[GRASS-SVN] r42011 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Fri Apr 23 12:19:59 EDT 2010
Author: rashadkm
Date: 2010-04-23 12:19:59 -0400 (Fri, 23 Apr 2010)
New Revision: 42011
grass-addons/gui/wxpython/data_catalog/mapdisplay.py
modified headers
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-23 16:13:42 UTC (rev 42010)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py 2010-04-23 16:19:59 UTC (rev 42011)
@@ -5,14 +5,12 @@
management functions, and additional toolbars (vector digitizer, 3d
view).
-Can be used either from Layer Manager or as p.mon backend.
Classes:
+- Command
+- MapWindow
+- BufferedWindow
- MapFrame
-- MapApp
-Usage:
-python mapdisp.py monitor-identifier /path/to/command/file
(C) 2006-2009 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -4572,47 +4570,4 @@
# end of class MapFrame
-class MapApp(wx.App):
- MapApp class
- def OnInit(self):
- wx.InitAllImageHandlers()
- if __name__ == "__main__":
- Map = render.Map() # instance of Map class to render GRASS display output to PPM file
- else:
- Map = None
- self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map,
- size=globalvar.MAP_WINDOW_SIZE)
- #self.SetTopWindow(Map)
- self.mapFrm.Show()
- # redraw map, if new command appears
- self.redraw = False
- return 1
-# end of class MapApp
-if __name__ == "__main__":
- ###### SET command variable
- title = "title"
- cmdfilename = "cmdfilename"
- gm_map = MapApp(0)
- # set title
- gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " + title + " - Location: " + grass.gisenv()["LOCATION_NAME"]))
- gm_map.MainLoop()
- sys.exit(0)
