[GRASS-SVN] r42013 - in grass-addons/ossim_grass: . ossim_grass
ossim_grass/r.planet ossim_grass/v.planet
svn_grass at osgeo.org
Sat Apr 24 06:44:20 EDT 2010
Author: epifanio
Date: 2010-04-24 06:44:19 -0400 (Sat, 24 Apr 2010)
New Revision: 42013
Added:
grass-addons/ossim_grass/ossim_grass/
grass-addons/ossim_grass/ossim_grass/Makefile
grass-addons/ossim_grass/ossim_grass/r.planet/
grass-addons/ossim_grass/ossim_grass/r.planet/Makefile
grass-addons/ossim_grass/ossim_grass/r.planet/description.html
grass-addons/ossim_grass/ossim_grass/r.planet/r.planet.py
grass-addons/ossim_grass/ossim_grass/v.planet/
grass-addons/ossim_grass/ossim_grass/v.planet/Makefile
grass-addons/ossim_grass/ossim_grass/v.planet/description.html
grass-addons/ossim_grass/ossim_grass/v.planet/ogrTovrt.py
grass-addons/ossim_grass/ossim_grass/v.planet/v.planet.py
Added: grass-addons/ossim_grass/ossim_grass/Makefile
--- grass-addons/ossim_grass/ossim_grass/Makefile (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/Makefile 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ..
+SUBDIRS = \
+ r.planet \
+ v.planet
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: htmldir
+htmldir: subdirs
+clean: cleansubdirs
Added: grass-addons/ossim_grass/ossim_grass/r.planet/Makefile
--- grass-addons/ossim_grass/ossim_grass/r.planet/Makefile (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/r.planet/Makefile 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.planet.py
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/ossim_grass/ossim_grass/r.planet/description.html
--- grass-addons/ossim_grass/ossim_grass/r.planet/description.html (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/r.planet/description.html 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,42 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.planet.py : </b></em> Scripts to :
+<p>
+- generate vrt layer from a selected grass raster layer and add/zoomTo/remove the data from/to ossimplanet using the ossimplanet tcp listner.
+<p>
+- generate ossimplanet 3d tiles from elevation data.
+<h2>EXAMPLE</h2>
+Add selected map to ossimplanet screen and zoom to it :
+<div class="code"><pre>
+r.planet.py map=elevation.10m -a
+</pre></div>
+<p>
+Remove selected map from ossimplanet screen :
+r.planet.py map=elevation.10m -r
+</pre></div>
+<p>
+Generate 3D tiles :
+r.planet.py map=elevation.10m -d tile=3601
+</pre></div>
+<p>
+<h2>REFERENCES</h2>
+<em><A HREF="http://web.me.com/epiesasha/PlanetSasha/">PlanetSasha</A></em> Google Summer of Code - OSGEO - Massimo Di Stefano.
