[GRASS-SVN] r42012 - grass-addons/raster/r.fuzzy.system
Sat Apr 24 04:02:12 EDT 2010
Author: jarekj71
Date: 2010-04-24 04:02:11 -0400 (Sat, 24 Apr 2010)
New Revision: 42012
   grass-addons/raster/r.fuzzy.system/description.html
   grass-addons/raster/r.fuzzy.system/main.c
   grass-addons/raster/r.fuzzy.system/map_parser.c
   grass-addons/raster/r.fuzzy.system/rule_parser.c
   grass-addons/raster/r.fuzzy.system/system.c
fix some memory leaks
Modified: grass-addons/raster/r.fuzzy.system/description.html
--- grass-addons/raster/r.fuzzy.system/description.html	2010-04-23 16:19:59 UTC (rev 42011)
+++ grass-addons/raster/r.fuzzy.system/description.html	2010-04-24 08:02:11 UTC (rev 42012)
@@ -44,7 +44,7 @@
 <P>An example of fuzzy rules definiton:
 <PRE>
-$ small {distance = high & elev = high};
+$ small {distance = high & elev = high}
 </PRE>
 </DD>
 <h2>ADVANCED OPTIONS</h2>
@@ -153,7 +153,7 @@
 <PRE>
 r.stream.extract elevation=elevation.10m at PERMANENT threshold=2000 stream_rast=streams direction=dirs
 r.stream.order stream=streams dir=dirs horton=horton
-r.mapcalc "horton3=if(horton>2,horton,null()"
+r.mapcalc "horton3=if(horton>2,horton,null())"
 r.stream.distance stream=streams dir=dirs dem=elevation.10m method=downstream distance=distance elevation=elevation
 </PRE>
@@ -178,14 +178,14 @@
 <P>RULES:
 <PRE>
 #flood.rul
-$ unprob {elevation = high & distance = far};
-$ prob {distance = near | elevation = low};
-$ veryprob {distance = near & elevation = low};
+$ unprob {elevation = high & distance = far}
+$ prob {distance = near | elevation = low}
+$ veryprob {distance = near & elevation = low}
 </PRE>
 finally we need run r.fuzzy.system:
 <PRE>
-r.fuzzy.system vars=flood.map rules=flod.rul output=flood
+r.fuzzy.system maps=flood.map rules=flod.rul output=flood
 </PRE>
 Resulting map should look like this below. Yellow color means no risk, red high risk, green, blue end so on moderate risk.
Modified: grass-addons/raster/r.fuzzy.system/main.c
--- grass-addons/raster/r.fuzzy.system/main.c	2010-04-23 16:19:59 UTC (rev 42011)
+++ grass-addons/raster/r.fuzzy.system/main.c	2010-04-24 08:02:11 UTC (rev 42012)
@@ -166,7 +166,8 @@
     if (multiple)
 	create_output_maps();
+	antecedents = (float *)G_malloc(nrules * sizeof(float));
     G_message("Calculate...");
     for (row = 0; row < nrows; ++row) {
@@ -217,6 +218,7 @@
 	G_close_cell(s_maps[i].cfd);
+    G_free(antecedents);
     G_free(out_buf);
     G_close_cell(outfd);
     G_short_history(output, "raster", &history);
Modified: grass-addons/raster/r.fuzzy.system/map_parser.c
--- grass-addons/raster/r.fuzzy.system/map_parser.c	2010-04-23 16:19:59 UTC (rev 42011)
+++ grass-addons/raster/r.fuzzy.system/map_parser.c	2010-04-24 08:02:11 UTC (rev 42012)
@@ -16,7 +16,7 @@
     fd = fopen(file, "r");
     if (!fd)
-	G_fatal_error(_("Cannot open varaible file '%s'"), file);
+	G_fatal_error(_("Cannot open map file '%s'"), file);
     fgetpos(fd, &init);
@@ -39,7 +39,7 @@
 	    continue;
 	if (*buf != '%' && *buf != '$')
-	    G_fatal_error(_("Wrong syntax at line %d: line must start with #, % or $ or be empty line"),
+	    G_fatal_error(_("Wrong syntax at line %d: line must start with <#>, <%> or <$> or be empty line"),
 			  line);
 	if (*buf == '%') {
@@ -109,7 +109,7 @@
 	    G_strcpy(set->setname, tmp);
 	else
 	    G_fatal_error(_("Map: <%s>, Membership: <%s>: Value name cannot be longer than 20 chars, but has %d chars"),
-			  mapname, tmp, strlen(tmp));
+			  mapname, tmp, (int)strlen(tmp));
     }				/* check length of fuzzy value */
     {				/* check if side is valid (both,left,right) */
Modified: grass-addons/raster/r.fuzzy.system/rule_parser.c
--- grass-addons/raster/r.fuzzy.system/rule_parser.c	2010-04-23 16:19:59 UTC (rev 42011)
+++ grass-addons/raster/r.fuzzy.system/rule_parser.c	2010-04-24 08:02:11 UTC (rev 42012)
@@ -64,7 +64,7 @@
     int done = 1;
     int stack_top;
     char tmp[30];
-    char opr[] = { '=', '&', '|', ';', '~', '(', ')', '{', '}' };
+    char opr[] = { '=', '&', '|', '~', '(', ')', '{', '}' };
     i = j = stack_top = 0;	/* variables of the while loop */
     char_strip(buf, '$');
@@ -136,7 +136,7 @@
-    {				/* adding weight */
+/*    {				 adding weight: not implemented yet
 	char local[900];
 	char weight[10];
@@ -150,7 +150,7 @@
 	if (s_rules[rule_num].weight <= 0.)
 	    G_fatal_error(_("Weight must be grater than 0 or non-number character"));
     {				/* check if rule syntax is proper and map names and vars values exist */
 	int k;
Modified: grass-addons/raster/r.fuzzy.system/system.c
--- grass-addons/raster/r.fuzzy.system/system.c	2010-04-23 16:19:59 UTC (rev 42011)
+++ grass-addons/raster/r.fuzzy.system/system.c	2010-04-24 08:02:11 UTC (rev 42012)
@@ -8,11 +8,11 @@
     int set_index;
     float consequent;
     float max_antecedent = 0;
+    float result;
     agregate = (float *)G_calloc(resolution, sizeof(float));
-    antecedents = (float *)G_malloc(nrules * sizeof(float));
-    if (coor_proc)
+    if (coor_proc) /* this is allocated only once */
 	visual_output = (float **)G_malloc(resolution * sizeof(float *));
     for (j = 0; j < nrules; ++j) {
@@ -53,7 +53,9 @@
 	for (i = 0; i < resolution; ++i)
 	    visual_output[i][j + 1] = agregate[i];
-    return defuzzify(agregate, defuzzyfication, max_antecedent);
+     result=defuzzify(agregate, defuzzyfication, max_antecedent);
+     G_free(agregate);
+     return result;
 float parse_expression(int n)
