info(title, argv[0]); /* unused? */
/* check if current mapset: (imagery libs are very lacking in this dept)
- abort if not,
- remove @mapset part if it is