+<h2>SEE ALSO</h2>
+<em><A HREF="v.planet.html">v.planet.py</A></em>
+<H2>AUTHOR</H2>
+Massimo Di Stefano - <EM><A HREF="mailto:massimodisasha at gmail.com">@-mail</A></EM> <br>
+<p><i>Last changed: $Date: 2010-02-07 00:45:10 +0200 (Mon, 9 Feb 2010) $</i>
Added: grass-addons/ossim_grass/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/ossim_grass/r.planet/r.planet.py (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/r.planet/r.planet.py 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,370 @@
+#!/usr/bin/env python
+# MODULE: r.planet.py
+# AUTHOR(S): Massimo Di Stefano 2010-02-7
+# PURPOSE:
+# COPYRIGHT: (c) 2010 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# REQUIRES: Ossimplanet
+#%module
+#% description:
+#% keywords: raster
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,raster,raster
+#% key_desc: name
+#% description: Name of raster map
+#% required: yes
+#%end
+#%option
+#% key: host
+#% type: string
+#% key_desc: host
+#% answer: 127.0.0.1
+#% description: Host
+#% required : no
+#%end
+#%option
+#% key: dport
+#% type: integer
+#% key_desc: dport
+#% answer: 8000
+#% description: Data Port
+#% required : no
+#%end
+#%option
+#% key: pport
+#% type: integer
+#% key_desc: port
+#% answer: 7000
+#% description: Position Port
+#% required : no
+#%end
+#%option
+#% key: np
+#% type: integer
+#% key_desc: Processor-Number
+#% answer: 0
+#% description: Mpi Processor Number
+#% required : no
+#%end
+#%option
+#% key: tile
+#% type: double
+#% key_desc: tile
+#% description: tile
+#% required : no
+#%end
+#%flag
+#% key: a
+#% description: Add raster
+#%END
+#%flag
+#% key: r
+#% description: Remove raster
+#%END
+#%flag
+#% key: d
+#% description: Orthoigen
+#%END
+#%flag
+#% key: m
+#% description: MPI
+#%END
+import sys
+import os
+import socket
+import grass.script as grass
+import osgeo.gdal as gdal
+def main():
+ add = flags['a']
+ remove = flags['r']
+ orthoigen = flags['d']
+ mpi = flags['m']
+ host = options['host']
+ dport = options['dport']
+ pport = options['pport']
+ tile = options['tile']
+ np = options['np']
+ grassenv = grass.gisenv()
+ mappa = options['map'].replace("@"," ")
+ mappa = mappa.split()
+ nflags = len(filter(None, [add, remove, orthoigen]))
+ if nflags > 1:
+ grass.run_command('g.message' , message = 'Cannot add & remove a map or use orthoigen at the same time.')
+ if nflags < 1:
+ grass.run_command('g.message' , message = 'No action requested , please choose one from "-a : add" or "-r : remove" flags.')
+ try :
+ rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'cellhd')
+ mapfile = os.path.join(rasterpath, mappa[0])
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt/raster/')
+ #print vrtdir
+ except :
+ rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'cellhd')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt/raster/')
+ #print vrtdir
+ d = os.path.dirname(vrtdir)
+ if not os.path.exists(d):
+ os.makedirs(d)
+ #os.makedirs(d)
+ vrtfilename = mappa[0] + '.vrt'
+ output = os.path.join(vrtdir, vrtfilename)
+ if not os.path.exists(output):
+ gdal.GetDriverByName('VRT').CreateCopy(output,gdal.Open(mapfile))
+ #grass.run_command('r.out.gdal', format = 'VRT', type = 'Float64', input = mappa[0] , output = '%s' % (output))
+ proj_info = projinfo()
+ unit = proj_info['units']
+ if unit.lower() == 'meters':
+ zoom_position = setCPRJ(options['map'])
+ if unit.lower() == 'metres':
+ if unit.lower() == 'degrees':
+ zoom_position = setCLL(options['map'])
+ lat = zoom_position[0]
+ lon = zoom_position[1]
+ distance = zoom_position[2]
+ if nflags == 1:
+ if add :
+ try :
+ addzoom(output,lon,lat,distance,host,dport,pport)
+ print 'Added raster file :', mappa[0]
+ print 'Camera positioned to : '
+ print 'Longitude = ',lon
