[GRASS-SVN] r41998 -
grass/branches/releasebranch_6_4/vector/v.random
svn_grass at osgeo.org
Fri Apr 23 10:02:12 EDT 2010
Author: martinl
Date: 2010-04-23 10:02:11 -0400 (Fri, 23 Apr 2010)
New Revision: 41998
grass/branches/releasebranch_6_4/vector/v.random/main.c
fix #1037
(merge r41996 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.random/main.c
--- grass/branches/releasebranch_6_4/vector/v.random/main.c 2010-04-23 13:37:33 UTC (rev 41997)
+++ grass/branches/releasebranch_6_4/vector/v.random/main.c 2010-04-23 14:02:11 UTC (rev 41998)
@@ -8,7 +8,7 @@
* PURPOSE: Randomly generate a 2D/3D GRASS vector points map.
- * COPYRIGHT: (C) 2003-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2007, 2010 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -99,6 +99,7 @@
parm.zmin->description =
_("Minimum z height (needs -z flag or column name)");
parm.zmin->answer = "0.0";
+ parm.zmin->guisection = _("3D output");
parm.zmax = G_define_option();
parm.zmax->key = "zmax";
@@ -107,19 +108,24 @@
parm.zmax->description =
_("Maximum z height (needs -z flag or column name)");
parm.zmax->answer = "0.0";
- parm.zcol = G_define_standard_option(G_OPT_COLUMN);
+ parm.zmax->guisection = _("3D output");
+ parm.zcol = G_define_option();
parm.zcol->key = "column";
+ parm.zcol->type = TYPE_STRING;
+ parm.zcol->multiple = NO;
parm.zcol->required = NO;
- parm.zcol->multiple = NO;
parm.zcol->label =
_("Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values");
parm.zcol->description =
- _("Writes Z data to column instead of 3D vector");
+ _("If type is not given then DOUBLE PRECISION is used. "
+ "Writes Z data to column instead of 3D vector.");
+ parm.zcol->guisection = _("3D output");
flag.z = G_define_flag();
flag.z->key = 'z';
flag.z->description = _("Create 3D output");
+ flag.z->guisection = _("3D output");
flag.drand48 = G_define_flag();
flag.drand48->key = 'd';
@@ -151,6 +157,8 @@
/* Do we need to write random values into attribute table? */
if (parm.zcol->answer) {
+ char **token = G_tokenize(parm.zcol->answer, " ");
Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
driver =
db_start_driver_open_database(Fi->driver,
@@ -163,8 +171,15 @@
db_begin_transaction(driver);
db_init_string(&sql);
- sprintf(buf, "create table %s (cat integer, %s double precision)", Fi->table,
- parm.zcol->answer);
+ if (G_number_of_tokens(token) > 1) {
+ sprintf(buf, "create table %s (cat integer, %s)", Fi->table,
+ parm.zcol->answer);
+ else {
+ G_verbose_message(_("Using 'double precision' for column <%s>"), parm.zcol->answer);
+ sprintf(buf, "create table %s (cat integer, %s double precision)", Fi->table,
db_set_string(&sql, buf);
Vect_map_add_dblink(&Out, 1, NULL, Fi->table, "cat", Fi->database,
Fi->driver);
@@ -219,6 +234,7 @@
G_fatal_error(_("You have created unsupported column type. This module supports only INTEGER"
" and DOUBLE PRECISION column types."));
+ G_free_tokens(token);
Vect_hist_command(&Out);
