[GRASS-SVN] r41999 - grass/trunk/vector/v.random
svn_grass at osgeo.org
Fri Apr 23 10:18:07 EDT 2010
Author: martinl
Date: 2010-04-23 10:18:04 -0400 (Fri, 23 Apr 2010)
New Revision: 41999
grass/trunk/vector/v.random/main.c
fix #1037 ('column_type' added)
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2010-04-23 14:02:11 UTC (rev 41998)
+++ grass/trunk/vector/v.random/main.c 2010-04-23 14:18:04 UTC (rev 41999)
@@ -21,7 +21,7 @@
* <25 Jun 1995> - new site API (jdm)
* <13 Sep 2000> - released under GPL
- * COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2010 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -67,7 +67,7 @@
struct GModule *module;
struct
- struct Option *output, *nsites, *zmin, *zmax, *zcol;
+ struct Option *output, *nsites, *zmin, *zmax, *zcol, *ztype;
} parm;
struct
@@ -83,6 +83,7 @@
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("statistics"));
+ G_add_keyword(_("random"));
module->description = _("Generates randomly 2D/3D vector points map.");
parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -112,12 +113,21 @@
parm.zmax->guisection = _("3D output");
parm.zcol = G_define_standard_option(G_OPT_DB_COLUMN);
- parm.zcol->label =
- _("Name of column for z values (only numeric type)");
+ parm.zcol->label = _("Name of column for z values");
parm.zcol->description =
_("Writes z values to column instead of 3D vector");
parm.zcol->guisection = _("3D output");
+ parm.ztype = G_define_option();
+ parm.ztype->key = "column_type";
+ parm.ztype->type = TYPE_STRING;
+ parm.ztype->required = NO;
+ parm.ztype->multiple = NO;
+ parm.ztype->description = _("Type of column for z values");
+ parm.ztype->options = "integer,double precision";
+ parm.ztype->answer = "double precision";
+ parm.ztype->guisection = _("3D output");
flag.z = G_define_flag();
flag.z->key = 'z';
flag.z->description = _("Create 3D output");
@@ -165,8 +175,8 @@
db_begin_transaction(driver);
db_init_string(&sql);
- sprintf(buf, "create table %s (cat integer, %s double precision)", Fi->table,
- parm.zcol->answer);
+ sprintf(buf, "create table %s (cat integer, %s %s)", Fi->table,
+ parm.zcol->answer, parm.ztype->answer);
db_set_string(&sql, buf);
Vect_map_add_dblink(&Out, 1, NULL, Fi->table, "cat", Fi->database,
Fi->driver);