+ print 'Latitude = ', lat
+ print 'Altitude = ' , distance
+ except :
+ print "conecction error"
+ if remove :
+ removefile(output,host,dport)
+ print 'Removed raster file :', mappa[0]
+ if orthoigen :
+ if tile != '':
+ path = os.path.dirname(output)
+ elevdir = os.path.join(path,'elevation',mappa[0]+'/')
+ if not os.path.exists(elevdir):
+ os.makedirs(elevdir)
+ elev = mappa[0]+'.tiff'
+ exportiff(output,elev)
+ instr = make3d(tile, elev, elevdir)
+ os.system(instr)
+ if tile == '':
+ print 'please set the tile dimension'
+def exportiff(infile,outfile):
+ gdal.GetDriverByName('GTiff').CreateCopy(outfile,gdal.Open(infile))
+def addfile(output,host,dport):
+ overview = output.replace('.vrt','.ovr')
+ if not os.path.isfile(overview):
+ makeoverview(output)
+ ossim_data_xml = "<Add target=':idolbridge'><Image groupType='groundTexture'><filename>%s</filename> <id>%s</id><name>%s</name></Image></Add>" % (output,output,output)
+ ossimdata = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+ ossimdata.connect((host, int(dport)))
+ ossimdata.send(ossim_data_xml)
+ ossimdata.close()
+def zoomto(lon,lat,distance,host,pport):
+ ossim_zoom_xml = '<Set target=":navigator" vref="wgs84"><Camera><longitude>%s</longitude><latitude>%s</latitude><altitude>%s</altitude><heading>0</heading><pitch>0</pitch><roll>0</roll><altitudeMode>absolute</altitudeMode><range>%s</range></Camera></Set>' % (lon, lat, distance, distance)
+ ossimposition = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+ ossimposition.connect((host, int(pport)))
+ ossimposition.send(ossim_zoom_xml)
+ ossimposition.close()
+def removefile(output,host,dport):
+ ossim_data_xml = "<Remove target=':idolbridge' id='%s' />" % (output)
+ ossimdata.close()
+def addzoom(output,lon,lat,distance,host,dport,pport):
+ addfile(output,host,dport)
+ zoomto(lon,lat,distance,host,pport)
+def projinfo():
+ units = grass.read_command("g.proj", flags='p')
+ units = units.replace('-','')
+ units = grass.parse_key_val(units, ':')
+ units_key = units.keys()
+ for i in units_key :
+ key_value = str(units[i]).strip()
+ units[i] = key_value
+ return units
+def setCLL(map):
+ center = []
+ info_region = grass.read_command('g.region', flags = 'cael', rast = '%s' % (map))
+ dict_region = grass.parse_key_val(info_region, ':')
+ lon = dict_region['east-west center']
+ lat = dict_region['north-south center']
+ lon = str(lon)
+ lat = str(lat)
+ lon = lon.replace(':', " ")
+ lat = lat.replace(':', " ")
+ if lat[-1] == 'N':
+ signlat = 1
+ if lat[-1] == 'S':
+ signlat = -1
+ if lon[-1] == 'E':
+ signlon = 1
+ if lon[-1] == 'W':
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ lat = [float(i) for i in lat.split()]
+ lon = [float(i) for i in lon.split()]
+ lat = (lat[0] + (lat[1] / 60) + lat[2] / 3600) * float(signlat)
+ lon = (lon[0] + (lon[1] / 60) + lon[2] / 3600) * float(signlon)
+ ns = float(dict_region['north-south extent'])
+ we = float(dict_region['east-west extent'])
+ distance = (ns + we) / 2
+ center.append(lat)
+ center.append(lon)
+ center.append(distance)
+ return center
+def setCPRJ(map):
+ center = []
+ info_region = grass.read_command('g.region', flags = 'ael', rast = '%s' % (map))
+ lon = dict_region['center longitude']
+ lat = dict_region['center latitude']
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
+def makedir(path):
+ d = os.path.dirname(path)
+ os.makedirs(d)
+def WhichPlatform():
+ #global platform
+ platforms = platform.system()
+ return platforms
+def make3d(tile, elev, outdir):
+ systemplatform = WhichPlatform()
+ if systemplatform == 'Darwin':
+ orthoigenexec = '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
+ else :
+ orthoigenexec = 'ossim-orthoigen'
+ makedir(outdir)
+ kwl = 'elev.kwl'
+ template = 'igen.slave_tile_buffers: 5 \n'
