[GRASS-SVN] r42058 - grass-addons/raster/r.fuzzy.system
Thu Apr 29 09:12:43 EDT 2010
Author: jarekj71
Date: 2010-04-29 09:12:42 -0400 (Thu, 29 Apr 2010)
New Revision: 42058
   grass-addons/raster/r.fuzzy.system/fuzzylogic.c
   grass-addons/raster/r.fuzzy.system/helpers.c
   grass-addons/raster/r.fuzzy.system/local_proto.h
   grass-addons/raster/r.fuzzy.system/main.c
   grass-addons/raster/r.fuzzy.system/system.c
small bug fixes
Modified: grass-addons/raster/r.fuzzy.system/fuzzylogic.c
--- grass-addons/raster/r.fuzzy.system/fuzzylogic.c	2010-04-28 21:18:00 UTC (rev 42057)
+++ grass-addons/raster/r.fuzzy.system/fuzzylogic.c	2010-04-29 13:12:42 UTC (rev 42058)
@@ -2,6 +2,7 @@
 float fuzzy(FCELL cell, SETS * set)
     float x;
     if (!set->side) {		/* both left and right */
@@ -52,13 +53,11 @@
     if (set->height < 1)
 	x = x * set->height;
     return (x >= 0 && x <= 1) ? x : -1;
-float f_and(float x, float y, int family)
+float f_and(float x, float y, logics family)
     switch (family) {
     case l_ZADEH:
@@ -91,9 +90,8 @@
     return -1;			/* error */
-float f_or(float x, float y, int family)
+float f_or(float x, float y, logics family)
-    float b;
     switch (family) {
@@ -125,7 +123,7 @@
-float f_not(float x, int family)
+float f_not(float x, logics family)
     if (family == l_HAMACHER)
Modified: grass-addons/raster/r.fuzzy.system/helpers.c
--- grass-addons/raster/r.fuzzy.system/helpers.c	2010-04-28 21:18:00 UTC (rev 42057)
+++ grass-addons/raster/r.fuzzy.system/helpers.c	2010-04-29 13:12:42 UTC (rev 42058)
@@ -97,11 +97,12 @@
     G_get_window(&window);
     num_points = sscanf(answer, "%lf,%lf", &x, &y);
-    r = (int)G_easting_to_col(x, &window);
-    c = (int)G_northing_to_row(y, &window);
+    c = (int)G_easting_to_col(x, &window);
+    r = (int)G_northing_to_row(y, &window);
 		get_rows(r);
     get_cells(c);
     result = implicate(); /* jump to different function */
     for (i = 0; i < nrules; ++i)
Modified: grass-addons/raster/r.fuzzy.system/local_proto.h
--- grass-addons/raster/r.fuzzy.system/local_proto.h	2010-04-28 21:18:00 UTC (rev 42057)
+++ grass-addons/raster/r.fuzzy.system/local_proto.h	2010-04-29 13:12:42 UTC (rev 42058)
@@ -183,9 +183,9 @@
 float parse_expression(int n);
 float defuzzify(float *agregate, int defuzzification, float max_antecedent);
-float f_and(float cellx, float celly, int family);
-float f_or(float cellx, float celly, int family);
-float f_not(float cellx, int family);
+float f_and(float cellx, float celly, logics family);
+float f_or(float cellx, float celly, logics family);
+float f_not(float cellx, logics family);
 float fuzzy(FCELL cell, SETS * set);
Modified: grass-addons/raster/r.fuzzy.system/main.c
--- grass-addons/raster/r.fuzzy.system/main.c	2010-04-28 21:18:00 UTC (rev 42057)
+++ grass-addons/raster/r.fuzzy.system/main.c	2010-04-29 13:12:42 UTC (rev 42058)
@@ -39,7 +39,7 @@
     file_vars = G_define_standard_option(G_OPT_F_INPUT);
     file_vars->key = "maps";
-    file_vars->required = NO;
+    file_vars->required = YES;
     file_vars->description = _("Name of fuzzy variable file");
     file_rules = G_define_standard_option(G_OPT_F_INPUT);
@@ -85,7 +85,7 @@
     in_coor_opt = G_define_option();	/* input coordinates de outlet */
     in_coor_opt->key = "coors";
     in_coor_opt->type = TYPE_STRING;
-    in_coor_opt->key_desc = "x|y";
+    in_coor_opt->key_desc = "x,y";
     in_coor_opt->answer = NULL;
     in_coor_opt->required = NO;
     in_coor_opt->multiple = NO;
@@ -107,6 +107,7 @@
     opt_output = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_output->description = _("Name of output file");
+		opt_output->required = NO;
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -118,6 +119,9 @@
     membership_only = (out_membership->answer != 0);
     coor_proc = (in_coor_opt->answer) ? 1 : 0;
+			if(!membership_only & (!output | !rule_name_file))
+		G_fatal_error(_("for standard analysis both output and rule file are required"));
     resolution = atoi(par_resolution->answer);
     if (resolution < 10)
 	G_fatal_error(_("Universe resolution too small, choose greater value"));
@@ -155,19 +159,18 @@
     nrows = G_window_rows();
     ncols = G_window_cols();
-    parse_map_file(var_name_file);
-    parse_rule_file(rule_name_file);
+		parse_map_file(var_name_file);
 			if (membership_only)
     show_membership();
+		parse_rule_file(rule_name_file);
     get_universe();
     open_maps();
-	antecedents = (float *)G_malloc(nrules * sizeof(float));
-    if (coor_proc)
-	process_coors(in_coor_opt->answer);
+		antecedents = (float *)G_malloc(nrules * sizeof(float));
+			if (coor_proc)
+		process_coors(in_coor_opt->answer);
     if ((outfd = G_open_raster_new(output, FCELL_TYPE)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), output);
@@ -176,7 +179,6 @@
     if (multiple)
 	create_output_maps();
     G_message("Calculate...");
Modified: grass-addons/raster/r.fuzzy.system/system.c
--- grass-addons/raster/r.fuzzy.system/system.c	2010-04-28 21:18:00 UTC (rev 42057)
+++ grass-addons/raster/r.fuzzy.system/system.c	2010-04-29 13:12:42 UTC (rev 42058)
@@ -22,7 +22,7 @@
 	     antecedents[j]) ? max_antecedent : antecedents[j];
-    if (max_antecedent == 0.)
+    if (max_antecedent == 0. && !coor_proc)
 	return -9999;		/* for all rules value is 0 */
     if (coor_proc)
@@ -87,6 +87,7 @@
     int set_index;
     float f_value;
     do {
 	if (s_rules[n].work_stack[i] == t_START) {	/* first token */
 	    if (i > 0)
@@ -97,11 +98,9 @@
 	if (s_rules[n].work_stack[i] == t_VAL) {
 	    f_value =
-		fuzzy(*s_rules[n].value_stack[i].value,
-		      s_rules[n].value_stack[i].set);
-	    values_stack[++val_top] =
-		(s_rules[n].value_stack[i].oper == '~') ?
-			f_not(f_value, family) :	f_value;
+		fuzzy(*s_rules[n].value_stack[i].value, s_rules[n].value_stack[i].set);
+	    values_stack[++val_top] =	(s_rules[n].value_stack[i].oper == '~') ?
+				f_not(f_value, family) :	f_value;
 	    continue;
