[GRASS-SVN] r42014 - grass-addons/ossim_grass/r.planet
svn_grass at osgeo.org
Sat Apr 24 07:15:12 EDT 2010
Author: epifanio
Date: 2010-04-24 07:15:11 -0400 (Sat, 24 Apr 2010)
New Revision: 42014
grass-addons/ossim_grass/r.planet/description.html
grass-addons/ossim_grass/r.planet/r.planet.py
added flag to run the ossim executables using MPI (mpirun -np 'process number')
Modified: grass-addons/ossim_grass/r.planet/description.html
--- grass-addons/ossim_grass/r.planet/description.html 2010-04-24 10:44:19 UTC (rev 42013)
+++ grass-addons/ossim_grass/r.planet/description.html 2010-04-24 11:15:11 UTC (rev 42014)
@@ -1,9 +1,12 @@
<h2>DESCRIPTION</h2>
-<em><b>r.planet.py : </b></em> Scripts to generate vrt layer from a selected grass raster layer and add/zoomTo/remove the data to ossimplanet using the ossimplanet tcp listner.
+<em><b>r.planet.py : </b></em> Scripts to :
+<p>
+- generate vrt layer from a selected grass raster layer and add/zoomTo/remove the data from/to ossimplanet using the ossimplanet tcp listner.
+<p>
+- generate ossimplanet 3d tiles from elevation data.
<h2>EXAMPLE</h2>
Add selected map to ossimplanet screen and zoom to it :
@@ -16,6 +19,11 @@
r.planet.py map=elevation.10m -r
</pre></div>
<p>
+Generate 3D tiles :
+<div class="code"><pre>
+r.planet.py map=elevation.10m -d tile=3601
+</pre></div>
+<p>
<h2>REFERENCES</h2>
Modified: grass-addons/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-24 10:44:19 UTC (rev 42013)
+++ grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-24 11:15:11 UTC (rev 42014)
@@ -57,6 +57,14 @@
#% required : no
#%end
#%option
+#% key: np
+#% type: integer
+#% key_desc: Processor-Number
+#% answer: 0
+#% description: Mpi Processor Number
+#% required : no
+#%end
+#%option
#% key: tile
#% type: double
#% key_desc: tile
@@ -75,6 +83,10 @@
#% key: d
#% description: Orthoigen
#%END
+#%flag
+#% key: m
+#% description: MPI
+#%END
import sys
@@ -87,10 +99,12 @@
add = flags['a']
remove = flags['r']
orthoigen = flags['d']
+ mpi = flags['m']
host = options['host']
dport = options['dport']
pport = options['pport']
tile = options['tile']
+ np = options['np']
grassenv = grass.gisenv()
mappa = options['map'].replace("@"," ")
mappa = mappa.split()
@@ -277,7 +291,19 @@
if not os.path.exists(d):
os.makedirs(d)
+def WhichPlatform():
+ #global platform
+ platforms = platform.system()
+ return platforms
def make3d(tile, elev, outdir):
+ systemplatform = WhichPlatform()
+ if systemplatform == 'Darwin':
+ orthoigenexec = '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
+ else :
+ orthoigenexec = 'ossim-orthoigen'
makedir(outdir)
kwl = 'elev.kwl'
template = 'igen.slave_tile_buffers: 5 \n'
@@ -307,7 +333,11 @@
template += 'product.projection.type: ossimEquDistCylProjection \n'
open(kwl,'w').write(template)
instr = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; '
- instr += '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
+ if mpi :
+ instr += 'mpirun -np %s ' % np
+ instr += orthoigenexec
+ else :
instr += ' --tiling-template '
instr += kwl
instr +=' --view-template '
@@ -323,7 +353,14 @@
def makeoverview(input):
- os.system("ossim-img2rr %s" % input)
+ img2rrexec = '/Users/sasha/OssimBuilds/Release/ossim-img2rr'
+ else :
+ img2rrexec = 'ossim-img2rr'
+ if mpi :
+ os.system("mpirun -np %s %s %s" % np, img2rrexec, input)
+ else :
+ os.system("%s %s" % img2rrexec, input)
if __name__ == "__main__":