+ template += 'igen.tiling.type: ossimTiling \n'
+ template += 'igen.tiling.tiling_distance: 1 1 \n'
+ template += 'igen.tiling.tiling_distance_type: degrees \n'
+ template += 'igen.tiling.delta: %s %s \n' % (tile,tile)
+ template += 'igen.tiling.delta_type: total_pixels \n'
+ template += 'igen.tiling.padding_size_in_pixels: 0 0 \n'
+ template += 'object1.description: \n'
+ template += 'object1.enabled: 1 \n'
+ template += 'object1.id: 1 \n'
+ template += 'object1.object1.description: \n'
+ template += 'object1.object1.enabled: 1 \n'
+ template += 'object1.object1.id: 2 \n'
+ template += 'object1.object1.resampler.magnify_type: bilinear \n'
+ template += 'object1.object1.resampler.minify_type: bilinear \n'
+ template += 'object1.object1.type: ossimImageRenderer \n'
+ template += 'object1.object2.type: ossimCastTileSourceFilter \n'
+ template += 'object1.object2.scalar_type: ossim_sint16 \n'
+ template += 'object1.type: ossimImageChain \n'
+ template += 'object2.type: ossimGeneralRasterWriter \n'
+ template += 'object2.byte_order: big_endian \n'
+ template += 'object2.create_overview: false \n'
+ template += 'object2.create_histogram: false \n'
+ template += 'object2.create_external_geometry: false \n'
+ template += 'product.projection.type: ossimEquDistCylProjection \n'
+ open(kwl,'w').write(template)
+ instr = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; '
+ if mpi :
+ instr += 'mpirun -np %s ' % np
+ instr += orthoigenexec
+ else :
+ instr += ' --tiling-template '
+ instr += kwl
+ instr +=' --view-template '
+ instr += kwl
+ instr +=' --writer-template '
+ instr += kwl
+ instr +=' --chain-template '
+ instr += kwl
+ instr += ' %s ' % elev
+ instr += '%s' % outdir
+ instr +='/%SRTM%'
+ return instr
+def makeoverview(input):
+ img2rrexec = '/Users/sasha/OssimBuilds/Release/ossim-img2rr'
+ else :
+ img2rrexec = 'ossim-img2rr'
+ if mpi :
+ os.system("mpirun -np %s %s %s" % np, img2rrexec, input)
+ else :
+ os.system("%s %s" % img2rrexec, input)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/ossim_grass/ossim_grass/r.planet/r.planet.py
___________________________________________________________________
Added: svn:executable
Added: grass-addons/ossim_grass/ossim_grass/v.planet/Makefile
--- grass-addons/ossim_grass/ossim_grass/v.planet/Makefile (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/v.planet/Makefile 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,7 @@
+PGM = v.planet.py
+default: script
Added: grass-addons/ossim_grass/ossim_grass/v.planet/description.html
--- grass-addons/ossim_grass/ossim_grass/v.planet/description.html (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/v.planet/description.html 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,34 @@
+<em><b>v.planet.py : </b></em> Scripts to generate vrt layer from a selected grass vector layer and add/zoomTo/remove the data to ossimplanet using the ossimplanet tcp listner.
+<h2>EXAMPLE</h2>
+v.planet.py map=elevation.10m -a
+</pre></div>
+<p>
+v.planet.py map=elevation.10m -r
+</pre></div>
+<p>
+<h2>SEE ALSO</h2>
+<em><A HREF="r.planet.html">r.planet.py</A></em>
+<h2>AUTHOR</h2>
+Massimo Di Stefano - <em><A HREF="mailto:massimodisasha at gmail.com">@-mail</A></em> <br>
Added: grass-addons/ossim_grass/ossim_grass/v.planet/ogrTovrt.py
--- grass-addons/ossim_grass/ossim_grass/v.planet/ogrTovrt.py (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/v.planet/ogrTovrt.py 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,139 @@
+# MODULE: ogrTovrt.py
+# relicensed with permission by
+# Frank Warmerdam - warmerdam at pobox.com - original author
+# original code : ogr2vrt.py
+# PURPOSE: Create OGR VRT from source datasource and
+# OMD associated style-file
+# COPYRIGHT: (c) 2010 by Massimo Di Stefano
+# for details.
+# REQUIRES: Gdal - python
+try:
+ from osgeo import osr, ogr, gdal
+except ImportError:
+ import osr, ogr, gdal
+import string
+import sys
+def GeomType2Name( type ):
+ if type == ogr.wkbUnknown:
+ return 'wkbUnknown'
+ elif type == ogr.wkbPoint:
+ return 'wkbPoint'
+ elif type == ogr.wkbLineString:
+ return 'wkbLineString'
+ elif type == ogr.wkbPolygon:
+ return 'wkbPolygon'
+ elif type == ogr.wkbMultiPoint:
+ return 'wkbMultiPoint'
+ elif type == ogr.wkbMultiLineString:
+ return 'wkbMultiLineString'
+ elif type == ogr.wkbMultiPolygon:
+ return 'wkbMultiPolygon'
+ elif type == ogr.wkbGeometryCollection:
+ return 'wkbGeometryCollection'
+ elif type == ogr.wkbNone:
+ return 'wkbNone'
+ elif type == ogr.wkbLinearRing:
+ return 'wkbLinearRing'
+ else:
+def Esc(x):
+ return gdal.EscapeString( x, gdal.CPLES_XML )
+def makestile(outfile, brush, pen, size, fill, thickness):
+ brush = brush.split(',')
+ pen = pen.split(',')
+ size = size.split(',')
+ outfile = outfile.replace('.vrt','')
+ outfile = outfile+'.omd'
+ omd = '// vector file rendering options\n'
+ omd += 'brush_color: %s %s %s \n' % (brush[0], brush[1], brush[2])
+ omd += 'pen_color: %s %s %s \n' % (pen[0], pen[1], pen[2])
+ omd += 'point_width_height: %s %s \n' % (size[0], size[1])
+ omd += 'fill_flag: %s \n' % (fill)
+ omd += 'thickness: %s \n' % (thickness)
+ open(outfile,'w').write(omd)
+def ogrvrt(infile,outfile):
+ layer_list = []
+ relative = "0"
+ schema=0
+ src_ds = ogr.Open( infile, update = 0 )
+ if len(layer_list) == 0:
+ for layer in src_ds:
+ layer_list.append( layer.GetLayerDefn().GetName() )
+ vrt = '<OGRVRTDataSource>\n'
+ for name in layer_list:
+ layer = src_ds.GetLayerByName(name)
+ layerdef = layer.GetLayerDefn()
+ vrt += ' <OGRVRTLayer name="%s">\n' % Esc(name)
+ vrt += ' <SrcDataSource relativeToVRT="%s" shared="%d">%s</SrcDataSource>\n' \
+ % (relative,not schema,Esc(infile))
+ if schema:
+ vrt += ' <SrcLayer>@dummy@</SrcLayer>\n'
+ else:
+ vrt += ' <SrcLayer>%s</SrcLayer>\n' % Esc(name)
+ vrt += ' <GeometryType>%s</GeometryType>\n' \
+ % GeomType2Name(layerdef.GetGeomType())
+ srs = layer.GetSpatialRef()
+ if srs is not None:
+ vrt += ' <LayerSRS>%s</LayerSRS>\n' \
+ % (Esc(srs.ExportToWkt()))
+ # Process all the fields.
+ for fld_index in range(layerdef.GetFieldCount()):
+ src_fd = layerdef.GetFieldDefn( fld_index )
+ if src_fd.GetType() == ogr.OFTInteger:
+ type = 'Integer'
+ elif src_fd.GetType() == ogr.OFTString:
+ type = 'String'
+ elif src_fd.GetType() == ogr.OFTReal:
+ type = 'Real'
+ elif src_fd.GetType() == ogr.OFTStringList:
+ type = 'StringList'
+ elif src_fd.GetType() == ogr.OFTIntegerList:
+ type = 'IntegerList'
+ elif src_fd.GetType() == ogr.OFTRealList:
+ type = 'RealList'
+ elif src_fd.GetType() == ogr.OFTBinary:
+ type = 'Binary'
+ elif src_fd.GetType() == ogr.OFTDate:
+ type = 'Date'
+ elif src_fd.GetType() == ogr.OFTTime:
+ type = 'Time'
+ elif src_fd.GetType() == ogr.OFTDateTime:
+ type = 'DateTime'
+ else:
+ type = 'String'
+ vrt += ' <Field name="%s" type="%s"' \
+ % (Esc(src_fd.GetName()), type)
+ if not schema:
+ vrt += ' src="%s"' % Esc(src_fd.GetName())
+ if src_fd.GetWidth() > 0:
+ vrt += ' width="%d"' % src_fd.GetWidth()
+ if src_fd.GetPrecision() > 0:
+ vrt += ' precision="%d"' % src_fd.GetPrecision()
+ vrt += '/>\n'
+ vrt += ' </OGRVRTLayer>\n'
+ vrt += '</OGRVRTDataSource>\n'
+ open(outfile,'w').write(vrt)
Added: grass-addons/ossim_grass/ossim_grass/v.planet/v.planet.py
--- grass-addons/ossim_grass/ossim_grass/v.planet/v.planet.py (rev 0)
+++ grass-addons/ossim_grass/ossim_grass/v.planet/v.planet.py 2010-04-24 10:44:19 UTC (rev 42013)
@@ -0,0 +1,311 @@
+# PURPOSE:
+# for details.
+#%module
+#% description:
+#% keywords: vector
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of vector map
+#% required: yes
+#%end
+#%option
+#% key: host
+#% type: string
+#% key_desc: host
+#% required : no
+#%end
+#%option
+#% key: dport
+#% type: integer
+#% key_desc: dport
+#% answer: 8000
+#% required : no
+#%end
+#%option
+#% key: pport
+#% type: integer
+#% key_desc: port
+#% answer: 7000
+#% required : no
+#%end
+#%flag
+#% key: a
+#% description: Add vector
+#%END
+#%flag
+#% key: r
+#% description: Remove vector
+#%END
+#%option
+#% key: brush
+#% type: string
+#% key_desc: brush
+#% description: brush color
+#% required : no
+#%end
+#%option
+#% key: pen
+#% type: string
+#% key_desc: pen
+#% description: pen color
+#% required : no
+#%end
+#%option
+#% key: size
+#% type: string
+#% key_desc: size
+#% description: size
+#% required : no
+#%end
+#%option
+#% key: fill
+#% type: string
+#% key_desc: fill
+#% description: fill
+#% required : no
+#%end
+#%option
+#% key: thickness
+#% type: string
+#% key_desc: thickness
+#% description: thickness
+#% required : no
+#% answer: 1
+#%end
+import sys
+import os
+import socket
+import string
+try:
+from ogrTovrt import ogrvrt #, makestile
+def main():
+ add = flags['a']
+ nflags = len(filter(None, [add, remove]))
+ if nflags > 1:
+ grass.run_command('g.message' , message = 'Cannot add & remove a map at same time.')
+ if nflags < 1:
+ try :
+ vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vector' , mappa[0] )
+ mapfile = os.path.join(vectorpath, 'head')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector/')
+ except :
+ vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], mappa[0] )
+ mapfile = os.path.join(vectorpath, 'head' )
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector/')
+ os.makedirs(d)
+ ogrvrt(mapfile,output)
+ print 'try to make omd'
+ makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
+ if unit == 'Degrees':
+ if add :
+ try:
+ print 'Added vector file :', mappa[0]
+ except :
+ if remove :
+ print 'Removed vector file :', mappa[0]
+ ossimdata.close()
+ ossimdata.close()
+def projinfo():
+ return units
+def setCLL(map):
+ center = []
+ info_region = grass.read_command('g.region', flags = 'cael', vect = '%s' % (map))
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
+def setCPRJ(map):
+ center = []
+ info_region = grass.read_command('g.region', flags = 'ael', vect = '%s' % (map))
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
+ print 'vector object should alredy have internal preview, make overview skipped'
+ #os.system("ossim-img2rr %s" % input)
+ print brush, pen, size
+ print omd
+ sys.exit(main())
Property changes on: grass-addons/ossim_grass/ossim_grass/v.planet/v.planet.py
